Страница 95 от 98 ПърваПърва ... 45859394959697 ... ПоследноПоследно
Резултати от 1,411 до 1,425 от общо 1459
Like Tree1Одобрявам
Samsung LCD TV / Faq - на първа страница ,обсъждане ,мнения /част 3/
    Nov 2011
    #1411
    Re:Samsung LCD TV / Faq - на първа страница ,обсъждане ,мнения /част 3/
    Или не съм разбрал и достатъчно търсил!Но не открих сваляне на приложения(widjets) за D7000.
    #1412
    Цитат Първоначално публикувано от EMSI_
    Свалят се от тук
    http://www.samsung.com/us/appstore
    Таблица с приложенията по серии.
    http://www.samsung.com/us/pdf/apps-a...duct-table.pdf
    За модели Samsung 2009 LCD
    http://www.parantar.com/2009/08/down...lcd-and-led-tv
    http://plexforsamsung.pbworks.com/w/...ll+Plex+Widget
    Как да си смените Internet@TV региона?
    Finally succeeded in changing my Internet@TV region to the USA! Finally alot more apps are available for download including Netflix etc.
    1. Enter Internet@TV
    2. Press "FastForward" (The button with two arrows point right)
    3. Press 2 8 9 about half a sec apart
    4. Press "FastRewind"
    This worked after about 3 attempts with timings on a C7000.
    Hope this helps someone!
    Инфото е от австралийските ни колеги
    http://forums.whirlpool.net.au/forum...t=1316239&p=14
    Има ли начин да си рефрешна Samsung Apps страницата?
    Yes.
    Ok ... it seems that the app is there, but it's not visible (at least to those of us with 2010 model Samsungs... the people with the new 2011 SMARTtv models are reporting to have it).
    So.. to get it, you need to trick your TV into installing all the "default" apps. One way to do this is to change the country to something else, then change it back.
    To do this:
    - Start internet@tv
    - Hit the following buttons:
    ">>" (fast forward")
    "2 8 9"
    "<<" (rewind)
    About &#189; second between each seems about the right pace.
    - Choose a country less interesting than Australia (say, New Zealand)
    - Accept the terms and conditions (3x)
    - Wait for it to install the default apps for NZ
    - Repeat the above steps to switch back to Australia. This will install the iView app
    - Delete and install the apps you want to keep.
    Done!
    http://forums.whirlpool.net.au/forum...t=1316239&p=15
    Как да си разблокирате достъпа до регионално блокирано видео на вашият компютър или телевизор.
    http://unblock-us.com/
  4. zgk
    zgk е офлайн
    Jun 2010
    #1413
    Цитат Първоначално публикувано от vladi8008
    аз пак да попитам дали има някой който ноже да ми прати покана за 3Д торента ,че само с покани става регистрацията
    _________________________________________________[color=red]слети поредни публикации на: [time]1324043760[/time]_________________________________________________
    какво значи хакнат .и как монтираш НФС
    И, аз не разбрах?
    _________________________________________________[color=red]слети поредни публикации на: [time]1324054664[/time]_________________________________________________
    Във връзка с хакването и монтирането на nfs.
  5. Super Moderator
    Dec 2000
    Sofia
    #1414
    Днес ми се ъпгрейдна Smart Hub-a и ми инстаира GCN PPV. Похвално Самсунг, похвално. Сега остана и да има повече филми ( в момента са 5-6) и да стане ясно колко ще струва гледането и къде може да се плати
    Jun 2011
    #1415
    Да,наистина похвално,обаче при мен става дублиране.Тези PPV 1 2 3 4 5 си ми вървят нон стоп по кабелната
  7. Super Moderator
    Dec 2000
    Sofia
    #1416
    Аз доволен. Булсатя и без това спря PPV.
    Jun 2011
    #1417
    Цитат Първоначално публикувано от stenly
    http://www.mobilebulgaria.com/news/2...BB%D0%BC%D0%B8
    Apr 2010
    #1418
    Toва PPV дали ще го има за серия С, или е само за D ?
    #1419
    http://turn-smoothing-off.blogspot.com/
    nStreamPlayer0.73Lmod
    http://forum.ixbt.com/topic.cgi?id=62:19152-75#2655
    Как да стартира заедно с телевизора /D-серия:
    smarthub ->Settings ([D]BLUE) -> Service Manager -> Ticker Autorun -> ON , избираме уиджет
    http://forum.ixbt.com/topic.cgi?id=62:19152-72#2563
    Как да инсталираме приложения
    http://smarttv.shatu.ru/guestbook.ph...7008c75301.txt
    Интересно D8000 чак сега се появява в Корея..
    http://samsungtomorrow.com/2018
    http://www.flickr.com/photos/samsung...in/photostream
    Apr 2010
    #1420
    Сам си отговарям на въпроса - PPV е за серии D. Супер тъпо, нови приложения за моделите от тази година, но не и за тези от миналата. Браво на Самсунг
    #1421
    То пък трябва да съм много приял да дам 15лв за да гледам GCN PPV.Филмите са много глупави
    Как да подкарам .sup фаил,пример:
    Film 1080p.ts
    Film 1080p.sup
    Jan 2009
    #1422
    Здравейте пичове, да ви питам пак, че така и не намерих решение за проблема с 3д на моя сами С750. Работата е там, че като пусна SBS енкоуд и активирам 3д ми разпъва картината и изрязва черните ленти отгоре и долу, и крайния резултат е че картината се разпъва и не е естествена. В менюто от tools / picture size стои в mode 2 и е неактивно за промяна.
    ПОМОЩ!
    Много е неприятно и ме отказва да гледам 3д филми.
    Фърмуеъра е 10_003011
    #1423
    Сравнение работата на очила SSG-3700CR и SSG-3100GB
    http://forum.ixbt.com/topic.cgi?id=62:19469:4634#4634
  17. Super Moderator
    Dec 2000
    Sofia
    #1424
    Моите са SSG-3100GB. Не съм забелязвал ghosting при местене на главата
  18. Banned
    Dec 2010
    #1425
    Цитат Първоначално публикувано от regned
    ПОМОЩ!
    С последния фърмуеър ли си,имаш ли някакви пробл с него,довйния образ при гледане на 3Д оправиха ли го?
  1. Отговори: 1434
    Последно: 12-12-13, 19:18
  2. Отговори: 1599
    Последно: 30-11-13, 22:51
  3. Отговори: 1511
    Последно: 20-10-12, 12:45
  4. Отговори: 1375
    Последно: 30-09-11, 17:31
  5. Отговори: 1307
    Последно: 26-05-11, 16:46
