ZINWELL ZP-500
[img width=800 height=279]http://www.zintech.com.tw/uploads/product/ZP-500(1).jpg[/img]
ZP-500 is a Networking High Definition multimedia player (up to 1080p) to enjoy the top quality home entertainment. It can playback the Multimedia in the external storage device through USB interface or through Networking. It is easy to connect to the TV and simple to use.
Key Features:
- Movie/Music/Photo multiple media formats playback on TV
- HD (1080p) output
- Photo slide show with background music
- User friendly on screen display and operation
- Easy to use File editing
- Networking supports SAMBA client, UPnP
- HDMI digital Audio/Video output, SPDIF digital Audio output
[img width=558 height=600]http://www.brite-view.com/images/bv5005_specification.png[/img]
Information on Max Bitrate
Mpeg1: Ok / Max Pixel 720x576
Mpeg2: Ok / Max Pixel 1920x1080p,Max bitrate 60m Bytes
H.264: Ok / Max Pixel 1920x1080p,Max bitrate 40m Bytes
RealVideo8/9/10: Ok / Max Pixel 1280x720p,Max bitrate 1m Bytes
Xvid: Ok / Max Pixel 1920x1080p,Max bitrate 50m Bytes
Divx3.x: Ok / Max Pixel 1920x1080p,Max bitrate 50m Bytes
Divx4.x: Ok / Max Pixel 1920x1080p,Max bitrate 50m Bytes
Divx5.x: Ok / Max Pixel 1920x1080p,Max bitrate 50m Bytes
Divx6.x: Ok / Max Pixel 1920x1080p,Max bitrate 50m Bytes
Vc-1/Wmv9: Ok / Max Pixel 1920x1080p,Max bitrate 40m Bytes
WMV: Ok / Max Pixel 1920x1080p,Max bitrate 40m Bytes
Mp3 Layer1: 8-48khz,32Kbps-448kbps
Mp3 Layer2: 8-48khz,32Kbps-384kbps
Mp3 Layer3: 8-48khz,32Kbps-320kbps
Mpeg2.5: 8-48khz,32Kbps-160kbps
Wma: 8-48khz,32Kbps-192kbps
Pcm,Lpcm: 8-96khz,8/16/24 bit
Pcm,Ima-Adpcm: 8-96khz,4 bit
Pcm,Ms-Adpcm: 8-96khz,4 bit
Pcm,A-Law: 8-96khz,8 bit
Pcm,U-Law: 8-96khz,8 bit
Ac3: 32/44.1/48khz
Jpeg/Jpg Photos with resolutions up to 8000x8000
Bmp Photos with resolutions up to 8000x8000
Tiff Photos with resolutions up to 8000x8000
Png Photos with resolutions up to 8000x8000
Gif Photos with resolutions up to 8000x8000
Notes
Those media formats not indicated as "Supported Formats" cannot be guaranteed run properly on the player. For example, under "WMV", only "WMV9" is supported but not "WMV7/8".
Media formats that can be supported but with limitation:
-- M-JPEG:support up to 640x480x30p
-- FLV(h.263): 352x288(maybe higher; no testing material to confirm)
-- RMVB:support up to 720p
-- The 7.1-channel surround sound can be decoded, but only downmixed and output to 2 channels.
Media files protected by DRM are not supported with current software version.
Only media files located on the USB storage device attached to the player can be added to the playlist. Users cannot add media files located on the remote PC or through UPnP support.
Firmwares:
Original
All firms
Cloning
Astone
Забелязах че в Метро са пуснали някакъв нов плеър Zinwell ZP-500, който поддържа май всичко необходимо.
И то на доста добра цена - 202 лв с ДДС то.
Ако някой има информация или отзиви за това нека да сподели!
 Новини
 Новини Форум
 Форум Актуално
 Актуално сървър
 сървър
  Отговор с цитат
  Отговор с цитат
 Първоначално публикувано от KumaLisko
 Първоначално публикувано от KumaLisko   ( Вярно ли е ?
( Вярно ли е ?
 Бърррррррррр, тръпки ме побиха преди да се зарадвам, че поддържа ЛАН!
