Страница 20 от 76 ПърваПърва ... 1018192021223070 ... ПоследноПоследно
Резултати от 286 до 300 от общо 1140
Like Tree162Одобрявам
Philips телевизори (инфо на първа страница)
    #286
    Отговор: Philips телевизори 2019
    Темата не е за избор....Стой далеч от моделите със Saphi
    иначе
    https://www.technopolis.bg/bg/Televi...LA-LED/p/16465
    https://www.technopolis.bg/bg/Televi...HD-LED/p/14993
    Този пост е редактиран от hristoslav2; 20-12-19 в 20:48.
    #287
    Philips 65OLED984/12 and 55OLED934/12 review
    https://tweakers.net/reviews/7544/ph...-verdient.html
    SoC from MediaTek: MT5887
    four Cortex-A53 ARM CPU cores at a maximum of 1.5 GHz
    2.5 GB of RAM
    3.8 GB is free to use and to use for installing apps
    GPU: Mali G51, 650MHz
    If the TV is in front of a white wall, we find the ISF mode the most comfortable. It provides constant white light behind the TV that has the same color temperature as a correctly adjusted screen. This makes looking in a dark room less tiring for your eyes and you experience the colors on the screen as they were intended. Unfortunately, the isf position ex-factory is rather blue, at a color temperature of almost 17,000 Kelvin. By entering the values ​​100, 82 and 73 in the menu for red, green and blue respectively, we were able to display the Ambilight LEDs white light with the correct color temperature of 6500 Kelvin.
    In the 'HDR film' mode, where the colors are displayed correctly, the maximum brightness is considerably lower. We see that in the graph below.
    https://www.digislovakia.sk/hu/zozna...-fast-scan-hu/
    Серия Oled
    984
    954
    934
    854
    804
    754
    LCD
    8804
    8204
    7504
    7394
    7654
    7334
    7304
    LCD
    6814
    6804
    6754
    6704
    6554
    6504
    LCD
    5304
    4504
    4354
    4304
    SOC MediaTek: MT5599 MediaTek: MT5599 MediaTek: MT5806 MSD92L
    CPU Cortex-A53 ARM Cortex-A53 ARM Cortex-A53 ARM
    CPU Cores 4 4 4
    CPU Frequency 1.5 GHz 1.5 GHz 1.2 GHz 1.0 GHz
    GPU Mali G51, 650MHz Mali G71, 650MHz Mali G51
    RAM 3.0 GB 3.0 GB 2.0 GB -
    Storage 16/8 GB 16/8 GB 8 GB -
    Този пост е редактиран от hristoslav2; 22-12-19 в 11:01.
    Jan 2016
    #288
    Philips 50pus7354/12 vs Sony 55xg8596
    Голяма дилема......
    Dec 2015
    #289
    Здравейте! Купих си 50PUS7304 и нещо не ми е ок картината. Виваком кабеларка, от друга страна от флашка е екстра.
    Не съм особено претенциозен, но тая зърнеста картина ме дразни. В този ред на мисли, ще бъда благодарен за някакви настройки.
    Nov 2019
    #290
    То в зърното е качеството при Philips и Sony обработката на картината.
    #291
    draki
    Поиграй си с настройката за острота на картината. Надявам се и че гледаш в режим кино.
    Dec 2015
    #292
    Мерси, сега ще опитам.
    А за поста над теб, исках андроид и амбилайт. И те така!
  10. Junior Member
    Jun 2019
    #293
    Аз гледам на естествено и жив,според мен проблема ти е от ниското качество на кабеларката,пробвай да пуснеш някой клип с високо качество в ютуб и сравни
    Изпратено от моят HMA-L29 с помощта на Tapatalk
    #294
    ANDROID TV 10 Q: ШЕСТЕ ПРОМЕНИ, КОИТО ТРЯБВА ДА ЗНАЕТЕ
    https://www.reddit.com/r/AndroidTV/c..._need_to_know/
    https://www.androidheadlines.com/201...to-expect.html
    Този пост е редактиран от hristoslav2; 01-01-20 в 16:09.
    Aug 2009
    #295
    Здравейте на всички.
    Предстои ми закупуване на нов ТВ(55-65"). Спрял съм се на Philips 55 Oled 754 модела, който ще се гледа от около 2.3м. Моля да ми кажете, заслужава ли си точно този модел, понеже мога да го взема на цена от 1700 някъде.
    Благодаря предварително
    #296
    2020 PHILIPS OLED HDR TV
    HDR10+ сертификация
    https://hdr10plus.org/certified-products/
    55OLED755/12 2020 PHILIPS Saphi OLED HDR TV
    65OLED755/12 2020 PHILIPS Saphi OLED HDR TV
    55OLED765/12 2020 PHILIPS Saphi OLED HDR TV
    65OLED765/12 2020 PHILIPS Saphi OLED HDR TV
    55OLED805/12 2020 PHILIPS Android OLED HDR TV
    65OLED805/12 2020 PHILIPS Android OLED HDR TV
    55OLED855/12 2020 PHILIPS Android OLED HDR TV
    65OLED855/12 2020 PHILIPS Android OLED HDR TV
    55OLED865/12 2020 PHILIPS Android OLED HDR TV
    65OLED865/12 2020 PHILIPS Android OLED HDR TV
    Този пост е редактиран от hristoslav2; 05-01-20 в 11:07.
    Jun 2018
    #297
    Цитат Първоначално публикувано от Taffcho Виж публикацията
    Здравейте, имам нужда малко от съвет. Искам да си сменя ТВ в дневната (Samsung 40UE5000) с нещо около 50 инча. Насочих се за Филипс около 1000 и малко лева. Спрях се първоначално на 50PUS8804, който в момента е на цена 1399лв. Обаче видях сега и на промоция за 999лв. на изплащане с 0% лихва и 50PUS7354. Четох, сравнявах и за човек, който не е много на ти се зачудих струва ли си разликата от 40% в двата. ОСвен звука и по-високата серия, какво повече ще получа за 400лв повече? Благодаря!
    В крайна сметка взех 50PUS7354 и за сега съм доста доволен. Имах малък проблем, докато се ориентирам как да заключа каналите +18 и с настойна на субтитрите от флашка , но се справих. На кабеларка съм, HD каналите се виждат много добре, доволен съм, някои като НОва Тв например не, но това е от сигнала основно. Амбилайта е супер. При много динамично движение на картината при високо качество се наблюдава и леко замазване, но се търпи. За тези пари съм доволен засега.
    #298
    Сетиха се от Philips....
    https://toengel.net/philipsblog/2020...ozess-burn-in/
    С пускането на фърмуера през декември 2019 г. ( TPM171E версия 107.1.101.2 ) за 2017 до 2019 телевизорите на Philips с Android, поведението на OLED почистването се промени или поведението е адаптирано към това на 2019 телевизорите. Вече публикувах подробности за анти-изгарянето през 2017 г. (които препоръчвам на всеки собственик на OLED). Ето няколко подробности как да адаптирате алгоритъма:
    • Новият фърмуер TPM171E версия 107.1.101.2 намалява OFFRS от 10 часа на 6 часа ( стойности като OFFRS могат да бъдат прочетени в CSM ).
    • Ако телевизорът вече работи повече от 6 часа без почистване по време на актуализацията на новия фърмуер, програмата за почистване идва веднага след процеса на актуализация, който не може да бъде отменен (има само бутон „OK“).
    • Ако след актуализацията телевизорът вече работи 6 часа без редовно почистване:
    • Има информационен диалог за почистване. Тук има и бутон „По-късно“. Ако се натисне "По-късно" и телевизорът се превключи в режим на готовност, почистването се извършва в режим на готовност.
    • Можете да кликнете върху „По-късно“ максимум два пъти. Третият път има само бутон „OK“ и почистването се извършва директно, когато щракнете върху „OK“. Не можете да прекъснете този процес.
    Този пост е редактиран от hristoslav2; 11-01-20 в 21:34.
  17. Senior Member Аватара на cable
    Dec 2010
    #299
    OLED телевизорите Philips ще се предлагат в САЩ. Компанията намери дистрибутор. Така сегментът OLED, който досега е бил тесен в САЩ, ще се разшири. Пазарът на OLED телевизори в САЩ е много ограничен. Например не можахме да намерим продукти на Panasonic или Philips. Положението на другата компания обаче се промени. Тази година OLED телевизорите ще влязат в продажба там, започвайки от модела OLED804 .
    Funai е дистрибутор на Philips OLED в САЩ Представянето на OLED телевизорите Philips в САЩ беше обявено от Funai , който има лиценз за дистрибуция на своите продукти.
    : https://hdtvpolska.com/philips-usa-o...aca-do-stanow/
    Jan 2020
    #300
    Привет,
    След още и още четене в форума аз лично за себе си реших, че новия OLED, с който искам да се "обзаведа" ще е Philips. По-трудния въпрос сега е - кой точно модел...да чакам или не...
    Спрямо момента опциите ми са по-скоро две, като третата ми се вижда прекалено скъпа - 873 или 754 и по-малко вероятно 804/854 в 65 инчов вариант.
    Моля някой да ме поправи, ако греша имам следната информация за моделите:
    > 873 модел 2018 е с първо поколение P5 процесор и OLED матрица от 2017 като технология. Смесени "чувства" за този модел и спрямо ревютата в Интернет.
    > 754, модел 2019 е с второ поколение P5 процесор и матрица от 2018 използвани в високия клас модел 903 от 2018 година и малко или много 754 е същия като 903, но без андроид.(поне според мен)
    > 804/854 са вече с P5 PRO процесор, модели от 2019, а за матрицата нямам инфо и си имат всичко - андроид, по новия процесор и т.н.и т.н. и като цяло по-добри от всичко под и преди тях.
    > за 9-та серия от 2019 година няма да говоря там е ясно как са нещата, но и кеша там е прекален поне според мен, а и не прекарвам чак толкова много време пред ТВ за да е оправдано за мен лично.
    Дилемата ми сега е: Да взема ли 754-ката, която според мен ще ми върши чудесна работа, защото към нея ще е закачен ТВ бокс и HTPC и единственото, което ще ползвам от вградените неща от ТВ е Youtube да си плейвам музика или през самия ТВ, който според мен мисля, че има едно от най-доброто звучене спрямо други ТВ в този клас (2.1 система с вграден суб) или през ARC-a ще "връщам" звука към ресивъра от Youtube апликацията в телевизора.
    Всички филми тип 4К/2180p със Dolby Atmos/DTS-HD & HDR10, HDR10+ / Dolby Vision ще "идват" в цифров и възможно най-непокътнат вид от HTPC-то през ресивъра, който може да "пропуска" както Dolby Vision така и HDR10 към ТВ. (само не съм сигурен за HDR10+ дали ще се справи.)
    Има го и варианта с чакането...но с чакане..я камилата, я камиларя накрая....разликата м/у 754 и 804 или 854 е 1000+ лв, което изобщо не е за пренебрегване, а и най-малкото според мен не си заслужава. Може и да не съм прав, но от информацията, която изчетох така ми изглежда. И да изчакам сега гаранцията е никаква какви ще станат цените и т.н, а и дали ще има и останала фабрично запечатана бройка ....а вече продадох стария ТВ и повече от два месеца чакане няма да издържа
    Да стоя наистина далеч от Saphi и на всяка цена?
    Поздрави.
    иначе
  1. Избор на климатик '2019
    Отговори: 3063
    Последно: 04-01-20, 11:11
  2. Philips телевизори 2018
    Отговори: 254
    Последно: 02-01-19, 14:11
  3. Philips телевизори 2017
    Отговори: 279
    Последно: 01-01-18, 07:35
  4. Philips телевизори 2016
    Отговори: 453
    Последно: 01-01-17, 19:22
  5. Philips телевизори 2015
    Отговори: 426
    Последно: 02-01-16, 08:21
