POD WINDOWS XP PROFISIONAL SAM I NE MI DAVA FORMAT NA HARD DISKA
KOGATO ZADAM FORMAT C::\Program Files\Support Tools>FORMAT C:
he type of the file system is NTFS.
nter current volume label for drive C: HP_PAVILION
ARNING, ALL DATA ON NON-REMOVABLE DISK
RIVE C: WILL BE LOST!
roceed with Format (Y/N)? Y
erifying 36035M
ormat cannot run because the volume is in use by another
rocess. Format may run if this volume is dismounted first
LL OPENED HANDLES TO THIS VOLUME WOULD THEN BE INVALID.
ould you like to force a dismount on this volume? (Y/N) Y
annot lock the drive. The volume is still in use.
:\Program Files\Support Tools>I TVA E NESHTE DA PRAI NISHTO
HELP
 Новини
 Новини Форум
 Форум Актуално
 Актуално сървър
 сървър
  }]P
}]P
						 )"и след това...си форматираш без проблем диска.
						 както пишеш ти),на него са Windows директорията,swapa и PM-ка ,и форматирам точно този дял.Ако пак не вярваш пробвай.
