Отговор: Samsung телевизори 2017
svetlio1
Още от вчера нещо бъркаш с цената.
Samsung Q9 review - FlatpanelsHD
...Samsung has this year decided to abandon FALD (full-array local dimming) and implemented edge LED its high-end TVs. This is a change from previous years. Q9 is the flagship model and it is equipped with LEDs placed along the sides of the TV, which is a curious decision considering that both Sony and Panasonic are raising the bar for LCD technology by implementing yet more advanced local dimming systems, and especially considering the history of issues that have been associated with edge LED.
Samsung has also decided to abandon its ‘SUHD’ moniker in favour of ‘QLED’, which is a marketing term for LCD panels with quantum dot technology. Historically, researchers have used the term ‘QLED’ to refer to an entirely new self-emitting display technology but Samsung decided to go ahead and use it to wrap its LCD in sparkling glitter paper. It is clearly meant to confuse consumers to think that ‘QLED’ and ‘OLED’ are related and it is honestly a bit tiring to once again see Samsung’s marketing engine go into overdrive. It happened with ‘LED’, then ‘SUHD’, and now ‘QLED’, each time trying to sell LCD technology as "the next big thing". Just produce a real QLED TV and call a spade a spade....
| Measurements | Out-of-box | Calibrated |
| Black level | 0.05 cd/m2 | 0.03 cd/m2 |
| Black level (HDR) | 0.17 cd/m2 | 0.17 cd/m2 |
| Brightness | 250 cd/m2 | 203 cd/m2 |
| Max brightness (HDR) | 1286 (770) cd/m2 | 770 cd/m2 |
| Contrast | 7000:1 | 7400:1 |
| Contrast (HDR) | 4580:1 | 4580:1 |
| Input lag | 81 ms | 21 ms (Game Mode) |
| DCI-P3 | 98% | - |
| Rec.2020 | 70% | - |
| Power consumption | Out-of-box | Calibration |
| SDR | 160 W | 130 W |
| HDR | 307 W | 307 W |
| Standby | 1.0 W | |
| Time measurements | Seconds |
| Start-up (until responsive) | 3s |
| Start-up (until picture comes on) | 2s |
| Netflix app start-up | 5s |
| Youtube app start-up | 3s |
| Amazon app start-up | 4s |
| Google Play app start-up | 7s |
| Video file / source | Specs | Status |
| Amazon 4K HDR | 4K (3840x2160 pixels) – 10 bit colors - Rec.2020 color space – 4:2:0 subsampling – HEVC | Works |
| Netflix 4K HDR | 4K (3840x2160 pixels) – 10 bit colors - Rec.2020 color space – 4:2:0 subsampling – HEVC | Works |
| YouTube 4K HDR | 4K (3840x2160 pixels) – 10 bit colors - Rec.2020 color space – 4:2:0 subsampling – VP9 Profile2 | Works |
| Dubai 4K | 4K (3840x2160 pixels) – 23.976fps – 10 bit colors - BT.709 color space – 4:2:0 subsampling – 51.4 Mbps bitrate – HEVC - .ts file | Works |
| Costa Rica 4K | 4K (3840x2160 pixels) – BT.709 color space – 4:2:0 subsampling – 12.71 Mbps bitrate – VP9 - .mkv file | Works |
| Terrifying Pyroclast 4K | 4K (3840x2160 pixels) – BT.709 color space – 4:2:0 subsampling – variable bitrate – VP9 - .mkv file | Works |
| Big Buck Bunny HD (.ts version) | HD (1920x1080 pixels) – 8 bit colors - YUV color space – 4:2:0 subsampling – 2.5 Mbps bitrate – 60fps - HEVC - .ts file | Works |
| Big Buck Bunny HD | HD (1920x1080 pixels) – 8 bit colors - YUV color space – 4:2:0 subsampling – 60fps - 2.2 Mbps bitrate – HEVC - .mkv file | Works |
| LG Arctique 4K | 4K (3840x2160 pixels) – 8 bit colors – YUV color space – 4:2:0 subsampling – 50.0 Mbps bitrate – 29.970fps - AVC - .mp4 file | Works |
| Eutelsat 4K demo | 4K (3840x2160 pixels) – 10 bit colors – YUV color space – 4:2:0 subsampling – 23.1 Mbps bitrate – 50fps - HEVC - .ts file | Works |
| TravelXP HLG | 4K (3840x2160 pixels) – 50fps frame rate – 10 bit colors – BT.2020 color space – 4:2:0 subsampling – 20.7 Mbps bitrate – HEVC – HLG – .ts file | Fails |
| Ghost Towns 8K | 8K (7680x4320 pixels) – variable frame rate – 8 bit colors - YUV color space – 4:2:0 subsampling – 20.7 Mbps bitrate – AVC - .mp4 file | Fails |
| HFR (100fps) test file | 4K (3840x2160 pixels) – 100fps – 10 bit colors – Rec.2020 color space – 4:2:0 subsampling – 23.7 Mbps bitrate – HEVC - .ts file | Fails |
Настройки (напомням, че са за конкретната тествана бройка)
| Group | Setting | Value |
| Profile | Movie |
| Expert | Backlight | 12 |
| Brightness | 0 |
| Contrast | 95 |
| Sharpness | 0 |
| Color | 50 |
| Tone (G/R) | R50 |
| Use picture settings | All sources |
| Digital clean view | Off |
| Auto Motion Plus | Off / (0/0) |
| Local Dimming | Low |
| HDMI UHD Color | On for HDR HDMI sources |
| Dynamic Contrast | Off |
| Color temp | Warm2 |
| Gamma | BT.1886 +1 |
| Color space | User |
| White balance | 2-point | |
| -Red | 7 |
| -Green | 7 |
| -Blue | 7 |
| +Red | 10 |
| +Green | -7 |
| +Blue | 0 |
svetlio1
Е да де, ама като го писах беше толкова ..., то и сега пак е с 270лв по-ниска от тукашните технота .:Drinks:
MU9000 : they replace the KS7500 of 2016 .
The MU9005 range is close to the features of last year's SUHD models (KS7500). There is a VA 100 Hz panel natively 10 bits and the luminous peak is announced at 1000 cd / m². The series also adopts an Ultra filter and Auto Depth Enhancer technology to improve the contrast ratio. Beware, the 49-inch model uses only a simulated 10-bit panel (8-bit + FRC), but unlike the 49-inch MU7000, it is 100 Hz. For the rest, the features are identical to the MU7045 series.
The differences of the 7045 range with the 7005 are subtle. Samsung is announcing a Micro Dimming Supreme UHD system (versus a Micro Dimming UHD for the MU7005 models), but both series share an Edge-Led backlight system, like all 2017 Samsung TVs mentioned in this article . The difference must therefore be made in the image processing, probably slightly more powerful. The fluidity index goes from the PQI 2300 (MU7005) to the PQI 2400. Be careful though, the 49-inch model is still limited by its 60 Hz panel.
Samsung UE65MU7075 - Edge-LED, 8-bit + FRC, VA panel,
This model is a variant of the MU7045, which is differentiated by its remote control. The MU7075 uses the same aluminum remote control as the QLed models.
The real changes come with the MU7005 series. If the 49-inch model is to be avoided (the VA 60 Hz panel is identical to that of the MU6405 models), the 55, 65, 75 and 82-inch models feature a VA 100 Hz panel, making it possible to scan the backlight - And we know from experience that the Auto Motion Plus from Samsung is very powerful. This range is announced HDR 1000 compatible, which implies a higher luminous peak (announced at 600 cd / m²). Compared to the MU6000 series, there are many improvements: the audio system switches to 40 W, there are 4 HDMI ports and 1 USB 3.0 port in addition to the 2 USB 2.0 ports, and even a dual DVB-T tuner, cable and satellite. The MU7005 series also uses the Mini One Connect, which allows the connection to be offset. It is a real upscale,
UHD TV (серии MU6100, MU6200, MU6400, MU6500, MU6600)
Samsung UE-MU6600(curved) : the declination of the MU6500 with a darker frame.
The MU6605 series is a variant of the MU6505 series. The three diagonals all have a curved VA slab and share the same characteristics. Samsung announces only a slightly faster PQI 1700 fluidity index, compared to a PQI 1600 for the MU6505 series. The most striking change is the color of the frame, here in imitation titanium with a matching foot.
The MU6505 series is simply the curved version of the MU6405. There is therefore no change in the characteristics. On the other hand, all these models have a VA panel and there should be no surprise in terms of contrast.
The MU6405 series shares the same features with a few details. The design is slightly different, since the borders are no longer black, but imitation aluminum. And this model embeds a DVB-S / S2 satellite tuner in addition to the DVB-T and cable tuner. As mentioned above, be careful when buying: the 49 and 55-inch versions are equipped with a PLS panel, the contrast of which is much lower than that of the other models in VA.
All these models have a VA Ultra HD panel, except for the 55-inch PLS. The native frequency is blocked at 50 Hz, which prevents the use of backlight scanning to improve the sharpness of moving images. These models are HDR-compatible, but again, we can not expect much, because the maximum brightness is limited to around 350 cd / m². Moreover, these panels are not natively in 10 bits, but use the Frame Rate Control Technology (FRC ) method to achieve this. These televisions have two 10W speakers and a fairly comprehensive connectivity (3 x HDMI, YUV / Composite, 2 USB ports, 1 optical output, and Wi-Fi), but they still do not Headphone output. Samsung's Tizen operating system,
Тея от Самсунг са .... По въпроса с бялото петно което ми се появи до долната рамка ето техният "експертен" отговор. Дал съм им още седмица да си помислят дали са го видяли и препращам писмото до КЗП както и ще пиша до централата им ...за кеф.
Благодарим Ви, че се свързахте със Самсунг Електроникс България!
Във връзка с Вашето запитване Ви информираме следното:
Симптомът, от който се оплаквате не представлява дефект, това е нормална проява на всеки дисплей, който използва активна матрица TFT . Този феномен се забелязва по-добре в случаите, при които дисплеите използват LED посветка в сравнение с дисплеите, които използват подсветка с лампи (CCFL), защото светлинната интензивност, която са в състояние да произведат устройствата с LED подсветка е много по-голяма отколкото на тези, които са с лампи (обикновен LCD).
Повишената интензивност на светлината предоставя по-добро качество на картината при условия на силно осветление в помещението (стая с естествена дневна светлина), условия, при които един обикновен LCD няма да възпроизведе толкова добра картина.
За да се възползвате от съответстващо изображение и при условия на по-ниска осветеност на помещението е необходимо да намалите в съответствие интензитета на единицата за led осветеност (Backlight) .
Използването на необосновано висока интензивност създава феномена, от който се оплаквате.
В случай че се нуждаете от допълнителна информация, не се колебайте да се свържете с нас на адрес : serom.bg.contactus@samsung.com
Ето го и дефекта:
https://forum.setcombg.com/attachmen...id=23998&stc=1
Направо ги прескачай и се свързвай с централата - то нищо чудно ако и лентата с диодите са лепили с двойно залепващо "тиксо" да се е отлепила и понадигнала в тая област;) и едав ли ще е сериозно усилие да се фиксира ама тия ботове от съпорта ги пишат едни ...
Мен преди ония от ЛГ се опитаха да ме убеждават , че не мога да си настроя тв ... , когато те не бяха сложили 100хц панел:029:
49MU6500....
http://www.vybortv.ru/forum-o-televi...&t=1807#p64620
stenly
Я пак?? Този симптом го има само при a-si TFT видеопанели използващи Edge-LED подсветка в долната част на рамката! Причината? Разместени лента със светодиоди, дифузьор...
Тези с CCFL, HCFL подсветка не се прилагат в телевизорите от години, а причината да не се среща при тях е, че лампите се намират директно зад матрицата, а не в долната част на рамката.
Повърхностно погледнато е така, но само ако се използва Direct-LED подсветка с локално затъмняване и голям брой клъстъри + променен алгоритъм за управление на субпикселите...в противен случай от това страда контраста.
За да се възползвате от съответстващо изображение и при условия на по-ниска осветеност на помещението е необходимо да намалите в съответствие интензитета на единицата за led осветеност (Backlight).
Това е най-лесното, като решение...ама нали така "ще пострада качеството на образа"- както се изразяват по горе.
Това не е феномен, а ефект, причинен от дефект.
Можеше и по-добра снимка да качиш :) иначе едва ли ще ти го ремонтират. Опасявам се, че в сервизите нямат право да отварят видеопанелите. Ако има техник във форума нека пише дали съм прав.
LG, Sony и Sharp увеличават доставките на телевизори за сметка на Samsung и китайски производители
По данни от отраслови източници, компаниите LG, Sony и Sharp увеличават доставките на телевизори за сметка на Samsung и големи китайски производители, които, напротив, са съкратили доставките.
Компанията Samsung първоначално е планирала да пусне тази година 48 млн телевизора, което е малко повече от миналогодишният показател от 46 млн броя. Но както се твърди, южнокорейският производител се наложило да коригира плана до 45 или даже до 42 млн броя, доколкото се е снижило търсенето.
Потвърждение на информацията за сега няма, тя даже е довела до повишаване на цените на LCD панелите за телевизори.
Очаква се, че планът по доставките няма да бъде изпълнен не само от Samsung, но и пет от шестте големи китайски производители (изключвайки TCL).
В същото време, на LG приписват увеличение в доставките до 29 млн броя. Миналата година същата компания пусна 28 млн телевизора. Очаква се, че компанията Sony ще увеличи доставките с 12 до 13 млн броя. За нарастването в доставките от тези производители помага интересът на потребителите към моделите с OLED екрани.
С цел да увеличат доставките, Sony и LG са се обърнали към странични производители: Sony - към TPV Technology и Foxconn Electronics, които заедно ще пуснат тази година 6 млн телевизора под марката Sony; а LG - към TPV Technology, Skyworth и BOE Vision-electronic Technology, които ще пуснат 4 млн телевизора под марката LG.
Компанията Sharp през тази година ще увеличи доставките на телевизори повече от два пъти - до 9-9,5 млн броя.
LG, Sony, Sharp ramping TV shipments at expense of Samsung, China players
SmartTv Service Remote Control
https://play.google.com/store/apps/d...arov.smarttvrc
https://www.youtube.com/watch?v=eazAn9l11cY
2017: Обзор и тест Samsung 43M5500, 49M5500
Samsung QE65Q7F : Test complet - Téléviseur - Les Numériques
QE65Q7F: true 4K UHD (RGB), MVA panel, Edge LED (bottom-local dimming-vertical stripes) LCD, 100/120Hz with MCFI + flashing backlight, HDR10/HLG/HDR10 + compatible, WCG, Tizen os.
Подсветка в долната част на рамката (долу в дясно, се вижда топлинната сигнатура на one conect box)
http://img1.lesnumeriques.com/optim/.../15261/q7f.jpg
http://img1.lesnumeriques.com/optim/...e65q7f-6-l.jpg
Белият оптичен кабел с куплунга идващ от One Connect Box - внимавайте да не го прегъвате, в комплекта трябва да има специален защитен пластмасов извит улей, през който се прекарва кабела, когато трябва да направите 90 градусов завой.
http://img1.lesnumeriques.com/optim/...-qe65q7f-3.jpg
One Connect Box не става за други марки телевизори, защото няма HDMI изход (output).
http://img1.lesnumeriques.com/optim/...e65q7f-2-l.jpg
Универсалното дистанционно
Smart Remote - Almighty one remote control | Samsung QLED TV
http://img1.lesnumeriques.com/optim/...-qe65q7f-1.jpg
Добър звук между 60Hz и 2000Hz за разбираем говор (гледа се зелената зона), но не достатъчно, така че е препоръчително да имате външно озвучаване(не говоря за компютърни колонки..)
http://img1.lesnumeriques.com/optim/.../15261/son.jpg
sourse: lesnumeriques.com
:confused: Всички HDMI на всички марки тв обикновено са си "вход" - изход е само аудиото по ARC ..., каква ти е идеята с това дето си написал?
svetlio1
В случай, че искаш да ползваш One Connect Box с телевизор от друга марка. Бокса няма HDMI изход, а само специалният One Conect порт, и съответно такъв кабел.
TV QLED (серии Q7F, Q7C, Q8, Q9) - HDR 2000 нита и 10-битов панел с Ultra HD Premium сертификат
TVs – UHD Alliance
HDR 10+(SMPTE 2094-40),
| Samsung QLED TV 2017 - european models |
Series Q
Model ______________ | Type
_________________ | bit
__________ | Resolution
_________ | Subpixel structure
_________ | Panel frequency | MCFI
Motion Clarity Frame Interpolation | BFI
black frame insertion | Backlight
_______________ | HDR
_________ | Series Q
QE-88Q9F | a-si TFT MVA QDCF (Samsung) | 10-bit | 3840x2160 | RGB | 120/100Hz | Yes | Yes | Edge LED (right-left, local dimming) | 2000cd/m2 | QE-88Q9F |
QE-75Q9F | a-si TFT MVA QDCF (Samsung) | 10-bit | 3840x2160 | RGB | 120/100Hz | Yes | Yes | Edge LED (right-left, local dimming) | 2000cd/m2 | QE-75Q9F |
QE-65Q9F | a-si TFT MVA QDCF (Samsung) | 10-bit | 3840x2160 | RGB | 120/100Hz | Yes | Yes | Edge LED (right-left, local dimming) | 2000cd/m2 | QE-65Q9F |
QE-75Q8C | a-si TFT MVA QDCF () | 10-bit | 3840x2160 | RGB | 120/100Hz | Yes | Yes | Edge LED (bottom) | 1500cd/m2 | QE-75Q8C |
QE-65Q8C | a-si TFT MVA QDCF (Samsung) | 10-bit | 3840x2160 | RGB | 120/100Hz | Yes | Yes | Edge-LED (bottom) | 1500cd/m2 | QE-65Q8C |
QE-55Q8C | a-si TFT MVA QDCF (Samsung) | 10-bit | 3840x2160 | RGB | 120/100Hz | Yes | Yes | Edge LED (bottom) | 1500cd/m2 | QE-55Q8C |
QE-65Q7C | a-si TFT MVA QDCF (Samsung) | 10-bit | 3840x2160 | RGB | 120/100Hz | Yes | Yes | Edge LED (bottom) | 1500cd/m2 | QE-65Q7C |
QE-55Q7C | a-si TFT MVA QDCF (Samsung) | 10-bit | 3840x2160 | RGB | 120/100Hz | Yes | Yes | Edge LED (bottom) | 1500cd/m2 | QE-55Q7C |
QE-49Q7C | a-si TFT MVA QDCF (Samsung) | 10-bit | 3840x2160 | RGB | 120/100Hz | Yes | Yes | Edge LED (bottom) | 1500cd/m2 | QE-49Q7C |
QE-75Q7F | a-si TFT MVA QDCF (Samsung) | 10-bit | 3840x2160 | RGB | 120/100Hz | Yes | Yes | Edge LED (bottom-12 zones) | 1500cd/m2 | QE-75Q7F |
QE-65Q7F | a-si TFT MVA QDCF (65A1MU8XM-Samsung) | 10-bit | 3840x2160 | RGB | 120/100Hz | Yes | Yes | Edge LED (bottom-12 zones) | 1500cd/m2 | QE-65Q7F |
QE-55Q7F | a-si TFT MVA QDCF (Samsung) | 10-bit | 3840x2160 | RGB | 120/100Hz | Yes | Yes | Edge LED (bottom-12 zones) | 1500cd/m2 | QE-55Q7F |
| QE-49Q7F | a-si TFT MVA QDCF (Samsung) | 10-bit | 3840x2160 | RGB | 120/100Hz | Yes | Yes | Edge LED (bottom-12 zones) | 1500cd/m2 | QE-49Q7F |
| Series | Premium UHD TV | Series |
| QE-65MU9000C | a-si TFT MVA QDEF () | 10-bit | 3840x2160 | RGB | 120/100Hz | Yes | Yes | Edge-LED (bottom) | 1000cd/m2 | QE-65MU9000C |
| QE-55MU9000C | a-si TFT MVA QDEF () | 10-bit | 3840x2160 | RGB | 120/100Hz | Yes | Yes | Edge-LED (bottom) | 1000cd/m2 | QE-55MU9000C |
| QE-49MU9000C | a-si TFT MVA QDEF () | 8-bit + FRC | 3840x2160 | RGB | 120/100Hz | Yes | Yes | Edge-LED (bottom) | 1000cd/m2 | QE-49MU9000C |
| QE-85MU8000 | a-si TFT MVA QDEF (Samsung) | 8-bit + FRC | 3840x2160 | RGB | 120/100Hz | Yes | Yes | Edge-LED (bottom + local dimming) | 1000cd/m2 | QE-82MU8000 |
| QE-75MU8000 | a-si TFT MVA QDEF (Samsung) | 8-bit + FRC | 3840x2160 | RGB | 120/100Hz | Yes | Yes | Edge-LED (bottom + local dimming) | 1000cd/m2 | QE-75MU8000 |
| QE-65MU8000 | a-si TFT MVA QDEF () | 8-bit + FRC | 3840x2160 | RGB | 120/100Hz | Yes | Yes | Edge-LED (bottom) | 1000cd/m2 | QE-65MU8000 |
| QE-55MU8000 | a-si TFT MVA QDEF () | 8-bit + FRC | 3840x2160 | RGB | 120/100Hz | Yes | Yes | Edge-LED (bottom + local dimming) | 1000cd/m2 | QE-55MU8000 |
| QE-49MU8000 | a-si TFT MVA QDEF (Samsung) | 8-bit + FRC | 3840x2160 | RGB | 60/50Hz | Yes | Yes | Edge-LED (bottom + local dimming) | 1000cd/m2 | QE-49MU8000 |
| QE-65MU7000 | a-si TFT MVA QDEF () | 8-bit + FRC | 3840x2160 | RGB | 120/100Hz | Yes | Yes | Edge-LED (bottom) | 1000cd/m2 | QE-65MU7000 |
| QE-55MU7000 | a-si TFT MVA QDEF () | 8-bit + FRC | 3840x2160 | RGB | 120/100Hz | Yes | Yes | Edge-LED (bottom) | 1000cd/m2 | QE-55MU7000 |
| QE-49MU7000 | a-si TFT MVA QDEF (49А6U0SM - Samsung) | 8-bit + FRC | 3840x2160 | RGB | 60/50Hz | Yes | Yes | Edge-LED (bottom) | 1000cd/m2 | QE-49MU7000 |
| QE-40MU7000 | a-si TFT MVA QDEF (Samsung) | 8-bit + FRC | 3840x2160 | RGB | 60/50Hz | Yes | Yes | Edge-LED (bottom) | 1000cd/m2 | QE-40MU7000 |
| Series | UHD TV | Series |
| QE-65MU6600 | a-si TFT MVA (Samsung) | 8-bit | 3840x2160 | RGB | 60/50Hz | - | Yes | Edge LED (bottom) | 320cd/m2 | QE-65MU6600 |
| QE-49MU6600 | a-si TFT MVA () | 8-bit | 3840x2160 | RGB | 60/50Hz | - | Yes | Edge LED (bottom) | 320cd/m2 | QE-49MU6600 |
| QE-49MU6500 | a-si TFT MVA () | 8-bit | 3840x2160 | RGB | 60/50Hz | - | Yes | Edge LED (bottom) | 320cd/m2 | QE-49MU6500 |
| QE-65MU6400 | a-si TFT MVA () | 8-bit + FRC | 3840x2160 | RGB | 60/50Hz | - | Yes | Edge LED (bottom) | 320cd/m2 | QE-65MU6400 |
| QE-55MU6400 | a-si TFT IPS(PLS) () | 8-bit + FRC | 3840x2160 | RGB | 60/50Hz | - | Yes | Edge LED (bottom) | 320cd/m2 | QE-55MU6400 |
| QE-49MU6400 | a-si TFT IPS(PLS) (49B6AUOKK-BOE) | 8-bit + FRC | 3840x2160 | RGB | 60/50Hz | - | Yes | Edge LED (bottom) | 320cd/m2 | QE-49MU6400 |
| QE-40MU6400 | a-si TFT MVA (Samsung) | 8-bit + FRC | 3840x2160 | RGB | 60/50Hz | - | Yes | Edge LED (bottom) | 320cd/m2 | QE-40MU6400 |
| QE-65MU6200 | a-si TFT MVA (Samsung) | 8-bit | 3840x2160 | RGB | 60/50Hz | - | Yes | Edge LED (bottom) | 320cd/m2 | QE-65MU6200 |
| QE-55MU6200 | a-si TFT MVA (Samsung) | 8-bit | 3840x2160 | RGB | 60/50Hz | - | Yes | Edge LED (bottom) | 320cd/m2 | QE-55MU6200 |
| QE-49MU6200 | a-si TFT MVA () | 8-bit | 3840x2160 | RGB | 60/50Hz | - | Yes | Edge LED (bottom) | 320cd/m2 | QE-49MU6200 |
| QE-55MU6100 | a-si TFT IPS () | 8-bit | 3840x2160 | RGB | 60/50Hz | - | Yes | Edge LED (bottom) | 320cd/m2 | QE-55MU6100 |
| QE-50MU6100 | a-si TFT MVA () | 8-bit | 3840x2160 | RGB | 60/50Hz | - | Yes | Edge LED (bottom) | 320cd/m2 | QE-50MU6100 |
| QE-43MU6100 | a-si TFT ? () | 8-bit | 3840x2160 | RGB | 60/50Hz | - | Yes | Edge LED (bottom) | 320cd/m2 | QE-43MU6100 |
| QE-40MU6100 | a-si TFT MVA (Samsung) | 8-bit | 3840x2160 | RGB | 60/50Hz | - | Yes | Edge LED (bottom) | 320cd/m2 | QE-40MU6100 |
| QE-65MU6000 | a-si TFT MVA () | 8-bit | 3840x2160 | RGB | 60/50Hz | - | Yes | Edge LED (bottom) | 320cd/m2 | QE-65MU6000 |
| QE-55MU6000 | a-si TFT IPS () | 8-bit | 3840x2160 | RGB | 60/50Hz | - | Yes | Edge LED (bottom) | 320cd/m2 | QE-55MU6000 |
| QE-49MU6000 | a-si TFT MVA (Samsung) | 8-bit | 3840x2160 | RGB | 60/50Hz | - | Yes | Edge LED (bottom) | 320cd/m2 | QE-49MU6000 |
| QE-40MU6000 | a-si TFT MVA (Samsung) | 8-bit | 3840x2160 | RGB | 60/50Hz | - | Yes | Edge LED (bottom) | 320cd/m2 | QE-40MU6000 |
| Series | Full HD TV | Series |
| QE-55M6300 | a-si TFT ?? () | 8-bit | 1920x1080 | RGB | 60/50Hz | - | Yes | Edge LED (bottom) | ---cd/m2 | QE-55M6300 |
| QE-49M6300 | a-si TFT ?? () | 8-bit | 1920x1080 | RGB | 60/50Hz | - | Yes | Edge LED (bottom) | ---cd/m2 | QE-49M6300 |
| QE-55M5500 | a-si TFT ?? () | 8-bit | 1920x1080 | RGB | 60/50Hz | - | Yes | Edge LED (bottom) | ---cd/m2 | QE-55M5500 |
| QE-49M5500 | a-si TFT ?? () | 8-bit | 1920x1080 | RGB | 60/50Hz | - | Yes | Edge LED (bottom) | ---cd/m2 | QE-49M5500 |
| QE-43M5500 | a-si TFT MVA (43L6AF0KK-AUO) | 8-bit | 1920x1080 | RGB | 60/50Hz | - | Yes | Edge LED (bottom) | ---cd/m2 | QE-43M5500 |
| QE-32M5500 | a-si TFT MVA () | 8-bit | 1920x1080 | RGB | 60/50Hz | - | Yes | Edge LED (bottom) | ---cd/m2 | QE-32M5500 |
Вчера ми изписа, че има нов ъпдейт. Някой инсталирал ли е? Впечатления?
120.1 ...инсталирах го, нищо ново/различно не видях. youtube продължава при мен да се дъни.
Той и при мен не е спрял. [emoji3]
В какъв смисъл се дъни?
От два дни пускам клипове на 50MU6102 и не съм имал проблеми ... засега;)
След известно време не мога да скролвам по клипчетата. Просто маркера стои на един клип и само него мога да пускам. Проблема се решава след рестарт на телевизора. След няколко часа, пак същото.
