Според мен - всички търговци, които купуват от LG Electronics Magyar Kft
Analysis Ultra HD Blu-ray: dynamic ranges up to 4000 nits in HDR10!
Analyses Ultra HD Blu-ray : des gammes dynamiques jusqu’à 4000 nits en HDR10 ! | HDfever
Хубава статия.И накрая написано нещо и за ''китайските боклуци'' както много тука ги определят.Не с цел да възобновявам безсмислената дискусия,ама мисля е интересно за най-бедните в Европа:
Take the Hisense H65M7000: not anywhere near the UHD Premium specifications but a stunner nonetheless. In my imaginary scenario, this TV would not get an HDR rating of A+++, but it did well enough that I’m certain it deserves a B at the very least.
И още нещо интересно за Китай,макар да не е по темата:
Huawei отвътре: разказ за Китай, фокуса, целите и амбициите, Feature | HiComm
От другата година няма да можете да си купите Samsung 40", 60" с матрица Sharp. В Китай строят 4 фабрики 10.5-11G поколения.
TV panel supply chain in major reshuffle with Sharp set to stop shipments to Samsung
Foxconn и Sharp теряют крупнейшего покупателя ТВ-дисплеев
Foxconn и Sharp собираются наладить выпуск ТВ-панелей в Китае
http://www.digitimes.com/news/a20161214PD209.html
Four 10.5G, 11G TFT-LCD factories under construction, to be constructed in China
Rebecca Kuo, Tainan; Adam Hwang, DIGITIMES [Thursday 15 December 2016]
Sakai Display Product's (Sharp's subsidiary) 10G using 2,880mm by 3,130mm glass substrates) TFT-LCD factory in Japan is currently one of the highest generation plants but four 10.5G and 11G TFT-LCD factories are under construction or are planned in China, according to industry sources.
China-based BOE Technology is constructing a 10.5G TFT-LCD factory with monthly production capacity of 120,000 2,940mm by 3,370mm glass substrates that will start production in the first half of 2018, the sources said.
China Star Optoelectronics Technology will soon start construction of an 11G TFT-LCD factory with monthly production capacity of 60,000 2,940mm by 3,370mm glass substrates in the first phase and of 140,000 substrates eventually, and plans to kick off production in the first half of 2019.
HKC plans to construct an 11G TFT-LCD factory with monthly production capacity of 90,000 glass substrates at an investment of CNY40 billion (US$5.8 billion). The factory is expected to have an annual output of 8.64 million panels for total revenues of CNY22 billion. In addition, HKC will invest CNY5 billion to set up an annual production capacity of 5-10 million LCD TVs.
In addition, Taiwan-based Foxconn Electronics has become the majority shareholder of Sharp and the two companies will cooperate to construct a 10.5G or 11G TFT-LCD factory in Guangzhou City, southern China, with planned investment of over JPY800 billion (US$6.9 billion) and production planned to begin in 2019.
As 43- and 65-inch LCD TV panels are in short supply, the four 10.5G and 11G TFT-LCD factories are expected to focus on production of 43-, 65-, and 75-inch and above TV panels, the sources analyzed.
Currently, 43-inch LCD TV panels are produced mainly at 7.5G factories (using 1,950mm by 2,250mm glass substrates), the sources said. As 7.5G factory capacity is not enough to meet market demand, panel makers also use a multi-model glass process at 8.5G factories to simultaneously produce eight 43-inch LCD TV panels and eight 18.5- or 21.5-inch panels from a single 2,200mm by 2,500mm substrate, the sources indicated.
65-inch LCD TV panels are mainly produced at 6G factories, with a 1,500mm by 1,850mm glass substrate being cut into two panels. However, Samsung Display and LG Display use a multi-model glass process to simultaneously produce 65- and 32-inch LCD TV panels at their 8.5G factories.
10.5G or 11G factories enable production of 18 43-inch LCD TV panels or eight 65-inch units using 93% and 94% of a single substrate without using multi-model glass processing, the sources indicated. However, yield rates hinge on effective control of cutting such large glass substrates, the sources noted.
https://www.zora.bg/sony/kd49xd7005baep/33257 какво мислите за този телевизор.
iveto-може и за бъзици да съм станал вече, ама отговора ти сериозен ли е или не.Аз горе-долу разбрах че с моя бюджет от 1200-1300 ще трябва да направя компромиси,но ще се радвам да ми кажете с кое мога да направя компромис.Това е от мен.
благодаря ти hristoslav.
Когато купихме на колега ТВ го доставиха и на въпроса – Може ли да го пробваме – ни отговориха –Ако има проблем има срок за връщане . Добре че всичко беше ОК . При покупка на ТВ по интернет с доставка как трябва да се постъпи.
Ако държиш да го тестваш на място: - когато шофьора ти подаде товарителницата за подпис, казваш че отказваш да я разпишеш, докато не отвориш и тестваш. Ако ти прави проблем - му даваш 5 лв да изчака теста.
Philips TV Range 2017 year
2 x Oled series (вероятно POS902F, POS902S)
12 x UHD series (...PUS8xx2, PUS7xx2, PUS65x2)
10 x Ambilight series (9, 8, 7, 6)
3 x HDR perfect sets
HDR Compability for all 2017 UHD range
2 серии със саундбар в долната част - PUS6502 и PUS7002
https://www.youtube.com/watch?v=ZRrbv7lLn_E
По традиция, Филипс представят новата си гама през втората половина на Февруари....
РОЅ902F - Oled, UHD, HDR Perfect, Ambilight 3, Android OS
PUS8002 - UHD + HDR Perfect, Ambilight3, Android OS
PUS7002 - UHD + HDR+, Ambilight3, Android OS
PUS65x2 - UHD + HDR+, Ambilight3, Android OS
PUS6502 - UHD + HDR+, Ambilight2, Android OS
PFH5002 - FullHD, Smart TV
PFH4002 - FullHD
Стигнах до тук и искам вашата помощ.До това което изчетох стигнах до няколко неща-два вида матрици IPS i VA с панели 50-60 Херца и 100-120 Херца.Има тв с RGB и такива с WRGB само не разбрах при ЛГ ли има WRGВ или и при другите марки има такова изрязване на 4К.Операционните системи ги разбрах Андроид се използва от Сони и Филипс,докато ЛГ и Самсунг, както и Панасоник използват свои собствени такива.Стигам до използването на тв и работата му като 4К с клипове от yuo tube и други.И сега въпроса ми е от какво мога да се лиша за да си взема и аз телевизор до 1400 лв. Ше гледам мачове-всичките канали са ни FUH местната кабеларка има на Джазирата пакета както и на Руската нова,имаме 15 канала само футбол, ще гледам някой друг филм и клипове на 4К.Благодаря ви дано не втръсвам на някои колеги.
Здравейте, чудя се между тези 2-а модела кой е по-добър
самсунг UE-48J5600 или
LG 49UF640V
