Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 02.11.2004 г. 12:54:32
NT-SPTI used
Nero Version: 6.6.1.15
Internal Version: 6, 6, 1, 15
Recorder:       <LITE-ON DVDRW LH-20A1S> Version: 9L02 - HA 1 TA 0 - 6.6.1.15
 Adapter driver:   <IDE>           HA 1
 Drive buffer :   2048kB
 Bus Type   :   via Inquiry data (1) -> ATAPI, detected: ?
 Connected to MMC as unknown drive with class-nr : 1
 Drive is autodetected - recorder class: Std. MMC recorder
CD-ROM:        <NO9803F RUE121N     >Version: 1.0 - HA 1 TA 1 - 6.6.1.15
 Adapter driver:   <SCSI>          HA 1
=== Scsi-Device-Map ===
DiskPeripheral    : HDS728040PLAT20         atapi Port 0 ID 0 DMA: On
CdRomPeripheral   : LITE-ON DVDRW LH-20A1S      atapi Port 2 ID 0 DMA: On
CdRomPeripheral   : NO9803F RUE121N     1.0  aotzwpqu Port 4 ID 0 DMA: Off
=== CDRom-Device-Map ===
LITE-ON DVDRW LH-20A1S   F:  CDRom0
NO9803F RUE121N      I:  CDRom1
AutoRun : 0
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
ShowDrvBufStat : 0
BUFE      : 0
Physical memory   : 1022MB (1047276kB)
Free physical memory: 634MB (649256kB)
Memory in use    : 38
Uncached PFiles: 0x0
Use Inquiry  : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
24.7.2007
ISO compilation
20:41:06	#1 Text 0 File SCSIPTICommands.cpp, Line 403
	LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
20:41:06	#2 Text 0 File Isodoc.cpp, Line 6494
	Iso document burn settings
	Determine maximum speed : FALSE
	Simulate        : FALSE
	Write          : TRUE
	Finalize CD       : TRUE
	Multisession      : FALSE
	Burning mode      : DAO
	Mode          : 1
	ISO Level        : 2 (Max. of 31 chars)
	Character set      : ISO 9660
	Joliet         : TRUE
	Allow pathdepth more than 8 directories : TRUE
	Allow more than 255 characters in path : TRUE
	Write ISO9660 ;1 file extensions    : TRUE
20:41:06	#3 ISO9660GEN -11 File geniso.cpp, Line 3312
	First writeable address = 0 (0x00000000)
20:41:06	#4 Text 0 File Burncd.cpp, Line 3316
	Turn on Disc-At-Once, using DVD media
20:41:06	#5 Text 0 File DlgWaitCD.cpp, Line 281
	Last possible write address on media: 2298495 (510:46.45, 4489MB)
	Last address to be written:      2290895 (509:05.20, 4474MB)
20:41:06	#6 Text 0 File DlgWaitCD.cpp, Line 293
	Write in overburning mode: NO (enabled: CD)
20:41:06	#7 Text 0 File DlgWaitCD.cpp, Line 2616
	Recorder: LITE-ON DVDRW LH-20A1S, Media type: DVD-R
	 Disc Manufacturer: MCC 03 - RG20
	 Disc Application Code: 64, Disc Physical Code: 193
20:41:06	#8 Text 0 File DlgWaitCD.cpp, Line 459
	>>> Protocol of DlgWaitCD activities: <<<
20:41:06	#9 Text 0 File ThreadedTransferInterface.cpp, Line 814
	Setup items (after recorder preparation)
	 0: TRM_DATA_MODE1 ()
	  2 indices, index0 (150) not provided
	  original disc pos #0 + 2290896 (2290896) = #2290896/509:5.21
	  relocatable, disc pos for caching/writing not required/ required
	  -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2290896 blocks [LITE-ON DVDRW LH-20A1S ]
20:41:06	#10 Text 0 File ThreadedTransferInterface.cpp, Line 1013
	Prepare recorder [LITE-ON DVDRW LH-20A1S] for write in CUE-sheet-DAO
	DAO infos:
	 MCN: ""
	 TOCType: 0x00; Session Closed, disc fixated
	 Tracks 1 to 1:
	  1: TRM_DATA_MODE1, 2048/0x00, FilePos       0       0  4691755008, ISRC ""
	DAO layout:
	 __Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep__________
	    0 | lead-in |  0 |  0x41 | 0x00
	    0 |    1 |  0 |  0x41 | 0x00
	    0 |    1 |  1 |  0x41 | 0x00
	 2290896 | lead-out |  1 |  0x41 | 0x00
20:41:06	#11 Text 0 File SCSIPTICommands.cpp, Line 208
	SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME
20:41:06	#12 Phase 24 File dlgbrnst.cpp, Line 1685
	Caching of files started
20:41:07	#13 Text 0 File Burncd.cpp, Line 4158
	Cache writing successful.
20:41:07	#14 Phase 25 File dlgbrnst.cpp, Line 1685
	Caching of files completed
20:41:07	#15 Phase 36 File dlgbrnst.cpp, Line 1685
	Burn process started at 8x (11 080 KB/s)
20:41:07	#16 Text 0 File ThreadedTransferInterface.cpp, Line 2717
	Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
20:41:07	#17 Text 0 File DVDR.cpp, Line 2846
	Recording mode: Sequential Recording Mode
20:41:07	#18 Text 0 File DVDR.cpp, Line 3002
	Start write address at LBA 0
	DVD high compatibility mode: Yes
20:41:07	#19 Text 0 File Cdrdrv.cpp, Line 8737
	---- DVD Structure: Physical Format Information (00h) ----
	Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
	 Book Type: DVD-R  (2), Part Version: 2.0x (5), Extended Part Version: 2.1 (33)
	 Disc Size: 120 mm,   Maximum Rate: <not specified> (F h)
	 Number of Layers: 1,  Track Path: Parallel Track Path (PTP), Layer Type: recordable
	 Linear Density:     0,267 um/bit, Track Density: 0,74 um/track
	 Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
	 End Physical Sector Number of Data Area:   26127F h
	 End Sector Number in Layer 0:         0 h (LBN: FFFD0000 h, 4193920 MB)
	 Data in Burst Cutting Area (BCA) does not exist
	 Start sector number of the current Border-Out: 0 h
	 Start sector number of the next Border-In:   0 h
	 Media Specific [16..63]:
	   00 60 00 10 20 30 40 50 - 00 00 00 21 00 00 00 00  .`...0@P...!....
	   00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00  ................
20:41:38	#20 Text 0 File Cdrdrv.cpp, Line 1224
	20:41:38.234 - F: LITE-ON DVDRW LH-20A1S : Queue again later
20:44:06	#21 SPTI -1135 File SCSIPassThrough.cpp, Line 178
	CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1135)
	Sense Key: 0x03 (KEY_MEDIUM_ERROR)
	Sense Code: 0x0C
	Sense Qual: 0x00
	CDB Data:  0x2A 00 00 07 CE 80 00 00 20 00 00 00
	Sense Area: 0x70 00 03 00 00 00 00 0A 00 00 00 00 0C
	Buffer x00000000: Len x10000
	0xD0 E7 DE 04 51 05 91 7C 78 07 96 02 6D 05 91 7C
	0x01 00 00 00 B8 ED 96 02 78 4C 96 02 38 00 00 00
	0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
20:44:06	#22 CDR -1135 File Writer.cpp, Line 281
	Write error
20:44:06	#23 Text 0 File DVDR.cpp, Line 3246
	EndDAO: Last written address was 511615
20:44:06	#24 Phase 38 File dlgbrnst.cpp, Line 1685
	Burn process failed at 8x (11 080 KB/s)
20:44:06	#25 Text 0 File SCSIPTICommands.cpp, Line 253
	SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
20:44:06	#26 Text 0 File Cdrdrv.cpp, Line 9945
	DriveLocker: UnLockVolume completed
20:44:06	#27 Text 0 File SCSIPTICommands.cpp, Line 403
	UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
Existing drivers:
File 'Drivers\scsiport.sys': Ver=5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), size=96256 bytes, created 03.8.2004 г. 21:59:42 (Adapter driver for src)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
====== *** Nero-Burning Rom, History File *** ======
