Страница 7 от 31 ПърваПърва ... 5678917 ... ПоследноПоследно
Резултати от 91 до 105 от общо 454
Like Tree93Одобрявам
Philips телевизори 2016
    #91
    Отговор: Philips телевизори 2016
    Philips 2016
    899 € - Philips 43PUS6501 (43’’, 124 cm)
    1 099 € - Philips 49PUS6501 (49’’, 124 cm)
    1 399 € - Philips 65PUS6501 (55'', 109 cm)
    1 799 € - Philips 56PUS6521 (65'', 165 cm)
    22PFK4000/12 FHD LED TV 100PMR Digital Crystal Clear 12 Volt Direct € 229,00
    24PHK4000/12 HD LED TV 100PMR Digital Crystal Clear Direct € 249,00
    24PFK5211/12 HD, LED, 200Hz Digital Crystal Clear + Bluetooth speaker Apr € 299,00
    32PFS5501/12 Full HD, LED, 500Hz, Android TV, Pixel Plus HD, Dual Core Mei € 449,00
    40PFS5501/12 Full HD, LED, 500Hz, Android TV, Pixel Plus HD, Dual Core Mei € 549,00
    49PFS5501/12 Full HD, LED, 500Hz, Android TV, Pixel Plus HD, Dual Core Mei € 749,00
    32PFS6401/12 FHD, Slim LED, Ambilight-2, 1000Hz, Android TV, Pixel Plus UHD, Quad Core Mrt € 549,00
    43PUS6401/12 UHD, Slim LED, Ambilight-2, 1000Hz, Android TV, Pixel Plus UHD, Quad Core Mrt € 799,00
    49PUS6401/12 UHD, Slim LED, Ambilight-2, 1000Hz, Android TV, Pixel Plus UHD, Quad Core Mrt € 999,00
    55PUS6401/12 UHD, Slim LED, Ambilight-2, 1000Hz, Android TV, Pixel Plus UHD, Quad Core Mrt € 1.199,00
    43PUS6501/12 UHD, Slim LED, Ambilight-2, 1800Hz, Android TV, Pixel Plus UHD, Quad Core Mrt € 999,00
    49PUS6501/12 UHD, Slim LED, Ambilight-2, 1800Hz, Android TV, Pixel Plus UHD, Quad Core Mrt € 1.199,00
    55PUS6501/12 UHD, Slim LED, Ambilight-2, 1800Hz, Android TV, Pixel Plus UHD, Quad Core Mrt € 1.399,00
    49PUS7101/12 UHD, Slim LED, Ambilight-3, 2000Hz, Android TV, Pixel Plus UHD, Quad Core Mrt € 1.399,00
    55PUS7101/12 UHD, Slim LED, Ambilight-3, 2000Hz, Android TV, Pixel Precise UHD, Quad Core Mrt € 1.599,00
    65PUS7101/12 UHD, Slim LED, Ambilight-3, 2000Hz, Android TV, Pixel Precise UHD, Quad Core Apr € 2.599,00
    75PUS7101/12 UHD, Slim LED, Ambilight-3, 2000Hz, Android TV, Pixel Precise UHD, Quad Core Mei € 5.499,00
    65PUS7601/12 UHD, Slim LED, Ambilight-3, 2800Hz, Android TV, Perfect Pixel UHD, HDR premium, Quad Core Jul € 2.999,00
    55PUS8601/12 UHD, Slim LED, Ambilight-4, 1800Hz, Android TV, Perfect Pixel UHD, Visible sound, Quad Core Direct € 2.299,00
    65PUS8601/12 UHD, Slim LED, Ambilight-4, 1800Hz, Android TV, Perfect Pixel UHD, Visible sound, Quad Core Direct € 3.499,00
    Този пост е редактиран от hristoslav2; 10-03-16 в 20:00.
    soon одобрява това.
    Oct 2010
    #92
    Инчовете? 55 и 65, предполагам...
    #93
    Този пост е редактиран от hristoslav2; 10-03-16 в 20:02.
    Oct 2010
    #94
    Да се похваля...
    Вече мога да ползвам пълноценно функцията "Картина в картината" ("Множествен изглед") с два кодирани канала едновременно, както и да записвам предаване по един кодиран канал, докато гледам друг кодиран.
    soon, hristoslav2, svetlio1 и 6 други харесват това.
    #95
    Това при използване на един модул и карта или с два модула и карти ?
    Oct 2010
    #96
    Два модула и две карти в два CI слота.
    hristoslav2 одобрява това.
    #97
    Рядко добър модел!
    podredko одобрява това.
    Apr 2013
    Sofia, Bulgaria, Bulgaria
    #98
    Здравейте, имам Phillips 55inch TV. Към него има Bluetooth WiFI Speaker на Phillips SWB50, който се връзва към телевизора посредством USB адаптер. Има ли възможност ако го вържа този адаптер на лаптоп да пусна звук от лаптоп.
    Oct 2010
    #99
    Не, доколкото разбирам този USB адаптер е за захранване на самия Speaker. Начини за "пускане" на звук (вероятно имаш предвид музика?) от лаптоп има различни през WiFI към телевизор или друго смарт устройство. Какъв е модела на телевизора и поддържа ли DLNA?
  12. abv
    abv е офлайн
    Member
    #100
    Някой слагал ли е новия софтуер за телевизори от 4ххх серия. Има ли някакви проблеми ?
    #101
    Ревю на модел от 2016 година
    TEST: Android TV Philips PUS 6501 Ultra HD - PHILIPS - HDTV Centrum Polska
    49PUS6501/12 - IPS panel,100/120Hz
    google превод pl to en
    google превод pl to bg
    #102
    тия явно са били здраво напушени за това ... "ревю" -
    The Philips 8901 Ambilux TV brings a rave to your front room | What Hi-Fi?
    #103
    Да забравим за измерванията при този панел IPS. Реално виждам много по-добро черно в самата картина от колкото VA. Много интересно и положително! Браво.
    #104
    What Hi-Fi отдавна не ги чета - това не са ревюта, а прегледи с общи приказки. Не си губи времето с тях.
    Таблица с модели 2016
    http://toengel.net/philipsblog/wp-co...rview_2016.png
    UHD
    65PUS8901/12 TPT650LS-FJ01 SC1H XM TPV
    55PUS8601/12 TPT550U1-FJ04.S SC1B XM TPV
    55PUS7181/12 TPT550U2-EQLSHA.G S1E NH TPV
    49PUS7181/12 TPT490U2-EQLSHA.G SC2C NH TPV
    55PUS7101/12 TPT550U2-EQLSHA.G S1E NH TPV
    49PUS7101/12 TPT490U2-EQLSHA.G SC2C NH TPV
    55PUS6581/12 TPT550U2-EQLSHA.G S1B XM TPV
    55PUS6561/12 TPT550U2-EQLSHA.G S1B XM TPV - IPS panel - 100hz
    49PUS6561/12 TPT490U2-EQLSHA.G SC2B XM TPV - IPS panel - 100hz
    55PUS6551/12 TPT550U2-EQLSHA.G S1B XM TPV - IPS panel - 100hz
    49PUS6551/12 TPT490U2-EQLSHA.G SC2B XM TPV - IPS panel - 100hz
    65PUS6521/12 TPT650UA-QVN04.U S400B NH TPV
    55PUS6501/12 TPT550U2-EQLSHA.G S1B XM TPV - IPS panel - 100hz
    49PUS6501/12 TPT490U2-EQLSHA.G SC2B XM TPV - IPS panel - 100hz
    43PUS6501/12 TPT430U3-EQLSHA.G S2A NH TPV - IPS panel - 100hz
    55PUS6401/12 TPT550J1-QUBN0.K S8940A XM TPV
    49PUS6401/12 TPT490U2-EQYSHM.G SC1G XM TPV
    43PUS6401/12 TPT430U3-EQYSHM.G S1H NH TPV
    FHD
    32PFS5501/12 TPT315B5-FHBN0.K S49P2H NH TPV
    48PFK4100/12 TPT480LS-HN08.S SG01A XM TPV
    40PFK4101/12 TPT400LA-J6PE1.N SC2A NH TPV
    Программное обеспечение 000.005.101.054 (для 55x0, 64x0, 65x0). Опыт использования. - Страница 4
    http://4pda.ru/forum/index.php?s=&sh...ost&p=45597798
    Този пост е редактиран от hristoslav2; 20-03-16 в 14:47.
    soon одобрява това.
    #105
    Таблица в pdf за модели 2016 - слезте надолу
    http://www.recordere.dk/wp-content/u...16_preview.pdf
    soon, podredko и Ka4akow харесват това.
  1. Левски - Завръщане | А ПФГ 2015 / 2016
    От kod във форум Спорт
    Последно: 13-11-17, 18:52
  2. Избор на климатик 2016 г.
    Отговори: 3492
    Последно: 01-01-17, 18:50
  3. Квалификации Евро 2016
    От iihtiandar във форум Спорт
    Последно: 10-06-16, 09:03
  4. Philips телевизори 2015
    Отговори: 426
    Последно: 02-01-16, 08:21
  5. системи за домашно кино-PHILIPS HTS-6100/12,PHILIPS HTS-8100/8140
    От maddog9 във форум Системи за домашно кино, плеъри и HTPC
    Последно: 24-09-09, 13:13
