Резултати от 1 до 15 от общо 44
Heroes Of Might And Magic V :) излезеee :P
    Mar 2005
    ЦЪК за торентче от арената :P и да не ви е шубе ей вече няма начин как да ви се разбере айпито :P e почти но кой ще се занимава да ги записва от клиента всичи айпита :P , но все пак има и други тракери така, че дърпайте от където ви дойде :P веднага като стана ще я инсталирам по описания начин и ще споделя дали има проблеми!
    ЦЪК за от чуждо тракечре :P
    [img width=424 height=600]*************************:8080/posters/11/45163.jpg[/img]
    G a m e N o t e s
    Heroes of Might and Magic V (C) Ubisoft
    Release Date : 05-09-2006 Protection : SecuROM
    Release Type : DVD Game Genre : Strategy
    Release Notes:
    The first game to reintroduce the video game legend to the public will
    be Heroes of Might and Magic V, the sequel to the universally acclaimed
    turn-based strategy series with a touch of RPG. The new opus will
    benefit from the features and characteristics that established the
    success of the initial saga while offering a wealth of innovations such
    as a a highly immersive scenario, a variety of appealing factions,
    modern 3D graphics, a revolutionary tactical combat system and a
    story-based campaign mode.
    Install Notes:
    1. Unpack the release with WinRAR or equivalent
    2. Burn in a120, burn with rmps checked, install DT4 with
    vdrives disabled, and enable rmps emulation in DT4.
    alternative option is mounting the image with Daemon-Tools
    with securom loader.
    3. Install
    4. Play
    Other Notes:
    You must be wondering what EMUDVD is, well EMUDVD stands for Emulation
    DVD, which is basically every dvd release out there that is mislabeled
    as "CLONEDVD." To burn a true clone of a game, the drive must have
    RAW DAO, regardless of the protection. RAW DAO only exists as a CD
    burning method. There is no such thing as DVD RAW DAO, and as a result,
    1:1 DVD clones do not exist. The only thing that can be burnt 1:1 and
    considered a true Clone, is a CDROM release. This is why CD-ROM Clones
    are still being released, despite being banned almost everywhere.
    You can still burn our release, but in order to run it you need an
    emulation program running in the background such as DT4's RMPS. You can
    also mount our release, but its still emulation. The Clone scene
    considers any release that requires a helper program that runs in the
    background to bypass the protection as emulation, and thus should be
    named properly as EMULATION. The *ONLY* possible exception to this rule
    is ATIP hiders.
    Enjoy HOMMV, brought to you first by Unleashed.
    :Super:
    Jan 2001
    Re: Heroes Of Might And Magic V :) излезеee :P
    мразим емулатори, мразим да mount-ваме, мразим да не е "оverwrite the original file with the file from directory /crack"
    сигурно до обяд ще излезе версия на RELOADED, така че...
    p.s. ааа, забравих да кажа, и че мразим да нарушаваме авторски права . ама как да не я пробваш, при положение, че при нас ще излезе сигурно след 6 месеца, докато се натуткат да преведат manual-a!?
    Jan 2005
    а изискванията към системата може ли да се видят някъде
  5. qni
    qni е офлайн
    Member Аватара на qni
    Mar 2002
    System Requirements:
    Supported OS: Windows® 2000/XP (only)
    Processor: Pentium® 4 or AMD AthlonTM 1.5 GHz (Pentium® 4 2.4 GHz recommended)
    RAM: 512 MB (1 GB recommended)
    Video Card: DirectX® 9 compliant w/ 64MB RAM (128 MB recommended)
    Sound Card: DirectX® 9 compliant
    DirectX Version: DirectX® 9 or higher (included on disc)
    DVD-ROM: 4X DVD-Rom or better
    Hard Drive Space: 2+ GB
    Multiplay: Broadband internet connection
    *Supported Video Cards at Time of Release
    NVIDIA® GeForce" 3/4/FX/6 families (GeForce 4 MX NOT supported)
    ATI® Radeon® 8500/9000/X families Matrox Parhelia"
    Laptop versions of these cards may work but are NOT supported.
    These chipsets are the only ones that will run this game. Additional chipsets may be supported after release. For an up-to-date list of supported chipsets, video cards, and operating systems, please visit the FAQ for this game on our support website at: http://support.ubi.com.
    източник хттп://ввв.уби.цом
    Mar 2005
    значи момчета подкарах играта... @FearMe с CureROM е много лесно... правиш си профил и след това той ти прави шорткът и само клик на него...
    значи на мен ми искаш играта и eдно .dll което се слага в WINDOWS! d3dx9_25.dll
    eто CureROM с който я подкарах!
    Приятна игра... но определено реснете PCто след инсталация и обработване с CureROM, защото, снощи не успя да тръгне, а сега като станах... оп
    и тази вече няма да се спи явно
    успех момчета!
  7. Super Moderator Аватара на FearMe
    Jan 2001
    razziel, не съм казал, че е трудно, а че не обичам емулатори, откачане на cd-та, blacklist-и на daemontools и затова използване на gamejack и т.н.
    което, реално погледнато, не пречи човек да се сдобие с това, а после да го "излекува", когато www.gamecopyworld.com или www.megagames.com (забележете не-български сайтове) се погрижат за това
    Feb 2006
    Точно сега ли трябваше....в тоя случай един изпит няма на взема....
    Mar 2005
    дам ето и кракчето вече от RELOADED :Super:
    Dec 2004
    Само лекарство от Reloaded - ЦЪК - чужд тракер
    Целия торент на Reloaded - ЦЪК - чужд тракер
  12. Super Moderator Аватара на FearMe
    Jan 2001
    след второто ниво мога да ви кажа само едно нещо - търсете ме някъде след средата на юни
    браво на руснаците!
    NIVAL и този път се показаха на ниво. не съм се и съмнявал, особено след Etherlords 2. явно преценката да им бъде възложен този култов проект е била правилна
    ужасно много съжалявам, че не съм обратно в гимназията или университета, че да имам времето, нужно да се потопя ( удавя ) в тази игра, както беше навремето
    и както LUDIA каза преди време - "ако играта е хубава, ще си я купя"
    някои неща наистина заслужават да бъде платено за тях.
    но за да бъда докрай честен, ще кажа, че ако има начин да се купи online, и по-голямата част от парите наистина да отиде при създателите, а не по джобовете на разни търгаши-вносители(дистрибутори), направете това
  13. Member Аватара на MoPcKu
    May 2003
    Бургас
    Размазването почна само дето има много малко сингъл карти, но се надявам до няколко седмици да излязт повече карти! А да питам някой направи ли мултиплеър и да каже как е?
    След първите 10тина часа играмога да кажа ,че играта е добра ,но само толкова .
    Х5 си е чист х3 + малко от вог и дисайпълс . Новата графика я признавам само дето играта е 1:1 с дисайпълс.
    Играх няколко часа и се усетих ,че вече не се чудя какво да правя ,а просто знам от старите части . За мен лично нововъведенията са много малки за да я нарекат нов хироус (изключвам графиката).
    Като фен на поредицата играл от х1 до х4 + двата дисайпълса Хироус5 не ми предлага нещо ново за съжаление. Надеждата ми е с експажъните да разбърнат потенциала на Нивал щото пичовете явно знаят за какво става дума .
  16. Super Moderator Аватара на FearMe
    Jan 2001
    zygot, ами то прекалените "нововъведения" обрекоха 4 на забвение. вярно, че не след 10-ия, а след 2-ия час вече се чувстваш "в свои води", но това е само за "старите кримки"
    нещото, което никога не съм харесвал на продълженията, е че се правят едва ли не само за фенове на предишните части - все по-усложнено, за все по-заклети фенове, които очакват нещо повече и нещо ново. нека сега започващите се чувстват и те комфортно. а за такива като теб и мен остава "impossible"-a
    аз пък мисля, че има доста сериозна разлика с 3. не по отношение на gameplay-я, а в "богатството" на гадинките. някои оригинални хрумки като "gating"-a на демоните, или магията за призоваване на готови войски от най-близкия град при хората страшно раздвижват играта. да не говорим за specialty на някои от гадинките... абе не е 1:1 копие на 3, каквото и да си говорим
    за красотата не говорим изобщо
    аз гласувам с 2 ръце за нея
    Feb 2006
    Има много общо с 3ката ама само хубавите неща...пипнали са тук и там за да е малко по раличен начина на игра...начина на придобиване на умения съвсем я променя...поне до колкото разпуцах демото...Мисля че играта е едно свежо продължение....ако не приличаше на 3ката щяха да я оплюват, както стана с 4ката...сега е просто нещо различно/ново и все пак познато, което ти прави удоволствие да играеш..
    Feb 2001
    Играя Heroes още от 2ката,тази версия е доста добра,а и има много нововъведения
    И бъгове......на некро мисията на 4тиа ден един идва отгоре развит до предел и те размазва,тва трябва да се пачне
    Другото нещо което е доста тъпо е че неможе да се напада директно героя
    Некрото мачка много здраво,ама много,с тия скелетончета си е направо IMBA,knight-овете да не говорим,с тия ъпгрейди на единиците,в същото време warlok-a доста слаб
  1. Отговори: 4
    Последно: 06-02-07, 17:26
  2. Heroes of Might and Magic V
    От dick във форум ИГРИ
    Последно: 14-01-04, 11:46
  3. IP Magic
    От X-RAY във форум Мрежи
    Последно: 06-12-02, 21:05
  4. IP Magic 2.5 ili 2.6 ima li niakoi?????
    От poznai във форум Мрежи
    Последно: 17-04-02, 19:14
