Страница 1 от 61 1231151 ... ПоследноПоследно
Резултати от 1 до 15 от общо 908
Media Player - Zinwell (всички модели)
    Dec 2007
    ZINWELL ZP-500
    [img width=800 height=279]http://www.zintech.com.tw/uploads/product/ZP-500(1).jpg[/img]
    ZP-500 is a Networking High Definition multimedia player (up to 1080p) to enjoy the top quality home entertainment. It can playback the Multimedia in the external storage device through USB interface or through Networking. It is easy to connect to the TV and simple to use.
    Key Features:
    - Movie/Music/Photo multiple media formats playback on TV
    - HD (1080p) output
    - Photo slide show with background music
    - User friendly on screen display and operation
    - Easy to use File editing
    - Networking supports SAMBA client, UPnP
    - HDMI digital Audio/Video output, SPDIF digital Audio output
    [img width=558 height=600]http://www.brite-view.com/images/bv5005_specification.png[/img]
    Information on Max Bitrate
    Mpeg1: Ok / Max Pixel 720x576
    Mpeg2: Ok / Max Pixel 1920x1080p,Max bitrate 60m Bytes
    H.264: Ok / Max Pixel 1920x1080p,Max bitrate 40m Bytes
    RealVideo8/9/10: Ok / Max Pixel 1280x720p,Max bitrate 1m Bytes
    Xvid: Ok / Max Pixel 1920x1080p,Max bitrate 50m Bytes
    Divx3.x: Ok / Max Pixel 1920x1080p,Max bitrate 50m Bytes
    Divx4.x: Ok / Max Pixel 1920x1080p,Max bitrate 50m Bytes
    Divx5.x: Ok / Max Pixel 1920x1080p,Max bitrate 50m Bytes
    Divx6.x: Ok / Max Pixel 1920x1080p,Max bitrate 50m Bytes
    Vc-1/Wmv9: Ok / Max Pixel 1920x1080p,Max bitrate 40m Bytes
    WMV: Ok / Max Pixel 1920x1080p,Max bitrate 40m Bytes
    Mp3 Layer1: 8-48khz,32Kbps-448kbps
    Mp3 Layer2: 8-48khz,32Kbps-384kbps
    Mp3 Layer3: 8-48khz,32Kbps-320kbps
    Mpeg2.5: 8-48khz,32Kbps-160kbps
    Wma: 8-48khz,32Kbps-192kbps
    Pcm,Lpcm: 8-96khz,8/16/24 bit
    Pcm,Ima-Adpcm: 8-96khz,4 bit
    Pcm,Ms-Adpcm: 8-96khz,4 bit
    Pcm,A-Law: 8-96khz,8 bit
    Pcm,U-Law: 8-96khz,8 bit
    Ac3: 32/44.1/48khz
    Jpeg/Jpg Photos with resolutions up to 8000x8000
    Bmp Photos with resolutions up to 8000x8000
    Tiff Photos with resolutions up to 8000x8000
    Png Photos with resolutions up to 8000x8000
    Gif Photos with resolutions up to 8000x8000
    Notes
    Those media formats not indicated as "Supported Formats" cannot be guaranteed run properly on the player. For example, under "WMV", only "WMV9" is supported but not "WMV7/8".
    Media formats that can be supported but with limitation:
    -- M-JPEG:support up to 640x480x30p
    -- FLV(h.263): 352x288(maybe higher; no testing material to confirm)
    -- RMVB:support up to 720p
    -- The 7.1-channel surround sound can be decoded, but only downmixed and output to 2 channels.
    Media files protected by DRM are not supported with current software version.
    Only media files located on the USB storage device attached to the player can be added to the playlist. Users cannot add media files located on the remote PC or through UPnP support.
    Firmwares:
    Original
    All firms
    Cloning
    Astone
    Забелязах че в Метро са пуснали някакъв нов плеър Zinwell ZP-500, който поддържа май всичко необходимо.
    И то на доста добра цена - 202 лв с ДДС то.
    Ако някой има информация или отзиви за това нека да сподели!
    Този пост е редактиран от hristoslav2; 11-11-14 в 10:38.
  3. Banned
    Aug 2009
    Re:Имате ли информация за плеърите Zinwell ZP-500 ?
    Как да ти кажа , като цена WD TV , но като функции много по-добро.Made in Taiwan .
    May 2001
    Тъкмо щях да пускам и аз тема за тоя плеър.
    Ето брошурката от Метро.
  5. Banned
    Aug 2009
    Ако и подръжката на фирмуера е добра може да стане пазарен хит.Между другото това е най-евтиния мултимедия плеър от цялата серия на Zinwell.ZP -530 е с най-много възможности.
    Ходих до Метро да го видя.Симпатична малка черна пластмасова кутия с неголямо дистанционно управление.Излежда добре на външен вид с не лошо направено меню , което беше на руски в случая.
    Feb 2007
    От USB ли чете? Няма хард май. Лан вход ли има?
    Jul 2009
    Вчера си го купих от Метро и съм много доволен от факта,че не можах да намеря видео файл в компа си който да му се опъне ...
    May 2001
    nikolai64, ако имаш възможност, дай малко повече информация и някоя снимка - колко са големи субтитрите, на колко реда, пренася ли автоматично дългите редове.
    Благодаря предварително!
  10. Banned
    Aug 2009
    Като бях в Метро и видях , че субтитрите се регулират по височина и имаше избор на цвят и излизаха на 5-6 реда.
    Nov 2007
    Все пак не разбрах от външен хард ли чете или има място в плеъра.
    Nov 2008
    Цитат Първоначално публикувано от KumaLisko
    няма място в плеъра,без проблем чете от флаш и външен хард- 2,5" и 3.5" размери
    Nov 2001
    Съдейки по снимката май не поддържа ЛАН ( Вярно ли е ?
    May 2001
    Съдейски по снимката на гърба на плеъра, а и от линковете на elcos, ясно се вижда че Лан няма, има Ethernet RJ45.
    Защо не гледате преди да пълните темата с излишни въпроси? И на двете места се вижда че има лан, написано е и в спецификациите.
    Nov 2001
    Цитат Първоначално публикувано от Eddie
    Покорно благодаря за информацията!
    Бърррррррррр, тръпки ме побиха преди да се зарадвам, че поддържа ЛАН!
  17. Тук е от
    Jul 2009
    Има 5 размера на субовете и 6 цвята. Плейва всичко (с около 2 секундно зависване при пускане на видео с висока резолюция) ,но не насича и върви гладко . Много удобно меню и навигация.
  18. Banned
    Aug 2009
    Този плеър много прилича на един продукт на компанията Zinnet - Brite-view Cinema Tube BV-5005 HD .Няма как да бъде иначе понеже Zinnet е дъщерна компания на Zinwell - Taiwan.Двата продукта се различават по това , че usb входовете на Zinwell ZP-500 са отпред , а на другия отзад .
    http://www.brite-view.com/cinematube.php
    Има достатъчно данни за продукта за разлика от сайта на Zinwell .
  1. Media Player - Dune (всички модели)
    От hristoslav2 във форум Мултимедийни плейъри
    Отговори: 535
    Последно: 18-05-21, 07:33
  2. Media Player - Egreat (всички модели)
    От bradqzata във форум Мултимедийни плейъри
    Отговори: 50
    Последно: 21-02-19, 23:38
  3. Media Player - HiMedia (всички модели)
    От orlie във форум Мултимедийни плейъри
    Отговори: 99
    Последно: 17-12-17, 13:04
  4. Media Player - ASUS (всички модели)
    От yavor44 във форум Мултимедийни плейъри
    Отговори: 177
    Последно: 29-06-14, 18:15
  5. Media Player - Hyundai (всички модели)
    От myDiva във форум Мултимедийни плейъри
    Отговори: 508
    Последно: 29-03-14, 18:00
