Страница 46 от 79 ПърваПърва ... 36444546474856 ... ПоследноПоследно
Резултати от 676 до 690 от общо 1171
Like Tree214Одобрявам
    #676
    Отговор: LG телевизори (инфо на първа страница)
    bigchicken
    https://en.wikipedia.org/wiki/Infrared_blaster
    LG 65A2PUA review
    https://www.rtings.com/tv/reviews/lg/a2-oled
    #677
    G 65QNED866QA review
    https://fwd.nl/beeld/review-lg-65qne...ie-lcd-led-tv/
    ADS panel (like IPS):
    ANSI contrast is, as expected, relatively low, 1070:1.
    miniLED backlight increases the ANSI contrast to 2,286:1, and in some test patterns even to 11.700 :1.
    miniLED FALD LCD, 15x12: 180 local dimming zones
    100/120Hz + MCFI + мигаща подсветка при 60Hz.
    Color gamut coverage : 91% DCI-P3 and 68% Rec.2020
    a7 gen5
    Conclusion:
    The LG 65QNED866 (QNED866 series) seems to us well suited to do its job in an illuminated living room.
    After all, the ADS panel delivers only a modest contrast and the local dimming can only adjust that to a limited extent.
    In dark images you risk seeing zone boundaries or halos, which can occur in both HDR and SDR.
    The QNED technology mainly focuses on brightness and a wide colour range.
    In those categories, the device scores well.
    For sports or other clear images, you will certainly not be disappointed with the results.
    The wide viewing angle is a plus if you invite friends.
    The TV delivers excellent calibration and the Alpha 7 processor ensures clever image processing.
    For gaming, the QNED is also suitable with two HDMI 2.1 connections and good input lag.
    The powerful audio performance is a nice surprise.
    LG WebOS 22 has received some improvement with an update and is already in its second reorganization this year.
    The price seems to be slightly on the high side, there are a lot of competitors in this segment.
    Calibration settings :
    Picture mode: Filmmaker mode
    Aspect ratio setting: Original / Scanning: On
    Power Saving: Off
    Brightness:
    Panel Brightness: 100
    Contrast: 80
    Black Level: 50
    Autodynamic Contrast: Off
    Gamma: 2.2 / BT.1886
    Video Range: Car
    LED Local Dimming: Low
    Motion Eye Care: Off
    Color:
    Color Depth: 50
    Shade: 0
    Color Range: Auto
    White Balance Color Temperature: Warm50
    Purity:
    Sharpness: 10
    Super resolution: Low
    Noise Reduction: Low
    MPEG noise reduction: Low
    Smooth Gradation: Low-Middle
    Real Cinema: To
    TruMotion: Cinematic or Natural
    Motion Pro: Off
    LG 86UQ80009LB review
    https://hifi.de/test/lg-uq80-test-110371
    IPS panel
    Direct LED LCD, no local dimming
    100/120Hz + MCFI
    Color gamut coverage : 83% DCI-P3uv and 76% DCI-P3xy
    α7 gen5
    Assembled in Poland
    #678
    превод
    Тествах 77G2 през последните няколко седмици.
    И най-новата актуализация (03.20.40) донесе редица нови функции и корекции на грешки, които подобриха качеството на изображението в сравнение с времето, когато за първи път прегледах този модел в размер 65, преди около 4 месеца.
    1. (0:23) Кино режимът Dolby Vision (DV) вече е по-точен. Предишното проследяване на PQ EOTF в този режим преди каквото и да е калибриране беше значително по-ярко от референтния (0:29), което караше тоновете на кожата да изглеждат неестествени с по-измит външен вид като цяло. След инсталирането на най-новия фърмуер проследяването на PQ EOTF се доближи до референтния стандарт ST2084, което незабавно подобри разпределението на светлината и кинематографичното качество на изображението на DV в стандартен кино режим (0:48).
    2. (0:55) Новата функция DV Fine Detail вече е отключена и можете да намерите настройката в подменюто Clarity, докато възпроизвеждате DV съдържание.
    Пуристите обаче може да не намерят тази функция за полезна поради две причини:
    - Първо, настройката за фини детайли е сива (1:11) във всички предварително зададени DV изображения, с изключение на панела за домашно кино, който е част от DV IQ технологията който се стреми да компенсира околното осветление, което означава, че DV демонстрацията ще бъде по-ярка, особено в сцени с ниска осветеност, и също така ще се отклони от творческото намерение в най-строгия смисъл на думата.
    - (1:36) второ, привлекателните фини детайли ще причинят произволни мигащи артефакти по време на определени сцени в DV, особено в приложения за поточно предаване. Следователно чувствителните зрители вероятно ще предпочетат да деактивират тази настройка.
    3. (1:53) Подобрение #3. Преди това някои от OLED телевизорите на LG за 2022 г., включително нашата единица за преглед 77G2, показваха слабо сияние, когато екранът беше напълно изпълнен с черно, дори ако плъзгачът за ниво на черното беше настроен на 0, което може да се забележи в тъмна стая, особено когато зареждате диск (DVD плейър Oppo).
    Сега в новия фърмуер това е коригирано, така че черното вече не се повдига.
    4. (02:22) Подобрение #4. Многоточков баланс на бялото (WB).
    При предишни фърмуери долната половина на точките за настройка на WB липсваха в режим HDR10, независимо дали са 10 или 22 точки, но тази грешка е коригирана във фърмуер 03.20. Следователно собствениците ентусиасти вече могат ръчно да калибрират многоточковия WB във всички HDR10 режими на картина, като HDR режим или режим Filmmaker (FMM).
    В противен случай LG 77G2 има много от силните страни, които по-рано идентифицирахме в нашите ревюта на C2 и G2 тази година.
    Новият чипсет O22 (2:55), предлаган от LG като процесор Alpha9 Gen5, носи редица подобрения спрямо OLED телевизора от 2021 г. Например проследяването на почти черна гама е по-точно в сравнение с C1 и G1, изисквайки по-малко задържащи фактори, което води до по-чисти и по-точни детайли в сенките.
    Естествената 10-битова градация вече е по-плавна (3:17), особено забележима в режим на оптимизация на играта. При 4k 120Hz мащабирането е по-рязко от преди, от тази карта в SMPTE RP133 до 576i (3:27).
    (3:45) По-големият 77-инчов размер на екрана може да причини накъсване при 24p възпроизвеждане - да бъде по-очевидно, което подтиква някои собственици да използват TruMotion, за да изгладят накъсването. И добрата новина е, че тази година настройката за кинематографично движение на LG е допълнително подобрена, което води до по-малко артефакти на интерполация и следователно по-малко soe (ефект от сапунена опера) във 24p филми, отколкото при моделите от 2021 г.
    Алгоритъмът 2022 True Motion също така причинява по-малко микрозадействания по време на жестове с ръце и движение на главата в излъчвано съдържание от 50 Hz.
    Едно от уникалните предимства на OLED LG TV е калибрирането в 3D LUT с цел постигане на висока точност на цветовете. Наистина, след калибриране с помощта на Kalman Autocal, средната грешка Delta E беше по-малка от 0,5 на тази сложна диаграма на Color Checker за проверка на цветовете (4:41), където бяха измерени 140 области, което съответства на вярно възпроизвеждане на творческото намерение, когато се гледа реално съдържание.
    (по-нататък малко реклама на уебинар на монитори).
    (06:00) Ето някои резултати от 77G2, след калибриране до бяла точка D65:
    Пикова яркост при 10% прозорец - 900 нита
    100% - 170 нита.
    Цветово пространство DCI-P3 99%, BT020 - 76%. Това е нормално за WBE OLED панел като този на 77G2.
    (06:31) Равномерността на яркостта беше отлична за нашата извадка, без ефект на мръсен екран или огъване на сивите слайдове на цял екран. Но розовият нюанс отстрани на екрана, когато се гледа от ъгъл, макар и едва доловим, все още е там.
    Тъмната еднородност беше прилична, като се има предвид, че еднаквостта обикновено се превръща в проблем, особено при по-големи размери на екрана.
    Input lag 4k 60fps - 13ms, в режим оптимизация на играта пада до 9.4ms. При 1920x1080P 120 fps - 4.8 ms.
    (7:27) Избирането на HGIG все още ще доведе до леко недостатъчно проследяване на PQ EOTF, дори на най-новия фърмуер 3.20. Но можете да използвате функцията за зареждане на тонове, когато калибрирате играта (7:39), за да направите твърд клипинг(изрязване) и да симулирате HGIG.
    Функцията за зареждане на тонове не работи с оптимизацията на играта, когато прегледахме LG G2 в размер 65 преди няколко месеца, така че това е друго нещо, което LG коригира.
    Оценка:
    Като цяло LG 77G2 е най-добрият телевизор, който можете да закупите в размери от 75 до 77 инча през 2022 г. Защото дори най-добрите 75-инчови мини-LED телевизори все още страдат от колебаене на фоновото осветление и трептене поради липса на контрол на осветлението на ниво пиксел. А QD-OLED достигат едва 65 инча тази година.
    Всъщност най-тежката конкуренция, с която LG 77G2 ще се сблъска в своя размерен клас, са други 77-инчови OLED панели, оборудвани с EX OLED панел и радиатор, като Panasonic LZ2000 и Philips 937.
    Разработката на собствен SoC на LG изплати дивиденти , предоставяйки много предимства пред други телевизори, използващи Mediatek HDMI 2.1 чипсет, който е някак ограничен. Например, LG 77G2 може да бъде калибриран от 3D LUT, осигурява 4 x HDMI 2.1 порта с пълна честотна лента с най-добрата в класа латентност на входа, пълна 4k 120 резолюция с HDR VRR и работещ HGIG и поддържа най-модерните функции на Dolby Vision.
    В допълнение, най-новата актуализация 3.20 поправя някои грешки и подобрява качеството на изображението, като допълнително затвърждава репутацията на LG като безспорно най-отзивчивия производител днес по отношение на поддръжката на фърмуера.
    Поради тези причини LG 77G2 получава нашата силно препоръчана награда за най-добър в класа (9:27).
    Разбира се, конкуренцията с по-малките екрани е по-силна поради наличието на QD-OLED телевизори. За да видите как 55-инчовият LG G2 се представи срещу Samsung S95B и Sony A95K в нашата годишна престрелка, очаквайте видеото скоро (09:50).
  5. Novice
    Jul 2014
    #679
    Здравейте, преди 2 дни си взех LG OLED48 C2 , но забелязах преди малко 3 бели точки когато вървеше Стани богат. Превключих на други канали, но вече не ги виждам, притеснението ми е за мъртви пиксели. Има ли някаква програма или друг начин с която да направя тест?
    Благодаря!
    #680
    Нямаш проблем, щом не се виждат на други програми или източници на сигнал. Вероятно е някакъв проблем с камерите на предаването.
    Можеш да провериш с цветни заливки на цял дисплей.
  7. Novice
    Jul 2014
    #681
    Благодаря много!
  9. Infraction Users
    Sep 2011
    #682
    Цитат Първоначално публикувано от koko28 Виж публикацията
    Благодаря!
    Изгорели пиксели на самата камера, не се стряскай колега!
    #683
    Всичко е на ваш риск и отговорност !
    Как да получите достъп до LG Service Menu без Service Remote
    https://www.reddit.com/r/OLED_Gaming...vice/?sort=new
    Mar 2018
    #684
    Благодаря!
    Нашите телевизии са много зле, особено на живи предавания. Камерите им са пълни с изгорели пиксели, сигурно са купили някои бракувани за без пари и само се излагат! Също така, много пъти на HD телевизии на живи предавания пускат SD сигнал и качеството е ужасно. Това най-често на нова съм го забелязал. Големи са мизерници!
    #685
  13. Junior Member
    Nov 2017
    гр. Левски
    #686
    НЕ е от телевизора ти спокойно при всички ни ги има тези проблеми най вече на това предаване не се стряскай :D
    Благодаря!
  15. Junior Member
    Sep 2008
    #687
    LG Display ще започне производство на 27" и 32" OLED панели.
    Вероятно повече подробности и представяне ще има на CES 2023 през януари.
    https://www.flatpanelshd.com/news.ph...22+OLED+panels
  16. Moderator
    Aug 2006
    #688
    Някой сблъсквал ли се е със следния проблем?
    Проектор на LG, койо ползва същата WebOS система като на телевизорите. Не може да се зареди User Agreement, дава грешка, че няма връзка със сървъра и съответно не иска да пусне нито едно приложение - YouTube, Netflix и тн.
    Като чета в интернет се среща често, но аз поне не успявам да го оправя по посочените начини.
  17. Novice
    Jan 2016
    #689
    Цитат Първоначално публикувано от lazarus18 Виж публикацията
    Опитайте да свържете телевизора си с интернет чрез гореща точка на мобилния си телефон.
  18. Moderator
    Aug 2006
    #690
    Цитат Първоначално публикувано от Baiker Виж публикацията
    Пробвах го този вариант, както и да го ресетна, свързан към хотспот от телефона. Не става нищо.
    Сега се чудя дали понеже бройката е купена от Германия уреда не се опитва да се свърже с някакви техни локални сървъри...
    Отговори: 1323
    Последно: 28-06-26, 22:03
  2. Отговори: 117
    Последно: 12-06-21, 00:44
  3. TCL 2020
    Последно: 02-06-20, 05:33
  4. Евровизия 2020
    Последно: 14-03-20, 21:22
  5. Честита Нова 2020
    От kod във форум Дъра-Бъра
    Последно: 01-01-20, 15:58
