| Samsung European UHD TV 2016 |
Product ____________ | Certification UHD
Premium _________ | Dolby Vision _______ | HDR 10 ____________________ | Videopanel ____________________________________ Type LCD matrix,
Bits of color,
Operating frequency of T-Con board of the panel,
Curvature,
MEMC,
Index,
Anti-reflective filter | Backlight ______________________ Type backlight
(Local Dimming zone)
Type LED
Puls Wide Modulation | Color Space _____________________ DCI P3
Rec.2020 | Contrast
White & Black level ________________________ ANSI
With local dimming
Without local dimming | Viewing
angle ___________ | Input Lag _______________________ | SoC
CPU
GPU
Platform
OS
_____________ | Ports _____________________ | Networks _______________________ | Tuner _________________ | Picture Accuracy
Out-of-the-Box
(score out of 10)
_______________ | Product |
KS9500
(curved) 78", 65", 55" | Yes | No | 78" - max 1000cd/m² 65" - 10% window max - 1473cd/m2
100% window max - 615cd/m2 55" - max Yes HDR10
Delta E <1 of all levels of brightness | 78"- SVA, 10bit, 120/100Hz, Curvature 4200R 65"- SVA, 10bit, 120/100Hz, Curvature 4200R 55"- SVA, 10bit, 120/100Hz, Curvature 4200R BFI - Flashing Backlight (Led Clear Motion)
Picture Quality Index - 2700
Moth Eye (anti-reflective filter) | 78" - FALD, Direct Led 65" - FALD, 15x10 - 150 zones 55" - FALD, Direct Led Blue Leds with RG phosphorus
PWM Freq. - 120/400Hz | 78"- DCI P3 - 65"- DCI P3 - 96% / Rec.2020-72% 55"- DCI P3- 96% / Rec.2020- 72% Quantum Dots | 78" - 65" - SD - ANSI 3783:1 / 120cd/m2 / 0.014cd/m2
with local dimming - 8571cd/m2 / 0.001cd/m2 55" - | 78" - 65" - 60° (cone) 55" -
| 78" - Game mode 21ms / by default 65" - Game mode 20ms / 55" - Game mode 20ms /
ARMv7
Quad Core
1.2GHz 16_DTV_JazzM Tizen 2,4 OS | 2 x USB 2.0
1 x USB 3.1
1 x Ethernet RJ45
4 x HDMI 2.0 (ARC, CEC,MHL)
1 x Satelite In (Main: F-type female)
1 x Satelite In (Sub:F-type female)
1 x Optical Audio Out
1 x RS 232 C
1 x Antena (RF) (female) in One Connect 1 x USB
1 x Ethernet RJ45
1 x CI+ 1.3
1 x One Connect Port in TV | Lan - Ethernet RJ45
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Wi-Fi Direct, Screen Mirroring
Bluetooth
DLNA(RUI2.0/DTCP-IP/DMP/DMR/DMS) | Dual tuners
DVB -T/ T2/C/S/S2
with PVR and PIP function + Timeshift
DiSEqC version 1.0
Analog (PAL,SECAM)
HEVC
VP9 profile 2 | CMS
White balans | KS9500 |
KS9000
(curved) 78", 65", 55", 49" | Yes | No | 75" - max-1000cd/m2 65" - max-1197cd/m2/ SD- 460cd/m2 55" - max-1000cd/m 49" - max 520cd/m2 full display / 1550cd/m2 for 3 sekonds / Yes HDR1000 | 75"- SVA or AMVA, ? ,120/100Hz, 65"- SVA, 10bit, 120/100Hz, Curvature 4200R 55"- SVA, 10bit, 120/100Hz, Curvature 4200R 49"- SVA, 10bit, 120/100Hz, Curvature 3000R BFI - Flashing Backlight (Led Clear Motion)
Picture Quality Index - 2400
Moth Eye (anti-reflective filter) | 75" - 65" - Edge LED - below 55" - Edge Led
8 vertical columns of dimmable zones 49" - Edge Led Blue Leds with RG phosphorus PWM Freq,-120/100Hz | 75"- DCI P3 - 65"- DCI P3 - 55"- DCI P3- 96% / Rec.2020- 72% 49"- DCI P3- 96% / Rec.2020- 76% Quantum Dots | 75" - 65" - 55" - 2688:1 / 0.039cd/m2 49" - ANSI 2900:1 /
| 75" - 65" - 55" - 20° (cone) 49" -
| 75" - Game mode 21ms / by default - 65" - Game mode 20ms / by default - 55" - Game mode 20ms / by default - 49" - Game mode 20ms / by default -
ARMv7
Quad Core
1.2Ghz 16_DTV_JazzM Tizen 2,4 OS | 2 x USB 2.0
1 x USB 3.1
4 x HDMI 2.0 (ARC, CEC, MHL)
1 x RS 232 C
1 x CI+ 1.3
1 x Ethernet RJ45
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Bluetooth
DVB -T/ T2/C/S/S2
DiSEqC version 1.0
Analog (PAL,SECAM)
HEVC
VP9 profile 2 | Rec.2020 settings are not correct | KS9000 |
KS8000 75", 65", 55", 49" | Yes | No | 75" - max 65" - 10% window max 766cd/m2 55"- 2% window max 1410cd/m2
55"- 100% window max 490cd/m2 49" - max 1270cd/m2 /SD- 450cd/m2
The TV is able to maintain the maximum brightness for a short time, and after about 15 seconds it drops down to about 450cd/m2. Yes HDR1000 | 75"- SVA or AMVA, 10-bit , 120/100Hz 65"- SVA, 10bit, 120/100Hz 55"- SVA, 10bit, 120/100Hz 49"- SVA, 10bit, 120/100Hz BFI - Flashing Backlight (Led Clear Motion)
Picture Quality Index 2300
Moth Eye (anti-reflective filter) | 75" - Edge LED - below 65" - Edge Led 55"- 8 vertical columns of dimmable zones 49" - Edge Led Blue Leds with RG phosphorus PWM Freq,-120/100Hz | 75" - DCI P3 - 65" - DCI P3 - 55" - DCI P3- 93% / Rec.2020- 70% 49" - DCI P3 - Quantum Dots | 75" - 65" - 4018:1 / 0.034cd/m2 / 167cd/m2 55" - 6820:1 /0.014cd/m2 / 95.48cd/m2 49" - 4080:1 / 0.027cd/m2 /
| 75" - Game mode 20ms / by default - 120ms 65" - Game mode 20ms / by default - 120ms 55" - Game mode 20ms / by default - 49" - Game mode 21ms / by default - 120ms
ARMv7
Quad Core
1 x USB 3.1
1 x RS 232 C
1 x CI+ 1.3
1 x Ethernet RJ45
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Bluetooth
DVB -T/ T2/C/S/S2
with PVR and PIP function + Tmeshift
DiSEqC version 1.0
Analog (PAL,SECAM)
HEVC
VP9 profile 2 | | KS8000 |
