Страница 5 от 5 ПърваПърва ... 345
Резултати от 61 до 73 от общо 73
Like Tree20Одобрявам
LG телевизори 2025 / ЧЗВ в първите постове
    #61
    Отговор: LG телевизори 2025 / ЧЗВ в първите постове
    LG OLED65C54LA model review
    https://geex.x-kom.pl/recenzje/recenzja-lg-oled65c5/
    webOS 2025 (10.1.0-40)
    O22N3 hardware platform was used , which is a modified version of the O22N known from its predecessor (C4 from 2024).
    base width: 470 mm; ground clearance: 56 mm
    all-new remote control without numeric keypad, but still with on-screen cursor (model MR25GA)
    In filmmaker (HDR) mode on the 10% board, the maximum luminance at the beginning of the three-minute measurement was 1091 nits and within 180 seconds it increased to almost 1300 nits.
    Unfortunately, although this is an excellent result, after three minutes the brightness began to decrease significantly: first to about 1000 nits, and then, i.e. five minutes after the beginning of measurements (i.e. after two minutes from the drops) it went down to 905 nits.
    Interestingly, in the predecessor C4 there was no such drop, which indicates the possibility of overdrive by the engineers, i.e. deliberately overdriving the OLED panel.
    Of course, this is possible only until critical conditions (temperature, current) are reached, after which the protection system automatically reduces the load on the panel.
    On the full-screen white board, the luminance was 195 nits.
    #62
    Ревюто показва и вътрешните компоненти на телевизора, например, драйверът на панела показва C4/G4.
    Този пост е редактиран от hristoslav2; 25-07-25 в 17:39.
  4. Dr.
    Dr. е офлайн
    Junior Member
    Aug 2014
    #63
    Ако държите на качествено 4К съдържание - G4. Ако ще се позлва предимно за HD, тогава и последния ще свърши работа.
    Да, купих този: Телевизор LG 55QNED86A3А
    Харесва ми
    Gena_bs и CubanLinx харесват това.
    #64
    LG OLED телевизорите добавят Bluetooth Auracast за споделено безжично аудио
    https://www.tomsguide.com/tvs/lg-tvs...lking-about-it
    https://www.hdtvtest.co.uk/news/lg-s...tooth-auracast
    Auracast обаче трябва да се поддържа и от вашите слушалки, и въпреки че има нарастващ избор от съвместими слушалки и слушалки тип „тапи“, от които да избирате, Auracast все още не е стандартна функция.
    Bluetooth групата има списък със сертифицирани Auracast продукти тук , но изглежда, че той не е напълно актуален.
    https://www.bluetooth.com/auracast/find-a-product/
    #65
    #66
    В ТП има два модела на LG LCD TV:
    50QNED86A3C и 55QNED86A3A
    Телевизор LG 50QNED86A3C 4K Ultra HD Mini LED evo AI SMART TV, WEBOS, 50.0 ", 126.0 см (technopolis.bg)
    Телевизор LG 55QNED86A3А 4K Ultra HD Mini LED evo AI SMART TV, WEBOS, 55.0 ", 139.0 см (technopolis.bg)
    В таблицата за серията като цяло е записано честота на опресняване 120Hz.
    Обаче се оказва, че 50QNED86A3C е 50/60Hz.
    На сайта на LG има същата информация.
    Съществува ли модел за нашия пазар 50QNED86A3А или от тази серия,който да е 120Hz?
    Този пост е редактиран от Gena_bs; 26-07-25 в 18:25.
    #67
    Gena_bs
    43, 50" - 60hz
    55, 65, 75, 86, 100" - 120Hz
    https://www.lcd-compare.com/index.ph...100QNED86A6=on
    Gena_bs одобрява това.
    #68
    WRGB WOLED EX панел от LG Display, LGD.
    Измерената пикова яркост на HDR на нашия 55-инчов тестов модел е 1150 нита при 10% прозорец след калибриране до бяла точка D65 и 220 нита за пълно поле.
    Обърнете внимание, че стойността по подразбиране за яркост от 80 в SDR режим в режим филмов режисьор, даде пикова яркост от 330 нита с деактивирани всички еко настройки.
    C5 използва чипсет с кодово име O22N3, което е малко късно, тъй като чипсетът O22 дебютира за първи път в C2 и G2 през 2022 г.
    Този пост е редактиран от hristoslav2; 28-07-25 в 10:55.
    #69
    55"...[小雪人评测]...LG 55G5 review,teardown
    00:00 Introduction/Packaging/Appearance
    00:40 Power On: PPI/Pixel Arrangement/Color Temperature/Color Gamut
    02:06 Brightness/Color Temperature Uniformity/Viewing Angle
    03:18 Flicker/Spectrum
    03:54 Port Compatibility/Input Lag
    04:25 HDR: Brightness/EOTF/Movies/Gaming
    05:44 Response/BET
    06:06 Teardown: Driver Board/Panel
    06:37 Test Data/Rankings
    07:12 Summary: Pros and Cons
    #70
    #71
    #72
    LG пуска алтернатива на магазина за изкуство на Samsung The Frame
    https://www.lgcorp.com/media/release/29291
    #73
    LG 65QNED93Α ревю
    https://tweakers.net/reviews/13654/l...lasse-hdr.html
    LCD, VA панел
    с пълномащабно локално затъмняване, mini-LED, подсветка с 486 зони,
    100/120Hz с MCFI+трептене на подсветката,
    144Hz се отнася само за PC игри, защото настоящите игрови конзоли са ограничени до 120Hz.
    α8 gen2 AI 4K процесор.
    HDR формати, от Dolby Vision до HDR10 и HLG.
  1. Samsung телевизори 2025 / ЧЗВ в първите постове
    Отговори: 68
    Последно: Днес, 18:58
  2. Отговори: 10040
    Последно: Вчера, 15:24
  3. OLED Телевизори - съвети и обсъждане
    От hristoslav2 във форум Телевизори
    Отговори: 1827
    Последно: 16-05-25, 21:15
  4. Първите лазерни телевизори са LaserVue на Mitsubishi
    От Baj Vylcho във форум Други телевизори
    Последно: 03-02-11, 17:04
  5. Отговори: 4
    Последно: 27-05-08, 07:30
