Samsung MU7000 review | TrustedReviews
Можете ли да препоръчате нещо максимално добро за около 600 лева.
Сравнение по характеристики
Comparaison des produits s
с тази разлика, че М5575 има вграден сателитен тунер, а М5502 няма
Samsung UE55MU7002
https://avmania.e15.cz/samsung-ue55m...r--test#part=1
Samsung TV 2017
Europe
QE65Q9F: Edge LED (right-left, local dimming), Samsung MVA panel (RGB) , 120/100Hz with MCFI + flashing backlight, QDCF, firmware T-KTMDEUC
QE65Q8F: Edge LED (bottom), Local Dimming-12 blосkѕ, Samsung MVA panel (RGB), 120/100Hz + blinking backlight, QDCF, in service menu 65A1MU8XM, firmware T-KTMDEUC
QE65Q8C: Edge LED (bottom), Local Dimming-12 blосkѕ, Samsung MVA panel (RGB), 120/100Hz + blinking backlight, QDCF, firmware T-KTMDEUC
QE65Q7F: Edge LED (bottom), Local Dimming-12 blосkѕ, Samsung MVA panel (RGB), 120/100Hz + BFI (Black Frame Insertion), QDCF, in service menu 65A1MU8XM, firmware T-KTMDEUC
QE65Q7C: Edge LED (bottom), Local Dimming-12 blосkѕ, MVA panel (RGB), 120/100Hz + BFI (Black Frame Insertion), QDCF, firmware T-KTMDEUC
QЕ55Q7F: Edge LED (bottom), Local Dimming-12 blосkѕ, Samsung MVA panel (RGВ), 120/100Hz + blinking backlight, QDCF, firmware T-KTMDEUC
UE55MU9002: Edge LED (bottom), Samsung MVA panel (RGB), 8-bit + FRC(10-bit), 120/100Hz + blinking backlight, in service menu -, firmware T-KTMDEUC
UE49MU9002: Edge LED (bottom), Samsung MVA panel (RGB), 8-bit + FRC(10-bit), 120/100Hz + blinking backlight, in service menu -, firmware T-KTMDEUC
UE75MU8002: Edge LED (bottom), Samsung MVA panel (RGB), 8-bit + FRC(10-bit), 120/100Hz + blinking backlight, in service menu -, firmware T-KTMDEUC
UE65MU8002: Edge LED (bottom), Samsung MVA panel (RGB), 8-bit + FRC(10-bit), 120/100Hz + blinking backlight, in service menu -, firmware T-KTMDEUC
UE55MU8002: Edge LED (bottom), Samsung MVA panel (RGB), 8-bit + FRC(10-bit), 120/100Hz + blinking backlight, in service menu -, firmware T-KTMDEUC
UE49MU8002: Edge LED (bottom), Samsung MVA panel (RGB), 8-bit, 60/50Hz + blinking backlight, in service menu 49A6AUOSM, firmware T-KTMDEUC
UE55MU7000: Edge LED (bottom-local dimming), MVA panel (RGB), 120/100Hz + blinking backlight, firmware T-KTMDEUC
UE49MU7002: Edge LED, Samsung MVA panel (RGB), 60/50Hz, in service menu 49A6AUOSM, firmware T-KTMDEUC
UE49MU6642: a-si TFT MVA panel (RGB), 60/50Hz, firmware T-KTMDEUC
UE55MU6502: a-si TFT MVA panel (RGB), 60/50Hz, firmware T-KTMDEUC
UE55MU6472: Edge LED (bottom), a-si TFT IPS(PLS) panel (RGВ), 60/50Hz + blinking backlight, firmware T-KTMDEUC
UE55MU6402: Edge LED (bottom), a-si TFT IPS(PLS) panel (RGВ), 60/50Hz + blinking backlight, firmware T-KTMDEUC
UE49MU6472: Edge LED (bottom), a-si TFT IPS(PLS) panel (RGВ), 60/50Hz + blinking backlight, firmware T-KTMDEUC
UE49MU6402: Edge LED (bottom), a-si TFT IPS(PLS) panel (RGB), 60/50Hz + blinking backlight, firmware T-KTMDEUC
UE49MU6400: Edge LED (bottom), a-si TFT IPS(PLS) panel (RGB), 60/50Hz + blinking backlight, firmware T-KTMDEUC
UE40MU6402: Edge LED (bottom), a-si TFT MVA panel (RGB), 50/60Hz + blinking backlight,
UE55MU6202: Edge LED (bottom), a-si TFT MVA panel (RGB), 60/50Hz
UE49MU6202: Edge LED (bottom), a-si TFT MVA panel (RGB), 60/50Hz,
UE55MU6172: a-si TFT IPS(PLS) panel (RGВ), 60/50Hz,
UE55MU6102: a-si TFT IPS(PLS) panel (RGB), 60/50Hz, in service menu 55,
UE55MU6100: a-si TFT IPS(PLS) panel (RGB), 60/50Hz, in service menu 55
UE50MU6102: a-si TFT MVA panel (RGB), 60/50Hz, platform
UE50MU6100: a-si TFT MVA panel (RGB), 60/50Hz, platform
UE43MU6100: a-si TFT AMVA panel (RGB), 60/50Hz, in service menu 43L6AUOVM,
UE40MU6102: a-si TFT MVA panel (RGВ), 60/50Hz,
UE55M5512: a-si TFT MVA panel (RGВ), 60/50Hz,
UE43M5502: a-si TFT MVA panel (RGB), 60/50Hz,
UE32M5602: a-si TFT MVA panel (RGВ), 60/50Hz,
Преди повече от 5 г. се сдобих с 40ES6100, а след това и с 32H5500. В семейството е наличен и един 32F5000.
Машините са безпроблемни и имат добро сервизно обслужване, по мое мнение.
Скоро към тях се присъедини и eдин нов 49KS7002. Няма такива много налични по магазините, така че който се чуди дали да взема такъв да не се бави много-много.
ТВ се използва за гледане на телевизия и филми с висока резолюция през медия-сървър. Вероятно ще се пуска и YouTube. През последната година гледах много филми през компа със слушалки, което беше причина да добавя към новата придобивка и един саундбар К450, защото звукът от ТВ изобщо не ме удовлетворяваше, а според мен хубавата картина върви с хубав звук. Ползвам интернет и IPTV, доставяни от оранжевия доставчик и съм доволен от услугата. Ползвам виртуален медия-сървър Serviio и напълно ме удовлетворява.
Откакто Samsung прекратиха Samsung Link не съм наясно предлагат ли някакъв нов подобен софтуер или услуга за нашите ТВ? Моля да ме насочите, ако има такива?
Не съм срещал някакви препоръки за настройки на картината, но ако има такива, моля да ме ориентирате? Редовно подменям фърмуеъра на ТВ с новите версии, така че с това ще се справя сам. Моля да споделите някои съвети и трикове за 49KS7002, защото миналата и тази година не съм следил редовно тази тема. С една дума - моля споделете своя опит с този модел или ме насочете къде да чета?
Благодаря!
П.п. След двудневни проби вече мога да кажа следното за работата на ТВ при мен:
1.YouTube от приложението при мен почти винаги забива - започва да плейва някаква листа и си остава на нея, като не приема никакви команди през дистанционното, менюто и т.н. Оправя се само след изключване и престой. През браузъра работи без проблем. Може да се пусне и през телефона.
ЗаТВ работи този fix - https://www.youtube.com/watch?v=HdW1JFEczso
2.При Serviio - лесно се свързва, но при възпроизвеждането на един *.mkv файл 1080р (сериал) се оказа, че на компа се стартира ffmpeg-процес, който натоварва почти на 100% процесора на компа (Core i5-3230M) и макар и рядко се стига до насичане на картина и звук. При по-леките файлове няма проблеми.
3.С PLEX работи безпроблемно, но пък той самият безплатен PLEX нещо не вижда папките със сериали (папките са празни), а вижда само филми .....
4.Намерих настройки за картината от темите във форума.
5.ТВ си дойде с фърм 1180.5, така че няма по-нова версия.
6.В режим "Телевизия" - без коментар. Перфектен!
7.Не съм ползвал много браузъра, но от това което видях съм доволен.
Здравейте предстои ми покупка на телевизор и съм се спрял на този модел Samsung 49KS7002.
Питането ми е следното има ли въпросният модел истинска 10 битова матрица.
Изчетох целият форум 2016 и 2017 едни казват, че е други,че не е вече не знам на кой да вярвам.
Благодаря за отделеното внимание.
с 10 битова е.
Въпросът е какво реално ще получиш в повече, ако е истинска 10-битова матрица?
То никой не знае колко истински HDR гледа. Новите модели са с 50% по-голяма пикова осветеност, значи би трябвало да са с 50% по HDR от нашите :) 8bit+FRC докарват голяма част от цветопредаването на 10 битовата матрица, просто не могат да се сертифицират за HDR10 заради изискването да е 10 бита матрицата
stenly
Виж сертифицираните
TVs – UHD Alliance
Нещо липсват миналогодишните модели..:) В старата тема, изказах съмнение относно 10-bit панели в някои от тях....Цитат:
Samsung 49Q7F
Samsung 49Q7C
Samsung 55Q7F
Samsung 55Q7C
Samsung 55Q8C
Samsung 65Q7F
Samsung 65Q7C
Samsung 65Q8C
Samsung 65Q9F
Samsung 75Q7F
Samsung 75Q8C
Samsung 75Q9F
А според мен просто Самсунг умишлено "убиха" KS (щото и KS9 липсва) серията, че сравнението с новите скъпи пръчки не изглеждаше добре за новитеQ като за по-добри , а същевременно много по-скъпи ...
