Hell, благодаря за помощта! :bravo Успях да настроя Transmission Remote GUI да се връзва с дивата по интернет, аднах един торент 150 GB и дивата го свали без проблем! Много съм доволен! :Drinks:
някои 4увал ли е за EVOLVE Solaris с андроид ос предлага се в метро и дали неговият фриим става за дивата
@gogoniko - ...
https://www.youtube.com/watch?v=iO1RryjzwQE#ws
http://www.iboum.com/pr/evosol.php
Фърмуерът не става за Дива !Цитат:
Android (Operating System)
Players based on Google's Android Operating System began to appear in 2011. These players are essentially tablets without a screen and use exactly the same chipsets as found in many popular Android tablet PCs.
Processing power will vary between players but they will all be able to run Android 2.2 with Flash 10.1. This will give access to the full web and, we hope / presume, on-demand streaming services like iPlayer, Hulu. etc. An Android 'TV market place' is rumoured to be in development providing access to apps specifically for the TV Android platform.
Android based Media Players are all based on ARM chipsets, with the more powerful players all currently using chips with a Cortex A9 ARM core running at 800Mhz. The Cortex A8 (as used in the original iPad) is significantly slower at all clock speeds than the Cortex A9 (as used in iPad 2).
ARM chips are not specialist media playback chipsets. A lot of decoding will have to be done in software and there is not currently complete support in Android for all formats. Pure media playback performance in Android players will therefore be inferior to that in a player using a specialist Media Player chipset. By going for Android you lose in format support and decoding performance but gain in versatility (potentially many apps) and full web access. One day something like XMBC may exist for Android and Android Media Players will come to dominate, but this is a long way (years) off yet!
An interesting compromise solution comes with the Realtek 1186 chipset, which can dual boot into either the usual Media Player interface or Android 2.2. If the implementation of Android is done well then this solution could offer the best of both worlds and be a significant step forwards.
Android 2.1 / 2.2 / 2.3 are all designed for phones. This has caused problems even for 7" tablets, with Apps not working correctly on the larger screen. With a typical HDTV being 40" we see this as a big problem for Android based Media Players at this early stage. When Android versions designed for larger screens are made open source (3.x Honeycomb / 4.x Ice Cream Sandwich) these problems may be resolved and Android Media Player may have a firmer base.
@gogoniko и @JaneBB6 Сега реклама ли правите на това устройство във форума на Diva или :wink: Hell Ви пуска характеристики, видео. Това не е плеър базиран на процесора RealTek RTD1073DD... какъвто е на Diva-та знае се от 1-ви ред на 1-ва страница, така че няма как да се говори за съвместимост. Машинчето е с ARM Android OS (2011) базиран чипсет (може би Cortex A9 ARM или Cortex A8 ARM - CPU инфото е оскъдно) подобни на които слагат сега на смартфоните от по-висок клас. Така че може да се каже това са плеъри базирани на процесор за телефони и поставени в по голяма кутия :cheesy:(а тази кутия на този наистина мноого прилича на кутията на Diva HD :-memnon ). Но кутията си е кутия но вътре има съвсем друго, като важи и обратното различни кутии а пък вътре едно и също.
благодаря за отговора
Аз пак да попитам за код за универсално дистанционно за Дивата....Никой ли не знае?
@cochi75 - още в предния Ви пост на предната страница съм написал къде са кодовете и какво да направите, но ... друго е да пишем излишни постове и да не четем ... после защо темите били големи и трудно се намирала информацията в тях, а тук почти всичко е в 1-ви и 2-ри пост !!!
Здравейте, интересува ме този плейър може ли да записва от външен източник (примерно ТВ).
идеята ми е да си вземам сигнала от ТВ и да го записвам на Дивата - долу горе като едно време с видеокасетофон, който няма тунер.
Има ли такава възможност или ако не - знаете ли модел при който може така да се записва ?
благодаря предварително.
@renault_fen - погледни този плеър-рекордер, това е A.C. Ryan PlayON!DVR HD ACR-PV76120
Хайде и на мене честито:) Взех си го този плайер най-накрая! Въпроса ми е, нормално ли е торрент клиента да сваля с макс 300 kB/s?!?!?
Уп и давнлоад са сетнати на 0. Демек неограничено. От ПЦ-о свалям с 4МБ?!?! А и то е на wi-fi.
@4i4i -> Честито и добре дошъл във форума.
А кой торент клиент ползваш ? Препоръчително е да настроиш Трансмишъна, а преди това си сложи фърм 5992 ...
Ами да, май wi-fi капацитетът не е кой знае какъв :sad:
При мен е същото. Не съм пробвал как е с кабел, но и да пробвам - не ми върши работа. Дивата е твърде далеч от рутъра и е неудобно разположена за разпъване на кабели. Много се надявах на wi-fi антената, ама излезе бошлаф. Лошото е, че не е сменяема.
По LAN кабел transmission-a сваля с около 1 MB/s (стигало е до 1.4). Аз виждам друг проблем: "гигабитовия" адаптер не пропуска повече от 64Mbit/s. Друг с подобни наблюдения?
Нека и аз да кажа две-три думи. Адаптерът не е причината, може да имате проблеми с мрежата, по-специално с настройката на сигурността на WiFi-то на рутерите. Идеалният вариант е настройките да са без криптиране, само MAC Filtering (указвате само MAC адресите на безжичните ланове на устройствата, които да се свързват с рутера) и тогава можете да имате пълната скорост на безжичната мрежа. Ако ползвате криптиране, то трябва да е само комбинацията WPA2/WPA2 PSK + AES. Да не забравяме, че е препоръчително рутерът да е стандарт 11n (300Mbit), 2/3 антени и фул сигнал (най-много 1 панелна стена като преграда). При мен с гигабитови портове на рутера имам по лан средно около 106 Мбита (Samba), което не е лошо за начало. Предполагам, че ниската скорост е по вина на фърмовете и SDK-то :)
Благодаря Хелл:)Цитат:
Първоначално публикувано от Hell
Аз ползвам този който са го дали в опътването. Б торрент мисля. Плеъра ми е включен директно към рутера през лан.
Фърма ми е v9.5.42 r3758. със бутлоудера KIKG.0303.0017. За сега не смея и като чета май няма полза да ъпдейтвам фърма.
Ако някой може да ме светне как да подкарам Трансмишъна ще съм благодарен!
Cheers!
МОД: Изпълни съвета, които съм ти дал в горния цитат, защото има доста оправени неща в 5992, също така за улеснение инсталирай в Windows Transmission Remote GUI и готово. Ако искаш да го управляваш от друго място, това упътване ще ти помогне за настройките на рутера и Трансмишъна.
Супер си Хелл !!!
Ъпдейтнах на 5992, и торрента тръгна, и сваля с 2МБ:))
Да си жив и здрав:))
