Резултати от 1 до 3 от общо 3
Проблем с .mkv файлове на Panasonic VIERA TX-L42E30E
  1. byb
    byb е офлайн
    Novice
    Nov 2011
    Защо някои .mkv файлове, плейъра на Panasonic VIERA TX-L42E30E не ги чете от флашка?
    Код:
     Чете:
    The Devil's Double LIMITED 2011 720p BluRay x264-Counterfeit\ctf-the.devils.double.720.mkv (4,36gb) DTS
    General
    Complete name          :\The Devil's Double LIMITED 2011 720p BluRay x264-Counterfeit\ctf-the.devils.double.720.mkv
    Format              : Matroska
    File size            : 4.36 GiB
    Duration             : 1h 48mn
    Overall bit rate         : 5 738 Kbps
    Encoded date           : UTC 2011-11-08 18:32:37
    Writing application       : mkvmerge v5.0.1 ('Es ist Sommer') built on Oct 9 2011 11:55:43
    Writing library         : libebml v1.2.2 + libmatroska v1.3.0
    Video
    Format              : AVC
    Format/Info           : Advanced Video Codec
    Format profile          : High@L4.1
    Format settings, CABAC      : Yes
    Format settings, ReFrames    : 5 frames
    Muxing mode           : Container profile=Unknown@4.1
    Codec ID             : V_MPEG4/ISO/AVC
    Duration             : 1h 48mn
    Bit rate             : 4 114 Kbps
    Nominal bit rate         : 4 227 Kbps
    Width              : 1 280 pixels
    Height              : 544 pixels
    Display aspect ratio       : 2.35:1
    Frame rate            : 23.976 fps
    Resolution            : 24 bits
    Colorimetry           : 4:2:0
    Scan type            : Progressive
    Bits/(Pixel*Frame)        : 0.246
    Stream size           : 3.13 GiB (72%)
    Writing library         : x264 core 119 r2106 07efeb4
    Encoding settings        : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=18 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=4227 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
    Audio
    Format              : DTS
    Format/Info           : Digital Theater Systems
    Codec ID             : A_DTS
    Duration             : 1h 48mn
    Bit rate mode          : Constant
    Bit rate             : 1 510 Kbps
    Channel(s)            : 6 channels
    Channel positions        : Front: L C R, Surround: L R, LFE
    Sampling rate          : 48.0 KHz
    Stream size           : 1.15 GiB (26%)
    Title              : english
    Не чете:
    Colombiana.2011.720p.BluRay.x264-TheWretched\wthd-colombiana.720p.mkv (4,35gb) DTS
    General
    Unique ID           : 237784377338194739309223124915586632207 (0xB2E39AF27884325EABE1E6DEFBA88A0F)
    Complete name         :\Colombiana.2011.READNFO.720p.BluRay.x264-TheWretched\wthd-colombiana.720p.mkv
    Format             : Matroska
    Format version         : Version 2
    File size           : 4.35 GiB
    Duration            : 1h 43mn
    Overall bit rate        : 6 026 Kbps
    Encoded date          : UTC 2011-11-26 05:00:30
    Writing application      : mkvmerge v4.9.1 ('Ich will') built on Jul 11 2011 23:53:15
    Writing library        : libebml v1.2.1 + libmatroska v1.1.1
    Video
    Format             : AVC
    Muxing mode          : Header stripping
    Duration            : 1h 43mn
    Bit rate            : 4 520 Kbps
    Height             : 544 pixels
    Frame rate           : 25.000 fps
    Color space          : YUV
    Chroma subsampling       : 4:2:0
    Bit depth           : 8 bits
    Bits/(Pixel*Frame)       : 0.260
    Stream size          : 3.18 GiB (73%)
    Encoding settings       : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-3 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=4520 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
    Language            : English
    Audio
    Format             : DTS
    Codec ID            : A_DTS
    Duration            : 1h 43mn
    Channel positions       : Front: L C R, Side: L R, LFE
    Bit depth           : 24 bits
    Compression mode        : Lossy
    Stream size          : 1.09 GiB (25%)
    Language            : English
    Предварително благодаря за отговорите.
  3. Moderator
    Aug 2006
    Re:Проблем с .mkv файлове на Panasonic VIERA TX-L42E30E
    Може би е затова:
    Изобщо не очаквай, че ще ти чете всички Mkv.
    Feb 2008
    При втория файл имаш:
    което е т.нар. "header compression", което дори моя външен плейър не го поддържаше докато не му ъпдейтнаха фърмуера и като цяло е нещо проблематично.
    Като не ти работи някой файл просто свали друг вариант и не го мисли много. Аз поне така правя.
    За да разбереш дали точно това е проблема (за науката!), може да пробваш да ремукснеш файла, използвайки следните инструкции:
    It is the Muxing mode : Header stripping. This is also called "header compression". Though it doesn't save enough space to matter.
    For some reason the Matroska developers made this mode the default earlier this summer. It doesn't work with most hardware players (including the EVA and also the WD Live).
    You have to re-process the files to remove the header compression. This doesn't hurt the quality at all, and is a pretty fast operation. If you are comfortable running command line tools, you can either use mkWDclean.exe (found at https://sourceforge.net/projects/mat...7.zip/download) or MKVMerge (found at http://www.videohelp.com/tools/mkvtoolnix)
    The command line strings are:
    mkWDclean input.mkv output.mkv
    mkvmerge -o output.mkv --compression -1:none input.mkv
    There are two other ways that don't require opening a command line shell:
    (a) You can use MKVMerge GUI, but it is tedious. You select every track (from the middle pane), select the "extra options" tab, and set "Compression:" to none. (blank is not good enough).
    (b) You can download VID2EVA from http://vid2eva.lefti.net. This is a freeware video conversion tool that I've put together. After installation you right click on the MKV and select "VID2EVA" then "transcode audio". For this particular file, it won't transcode since the audio is already AC3. But it will remove the header compression.
  1. Panasonic Viera и 3D субтитри
    От sp1der80 във форум Panasonic телевизори
    Отговори: 37
    Последно: 28-09-19, 14:44
  2. Странен проблем с HDMI-а на Panasonic Viera TX-L32C4E
    От sem-pai във форум Panasonic телевизори
    Отговори: 19
    Последно: 18-08-14, 12:33
  3. Проблем със субтитрите на телевизор Panasonic Viera TX-L47ET5E
    От tigarle във форум Panasonic телевизори
    Отговори: 16
    Последно: 24-10-13, 08:50
  4. TOSHIBA 42SL863 VS. PANASONIC TX-L42E30E
    От V.Valev във форум Toshiba телевизори
    Последно: 25-10-11, 19:11
  5. Субтитри за Panasonic Viera
    От gorogeorgiev във форум Panasonic телевизори
    Последно: 16-02-11, 23:55
