Той е наличен от повече от седмица в други държави,за БГ излезе преди 3-4 дена.Имам го свален,но точно в това гадно време не смея да го кача с флашка.Какъвто съм си карък,точно тогава ще вземе да спре тока :)
https://nl.hardware.info/reviews/742...beter-dan-oled
QE55Q7F: subpixel panel structure RGB,(за съжаление нидерландците не са направили снимка с поне 50 кратно увеличение за да видим точнта структура- MVA)
https://content.hwigroup.net/images/...sub-pixels.jpg
...viewing Angles
What we find particularly interesting is how Samsung has managed to improve the viewing angles. This is not so much seems to be a change in the panel technology, but rather in the way the panels are controlled. The QLED TVs, namely, fit a foreign kind of dithering, in which pixels are located next to each other and to-be brighter and less bright displayed. The viewing angle of pixels 'full open' stand is in fact better than that of pixels partially pinched. Through to quarter-to control, there are more pixels with high brightness, resulting in improved viewing angles of the screen. In practice, the effect of this control hardly visible, only if you close to plain gray surface looks can clearly see that not all pixels illuminate same. A realistic viewing distance it is virtually invisible effect, though, the effective resolution is of course by off. Possibly for this reason, the TV does not always dithering mode. Depending on what is being displayed on the screen, the screen sometimes chooses to send to the panel in a traditional manner, with all the pixels so really work individually. During our test showed that the actual television to display video sources always worked in dither mode, while playing a desktop PC usually opted for the normal mode. In some cases, the TV turns off and switch to, we noticed that when playing HDR test patterns from an ultra-high definition Blu-ray disc...
...Although dithering method clearly something helps to improve viewing angles, is in our opinion a shame that you as a consumer have the choice to enable or disable this feature, the TV it always decides for himself. If you are always right screen is it - especially at smaller viewing distances - in our opinion better to have eliminated the dithering because it improves the image sharpness. Perhaps Samsung the option to enable or disable this feature manually adds later via a firmware update.
https://www.youtube.com/watch?v=bq8jbNTOFwU
https://content.hwigroup.net/images/...ng-qe55q7f.jpg
source photo:[nl.hardware.info]
Някой да е инсталирал 1180 за KS, че в youtube този твърди, че се влошава драстично качеството на картината след ъпдеита?
https://www.youtube.com/watch?v=osyd1F0_CwI
Аз инсталирах. Не виждам промяна в качеството на картината.
Модели 2016г получиха ли ъпдейт до Tizen 3.0 , че новите (2017) гледам ги дават с 3.0 ?
Къде точно гледате за ъпдейти, че днес моя се ъпдейтна, но не намирам информация за промените?
Ми аз за това и питах дали е получена ;). Реално не би трябвало да има пречки , щото повечето модели са същите хардуерно ... освен да послъгват в описанията - някой взел ли е нещо от 2017г да каже с коя версия са ?
Самсунг не ъпдейтват версията на Tizen до актуалната в момента. Или поне не пипат по потребителският интерфейс. Така, че едва ли ще се случи. Който иска нова версия, да си купува новият модел ТВ :)
За съжаление, Samsung са от малцината компании, които не публикуват списък на промените (changelog)
Център за изтегляния | Samsung България
Къде мога да намеря последната версия на фирмуеъра на моя телевизор?
QE65Q7FAM - 65A1MU8XM
http://www.vybortv.ru/forum-o-televi...art=170#p68422
43MU6100 - 43L6AUOVM
Малко снимки на панели
43MU6102 - IPS
https://forum.setcombg.com/attachmen...id=23611&stc=1
49MU6472 - IPS
https://forum.setcombg.com/attachmen...id=23612&stc=1
50MU6102 - VA
https://forum.setcombg.com/attachmen...id=23613&stc=1
55M5512 - VA
https://forum.setcombg.com/attachmen...id=23614&stc=1
Леко кофти се вижда вече с таз камера :(
Добре са, моите и по-лоши стават . Горните повече ми приличат на AMVA, отколкото на IPS :confused:
После пак ще мина през някой магазин да опитам нова снимка, но с такъв диагонал на 4К си е тегаво с циклопа, който ползвам.
За 49-ката съм сигурен, че не е VA панел.
Още един клип с предупреждение да не се ъпдейтва до 1180
https://www.youtube.com/watch?v=D82GLKzpQfA
Аз ъпдейтнах преди няколко дни и не виждам с нещо да ми е влошено качеството на картината, единствено при игра с hdr подръжка вече не излиза надписа с предупреждението, че се пуска hdr съдържание.
