Страница 15 от 24 ПърваПърва ... 51314151617 ... ПоследноПоследно
Резултати от 211 до 225 от общо 346
Like Tree89Одобрявам
Panasonic телевизори 2016
    #211
    Отговор: Panasonic телевизори 2016
    Panasonic DX750 (TX-55DX750) Test - UHD 4K 120Hz - PANASONIC - HDTV Centrum Polska
    Google translate Pl to Bg
    Google translate Pl to En
    https://developer.vieraconnect.com/
    Няма свободен достъп до базата - задължително трябва да се регистрираш и.....достъпът е платен.
    Ето и опита на един заблуден...
    http://mattpilz.com/project-postmort...viera-connect/
    http://mattpilz.com/project-postmort...onnect-part-2/
    http://mattpilz.com/project-postmort...era-connect-3/
    добре че преминаха на FirefoxOS
    https://developer.mozilla.org/en-US/...efox_OS_for_TV
    Smart TV Alliance - Developers
    Този пост е редактиран от hristoslav2; 16-06-16 в 22:33.
    #212
    Panasonic tévé remek képminőséggel - PROHARDVER! Házimozi teszt
    Google translate Hg to Bg
    DX703 - DVB-T/T2/C/S2
    DX700 - DVB-T/T2/C
    DX653 - DVB-T/T2/C/S2
    DX650 - DVB-T/T2/C
    DX402 - ??????
    Panasonic UltraHD TV 2016
    Product
    Certification UHD
    Premium
    ______________________
    Resolution: 3,840x2,160.
    Color depth: 10-bit.
    Color gamut: Wide, including the ability to show at least 90 percent of the P3 color gamut .
    High dynamic range: Specifically the ability to use SMPTE ST2084's electro-optical transfer function, which Dolby helped create .
    Minimum brightness and contrast ratios: There are two possible minimum specs. A minimum brightness of 1,000 nits, along with a black level of a maximum of 0.05 nits (20,000:1 contrast ratio), or a minimum brightness of 540 nits, along with a black level of a maximum of 0.0005 (1,080,000:1)
    Dolby Vision
    _______________________________
    The metadata is graded in each scene so you get different grades throughout the file. Dolby tells us that scene by scene grading is the superior way to grade a movie, which on paper does sound more efficient.
    Standard: Poprietary
    Peak Luminance: Up to 10,000 nits
    Video Bit Depth: 12-bit
    Metadata: Dynamic (scene by scene)
    Software Upgradability: No(SoC hardware-embedded)
    HDR 10
    The metadata is graded and determined, and is then sent at the beginning of the file and covers the entire file. One set of metadata
    Standard: Open
    Peak Luminance: Up to 4,000 nits
    Video Bit Depth: 10-bit
    Metadata: Static (per title)
    Software Upgradability: Yes
    Videopanel - LCD matrix
    _______________________________________
    Backlight
    Dimming
    _________________________________________
    Color Space
    Contrast
    White & Black level
    Viewing angle
    _____________
    Input Lag
    SoC
    CPU
    GPU
    software
    OS
    _________________
    Conectors
    _________________
    Networks
    Tuner
    Opportunities for calibration
    ________________________________________________________
    Product
    CZ950
    65"
    OLED
    Yes No 65" - max 450cd/m2
    Yes
    SMPTE standarts
    ST2084, ST 2086
    Oled, WRGB (LG Display), 10bit, 120/100Hz No 65" - DCI P3 X,Y - 86% / Rec.2020 - 70% 65" - ∞ / 151cd/m2 / 0.00cd/m2 65" - 45°
    65" - Game mode - 0ms / by default - 80ms
    Quad Core Pro 5
    Firefox 2.0
    1 x Ethernet RJ45
    2 x USB 2.0 (max500mA)
    1 x USB 3.0 (max900mA)
    4 x HDMI 2.0 (ARC,CEC)
    1 x Satelite In (Main: F-type female)
    1 x Satelite In (Sub: F-type female)
    1 x AV Composite In
    1 x AV Component In
    1 x Optical Audio Out
    1 x 3.5mm Audio Out
    1 x Antena (RF)female
    1 x CI+ 1.3
    1 x Card reader SD/SDHC
    Lan -
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Bluetooth ver. 4.0
    Wi-Fi Direct
    DLNA (RUI2.0/DTCP-IP/DMP/DMR/DMS)
    2 x DVB-C/T2/S2,
    1 x SAT>IP Client & Server
    DVB-T2: HEVC H.264 и H.265
    Analog (PAL,SECAM)
    2 x CI+1.3
    PVR, Time Shifting
    HEVC
    VP9
    CZ950
    DX900
    58", 65"
    Yes No 65"- max 1250cd/m2
    58"- max 1430cd/m2
    Yes HDR10
    SMPTE standards
    ST2084, ST2086
    65"- SMVA, 10-bit, 120/100Hz + MCFI
    58"- SMVA, 10-bit, 120/100Hz + MCFI
    MCFI - Motion Clarity Frame Interpolation
    BFI - Black Frame Insertion
    65"' - FALD - 512 zones (32 columns x 16 rows)
    58" - FALD - 512 zones (32 columns x 16 rows)
    Honeycomb backlight structure
    Blue Leds - "boosted" with red phosphorus
    (BLS - Backlight Scaning) +
    (BFI - Black Frame Insertion)
    6 cooling fan backlight
    65"- DCI P3 X,Y - 98% / Rec.2020 - 78%
    58"- DCI P3 X,Y - 96% / Rec.2020 - 74%
    65" - ANSI
    Static - 5360:1 / 134cd/m2 / 0.025cd/m2
    Dynamic - 50000:1
    58" - ANSI
    Static - 4600:1 / ---- cd/m2 / 0.023cd/m2
    Dynamic - 50000:1
    65" - 42°(cone)
    58" - 46°(conе)
    65"- Game mode - 41ms / by default - 51ms
    58" - Game mode- 40ms / by default - 50ms
    Quad Core
    P163
    Firefox 2.5
    1 x Ethernet RJ45
    1 x AV Composite In
    1 x AV Component In
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    Lan
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Bluetooth ver. 4.0
    Wi-Fi Direct
    2x DVB-C/T2/S2,
    Analog (PAL,SECAM)
    2 x CI+1.3
    PVR, Time Shifting
    HEVC
    VP9
    DX900
    DX800
    58", 50"
    Yes No 58" - max...cd/m2
    50" - max...cd/m2
    Yes HDR10
    SMPTE standards
    ST2084, ST2086
    58"- Super-MVA, 8-bit+Hi-FRC, 120/100Hz + MCFI
    50"- Super-MVA, 8-bit+Hi-FRC, 120/100Hz + MCFI
    58" - Edge Led
    50" - Edge Led
    with red phosphorus)
    58"- DCI P3 X,Y - 94%
    50"- DCI P3 X,Y - 90%
    58"-
    50"-
    58" -
    50" -
    58" - Game mode
    50" - Game mode
    Quad Core
    P163
    Firefox 2.5
    1 x Ethernet RJ45
    4 x HDMI 2.0a (ARC,CEC)
    1 x AV Composite In
    1 x AV Component In
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    Lan
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Bluetooth ver. 4.0
    Wi-Fi Direct
    2 x DVB-C/T2/S2,
    Analog (PAL,SECAM)
    2 x CI+1.3
    PVR, Time Shifting
    HEVC
    VP9
    DX800
    DX780
    65", 58", 50"
    No No 65" - max......cd/m2
    55" - max 577cd/m2
    50" - max 5....cd/m2
    Compatible
    HDR processing
    (but no hardware for HDR)
    65" - Super-MVA, 8-bit+FRC, 120/100Hz + MCFI
    58" - Super-MVA, 8-bit+FRC, 120/100Hz + MCFI
    50" - Super-MVA, 8-bit+FRC, 120/100Hz + MCFI
    BFI - Black Frame insertion
    65" - Direct Led, Local Dimming - 32 zones (8 x 4)
    58" - Edge Led (below) Vertical Dimming
    50" - Edge Led (below) Vertical Dimming
    65" - DCI P3 X,Y -
    58" - DCI P3 X,Y -
    50" - DCI P3 X,Y - 89% / Rec.2020 - 66%
    65" -
    58" -
    50" -
    65" -
    58" -
    50" -
    65" - Game mode
    58" - Game mode
    50" - Game mode
    Quad Core
    P163
    Firefox 2.5
    1 x Ethernet RJ45
    2 x HDMI 2.0a (ARC,CEC)
    2 x HDMI 1.4 (CEC)
    1 x AV Composite In
    1 x AV Component In
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    Lan (10BASE-T/100BASE-TX)
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Bluetooth ver. 4.0
    Wi-Fi Direct
    2 x DVB-C/T2/S2,
    Analog (PAL,SECAM)
    2 x CI+1.3
    PVR, Time Shifting
    HEVC
    VP9
    DX780
    DX750
    65", 58", 50"
    No
    No 65" - HDR max 435cd/m2
    58" - HDR 50-100% max 550cd/m2
    50" - HDR 10% max 628cd/m2/ 50-100% - 550cd/m2
    SDR max 500cd/m2
    Compatible
    HDR processing
    MCFI - Motion Clarity Frame Interpolation(IFC)
    very glossy panel
    65" - Direct Led, No Dimming
    58" - Edge Led (below), Vertical Dimming ?
    50" - Edge Led (below), Vertical Dimming ?
    65" - DCI P3 X,Y- 94% / Rec.2020 - 75%
    58" - DCI P3 X,Y - 94% / Rec.2020 - 75%
    50" - DCI P3 X,Y- 95% / Rec.2020 - 76%
    65" - ANSI 4300:1 / 123cd/m2 / 0.03cd/m2
    58" - ANSI 4029:1 /154cd/m2 / 0.04cd/m2
    50" - ANSI 4000:1 /
    Static - 4800:1/ 120 cd/m2 / 0.025cd/m2
    Dynamic - 5000:1 / 625cd/m2 / 0.10cd/m2
    65" - 35° (cone)
    58" - 40° (cone)
    50" - 46° (cone)
    65"- Game mode-45ms / by default-106ms
    58"- Game mode-44ms / by default-105ms
    50"- Game mode-47ms / by default-105ms
    Quad Core
    P163
    Firefox 2.5
    1 x Ethernet RJ45
    2 x HDMI 1.4 (CEC)
    1 x AV Composite In
    1 x AV Component In
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Bluetooth ver. 4.0
    Wi-Fi Direct
    DVB- C/T2/S2
    with PIP functions, PAP, PAT, PVR and Time shift
    Analog (PAL,SECAM)
    PVR, Time Shifting
    HEVC
    VP9
    Accurate Colour Drive technology with 3D LUT conversion table with 8 000 points correction and the ability to calibrate 6 primary and secondary colors within a CMS on 3 axes. Or Black Gradation Drive that can provide more gradations in dark scenes through treatment with 12 bit color.
    To adjust the colorimetry, the DX750 offers all the necessary settings with the choice of gamut used (Rec.601, Rec.709, EBU, DCI / P3 or Rec.2020), gamma used (with varying gamma whose BT.1886 with compensation of black, 2.2 used in lit room, the 2.4 used in dark room). You can edit each Gamma to correct on 10 points. Each gamut can be calibrated from a CMS (Color Management System) 3-axis (luminance, saturation and hue) with opportunity to correct 6 primary and secondary colors (RGBCMY). Finally, we also find a Balance Whites 2P and 10P (10 points) to adjust the color temperature.
    DX750
    DX730
    58", 50", 40"
    No No 58"- max....cd/m2
    50"- max 317cd/m2
    40" - max...cd/m2
    Compatible
    HDR processing
    58" - Super-MVA, 8-bit, 60/50Hz + BLB + MCFI
    50" - Super-MVA, 8-bit, 60/50Hz + BLB + MCFI
    40" - Super-MVA, 8-bit, 60/50Hz + BLB + MCFI
    very glossy panel
    40" - Edge Led (below) Vertical Dimming
    58" - DCI P3 -
    50" - DCI P3 -
    40" - DCI P3 -
    58" -
    50" - 4824:1 / 0.04cd/m2
    40" -
    58" -
    50" - 42° (cone)
    40" -
    58" - Game mode
    50" - Game mode
    40" - Game mode
    Quad Core
    P193
    Firefox 2.5
    1 x Ethernet RJ45
    1 x HDMI 1.4 (CEC)
    1 x AV Composite In
    1 x AV Component In
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Bluetooth Ver. 4.0 (keyboards, mouse)
    Wi-Fi Direct
    DVB-T/T2/C
    Analog (PAL,SECAM)
    PVR, Time Shifting
    HEVC
    VP9
    DX730
    DX700
    58", 50"'40"
    No No 58" - HDR 350cd/m2
    50" - HDR 350cd/m2
    40" -
    Compatible
    HDR processing
    very glossy panel
    40" - Edge Led (below), Vertical Dimming
    58" - DCI P3 - / Rec.2020 - 68.27%
    50" - DCI P3 -
    40" - DCI P3 -
    58"- 5736:1 / 153cd/m2 / 0.03cd/m2
    3184:1 / 0.038cd/m2
    ANSI - 2304:1 / 0.046cd/m2
    50" - 4700:1 /
    40" -
    58" - 40°(conе)
    50" -
    40" -
    58"- Game mode-49.8ms / by default-69.7ms
    50"- Game mode
    40" - Game mode
    Quad Core
    P193
    Firefox 2.5
    1 x Ethernet RJ45
    1 x USB 2.0 (max 500mA)
    1 x USB 3.0 (max 900mA)
    1 x HDMI 1.4 (CEC)
    2 x HDMI 2.0 (ARC,CEC)
    1 x AV Composite in
    1 x AV Component in
    1 x 3.5mm Audio Out
    1 x Antena (RF) female
    1 x CI+ 1.3
    WiFi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Bluetooth ver. 4.0
    Wi-Fi Direct
    DVB-C/T2/S/S2
    Analog (PAL,SECAM)
    HEVC
    9 DX700
    DX650
    58", 50",40"
    No No 58" -
    50" -
    40" -
    No
    58"- Super-MVA, 8-bit, 60/50Hz + BLB
    50"- Super-MVA, 8-bit, 60/50Hz + BLB
    40"- Super-MVA, 8-bit, 60/50Hz + BLB
    58" - Edge Led, (below)
    50" - Edge Led, (below)
    40" - Edge Led, (below)
    58"- DCI P3 -
    50"- DCI P3 -
    40"- DCI P3 -
    58"-
    50"-
    40"-
    58"-
    50"-
    40"-
    58" - Game mode
    50" - Game mode
    40" - Game mode
    Quad Core
    Firefox 2.5
    1 x Ethernet RJ45
    1 x HDMI 1.4 (CEC)
    1 x AV Composite in
    1 x AV Component in
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Wi-Fi Direct
    DVB-T/T2/C
    Analog (PAL,SECAM)
    DX650
    DX600
    55", 49", 40"
    No No 55" - max 294cd/m2
    49" - max...cd/m2
    40" - max...cd/m2
    No
    55"- Super-IPS, 8-bit, 60/50Hz + BLB
    49"- Super-IPS, 8-bit, 60/50Hz + BLB
    55" - Edge Led, (below)
    49" - Edge Led, (below)
    40" - Edge Led
    55"- DCI P3 -
    49"- DCI P3 -
    40"- DCI P3 -
    55"-
    49"-
    40"-
    55"- 78° (cone)
    49"-
    40"-
    55" - Game mode
    49" - Game mode
    40" - Game mode
    Firefox 2.5
    1 x Ethernet RJ45
    1 x HDMI 1.4 (CEC)
    1 x AV Composite in
    1 x AV Component in
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Wi-Fi Direct
    DVB-T/T2/C
    Analog (PAL,SECAM)
    DX600
    Panasonic Full HD TV 2016
    Product UHD
    Premium
    Dolby
    Vision
    HDR
    _________________
    _________________
    Backlight
    Dimming
    Color Space
    Contrast & Black level
    Viewing angle
    ____________
    Input Lag
    _____________
    SoC
    software
    OS
    _________________
    Conectors
    Networks
    Tuner
    Picture Accuracy Out-of-the-Box (score out of 10)
    _______________
    Product
    DS630
    50", 40", 32"
    No No 50" - max - 362cd/m2
    40" - max...cd/m2
    32" - max...cd/m2
    No
    50"- Super-MVA, 8-bit, 120/100Hz + BLB + MCFI
    40"- Super-MVA, 8-bit, 120/100Hz + BLB + MCFI
    32"- ?, 8-bit, 60/50Hz
    50" - Edge Led
    40" - Edge Led
    32" - Edge Led
    Only globally
    (Adaptive Backlight Dimming)
    50"- DCI P3 - 74%
    40"- DCI P3 -
    32"- DCI P3 -
    50"- 4311:1 /0.038cd/m2
    40"-
    32"-
    50"-
    40"-
    32"-
    50" -
    40" -
    32" -
    P162
    my Home Screen 1.0
    Bluetooth 3.0(2.402GHz-2.480GHz)
    1 x Lan Ethernet RJ45
    3 x HDMI 1.4 (CEC)
    1 x mini Jack (3.5mm) stereo
    1 x SCART
    1 x Component (RCA PIN type)
    Wi-Fi
    Wi-Fi Direct
    DLNA
    802.11 a/n
    5.180GHZ-5.320GHz,5.500GHz-5.580GHz
    5.660GHZ-5.700GHz
    802.11 b/g/n
    2.412GHz-2.472GHz
    Security
    WPA2-PSK(TKIP/AES)
    WPA-PSK(TKIP/AES)
    WEP(64-bit/128-bit)
    DVB-T/T2/C
    Analog (PAL,SECAM,NTSC)
    No HEVC
    DS630
    DS600
    50", 40", 32"
    No No 50" - max...cd/m2
    40" - max...cd/m2
    32" - max...cd/m2
    No
    50" - MVA , 8-bit, 60/50Hz
    40" - Super-MVA, 8bit, 60/50Hz
    32" - , 8/-bit, 60/50Hz
    Backlight Motion Rate 400
    50" - Edge Led
    40" - Edge Led
    32" - Edge Led
    50"- DCI P3 -
    40"- DCI P3 -
    32"- DCI P3 -
    50"-
    40"-
    32"-
    50"-
    40"-
    32"-
    50" -
    40" -
    32" -
    P161
    3 x HDMI 1.4 (CEC)
    2 x USB 2.0
    1 x SCART
    1 x CI+ 1.3
    Bluetooth 3.0 (2.402GHz-2.480Ghz)
    Wi-Fi
    Wi-Fi Direct
    DLNA
    802.11 a/n
    5.660GHZ-5.700GHz
    802.11 b/g/n
    2.412GHz-2.472GHz
    Security
    WPA2-PSK(TKIP/AES)
    WPA-PSK(TKIP/AES)
    WEP(64-bit/128-bit)
    DVB-T/T2/C
    Analog (PAL,SECAM)
    No HEVC
    DS600
    DS500
    55", 49", 40",32",24"
    No No 55" - max...cd/m2
    49" - max 314cd/m2
    40" - max...cd/m2
    32" - max...cd/m2
    24" - max...cd/m2
    No
    55" - Super-IPS, 8bit, 60/50Hz
    49" - Super-IPS , 8-bit, 60/50Hz
    40" - , 8-bit, 60/50Hz
    32" - , 8-bit, 60/50Hz
    24" - , 8-bit, 60/50Hz
    55" - Edge Led
    49" - Edge Led
    40" - Edge Led
    32" - Edge Led
    24" - Edge Led
    55" - DCI P3 -
    49" - DCI P3 -
    40" - DCI P3 -
    32" - DCI P3 -
    24" -
    55"-
    49"- 882:1 /
    40"-
    32"-
    24" -
    55"-
    49"- 66° (cone)
    40"-
    32"-
    24" -
    55" -
    49" -
    40" -
    32" -
    24" -
    P161
    1 x USB 2.0
    1 x Ethernet RJ45
    2 x HDMI 1.4 (ARC, CEC)
    1 x Scart
    1 x AV Composite In
    1 x AV Component In
    1 x Opticasl Audio Out
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    Bluetooth 3.0 (2.402GHz-2.480GHz)
    Wi-Fi
    Wi-Fi Direct
    802.11 a/n
    5.660GHZ-5.700GHz
    802.11 b/g/n
    2.412GHz-2.472GHz
    Security
    WPA2-PSK(TKIP/AES)
    WPA-PSK(TKIP/AES)
    WEP(64-bit/128-bit)
    DLNA
    DVB-T/T2/C
    Analog (PAL,SECAM)
    No HEVC
    DS500
    DS400
    40"
    No No 40" - max...cd/m2
    No
    40" - MVA, 8bit, 60/50Hz
    Backlight Motion Rate - 400
    40" - Edge Led 40"- DCI P3 - 40"- 40"- 40" - -
    P161
    1 x USB 2.0
    1 x Ethernet RJ 45
    1 x SCART
    1 x AV Composite In
    1 x AV Component In
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    Lan
    WiFi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5Ghz
    DLNA
    DVB-T/T2/C
    Analog (PAL,SECAM)
    DS400
    Този пост е редактиран от hristoslav2; 04-07-16 в 23:31.
    #213
    Panasonic TX-50DX750B (DX750) Review
    Google translate En to Bg
    Measured panel refresh rate 120Hz,
    Motion resolution:1080 lines with optimised [IFC] “Custom“
    Panasonic Escapes From U.S. TV Market
    Този пост е редактиран от hristoslav2; 05-07-16 в 18:25.
    stanislav77 одобрява това.
    #214
    Panasonic DX800 (TX-58DX800E) Test - Ultra HD 4K, HDR, 120Hz - PANASONIC - HDTV Centrum Polska
    Google превод Pl to Bg
    TX -58DX800E: VA panel RGB 100 / 120Hz with MCFI + flashing backlight
    Panasonic DX600 (TX-55DX600B) Ultra HD 4K TV Review
    TX-55DX600B: IPS panel, 50/60Hz (4K 800 Hz BMR IFC), average black level of 0.19 nits, ANSI contrast ratio of less than 750: 1
    #215
    Този пост е редактиран от hristoslav2; 14-07-16 в 22:22.
  7.
  8. Senior Member Аватара на hristoslav2
    #217
    Panasonic DXW804 UHDTV Review - Beautiful image and sound in a unique design
    Google превод Nl to Bg
    DXW804 е германска версия на DX800 - с малка софтуерна разлика. Хардуера е същият.
    Product
    Certification UHD
    Premium
    Dolby Vision
    HDR 10
    Standard: Open
    Videopanel
    Type LCD matrix,
    Bits of color,
    Operating frequency of T-Con board of the panel,
    Curvature,
    Index,
    Anti-reflective filter
    Backlight
    Type backlight
    (Local Dimming zone)
    Type LED
    MEMC
    Backlight Scanning
    Pulsе Wide Modulation
    Color Space
    DCI P3 - %
    Rec.2020 - %
    Contrast
    White & Black level
    ANSI
    With local dimming
    Without local dimming
    Viewing angle
    _____________
    Input Lag
    SoC
    CPU
    GPU
    software
    OS
    _____________
    Conectors
    Networks
    Tuner
    __________________
    Audio
    ______________
    Opportunities for
    calibration
    Product
    CZ950
    65"
    OLED
    Yes
    SMPTE standarts
    ST2084, ST 2086
    Oled, WRGB (LG Display), 10bit, 120/100Hz No backlight 65" - DCI P3 X,Y - 86% / Rec.2020 - 70% 65" - ∞ / 151cd/m2 / 0.00cd/m2 65" - 45°
    Quad Core Pro 5
    Firefox 2.0
    1 x Ethernet RJ45
    1 x AV Composite In
    1 x AV Component In
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    Lan -
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Bluetooth ver. 4.0
    Wi-Fi Direct
    2 x DVB-C/T2/S2,
    Analog (PAL,SECAM)
    2 x CI+1.3
    PVR, Time Shifting
    HEVC
    VP9
    CZ950
    DX900
    58", 65"
    58"- max 1430cd/m2
    Yes HDR10
    SMPTE standards
    ST2084, ST2086
    Blue Leds - with red phosphorus
    MEMC - Intelligent Frame Creation
    BFI - Clear Motion
    65" - ANSI
    Dynamic - 50000:1
    58" - ANSI
    Dynamic - 50000:1
    65" - 42°(cone)
    58" - 46°(conе)
    Quad Core
    Chassis P163
    Firefox 2.5
    1 x Ethernet RJ45
    1 x AV Composite In
    1 x AV Component In
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    Lan
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Bluetooth ver. 4.0
    Wi-Fi Direct
    2x DVB-C/T2/S2,
    Analog (PAL,SECAM)
    2 x CI+1.3
    PVR, Time Shifting
    HEVC
    VP9
    40Watt
    integrated subwoofer
    Dolby Digital Plus
    VR-Audio Master Surround 2.1
    ISF Professional
    THX Bright Room
    3D LUT
    CMS - RGBCYM
    gray scale of 10 points
    Rec.2020
    Rec.709
    direct Display Control mode to allow to adjust settings directly from the Calman software (professional edition) by connecting screen to a PC via Ethernet
    DX900
    DX800
    58", 50"
    No No 58" - max 553cd/m, 10% - 458cd/m2
    50" - max...cd/m2
    Yes HDR10
    SMPTE standards
    ST2084, ST2086
    58"- Super-MVA, 8-bit+FRC, 120/100Hz
    50"- Super-MVA, 8-bit+FRC, 120/100Hz
    58" - Edge Led
    50" - Edge Led
    Dimming - 4 Vertical zones
    Blue Leds - with red phosphorus)
    BFI - Clear Motion
    58"- DCI P3 X,Y - 95% / Rec.2020 - 72%
    50"- DCI P3 X,Y - 92%
    58" - ANSI 3500:1
    50"-
    58" -
    50" -
    58" - Game mode 43ms / by default 110ms
    50" - Game mode
    Quad Core
    Chassis P163
    Firefox 2.5
    1 x Ethernet RJ45
    1 x AV Composite In
    1 x AV Component In
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    Lan
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Bluetooth ver. 4.0
    Wi-Fi Direct
    2 x DVB-C/T2/S2,
    Analog (PAL,SECAM)
    2 x CI+1.3
    PVR, Time Shifting HEVC
    VP9
    40 W
    Dolby Digital Plus
    VR-Master Audio 2.1 Surround
    12 Train
    Prismatic Speaker
    ISF Professional
    THX Bright Room
    3D LUT
    CMS - RGBCYM
    Rec.2020
    Rec.709
    DX800
    DX780
    65", 58", 50"
    55" - max 577cd/m2
    Compatible
    HDR processing
    BFI - Clear Motion
    65" - DCI P3 X,Y -
    58" - DCI P3 X,Y -
    65" -
    58" -
    50" -
    65" -
    58" -
    50" -
    65" - Game mode
    58" - Game mode
    50" - Game mode
    Quad Core
    Chassis P163
    Firefox 2.5
    1 x Ethernet RJ45
    2 x HDMI 1.4 (CEC)
    1 x AV Composite In
    1 x AV Component In
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Bluetooth ver. 4.0
    Wi-Fi Direct
    2 x DVB-C/T2/S2,
    Analog (PAL,SECAM)
    2 x CI+1.3
    PVR, Time Shifting
    HEVC
    VP9
    2x10 Watt RMS
    Dolby Digital Plus
    VR-Audio Surround True
    DX780
    DX750
    65", 58", 50"
    No
    SDR max 500cd/m2
    Compatible
    HDR processing
    very glossy panel
    58"- ANSI 4313:1 /120cd/m2 / 0.017cd/m2
    50" - ANSI 4000:1 /
    65" - 35° (cone)
    58" - 40° (cone)
    50" - 46° (cone)
    65"- Game mode-46ms / by default-106ms
    58"- Game mode-47ms / by default-105ms
    Quad Core
    Chassis P163
    Firefox 2.5
    1 x Ethernet RJ45
    2 x HDMI 1.4 (CEC)
    1 x AV Composite In
    1 x AV Component In
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Bluetooth ver. 4.0
    Wi-Fi Direct
    DVB- C/T2/S2
    PVR and Time shift
    Analog (PAL,SECAM)
    PVR, Time Shifting
    HEVC
    VP9
    2x10 Watt RMS
    Dolby Digital Plus
    DX750
    DX730
    58", 50", 40"
    50"- max 317cd/m2
    40" - max...cd/m2
    Compatible
    HDR processing
    very glossy panel
    58" - DCI P3 -
    50" - DCI P3 -
    40" - DCI P3 -
    58" -
    40" -
    58" -
    50" - 42° (cone)
    40" -
    58" - Game mode
    50" - Game mode
    40" - Game mode
    Quad Core
    Chassis P193
    Firefox 2.5
    1 x Ethernet RJ45
    1 x HDMI 1.4 (CEC)
    1 x AV Composite In
    1 x AV Component In
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Wi-Fi Direct
    DVB-T/T2/C
    Analog (PAL,SECAM)
    PVR, Time Shifting
    HEVC
    VP9
    2x10 Watt RMS
    Dolby Digital Plus
    DX730
    DX700
    58", 50"'40"
    No No 58" - HDR max 350cd/m2
    50" - HDR max 350cd/m2
    40" -
    Compatible
    HDR processing
    very glossy panel
    40" - Edge Led(below), Vertical Dimming
    50" - DCI P3 -
    40" - DCI P3 -
    3184:1 / 0.038cd/m2
    50" - 4700:1 /
    40" -
    58" - 40°(conе)
    50" -
    40" -
    50"- Game mode
    40" - Game mode
    Quad Core
    Chassis P193
    Firefox 2.5
    1 x Ethernet RJ45
    1 x HDMI 1.4 (CEC)
    1 x AV Composite in
    1 x AV Component in
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    WiFi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Bluetooth ver. 4.0
    Wi-Fi Direct
    DVB-C/T2/S/S2
    Analog (PAL,SECAM)
    HEVC
    2x10 Watt RMS
    Dolby Digital Plus
    9 DX700
    DX650
    58", 50",40"
    No No 58" -
    50" -
    40" -
    No
    MEMC - Inteligent Frame Creation
    58"- DCI P3 -
    50"- DCI P3 -
    40"- DCI P3 -
    58"-
    50"-
    40"-
    58"-
    50"-
    40"-
    58" - Game mode
    50" - Game mode
    40" - Game mode
    Quad Core
    Chassis -
    Firefox 2.5
    1 x Ethernet RJ45
    1 x HDMI 1.4 (CEC)
    1 x AV Composite in
    1 x AV Component in
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Wi-Fi Direct
    DVB-T/T2/C
    Analog (PAL,SECAM)
    2x10 Watt RMS
    Dolby Digital Plus
    DX650
    DX600
    55", 49", 40"
    49" - max...cd/m2
    40" - max...cd/m2
    No
    40" - Edge Led
    55"- DCI P3 -
    49"- DCI P3 -
    40"- DCI P3 -
    55"-
    49"-
    40"-
    55"- 78° (cone)
    49"-
    40"-
    55" - Game mode
    49" - Game mode
    40" - Game mode
    Chassis -
    Firefox 2.5
    1 x Ethernet RJ45
    1 x HDMI 1.4 (CEC)
    1 x AV Composite in
    1 x AV Component in
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Wi-Fi Direct
    DVB-T/T2/C
    Analog (PAL,SECAM)
    2x10 Watt RMS
    Compatible Dolby® Digital Plus
    VR-Audio True Surround
    DX600
    Product UHD
    Premium
    Dolby
    Vision
    HDR
    _________________
    _________________
    Backlight
    Dimming
    Color Space
    Viewing angle
    ____________
    Input Lag
    SoC
    software
    OS
    _____________
    Conectors
    Networks
    Tuner
    __________________
    Audio
    ______________
    _______________
    Product
    DS630
    50", 40", 32"
    40" - max...cd/m2
    32" - max...cd/m2
    No
    50" - Edge Led
    40" - Edge Led
    32" - Edge Led
    Only globally
    50"- DCI P3 - 74%
    40"- DCI P3 -
    32"- DCI P3 -
    40"-
    32"-
    50"-
    40"-
    32"-
    50" -
    40" -
    32" -
    Chassis P162
    my Home Screen 1.0
    3 x HDMI 1.4 (CEC)
    1 x SCART
    Wi-Fi
    Wi-Fi Direct
    DLNA
    802.11 a/n
    5.660GHZ-5.700GHz
    802.11 b/g/n
    2.412GHz-2.472GHz
    Security
    WPA2-PSK(TKIP/AES)
    WPA-PSK(TKIP/AES)
    WEP(64-bit/128-bit)
    DVB-T/T2/C
    No HEVC
    20 W
    Dolby Digital Plus
    DS630
    DS600
    50", 40", 32"
    40" - max...cd/m2
    32" - max...cd/m2
    No
    50" - Edge Led
    40" - Edge Led
    32" - Edge Led
    50"- DCI P3 -
    40"- DCI P3 -
    32"- DCI P3 -
    50"-
    40"-
    32"-
    50"-
    40"-
    32"-
    50" -
    40" -
    32" -
    Chassis P161
    3 x HDMI 1.4 (CEC)
    2 x USB 2.0
    1 x SCART
    1 x CI+ 1.3
    Wi-Fi
    Wi-Fi Direct
    DLNA
    802.11 a/n
    5.660GHZ-5.700GHz
    802.11 b/g/n
    2.412GHz-2.472GHz
    Security
    WPA2-PSK(TKIP/AES)
    WPA-PSK(TKIP/AES)
    WEP(64-bit/128-bit)
    DVB-T/T2/C
    Analog (PAL,SECAM)
    No HEVC
    20 W
    Dolby Digital Plus
    VR-Audio
    DS600
    DS500
    49" - max 314cd/m2
    40" - max...cd/m2
    32" - max...cd/m2
    24" - max...cd/m2
    No
    55" - Edge Led
    49" - Edge Led
    40" - Edge Led
    32" - Edge Led
    24" - Edge Led
    55" - DCI P3 -
    49" - DCI P3 -
    40" - DCI P3 -
    32" - DCI P3 -
    24" -
    55"-
    49"- 882:1 /
    40"-
    32"-
    24" -
    55"-
    49"- 66° (cone)
    40"-
    32"-
    24" -
    55" -
    49" -
    40" -
    32" -
    24" -
    Chassis P161
    1 x USB 2.0
    1 x Ethernet RJ45
    1 x Scart
    1 x AV Composite In
    1 x AV Component In
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    Wi-Fi
    Wi-Fi Direct
    802.11 a/n
    5.660GHZ-5.700GHz
    802.11 b/g/n
    2.412GHz-2.472GHz
    Security
    WPA2-PSK(TKIP/AES)
    WPA-PSK(TKIP/AES)
    WEP(64-bit/128-bit)
    DLNA
    DVB-T/T2/C
    Analog (PAL,SECAM)
    No HEVC
    6 W [24 "] / 20 W [≥ 32"]
    Dolby Digital Plus
    VR-Audio
    DS500
    DS400
    40"
    No
    Chassis P161
    1 x USB 2.0
    1 x Ethernet RJ 45
    1 x SCART
    1 x AV Composite In
    1 x AV Component In
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    Lan
    WiFi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5Ghz
    DLNA
    DVB-T/T2/C
    Analog (PAL,SECAM)
    20 W
    Dolby Digital Plus
    VR-Audio
    DS400
    Този пост е редактиран от hristoslav2; 15-07-16 в 20:32.
  9. Junior Member Аватара на Darakchiev
    Nov 2013
    #218
    Има ли вариант при ъпдейт да се запазват настройките на картината.
    Предният път като ъпдейтвах се нулираха, което е дразнещо.
    #219
    Никога не са ми се нулирали настройки при ъпдейт - ако си го върнал към първоначални , то тогава се нулират .
    ruuni9 одобрява това.
    #220
    Panasonic TX-50DX750E teardown..
    TX-50DX750E : panel made by INNOLUX V500DK4-KS7 Revision R24
    INNOLUX V500DK4-KS7 Rev.B2 Overview - Panelook.com
    Поглед отзад - кафявата платка отляво е захранващият бок, а зелената отдясно е главната платка процесора и интерфейса
    Speaker - говорител
    Power board - захранващ блок
    Main board - основна платка (процесорът е скрит под радиатора)
    горе в дясно е слота за модула с картата, под него са портовете, а най отдолу пак в дясно е тунерът(металната кутийка)
    Model videopanel
    Този пост е редактиран от hristoslav2; 28-07-16 в 16:36.
    svetlio1, ronnie72, stanislav77 и 1 други харесват това.
    #221
    Panasonic 65DX900Който иска да брои...контролът не е индивидуален а на групи по..знам ли.В центъра по 7, в долната и горната част до рамката по 5, отляво и дясно по 3..Panasonic VIERA プラズマ/有機EL | ログ速@2ちゃんねる(sc)
    Хммм снимката е в противоречие с това, което излезе като презентации в началото на годината...Освен това дистанционното намиращо се под лявата част на телевизора ми се струва доста странно, та се чудя дали на снимката не е Visio P series
    Този пост е редактиран от hristoslav2; 01-08-16 в 23:49.
  13.
  14. Senior Member Аватара на hristoslav2
    #222
    Panasonic DX780 / DXW784 review: rounder with HDR
    Google translate Ni to Bg
    https://www.avforums.com/review/pana...v-review.12800
    Днес ще пооправя таблицата, като я изравня с готовата за Сони. Чудя се, дали да има колонка за вграденият медия плейър...
    1
    Panasonic UHD TV 2016 - european models
    Series
    Model
    ________________
    Certification UHD Premium (1)
    ________
    Dolby Vision(2)
    ____
    HDR 10
    _________________
    In Windows
    2/5/10/20/100%
    Videopanel
    Type LCD matrix,
    Bits of color,
    (Operating frequency of T-Con board of the panel)
    Curvature,
    Index,
    Screen Uniformity
    Backlight
    Type backlight
    Type LED
    MEMC
    Backlight Scanning
    Color Space
    DCI P3 / Rec.2020 / Delta E / Gamma / Temperature
    Contrast White & Black level
    ANSI
    With local dimming
    Viewing angle___________
    ( ° cone)
    Motion resolution
    Horizontal Lines
    Product_____________
    Input Lag
    Audio
    SoC,
    CPU,
    GPU,
    Software,
    OS
    Networks
    Conectors
    Tuners
    ________________
    Note
    ____________________________________________________________________________
    Pros & Cont
    Product
    CZ950 OLED
    TX-65CZ950
    YesSMPTE standartsST2084, ST 2086
    Oled, WRGB (LG Display), 10bit, 120/100Hz No backlight 65" - DCI P3 X,Y - 86% / Rec.2020 - 70% 65" - ∞ / 151cd/m2 / 0.00cd/m2 65" - 45° CZ950
    65"
    OLED
    65" - Game mode - 0ms / by default - 80ms -
    Quad Core Pro 5
    Firefox 2.0
    1 x Ethernet RJ45
    4 x HDMI 2.0a HDCP2.2 (ARC,CEC)
    1 x AV Composite In
    1 x AV Component In
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    Lan -
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Bluetooth ver.4.0(for keyboard and mouse, no Bluetooth audio)
    Wi-Fi Direct
    2 x DVB-C/T2/S2,
    Analog (PAL,SECAM)
    2 x CI+1.3PVR, Time Shifting
    HEVC, VP9
    CZ950
    DX900
    TX-65DX900E
    TX-65DXC904
    TX-65DXW904
    TX-65DX902B
    TX-58DX900E
    TX-58DXC904
    TX-58DXW904
    TX-58DX902B
    58"- max 1430cd/m2
    Yes HDR10SMPTE standardsST2084, ST2086
    Black Frame Insertion (Clear Motion)
    65"' - FALD, 512 zones (32 columns x 16 rows)
    58" - FALD, 512 zones (32 columns x 16 rows)
    BFI - Clear Motion
    65"- 98% / 78% /
    58"- 96% / 74%
    phosphorus-based diodes for a wide gamut close to the DCI 4K(Blue Led + Red/Green phosphorus)
    65" - ANSIStatic - 5360:1 / 134cd/m2 / 0.025cd/m2Dynamic - 50000:1
    58" - ANSI Static - 4600:1 / ---- cd/m2 / 0.023cd/m2 /Dynamic - 50000:1
    65" - 42°(cone)
    58" - 46°(conе)
    DX900
    58", 65"
    40Watt (10W+10W+10W+10W)
    Dolby Digital Plus
    No DTS
    Quad Core
    Chassis P163
    Firefox 2.5
    1 x Ethernet RJ45
    1 x AV Composite In
    1 x AV Component In
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    Lan
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Wi-Fi Direct
    2x DVB-C/T2/S2,
    1 x SAT>IP Client & ServerDVB-T2: HEVC H.264 и H.265
    Analog (PAL,SECAM)
    HEVC, VP9
    ISF ProfessionalTHX Bright Room3D LUTCMS - RGBCYMgray scale of 10 pointsRec.2020Rec.709direct Display Control mode to allow to adjust settings directly from the Calman software (professional edition) by connecting screen to a PC via Ethernet DX900
    DX800
    TX-58DX800E
    TX-58DXW804
    TX-58DX802B
    TX-50DX800E
    TX-50DXW804
    TX-50DX802B
    10% - 458cd/m2
    50" - 10% - 545cd/m2
    Panasonic have done an excellent job of ensuring the backlight is suitably uniform. There was no apparent dirty screen effect or any obvious bright edges and overall with normal viewing material the backlight performance was very good. At night in a dark room you could see some minor backlight issues but those were rare and easily mitigated with some bias lighting.
    58" - Edge Led
    50" - Edge Led
    BFI - Clear Motion
    58"- 95% / 72%
    50"- 86% / 67% / DeltaE 2.3 / Gamma 2.4
    58" - ANSI 3500:1 / 0.0
    50" - ANSI 5310:1 / 0.02cd/m2
    with Adaptive Backlight Control (local dimming) 0.002cd/m2,
    58" -
    50" -
    58" -
    50" - with IFC - 1080 / without - 350
    DX800
    58", 50"
    50" - Game mode 44ms / by default 110ms
    The DX802 delivered an input lag of 44ms in Game Mode, which whilst not as low as some of the competition, should be good enough for all but the most demanding of gamers. We certainly had no problems with lag when gaming and found the overall performance to be very good with our PS4. One interesting thing to note is that you can select the Game Mode when watching HDR content, which means that when HDR games are released you should still be able to enjoy the benefits of a lower input lag.
    40 W (10W+10W+20W)
    Dolby Digital Plus
    No DTS
    12 TrainPrismatic Speaker
    The soundbar includes a 12 train prismatic speaker, a quad passive radiator and 40W of amplification, whilst there are holes at the back so that it can, along with the TV, also be wall mounted. The fact that you can detach the soundbar completely means you also have the option to not use it at all and simply use your DX802 with a third-party audio solution.
    Quad Core
    Chassis P163
    Firefox 2.5
    1 x Ethernet RJ45
    1 x AV Composite In
    1 x AV Component In
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    Lan
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Wi-Fi Direct
    2 x DVB-C/T2/S2,
    Analog (PAL,SECAM)2 x CI+1.3PVR, Time Shifting HEVC, VP9
    As with all Panasonic TVs, the DX800 comes with an excellent set of calibration controls, including 2- and 10-point white balance controls, a separate gamma control and a full Colour Management System (CMS),ISF Professional, THX Bright Room, 3D LUTCMS - RGBCYM gray scale of 10 points. Rec.2020, Rec.709 direct Display Control mode to allow to adjust settings directly from the Calman software (professional edition) by connecting screen to a PC via Ethernet The colour accuracy of the DX802 wasn't as good as we would expect from a Panasonic TV DX800
    DX780
    TX-65DX780E
    TX-65DXW784
    TX-58DX780E
    TX-58DXW784
    TX-58DXX789
    TX-58DXN788
    TX-58DXF787
    TX-58DXT786
    TX-50DX780E
    TX-50DXW784
    TX-50DXT786
    TX-50DXF787
    55" - max 577cd/m2
    CompatibleHDR processing (but no hardware for HDR)
    65" - Super-MVA, 8-bit+Hi-FRC, 120/100Hz
    58" - Super-MVA, 8-bit+Hi-FRC, 120/100Hz
    50" - Super-MVA, 8-bit+Hi-FRC, 120/100Hz
    BFI - Clear Motion
    65" - DCI P3 X,Y -
    58" - DCI P3 X,Y -
    65" -
    58" -
    50" -
    65" -
    58" -
    50" -
    DX780
    65", 58", 50"
    65" - Game mode
    58" - Game mode
    50" - Game mode
    2x10 Watt RMS
    Dolby Digital Plus
    No DTS
    Quad Core
    Chassis P163
    Firefox 2.5
    1 x Ethernet RJ45
    2 x HDMI 2.0a HDCP2.2 (ARC,CEC)
    2 x HDMI 1.4 (CEC)
    1 x AV Composite In
    1 x AV Component In
    1 x 3.5mm Audio Out
    1 x Antena (RF)female1 x CI+ 1.3
    Wi-Fi 802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Bluetooth Ver.4.0(for keyboard and mouse, no Bluetooth audio)
    Wi-Fi Direct
    2 x DVB-C/T2/S2,
    1 x SAT>IP Client & ServerDVB-T2: HEVC H.264 и H.265Analog (PAL,SECAM)2 x CI+1.3PVR, Time Shifting
    HEVC, VP9
    DX780
    DX750
    TX-65DX750E
    TX-65DX750B
    TX-58DX750E
    TX-58DX750F
    TX-50DX750E
    TX-50DX750F
    TX-50DX750B
    No No 65" - max 435cd/m2
    58" - 100% max 550cd/m2
    50" - 10% max 529cd/m2/
    SDR max 500cd/m2
    50" - Super-MVA, 8-bit+HI-FRC, 120/100Hz
    50"- panel Innolux V500DK4-KS7-Rev.R24
    very glossy panel
    The Adaptive Backlight Control (local dimming) on the DX750 was a little disappointing, especially compared to the sophisticated system employed by Samsung, and even in the low mode we saw artefacts that were quite obvious at times. Although it was less an issue of haloing and more of a problem of the entire image obviously dimming in certain scenes. However since the native blacks and backlight uniformity are good, if you sit central to the screen there is very little difference with the local dimming on or off and at least when it's off you avoid any issues.
    BMR 1800
    65" - 90% / 70%
    58" - 90% / 70%
    50" - 86% / 66%
    50" - ANSI 3795:1 / 0.023cd/m2
    with Adaptive Backlight Control(Local Dimming) 0.001cd/m2
    Static 4800:1/ 120 cd/m2 / 0.025cd/m2
    Dynamic 5000:1 / 625cd/m2 / 0.10cd/m2
    65" - 42° (cone)
    58" - 44° (cone)
    50" - 46° (cone)
    65" -
    58" - with IFC 1080 / without - 350
    50" - with IFC 1080 / without - 350
    DX750
    65", 58", 50"
    2x10 Watt RMS
    Dolby Digital Plus
    No DTS
    The rendering is still acceptable, average with perfectly intelligible dialogue, but rather limited power with 2 x 10 Watts and no Subwoofer output as Sony. no one still finds a lot of settings to optimize the sound rendering, level the volume changes from one channel to another, a 7-band EQ, a surround mode, etc.
    Quad Core
    Chassis P163
    Firefox 2.5
    1 x Ethernet RJ45
    2 x HDMI 1.4 (CEC)
    1 x AV Composite In
    1 x AV Component In
    1 x 3.5mm Audio Out
    Wi-Fi 802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Wi-Fi Direct
    DVB- C/T2/S2
    Analog (PAL,SECAM)
    PVR, Time Shifting
    HEVC H.265, VP9
    Accurate Colour Drive technology with 3D LUT conversion table with 8 000 points correction and the ability to calibrate 6 primary and secondary colors within a CMS on 3 axes. Or Black Gradation Drive that can provide more gradations in dark scenes through treatment with 12 bit color.To adjust the colorimetry, the DX750 offers all the necessary settings with the choice of gamut used (Rec.601, Rec.709, EBU, DCI / P3 or Rec.2020), gamma used (with varying gamma whose BT.1886 with compensation of black, 2.2 used in lit room, the 2.4 used in dark room). You can edit each Gamma to correct on 10 points. Each gamut can be calibrated from a CMS (Color Management System) 3-axis (luminance, saturation and hue) with opportunity to correct 6 primary and secondary colors (RGBCMY). Finally, we also find a Balance Whites 2P and 10P (10 points) to adjust the color temperature.THX - NoISF - No As for upscaling UHD Panasonic, there is no doubt he has made great progress. It's quite different from what Samsung offers, closer to what Sony offers, that is to say a very natural image, less chiseled than on the Samsung TV, but very precise and with a sumptuous quilted. The upscaling provides an image with rich texture and greatly improves accuracy without displaying traces of upscaling. So it is very comprehensive, especially for network management, but lacks however DisplayPort who was present on the AX900, or aptX Bluetooth and a Subwoofer output like what Sony offers. Standard remote control, without micro or backlit button. A good remote control, solid but rather plain .., and no possibility to calibrate the TV for a tablet like the DX900 as the DX750 is not certified ISF.
    • + Design, build quality, the possibility of multiple foot positions
    • + A powerful contrast to an Edge LED (4800: 1 ANSI)
    • + A bright peak in HDR pretty good (625 nits)
    • + System of internal gradation great despite the slab 8 bit
    • + HDR rendering of very good quality
    • + A rich spectrum of beautiful, balanced colors, a wide gamut (91.2% of DCI)
    • + Colorimetry output very correct card (delta E less than 3)
    • + A high-performance video processing, including SD content with a very natural picture
    • + Several algorithms with efficient remastering yet made once natural
    • + Ultra settings to complete color management level and HDMI
    • + IFC made without a fluid including 24P
    • + Complete network management, Samba, DLNA / UPnP, multiroom client / server, sharing the tuner on the network
    • + interesting multimedia management (UHD video playback and HDR, VP9 and HEVC, MKV, TS, Flac, ALAC, etc.), but no DTS decoding that just spoils the fun!
    • + A good quality 3D rendering, although some ghosting
    • + The best quality / price ratio in 2016, certainly!
    • - The anti-reflection treatment of limited
    • - A slab 8 bit (although fnally we do not notice it)
    • - IFC made too which generates a digital or video camera (main fault)
    • - Lack of support DTS multimedia
    • - A single HD tuner (DVB-C / T2 compliant HEVC and MPEG4)
    • - A slightly Directive slab contrast term as all VA panels
    • - A detail enhancement filter and / or contours would have been welcome for more chiseled picture lovers
    • - No compatibility Dolby Vision
    • - Local Dimming that a mouth too black to Medium or High
    • - The edges of the slab clearer in some dark scenes
    DX750
    DX730
    TX-58DX730E
    TX-50DX730E
    TX-40DX730E
    TX-40DXW735
    TX-40DXW734
    50"- max 317cd/m2
    40" - max...cd/m2
    58" - Super-MVA, 8-bit+FRC, 60/50Hz
    50" - Super-MVA, 8-bit+FRC, 60/50Hz
    40" - Super-MVA, 8-bit+FRC, 60/50Hz
    Black Frame Interpolation
    4K Backlight Motion Rate IFC 1400
    very glossy panel
    58" - DCI P3 -
    50" - DCI P3 -
    40" - DCI P3 -
    58" -
    40" -
    58" -
    50" - 42° (cone)
    40" -
    DX730
    58", 50", 40"
    58" - Game mode
    50" - Game mode
    40" - Game mode
    2x10 Watt RMS
    Dolby Digital Plus
    No DTS
    VR-Audio Surround
    True
    Quad Core
    Chassis P193
    Firefox 2.5
    1 x Ethernet RJ45
    1 x HDMI 1.4 (CEC)
    1 x AV Composite In
    1 x AV Component In
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Wi-Fi Direct
    DVB-T/T2/C/S/S2
    Double Tuner
    Analog (PAL,SECAM)
    PVR, Time Shifting
    HEVC, VP9
    DX730
    DX720
    TX-58DX720E
    TX-50DX720E
    TX-40DX720E
    50"- max ....cd/m2
    40" - max...cd/m2
    4K Backlight Motion Rate IFC 1600
    very glossy panel
    58" - Led, Local Dimming
    50" - Led, Local Dimming
    40" - Led, Local Dimming
    58" - DCI P3 -
    50" - DCI P3 -
    40" - DCI P3 -
    58" -
    40" -
    58" -
    50" - 42° (cone)
    40" -
    DX720
    58", 50", 40"
    58" - Game mode
    50" - Game mode
    40" - Game mode
    2x10 Watt RMS
    Dolby Digital Plus
    No DTS
    Quad Core
    Chassis P193
    Firefox 2.5
    1 x Ethernet RJ45
    1 x HDMI 1.4 (CEC)
    1 x AV Composite In
    1 x AV Component In
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Wi-Fi Direct
    DVB-T/T2/C
    Analog (PAL,SECAM)
    PVR, Time Shifting
    HEVC, VP9
    DX720
    DX700
    TX-58DX700E
    TX-58DX700F
    TX-58DXW704
    TX-50DX700E
    TX-50DX703E
    TX-50DXU701
    TX-40DX700E
    TX-40DX703E
    TX-40DX700F
    TX-40DXU701
    40" -
    very glossy panel
    50" - DCI P3 -
    40" - DCI P3 -
    58"- 5736:1 / 153cd/m2 / 0.03cd/m23184:1 / 0.038cd/m2ANSI - 2304:1 / 0.046cd/m2
    50" - 4700:1 /
    40" -
    58" - 40°(conе)
    50" -
    40" -
    DX700
    58", 50"'40"
    50"- Game mode
    40" - Game mode
    2x10 Watt RMS
    Dolby Digital Plus
    No DTS
    Quad Core
    Chassis P193
    Firefox 2.5
    1 x Ethernet RJ45
    1 x HDMI 1.4 (CEC)
    1 x AV Composite in
    1 x AV Component in
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    WiFi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Bluetooth ver. 4.0
    Wi-Fi Direct
    DVB-C/T2/S/S2
    Analog (PAL,SECAM)
    HEVC,
    DX700
    DX650
    TX-55DX650E
    TX-55DX653E
    TX-55DXW654
    TX-49DX650E
    TX-49DX653E
    TX-40DX650E
    TX-40DX653E
    No No 55" -
    49" -
    40" -
    No
    49"- Super-MVA, 8-bit, 60/50Hz
    4K Backlight Motion Rate IFC 1000
    55"- DCI P3 -
    49"- DCI P3 -
    40"- DCI P3 -
    55"-
    49"-
    40"-
    55"-
    49"-
    40"-
    DX650
    55", 49",40"
    55" - Game mode
    49" - Game mode
    40" - Game mode
    2x10 Watt RMS
    Dolby Digital Plus
    No DTS
    Quad Core
    Chassis -Firefox 2.5
    1 x Ethernet RJ45
    1 x HDMI 1.4 (CEC)
    1 x AV Composite in
    1 x AV Component in
    1 x 3.5mm Audio Out
    1 x Antena (RF) female1 x CI+ 1.3
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Wi-Fi Direct
    DVB-T/T2/C
    Analog (PAL,SECAM)
    DX650
    DX600
    TX-55DX600E
    TX-55DX603E
    TX-55DXW604
    TX-55DXU601
    TX-49DX600E
    TX-49DX603E
    TX-49DXU601
    TX-49DXW604
    TX-40DX600E
    TX-40DX603E
    TX-40DXW604
    TX-40DXU601
    49" - max...cd/m2
    40" - max...cd/m2
    No
    4K Backlight Motion Rate IFC 800
    40" - Edge Led
    55"- DCI P3 -
    49"- DCI P3 -
    40"- DCI P3 -
    55"-
    49"-
    40"-
    55"- 78° (cone)
    49"-
    40"-
    DX600
    55", 49", 40"
    55" - Game mode
    49" - Game mode
    40" - Game mode
    2x10 Watt RMS
    Compatible
    Dolby Digital Plus
    No DTS
    Chassis
    Firefox 2.5
    1 x Ethernet RJ45
    1 x HDMI 1.4 (CEC)
    1 x AV Composite in
    1 x AV Component in
    1 x 3.5mm Audio Out
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Wi-Fi Direct
    DVB-T/T2/C
    Analog (PAL,SECAM)
    DX600
    Series
    Model
    ________________
    ________
    Dolby Vision(2)
    ____
    HDR 10
    ________________
    In Windows
    2/5/10/20/100%
    Videopanel
    Type LCD matrix,
    Bits of color,
    Curvature,
    Index,
    Screen Uniformity
    Backlight
    Type backlight
    Type LED
    MEMC
    Backlight Scanning
    Color Space
    ___________________
    ANSIWith local dimmingWithout local dimming
    Viewing angle
    _______________
    ( ° cone)
    Motion resolution
    Product
    _____________
    Input Lag
    Audio
    SoCCPUGPUSoftwareOS
    Networks
    ____________
    Conectors
    Tuners
    ______________
    Note
    Pros & Cont
    Product
    Този пост е редактиран от hristoslav2; 01-08-16 в 22:13.
    #223
    Panasonic 65DX900E (DX900E) UHD HDR LCD TV – recenzija – HD Televizija – HDTV eZine
    Google превод Hr to Bg
    Series
    Model
    ________________
    ________
    Dolby Vision(2)
    ____
    HDR 10
    _________________
    In Windows
    2/5/10/20/100%
    Videopanel
    Type LCD matrix,
    Bits of color,
    Curvature,
    Index,
    Screen Uniformity
    Backlight
    Type backlight
    Type LED
    MEMC
    Backlight Scanning
    Color Space
    ANSI
    With local dimming
    ( ° cone)
    Motion resolution
    Horizontal Lines
    Input Lag
    Audio
    SoC,
    CPU,
    GPU,
    Software,
    OS
    Networks
    Conectors
    Tuners
    ________________
    Note
    ______________________________________________________________________________
    Pros & Cont
    Product
    CZ950 OLED
    TX-65CZ950
    TX-65CZ952B
    Yes
    SMPTE standarts
    ST2084, ST 2086
    Oled, WRGB (LG Display), 10bit, 120/100Hz No backlight 65" - 86% / 70% / 65" - ∞ / 151cd/m2 / 0.00cd/m2 65" - 45° CZ950
    65"
    OLED
    65" - Game mod.
    DX900
    TX-65DX900E
    TX-65DXC904
    TX-65DXW904
    TX-65DX902B
    TX-58DX900E
    TX-58DXC904
    TX-58DXW904
    TX-58DX902B
    58"- max 1430cd/m2
    Yes HDR10
    SMPTE standards
    ST2084, ST2086
    Motion Clarity Frame Interpolation (IFC)
    BFI - Clear Motion
    65"- 98% / 78% /
    58"- 96% / 74%
    65" - 42°(cone)
    58" - 46°(conе)
    DX900
    58", 65"
    65"- 65" - Normal: 51.2ms
    Normal + Game mode: 40.7ms
    THX cinema + Game mode: 42.7ms
    Professional 1 + Game mode: 42.8ms
    Dolby Digital Plus
    No DTS
    Quad Core
    Chassis P163
    Firefox 2.5
    1 x Ethernet RJ45
    1 x AV Composite In
    1 x AV Component In
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    Lan
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Wi-Fi Direct
    2x DVB-C/T2/S2,
    Analog (PAL,SECAM)
    HEVC, VP9
    • + The Full LED backlight with honeycomb structure and 512 zones Local Dimming
    • + A record for a contrast LED TV, visually very close to the OLED
    • + An ultra high light pic!
    • + A 10-bit panel
    • + An exceptional rendering HDR
    • + A rich spectrum of stunning colors and balanced
    • + Colorimetry output of cardboard near-perfect in Rec.709 and DCI (Delta E 1)
    • + The efficiency of HCX + processor: magnificent display UHD upscaling and great
    • + Rendering fluid, even without IFC
    • + Complete network management, Samba, DLNA / UPnP, multiroom client / server, sharing of tuners on the network
    • + A good anti-reflective coating
    • + Very good record audio
    • + The best current LED TV, a reference!
    • - IFC made too which generates a digital camcorder
    • - The very average 3D or not good (blocked backlight, gray and black marked ghosting)
    • - The absence of DTS support, multimedia playback 24p, or playback HD audio tracks
    • - A very directive slab (loss of contrast and color beyond 20 °)
    • - A filter detail enhancement and / or contours would have been welcome for picture lovers scalpel
    • - The inclination of the slab to 6, no interest and can be binding
    • - A cover 100% of the DCI would have been welcome at this price!
    • - The price, too high for a LED TV, whatever its quality!
    • - many users have encountered the vertical banding worries with the 58 "(65" offers however excellent homogeneity)
    DX900
    DX800
    TX-58DX800E
    TX-58DXW804
    TX-58DX802B
    TX-50DX800E
    TX-50DXW804
    TX-50DX802B
    10% - 458cd/m2
    Yes HDR10
    SMPTE standards
    ST2084, ST2086
    58" - Edge Led
    50" - Edge Led
    BFI - Clear Motion
    58"- 95% / 72%
    58" -
    50" -
    58" -
    DX800
    58", 50"
    40 W (10W+10W+20W)
    Dolby Digital Plus
    No DTS
    Quad Core
    Chassis P163
    Firefox 2.5
    1 x Ethernet RJ45
    1 x AV Composite In
    1 x AV Component In
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    Lan
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Wi-Fi Direct
    2 x DVB-C/T2/S2,
    DX780
    TX-65DX780E
    TX-65DXW784
    TX-58DX780E
    TX-58DXW784
    TX-58DXX789
    TX-58DXN788
    TX-58DXF787
    TX-58DXT786
    TX-50DX780E
    TX-50DXW784
    TX-50DXT786
    TX-50DXF787
    55" - max 577cd/m2
    Compatible
    BFI - Clear Motion
    65" - DCI P3 X,Y -
    58" - DCI P3 X,Y -
    65" -
    58" -
    50" -
    65" -
    58" -
    50" -
    DX780
    65", 58", 50"
    65" - Game mode
    58" - Game mode
    50" - Game mode
    2x10 Watt RMS
    Dolby Digital Plus
    No DTS
    Quad Core
    Chassis P163
    Firefox 2.5
    1 x Ethernet RJ45
    2 x HDMI 1.4 (CEC)
    1 x AV Composite In
    1 x AV Component In
    1 x 3.5mm Audio Out
    Wi-Fi 802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Wi-Fi Direct
    2 x DVB-C/T2/S2,
    HEVC, VP9
    DX780
    DX750
    TX-65DX750E
    TX-65DX750B
    TX-58DX750E
    TX-58DX750F
    TX-50DX750E
    TX-50DX750F
    TX-50DX750B
    SDR max 500cd/m2
    Compatible
    very glossy panel
    BMR 1800
    65" - 90% / 70%
    58" - 90% / 70%
    50" - 86% / 66%
    65" - 42° (cone)
    58" - 44° (cone)
    50" - 46° (cone)
    65" -
    DX750
    65", 58", 50"
    2x10 Watt RMS
    Dolby Digital Plus
    No DTS
    Quad Core
    Chassis P163
    Firefox 2.5
    1 x Ethernet RJ45
    2 x HDMI 1.4 (CEC)
    1 x AV Composite In
    1 x AV Component In
    1 x 3.5mm Audio Out
    Wi-Fi 802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Wi-Fi Direct
    DVB- C/T2/S2
    Analog (PAL,SECAM)
    PVR, Time Shifting
    HEVC H.265, VP9
    DX750
    DX730
    TX-58DX730E
    TX-50DX730E
    TX-40DX730E
    TX-40DXW735
    TX-40DXW734
    50"- max 317cd/m2
    40" - max...cd/m2
    Compatible
    very glossy panel
    58" - DCI P3 -
    50" - DCI P3 -
    40" - DCI P3 -
    58" -
    40" -
    58" -
    50" - 42° (cone)
    40" -
    DX730
    58", 50", 40"
    58" - Game mode
    50" - Game mode
    40" - Game mode
    2x10 Watt RMS
    Dolby Digital Plus
    No DTS
    VR-Audio Surround
    True
    Quad Core
    Chassis P193
    Firefox 2.5
    1 x Ethernet RJ45
    1 x HDMI 1.4 (CEC)
    1 x AV Composite In
    1 x AV Component In
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Wi-Fi Direct
    DVB-T/T2/C/S/S2
    Double Tuner
    Analog (PAL,SECAM)
    PVR, Time Shifting
    HEVC, VP9
    DX730
    DX720
    TX-58DX720E
    TX-50DX720E
    TX-40DX720E
    50"- max ....cd/m2
    40" - max...cd/m2
    Compatible
    very glossy panel
    58" - DCI P3 -
    50" - DCI P3 -
    40" - DCI P3 -
    58" -
    40" -
    58" -
    50" - 42° (cone)
    40" -
    DX720
    58", 50", 40"
    58" - Game mode
    50" - Game mode
    40" - Game mode
    2x10 Watt RMS
    Dolby Digital Plus
    No DTS
    Quad Core
    Chassis P193
    Firefox 2.5
    1 x Ethernet RJ45
    1 x HDMI 1.4 (CEC)
    1 x AV Composite In
    1 x AV Component In
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Wi-Fi Direct
    DVB-T/T2/C
    Analog (PAL,SECAM)
    PVR, Time Shifting
    HEVC, VP9
    DX720
    DX700
    TX-58DX700E
    TX-58DX700F
    TX-58DXW704
    TX-50DX700E
    TX-50DX703E
    TX-50DXU701
    TX-40DX700E
    TX-40DX703E
    TX-40DX700F
    TX-40DXU701
    40" -
    Compatible
    very glossy panel
    50" - DCI P3 -
    40" - DCI P3 -
    50" - 4700:1 /
    40" -
    58" - 40°(conе)
    50" -
    40" -
    DX700
    58", 50"'40"
    50"- Game mode
    40" - Game mode
    2x10 Watt RMS
    Dolby Digital Plus
    No DTS
    Quad Core
    Chassis P193
    Firefox 2.5
    1 x Ethernet RJ45
    1 x HDMI 1.4 (CEC)
    1 x AV Composite in
    1 x AV Component in
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    WiFi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Bluetooth ver. 4.0
    Wi-Fi Direct
    DVB-C/T2/S/S2
    Analog (PAL,SECAM)
    HEVC,
    DX700
    DX650
    TX-55DX650E
    TX-55DX653E
    TX-55DXW654
    TX-49DX650E
    TX-49DX653E
    TX-40DX650E
    TX-40DX653E
    No No 55" -
    49" -
    40" -
    No
    55"- DCI P3 -
    49"- DCI P3 -
    40"- DCI P3 -
    55"-
    49"-
    40"-
    55"-
    49"-
    40"-
    DX650
    55", 49",40"
    55" - Game mode
    49" - Game mode
    40" - Game mode
    2x10 Watt RMS
    Dolby Digital Plus
    No DTS
    Quad Core
    1 x Ethernet RJ45
    1 x HDMI 1.4 (CEC)
    1 x AV Composite in
    1 x AV Component in
    1 x 3.5mm Audio Out
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Wi-Fi Direct
    DVB-T/T2/C
    Analog (PAL,SECAM)
    DX650
    DX600
    TX-55DX600E
    TX-55DX603E
    TX-55DXW604
    TX-55DXU601
    TX-49DX600E
    TX-49DX603E
    TX-49DXU601
    TX-49DXW604
    TX-40DX600E
    TX-40DX603E
    TX-40DXW604
    TX-40DXU601
    49" - max...cd/m2
    40" - max...cd/m2
    No
    40" - Edge Led
    55"- DCI P3 -
    49"- DCI P3 -
    40"- DCI P3 -
    55"-
    49"-
    40"-
    55"- 78° (cone)
    49"-
    40"-
    DX600
    55", 49", 40"
    55" - Game mode
    49" - Game mode
    40" - Game mode
    2x10 Watt RMS
    Compatible
    Dolby Digital Plus
    No DTS
    Chassis
    Firefox 2.5
    1 x Ethernet RJ45
    1 x HDMI 1.4 (CEC)
    1 x AV Composite in
    1 x AV Component in
    1 x 3.5mm Audio Out
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Wi-Fi Direct
    DVB-T/T2/C
    Analog (PAL,SECAM)
    DX600
    Series
    Model
    ________________
    ________
    Dolby Vision(2)
    ____
    HDR 10
    ________________
    In Windows
    2/5/10/20/100%
    Videopanel
    Type LCD matrix,
    Bits of color,
    Curvature,
    Index,
    Screen Uniformity
    Backlight
    Type backlight
    Type LED
    MEMC
    Backlight Scanning
    Color Space
    ___________________
    Viewing angle
    _______________
    ( ° cone)
    Motion resolution
    Product
    _____________
    Input Lag
    Audio
    SoCCPUGPUSoftwareOS
    Networks
    ____________
    Conectors
    Tuners
    ______________
    Note
    Pros & Cont
    Product
    Този пост е редактиран от hristoslav2; 04-08-16 в 17:26.
    #224
    Panasonic TX-65DX902B Review
    Series
    Model
    ________________
    ________
    Dolby Vision(2)
    ____
    HDR 10
    _________________
    In Windows
    2/5/10/20/100%
    Videopanel
    Type LCD matrix,
    Bits of color,
    Curvature,
    Index,
    Screen Uniformity
    Backlight
    Type backlight
    Type LED
    MEMC
    Backlight Scanning
    Measurements
    (Pre & Post Calibration)
    DCI P3
    Rec.2020
    Delta E
    Gamma
    Temperature
    Measurements
    ANSI contrast
    White & Black level
    With local dimming
    Viewing angle
    ______________
    ( ° cone)
    Motion resolution
    Horizontal Lines
    Input Lag
    Audio
    SoC,
    CPU,
    GPU,
    Software,
    OS
    Networks
    Conectors
    Tuners
    ________________
    Note
    Pros & Cont
    Product
    CZ950 OLED
    TX-65CZ950
    TX-65CZ952B
    Yes
    SMPTE standarts
    ST2084, ST 2086
    Oled, WRGB (LG Display), 10bit, 120/100Hz No backlight DCI-P3 - 86%
    Rec.2020 - 70%
    Gama - 2.44 - 2.38
    65"
    OLED
    65" - Game mode - 74ms
    DX900
    TX-65DX900E
    TX-65DXC904
    TX-65DXW904
    TX-65DX902B
    TX-58DX900E
    TX-58DXC904
    TX-58DXW904
    TX-58DX902B
    100% - 885cd/m2
    58"- max 1430cd/m2
    Yes HDR10
    SMPTE standards
    ST2084, ST2086
    65" - FALD, 512 zones (32 x 16)
    58" - FALD, 512 zones (32 x 16)
    Blue Leds - PFS (potassium-fluorosilicate) phosphor featuring an extremely narrow red peak
    BFI - Clear Motion
    65"-
    DCI-P3 - 98.03%
    Rec=2020 - 78%
    Gama - 2.41 - 2.4 /
    58"-
    DCI-P3 - 96%
    Rec.2020 - 74%
    Gama - 2.41 - 2.4
    65" - ANSI (4x4) - 5360:1
    Pre - 134cd/m2 (white)
    Pre - 0.025cd/m2 (black)
    Post - 0.019cd/m2 (black)
    Dynamic - 50000:1
    58" - ANSI (4x4) - 4600:1
    without - 0.025 cd/m2 (black)
    with - 0.023cd/m2 (black)Dynamic - 50000:1
    65" - 46°(cone)
    58" - 46°(conе)
    65" - 1080 lines with[IFC]“Custom“; 300 “Off“
    58" - 1080 lines
    DX900
    58", 65"
    HDR + Game mode - 38.8ms [Adaptive Backlight Control - OFF]
    Dolby Digital Plus
    No DTS
    Quad Core
    Chassis P163
    Firefox 2.5
    1 x Ethernet RJ45
    1 x AV Composite In
    1 x AV Component In
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    Lan
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Wi-Fi Direct
    2x DVB-C/T2/S2,
    Analog (PAL,SECAM)
    HEVC, VP9
    ISF ProfessionalTHX Bright Room3D LUTCMS - RGBCYMgray scale of 10 pointsRec.2020Rec.709direct Display Control mode to allow to adjust settings directly from the Calman software (professional edition) by connecting screen to a PC via Ethernet Although the Panasonic DX902 features a high number of FALD zones, in certain low-APL scenes the dimming algorithm in HDR mode could be too aggressive even with [Automatic Backlight Control] set to the lowest value of “Min“, spoiling the original creative intent of the movie. One such instance was during the opening space sequence in The Martian: the Viera TX-65DX902B was darkening several dark patches excessively, resulting in a blotchy “reverse clouding” effect.
    The DX900′s sharply-defined backlight algorithm also had a tendency to show up the FALD grid structure of the television. As the title “The Martian” appeared on the aforementioned space scene, the bright letters were accompanied by square-shaped haloing/ blooming against the dark backdrop. The same phenomenon could be observed in timecode 00:19:56 of The Revenant where Hugh is reassuring his son Hawk at night, with the silhouettes being displayed in rectangular halos.
    • + A 10-bit panel
    DX900
    DX800
    TX-58DX800E
    TX-58DXW804
    TX-58DX802B
    TX-50DX800E
    TX-50DXW804
    TX-50DX802B
    10% - 458cd/m2
    Yes HDR10
    SMPTE standards
    ST2084, ST2086
    58" - Edge Led
    50" - Edge Led
    BFI - Clear Motion
    58"- 95% / 72%
    58" -
    50" -
    58" -
    DX800
    58", 50"
    40 W (10W+10W+20W)
    Dolby Digital Plus
    No DTS
    Quad Core
    Chassis P163
    Firefox 2.5
    1 x Ethernet RJ45
    1 x AV Composite In
    1 x AV Component In
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    Lan
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Wi-Fi Direct
    2 x DVB-C/T2/S2,
    DX780
    TX-65DX780E
    TX-65DXW784
    TX-58DX780E
    TX-58DXW784
    TX-58DXX789
    TX-58DXN788
    TX-58DXF787
    TX-58DXT786
    TX-50DX780E
    TX-50DXW784
    TX-50DXT786
    TX-50DXF787
    55" - max 577cd/m2
    Compatible
    BFI - Clear Motion
    65" - DCI P3 X,Y -
    58" - DCI P3 X,Y -
    65" -
    58" -
    50" -
    65" -
    58" -
    50" -
    DX780
    65", 58", 50"
    65" - Game mode
    58" - Game mode
    50" - Game mode
    2x10 Watt RMS
    Dolby Digital Plus
    No DTS
    Quad Core
    Chassis P163
    Firefox 2.5
    1 x Ethernet RJ45
    2 x HDMI 1.4 (CEC)
    1 x AV Composite In
    1 x AV Component In
    1 x 3.5mm Audio Out
    Wi-Fi 802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Wi-Fi Direct
    2 x DVB-C/T2/S2,
    HEVC, VP9
    DX780
    DX750
    TX-65DX750E
    TX-65DX750B
    TX-58DX750E
    TX-58DX750F
    TX-50DX750E
    TX-50DX750F
    TX-50DX750B
    SDR max 500cd/m2
    Compatible
    very glossy panel
    BMR 1800
    65" - 90% / 70%
    58" - 90% / 70%
    50" - 86% / 66%
    65" - 42° (cone)
    58" - 44° (cone)
    50" - 46° (cone)
    65" -
    DX750
    65", 58", 50"
    2x10 Watt RMS
    Dolby Digital Plus
    No DTS
    Quad Core
    Chassis P163
    Firefox 2.5
    1 x Ethernet RJ45
    2 x HDMI 1.4 (CEC)
    1 x AV Composite In
    1 x AV Component In
    1 x 3.5mm Audio Out
    Wi-Fi 802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Wi-Fi Direct
    DVB- C/T2/S2
    Analog (PAL,SECAM)
    PVR, Time Shifting
    HEVC H.265, VP9
    DX750
    DX730
    TX-58DX730E
    TX-50DX730E
    TX-40DX730E
    TX-40DXW735
    TX-40DXW734
    50"- max 317cd/m2
    40" - max...cd/m2
    Compatible
    very glossy panel
    58" - DCI P3 -
    50" - DCI P3 -
    40" - DCI P3 -
    58" -
    40" -
    58" -
    50" - 42° (cone)
    40" -
    DX730
    58", 50", 40"
    58" - Game mode
    50" - Game mode
    40" - Game mode
    2x10 Watt RMS
    Dolby Digital Plus
    No DTS
    VR-Audio Surround
    True
    Quad Core
    Chassis P193
    Firefox 2.5
    1 x Ethernet RJ45
    1 x HDMI 1.4 (CEC)
    1 x AV Composite In
    1 x AV Component In
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Wi-Fi Direct
    DVB-T/T2/C/S/S2
    Double Tuner
    Analog (PAL,SECAM)
    PVR, Time Shifting
    HEVC, VP9
    DX730
    DX720
    TX-58DX720E
    TX-50DX720E
    TX-40DX720E
    50"- max ....cd/m2
    40" - max...cd/m2
    Compatible
    very glossy panel
    58" - DCI P3 -
    50" - DCI P3 -
    40" - DCI P3 -
    58" -
    40" -
    58" -
    50" - 42° (cone)
    40" -
    DX720
    58", 50", 40"
    58" - Game mode
    50" - Game mode
    40" - Game mode
    2x10 Watt RMS
    Dolby Digital Plus
    No DTS
    Quad Core
    Chassis P193
    Firefox 2.5
    1 x Ethernet RJ45
    1 x HDMI 1.4 (CEC)
    1 x AV Composite In
    1 x AV Component In
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Wi-Fi Direct
    DVB-T/T2/C
    Analog (PAL,SECAM)
    PVR, Time Shifting
    HEVC, VP9
    DX720
    DX700
    TX-58DX700E
    TX-58DX700F
    TX-58DXW704
    TX-50DX700E
    TX-50DX703E
    TX-50DXU701
    TX-40DX700E
    TX-40DX703E
    TX-40DX700F
    TX-40DXU701
    40" -
    Compatible
    very glossy panel
    50" - DCI P3 -
    40" - DCI P3 -
    50" - 4700:1 /
    40" -
    58" - 40°(conе)
    50" -
    40" -
    DX700
    58", 50"'40"
    50"- Game mode
    40" - Game mode
    2x10 Watt RMS
    Dolby Digital Plus
    No DTS
    Quad Core
    Chassis P193
    Firefox 2.5
    1 x Ethernet RJ45
    1 x HDMI 1.4 (CEC)
    1 x AV Composite in
    1 x AV Component in
    1 x 3.5mm Audio Out
    1 x CI+ 1.3
    WiFi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Bluetooth ver. 4.0
    Wi-Fi Direct
    DVB-C/T2/S/S2
    Analog (PAL,SECAM)
    HEVC,
    DX700
    DX650
    TX-55DX650E
    TX-55DX653E
    TX-55DXW654
    TX-49DX650E
    TX-49DX653E
    TX-40DX650E
    TX-40DX653E
    No No 55" -
    49" -
    40" -
    No
    55"- DCI P3 -
    49"- DCI P3 -
    40"- DCI P3 -
    55"-
    49"-
    40"-
    55"-
    49"-
    40"-
    DX650
    55", 49",40"
    55" - Game mode
    49" - Game mode
    40" - Game mode
    2x10 Watt RMS
    Dolby Digital Plus
    No DTS
    Quad Core
    1 x Ethernet RJ45
    1 x HDMI 1.4 (CEC)
    1 x AV Composite in
    1 x AV Component in
    1 x 3.5mm Audio Out
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Wi-Fi Direct
    DVB-T/T2/C
    Analog (PAL,SECAM)
    DX650
    DX600
    TX-55DX600E
    TX-55DX603E
    TX-55DXW604
    TX-55DXU601
    TX-49DX600E
    TX-49DX603E
    TX-49DXU601
    TX-49DXW604
    TX-40DX600E
    TX-40DX603E
    TX-40DXW604
    TX-40DXU601
    49" - max...cd/m2
    40" - max...cd/m2
    No
    40" - Edge Led
    55"- DCI P3 -
    49"- DCI P3 -
    40"- DCI P3 -
    55"-
    49"-
    40"-
    55"- 78° (cone)
    49"-
    40"-
    DX600
    55", 49", 40"
    55" - Game mode
    49" - Game mode
    40" - Game mode
    2x10 Watt RMS
    Compatible
    Dolby Digital Plus
    No DTS
    Chassis
    Firefox 2.5
    1 x Ethernet RJ45
    1 x HDMI 1.4 (CEC)
    1 x AV Composite in
    1 x AV Component in
    1 x 3.5mm Audio Out
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    Wi-Fi Direct
    DVB-T/T2/C
    Analog (PAL,SECAM)
    DX600
    Series
    Model
    ________________
    ________
    Dolby Vision(2)
    ____
    HDR 10
    ________________
    In Windows
    2/5/10/20/100%
    Videopanel
    Type LCD matrix,
    Bits of color,
    Curvature,
    Index,
    Screen Uniformity
    Backlight
    Type backlight
    Type LED
    MEMC
    Backlight Scanning
    Color Space
    ___________________
    Viewing angle
    _______________
    ( ° cone)
    Motion resolution
    Product
    _____________
    Input Lag
    Audio
    SoCCPUGPUSoftwareOS
    Networks
    ____________
    Conectors
    Tuners
    ______________
    Note
    Pros & Cont
    Product
    #225
    трейлинг/смиринг
    При нормално гледане е слабо забележим
    Известни бъгове при DX900:
    1. Загуба на звук при преглед на Netflix и Amazon Video чрез HDMI и оптика (стерео нормално)
    2. 3D в някои модели блу-рей - има проблем с предният и заден план. Препоръчва се UB900
    На 5:28 (същият проблем при Сони):
    3. Локалното затъмняване се изключва в 3D режим.
    4. Повече хостинг при гледане с оригиналните очила. При използване очила от други производители е по-добре.
    5. Трейлинг на черното в редки сцени (нинджа-весла)- включването на IFC само влошава нещата
    6. В HDR в среден и максимален режим се вижда работата на адаптивната подсветка с невъоръжено око. Локалното затъмняване е прекалено агресивно.
    7. Задръжка на звука при неговото изпращане от HDMI на оптика.
    8. Лагва видео през USB.
    DX900 и шаманските очила:
    Този пост е редактиран от hristoslav2; 24-08-16 в 10:20.
  1. Panasonic Plasma телевизори - част 4
    От hristoslav2 във форум Panasonic телевизори
    Отговори: 1725
    Последно: 01-10-23, 23:58
  2. Избор на климатик 2016 г.
    Отговори: 3492
    Последно: 01-01-17, 17:50
  3. Квалификации Евро 2016
    От iihtiandar във форум Спорт
    Последно: 10-06-16, 08:03
  4. Panasonic телевизори 2015
    Отговори: 677
    Последно: 02-01-16, 07:49
  5. Отговори: 0
    Последно: 02-03-12, 10:17
