Преди три дни си купих телевизор от същия сайт. Всичко около доставката беше наред, срока на доставка между 3 и 5 дни. Пратките се получават в Еконт, като имаш право на проверка преди да платиш.
Samsung UE65NU7455 vs Sony KD-65XF7596 vs Philips 65PUS7363 vs Panasonic TX-65FX700E vs LG 65SK7900
https://www.tek.no/artikler/samletes...s-tv-er/439093
превод
https://www.microsofttranslator.com/...tv-er%2F439093
LG 65SK7900
____________Panasonic TX-65FX700E
_____________________Philips 65PUS7363
________________Samsung UE65NU7455
_____________________Sony KD-65XF75
________________Put-away kindness Good. Please note that your feet are placed all the way out towards the sides of the TV, so it requires a table the size of the width of the screen. Tv has a stylish design with thin frames. Good. Smart option to choose whether to place the feet wide or narrow below the screen. Have the test smekreste and most trim look. Good. Philips stand out from the crowd with a hoop under the TV. Suitable for those who want a lighter TV, when the screen is aluminiumsfarget. Good. Have a resilient foot shaped like a V, which allows the monitor is safe and well against the substrate. Tv has a bit larger than several of the frames the competitors, but have a back side that stands out. Good. Also this model has feet that are position relatively far out to the sides. Otherwise fine design. Connectivity options Very good. Has four HDMI and network support. Good. Three HDMI ports and good network support. Very good. Four HDMI, as well as from network support. Good. Three HDMI ports, and good opportunities for networking. Very good. Four HDMI and good network support. Ease of use Very good. Well with the app. Convenient point function. Medium. To get apps. The remote control need a clear view to the TV to work. Good. Well with the app. Hang a little now and then. Plus for convenient remote control. Very good. Well with the app. Well functioning interaction between the remote control and the interface. Good. Well with the app. Get a little hiccup now and then. Inputlag (play mode) 33.9 ms 14.2 ms 31.4 ms 13.4 ms 31.7 ms Sound quality Poor. Pretty platt soundscape with the lack of bass. Poor. Completely fair to the news but not to film. Medium. Good sound quality with relatively much bass to a flat panel display to be. Medium. Clear and Nice on the speech. A little bass. Medium. Live well enough for the news. A little bass. Image quality Medium. In the HDR mode, go dimmingen bananas when we pull up the pointer. More "black crush" than the other in dark scenes. Good. Weak viewing angle. Struggling a bit too bright picture across the table.Otherwise good sharpness and movement. Good. The picture is characterised by too much light strength evenly across. Otherwise good sharpness and movement. Very good. Have good dynamics and details in the image. Good on movement and sharpness. Very good. Delivers about the same with Samsung on the dynamics and details. Also good on movement and sharpness. Price Cheaper than the other in the test. Put them in the middle of the Pack. As of this writing most expensive in the test. The test's second cheapest. In the middle of the tree in price.
Здавейте,
Аз повече нищо няма да си поръчам от https://edigital.bg/ . Първото и единствено нещо което си поръчах, а след 10-тия ден отмених поръчката е една проста машинка за подстригване (пишеше, че я имат в наличност https://edigital.bg/drugi-za-brsnene...igvane-p242733), доставката е за 6 дни. На 10-тия ден ми изпратиха писмо, че прогнозно ще бъде доставена след 14 дни, при което Аз много се ядосах и отмених поръчката.
Не съм доволен от услугите на търговеца.
Поздрaви,
nass
Привет Наско,
Преди време стартирах тема за машинки за подстригване която е на линка долу, а този подфорум е за телевизори - добре е да има ред...
https://forum.setcombg.com/%D0%B4%D1...%BD%D0%B5.html
препоръчвам ти два модела
https://www.philips.bg/c-p/HC7460_15...otorized-combs
и
https://www.panasonic.com/bg/consume...s/er-gc71.html
като Panasonic (и Brown) използват масло за смазване на ножчетата - има такова в комплекта
Днес ми се обадиха от магазина и казаха, че от производителя(LG) сам казали, че и да изпратят друг тв не е гаранция, че няма да има същия дефект. Дефакто всички от серията имали проблем с подсветката. Направо им го връщам и сменям марката. Тва е излагация тяхното....
Velimus
може да направите смяна за
https://edigital.bg/led-televizori/s...evizor-p563003 - 60/50Hz VA
SAMSUNG-UE-55NU7472 - 60/50Hz VA
SAMSUNG-UE-55MU8002 - 120/100Hz VA
Първата вечер след покупката го огледай за неравномерна подсветка.
https://www.flatpanelshd.com/news.ph...&id=1529316883
https://dot-color.com/2018/06/14/201...-a-difference/
https://www.rapidtvnews.com/20180617...#axzz5InNp4s1e
The Status of Wide Color Gamut UHDTVs.
http://multimedia.3m.com/mws/media/1...hite-paper.pdf
Добър избор, ще останеш доволен
Моля за помощ с избор на телевизор. Ще се гледа предимно кабелна (Мтел) + филми. За сега съм се спрял на следните 3 модела на Сони, като още не съм ходил да ги гледам на място:
SONY KD-55XE8096
SONY KD-49XF7596
SONY KD-49XE8005
Ако може да препоръчате нещо друго 49-55 инча до 1600лв.
Благодаря предварително.
Без да съм голям разбирач, ще ти кажа, че 8ма серия е по-добра от 7ма, а 9та - по-добра от 8ма. Също така можеш да разгледаш и тук -> https://www.rtings.com/
Philips 49PUS7503
Samsung 50MU6102
Sony 49XE7005
LG 49UJ701V
В момента Сонито е на 917 лева при унгарците, а Самсунга на 900 при румънците. Филипса го има за 1200, но знам, че е 100 херца. Иначе LG-то го имам в 43 в стаята и операционната му система е супер бърза и приятна. С мачове, обаче, не ми харесва как се справя, а аз предимно футбол гледам по телелевизията. Какво бихте взели на мое място ? Благодаря предварително !
49xe80
Още един глас за SONY XE8005 XE8077 няма мазане няма насичане на картината при футбол или бързи сцени.
