| Samsung QLED TV 2017 - european models / Samsung QLED TV 2017 - european models / Samsung QLED TV 2017 - european models / Samsung QLED TV 2017 - european models |
 | Series |  Certificates |  Hardware & Software |  Calibration |  Picture Quality |  Other |  Notes |  Series |
 Series Q
Model  ___________ |  UHD Premium   (by UHD Alliance) _____ |  Dolby Vision
VS10 ____ |  Hybrid
Log Gamma
(HLG) _____ |  HDR 10  ST2084
(EOTF PQ),
ST2086
(static metadata)
ST2094-40
(dynamic metadata)  ________    |  Advanced HDR Technicolor
ST2094-30  _______  |  THX ____ |  SoC / GPU / RAM   ________________________  Plattform
Central Processing Unit
System on Chip
Instruction set
Graphic Processor Unit
RAM
Total memory  |  Software  ____________  Operating System
SDK
Firmware version
Internal Processing  |  Videopanel  ______________________Type LCD/Oled matrix,
Resolution,
Bits of color,
(Operating frequency of T-Con board)
FRC,
Curvature,
Screen Uniformity,
Anti-reflective filter  |  Backlight Unit _______________Type backlight
Local Dimming zone,
Type LED,
MEMC,
Backlight Scanning,
Black Frame Insertion,
Pulsе Wide Modulation  |  Display Measurement _____________________Temperature
Uniformity,
Image retention,
Motion blur,
Image flicker,
Motion Interpolation,
Reflection  |  Opportunities for calibration ____________________ |  Post calibration  delta E - standard colors
delta E color - stencil
delta E palette of gray
Gamma
Color Temperature _________________ |  Color Gamut ______________DCI P3,
Rec.2020,
Color Volume,
Millions of Distinguishable Colours (MDC)  |  Color Volume _____________________________Normalized DCI P3 Coverage
(How much of the DCI-P3 colorspace a TV can display at different luminosity levels)    Normalized REC. 2020 Coverage
(How much of the Rec. 2020 colorspace a TV can display at different luminosity levels)   |  SDR Peak Brightness __________________________Peak Brithness
Average Picture Level,
Automatic Brightness Limiter,  |  HDR Peak Brightness __________________________Peak Brithness
Automatic Brightness Limiter,  |  Contrast ___________________ANSI Contrast,
With local dimming,
Without local dimming,
White level,
Black level  |  Viewing angle  ____________ Horizontal & Vertical
(°cone)
Color Shift
Brightness
Black Level  |  Motion resolution _________________________ |  Input Lag ___________________________ |  Audio _______________ |  Built in Media Player  Supported file systems
Image file formats
Audio file formats/codecs
Video file formats
Subtitles ________________________ |  Networks __________________ |  Supported Resolutions _______________________Frame per seconds
24, 25, 30, 50, 60, 100, 120
Chroma subsampling
4:4:4
4:2:2
4:2:0  |  Conectors _____________________________________ |  Tuners ___________________ |  Note ____________________________________________________________________Pros & Cons  |  Product
____________ |
 Q9F  (Flat)
QE-88Q9F
QE-65Q9F  successor models
KS98, KS95   |  Yes |  ? |  Yes  |  Yes in internet services, HDMI, USB port.    HDR 10+ for Amazon Video   Conversion SDR/HDR ST2084,
ST2086,
ST2094, |  No      |  No |  Plattform:
SoC:
Core Architecture:
Instruction set:
Operating at up to:
GPU:
Open GL
RAM:
Total memory:
Available memory:
Internal storage total space:
Internal storage free space:   Electronics and remote connection in the One Connect box   |  OS: Tizen 3.0,
TV Extension Image 3.0.2, |  88"
QDCF-MVA (Samsung Display), 3840x2160, RGB, 10-bit,
120/100Hz, + BFI (black frame insertion),
FRC,
Flat   65"
120/100Hz, FRC,
Flat |  Edge Lit led system positioned at the left and right sides of the screen   32 Dimming blocks
(two columns, each one with 16 zones)   WLED   MEMC   No   BFI - yes/blinking backlight   PWM - Yes |  -- |  “CalMAN Ready” HDR Autocalibration.
To use the auto calibration feature you'll need to get hold of a 3.5mm to serial cable and a matching serial to USB adapter, that allows you to connect the Ex Out jack on the One Connect box to your laptop. You then run the Home Enthusiast workflow on CalMAN and use Direct Display Control to control the Q8C directly along with your pattern generator and colour meter.   White balance - 2/20points
CMS
Color Space Settings |  White Balance dE:
dE(color): 2.8 max 5.2
dE(stencil): 2.5 max 4.4
dE(grey): 2.2 max 3.7
Gamma: |  88"
DCI/P3 xy - %
DCI/P3 uv - %
Rec.2020 xy - %
Rec.2020 uv - %   65"
DCI-P3(L) - 109%
DCI/P3 xy - 99%
DCI/P3 uv - 99%
Rec.2020 xy- 79%
Rec.2020 uv - %
DCI-P3 - 85%
Rec.2020 - 58%
  |  88"
Normalized DCI P3 Coverage:  %
10,000 cd/m² DCI P3 Coverage: %
Normalized Rec 2020 Coverage:  %
10,000 cd/m² Rec 2020 Coverage: %   65"
10,000 cd/m² Rec 2020 Coverage: % |  88" -   65" - 460cd/m2 (100% Window)   APL -   ABL - full-field peak white came in at:
5% - cd/m2 (? mode) - in SDR
10% - cd/m2 (? mode) - in SDR   |  - 65"
Real Scene Peak Brightness:  cd/m2
Peak 2% Window:  cd/m2
Peak 10% Window : 1637 cd/m2
Peak 25% Window: 1415 cd/m2
Peak 50% Window:  cd/m2
Peak 100% Window:  cd/m2
Sustained 2% Window :  cd/m2
Sustained 10% Window:  cd/m2
Sustained 25% Window:  cd/m2
Sustained 50% Window :  cd/m2
Sustained 100% Window:
Medium in HDR: 735cd/m2 |  88" -
88" -
88" -
88" -
88" -   65" - 3900:1
65" -
65" -
65" -
65" - 0.016 nits |  88"
H&V -°
Color Shift -
Brightness -
Black Level -   65"
H&V - 30°
Color Shift -
Brightness -
Black Level -
  |  88" - 65" -
  |  88"- HDR - ms
88"- Game mode - ms
88"- by default - ms   65"- HDR - ms
65"- Game mode - 21.4 ms (1080/60p)
65"- by dafault
  |    ? W (4ohms)   Dolby Plus,
Dolby Puls,
DTS, |  FAT16, FAT32, NTFS and exFAT   Image formats:
JPEG, JIF, PNG, MPO, BMP   Video formats:
3GPP, AVI, ASF, DivX, Flash Video, H.263, H.264, H.265, MKV, M2TS, MP4, MPEG-4,TS, VC-1, VP7, VP8, VP9, VRO, WebM, WMV,   Audio formats:
AAC, FLAC, M4A, MIDI, MP3, OGG, WMA, WAV, APE, AIFF, ALAC,   Subtitles formats: |  Lan (100BASE-TX/10BASE-T)
Wi-Fi
802.11 a
802.11 b
802.11 g802.11 n
802.11 n 5GHz
802.11 ac
Wi-Fi Direct
DLNA
Bluetooth
    |  PC mode - 2160/60p - 4:4:4, 10bits |  2 x USB 2.0 (DC 5V MAX 500mA)
1 x USB 3.0 (DC 5V MAX 900mA)
1 x Ethernet RJ45
4 x HDMI 2.0a - HDCP2.2 (ARC, CEC, MHL 3.0)
1 x AV Cimposite in
1 x AV Component In
1 x Optical Audio Out (AAC/PCM/AC3/Dolby/DTS/DTS Neo2.5)
1 x Antena (RF) (female)
1 x CI+ 1.3
1 x RS.232C   Compatible Rec.2020 input   Invisible Connection
Due to the OneConnect box, the only two cables into the back of the TV are the optical OneConnect cable and a power cable. These can both be hidden behind panels. The OneConnect box and the TV each require a separate power cable. |  Double tuners
DVB-T/T2/C/S/S2
DiSEqC version 1.0
PIP, PAP, PAT
Timeshift & PVR
MPEG2, MPEG4,HEVC H.265, VP9 |  PROS
- HDR effect great good class edge LCD TVs, very good in all classes -
- Excellent representation of the traffic at the sport, one of the best TV in this respect
- Very low input lag, also in HDR mode - ideal for the PC and console players
- High brightness sensor SDR - a good choice for sun rooms
- The widest among LCD color palette - DCI 99%
- Performing at the highest level
- 360 design, the TV looks very elegantly on both the front and rear
- Large picture calibration options
- Nice black, clearly better than in other TV series QLED
- Viewing angles a little better than in a typical matrix VA
- The new system Tizen
- Great co-operation with external devices (one remote control)
- Fully ready for Ultra HD TV reception (satellite, terrestrial)
- Support for HDR television (HLG)    MINUSES
- Edge illumination despite the high-end TV character
- Poor viewing angles (though good in the class of matrices VA) |  Q9F  (Flat)
QE-88Q9F
QE-65Q9F   |
 Q8C  (Curved)
QE-75Q8C
QE-65Q8C
QE-55Q8C  successor model
KS8   |  Yes |  ? |  Yes |  Yes in internet video services, HDMI, USB port.   HDR 10+ for Amazon Video   Conversion SDR/HDR   ST2084,
ST2086,
SoC:
Core architecture:
Instruction set:
Operating at up to
GPU:
OpenGL
RAM:
Total memory:
Available memory:
TV Extension Image 3.0.2 |  75"
QDCF-MVA (Samsung Display), 3840x2160, RGB, 10-bit(?),
FRC,
Curvature 4200R   65"
FRC,
Curvature 4200R   54,5"
120/100Hz, +BFI (black frame insertion)
FRC,
Curvature 4200R |  Edge Led lighting from the bottom of the screen
()   12 Dimming blocks   WLED   MEMC   ?   BFI - yes/blinking backlight   PWM - Yes
To use the auto calibration feature you'll need to get hold of a 3.5mm to serial cable and a matching serial to USB adapter, that allows you to connect the Ex Out jack on the One Connect box to your laptop. You then run the Home Enthusiast workflow on CalMAN and use Direct Display Control to control the Q8C directly along with your pattern generator and colour meter.   White balance - 2/20 points
CMS
color Space Settings |  White Balance dE:
Color dE:
Gamma: |  75"
DCI/P3 xy - %
DCI/P3 uv - %
Rec.2020 xy - %
Rec.2020 uv - %   65"
DCI/P3 xy - 99%
DCI/P3 uv - 99%
Rec.2020 xy - 74%
Rec.2020 uv - %
Rec.709 - 127%
DCI-P3 - 85%
Rec.2020 - 58%
MDC - 442   55"
DCI/P2 xy - %
DCI/P3 uv - %
Rec.2020 xy - %
Rec.2020 uv - %   |  75"
10,000 cd/m² Rec 2020 Coverage: % |  75" -  65" -    APL   ABL - full-field peak white came in at:
5% - cd/m2 (Vivid mode) - in SDR
10% - cd/m2 (Vivid mode) - in SDR   |  75" -
75" -   65" -
65" - |  75" -
75" -
75" -
75" -
75" -   65" - 4464:1
65" - 0.0003cd/m2
65" - 0.0001cd/m2
65" -
65" - |  75"
H&V -  °
Color Shift -
Brightness -
Black Level -   65" -  °
  |  75" -
75" -   65" - 300 lines without Auto Motion Plus
65" - 1080 lines with Auto Motion Plus
  |  75" - HDR
75" - Game mode
75" - by dafault   65" - HDR - 24 ms
65" - SDR - 24 ms
65" - 4:4:4 - 20 ms
65" - Game mode 24 ms
65" - by default ms
  |  65" -   55" - 60W (20W x 2 + Woofer 10W x 2 )(4ohms)
Front Firing (4.2CH)   Dolby Digital Plus,
Dolby Puls,
DTS Premium Sound 5.1,    |  FAT16, FAT32, NTFS and exFAT   Image formats:
Wi-Fi
802.11 a,
802.11 b,
802.11 g,
802.11 n,
802.11 n 5GHz,
802.11 ac,
WiFi Direct
DLNA
Blietooth    |     |  2 x USB 2.0 (DC 5V MAX 500mA) - [HID support]
2 x USB 3.0 (DC 5V MAX 900mA)
1 x Ethernet RJ45
4 x HDMI 2.0 - (ARC, CEC, MHL 3.0)
1 x Satelite In (Main: F-type female)
1 x Satelite In (Sub: F-type female)
1 x SCART
1 x AV Composite In
1 x AV Component In
1 x Optical Audio Out (AAC/PCM/AC3/Dolby/DTS/DTS Neo 2.5)
1 x 3.5mm Audio Out
1 x CI+, (Version 1.3)
1 x RS.232C    CompatibleRec.2020 input   Invisible connection
DVB-T/T2/C/S/S2
DiSEqC version 1.0
PIP, PAP, PAT
Timeshift & PVR
MPEG2, MPEG4, HEVC H.265,
VP9 |   |  Q8C  (Curved)
QE-75Q8C
QE-65Q8C
QE-55Q8C   |
 Q7C  (Curved)
QE-65Q7C
QE-55Q7C
QE-49Q7C  successor model
KS7   |  Yes |  ? |  Yes  |  Yes in internet services, HDMI, USB port. Conversion SDR/HDR ST2084,
ST2086,
ST2094, |  No      |  No |  Plattform: Jazz-M
SoC:
Core Architecture: Quad
Instruction set:
Operating at up to: 1.7GHz
GPU:
Open GL
RAM:
Total memory:
Available memory:
Internal storage free space:   Electronics and remote connection in the One Connect box   |  OS: Tizen 3.0 |  64.5"
FRC,
3840x2160, RGB, 10-bit(?), 120/100Hz, + BFI
Curvature 4200R
Model:  ()   48.5"
120/100Hz,
FRC,
Curvature 3000R |  Edge Led lighting from the bottom of the screen
(6 zone)   12 Dimming blocks   WLED   MEMC   ?   BFI - yes/blinking backlight   PWM - |  -- |  “CalMAN Ready” HDR Autocalibration.
CMS
Color Space settings |  White Balance dE:
Color dE:
Gamma: |  55"
DCI/P3 xy - 99%
DCI/P3 uv - 99%
Rec.2020 xy - %
Rec.2020 uv - %   49"
DCI/P3 xy - %
DCI/P3 uv - %
BT.2020 xy - %
BT.2020 uv - %
  |  55"
10,000 cd/m² Rec 2020 Coverage:  %   49"
10,000 cd/m² Rec 2020 Coverage: % |  55"    49" -    APL -   ABL - full-field peak white came in at:
10% - cd/m2 (? mode) - in SDR   |  55" - 49" - |  55" -
55" -
55" -
55" -
55" -   49" -
49" -
49" -
49" -
49" - |  55"
H&V - °
Color Shift -
Brightness -
Black Level -   49"
H&V - °
Color Shift -
Brightness -
Black Level -
  |  55" - 49" -
  |  55"- HDR - ms
55"- Game mode - ms
55"- by default - ms   49"- HDR - ms
49"- Game mode -
49"- by dafault
Dolby Puls,
Wi-Fi
802.11 a,
802.11 b,
802.11 g,
802.11 n,
802.11 n 5GHz,
802.11 ac,
Wi-Fi Direct
DLNA
Bluetooth
1 x Ethernet RJ45
1 x AV Cimposite in
1 x AV Component In
1 x RS.232   Compatible Rec.2020 input   Invisible Connection
DVB-T/T2/C/S/S2
DiSEqC version 1.0
PIP, PAP, PAT
Timeshift & PVR
MPEG2, MPEG4,
HEVC H.265
VP9 |   |  Q7C  (Curved)
QE-65Q7C
QE-55Q7C
QE-49Q7C   |
 Q7F  (Flat)
QE-75Q7F
QE-65Q7F
QE-55Q7F
QE-49Q7F  successor model
ST2086,
SoC:
Instruction set:
GPU:
Open GL
RAM:
Total memory:
Available memory:
Internal storage free space:   Electronics and remote connection in the One Connect box   |  OS: Tizen 3.0 |  74.5"
120/100Hz, + BFI (black frame insertion),    64.5"
120/100Hz   54.5"
3840x2160, RGB,10-bit,
120/100Hz,
Flat   48.5"
QDCF-MVA (),
120/100Hz,
Flat |  Edge Led lighting from the bottom of the screen   12 Dimming blocks   WLED   MEMC   -   PWM - Yes   Vertical blooming is visible when there is a bright highlight. Note that on the Q7F, the local dimming cannot be totally turned off, the minimum setting is 'Low'.   |  Maximum Temperature: 46 °C
Average Temperature: 38 °C   Gray Uniformity
50% Std. Dev.: 3.955 %
50% DSE: 0.147 %
5% Std. Dev.: 0.778 %
5% DSE: 0.106 %
Black Uniformity
Std. Dev.: 1.618 %   Image Retention: 0%   Response Time: 9.9 ms
Overshoot: 0 ms   PWM Dimming Frequency: 120 Hz
BFI: No
BFI Frequency: 120 Hz
BFI In Game Mode: No   Motion Interpolation (30 fps): Yes
Motion Interpolation (60 fps): Yes   Reflection: 0.4 %
Screen Finish: Glossy   |  “CalMAN Ready” HDR Autocalibration.
CMS |  White Balance dE: 0.31
Color dE: 1.64
Gamma: 2.21   The calibration process is relatively easy to do with the 2 points, 10 points and color management system provided. With those tools, the white balance dE was brought down to a negligible 0.31 dE, which is excellent. The gamma value did not change too much (from 2.28 to 2.21), but the gamma tracks the 2.2 target much closer. The color error was brought down considerably, but even then the cyan is still a bit less precise than the other colors. |  55" -
DCI/P3 xy - 99.00%
DCI/P3 uv - 99.27%
Rec.2020 xy - 73.52%
Rec.2020 uv - 77.19%   49"
DCI/P3 xy - %
DCI/P3 uv - %
Rec.2020 xy -  %
Rec.2020 uv - %
  |  55"
Normalized DCI P3 Coverage: 86.341 %
10,000 cd/m² DCI P3 Coverage: 57.257 %
Normalized Rec 2020 Coverage: 69.545 %
10,000 cd/m² Rec 2020 Coverage: 46.116 %
Normalized Rec 709 coverage: 125.2 %   49"
10,000 cd/m² Rec 2020 Coverage: %   This color volume is good, with slightly better performance than the B6, C6 and E6 and noticeably better performance than the Samsung KS* TVs of 2016. The TV can produce saturated colors especially at higher brightness. The darker colors cannot get as saturated as OLED TVs though. |  55" - SDR results are for Movie mode calibrated to 6500k;
Real Scene Peak Brightness: 195 cd/m2
Peak 2% Window : 409 cd/m2
Peak 10% Window : 918 cd/m2
Peak 25% Window : 508 cd/m2
Peak 50% Window : 317 cd/m2
Peak 100% Window : 105 cd/m2
Sustained 2% Window : 284 cd/m2
Sustained 10% Window : 490 cd/m2
Sustained 25% Window : 468 cd/m2
Sustained 50% Window : 317 cd/m2
Sustained 100% Window : 104 cd/m2   49" -    APL -   ABL - full-field peak white came in at:
5% - cd/m2 (? mode) - in HDR
10% - cd/m2 (? mode) - in HDR   |  55" - HDR results are for Movie mode calibrated to 6500k;
Real Scene Peak Brightness: 359 cd/m2
Peak 2% Window: 598 cd/m2
Peak 10% Window : 782 cd/m2
Peak 25% Window: 599 cd/m2
Peak 50% Window: 405 cd/m2
Peak 100% Window: 362 cd/m2
Sustained 2% Window : 376 cd/m2
Sustained 10% Window: 504 cd/m2
Sustained 25% Window: 516 cd/m2
Sustained 50% Window : 361 cd/m2
Sustained 100% Window: 362 cd/m2   49" -   APL -   ABL - |  55" - 3120:1 / ANSI
55" -
55" -
55" - 100.4 cd/m2
55" - 0.020 cd/m2
This is slightly worse than the KS* TVs of 2016. 49" -
49" -
49" -
49" -
49" - |  55"
H&V - 59°/
Color Shift - 27°
Brightness - 35°
Black Level - 25°   49"
H&V - °
Color Shift -
Brightness -
Black Level -
  |  55" -   49" -
  |  55"
1080p @ 60Hz: 24.3 ms
 1080p With Interpolation : 79.5 ms
 1080p @ 60Hz Outside Game Mode: 79.4 ms
 1080p @ 60Hz @ 4:4:4: 20.2 ms
 4k @ 60Hz: 24.2 ms
 4k @ 60Hz @ 4:4:4: 20.3 ms
 4k @ 60Hz + HDR: 24.4 ms   49"   The Q7F has low input lag in game mode which is great, and should be good enough for all but the most competitive gamers. The lowest input lag was actually found in PC mode, as seen in our 4:4:4 color tests; however it's only 4 ms lower than game mode which is not significant.
Note: The game mode setting has moved into 'General' > 'External Device Manager'. |  40 W (4ohms)
2,2 chanels
Woofer   Dolby Digital Plus,
Dolby Digital Puls,
DTS,
Bluetooth Audio, |  FAT16, FAT 32, NTFS and exFAT   Video Codec
H.264 BP/MP/HP, HEVC (H.265 - Main, Main10), Motion JPEG, MVC, Divx 3.11/4/5/6, MPEG4 SP/ASP, Window Media Video v9(VC1), MPEG2, MPEG1, Microsoft MPEG-4 v1/v2/v3, Window Media Video v7(WMV1)/v8(WMV2), H 263 Sorrenson, VP6, VP8, VP9, RV8/9/10 (RV30/40)   Audio Codec
MPEG1 Audio Layer 3, MPEG4/AAC, FLAC, OGG/Vorbis, WMA, wav, midi, ape, AIFF, ALAC   Container
AVI, MKV, ASF, MP4, 3GP, MOV, FLV, VRO, VOB   File transfer
avi, mkv, asf, wmv, mp4, mov, 3gp, vro, mpg, mpeg, ts, tp, trp, mov, flv, vob, svi, m2ts, mts, divx, webm, rmvb, mp3, m4a, mpa , Aac, flac, ogg, wma, wav, mid, midi, ape, aif, aiff, m4a |  Lan (100BASE-TX/10BASE-T)
Wi-Fi
802.11 a,
802.11 b,
802.11 g,
802.11 n,
802.11 n 5GHz,
802.11 ac,
Wi-Fi Direct
DLNA
Bluetooth
    |  1080p @ 60Hz @ 4:4:4: Yes
1080p @ 120Hz: No
4k @ 30Hz @ 4:4:4: Yes
4k @ 60Hz : Yes
4k @ 60Hz @ 4:4:4: Yes   All tested resolutions worked except for 120 Hz input. To show 4k @ 60 Hz @ 4:2:2 or 4:4:4 color 'HDMI UHD color' needs to be enabled. To show 4:4:4 color properly the TV needs to be in PC mode. HDR was not supported in PC mode; the TV displayed that it was showing HDR but the picture was clearly not HDR because it was still using the gamma curve and not the PQ curve. |  2 x USB 2.0 (DC 5V MAX 500mA)
1 x Ethernet RJ45
1 x AV Cimposite in
1 x AV Component In
1 x RS.232   Compatible Rec.2020 input   15 meters optical cable - Invisible Connection
DVB-T/T2/C/S/S2
DiSEqC version 1.0
PIP, PAP, PAT
Timeshift & PVR
MPEG2,
MPEG4,
HEVC H.265, (Only for S2 & T2)
VP9 |  PROS
- wide range of colors (I think) the best on the market covering the DCI,
- excellent sharpness of moving images,
- very good control of the flow of traffic,
- good contrast (but see below)
- bad characteristics of brightness in HDR mode (but see. below)
- subjectively very attractive image in 4K,
- trouble accepting 12-bit signal from the Blu-ray 4K
- very large, the largest market in the number of playable video formats from USB
- very low input lag in game mode (24,7ms)
- Only two cables from the TV make life easier for those planning to hang it on the wall,
- Tizen system works quickly and efficiently and is more user-friendly than Android and Firefox OS,
- One unique module Connect allows you to move away from the TV cable clutter at a convenient distance
- the best on the market and features the largest number of smart applications,
- extremely attractive welcome package applications - Elite SmartPack,
- All HDMI accept augmentation signal 4K (and not just two like. Sony)
- good, clear sound with good bass selected,
- good performance and finish.
- solid metal base,
- modern, attractive appearance,
- great, unique, almost luxurious remote control (something wonderful).   MINUSES
-  Non-exclusive manipulation of the brightness characteristics in SDR mode, which has a negative effect on color reproduction and detail in dark and bright parts of an image,
- very large errors in color reproduction in primary mode SDR (particularly red) when they occupy a considerable portion of the surface of the screen,
- brightness in the HDR mode, almost half the declared (800 instead of 1500 cd / m ^ 2)
- low brightness mode SDR (only 180 cd / m ^ 2 full screen)
- larger than the color reproduction errors in last year 55KS8000,
- ANSI contrast almost 40% lower than in last year's 55KS8000,
- fading in or out areas of the screen by means of vertical strips interferes with the original intentions of creators of films and punching dynamic light by black bars are unlikely to appeal to purists.
- blanking of the algorithms / lightening could be more elaborate - not always succeed in demanding scenes (see Exodus)
- the inability to disable the "local dimming" (local extinction) by the user,
- preset menu impractical bright in a dark room and / or HDR mode (but can be changed to dark)
television still does not play 4K resolution greater than 2160 vertical lines, e.g.,. 2304p.
- the lack of USB ports 3.0,
- none of the traditional headphone jack.
- thin optical cable more susceptible to damage than traditional cables (manual warns about this many times)
- CICAM module does not fit in the box Connect One - the protruding part is not very aesthetic,
- glossy plastic module Connect One susceptible to scratches and exposes too well fingerprints,
- pilot may be harder to use for people with large hands,
- TV high price (compared to the possibilities). |  Q7F
(Flat)
QE-75Q7F
QE-65Q7F
QE-55Q7F
QE-49Q7F   |
