General
Complete name : Rammstein - Pussy Uncensored 2009 XXX 720p AVC AAC 2.0 - MiB.mp4
Format : MPEG-4
Format profile : Adobe Flash
Codec ID : f4v
File size : 28.4 MiB
Duration : 3mn 57s
Overall bit rate : 1 003 Kbps
Encoded date : UTC 2009-09-15 13:48:45
Tagged date : UTC 2009-09-15 13:48:45
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : Main@L4.0
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 3mn 57s
Bit rate mode : Variable
Bit rate : 898 Kbps
Width : 1 024 pixels
Height : 630 pixels
Display aspect ratio : 1.625
Frame rate mode : Constant
Frame rate : 25.000 fps
Standard : NTSC
Resolution : 8 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.056
Stream size : 25.4 MiB (90%)
Title : MainConcept
Language : English
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format version : Version 4
Format profile : LC
Format settings, SBR : No
Codec ID : 40
Duration : 3mn 57s
Bit rate mode : Constant
Bit rate : 96.0 Kbps
Channel(s) : 2 channels
Channel positions : L R
Sampling rate : 44.1 KHz
Resolution : 16 bits
Stream size : 2.72 MiB (10%)
Language : English
ей на това не ми тръгва звука. не разпознава кодека!
