Страница 8 от 10 ПърваПърва ... 678910 ПоследноПоследно
Резултати от 106 до 120 от общо 142
Like Tree24Одобрявам
LG телевизори 2026 (инфо в първи пост) - дискусия
    #106
    Отговор: LG телевизори 2026 (инфо в първи пост) - дискусия
    LG OLED асемблиран в Турция ?
    https://webos-forums.ru/post201514.html#p201514
    #107
    Бай Koç не спи, а прави парички!
    От години имат договори с LG за климатичните технологии. А вероятно и за друга електронна продукция.
    Arçelik produces its OLED TVs in Turkey using panels sourced directly from LG Display.
    The final TV assembly takes place at Arçelik’s electronics manufacturing plants, with its primary TV and consumer electronics facilities located in Beylikdüzü (Istanbul) and Çerkezköy (Tekirdağ).
    #108
    LG 77C6 test
    https://www.clubic.com/test-produit-...g-oled-c6.html
    LG 55B6 (55B68LA) test
    https://www.computerbild.de/artikel/...-41029937.html
    https://www.lg.com/us/tv-home-theate...80b-wall-mount
    EZ Slim Wall Mount for LG TV's
    WB24GCB
    Compatible with the following 2025 TVs: 83" OLEDG5/C5/B5
    View movies, games and more without distraction thanks to a slim, minimalist wall mount
    Compatible with the following 2026 TV’s: 83/77/65 G6 Series, 83 C6 Series, 83 B6 Series, 75 MRGB95B Series, 85 QNED84B Series, 85/75 QNED75B Series, 85/75 NU85 Series
    Compatible with the following 2025 TVs: 83" OLEDM5/G5/C5/B5
    Compatible with the following 2025 TVs: 77" OLEDM5/G5, 65" OLEDG5
    Compatible with the following 2025 TVs: 75/65/55" QNED85A
    Compatible with the following 2025 TVs: 75UA7700A
    https://www.lg.com/de/care-accessori...t/mec63304901/
    EZ Slim Wall Mount for LG TV's (VESA - 300 X 300 / 300 X 200 / 400 X 200)
    OLW480B
    EZ Slim Wall Mount for LG TVs
    Compatible with the following 2026 TV’s: 55 G6 Series, 77/65/55/48/42 C6 Series, 77/65/55/48 B6 Series, 75/65/55 QNED84B Series, 65/55/50/43 QNED75B Series, 65/55/50 NU85 Series
    Compatible with the following 2025 OLED TV's: 77/65/55/48/42" OLED C5 Series, 77/65/55/48" OLED B5 Series
    Compatible with the following 2025 QNED TV's: 75/65" QNED9MA Series, 75/65/55" QNED82A Series
    Compatible with the following 2025 UHD TV's: 65/55" UA7700AUA Series, 65/55" UA7500ZUA Series
    Compatible with the following 2024 OLED TV's: 77/65/55 OLED G4 Series, 77/65/55/48/42 OLED C4 Series, 77/65/55/48 OLED B4 Series
    Compatible with the following 2024 QNED TV's: 75/65/55 QNED85T Series, 65/55 QNED80T Series, 65/55 UT80 Series
    Този пост е редактиран от hristoslav2; 26-06-26 в 20:36.
    #109
    Функции с изкуствен интелект в телевизорите на LG: какво могат да правят и струва ли си да се използват?
    https://www.x-kom.pl/poradniki/10313...korzystac.html
    #110
    Значително по-ярък, но температурата на панела сега се повишава до над 100 градуса по Целзий.
    Този пост е редактиран от hristoslav2; 29-06-26 в 19:45.
    #111
    Проблемът с актуализацията на фърмуера на LG за 2026 г. (сравнение на G6 и G5)
    LG G6 от 2026 г. предлага някои малки подобрения спрямо G5 от 2025 г.
    Струват ли си тези подобрения допълнителните разходи, свързани с получаването на по-новия модел, или е по-добре да спестите пари и да си вземете G5, докато все още можете?
    Тестови модели: 65G6 и 77G5
    нова актуализация на фърмуера се пуска на всеки две седмици.
    18. Mai 2026 - 43.10.42
    09. Juni 2026 - 43.11.66
    18. Juni 2026 - 43.11.67
    24. Juni 2026 - 43.11.68.
    01. Juli 2026 - 43.11.71
    #112
    LG C6 48 OLED Monitor Review
    https://www.rtings.com/monitor/revie...ZwoMNHIGbJ3r4H
    достъпът е само за 24 часа
    #113
    При възпроизвеждане на **HDR** (висок динамичен диапазон) и **Dolby Vision** се прилага основен принцип: Изходният материал се обработва с абсолютни стойности на яркостта. За разлика от SDR (стандартен динамичен диапазон), където настройвате яркостта според околната светлина, HDR е проектиран така, че телевизорът да извежда точно яркостта, която режисьорът е предвидил за всяка сцена.
    Ако ръчно намалите яркостта на LG OLED (например, използвайки контролата "OLED Pixel Brightness" или, преди това, "OLED Light"), вие влияете негативно върху тази предварително дефинирана крива. Това се дължи на следните причини:
    ### 1. Огъване на кривата EOTF (PQ крива)
    HDR използва фиксирана електрооптична трансферна функция (EOTF), т.нар. **PQ крива** (Perceptual Quantizer). Тя присвоява точна стойност на яркостта (в нитове) на екрана на всяка цифрова стойност на цвят и яркост във видео сигнала.
    * Ако според сигнала се очаква един пиксел да е с точно **400 нита** ярък, телевизорът трябва да осигури точно тези 400 нита.
    * Ако намалите основната яркост на панела, цялото изображение се намалява. Телевизорът изрязва или компресира кривата, което води до загуба на тонална точност.
    ### 2. Загуба на детайли в светлите зони (динамичен диапазон)
    OLED панелите процъфтяват благодарение на безкрайния си контраст – дълбоки черни тонове точно до изключително ярки светлини като слънчеви лъчи, експлозии или фарове. Ако намалите максималната яркост на панела, лишавате телевизора от необходимия запас за ясно показване на тези пикови нива на яркост. Изображението губи дълбочина и изглежда плоско („измито“ в HDR смисъла).
    ### 3. Разрушаване на тоналното картографиране
    Тъй като много HDR филми се мастерират при 1000, 4000 или дори 10 000 нита, но OLED панелът физически управлява само между 700 и 1500 нита, LG използва техника, наречена **тонално картографиране**. Той интелигентно преобразува екстремните нива на яркост спрямо физическите възможности на панела.
    Ако изкуствено намалите максималната яркост чрез настройките на картината, принуждавате вътрешния алгоритъм да работи с неправилни максимални стойности. Това води до неправилно картографиране на тоновете, което може да доведе до пълна загуба на детайли в светлите области („изрязване“).
    ### 4. Dolby Vision губи динамичния си диапазон.
    Особено при Dolby Vision, който работи с **динамични метаданни** и настройва яркостта сцена по сцена (или дори кадър по кадър), правилната конфигурация на панела е от съществено значение. Системата Dolby Vision в LG очаква панелът да работи с пълния си, неограничен капацитет. Ако намалите контрола на яркостта, вие по същество „заслепявате“ системата за правилната обработка на метаданните.
    **Заключение за правилна картина:**
    > За HDR10 и Dolby Vision, контролите за **яркост на OLED пикселите** и **контраст** трябва да бъдат настроени на **100** по подразбиране (или на максималната стойност по подразбиране на съответния профил, като например *Filmmaker Mode* или *Cinema Home*).
    Ако картината изглежда твърде ярка или изморителна в напълно тъмна стая, правилното решение в областта на HDR не е да се намали яркостта на панела, а да се използват функции като **Dolby Vision IQ** или **LG AI Brightness** (които нежно регулират PQ кривата чрез сензора за околна светлина, без да нарушават напълно HDR структурата) или да се активира фина, цветно неутрална подсветка (*bias lighting*) зад телевизора, за да се намали напрежението в очите.
    CubanLinx одобрява това.
    #114
    Телевизорите LG OLED evo от 2026 г. получават нов режим на картина Creator Original
    LG Electronics въвежда нов режим на картината, наречен Creator Original, за избрани модели телевизори. Тази настройка предлага на студиата по-прецизен контрол от Filmmaker Mode за стрийминг на съдържание. Неутралните режими на картината, като Filmmaker, съществуват по същество като отговор на тежката последваща обработка на съвременните телевизори, деактивирайки bwku[rr като изглаждане на движението за по-традиционно представяне. Creator Original вместо това приема тези допълнителни функции, позволявайки на филмовите и телевизионни студия да задават параметри като детайли на сенките, баланс на цветовете, намаляване на шума и обработка на движението, за да представят най-добре творческата си визия.
    Засега тази опция за картина е ексклузивна за сериите LG OLED evo W6, G6 и C6 от 2026 г.
    Стартирането се осъществява в партньорство с Prime Video и е фокусирано върху предстоящия филм на услугата „ Господарите на Вселената“ . Всички сериозни фенове на Skeletor и екипа могат да използват и специална гласова команда с LG Magic Remote на LG Smart TV, работещи с поне webOS 23. Провъзгласяването на „Аз имам силата“ с дистанционното автоматично ще изведе съдържание за новата версия, което е или забавно, или шокиращо. Или може би и двете едновременно.
    Read More: https://www.engadget.com/2220242/202...-picture-mode/
  12. ivu
    ivu е офлайн
    Junior Member
    Mar 2018
    #115
    По-големите размери (77 инчовият по-специално) дали има някаква индикация кога ще ги пускат в България? Засичал съм само 55 и 65 инчовите до момента.
    Jan 2017
    #116
    За българските техно вериги ли става въпрос? При румънците има(ше) и 77".
  15. ivu
    ivu е офлайн
    Junior Member
    Mar 2018
    #117
    За българските популярни вериги - да. Идеята е да е нещо лесно и сигурно за гаранционното обслужване в последствие.
    Сега пак погледнах и го видях пуснат явно току-що на 3899 в една от веригите.
    #118
    svetlio1 и CubanLinx харесват това.
    #119
    Dec 2024
    #120
    Големи ефекти на MRGB85 на видеото с хеликоптера.
  1. Samsung телевизори 2026 (инфо в първи пост) - дискусия
    Отговори: 91
    Последно: Вчера, 12:13
  2. VOX телевизори
    Последно: 26-06-23, 11:46
  3. телевизори
    Последно: 31-08-12, 07:46
  4. 3d Телевизори
    Последно: 18-12-11, 16:06
  5. 3д телевизори на LG
    Последно: 10-10-11, 21:39
