Страница 9 от 34 ПърваПърва ... 789101119 ... ПоследноПоследно
Резултати от 121 до 135 от общо 509
Media Player - Hyundai (всички модели)
  1. Banned
    Feb 2008
    #121
    Re:Hyundai Light HMB-L110
    В крайна сметка потдържа или не ААС звук.
  3. Banned
    Aug 2009
    #122
    Колега , според мен това зависи от фирмуера , който му дава необходимите функции ! Различен софт - различни функции !
    Audio-Codecs : Dolby Digital, DTS, WMA, AAC, MP1, 2 und 3, LPCM, FLAC, Vorbis !
    Aug 2002
    #123
    Цитат Първоначално публикувано от petttto
    Поддържа лично го пробвах с няколко формата ето ги и тях:
    General
    Complete name : E:\Downloads\Avatar 2009 DVDScr H264 AAC-SecretMyth (Kingdom-Release)\Sample\Avatar sample.mp4
    Format : MPEG-4
    Format profile : Base Media
    Codec ID : isom
    File size : 17.8 MiB
    Duration : 1mn 9s
    Overall bit rate : 2 152 Kbps
    Encoded date : UTC 2010-02-07 13:19:02
    Tagged date : UTC 2010-02-07 13:19:02
    Video
    Format : AVC
    Format/Info : Advanced Video Codec
    Format profile : High@L4.1
    Format settings, CABAC : Yes
    Format settings, ReFrames : 8 frames
    Codec ID : avc1
    Codec ID/Info : Advanced Video Coding
    Duration : 1mn 9s
    Bit rate mode : Variable
    Bit rate : 1 750 Kbps
    Maximum bit rate : 5 147 Kbps
    Width : 720 pixels
    Height : 400 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 29.970 fps
    Resolution : 8 bits
    Colorimetry : 4:2:0
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.203
    Stream size : 16.3 MiB (92%)
    Encoded date : UTC 2010-02-05 09:02:31
    Tagged date : UTC 2010-02-07 13:19:03
    Audio
    Format : AAC
    Format/Info : Advanced Audio Codec
    Format version : Version 4
    Format profile : LC
    Format settings, SBR : No
    Codec ID : 40
    Duration : 1mn 9s
    Bit rate : 167 Kbps
    Nominal bit rate : 168 Kbps
    Maximum bit rate : 218 Kbps
    Channel(s) : 2 channels
    Channel positions : Front: L R
    Sampling rate : 48.0 KHz
    Stream size : 1.38 MiB (8%)
    Encoded date : UTC 2010-02-07 03:20:04
    General
    Complete name : E:\Downloads\La.Doublure.2006.BluRay.1080p.DTS.2Audio.x264-CHD\La.Doublure-SAMPLE.mkv
    Format : Matroska
    File size : 100 MiB
    Duration : 58s 934ms
    Overall bit rate : 14.3 Mbps
    Encoded date : UTC 2010-02-08 16:20:56
    Writing application : mkvmerge v2.5.2 ('Stranger in your Soul') built on Feb 28 2009 18:58:17
    Writing library : libebml v0.7.7 + libmatroska v0.8.1
    Video
    Format : AVC
    Format settings, ReFrames : 5 frames
    Muxing mode : Container profile=Unknown@4.1
    Codec ID : V_MPEG4/ISO/AVC
    Duration : 58s 875ms
    Bit rate : 11.0 Mbps
    Width : 1 920 pixels
    Height : 822 pixels
    Display aspect ratio : 2.35:1
    Frame rate : 23.976 fps
    Resolution : 8 bits
    Colorimetry : 4:2:0
    Bits/(Pixel*Frame) : 0.291
    Stream size : 77.2 MiB (77%)
    Title : La.Doublure.2006
    Language : French
    Audio #1
    Format : DTS
    Format/Info : Digital Theater Systems
    Codec ID : A_DTS
    Bit rate mode : Constant
    Bit rate : 1 510 Kbps
    Channel(s) : 6 channels
    Channel positions : Front: L C R, Side: L R, LFE
    Resolution : 24 bits
    Video delay : 65ms
    Stream size : 10.6 MiB (11%)
    Title : DTS-5.1CH 1536K
    Language : French
    Audio #2
    Format : DTS
    Codec ID : A_DTS
    Video delay : 65ms
    Language : Chinese
    General
    Complete name : E:\Downloads\The Twilight Saga New Moon 2009 BRRip H264 AAC-SecretMyth (Kingdom-Release)\Sample\Sample.mp4
    Format : MPEG-4
    Codec ID : isom
    File size : 26.9 MiB
    Duration : 43s 1ms
    Overall bit rate : 5 242 Kbps
    Encoded date : UTC 2010-03-06 19:55:09
    Tagged date : UTC 2010-03-06 19:55:09
    Video
    Format : AVC
    Codec ID : avc1
    Duration : 43s 1ms
    Bit rate : 1 948 Kbps
    Maximum bit rate : 19.3 Mbps
    Width : 1 264 pixels
    Height : 528 pixels
    Resolution : 8 bits
    Colorimetry : 4:2:0
    Bits/(Pixel*Frame) : 0.122
    Stream size : 25.4 MiB (94%)
    Encoded date : UTC 2010-03-05 17:12:19
    Audio
    Format : AAC
    Format profile : LC
    Codec ID : 40
    Duration : 42s 965ms
    Bit rate : 288 Kbps
    Maximum bit rate : 411 Kbps
    Stream size : 1.49 MiB (6%)
    Encoded date : UTC 2010-03-06 00:40:48
    General
    Complete name : E:\Downloads\Sample\Tina Turner-DTS5.1.wav
    Format : Wave
    File size : 43.9 MiB
    Duration : 4mn 20s
    Overall bit rate : 1 411.2 Kbps
    Audio
    Format : DTS
    Format profile : LE / 14
    Codec ID : 1
    Codec ID/Hint : Microsoft
    Duration : 4mn 20s
    Bit rate : 1 411.2 Kbps
    Sampling rate : 44.1 KHz
    Stream size : 43.9 MiB (100%)
    General
    Complete name : E:\Downloads\Sample\Valleys of Neptune FLAC.flac
    Format : FLAC
    Format/Info : Free Lossless Audio Codec
    File size : 26.1 MiB
    Duration : 3mn 56s
    Overall bit rate : 927 Kbps
    Album : Valleys of Neptune Promo
    Track name : Valleys of Neptune
    Track name/Position : 01
    Performer : Jimi Hendrix
    Genre : Rock
    Recorded date : 2010
    Audio
    Format : FLAC
    Duration : 3mn 56s
    Bit rate : 926 Kbps
    Resolution : 16 bits
    Stream size : 26.1 MiB (100%)
    Writing library : libFLAC 1.2.1 (UTC 2007-09-17)
    Това са част от нещата които пробвах имаше и доста други, нямах никакви проблеми с нито един от тях.
    С последния фирмуер (C507LP_1P00C_100224a_110HD.zip) е Hyundai-а на един приятел затова и аз си търся един защото останах доволен от всичко което ме интересуваше от такъв род устройство.
  5. Moderator
    Dec 2005
    #124
    Да попитам:
    1. Ако не е свързан донгъл към устройството и мрежата е по кабел - възможно ли е да се виждат и използват два различни HDD свързани към двата USB порта?
    2. Софтуерът поддържа ли опция за копиране на файлове между тези два HDD, когато са закачени към устройството?
    3. Някой успял ли е да изкара True HD от това устройство през HDMI?
    #125
    Да- HDD,свързани към двата USB порта се виждат и са активни.Копиране между двата HDD се поддържа софтуерно.
  7. Junior Member
    Apr 2004
    #126
    Цитат Първоначално публикувано от Miro1001
    Не може да е моно. Би трябвало да стане с кабела от камерата, ако е изправен. С втория кабел с два чинча ясно, че ще е само единия звуков канал.
    Вчера купих нов кабел - ОТ СКЪПИТЕ, иииии - О ЧУДО!!!
    Сега вече всичко е ОК. Много съм доволен.
  9. Banned
    Nov 2009
    Кестрич
    #127
    Днес си закупих Hyundai Light HMB-L110-свързах го към външен хард -плейъра се държи много добре с всички формати,които се сетих да му пусна-не успя да разчете само .flv,но това не е болка за умиралка купих си и Wireless usb adapter ,който по думите от опаковката е съвнестим с Hyunday m box l-110!Oбаче не мога да направя мрежа с въпросния адаптер-разпознава го ,намира ми нета -вкарвам паролата -открива ми и името на компа ,но когато кликна в/у него ми иска user id и парола!!Какво да правя?Помагайте,че ми е много мерак да си шерна нещата от лаптопа,без постоянно да закачам и откачам usb harda !
  10. Junior Member
    Aug 2002
    #128
    Цитат Първоначално публикувано от martosblack
    Здрасти, аз съм на Windows 7 64bit шернах си един дял от диска на PC-то като го направих така че да се чете и записва от всеки но пак ми искаше user и password за целта аз си създадох един потребител - media с парола - 1234 и готово защото нормалния ми всекидневен потребител е на кирилица а на медиа плеяра не може да се пише на кирилица.
  11. Banned
    Nov 2009
    Кестрич
    #129
    Привет -бЛагодаря за отговора VaskoD и аз съм с Уин 7 ,но 32бит.амии-шернах част от хард на компа си,но къде да сложа паролата и усера-хич не съм в час ВСЕ ИЗЛИЗА това пусто -ПАРОЛААА И НЕТ УЗЕР ИД
  12. Junior Member
    Aug 2002
    #130
    Здрасти, ами от конторл панела отиваш на акаунти и от там си създаваш нов user.
  13. Junior Member
    Apr 2004
    #131
    Абе аз май не разбрах данеби да ти иска парола мрежата (рутера).
    При XP няма такъв проблем. След като избрах мрежа ми поиска парола (тази за рутера). И после нищо повече. Виждам даже шернатите папки на некви дет са ми се закачили на мрежата (въпреки паролата)
    Май ще слагам защита по MAC - адрес.
  15. Banned
    Aug 2009
    #132
    Обикновено и на двете места иска парола - за wifi мрежата и за достъпа до съдържанието от компа !
  16. Junior Member
    Apr 2004
    #133
    Цитат Първоначално публикувано от bateradko
  17. Junior Member
    #134
    Пусни си Guest акуанта да ти е ON
  18. Banned
    Nov 2009
    Кестрич
    #135
    е Направих всичко това-пуснах guest aкаунта на ON,вкарах паролата за wi fi мрежата,на акаунта създадох нов user-WELL ,не се получава-родължава да си иска парола и user!!!Някакви други идеи?ме искам отново да си преинсталирам win 7-ta само защото не мога да направя мрежа
  1. Media Player - Dune (всички модели)
    От hristoslav2 във форум Мултимедийни плейъри
    Отговори: 535
    Последно: 18-05-21, 07:33
  2. Media Player - MiniX (всички модели)
    От z_harris във форум Мултимедийни плейъри
    Отговори: 53
    Последно: 19-03-21, 18:58
  3. Media Player - DIVA (всички модели)
    От kod във форум Мултимедийни плейъри
    Отговори: 2806
    Последно: 07-12-20, 20:35
  4. Media Player - Egreat (всички модели)
    От bradqzata във форум Мултимедийни плейъри
    Отговори: 50
    Последно: 21-02-19, 23:38
  5. Media Player - HiMedia (всички модели)
    От orlie във форум Мултимедийни плейъри
    Отговори: 99
    Последно: 17-12-17, 13:04
