Резултати от 1 до 3 от общо 3
TOSHIBA 42SL863 VS. PANASONIC TX-L42E30E
    Oct 2011
    Здравейте!
    Нека всички по компетентни и запознати с технологиите на използваните компоненти в двата телевизора,както и всички които ги притежават да изкажат мненията си относно предимствата и недостатъците на двата телевизора.
    ето характеристиките на двата модела,както и разликите които намирам аз между тях са описани по долу.
    Прочетете и споделете
    TOSHIBA 42SL863
    Diagonal Screen Size (cm / inch) 107/42
    Screen Format 16:9
    Panel Resolution 1920 x 1080
    Brightness (cd/m2) 450
    Dynamic Contrast Ratio 4.000.000:1
    Response Time (G to G) (ms) 5.5
    Viewing Angle (&#186 178
    LED-TV Yes
    LED Edge Yes
    Full HD - High Definition 1080p Yes
    Meta Brain Yes
    200 Active Motion Rate (AMR) / Frame Refresh Rate Yes
    Resolution+ Yes
    24p Mode: Standard | Smooth Yes
    Real Digital Picture Yes
    Digital Noise Reduction Yes
    MPEG Noise Reduction Yes
    3D Digital Comb Filter Yes
    Active Backlight Control Yes
    Ambient Light Sensor Yes
    3D Colour Management Yes
    Colour Temperature selectable Yes
    Manual picture size select Yes
    Exact Scan Mode Yes
    Expert Settings
    Pre-Sets: Hollywood Mode 1 & 2 (Day/Night Mode) Yes
    Greyscale Settings Yes
    Gamma Settings Yes
    RGB Filter Yes
    Integrated Universal Test Pattern Yes
    601/709 Colour Decoding Selection Yes
    Copy to All Inputs Yes
    HDMI Information Yes
    Tuning
    TV Standards PAL I/BG/DK; SECAM BG/DK/L, NTSC BG 4.43
    Number of Channels ATV (100) │ DTV (9999)
    Analogue Yes
    DVB-T Yes
    DVB-T2 Yes
    DVB-C / DVB-C (HD) Yes
    DVB-S / DVB-S2 (HD) Yes
    H.264 Yes
    DVB Common Interface+ (CI+) Yes
    NTSC Video-Playback Yes
    Auto Set-up Yes
    USB-Features
    Picture (USB) JPEG
    Audio (USB) MP3, MP4
    Video (USB) AVCHD, AVCHD Lite, mts, m2ts, H.264, MPEG2-PS, mpg, mpeg, MPEG2, MP4, mp4, m4v
    Personal-TV
    4 User Modes Yes
    Personal Picture Setting Yes
    Personal Volume Setting Yes
    Personal Favorite List Yes
    Personal Recording Management Yes
    Other Features
    Freeze Screen Yes
    Timer Yes
    Panel Lock Yes
    Auto Format Yes
    4:3 stretch Yes
    No Signal Off Yes
    Hotel Mode Yes
    Clone Mode Yes
    Store Mode
    Digital POP Demo Yes
    Active Vision 100Hz demo Yes
    Resolution + demo Yes
    Eco
    EU Eco Label Yes
    Energie Label B
    Presence of Lead (Below RoHS Directive limit including exemptions) Yes
    Mercury Content <0,1 mg/kg
    Cabinet
    Touch Control Panel Yes
    Swivel stand Yes
    Wall Mountable (VESA) 400 x 400 (M8)
    Accessories (optional)
    USB wireless Dongle Yes
    Picture Mode
    AutoView Yes
    Dynamic Yes
    Game Yes
    Movie Yes
    PC Yes
    Standard Yes
    Store Yes
    Audio
    NICAM Stereo Yes
    udyssey EQ Yes
    Dolby Digital Plus Yes
    Dolby Volume Yes
    Sound Navi Yes
    Sound Output (RMS) W 2 x 10
    Interactive Features
    Digital Text Yes
    Text Page Memory 500
    Electronic Programme Guide 8 Day Yes
    Now and Next Information Yes
    Favourite Channel Memory Yes
    Smart-TV
    Wireless Ready (Toshiba WiFi Dongle required) Yes
    WiFi Protected Setup (WPS) Yes
    DLNA Yes
    DLNA DMP Yes
    DLNA DMR Yes
    Toshiba Media Controller compatible Yes
    Compatible with Windows 7 Yes
    You Tube Channel Yes
    HbbTV Yes
    Toshiba Places Yes
    Toshiba AppsConnect Yes
    Connections
    HDMI 4
    1080p, 1080i, 720p, 720i, 576p, 576i, 480p, 480i | 24Hz (24p) Yes I Yes
    Version 1.4 | Audio Return Channel | HDMI Ethernet Channel | Audio Content Enhancement | 3D Yes │ Yes │ - │ Yes
    REGZA-Link (HDMI-CEC) Yes
    INSTAPORT™ Yes
    LAN Yes
    Component Video Yes
    Composite Video Yes
    SCART Yes
    SCART (RGB | S-Video | AV) Yes
    Analogue audio (Cinch) | Audio (mini jack) Yes IYes
    PC Input Yes
    USB Yes
    Number of USB 2
    Digial Audio Out Yes
    Headphone Yes
    Power Supply
    Line Voltage 220-240V 50-60Hz
    Power Consumption EN62087 - Home Mode (W) 94.75
    Power Consumption EN60065 - Maximum power (W) 135
    Power Consumption - Stand-by (W) 0.186
    Yearly energy consumption (average) 138.335
    Dimensions
    Width (mm) 989
    Height without Ped.Stand (mm) 607
    Height with Ped.Stand (mm) 675
    Depth without Ped.Stand (mm) 35.8
    Depth with Ped.Stand (mm) 287
    Weight without Ped.Stand (kg) 15.5
    Weight with Ped.Stand (kg) 19.6
    Packed width (mm) 1305
    Packed depth (mm) 95
    Packed height (mm) 700
    Packed weight (kg) 21.6
    Accessories (included in carton box)
    Remote Control (Type) CT-90369
    Remote Control Battery R03(AAA) x2
    TV Stand Integrated Yes
    Instruction Manual Yes
    EAN
    EAN 5900496513464
    TV Tuner
    Интегрирани тунери* PAL -B/G/H, -I, -D/K: SECAM -B/G, -D/K, L/L'; DVB-T, DVB-T (MPEG4-AVC [H.264]), DVB-C (MPEG4-AVC [H.264])
    Приемане на телетекст 1000P
    Дисплей
    Контраст Висок контраст
    Размер на екрана 42" (106 cm) диагонално
    Панел IPS-alpha LED LCD панел (E-LED подсветка)
    Panel Drive 200 blb IFC pro
    Свободен зрителен ъгъл 178 градуса
    Резолюция Full-HD 1,920 x 1,080 (16:9)
    Приложими PC сигнали XGA, WXGA, SXGA 60Hz, 1920 x 1080 (HDMI)
    Приложим формат на сканиране
    FULL-HD 1080p (HDMI only), 1080i
    HD 720p
    SD 576i/p, 480i/p
    Moving Picture Resolution 900 линии
    Intelligent Frame Creation Pro да
    Motion Focus Technology да
    24p Smooth Film/Playback да/ да
    Deep Colour (10-битов панел) да
    Супер Резолюция да
    Режим на картина Dynamic/Normal/Cinema/True Cinema/Game/Photo
    Vreal Vreal Live
    Звук
    Високоговорители 2 x 10 watt 1-канални долни високоговорители
    Режим на звука Music/Speech/User
    Virtual съраунд V-Audio Surround
    Dolby Digital/dts Dolby Digital Plus/DolbyPulse/dts2.0+Digital Out
    Вход / изход
    CI (Общ интерфейс) да
    VIERA Image Viewer да (AVCHD/SD-VIDEO/Motion JPEG [Lumix]/MP4 [Xacti]/DivXPlusHD/MKV/MPEG4/JPEG/MP3/AAC/WMV/WMA playback)
    USB 3 (2 задни, 1 страничен); Mass Storage/Keyboard/WiFi/USB-HDD Recording/SK Camera
    USB HDD / SD Card Записване да (USB HDD)
    HDMI Input/ Support Feature 4 (3 задни, 1 страничен)/ Audio Return Channel (Вход 2)
    Композитен видео вход AV2: RCA фото тип х 1 (отстрани)
    Компонентен видео вход RCA фоно тип x 1 set (задна част)
    РC вход Мини D-sub 15-pin x 1 (отзад)
    Аудио вход (HDMI, PC, Composite, Component) RCA фоно тип x 1 set (задна част)
    21-Pin вход/изход AV1: AV вход/изход, RGB вход, Q-Link (отзад)
    LAN Port да
    Аналогов аудио изход RCA фоно тип x 1 set (задна част)
    Цифров аудио изход (оптичен) 1, заден
    Headphone Jack 1, страничен
    Характеристики
    Wireless LAN Адаптор** WiFi Ready
    EPG (Now and Next) да
    EPG for DVB-T (7days) Gemstar EPG: UK, Италия, Германия, Испания; 7-Days SI EPG: Франция, Швеция
    VIERA Connect да
    DLNA да
    VIERA Tools да
    VIERA Link да (HDAVI контрол 5)
    Много прозорци PAT
    Eco Навигация да
    Режим Игра да
    Q-Link да
    Таймер изкл. да
    Заключване за деца да
    Основни
    На режим средна мощност на потребление*** 70 W
    Захранване AC 220 - 240 V, 50/60 Hz
    Консумация-висока оценка 102 W
    В режим на готовност потребление 0.3 W
    Размери (Ш х H х Д) (без стойка о) 1,002 x 611 x 75 mm (Дълбочина на панела: 41 mm)
    Размери (Ш х H х Д) (със стойката) 1,002 x 646 x 288 mm
    Тегло (без стойка о) 15.5 kg
    Тегло (със стойката) 19.0 kg
    Wall Bracket TY-WK3L2RW
    VESA Standard да
    Други спецификации
    ЗАБЕЛЕЖКА * Забележка за DVB функции: / Този телевизор е предназначен да отговаря на стандартите (настоящи от август 2009 г.) на DVB-T/C/S/S2 (MPEG2 и MPEG4-AVC [H.264]) услуги. / Съвместимостта с бъдещите услуги DVB не е гарантирана. / DVB-T MPEG4-AVC предаване е на разположение в избрани страни: Дания, Испания, Естония, Франция, Литва, Норвегия, Словения, Швеция, Полша, Унгария, Португалия. / DVB-C функция е достъпна само в следните страни: / Швеция (ComHem, Canal Digital), Дания (YouSee), Норвегия (Canal Digital), Финландия (кабелна Готов HD), Германия, Швейцария, Холандия / Списъкът на страни по-горе е от 1 януари, 2010. / Проверете най-новата информация за наличните услуги на следния електронен адрес (само на английски): / http://panasonic.jp/support/global/cs/tv/ / ** В зависимост от района, този аксесоар може да не е включен. / ** Въз основа на метода за измерване на IEC 62087 Ed.2.
    Основните разлики които намирам аз са:
    TOSHIBA 42SL863 PANASONIC TX-L42E30E
    s-тунер-да не
    usb-2бр. 3бр.
    pvr функция-не да
    DTS-не да
    За Тошибата чзнам,че има проблеми със субтитрите на DIVX,но така и не разбрах с другите кодеци има ли субтитри?
    -Слаб контраст спрямо други модели-аз го гледах в магазина и на SD сигнал си излъчва доста прилично.
    -не познава всички спътници
    -медия сървъра дава грешка на avi формат
    -некачествен звук
    За Панасоника
    -Проблеми с PVR фукцията от външен хард(при запис диска се форматира и губи цялата информация)
    -лош контрол на панела и настройките на картина и канали
    Това се сещам за сега.
    За проблеми със субтитрите от usb при Панасоника не съм запознат,така че който го има или знае да пише.
    За отстраняването на същите при Тошибата давайте решения.
    Какво е най удачното свързване с компютър и за двата модела?
    Имам видео карта nvidia G-force 9800GT преходник от DVI към HDMI и S-PDF кабел за връзка с аудиото към дъното.
    Изискванията към телевизора са:
    -Надежден панел с приятна за окото картина
    -40-42 инча
    -цена до 1400лв.
    -по възможност добър медия плеър и настройки
    Да не пускам нова тема:
    приемам и други предложения за марка и модел.
    от 3d моделите се спрях на LG 47LW4500 основно поради ниската цена и гаранцията от 5 години!(пишете от трите кой си заслужава най вече)3d-то не е приоритет
    Трябва да направя избор възможно най скоро,така че не се бавете с постовете си
    Благодаря!
    Oct 2011
    Re:TOSHIBA 42SL863 VS. PANASONIC TX-L42E30E
    -Според мен панел Samsung с матрица S-PVA
    -Samsung UE-40D5800 Version:01 Z8Y83SMB500010F
    -цена1.339 лв
    -най добрият плеър e на samsung
    Относно 3d LG 42PW450 е добър избор !
    Цитат Първоначално публикувано от V.Valev
    За Панасоника
    Това е стандартно за всички марки телевизори. Харда се форматира от телевизора, като записва е кодиран и се възпроизвежда само от телевизора на който е направен.
  1. Проблем със субтитри Toshiba 42SL863
    От Iva63 във форум Toshiba телевизори
    Отговори: 56
    Последно: 04-06-13, 17:01
  2. Проблем с CAM MODUL и Toshiba 42SL863
    От Tedo във форум Toshiba телевизори
    Последно: 23-06-12, 00:13
  3. Проблем с .mkv файлове на Panasonic VIERA TX-L42E30E
    От byb във форум Panasonic телевизори
    Последно: 02-01-12, 00:00
  4. Fujitsu ASYA12LGC, Panasonic CS/CU-E12HKE или Toshiba RAS-13SKV-E
    От tikettiket във форум Климатици Toshiba, Carrier
    Отговори: 39
    Последно: 25-02-10, 13:25
  5. Panasonic или Toshiba
    От brainwave във форум Климатици Toshiba, Carrier
    Отговори: 10
    Последно: 06-11-08, 21:03
