Страница 14 от 24 ПърваПърва ... 41213141516 ... ПоследноПоследно
Резултати от 196 до 210 от общо 346
Like Tree89Одобрявам
Panasonic телевизори 2016
  1. Senior Member Аватара на svetlio1
    #196
    Отговор: Panasonic телевизори 2016
    sirgeorge и ronnie72 харесват това.
    #197
    DX900
    http://www.fwdmagazine.be/fwd/164064...c-tx-65dx900e/
    DX780
    http://www.fwdmagazine.be/fwd/163976...c-tx-50dx780e/
    DS630
    http://hdtelevizija.com/2016/05/09/p...-tv-recenzija/
    DX600
    http://www.trustedreviews.com/panaso...40dx600-review
    Обръщам ви внимание, че в серия DX600 се използват два типа панели
    55"- IPS, 8-bit,
    49"- IPS, 8-bit
    40"- MVA, 8-bit
    Panasonic UltraHD TV 2016
    Product UHD
    Premium
    Dolby
    Vision
    HDR
    ________________
    Videopanel - LCD matrix
    ___________________
    Backlight
    Dimming
    ______________________
    Color Space
    _____________________________
    Contrast & Black level
    Viewing angle
    ____________
    SoC
    software
    OS
    ________________
    Bluetooth & ports
    ______________________________
    Networks
    _______________________________
    Tuner
    Picture Accuracy Out-of-the-Box (score out of 10)
    _______________
    Product
    CZ950 Yes ? Oled
    WRGB
    10bit,
    120/100Hz
    No
    Lan -
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Bluetooth
    Wi-Fi Direct
    DLNA (RUI2.0/DTCP-IP/DMP/DMR/DMS)
    2 x DVB-C/T2/S2,
    1 x SAT>IP Client & Server
    DVB-T2: HEVC H.264 и H.265
    Analog (PAL,SECAM)
    2 x CI+1.3
    HEVC
    CZ950
    DX900
    58", 65"
    Yes No Yes HDR10
    65"- max 1250cd/m2
    58"- max 1320cd/m2
    65, 58"- SMVA,
    TRUE 10bit
    120/100Hz
    FALD - 512 zones
    (32 columns x 16 rows)
    Honeycomb backlight structure
    Blue Leds (actually white
    LEDs "boosted"
    with red phosphorus)
    (BLS - Backlight Scaning) +
    (BFI - Black Frame Insertion)
    6 cooling fan backlight
    65"- DCI P3 - 98% / Rec.2020- 78%
    58"- DCI P3 - 96% / Rec.2020 - 74%
    58" - 4600:1 / 0.026cd/m2
    ANSI - 4100:1 / 0.023cd/m2
    65"- 42°(cone)
    58"- 46°(conе)
    Quad Core
    P163
    Firefox 2.5
    Bluetooth Ver. 4.0 (keyboards, mouse)
    1 x Ethernet RJ45
    2 x USB 2.0 (max500mA)
    1 x USB 3.0 (max900mA)
    1 x Ethernet RJ45
    1 x HDMI 1.4 (CEC)
    2 x HDMI 2.0 (ARC,CEC)
    1 x Satelite In (Main: F-type female)
    1 x Satelite In (Sub: F-type female)
    1 x AV Composite In
    1 x AV Component In
    1 x Optical Audio Out
    1 x 3.5mm Audio Out
    1 x Antena (RF)female
    1 x CI+ 1.3
    Card reader SD/SDHC
    Lan
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Wi-Fi Direct
    2x DVB-C/T2/S2,
    Analog (PAL,SECAM)
    2 x CI+1.3
    HEVC
    9 DX900
    DX800
    58", 50"
    Yes No Yes HDR10
    SMPTE standards
    ST2084, ST2086
    MVA,
    10bit (?),
    120/100Hz
    Edge led 58"-
    50"-
    58"-
    50"-
    58"-
    50"-
    Quad Core
    P163
    Firefox 2.5
    1 x Ethernet RJ45
    1 x Ethernet RJ45
    1 x HDMI 1.4 (CEC)
    1 x AV Composite In
    1 x AV Component In
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    Card reader SD/SDHC
    Lan
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Wi-Fi Direct
    2 x DVB-C/T2/S2,
    Analog (PAL,SECAM)
    2 x CI+1.3
    HEVC
    DX800
    CR850
    (model 2015 -CURVED)
    No No 65"- max 355cd/m2 SMVA,
    8bit+Hi-FRC
    120/100Hz
    65" - Direct led
    Local Dimmig-16 zones
    (8columns x 2rows)
    65"- DCI P3 - 84% 65"- / 0.05cd/m2
    55" -
    65" - 30°(cone) Bluetooth Ver. 4.0 (keyboards, mouse)
    1 x Ethernet RJ45
    1 x Ethernet RJ45
    1 x HDMI 1.4 (CEC)
    1 x AV Composite In
    1 x AV Component In
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    Card reader SD/SDHC
    Lan (10BASE-T/100BASE-TX)
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Wi-Fi Direct
    2 x DVB-C/T2/S2,
    Analog (PAL,SECAM)
    1 x CI+1.3
    HEVC
    CR850
    CR730
    (model 2015 - CURVED)
    No No Yes - HDR10
    max - 343cd/m2
    8bit+Hi-FRC
    120/100Hz
    Direct led
    Local Dimmig
    55"- 850:1 EBU / 401:1 ANSI 55" - 30°(cone) Bluetooth Ver. 4.0 (keyboards, mouse)
    1 x Ethernet RJ45
    1 x Ethernet RJ45
    1 x HDMI 1.4 (CEC)
    1 x AV Composite In
    1 x AV Component In
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    Card reader SD/SDHC
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Wi-Fi Direct
    2 x DVB-C/T2/S2,
    Analog (PAL,SECAM)
    CR750
    DX780
    65", 58", 50"
    No No Yes - HDR10
    65"- max......cd/m2
    55"- max 577cd/m2
    50"- max .....cd/m2
    65" -
    58" - MVA, 8-bit+Hi-FRC
    50" -
    120/100Hz + MCFI
    65" - Direct led
    50", 58" - Edge Led (below)
    50", 58" - Vertical Dimming
    65" -
    58" -
    50" - DCI P3 - 89% / Rec.2020 - 66%
    65" -
    58" -
    50" -
    65" -
    58" -
    50"-
    Quad Core
    P163
    Firefox 2.5
    1 x Ethernet RJ45
    1 x Ethernet RJ45
    1 x HDMI 1.4 (CEC)
    1 x AV Composite In
    1 x AV Component In
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    Card reader SD/SDHC
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Wi-Fi Direct
    2 x DVB-C/T2/S2,
    Analog (PAL,SECAM)
    2 x CI+1.3
    HEVC
    DX780
    DX750
    65", 58", 50"
    No
    No Yes - HDR10
    65" - max......cd/m2
    58" - max 550cd/m2
    50" - max.....cd/m2
    MVA,
    8-bit+FRC
    120/100Hz + MCFI
    65" -
    55" -
    50" -
    Local Dimmig
    65"-
    58"-
    50"- DCI P2 - 86% / Rec.2020 - 66%
    65"-
    58"-
    50"- ANSI 3795:1/
    black 0.29cd/m2
    65"-
    58"-
    50"-
    Quad Core
    P163
    Firefox 2.5
    1 x Ethernet RJ45
    1 x Ethernet RJ45
    1 x HDMI 1.4 (CEC)
    1 x AV Composite In
    1 x AV Component In
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    Card reader SD/SDHC
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Wi-Fi Direct
    DVB- C/T2/S2
    with PIP functions, PAP, PAT, PVR and Time shift
    Analog (PAL,SECAM)
    HEVC
    THX & ISF sertification
    Accurate Colour Drive: 3DLUT with 8000 points corrections
    DX750
    DX730
    58", 50", 40"
    No No No
    58"- max....cd/m2
    50"- max 317cd/m2
    MVA,
    8bit,
    60/50Hz + BLB
    Edge Led 58"-
    50"-
    40"-
    58"-
    50"- 4824:1 / 0.04cd/m2
    40"-
    58"-
    50"- 42° (cone)
    40"-
    Quad Core
    P193
    Firefox 2.5
    1 x Ethernet RJ45
    1 x Ethernet RJ45
    1 x HDMI 1.4 (CEC)
    1 x AV Composite In
    1 x AV Component In
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    Card reader SD/SDHC
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Wi-Fi Direct
    DVB-T/T2/C
    Analog (PAL,SECAM)
    DX730
    DX700
    58", 50"'40"
    No No No
    58"- max 350cd/m2
    58" - MVA, 8-bit
    50" - , 8-bit
    40" - MVA, 8-bit
    8bit,
    60/50Hz + BLB
    Edge Led
    Local Dimming
    58" - Rec.2020 - 68.27% 58" - 3184:1 / 0.038cd/m2
    ANSI - 2304:1 / 0.046cd/m2
    58"- 40°(conе)
    50"-
    40"-
    Quad Core
    P193
    Firefox 2.5
    Bluetooth Ver.4.0(keyboards, mouse)
    1 x Ethernet RJ45
    1 x USB 2.0 (max 500mA)
    1 x USB 3.0 (max 900mA)
    1 x HDMI 1.4 (CEC)
    1 x AV Composite in
    1 x AV Component in
    1 x 3.5mm Audio Out
    1 x Antena (RF) female
    1 x CI+ 1.3
    WiFi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Wi-Fi Direct
    DVB-C/T2/S/S2
    Analog (PAL,SECAM)
    9 DX700
    DX650
    58", 50",40"
    No No No
    58"- MVA, 8-bit
    50"- , 8-bit
    40"- MVA, 8-bit,
    60/50Hz + BLB
    58"-
    50"-
    40"-
    58"-
    50"-
    40"-
    58"-
    50"-
    40"-
    Quad Core
    Firefox 2.5
    1 x Ethernet RJ45
    1 x HDMI 1.4 (CEC)
    1 x AV Composite in
    1 x AV Component in
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Wi-Fi Direct
    DVB-T/T2/C
    Analog (PAL,SECAM)
    DX650
    DX600
    55", 49", 40"
    No No No
    55"- max 294cd/m
    55"- IPS, 8-bit,
    49"- IPS, 8-bit
    40"- MVA, 8-bit
    60/50Hz + BLB
    Edge Led 55"-
    49"-
    40"-
    55"-
    49"-
    40"-
    55"- 78° (cone)
    49"-
    40"-
    Firefox 2.5 1 x Ethernet RJ45
    1 x HDMI 1.4 (CEC)
    1 x AV Composite in
    1 x AV Component in
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Wi-Fi Direct
    DLNA
    DVB-T/T2/C
    Analog (PAL,SECAM)
    DX600
    Panasonic Full HD TV 2016
    Product UHD
    Premium
    Dolby
    Vision
    HDR
    ________________
    _________________
    Backlight
    Dimming
    Color Space
    Viewing angle
    ____________
    SoC
    software
    OS
    ________________
    Bluetooth & ports
    Networks
    Tuner
    _______________
    Product
    DS630
    50", 40", 32"
    No No No
    max - 362cd/m2
    MVA, 8bit,
    120/100Hz + BLB
    Edge Led
    No - only globally (Adaptive Backlight Dimming)
    50"- DCI P3 - 74%
    40"-
    32"-
    50"- 4311:1 /0.038cd/m2
    40"-
    32"-
    50"-
    40"-
    32"-
    P162
    my Home Screen 1.x
    Bluetooth 3.0(2.402GHz-2.480GHz)
    1 x Lan Ethernet RJ45
    1 x mini Jack (3.5mm) stereo
    1 x SCART
    1 x Component (RCA PIN type)
    Wi-Fi
    Wi-Fi Direct
    DLNA
    802.11 a/n
    5.180GHZ-5.320GHz,5.500GHz-5.580GHz
    5.660GHZ-5.700GHz
    802.11 b/g/n
    2.412GHz-2.472GHz
    Security
    WPA2-PSK(TKIP/AES)
    WPA-PSK(TKIP/AES)
    WEP(64-bit/128-bit)
    DVB-T/T2/C
    Analog (PAL,SECAM,NTSC)
    No HEVC
    DX630
    DS600
    50", 40", 32"
    No No No VA, 8bit,
    60/50Hz
    50"-
    40"-
    32"-
    50"-
    40"-
    32"-
    50"-
    40"-
    32"-
    P161 Bluetooth 3.0(2.402GHz-2.480GHz)
    Wi-Fi
    Wi-Fi Direct
    DLNA
    802.11 a/n
    5.660GHZ-5.700GHz
    802.11 b/g/n
    2.412GHz-2.472GHz
    Security
    WPA2-PSK(TKIP/AES)
    WPA-PSK(TKIP/AES)
    WEP(64-bit/128-bit)
    DVB-T/T2/C
    Analog (PAL,SECAM)
    No HEVC
    DX600
    DS500
    55", 49", 40",32",24"
    No No No
    49"- max 314cd/m2
    IPS, 8bit,
    60/50Hz
    Edge Led 55"-
    49"-
    40"-
    32"-
    55"-
    49"- 882:1 /
    40"-
    32"-
    55"-
    49"- 66° (cone)
    40"-
    32"-
    Wi-Fi
    Wi-Fi Direct
    DLNA
    802.11 a/n
    5.660GHZ-5.700GHz
    802.11 b/g/n
    2.412GHz-2.472GHz
    Security
    WPA2-PSK(TKIP/AES)
    WPA-PSK(TKIP/AES)
    WEP(64-bit/128-bit)
    DVB-T/T2/C
    Analog (PAL,SECAM)
    No HEVC
    DS500
    DS400
    40"
    No No No VA, 8bit,
    60/50Hz
    40"- 40"- 40"- P161 DVB-T/T2/C
    Analog (PAL,SECAM)
    DS400
    Този пост е редактиран от hristoslav2; 15-05-16 в 16:25.
  4. Moderator
    Aug 2006
    #198
    Някой пробвал ли на новите 4к телевзори дали може да си пускат тези 4k web-dl клипове и как вървят?
  5. Senior Member Аватара на iveto
    Jan 2013
    Свети Влас
    #199
    Вървят страхотно....
    lazarus18 одобрява това.
  6. Senior Member Аватара на Frost
    May 2007
    #200
    Вървят, но като цяло няма особено подобрение спрямо 1080p Blu-ray. Истината е в UHD HDR дисковете, но още не е разбита защитата им, така че ще почакаме...
    #201
    Цитат Първоначално публикувано от Frost Виж публикацията
    А истината е, че всички появили се UHD Blu-ray дискове са мастерирани от 2K в 4K(ъпскейл - понеже филмите оригинално са снимани в 2К)...+ добавен статичен HDR.
    4K Movies, 4K Blu-ray Movies, 4K Blu-ray Players
    с един гол сертификат
    UHD ALLIANCE PRESS RELEASE April 12, 2016 – UHD Alliance
    сега индустрията разработва нов стандарт за динамични метадани за HDR...с цел да догонят Dolby Vision
    Samsung Proposes Dynamic Metadata at NAB 2016
    SMPTE’s new ST2094 specification
    https://kws.smpte.org/kws/public/pro...project_id=294
    ITU-T liaison statements database
    http://audiovision.de/2016/04/14/pan...65dxw904-test/
    Този пост е редактиран от hristoslav2; 14-05-16 в 20:39.
    #202
    DX900
    Test: Panasonic TX-65DX900E - fwd - FWD Magazine
    DX780
    Test: Panasonic TX-50DX780E - fwd - FWD Magazine
    DS630
    Panasonic 50DS630E (DS630E) Smart Full HD TV – recenzija – HD Televizija – HDTV eZine
    DX600
    Panasonic TX-40DX600 hand-on | TrustedReviews
    DS630
    TX-50DS630E:VA panel RGB subixel structure , 1000 Hz BMR (Backlight Motion Rate):100/120Hz with MCFI.
    source videos:[you tube - hdtelevizija.com]
    Product UHD
    Premium
    Dolby
    Vision
    HDR
    ________________
    __________________________________
    Backlight
    Dimming
    Color Space
    Viewing angle
    ____________
    SoC
    software
    OS
    _________________
    Bluetooth & ports
    Networks
    Tuner
    _______________
    Product
    CZ950 Yes ? Oled, WRGB, 10bit, 120/100Hz No
    Lan -
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Bluetooth
    Wi-Fi Direct
    2 x DVB-C/T2/S2,
    Analog (PAL,SECAM)
    2 x CI+1.3
    HEVC
    CZ950
    DX900
    58", 65"
    Yes No Yes HDR10
    65"- max 1250cd/m2
    58"- max 1320cd/m2
    65"- SMVA, 10-bit, 120/100Hz
    58"- SMVA, 10-bit, 120/100Hz
    FALD - 512 zones
    LEDs "boosted"
    65"- 42°(cone)
    58"- 46°(conе)
    Quad Core
    P163
    Firefox 2.5
    1 x Ethernet RJ45
    1 x Ethernet RJ45
    1 x HDMI 1.4 (CEC)
    1 x AV Composite In
    1 x AV Component In
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    Card reader SD/SDHC
    Lan
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Wi-Fi Direct
    2x DVB-C/T2/S2,
    Analog (PAL,SECAM)
    2 x CI+1.3
    HEVC
    9 DX900
    DX800
    58", 50"
    Yes No Yes HDR10
    SMPTE standards
    ST2084, ST2086
    50"- SMVA, 10-bit, 120/100Hz
    Edge led 58"-
    50"-
    58"-
    50"-
    58"-
    50"-
    Quad Core
    P163
    Firefox 2.5
    1 x Ethernet RJ45
    1 x Ethernet RJ45
    1 x HDMI 1.4 (CEC)
    1 x AV Composite In
    1 x AV Component In
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    Card reader SD/SDHC
    Lan
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Wi-Fi Direct
    2 x DVB-C/T2/S2,
    Analog (PAL,SECAM)
    2 x CI+1.3
    HEVC
    DX800
    CR850
    No No 65"- max 355cd/m2 SMVA, 8bit+Hi-FRC, 120/100Hz 65" - Direct led
    (8columns x 2rows)
    55" -
    65" - 30°(cone) -
    1 x Ethernet RJ45
    1 x Ethernet RJ45
    1 x HDMI 1.4 (CEC)
    1 x AV Composite In
    1 x AV Component In
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    Card reader SD/SDHC
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Wi-Fi Direct
    2 x DVB-C/T2/S2,
    Analog (PAL,SECAM)
    1 x CI+1.3
    HEVC
    CR850
    CR730
    No No Yes - HDR10
    max - 343cd/m2
    8bit+Hi-FRC, 120/100Hz Direct led
    Local Dimmig
    55"- 850:1 EBU / 401:1 ANSI 55" - 30°(cone) -
    1 x Ethernet RJ45
    1 x Ethernet RJ45
    1 x HDMI 1.4 (CEC)
    1 x AV Composite In
    1 x AV Component In
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    Card reader SD/SDHC
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Wi-Fi Direct
    2 x DVB-C/T2/S2,
    Analog (PAL,SECAM)
    CR750
    DX780
    65", 58", 50"
    No No Yes - HDR10
    65"- max......cd/m2
    55"- max 577cd/m2
    50"- max .....cd/m2
    65"- SMVA, 10-bit, 120/100Hz + MCFI
    58"- SMVA, 10-bit, 120/100Hz + MCFI
    50"- SMVA, 10-bit, 120/100Hz + MCFI
    65" - Direct led
    65" -
    58" -
    65" -
    58" -
    50" -
    65" -
    58" -
    50"-
    Quad Core
    P163
    Firefox 2.5
    1 x Ethernet RJ45
    1 x Ethernet RJ45
    1 x HDMI 1.4 (CEC)
    1 x AV Composite In
    1 x AV Component In
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    Card reader SD/SDHC
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Wi-Fi Direct
    2 x DVB-C/T2/S2,
    Analog (PAL,SECAM)
    2 x CI+1.3
    HEVC
    DX780
    DX750
    65", 58", 50"
    No
    No Yes - HDR10
    58" - max 550cd/m2
    50" - max.....cd/m2
    65" -
    55" -
    50" -
    Local Dimmig
    65"-
    58"-
    65"-
    58"-
    50"- ANSI 3795:1/
    black 0.29cd/m2
    65"-
    58"-
    50"-
    Quad Core
    P163
    Firefox 2.5
    1 x Ethernet RJ45
    1 x Ethernet RJ45
    1 x HDMI 1.4 (CEC)
    1 x AV Composite In
    1 x AV Component In
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    Card reader SD/SDHC
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Wi-Fi Direct
    DVB- C/T2/S2
    Analog (PAL,SECAM)
    HEVC
    DX750
    DX730
    58", 50", 40"
    No No No
    58"- max....cd/m2
    50"- max 317cd/m2
    58"- SMVA, 10-bit, 60/50Hz + BLB
    50"- SMVA, 10-bit, 60/50Hz + BLB
    Edge Led 58"-
    50"-
    40"-
    58"-
    40"-
    58"-
    50"- 42° (cone)
    40"-
    Quad Core
    P193
    Firefox 2.5
    1 x Ethernet RJ45
    1 x Ethernet RJ45
    1 x HDMI 1.4 (CEC)
    1 x AV Composite In
    1 x AV Component In
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    Card reader SD/SDHC
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Wi-Fi Direct
    DVB-T/T2/C
    Analog (PAL,SECAM)
    DX730
    DX700
    58", 50"'40"
    No No No
    58" - HDR 350cd/m2
    50" - HDR 350cd/m2
    58" - SMVA, 10-bit, 60/50Hz + BLB + MCFI
    50" - SMVA, 10-bit, 60/50Hz + BLB + MCFI
    40" - SMVA, 10-bit, 60/50Hz + BLB + MCFI
    Edge Led - below
    Vertical Local Dimming
    50Ч -
    50" - 4700:1
    58"- 40°(conе)
    50"-
    40"-
    Quad Core
    P193
    Firefox 2.5
    1 x Ethernet RJ45
    1 x HDMI 1.4 (CEC)
    1 x AV Composite in
    1 x AV Component in
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    WiFi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Wi-Fi Direct
    DVB-C/T2/S/S2
    Analog (PAL,SECAM)
    9 DX700
    DX650
    58", 50",40"
    No No No
    58"- SMVA, 8-bit, 60/50Hz + BLB
    50"- SMVA, 8-bit, 60/50Hz + BLB
    40"- SMVA, 8-bit, 60/50Hz + BLB
    58"-
    50"-
    40"-
    58"-
    50"-
    40"-
    58"-
    50"-
    40"-
    Quad Core
    Firefox 2.5
    1 x Ethernet RJ45
    1 x HDMI 1.4 (CEC)
    1 x AV Composite in
    1 x AV Component in
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Wi-Fi Direct
    DVB-T/T2/C
    Analog (PAL,SECAM)
    DX650
    DX600
    55", 49", 40"
    No No No
    55"- max 294cd/m
    55"- IPS, 8-bit, 60/50Hz + BLB
    49"- IPS, 8-bit, 60/50Hz + BLB
    40"- MVA, 8-bit, 60/50Hz + BLB
    Edge Led 55"-
    49"-
    40"-
    55"-
    49"-
    40"-
    55"- 78° (cone)
    49"-
    40"-
    Firefox 2.5
    1 x Ethernet RJ45
    1 x HDMI 1.4 (CEC)
    1 x AV Composite in
    1 x AV Component in
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Wi-Fi Direct
    DLNA
    DVB-T/T2/C
    Analog (PAL,SECAM)
    DX600
    Product UHD
    Premium
    Dolby
    Vision
    HDR
    ________________
    _________________
    Backlight
    Dimming
    Color Space
    Viewing angle
    ____________
    SoC
    software
    OS
    _________________
    Bluetooth & ports
    Networks
    Tuner
    _______________
    Product
    DS630
    50", 40", 32"
    No No No
    max - 362cd/m2
    50"- MVA, 8-bit, 120/100Hz + BLB + MCFI
    40"- MVA, 8-bit, 120/100Hz + BLB + MCFI
    32"- ?
    Edge Led
    Only globally (Adaptive Backlight Dimming)
    50"- DCI P3 - 74%
    40"-
    32"-
    40"-
    32"-
    50"-
    40"-
    32"-
    P162
    my Home Screen 1.0
    3 x HDMI 1.4 (CEC)
    1 x SCART
    Wi-Fi
    Wi-Fi Direct
    DLNA
    802.11 a/n
    5.660GHZ-5.700GHz
    802.11 b/g/n
    2.412GHz-2.472GHz
    Security
    WPA2-PSK(TKIP/AES)
    WPA-PSK(TKIP/AES)
    WEP(64-bit/128-bit)
    DVB-T/T2/C
    No HEVC
    DX630
    DS600
    50", 40", 32"
    No No No 50" -
    40" - SMVA, 8bit, 60/50Hz
    32" -
    50"-
    40"-
    32"-
    50"-
    40"-
    32"-
    50"-
    40"-
    32"-
    P161
    3 x HDMI 1.4 (CEC)
    Wi-Fi
    Wi-Fi Direct
    DLNA
    802.11 a/n
    5.660GHZ-5.700GHz
    802.11 b/g/n
    2.412GHz-2.472GHz
    Security
    WPA2-PSK(TKIP/AES)
    WPA-PSK(TKIP/AES)
    WEP(64-bit/128-bit)
    DVB-T/T2/C
    Analog (PAL,SECAM)
    No HEVC
    DX600
    DS500
    No No No
    49"- max 314cd/m2
    55" - IPS, 8bit, 60/50Hz
    49" -
    40" -
    32" -
    24" -
    Edge Led 55"-
    49"-
    40"-
    32"-
    55"-
    49"- 882:1 /
    40"-
    32"-
    55"-
    49"- 66° (cone)
    40"-
    32"-
    P161
    Wi-Fi
    Wi-Fi Direct
    DLNA
    802.11 a/n
    5.660GHZ-5.700GHz
    802.11 b/g/n
    2.412GHz-2.472GHz
    Security
    WPA2-PSK(TKIP/AES)
    WPA-PSK(TKIP/AES)
    WEP(64-bit/128-bit)
    DVB-T/T2/C
    Analog (PAL,SECAM)
    No HEVC
    DS500
    DS400
    40"
    No No No 40" - VA, 8bit, 60/50Hz 40"- 40"- 40"- -
    P161
    DVB-T/T2/C
    Analog (PAL,SECAM)
    DS400
    Този пост е редактиран от hristoslav2; 22-05-16 в 00:43.
    #203
    Panasonic TX-50DX700E TEST - Ultra HD LCD LED - PANASONIC - HDTV Centrum Polska
    google translate pl to en
    TX-50DX700E subpixel panel structure RGB, VA, 4K 1400 Hz BMR, 50/60Hz panel despite having regulatory Intelligent Frame Creation's,
    WCG DCI P3: 94%, Rec 2020: 74%, Maximum brightness HDR - the entire screen : 350cd / m2
    Двете позиции на краката - от 1:40
    Panasonic 58DX700E (DX700E) Firefox Ultra HD TV – recenzija – HD Televizija – HDTV eZine
    TX -58DX700E: VA Panel, 1400 Hz BMR IFC (Backlight Motion Rate), 50/60Hz
    Motion Resolution (Monoscope Test, Max. 1080): 450 Max.
    WCG, Coverage of DCI-P3: 90%,
    the Maximum brightness [cd/m2] (factory): 333cd/m2
    Panasonic DX700E UHD TV motion resolution test
    Този пост е редактиран от hristoslav2; 22-05-16 в 19:54.
    #204
    Panasonic TX-58DX700 (TX-58DX700F) : Test complet
    google translate fr to en
    Test Panasonic DX750 : un TV LED Ultra HD 4K s
    Прави ми впечатление еднаквата структура на пикселите в модели DX900 / DX780 / Dx750 / DX730 / DX700
    Product UHD
    Premium
    Dolby
    Vision
    HDR
    ________________
    Backlight
    Dimming
    _____________________________________
    Color Space
    Contrast
    White & Black level
    Viewing angle
    _____________
    Input Lag
    SoC
    software
    OS
    _________________
    Conectors
    _________________
    Networks
    Tuner
    _______________
    Product
    Lan -
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Bluetooth
    Wi-Fi Direct
    2 x DVB-C/T2/S2,
    Analog (PAL,SECAM)
    2 x CI+1.3
    HEVC
    CZ950
    DX900
    58", 65"
    Yes No 65"- max 1250cd/m2
    58"- max 1320cd/m2
    Yes HDR10
    SMPTE standards
    ST2084, ST2086
    65"' - FALD - 512 zones (32 columns x 16 rows)
    58" - FALD - 512 zones (32 columns x 16 rows)
    LEDs "boosted"
    65"- DCI P3 - 98% / Rec.2020 - 78%
    65"
    58"
    Native - 4600:1 (0.026cd/m2)
    ANSI - 4100:1 (0.023cd/m2
    65"- 42°(cone)
    58"- 46°(conе)
    Quad Core
    P163
    Firefox 2.5
    1 x Ethernet RJ45
    1 x Ethernet RJ45
    1 x HDMI 1.4 (CEC)
    1 x AV Composite In
    1 x AV Component In
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    Card reader SD/SDHC
    Lan
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Wi-Fi Direct
    2x DVB-C/T2/S2,
    Analog (PAL,SECAM)
    2 x CI+1.3
    HEVC
    9 DX900
    DX800
    58", 50"
    Yes No 58" - max...cd/m2
    50" - max...cd/m2
    Yes HDR10
    SMPTE standards
    ST2084, ST2086
    58"- SMVA, 8-bit+Hi-FRC, 120/100Hz
    50"- SMVA, 8-bit+Hi-FRC, 120/100Hz
    58" - Edge Led
    50" -
    58"-
    50"-
    58"-
    50"-
    58"-
    50"-
    Quad Core
    P163
    Firefox 2.5
    1 x Ethernet RJ45
    1 x Ethernet RJ45
    1 x HDMI 1.4 (CEC)
    1 x AV Composite In
    1 x AV Component In
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    Card reader SD/SDHC
    Lan
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Wi-Fi Direct
    2 x DVB-C/T2/S2,
    Analog (PAL,SECAM)
    2 x CI+1.3
    HEVC
    DX800
    DX780
    65", 58", 50"
    No No 65" - max......cd/m2
    55" - max 577cd/m2
    50" - max .....cd/m2
    Compatible
    65" - SMVA, 8-bit+FRC, 120/100Hz + MCFI
    58" - SMVA, 8-bit+FRC, 120/100Hz + MCFI
    50" - SMVA, 8-bit+FRC, 120/100Hz + MCFI
    65" - Direct Led, Local Dimming ?
    58" - Edge Led (below) Vertical Dimming
    50" - Edge Led (below) Vertical Dimming
    65" -
    58" -
    65" -
    58" -
    50" -
    65" -
    58" -
    50" -
    Quad Core
    P163
    Firefox 2.5
    1 x Ethernet RJ45
    1 x Ethernet RJ45
    1 x HDMI 1.4 (CEC)
    1 x AV Composite In
    1 x AV Component In
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    Card reader SD/SDHC
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Wi-Fi Direct
    2 x DVB-C/T2/S2,
    Analog (PAL,SECAM)
    2 x CI+1.3
    HEVC
    DX780
    DX750
    65", 58", 50"
    No
    No 65" - max 550cd/m2
    58" - max 550cd/m2
    50" - max 550cd/m2
    Compatible
    50" -
    58" - EdgE Led (below) Vertical Dimming
    65" -
    58" - DCI P2 - 94% / Rec.2020 -
    50" - DCI P2 - 86% / Rec.2020 - 66%
    65" -
    58" -
    50" - ANSI 3795:1/ 0.29cd/m2
    65" -
    58" -
    50" -
    65"
    58"
    50"
    Quad Core
    P163
    Firefox 2.5
    1 x Ethernet RJ45
    1 x Ethernet RJ45
    1 x HDMI 1.4 (CEC)
    1 x AV Composite In
    1 x AV Component In
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    Card reader SD/SDHC
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Wi-Fi Direct
    DVB- C/T2/S2
    Analog (PAL,SECAM)
    HEVC
    DX750
    DX730
    58", 50", 40"
    No No 58"- max....cd/m2
    50"- max 317cd/m2
    40" - max...cd/m2
    Compatible
    50" - SMVA, 8-bit, 60/50Hz + BLB
    40" -
    50" - Edge Led (below) Verical Dimming
    40" - Edge Led (below) Vertical Dimming
    58" -
    50" -
    40" -
    58" -
    50" - 4824:1 / 0.04cd/m2
    40" -
    58" -
    50" - 42° (cone)
    40" -
    58"
    50"
    40"
    Quad Core
    P193
    Firefox 2.5
    1 x Ethernet RJ45
    1 x Ethernet RJ45
    1 x HDMI 1.4 (CEC)
    1 x AV Composite In
    1 x AV Component In
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    Card reader SD/SDHC
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Wi-Fi Direct
    DVB-T/T2/C
    Analog (PAL,SECAM)
    DX730
    DX700
    58", 50"'40"
    No No 58" - HDR 350cd/m2
    50" - HDR 350cd/m2
    40" -
    Compatible
    58" - SMVA, 8-bit, 60/50Hz + BLB + MCFI
    50" - SMVA, 8-bit, 60/50Hz + BLB + MCFI
    40" - SMVA, 8-bit, 60/50Hz + BLB + MCFI
    50" -
    40" -
    58"
    Native 5736:1 (153cd/m2 / 0.03cd/m2)
    3184:1 / 0.038cd/m2
    50" - 4700:1
    40"
    58" - 40°(conе)
    50" -
    40" -
    58"
    Game - 49.8ms
    by default - 69.7ms
    50" -
    40" -
    Quad Core
    P193
    Firefox 2.5
    1 x Ethernet RJ45
    1 x HDMI 1.4 (CEC)
    1 x AV Composite in
    1 x AV Component in
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    WiFi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Wi-Fi Direct
    DVB-C/T2/S/S2
    Analog (PAL,SECAM)
    9 DX700
    DX650
    58", 50",40"
    No No 58" -
    50" -
    40" -
    No
    58" - Edge Led
    50" - Edge Led
    40" - Edge Led
    58"-
    50"-
    40"-
    58"-
    50"-
    40"-
    58"-
    50"-
    40"-
    Quad Core
    Firefox 2.5
    1 x Ethernet RJ45
    1 x HDMI 1.4 (CEC)
    1 x AV Composite in
    1 x AV Component in
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Wi-Fi Direct
    DVB-T/T2/C
    Analog (PAL,SECAM)
    DX650
    DX600
    55", 49", 40"
    No No 55" - max 294cd/m2
    49" - max...cd/m2
    40" - max...cd/m2
    No
    55" - Edge Led
    49" - Edge Led
    40" - Edge Led
    55"-
    49"-
    40"-
    55"-
    49"-
    40"-
    55"- 78° (cone)
    49"-
    40"-
    Firefox 2.5
    1 x Ethernet RJ45
    1 x HDMI 1.4 (CEC)
    1 x AV Composite in
    1 x AV Component in
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Wi-Fi Direct
    DLNA
    DVB-T/T2/C
    Analog (PAL,SECAM)
    DX600
    Product UHD
    Premium
    Dolby
    Vision
    HDR
    _________________
    _________________
    Backlight
    Dimming
    Color Space
    Viewing angle
    ____________
    Input Lag
    _____________
    SoC
    software
    OS
    _________________
    Conectors
    Networks
    Tuner
    _______________
    Product
    DS630
    50", 40", 32"
    No No 50" - max - 362cd/m2
    40" - max...cd/m2
    32" - max...cd/m2
    No
    32"- ?, 8-bit, 60/50Hz
    50" - Edge Led
    40" - Edge Led
    32" - Edge Led
    Only globally
    50"- DCI P3 - 74%
    40"-
    32"-
    40"-
    32"-
    50"-
    40"-
    32"-
    P162
    my Home Screen 1.0
    3 x HDMI 1.4 (CEC)
    1 x SCART
    Wi-Fi
    Wi-Fi Direct
    DLNA
    802.11 a/n
    5.660GHZ-5.700GHz
    802.11 b/g/n
    2.412GHz-2.472GHz
    Security
    WPA2-PSK(TKIP/AES)
    WPA-PSK(TKIP/AES)
    WEP(64-bit/128-bit)
    DVB-T/T2/C
    No HEVC
    DX630
    DS600
    50", 40", 32"
    No No No 50" - , 8-bit, 60/50Hz
    32" - , 8/-bit, 60/50Hz
    50" - Edge Led
    40" - Edge Led
    32" - Edge Led
    50"-
    40"-
    32"-
    50"-
    40"-
    32"-
    50"-
    40"-
    32"-
    P161
    3 x HDMI 1.4 (CEC)
    Wi-Fi
    Wi-Fi Direct
    DLNA
    802.11 a/n
    5.660GHZ-5.700GHz
    802.11 b/g/n
    2.412GHz-2.472GHz
    Security
    WPA2-PSK(TKIP/AES)
    WPA-PSK(TKIP/AES)
    WEP(64-bit/128-bit)
    DVB-T/T2/C
    Analog (PAL,SECAM)
    No HEVC
    DX600
    DS500
    No No 55" - max...cd/m2
    49" - max 314cd/m2
    40" - max...cd/m2
    32" - max...cd/m2
    24" - max...cd/m2
    No
    49" - , 8-bit, 60/50Hz
    40" - , 8-bit, 60/50Hz
    32" - , 8-bit, 60/50Hz
    24" - , 8-bit, 60/50Hz
    55" - Edge Led
    49" - Edge Led
    40" - Edge Led
    32" - Edge Led
    24" - Edge Led
    55"-
    49"-
    40"-
    32"-
    24" -
    55"-
    49"- 882:1 /
    40"-
    32"-
    24" -
    55"-
    49"- 66° (cone)
    40"-
    32"-
    24" -
    P161
    Wi-Fi
    Wi-Fi Direct
    DLNA
    802.11 a/n
    5.660GHZ-5.700GHz
    802.11 b/g/n
    2.412GHz-2.472GHz
    Security
    WPA2-PSK(TKIP/AES)
    WPA-PSK(TKIP/AES)
    WEP(64-bit/128-bit)
    DVB-T/T2/C
    Analog (PAL,SECAM)
    No HEVC
    DS500
    DS400
    40"
    No No 40" - max...cd/m2
    No
    P161
    DVB-T/T2/C
    Analog (PAL,SECAM)
    DS400
    Този пост е редактиран от hristoslav2; 26-05-16 в 20:26.
    #205
    #206
    Catalog
    http://www.panasonic.com/content/dam...hjahr_2016.pdf
    DX900
    https://www.avforums.com/threads/cur...ssues.2025821/
    10bit (for RGB model -1024x1024x1024) - > 1073741824 colors - но заради спецификата на работа, LCD матрицата не може да възпроизведе всичките 1024 дискретни степени на яркост на всеки цвят. Още с прехода от черно към първа степен на яркост на домейн - скача на 16 степен - > 0-16, а от предпоследната на последната степен на яркост, пиксела прескача от 1002 на 1024....От тук имаме и ограничен цветови диапазон...и липса на детайли в тъмните и светлите части на картината.
    Същото важи и за 8-bit (256x256x256) -> реалният диапазон е 16-235 степени...
    TEST
    DX900
    Test Panasonic DX900 : un contraste record et une expérience HDR exceptionnelle ! | HDfever
    Panasonic DX750 review - FlatpanelsHD
    Panasonic TX-65DX900 ( DX900 ) TEST - Ultra HD Premium LCD LED - PANASONIC - HDTV Centrum Polska
    Panasonic TX-58DX902B (DX902/ DX900) Review
    Test TV - Écran plat Panasonic TX-58DX900 - Résumé
    Preview Panasonic TX-58DX900 4K | Pag 1: Introduzione | AV Magazine
    DX780
    XXL-TEST: Panasonic 4K Pro Studio Master UHD-TV TX-65DXW784 – Bild-Performance-Meister mit HDR | AREA DVD
    DX750
    https://www.avforums.com/review/pana...v-review.12550
    DX730
    Panasonic 50"-DX730 Review - Inleiding - Tweakers
    DX700
    https://www.avforums.com/review/pana...v-review.12515
    DS630
    DX750F - DVB-T/T2
    DX730E - 2 x DVB-T/T2/C/S/S2
    DXE720 - DVB-T/T2/C
    Product UHD
    Premium
    Dolby
    Vision
    HDR
    _______________________________________
    Backlight
    Dimming
    _________________________________________
    Color Space
    Contrast
    White & Black level
    Viewing angle
    _____________
    Input Lag
    SoC
    CPU
    GPU
    software
    OS
    _________________
    Conectors
    _________________
    Networks
    Tuner
    _______________
    Product
    CZ950
    65"
    OLED
    Yes No 65" - max 450cd/m2
    Yes
    SMPTE standarts
    ST2084, ST 2086
    Oled, WRGB(LG Display), 10bit, 120/100Hz No 65" - DCI P3 - 86% / rec.2020 - 70% 65" - ∞ / 151cd/m2 / 0.00cd/m2 65" - 45°
    65" - Game mode - 0ms / by default - 80ms
    Quad Core Pro 5
    Firefox 2.0
    1 x Ethernet RJ45
    1 x Ethernet RJ45
    4 x HDMI 2.0 (ARC,CEC)
    1 x AV Composite In
    1 x AV Component In
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    1 x Card reader SD/SDHC
    Lan -
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Bluetooth ver. 4.0
    Wi-Fi Direct
    2 x DVB-C/T2/S2,
    Analog (PAL,SECAM)
    2 x CI+1.3
    HEVC
    VP9
    CZ950
    DX900
    58", 65"
    58"- max 1430cd/m2
    Yes HDR10
    SMPTE standards
    ST2084, ST2086
    MCFI - Motion Clarity Frame Interpolation
    Blue Leds
    (actually white LEDs "boosted" with red phosphorus)
    65" - ANSI
    Static - 5360:1 / 134cd/m2 / 0.025cd/m2
    Dynamic - 50000:1
    58" - ANSI
    Static - 4600:1 / ---- cd/m2 / 0.023cd/m2
    Dynamic - 50000:1
    65" - 42°(cone)
    58" - 46°(conе)
    65"- Game mode - 41ms / by default - 51ms
    58" - Game mode- 40ms / by default - 50ms
    Quad Core
    P163
    Firefox 2.5
    1 x Ethernet RJ45
    1 x Ethernet RJ45
    1 x AV Composite In
    1 x AV Component In
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    Lan
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Bluetooth ver. 4.0
    Wi-Fi Direct
    2x DVB-C/T2/S2,
    Analog (PAL,SECAM)
    2 x CI+1.3
    HEVC
    VP9
    9 DX900
    DX800
    58", 50"
    50" - max...cd/m2
    Yes HDR10
    SMPTE standards
    ST2084, ST2086
    58"- Super-MVA, 8-bit+Hi-FRC, 120/100Hz + MCFI
    50"- Super-MVA, 8-bit+Hi-FRC, 120/100Hz + MCFI
    58" - Edge Led
    50" - Edge Led
    LEDs "boosted"
    58"- DCI P3 - 94%
    50"- DCI P3 - 90%
    58"-
    50"-
    58" -
    50" -
    58" - Game mode
    50" - Game mode
    Quad Core
    P163
    Firefox 2.5
    1 x Ethernet RJ45
    1 x Ethernet RJ45
    1 x AV Composite In
    1 x AV Component In
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    Lan
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Bluetooth ver. 4.0
    Wi-Fi Direct
    2 x DVB-C/T2/S2,
    Analog (PAL,SECAM)
    2 x CI+1.3
    HEVC
    VP9
    DX800
    DX780
    65", 58", 50"
    55" - max 577cd/m2
    50" - max 5....cd/m2
    Compatible
    HDR processing
    (but no hardware for HDR)
    65" - Super-MVA, 8-bit+FRC, 120/100Hz + MCFI
    58" - Super-MVA, 8-bit+FRC, 120/100Hz + MCFI
    50" - Super-MVA, 8-bit+FRC, 120/100Hz + MCFI
    LEDs "boosted"
    65" - DCI P3 -
    58" - DCI P3 -
    65" -
    58" -
    50" -
    65" -
    58" -
    50" -
    65" - Game mode
    58" - Game mode
    50" - Game mode
    Quad Core
    P163
    Firefox 2.5
    1 x Ethernet RJ45
    1 x Ethernet RJ45
    2 x HDMI 1.4 (CEC)
    1 x AV Composite In
    1 x AV Component In
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Bluetooth ver. 4.0
    Wi-Fi Direct
    2 x DVB-C/T2/S2,
    Analog (PAL,SECAM)
    2 x CI+1.3
    HEVC
    VP9
    DX780
    DX750
    65", 58", 50"
    No
    No 65" - max 435cd/m2
    58" - max 550cd/m2
    50" - max 550cd/m2
    Compatible
    HDR processing
    very glossy panel
    65" - Direct Led, No Dimming
    58" - Edge Led (below), Vertical Dimming ?
    50" - Edge Led (below), Vertical Dimming ?
    65" - DCI P3 - 94% / Rec.2020 -
    58" - DCI P3 - 94% / Rec.2020 -
    50" - DCI P3 - 86% / Rec.2020 - 66%
    65" - 4300:1 / 123cd/m2 / 0.03cd/m2
    58" -
    50" -
    Static - 3795:1/ ---- cd/m2 / 0.29cd/m2
    Dynamic -
    65" - 30° (cone)
    58" -
    50" -
    65"- Game mode-45ms / by default-106ms
    58"- Game mode-44ms / by default-105ms
    50"- Game mode-44ms / by default-105ms
    Quad Core
    P163
    Firefox 2.5
    1 x Ethernet RJ45
    1 x Ethernet RJ45
    2 x HDMI 1.4 (CEC)
    1 x AV Composite In
    1 x AV Component In
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Bluetooth ver. 4.0
    Wi-Fi Direct
    DVB- C/T2/S2
    Analog (PAL,SECAM)
    HEVC
    VP9
    DX750
    DX730
    58", 50", 40"
    50"- max 317cd/m2
    40" - max...cd/m2
    Compatible
    HDR processing
    58" - Super-MVA, 8-bit, 60/50Hz + BLB + MCFI
    50" - Super-MVA, 8-bit, 60/50Hz + BLB + MCFI
    40" - Super-MVA, 8-bit, 60/50Hz + BLB + MCFI
    very glossy panel
    58" - DCI P3 -
    50" - DCI P3 -
    40" - DCI P3 -
    58" -
    40" -
    58" -
    50" - 42° (cone)
    40" -
    58" - Game mode
    50" - Game mode
    40" - Game mode
    Quad Core
    P193
    Firefox 2.5
    1 x Ethernet RJ45
    1 x Ethernet RJ45
    1 x HDMI 1.4 (CEC)
    1 x AV Composite In
    1 x AV Component In
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Wi-Fi Direct
    DVB-T/T2/C
    Analog (PAL,SECAM)
    HEVC
    VP9
    DX730
    DX700
    58", 50"'40"
    50" - HDR 350cd/m2
    40" -
    Compatible
    HDR processing
    very glossy panel
    40" - Edge Led (below), Vertical Dimming
    58" - DCI P3 - / Rec.2020 - 68.27%
    50" - DCI P3 -
    40" - DCI P3 -
    58"- 5736:1 / 153cd/m2 / 0.03cd/m2
    3184:1 / 0.038cd/m2
    50" - 4700:1 /
    40" -
    58" - 40°(conе)
    50" -
    40" -
    58"- Game mode-49.8ms / by default-69.7ms
    50"- Game mode
    40" -
    Quad Core
    P193
    Firefox 2.5
    1 x Ethernet RJ45
    1 x HDMI 1.4 (CEC)
    1 x AV Composite in
    1 x AV Component in
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    WiFi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Bluetooth ver. 4.0
    Wi-Fi Direct
    DVB-C/T2/S/S2
    Analog (PAL,SECAM)
    HEVC
    9 DX700
    DX650
    58", 50",40"
    No No 58" -
    50" -
    40" -
    No
    58"- Super-MVA, 8-bit, 60/50Hz + BLB
    50"- Super-MVA, 8-bit, 60/50Hz + BLB
    40"- Super-MVA, 8-bit, 60/50Hz + BLB
    58" - Edge Led, (below)
    50" - Edge Led, (below)
    40" - Edge Led, (below)
    58"- DCI P3 -
    50"- DCI P3 -
    40"- DCI P3 -
    58"-
    50"-
    40"-
    58"-
    50"-
    40"-
    Quad Core
    Firefox 2.5
    1 x Ethernet RJ45
    1 x HDMI 1.4 (CEC)
    1 x AV Composite in
    1 x AV Component in
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Wi-Fi Direct
    DVB-T/T2/C
    Analog (PAL,SECAM)
    DX650
    DX600
    55", 49", 40"
    49" - max...cd/m2
    40" - max...cd/m2
    No
    55"- Super-IPS, 8-bit, 60/50Hz + BLB
    49"- Super-IPS, 8-bit, 60/50Hz + BLB
    55" - Edge Led, (below)
    49" - Edge Led, (below)
    40" - Edge Led
    55"- DCI P3 -
    49"- DCI P3 -
    40"- DCI P3 -
    55"-
    49"-
    40"-
    55"- 78° (cone)
    49"-
    40"-
    Firefox 2.5
    1 x Ethernet RJ45
    1 x HDMI 1.4 (CEC)
    1 x AV Composite in
    1 x AV Component in
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Wi-Fi Direct
    DVB-T/T2/C
    Analog (PAL,SECAM)
    DX600
    Product UHD
    Premium
    Dolby
    Vision
    HDR
    _________________
    _________________
    Backlight
    Dimming
    Color Space
    Viewing angle
    ____________
    Input Lag
    _____________
    SoC
    software
    OS
    _________________
    Conectors
    Networks
    Tuner
    _______________
    Product
    DS630
    50", 40", 32"
    40" - max...cd/m2
    32" - max...cd/m2
    No
    50"- Super-MVA, 8-bit, 120/100Hz + BLB + MCFI
    40"- Super-MVA, 8-bit, 120/100Hz + BLB + MCFI
    50" - Edge Led
    40" - Edge Led
    32" - Edge Led
    Only globally
    50"- DCI P3 - 74%
    40"- DCI P3 -
    32"- DCI P3 -
    40"-
    32"-
    50"-
    40"-
    32"-
    P162
    my Home Screen 1.0
    3 x HDMI 1.4 (CEC)
    1 x SCART
    Wi-Fi
    Wi-Fi Direct
    DLNA
    802.11 a/n
    5.660GHZ-5.700GHz
    802.11 b/g/n
    2.412GHz-2.472GHz
    Security
    WPA2-PSK(TKIP/AES)
    WPA-PSK(TKIP/AES)
    WEP(64-bit/128-bit)
    DVB-T/T2/C
    No HEVC
    DX630
    DS600
    50", 40", 32"
    No No 50" - max...cd/m2
    40" - max...cd/m2
    32" - max...cd/m2
    No
    50" - MVA , 8-bit, 60/50Hz
    40" - Super-MVA, 8bit, 60/50Hz
    50" - Edge Led
    40" - Edge Led
    32" - Edge Led
    50"- DCI P3 -
    40"- DCI P3 -
    32"- DCI P3 -
    50"-
    40"-
    32"-
    50"-
    40"-
    32"-
    P161
    3 x HDMI 1.4 (CEC)
    2 x USB 2.0
    1 x SCART
    1 x CI+ 1.3
    Wi-Fi
    Wi-Fi Direct
    DLNA
    802.11 a/n
    5.660GHZ-5.700GHz
    802.11 b/g/n
    2.412GHz-2.472GHz
    Security
    WPA2-PSK(TKIP/AES)
    WPA-PSK(TKIP/AES)
    WEP(64-bit/128-bit)
    DVB-T/T2/C
    Analog (PAL,SECAM)
    No HEVC
    DX600
    DS500
    49" - max 314cd/m2
    40" - max...cd/m2
    32" - max...cd/m2
    24" - max...cd/m2
    No
    55" - Super-IPS, 8bit, 60/50Hz
    49" - Super-IPS , 8-bit, 60/50Hz
    55" - Edge Led
    49" - Edge Led
    40" - Edge Led
    32" - Edge Led
    24" - Edge Led
    55" - DCI P3 -
    49" - DCI P3 -
    40" - DCI P3 -
    32" - DCI P3 -
    24" -
    55"-
    49"- 882:1 /
    40"-
    32"-
    24" -
    55"-
    49"- 66° (cone)
    40"-
    32"-
    24" -
    P161
    1 x Scart
    1 x CI+ 1.3
    Wi-Fi
    Wi-Fi Direct
    DLNA
    802.11 a/n
    5.660GHZ-5.700GHz
    802.11 b/g/n
    2.412GHz-2.472GHz
    Security
    WPA2-PSK(TKIP/AES)
    WPA-PSK(TKIP/AES)
    WEP(64-bit/128-bit)
    DVB-T/T2/C
    Analog (PAL,SECAM)
    No HEVC
    DS500
    DS400
    40"
    No
    40" - ? , 8bit, 60/50Hz 40" - 40"- 40"- 40"- -
    P161
    1 x Antena (RF) female DVB-T/T2/C
    Analog (PAL,SECAM)
    DS400
    Този пост е редактиран от hristoslav2; 31-05-16 в 23:37.
    #207
    Панасоник прекратява производството на LCD панели
    Panasonic to cease production of TV liquid crystal panels:The Asahi Shimbun
    #208
    Panasonic TX-58DX750F : Test complet
    Google translate Fr to Bg
    Product Certification UHD
    Premium
    Resolution: 3,840x2,160 .
    Color depth: 10-bit.
    Color gamut: Wide, including the ability to show at least 90 percent of the P3 color gamut .
    High dynamic range: Specifically the ability to use SMPTE ST2084's electro-optical transfer function, which Dolby helped create .
    Minimum brightness and contrast ratios: There are two possible minimum specs. A minimum brightness of 1,000 nits, along with a black level of a maximum of 0.05 nits (20,000:1 contrast ratio), or a minimum brightness of 540 nits, along with a black level of a maximum of 0.0005 (1,080,000:1)
    Dolby
    Vision
    HDR
    Backlight
    Dimming
    Color Space
    Contrast
    White & Black level
    Viewing angle
    _____________
    Input Lag
    SoC
    CPU
    GPU
    software
    OS
    _________________
    Conectors
    _________________
    Networks
    Tuner
    _______________
    Product
    CZ950
    65"
    OLED
    Yes
    SMPTE standarts
    ST2084, ST 2086
    Quad Core Pro 5
    Firefox 2.0
    1 x Ethernet RJ45
    1 x Ethernet RJ45
    1 x AV Composite In
    1 x AV Component In
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    Lan -
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Bluetooth ver. 4.0
    Wi-Fi Direct
    2 x DVB-C/T2/S2,
    Analog (PAL,SECAM)
    2 x CI+1.3
    HEVC
    VP9
    CZ950
    DX900
    58", 65"
    58"- max 1430cd/m2
    Yes HDR10
    SMPTE standards
    ST2084, ST2086
    Blue Leds
    65" - ANSI
    Dynamic - 50000:1
    58" - ANSI
    Dynamic - 50000:1
    65" - 42°(cone)
    58" - 46°(conе)
    Quad Core
    P163
    Firefox 2.5
    1 x Ethernet RJ45
    1 x Ethernet RJ45
    1 x AV Composite In
    1 x AV Component In
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    Lan
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Bluetooth ver. 4.0
    Wi-Fi Direct
    2x DVB-C/T2/S2,
    Analog (PAL,SECAM)
    2 x CI+1.3
    HEVC
    VP9
    9 DX900
    DX800
    58", 50"
    50" - max...cd/m2
    Yes HDR10
    SMPTE standards
    ST2084, ST2086
    58" - Edge Led
    50" - Edge Led
    LEDs "boosted"
    58"- DCI P3 - 94%
    50"- DCI P3 - 90%
    58"-
    50"-
    58" -
    50" -
    58" - Game mode
    50" - Game mode
    Quad Core
    P163
    Firefox 2.5
    1 x Ethernet RJ45
    1 x Ethernet RJ45
    1 x AV Composite In
    1 x AV Component In
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    Lan
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Bluetooth ver. 4.0
    Wi-Fi Direct
    2 x DVB-C/T2/S2,
    Analog (PAL,SECAM)
    2 x CI+1.3
    HEVC
    VP9
    DX800
    DX780
    65", 58", 50"
    55" - max 577cd/m2
    Compatible
    HDR processing
    LEDs "boosted"
    65" - DCI P3 -
    58" - DCI P3 -
    65" -
    58" -
    50" -
    65" -
    58" -
    50" -
    65" - Game mode
    58" - Game mode
    50" - Game mode
    Quad Core
    P163
    Firefox 2.5
    1 x Ethernet RJ45
    1 x Ethernet RJ45
    2 x HDMI 1.4 (CEC)
    1 x AV Composite In
    1 x AV Component In
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Bluetooth ver. 4.0
    Wi-Fi Direct
    2 x DVB-C/T2/S2,
    Analog (PAL,SECAM)
    2 x CI+1.3
    HEVC
    VP9
    DX780
    DX750
    65", 58", 50"
    No
    58" - max 550cd/m2
    50" - max 550cd/m2
    Compatible
    HDR processing
    very glossy panel
    58" - 4029:1 /154cd/m2 / 0.04cd/m2
    50" -
    Dynamic -
    65" - 30° (cone)
    58" - 40° (cone)
    50" -
    Quad Core
    P163
    Firefox 2.5
    1 x Ethernet RJ45
    1 x Ethernet RJ45
    2 x HDMI 1.4 (CEC)
    1 x AV Composite In
    1 x AV Component In
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Bluetooth ver. 4.0
    Wi-Fi Direct
    DVB- C/T2/S2
    Analog (PAL,SECAM)
    HEVC
    VP9
    DX750
    DX730
    58", 50", 40"
    50"- max 317cd/m2
    40" - max...cd/m2
    Compatible
    HDR processing
    very glossy panel
    58" - DCI P3 -
    50" - DCI P3 -
    40" - DCI P3 -
    58" -
    40" -
    58" -
    50" - 42° (cone)
    40" -
    58" - Game mode
    50" - Game mode
    40" - Game mode
    Quad Core
    P193
    Firefox 2.5
    1 x Ethernet RJ45
    1 x Ethernet RJ45
    1 x HDMI 1.4 (CEC)
    1 x AV Composite In
    1 x AV Component In
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Wi-Fi Direct
    DVB-T/T2/C
    Analog (PAL,SECAM)
    HEVC
    VP9
    DX730
    DX700
    58", 50"'40"
    50" - HDR 350cd/m2
    40" -
    Compatible
    HDR processing
    very glossy panel
    50" - DCI P3 -
    40" - DCI P3 -
    3184:1 / 0.038cd/m2
    50" - 4700:1 /
    40" -
    58" - 40°(conе)
    50" -
    40" -
    50"- Game mode
    40" -
    Quad Core
    P193
    Firefox 2.5
    1 x Ethernet RJ45
    1 x HDMI 1.4 (CEC)
    1 x AV Composite in
    1 x AV Component in
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    WiFi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Bluetooth ver. 4.0
    Wi-Fi Direct
    DVB-C/T2/S/S2
    Analog (PAL,SECAM)
    HEVC
    9 DX700
    DX650
    58", 50",40"
    No No 58" -
    50" -
    40" -
    No
    58"- DCI P3 -
    50"- DCI P3 -
    40"- DCI P3 -
    58"-
    50"-
    40"-
    58"-
    50"-
    40"-
    Quad Core
    Firefox 2.5
    1 x Ethernet RJ45
    1 x HDMI 1.4 (CEC)
    1 x AV Composite in
    1 x AV Component in
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Wi-Fi Direct
    DVB-T/T2/C
    Analog (PAL,SECAM)
    DX650
    DX600
    55", 49", 40"
    49" - max...cd/m2
    40" - max...cd/m2
    No
    40" - Edge Led
    55"- DCI P3 -
    49"- DCI P3 -
    40"- DCI P3 -
    55"-
    49"-
    40"-
    55"- 78° (cone)
    49"-
    40"-
    Firefox 2.5
    1 x Ethernet RJ45
    1 x HDMI 1.4 (CEC)
    1 x AV Composite in
    1 x AV Component in
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Wi-Fi Direct
    DVB-T/T2/C
    Analog (PAL,SECAM)
    DX600
    Product UHD
    Premium
    Dolby
    Vision
    HDR
    _________________
    _________________
    Backlight
    Dimming
    Color Space
    Viewing angle
    ____________
    Input Lag
    _____________
    SoC
    software
    OS
    _________________
    Conectors
    Networks
    Tuner
    _______________
    Product
    DS630
    50", 40", 32"
    40" - max...cd/m2
    32" - max...cd/m2
    No
    50" - Edge Led
    40" - Edge Led
    32" - Edge Led
    Only globally
    50"- DCI P3 - 74%
    40"- DCI P3 -
    32"- DCI P3 -
    40"-
    32"-
    50"-
    40"-
    32"-
    P162
    my Home Screen 1.0
    3 x HDMI 1.4 (CEC)
    1 x SCART
    Wi-Fi
    Wi-Fi Direct
    DLNA
    802.11 a/n
    5.660GHZ-5.700GHz
    802.11 b/g/n
    2.412GHz-2.472GHz
    Security
    WPA2-PSK(TKIP/AES)
    WPA-PSK(TKIP/AES)
    WEP(64-bit/128-bit)
    DVB-T/T2/C
    No HEVC
    DX630
    DS600
    50", 40", 32"
    40" - max...cd/m2
    32" - max...cd/m2
    No
    50" - Edge Led
    40" - Edge Led
    32" - Edge Led
    50"- DCI P3 -
    40"- DCI P3 -
    32"- DCI P3 -
    50"-
    40"-
    32"-
    50"-
    40"-
    32"-
    P161
    3 x HDMI 1.4 (CEC)
    2 x USB 2.0
    1 x SCART
    1 x CI+ 1.3
    Wi-Fi
    Wi-Fi Direct
    DLNA
    802.11 a/n
    5.660GHZ-5.700GHz
    802.11 b/g/n
    2.412GHz-2.472GHz
    Security
    WPA2-PSK(TKIP/AES)
    WPA-PSK(TKIP/AES)
    WEP(64-bit/128-bit)
    DVB-T/T2/C
    Analog (PAL,SECAM)
    No HEVC
    DX600
    DS500
    49" - max 314cd/m2
    40" - max...cd/m2
    32" - max...cd/m2
    24" - max...cd/m2
    No
    55" - Edge Led
    49" - Edge Led
    40" - Edge Led
    32" - Edge Led
    24" - Edge Led
    55" - DCI P3 -
    49" - DCI P3 -
    40" - DCI P3 -
    32" - DCI P3 -
    24" -
    55"-
    49"- 882:1 /
    40"-
    32"-
    24" -
    55"-
    49"- 66° (cone)
    40"-
    32"-
    24" -
    P161
    1 x Scart
    1 x CI+ 1.3
    Wi-Fi
    Wi-Fi Direct
    DLNA
    802.11 a/n
    5.660GHZ-5.700GHz
    802.11 b/g/n
    2.412GHz-2.472GHz
    Security
    WPA2-PSK(TKIP/AES)
    WPA-PSK(TKIP/AES)
    WEP(64-bit/128-bit)
    DVB-T/T2/C
    Analog (PAL,SECAM)
    No HEVC
    DS500
    DS400
    40"
    No
    P161
    Analog (PAL,SECAM)
    DS400
    Този пост е редактиран от hristoslav2; 07-06-16 в 21:01.
  17. Senior Member Аватара на svetlio1
    #209
    Нов софтуер за модели 2015 - 3.228
    • Improve network functions.
    • Improve system stability.
    #210
    Test Panasonic TX-50DX750 : le meilleur rapport qualité/prix de 2016 ? | HDfever
    Според снимките, DX900, DX800, DX780 и DX750 имат една и съща поставена матрица.
    Комплектацията на видео-панелите е различна.
    DX703 - DVB-T/T2/C/S2
    DX700 - DVB-T/T2/C
    DX653 - DVB-T/T2/C/S2
    DX650 - DVB-T/T2/C
    DX402 - ??????
    Premium
    Dolby
    Vision
    HDR
    Backlight
    Dimming
    Color Space
    Contrast
    White & Black level
    Viewing angle
    _____________
    Input Lag
    SoC
    CPU
    GPU
    software
    OS
    _________________
    Conectors
    _________________
    Networks
    Tuner
    Opportunities for calibration
    ________________________________________________________
    Product
    CZ950
    65"
    OLED
    Yes
    SMPTE standarts
    ST2084, ST 2086
    Oled, WRGB (LG Display), 10bit, 120/100Hz No 65" - DCI P3 - 86% / rec.2020 - 70% 65" - ∞ / 151cd/m2 / 0.00cd/m2 65" - 45°
    Quad Core Pro 5
    Firefox 2.0
    1 x Ethernet RJ45
    1 x Ethernet RJ45
    1 x AV Composite In
    1 x AV Component In
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    Lan -
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Bluetooth ver. 4.0
    Wi-Fi Direct
    2 x DVB-C/T2/S2,
    Analog (PAL,SECAM)
    2 x CI+1.3
    PVR, Time Shifting
    HEVC
    VP9
    CZ950
    DX900
    58", 65"
    58"- max 1430cd/m2
    Yes HDR10
    SMPTE standards
    ST2084, ST2086
    Blue Leds
    65" - ANSI
    Dynamic - 50000:1
    58" - ANSI
    Dynamic - 50000:1
    65" - 42°(cone)
    58" - 46°(conе)
    Quad Core
    P163
    Firefox 2.5
    1 x Ethernet RJ45
    1 x Ethernet RJ45
    1 x AV Composite In
    1 x AV Component In
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    Lan
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Bluetooth ver. 4.0
    Wi-Fi Direct
    2x DVB-C/T2/S2,
    Analog (PAL,SECAM)
    2 x CI+1.3
    PVR, Time Shifting
    HEVC
    VP9
    DX900
    DX800
    58", 50"
    50" - max...cd/m2
    Yes HDR10
    SMPTE standards
    ST2084, ST2086
    58" - Edge Led
    50" - Edge Led
    LEDs "boosted"
    58"- DCI P3 - 94%
    50"- DCI P3 - 90%
    58"-
    50"-
    58" -
    50" -
    58" - Game mode
    50" - Game mode
    Quad Core
    P163
    Firefox 2.5
    1 x Ethernet RJ45
    1 x Ethernet RJ45
    4 x HDMI 2.0a (ARC,CEC)
    1 x AV Composite In
    1 x AV Component In
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    Lan
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Bluetooth ver. 4.0
    Wi-Fi Direct
    2 x DVB-C/T2/S2,
    Analog (PAL,SECAM)
    2 x CI+1.3
    PVR, Time Shifting
    HEVC
    VP9
    DX800
    DX780
    65", 58", 50"
    55" - max 577cd/m2
    Compatible
    HDR processing
    BFI - Black Frame insertion
    65" - Direct Led, Local Dimming - 32 zones (8 x 4)
    LEDs "boosted"
    65" - DCI P3 -
    58" - DCI P3 -
    65" -
    58" -
    50" -
    65" -
    58" -
    50" -
    65" - Game mode
    58" - Game mode
    50" - Game mode
    Quad Core
    P163
    Firefox 2.5
    1 x Ethernet RJ45
    1 x Ethernet RJ45
    2 x HDMI 2.0a (ARC,CEC)
    2 x HDMI 1.4 (CEC)
    1 x AV Composite In
    1 x AV Component In
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Bluetooth ver. 4.0
    Wi-Fi Direct
    2 x DVB-C/T2/S2,
    Analog (PAL,SECAM)
    2 x CI+1.3
    PVR, Time Shifting
    HEVC
    VP9
    DX780
    DX750
    65", 58", 50"
    No
    58" - max 550cd/m2
    50" - HDR max 625cd/m2
    SDR max 500cd/m2
    Compatible
    HDR processing
    MCFI - Motion Clarity Frame Interpolation(IFC)
    very glossy panel
    50" -
    Static - 4800:1/ 120 cd/m2 / 0.025cd/m2
    Dynamic - 5000:1 / 625cd/m2 / 0.10cd/m2
    65" - 35° (cone)
    58" - 40° (cone)
    50" - 35° (cone)
    Quad Core
    P163
    Firefox 2.5
    1 x Ethernet RJ45
    1 x Ethernet RJ45
    2 x HDMI 1.4 (CEC)
    1 x AV Composite In
    1 x AV Component In
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Bluetooth ver. 4.0
    Wi-Fi Direct
    DVB- C/T2/S2
    Analog (PAL,SECAM)
    PVR, Time Shifting
    HEVC
    VP9
    Accurate Colour Drive technology with 3D LUT conversion table with 8 000 points correction and the ability to calibrate 6 primary and secondary colors within a CMS on 3 axes. Or Black Gradation Drive that can provide more gradations in dark scenes through treatment with 12 bit color.
    To adjust the colorimetry, the DX750 offers all the necessary settings with the choice of gamut used (Rec.601, Rec.709, EBU, DCI / P3 or Rec.2020), gamma used (with varying gamma whose BT.1886 with compensation of black, 2.2 used in lit room, the 2.4 used in dark room). You can edit each Gamma to correct on 10 points. Each gamut can be calibrated from a CMS (Color Management System) 3-axis (luminance, saturation and hue) with opportunity to correct 6 primary and secondary colors (RGBCMY). Finally, we also find a Balance Whites 2P and 10P (10 points) to adjust the color temperature.
    DX750
    DX730
    58", 50", 40"
    50"- max 317cd/m2
    40" - max...cd/m2
    Compatible
    HDR processing
    very glossy panel
    58" - DCI P3 -
    50" - DCI P3 -
    40" - DCI P3 -
    58" -
    40" -
    58" -
    50" - 42° (cone)
    40" -
    58" - Game mode
    50" - Game mode
    40" - Game mode
    Quad Core
    P193
    Firefox 2.5
    1 x Ethernet RJ45
    1 x Ethernet RJ45
    1 x HDMI 1.4 (CEC)
    1 x AV Composite In
    1 x AV Component In
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Wi-Fi Direct
    DVB-T/T2/C
    Analog (PAL,SECAM)
    PVR, Time Shifting
    HEVC
    VP9
    DX730
    DX700
    58", 50"'40"
    50" - HDR 350cd/m2
    40" -
    Compatible
    HDR processing
    very glossy panel
    50" - DCI P3 -
    40" - DCI P3 -
    3184:1 / 0.038cd/m2
    50" - 4700:1 /
    40" -
    58" - 40°(conе)
    50" -
    40" -
    50"- Game mode
    40" - Game mode
    Quad Core
    P193
    Firefox 2.5
    1 x Ethernet RJ45
    1 x HDMI 1.4 (CEC)
    1 x AV Composite in
    1 x AV Component in
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    WiFi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Bluetooth ver. 4.0
    Wi-Fi Direct
    DVB-C/T2/S/S2
    Analog (PAL,SECAM)
    HEVC
    9 DX700
    DX650
    58", 50",40"
    No No 58" -
    50" -
    40" -
    No
    58"- DCI P3 -
    50"- DCI P3 -
    40"- DCI P3 -
    58"-
    50"-
    40"-
    58"-
    50"-
    40"-
    58" - Game mode
    50" - Game mode
    40" - Game mode
    Quad Core
    Firefox 2.5
    1 x Ethernet RJ45
    1 x HDMI 1.4 (CEC)
    1 x AV Composite in
    1 x AV Component in
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Wi-Fi Direct
    DVB-T/T2/C
    Analog (PAL,SECAM)
    DX650
    DX600
    55", 49", 40"
    49" - max...cd/m2
    40" - max...cd/m2
    No
    40" - Edge Led
    55"- DCI P3 -
    49"- DCI P3 -
    40"- DCI P3 -
    55"-
    49"-
    40"-
    55"- 78° (cone)
    49"-
    40"-
    55" - Game mode
    49" - Game mode
    40" - Game mode
    Firefox 2.5
    1 x Ethernet RJ45
    1 x HDMI 1.4 (CEC)
    1 x AV Composite in
    1 x AV Component in
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Wi-Fi Direct
    DVB-T/T2/C
    Analog (PAL,SECAM)
    DX600
    Product UHD
    Premium
    Dolby
    Vision
    HDR
    _________________
    _________________
    Backlight
    Dimming
    Color Space
    Viewing angle
    ____________
    Input Lag
    _____________
    SoC
    software
    OS
    _________________
    Conectors
    Networks
    Tuner
    _______________
    Product
    DS630
    50", 40", 32"
    40" - max...cd/m2
    32" - max...cd/m2
    No
    50" - Edge Led
    40" - Edge Led
    32" - Edge Led
    Only globally
    50"- DCI P3 - 74%
    40"- DCI P3 -
    32"- DCI P3 -
    40"-
    32"-
    50"-
    40"-
    32"-
    50" -
    40" -
    32" -
    P162
    my Home Screen 1.0
    3 x HDMI 1.4 (CEC)
    1 x SCART
    Wi-Fi
    Wi-Fi Direct
    DLNA
    802.11 a/n
    5.660GHZ-5.700GHz
    802.11 b/g/n
    2.412GHz-2.472GHz
    Security
    WPA2-PSK(TKIP/AES)
    WPA-PSK(TKIP/AES)
    WEP(64-bit/128-bit)
    DVB-T/T2/C
    No HEVC
    DS630
    DS600
    50", 40", 32"
    40" - max...cd/m2
    32" - max...cd/m2
    No
    Backlight Motion Rate 400
    50" - Edge Led
    40" - Edge Led
    32" - Edge Led
    50"- DCI P3 -
    40"- DCI P3 -
    32"- DCI P3 -
    50"-
    40"-
    32"-
    50"-
    40"-
    32"-
    50" -
    40" -
    32" -
    P161
    3 x HDMI 1.4 (CEC)
    2 x USB 2.0
    1 x SCART
    1 x CI+ 1.3
    Bluetooth 3.0 (2.402GHz-2.480Ghz)
    Wi-Fi
    Wi-Fi Direct
    DLNA
    802.11 a/n
    5.660GHZ-5.700GHz
    802.11 b/g/n
    2.412GHz-2.472GHz
    Security
    WPA2-PSK(TKIP/AES)
    WPA-PSK(TKIP/AES)
    WEP(64-bit/128-bit)
    DVB-T/T2/C
    Analog (PAL,SECAM)
    No HEVC
    DS600
    DS500
    49" - max 314cd/m2
    40" - max...cd/m2
    32" - max...cd/m2
    24" - max...cd/m2
    No
    55" - Edge Led
    49" - Edge Led
    40" - Edge Led
    32" - Edge Led
    24" - Edge Led
    55" - DCI P3 -
    49" - DCI P3 -
    40" - DCI P3 -
    32" - DCI P3 -
    24" -
    55"-
    49"- 882:1 /
    40"-
    32"-
    24" -
    55"-
    49"- 66° (cone)
    40"-
    32"-
    24" -
    55" -
    49" -
    40" -
    32" -
    24" -
    P161
    1 x USB 2.0
    1 x Ethernet RJ45
    2 x HDMI 1.4 (ARC, CEC)
    1 x Scart
    1 x AV Composite In
    1 x AV Component In
    1 x Opticasl Audio Out
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    Bluetooth 3.0 (2.402GHz-2.480GHz)
    Wi-Fi
    Wi-Fi Direct
    802.11 a/n
    5.660GHZ-5.700GHz
    802.11 b/g/n
    2.412GHz-2.472GHz
    Security
    WPA2-PSK(TKIP/AES)
    WPA-PSK(TKIP/AES)
    WEP(64-bit/128-bit)
    DLNA
    DVB-T/T2/C
    Analog (PAL,SECAM)
    No HEVC
    DS500
    DS400
    40"
    No
    40" - MVA, 8bit, 60/50Hz
    Backlight Motion Rate - 400
    40" - Edge Led 40"- DCI P3 - 40"- 40"- 40" - -
    P161
    1 x USB 2.0
    1 x Ethernet RJ 45
    1 x SCART
    1 x AV Composite In
    1 x AV Component In
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    Lan
    WiFi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5Ghz
    DLNA
    DVB-T/T2/C
    Analog (PAL,SECAM)
    DS400
    Този пост е редактиран от hristoslav2; 13-06-16 в 20:01.
    stanislav77 одобрява това.
  1. Panasonic Plasma телевизори - част 4
    От hristoslav2 във форум Panasonic телевизори
    Отговори: 1733
    Последно: 23-07-25, 14:28
  2. Избор на климатик 2016 г.
    Отговори: 3492
    Последно: 01-01-17, 18:50
  3. Квалификации Евро 2016
    От iihtiandar във форум Спорт
    Последно: 10-06-16, 09:03
  4. Panasonic телевизори 2015
    Отговори: 677
    Последно: 02-01-16, 08:49
  5. Отговори: 0
    Последно: 02-03-12, 11:17
