Страница 1 от 5 123 ... ПоследноПоследно
Резултати от 1 до 15 от общо 65
Hiren's BootCD X.x
    Dec 2001
    Hiren's BootCD X.x
    Пръкна се нова версия на Hiren's BootCD []
    Код:
    Hiren's BootCD 7.0 - All in one Dos Bootable CD which has all these utilities.
    Partition Tools:
    -Partition Magic Pro 8.05 - Best software to partition hard drive
    -Paragon Partition Manager 6.1.571 - Universal tool for partitions
    -Partition Commander 8.01 - The safe way to partition your hard drive,with undo feature
    -Ranish Partition Manager 2.44 - a boot manager and hard disk partitioner.
    -The Partition Resizer v1.3.4 - move and resize your partitions in one step and more.
    -Smart Fdisk 2.05- a simple harddisk partition manager
    - SPecial Fdisk - SPFDISK a partition tool.
    - eXtended Fdisk - XFDISK allows easy partition creation and edition
    Disk Clone Tools:
    -Drive Image 2002 - Best software to clone hard drive
    -Norton Ghost 8.0 - Similar to Drive Image
    -Partition Saver 2.80 - A tool to backup/restore partitions.
    Antivirus Tools:
    -F-Prot Antivirus 3.16b - Very good virus scanner (with ntfs support and easy to use menu)
    -McAfee Antivirus 4.40 - a virus scanner (with ntfs support and easy to use menu)
    Recovery Tools:
    -Active Password Changer 2.1 - To Reset User Password on windows NT/2000/XP/2003 (FAT/NTFS)
    -Offline NT/2K/XP Password Changer - utility to reset windows nt/2000/xp administrator/user password.
    -Active Partition Recovery 3.0 - To Recover a Deleted partition.
    -Active Uneraser 3.0 - To recover deleted files and folders on FAT and NTFS systems.
    -Ontrack Easy Recovery Pro 6.04 - To Recover data that has been deleted/virus attack
    -Winternals Disk Commander 1.1 - more than just a standard deleted-file recovery utility
    -TestDisk 5.8 - Tool to check and undelete partition.
    -Lost & Found 1.06 - a good old data recovery software.
    Testing Tools:
    -DocMemory 2.2b - RAM Test utility
    -GoldMemory 6.64 - RAM Test utility
    -Memtest86+ 1.55 - PC Memory Test
    -System Speed Test 4.78 - it tests CPU, harddrive, ect.
    -PC-Check 5.50 - Easy to use hardware tests
    -The Troubleshooter 7.02 - all kind of hardware testing tool
    -PC Doctor 3.0 - a benchmarking and information tool
    -Test Cpu/Video/Disk 5.6 - a tool to test cpu, video, and disk
    Hard Disk Tools:
    -Hard Disk Diagnostic Utilities
    -Seagate Seatools Desktop Edition 2.10
    -Western Digital Diagnostics (DLGDIAG) 5.04c
    -Western Digital Data Lifeguard Tools
    -Maxtor PowerMax 4.21
    -Maxtor amset utility 4.0
    -Maxtor(or any Hdd) Low Level Formatter 1.1
    -Fujitsu HDD Diagnostic Tool 6.30
    -Fujitsu IDE Low Level Format 1.0
    -Samsung HDD Utility 1.25
    -Samsung Disk Diagnose (SHDIAG) 1.25
    -IBM/Hitachi Drive Fitness Test 4.04
    -IBM/Hitachi Feature Tool 1.80
    -MHDD 4.4
    -HDD Regenerator 1.51 - to recover a bad hard drive
    -Ontrack Disk Manager 9.57 - Disk Test/Format/Maintenance tool.
    -Norton Disk Doctor 2002 - a tool to repair a damaged disk, or to diagnose your hard drive.
    -Norton Disk Editor 2002 - a powerful disk editing, manual data recovery tool.
    -Active Kill Disk 1.1 - Securely overwrites and destroys all data on physical drive.
    -SmartUDM 2.00 - Hard Disk Drive S.M.A.R.T. Viewer.
    System Information Tools:
    -Aida16 2.12 - a system information tool, extracts details of all components of the PC
    -PCI and AGP info Tool - The PCI System information & Exploration tool.
    -System Analyser version 5.3h - View extensive information about your hardware
    -Navrбtil Software System Information 0.58.6 - High-end professional system information tool
    -Astra 5.1 - Advanced System info Tool and Reporting Assistant
    -HwInfo 4.96 - a powerful system information utility
    -PC-Config 9.33 - Complete hardware detection of your computer
    -SysChk 2.46 - Find out exactly what is under the hood of your PC
    Dos File Managers:
    -Volkov Commander 4.99 - Dos File Manager with LongFileName/ntfs support (Similar to Norton Commander)
    -Dos Command Center 5.1 - Classic dos-based file manager.
    -File Wizard 1.35 - a file manager - colored files, drag and drop copy, move, delete etc.
    -File Maven 3.5 - an advanced Dos file manager with high speed PC-to-PC file transfers via serial or parallel cable
    -FastLynx 2.0 - Dos file manager with Pc to Pc file transfer capability
    -LapLink 5.0 - the smart way to transfer files and directories between PCs.
    -Mini Windows 3.11 - Back to old days, use it as a file manager
    -Mini Windows 98 - Can run from Hard Drive/ Ram Drive, Added 7-Zip which supports .7z .zip .cab .rar .arj .gzip, .bzip2 .z .tar .cpio .rpm and .deb, Disk Defragmenter, Notepad / RichText Editor, Image Viewer, .avi .mpg .divx .xvid Movie Player, etc...
    Other Tools:
    -DosCDroast beta 2 - Dos CD Burning Tools
    -Ontrack Data Advisor 5.0 - Powerful diagnostic tool for assessing the condition of your computer
    -Bootmagic 8.0 - This tool is for multi boot operating systems
    -Picture Viewer 1.94 - Picture viewer for dos, supports more then 40 filetypes.
    -QuickView Pro 2.54 - movie viewer for dos, supports many format including divx.
    -MpxPlay 1.15 - a small Music Player for dos.
    -Universal TCP/IP Network 5.2 - MSDOS Network Client to connect via TCP/IP to a Microsoft based network. The network can either be a peer-to-peer or a server based network, it contains 85 different network card drivers
    Dos Tools:
    -NTFS Dos Pro 5.0 - To access ntfs partitions from Dos
    -USB CD-Rom Driver 1 - Standard usb_cd.sys driver for cd drive
    -Universal USB Driver 2 - Panasonic v2.20 ASPI Manager for USB mass storage
    -Interlnk support at COM1 - To access another computer from COM port
    -Interlnk support at LPT1 - To access another computer from LPT port
    Windows Tools:
    -SpaceMonger 1.4 - keeping track of the free space on your computer
    -Drive Temperature 1.0 - Hard Disk Drive temperature meter
    -Disk Speed1.0 - Hard Disk Drive Speed Testing Tool
    -MemTest 1.0 - a Memory Testing Tool
    -PageDfrg 2.3 - System file Defragmenter For NT/2k/XP
    -Split Join 1.3.3 - a Small File Split-Join Tool
    -Ghost Image Explorer 7.0 - to add/remove/extract files from Ghost image file
    -DriveImage Explorer 5.0 - to add/remove/extract files from Drive image file
    -Active Undelete 5.0 - a tool to recover deleted files
    -Restoration 2.5.14 - a tool to recover deleted files
    -Startup Control Panel 2.8 - a tool to edit startup programs
    -Startup Monitor 1.02 - a tool that notifies you when any program registers itself to run at system startup
    -IB Process Manager 1.02 - a little process manager for 9x/2k, shows dll info etc.
    -HijackThis 1.99 - a general homepage hijackers detector and remover and more.
    -TCPView 2.40 - a detailed listings of all TCP and UDP endpoints
    -Unknown Devices 1.2 - helps you find what those unknown devices in Device Manager really are.
    -PCI 32 Sniffer 1.1 - device information tool (similar to unknown devices).
    -Ad-Aware SE Personal 1.06 - find and remove spyware, adware, dialers etc. (a must have tool)
    <u><b>Download</b></u>
  3. Senior Member Аватара на ru-boy
    Jan 2000
    Re: Hiren's BootCD X.x
    браво, браво, това най-новата версия ли е?
  4. Senior Member Аватара на glarus
    Aug 2003
    някой не го ли е изтеглил вече, че този site е ужасен за не знам кой път ме реже вече
  5. Junior Member
    Aug 2003
    Виж тук http://store3.data.bg/licenseduser/Hiren's.BootCD.7.0/
    Но не знам дали е работещо не съм го провал.
    <font color="purple">Не точно offtopic:</font id="purple"> А какво стана със Setcom's BOOT CD ? Мисля си, че предстоящата сбирка е нелош момент за разпространението му, ако има напредък по въпроса.
    May 2004
    Свалил съм .ISO-файла на 7-мицата, но ще го тествам най-рано към средата на другата седмица, когато си обновявам програмките и антивирусните дефиниции на MiniCD-то, което засега е все още с Launcher: Hiren's BootCD 6.0.
    <u><font color="red">Добавено:</font id="red"></u>
    Определено Бай ви <font color="purple">Hiren</font id="purple"> се грижи за BootCD-то си [<font color="green">HBCD</font id="green">]. В тази <font color="green">7-ма версия</font id="green"> има доста приятни изненадки. Например, "излекувана" версия 1.51 на програмката <font color="red">"HDD Regenerator"</font id="red">, която <font color="purple">Dockera</font id="purple"> представи неотдавна в новините на <font color="purple">SetCom</font id="purple"> и която иначе струва скромните... $ 60. []
    От новите неща, които видях [да, видях, защото предпочитам да видя, а не да вярвам сляпо на описанията в съдържанието], повечето от които по-нови версии на програмките от старите CD's, имаше един <font color="red">"Picture Viewer"</font id="red"> [под <font color="blue">DOS</font id="blue">] и един <font color="red">"Music Player"</font id="red"> [който така и не успях да подкарам, тъй като CD-то нещо не детектна саунд-картата ми в <font color="blue">DOS</font id="blue">-среда]. Това е бял кахър, важното е, че го има и че евентуално е тестван и работи, щом е там. А както знаем, съвсем по български - "от имане, глава не боли". []
    Обновени са и "енджините" на двете антивирусни програми: <font color="red">"F-Prot"</font id="red"> - до версия 3.16b [в <font color="green">HBCD 6.0</font id="green"> беше 3.14] и <font color="red">"McAfee"</font id="red"> - до версия 4.40 [в <font color="green">HBCD 6.0</font id="green"> беше 4.32]. Както знаете, новите дефиниции, може да си ги добавяте "ръчно" в директорията <font color="blue">"Vdefs"</font id="blue"> на CD-то и това ви гарантира да си джиткате със съвсем прясна база, "лицензирани" на всичкото отгоре, антивирусни програми, по всяко едно време и да лекувате заразени компютри "на крак". []
    "Хитът", така да се каже, при версия <font color="green">6.0</font id="green">, се намираше в менюто "File Menagers" и се наричаше простичко <font color="red">"Mini Windows 3.11"</font id="red"> - носталгичен подарък за всички почитатели на <font color="purple">Чичко Бил</font id="purple">.
    Е, това не е всичко. В тази версия на CD-то, освен гореспоменатата антична ОС, имаме вече и <font color="red">"Mini Windows 98"</font id="red"> [дооооста орязан, но пък нали и затова е именно "Mini Edition"], което и оправдава нарастването размера на ISO-файла до почти 50 МВ.
    Ами освен да си пожелаем в следващата версия да има и <font color="red">"Mini Windows XP"</font id="red">, какво друго? []
    Общият брой на програмите надхвърля 60, включително двете ОС и няколко "shells" [от които най-вече изпъква по-малкото братче на <font color="red">"Norton Commander"</font id="red"> - <font color="red">"Volkov Commander"</font id="red">], което за размер от 50 МВ си е адски добро постижение.
    Пожелавам на <font color="purple">Hiren</font id="purple"> да се развива все така яко и занапред.
    Амин. []
  9. Senior Member Аватара на ru-boy
    Jan 2000
    <blockquote id="quote"><font size="1" id="quote"><b id="quote">quote:</b id="quote"></font id="quote"><table border="0" id="quote"><tr id="quote"><td class="quote" id="quote"><font size="1" id="quote"><font color="purple">Не точно offtopic:</font id="purple"> А какво стана със Setcom's BOOT CD ? Мисля си, че предстоящата сбирка е нелош момент за разпространението му, ако има напредък по въпроса.
    <div align="right">Originally posted by Slero - 02/07/2005 : 10:36:10</div id="right">
    </td id="quote"></tr id="quote"></table id="quote"></blockquote id="quote"><font size="2" id="quote"></font id="quote">Ще поработя по въпроса. Ще скалъпя нещо пък да видим, какво ще излезе.
    Dec 2001
    Нова версия - 7.4. За сваляне - тук и тук. Промените не ги знам още, по-късно ще ги видим
    добавено: Промених линка за сваляне.
  11. Senior Member Аватара на badr
    Aug 2004
    @bucho
    Линка не работи
  12. SAGE
    Guest
    Може да опитате от тук
    May 2004
    Свалих го още от първият линк на Bucho и се чудя какво ли допълнително има в него, че размера му е почти 6 МВ повече от HBCD 7.3 ...
    Скоро ще разбера.
  15. Member Аватара на daley
    Jun 2004
    Излезе пореднната 7.5 версия на Hiren's BootCD. Може да си я свалите от тук.
    Кратко описание на програмките вътре
    Hiren's BootCD 7.5
    Partition ToolsPartition Magic Pro 8.05
    Acronis Disk Director Suite 9.0
    Popular disk management functions in a single suite
    Paragon Partition Manager 7.0.1057
    Partition Commander 9.01
    Smart Fdisk 2.05
    SPecial Fdisk 2000
    eXtended Fdisk 0.9.3
    GDisk 1.1.1
    Complete replacement for the DOS FDISK utility and more.
    Disk Clone ToolsImageCenter 5.6 (Drive Image 2002)
    Norton Ghost 8.2
    Similar to Drive Image (with usb/scsi support)
    Acronis True Image 8.0
    Create an exact disk image for complete system backup and disk cloning.
    Antivirus ToolsF-Prot Antivirus 3.16b
    Recovery ToolsActive Partition Recovery 3.0
    Active Uneraser 3.0
    Ontrack Easy Recovery Pro 6.10
    TestDisk 5.8
    Lost & Found 1.06
    DiyDataRecovery Diskpatch 2.1.100
    An excellent data recovery software.
    Prosoft Media Tools 5.0 v1.1.2.64
    Another excellent data recovery software with many other options.
    Testing ToolsSystem Speed Test 4.78
    PC-Check 5.50
    PC Doctor 3.0
    Test Hard Disk Drive 1.0
    a tool to test Hard Disk Drive
    RAM (Memory) Testing ToolsDocMemory 2.2b
    RAM Test utility
    GoldMemory 5.07
    RAM Test utility
    Memtest86+ 1.60
    PC Memory Test
    Hard Disk ToolsHard Disk Diagnostic Utilities
    Seagate Seatools Desktop Edition 3.02
    Samsung HDD Utility(HUTIL) 1.28
    Samsung Disk Diagnose (SHDIAG) 1.28
    Gateway GwScan 3.15
    MHDD 4.5
    SmartUDM 2.00
    System Information ToolsAida16 2.12
    System Analyser version 5.3j
    Navr&#225;til Software System Information 0.58.6
    Astra 5.10
    HwInfo 4.9.7
    PC-Config 9.33
    SysChk 2.46
    CPU Identification utility v1.8
    Detailed information on CPU
    CTIA CPU Information
    another CPU information tool
    MBR (Master Boot Record) ToolsMBR Work 1.07b
    a utility to perform some common and uncommon MBR functions
    MBR Tool 2.1.100
    backup, verify, restore, edit, refresh, remove, display, re-write...
    DiskMan4
    all in one tool for cmos, bios, bootrecord and more
    BootFix Utility
    Run this utility if you get ''Invalid system disk''
    MBR SAVE / RESTORE 2.1
    BootSave and BootRest tools to save / restore MBR
    Boot Partition 2.50
    add Partition in the Windows NT/2000/XP Multi-boot loader
    Partition Table Doctor 3.0
    a tool to repair/modify mbr, bootsector, partition table
    Smart Boot Manager 3.7.1
    a multi boot manager
    Bootmagic 8.0
    BIOS / CMOS ToolsCMOS 0.93
    CMOS Save / Restore Tool
    BIOS Cracker 4.6
    BIOS password remover (cmospwd)
    BIOS Cracker 1.4
    BIOS password remover (cmospwc)
    BIOS Utility 1.35.0
    BIOS Informations, password, beep codes and more.
    !BIOS 3.20
    a powerfull utility for bios and cmos
    DISKMAN4
    a powerful all in one utility
    UniFlash 1.40
    bios flash utility
    Kill CMOS
    a tiny utility to wipe cmos
    MultiMedia ToolsPicture Viewer 1.94
    QuickView Pro 2.54
    MpxPlay 1.15
    Password ToolsActive Password Changer 3.0
    NTPWD
    NTFS ToolsNTFS Dos Pro 5.0
    NTFS 4 Dos 1.4
    NTFS Dos 3.02
    EditBINI 1.01
    to Edit boot.ini on NTFS Partition
    Dos File ManagersVolkov Commander 4.99
    File Wizard 1.35
    File Maven 3.5
    FastLynx 2.0
    LapLink 5.0
    Mini Windows 3.11
    Mini Windows 98
    Can run from Ram Drive, with ntfs support,
    Other ToolsGhost Walker 2003.793
    utility that changes the security ID (SID) for Windows NT, 2000 and XP
    DosCDroast beta 2
    Universal TCP/IP Network 5.4
    Dos ToolsUSB CD-Rom Driver 1
    and too many great dos tools
    very good collection of dos utilities
    extract.exepkzip.exepkunzip.exeunrar.exerar...
    ToolsSpaceMonger 1.4
    Disk Speed1.0
    MemTest 1.0
    PageDfrg 2.3
    Split Join 1.3.3
    Drive SnapShot 1.36
    creates an exact Disk Image of your system into a file while windows is running.
    Active Undelete 5.0
    Restoration 2.5.14
    it notifies you when any program registers itself to run at system startup
    HijackThis 1.99
    CurrPort 1.07
    displays the list of all currently opened TCP and UDP ports on your computer
    Unknown Devices 1.2
    PCI 32 Sniffer 1.1
    NewSID 4.10
    Double Driver 1.0
    Driver Backup and Restore tool
    Sep 2003
    Цитат Първоначално публикувано от daley
    Излезе пореднната 7.5 версия...
    Какво е по различното или по-новото от 7.4, която между другото изтеглих едва преди 4-5 дни?
  17. TODD_BG
    Guest
    Излезе Hiren's BootCD 7.6 тази версия вклучва следното:
    Partition Tools
    Smart Fdisk 2.05
    SPecial Fdisk 2000
    GDisk 1.1.1
    Disk Clone Tools
    Norton Ghost 8.2
    Antivirus Tools
    Recovery Tools
    Active Uneraser 3.0
    TestDisk 6.2
    Lost & Found 1.06
    PhotoRec 6.2
    File and pictures recovery Tool.
    Testing Tools
    PC-Check 5.50
    PC Doctor 3.0
    DocMemory 2.2b
    RAM Test utility
    GoldMemory 5.07
    RAM Test utility
    Memtest86+ 1.65
    PC Memory Test
    Hard Disk Tools
    Samsung HDD Utility(HUTIL) 2.00
    Gateway GwScan 3.15
    MHDD 4.6
    HDAT2 4.02.05
    main function is testing and repair (regenerates) bad sectors for detected devices
    SmartUDM 2.00
    Aida16 2.12
    Astra 5.11
    HwInfo 4.9.7
    PC-Config 9.33
    SysChk 2.46
    MBR Work 1.07b
    MBR Tool 2.1.100
    DiskMan4
    BootFix Utility
    Run this utility if you get 'Invalid system disk'
    Boot Partition 2.50
    Bootmagic 8.0
    BIOS / CMOS Tools
    CMOS 0.93
    BIOS Cracker 4.6
    BIOS Cracker 1.4
    BIOS Utility 1.35.0
    !BIOS 3.20
    DISKMAN4
    UniFlash 1.40
    bios flash utility
    Kill CMOS
    MultiMedia Tools
    Picture Viewer 1.94
    QuickView Pro 2.56
    MpxPlay 1.53b
    Password Tools
    NTPWD
    Registry Viewer 4.2
    Registry Viewer/Editor for Win9x/Me/NT/2K/XP
    NTFS Tools
    NTFS Dos Pro 5.0
    NTFS 4 Dos 1.4
    NTFS Dos 3.02
    EditBINI 1.01
    Dos File Managers
    File Wizard 1.35
    File Maven 3.5
    FastLynx 2.0
    LapLink 5.0
    Dos Navigator 5.9.0
    Dos File Manager, Norton Commander clone but has much more features.
    Mini Windows 3.11
    Mini Windows 98
    Other Tools
    DosCDroast beta 2
    Dos Tools
    USB CD-Rom Driver 1
    extract.exe pkzip.exe pkunzip.exe unrar.exe rar.exe
    ace.exe lha.exe gzip.exe uharcd.exe mouse.com
    attrib.com deltree.exe xcopy.exe diskcopy.com imgExtrc.exe
    undelete.com edit.com fdisk.exe fdisk2.exe fdisk3.exe
    lf.exe delpart.exe wipe.com zap.com format.com
    move.exe more.com find.exe hex.exe debug.exe
    split.exe mem.exe mi.com sys.com smartdrv.exe
    xmsdsk.exe killer.exe share.exe scandisk.exe scanreg.exe
    guest.exe doskey.exe duse.exe biosdtct.exe setver.exe
    ntersvr.exe interlnk.exe loadlin.exe lfndos.exe doslfn.com
    Windows Tools
    SpaceMonger 1.4
    Disk Speed1.0
    MemTest 1.0
    PageDfrg 2.32
    Split Join 1.3.3
    Drive SnapShot 1.36
    Active Undelete 5.0
    Restoration 2.5.14
    HijackThis 1.99
    CurrPort 1.07
    Unknown Devices 1.2
    PCI 32 Sniffer 1.1
    NewSID 4.10
    Double Driver 1.0
    CPU-Z 1.31
    It gathers information on some of the main devices of your system
    Spybot - Search & Destroy 1.4
    Application to scan for spyware, adware, hijackers and other malicious software.
    Някой случайно да знае от каде може да се дръпне че аз не можах да намеря.
  18. Member Аватара на daley
    Jun 2004
    Цитат Първоначално публикувано от TODD_BG
    Аз си я дръпнах от DC++
  1. Hiren's Bootcd 9.9
    От stfn във форум Общ - софтуер
    Последно: 19-06-09, 18:06
  2. F-Prot от Hiren's BootCD не сканира всички файлове
    Последно: 06-07-07, 19:06
  3. Hiren's BootCD 7.9
    От ru-boy във форум Общ - софтуер
    Последно: 10-04-06, 10:04
  4. Как да оправя bad секторите с Hiren's BootCD?
    От kosbg във форум Общ - софтуер
    Последно: 23-12-05, 20:01
