Страница 32 от 55 ПърваПърва ... 22303132333442 ... ПоследноПоследно
Резултати от 466 до 480 от общо 822
Like Tree136Одобрявам
Samsung телевизори 2016
    #466
    Отговор: Samsung телевизори 2016
    https://www.youtube.com/watch?v=Qme7XGhjoZw
    https://wiki.samygo.tv/index.php5?ti...ps_on_H-Series
    https://www.samsungdforum.com/
    Samsung KS8000 review - FlatpanelsHD
    Google translate En to Bg
    Samsung European UHD TV 2016
    Product
    ____________
    Certification UHD
    Premium
    ________________
    Resolution: 3,840x2,160.
    Color depth: 10-bit.
    Color gamut: Wide, including the ability to show at least 90 percent of the P3 color gamut .
    High dynamic range: Specifically the ability to use SMPTE ST2084's electro-optical transfer function, which Dolby helped create .
    Minimum brightness and contrast ratios: There are two possible minimum specs. A minimum brightness of 1,000 nits, along with a black level of a maximum of 0.05 nits (20,000:1 contrast ratio), or a minimum brightness of 540 nits, along with a black level of a maximum of 0.0005 (1,080,000:1)
    Dolby Vision
    _____________________
    The metadata is graded in each scene so you get different grades throughout the file. Dolby tells us that scene by scene grading is the superior way to grade a movie, which on paper does sound more efficient.
    Standard: Poprietary
    Peak Luminance: Up to 10,000 nits
    Video Bit Depth: 12-bit
    Metadata: Dynamic (scene by scene)
    Software Upgradability: No(SoC hardware-embedded)
    HDR 10
    The metadata is graded and determined, and is then sent
    at the beginning of the file
    and covers the entire file.
    One set of metadata
    Standard: Open
    Peak Luminance: Up to 4,000 nits
    Video Bit Depth: 10-bit
    Metadata: Static (per title)
    Software Upgradability: Yes
    Videopanel
    ____________________________________
    Type LCD matrix,
    Bits of color,
    Operating frequency of T-Con board of the panel,
    Curvature,
    MEMC,
    Index,
    Anti-reflective filter
    Backlight
    Type backlight
    (Local Dimming zone)
    Type LED
    Puls Wide Modulation
    Color Space
    DCI P3
    Rec.2020
    Contrast
    White & Black level
    ANSI
    With local dimming
    Without local dimming
    Viewing
    angle
    ___________
    Input Lag
    SoC
    CPU
    GPU
    Platform
    OS
    _____________
    Ports
    Networks
    Tuner
    _________________
    Picture Accuracy
    Out-of-the-Box
    (score out of 10)
    _______________
    Product
    KS9800
    (curved)
    88"
    Technically it is a KS9500 – just larger and with a slightly different design.
    Yes No 88" - max-1250 cd/m²
    Yes HDR10
    88"- SVA,10bit ?, 120/100Hz, Curvature 4200R
    BFI - Scaning Backlight (Led Clear Motion)
    Picture Quality Index - 2600
    Moth Eye (anti-reflective filter)
    88" - FALD, Direct Led
    ? - Local Dimming zones
    Blue Leds with RG phosphorus
    PWM Freq,-120/100Hz
    88"-DCI P3- 96% / Rec.2020-
    Quantum Dots
    88" - 88" - 88" - Game mode -
    ARMv7
    Cortex-A7
    Quad Core 1.2GHz
    16_DTV_JazzM
    Tizen 2,4 OS
    2 x USB 2.0
    1 x USB 3.1
    4 x HDMI 2.0 (ARC, CEC,MHL)
    1 x Satelite In (Main: F-type female)
    1 x Satelite In (Sub:F-type female)
    1 x Optical Audio Out
    1 x RS 232 C
    1 x Antena (RF) (female)
    One Connect
    1 x USB
    1 x Ethernet RJ45
    1 x CI+ 1.3
    in TV
    Lan - Ethernet RJ45
    Wi-Fi
    802.11 a
    802.11 b
    802.11 n
    802.11 n 5GHz
    802.11 ac
    Wi-Fi Direct, Screen Mirroring
    Bluetooth
    DLNA(RUI2.0/DTCP-IP/DMP/DMR/DMS)
    Dual tuners
    DVB -T/ T2/C/S/S2
    with PVR and PIP function + Timeshift
    DiSEqC version 1.0
    Analog (PAL,SECAM)
    HEVC
    KS9800
    KS9500
    (curved)
    78", 65", 55"
    Yes No 78" - max 1000cd/m²
    65" - 10% window max - 1473cd/m2
    100% window max - 615cd/m2
    55" - max
    Yes HDR10
    Delta E <1 of all levels of brightness
    78"- SVA, 10bit, 120/100Hz, Curvature 4200R
    65"- SVA, 10bit, 120/100Hz, Curvature 4200R
    55"- SVA, 10bit, 120/100Hz, Curvature 4200R
    BFI - Flashing Backlight (Led Clear Motion)
    Picture Quality Index - 2700
    78" - FALD, Direct Led
    65" - FALD, 15x10 - 150 zones
    55" - FALD, Direct Led
    PWM Freq. - 120/400Hz
    78"- DCI P3 -
    65"- DCI P3 - 96% / Rec.2020-72%
    55"- DCI P3- 96% / Rec.2020- 72%
    Quantum Dots
    78" -
    65" - SD - ANSI 3783:1 / 120cd/m2 / 0.014cd/m2
    with local dimming - 8571cd/m2 / 0.001cd/m2
    55" -
    78" -
    65" - 60° (cone)
    55" -
    78" - Game mode 21ms / by default
    65" - Game mode 20ms /
    55" - Game mode 20ms /
    ARMv7
    Quad Core
    1.2GHz
    16_DTV_JazzM
    Tizen 2,4 OS
    2 x USB 2.0
    1 x USB 3.1
    1 x Ethernet RJ45
    1 x RS 232 C
    in One Connect
    1 x USB
    1 x Ethernet RJ45
    1 x CI+ 1.3
    1 x One Connect Port
    in TV
    Lan - Ethernet RJ45
    Wi-Fi
    802.11 a
    802.11 b
    802.11 n
    802.11 n 5GHz
    802.11 ac
    Bluetooth
    Dual tuners
    DVB -T/ T2/C/S/S2
    DiSEqC version 1.0
    Analog (PAL,SECAM)
    HEVC
    VP9 profile 2
    CMS
    White balans
    KS9500
    KS9000
    (curved)
    78", 65", 55", 49"
    Yes No 75" - max-1000cd/m2
    65" - max-1197cd/m2/ SD- 460cd/m2
    55" - max-1000cd/m
    49" - max 520cd/m2 full display / 1550cd/m2 for 3 sekonds /
    Yes HDR1000
    75"- SVA or AMVA, ? ,120/100Hz,
    49"- SVA, 10bit, 120/100Hz, Curvature 3000R
    Picture Quality Index - 2400
    75" -
    65" - Edge LED - below
    55" - Edge Led
    8 vertical columns of dimmable zones
    49" - Edge Led
    PWM Freq,-120/100Hz
    75"- DCI P3 -
    65"- DCI P3 -
    49"- DCI P3- 96% / Rec.2020- 76%
    Quantum Dots
    75" -
    65" -
    55" - 2688:1 / 0.039cd/m2
    49" - ANSI 2900:1 /
    75" -
    65" -
    55" - 20° (cone)
    49" -
    75" - Game mode 21ms / by default -
    65" - Game mode 20ms / by default -
    55" - Game mode 20ms / by default -
    49" - Game mode 20ms / by default -
    ARMv7
    Quad Core
    1.2Ghz
    16_DTV_JazzM
    Tizen 2,4 OS
    2 x USB 2.0
    1 x USB 3.1
    4 x HDMI 2.0 (ARC, CEC, MHL)
    1 x RS 232 C
    in One Connect
    1 x USB
    1 x CI+ 1.3
    1 x Ethernet RJ45
    in TV
    Lan - Ethernet RJ45
    Wi-Fi
    802.11 a
    802.11 b
    802.11 n
    802.11 n 5GHz
    802.11 ac
    Bluetooth
    Dual tuners
    DVB -T/ T2/C/S/S2
    DiSEqC version 1.0
    Analog (PAL,SECAM)
    HEVC
    VP9 profile 2
    Rec.2020 settings are not correct
    KS9000
    KS8000
    75", 65", 55", 49"
    Yes No 75" - max
    65" - 10% window max 766cd/m2
    55"- 2% window max 1410cd/m2
    55"- 100% window max 490cd/m2
    49" - max 1270cd/m2 /SD- 450cd/m2
    The TV is able to maintain the maximum brightness for a short time, and after about 15 seconds it drops down to about 450cd/m2.
    Yes HDR1000
    75"- SVA or AMVA, 10-bit , 120/100Hz
    Picture Quality Index 2300
    75" - Edge LED - below
    65" - Edge Led
    55"- 8 vertical columns of dimmable zones
    49" - Edge Led
    PWM Freq,-120/100Hz
    75" - DCI P3 -
    65" - DCI P3 -
    55" - DCI P3- 93% / Rec.2020- 70%
    49" - DCI P3 -
    Quantum Dots
    75" -
    65" - 4018:1 / 0.034cd/m2 / 167cd/m2
    55" - 6820:1 /0.014cd/m2 / 95.48cd/m2
    49" - 4080:1 / 0.027cd/m2 /
    75" -
    65" -
    55" - 20° (cone)
    49" -
    75" - Game mode 20ms / by default - 120ms
    65" - Game mode 20ms / by default - 120ms
    49" - Game mode 21ms / by default - 120ms
    ARMv7
    Quad Core
    1.2GHz
    16_DTV_JazzM
    Tizen 2,4 OS
    2 x USB 2.0
    1 x USB 3.1
    1 x RS 232 C
    in One Connect
    1 x USB
    1 x CI+ 1.3
    1 x Ethernet RJ45
    in TV
    Lan - Ethernet RJ45
    Wi-Fi
    802.11 a
    802.11 b
    802.11 n
    802.11 n 5GHz
    802.11 ac
    Bluetooth
    Dual tuners
    DVB -T/ T2/C/S/S2
    with PVR and PIP function + Tmeshift
    DiSEqC version 1.0
    Analog (PAL,SECAM)
    HEVC
    VP9 profile 2
    KS8000
    KS7500
    (curved)
    65", 55", 49", 43"
    Yes? No 65" - max
    55" - max 1185cd/m² - 1600cd/m2
    49" - max
    43" - max
    Yes HDR1000
    65" - SVA, 8-bit+FRC, 120/100Hz, 4200R
    55" - SVA, 8-bit+FRC, 120/100Hz, 4200R
    49" - SVA, 8-bit+FRC, 120/100Hz, 3000R
    43" - AMVA3, 8-bit+FRC, 120/100Hz, 3000R
    PQI - 2000 [43"] / 2200 [≥49"]
    (55"- 8 vertical columns of dimmable zones)
    49" -
    43" -
    PWM Freq,-120/100Hz
    65"- DCI P3- / Rec.2020-
    49"- DCI P3- / Rec.2020-
    43"- DCI P3- / Rec.2020-
    Quantum Dots
    65" -
    55" - ANSI 4000:1/0.03-0.043cd/m2
    native 2600:1 /0.046cd/m2/120cd/m2
    49" -
    43" -
    65" -
    55" - 30° (cone)
    49" -
    43" -
    65" - Game mode 21,8ms
    55" - Game mode 21.7ms / by default
    49" - Game mode 21.5ms
    43" - Game mode 21 ms
    ARMv7
    Quad Core
    1GHz
    16_DTV_JazzM
    Tizen 2,4 OS
    2 x USB 2.0
    1 x USB 3.1
    in One Connect
    1 x USB
    1 x Ethernet RJ45
    1 x CI+ 1.3
    in TV
    Lan - Ethernet RJ45
    Wi-Fi
    802.11 a
    802.11 b
    802.11 n
    802.11 n 5GHz
    802.11 ac
    Wi-Fi Direct
    Bluetooth, Screen Mirroring
    Dual tuners
    DVB -T/ T2/C/S/S2
    DiSEqC version 1.0
    Analog (PAL,SECAM)
    HEVC
    VP9 profile 2
    Vertical Blooming
    Variable depth of black in HDR mode
    Sometimes black in HDR mode is approximately 0.20cd/m², which is comparable to the black level of the panel IPS!
    KS7500
    KS7000
    65", 60", 55", 49"
    Yes ? No 65" - max-1000cd/m²
    60" - max-1000cd/m2
    55" - 10% window max-1402d/m2/
    100% window max - 537cd/m2
    SD - 486cd/m2
    49" - max-1000cd/m2
    Yes HDR1000
    60" - SVA, 8-bit+FRC, 120/100Hz
    Picture Quality Index - 2100
    65" - Edge Led - below
    60" - Edge Led - below
    (55"- Edge led - below
    49"' - Edge Led - below
    PWM Freq,-120/100Hz
    60"- DCI P3- / Rec.2020-
    55"- DCI P3- 96% / Rec.2020- 71%
    Quantum Dots
    65" -
    60" -
    55" - native - 4000:1 / 138cd/m2/0.033cd/m2
    ANSI 3140:1 / with local dimming 0.002cd/m2
    49" -
    65" -
    60" -
    55" - 20° (cone)
    49" -
    65" - Game mode
    60" - Game mode
    55" - Game mode 21ms / by default 112ms
    ARMv7
    Quad Core
    1GHz
    16_DTV_JazzM
    Tizen 2,4 OS
    2 x USB 2.0
    1 x USB 3.1
    3 x HDMI 2.0 (ARC, CEC)
    1 x RS 232 C
    in One Connect
    1 x USB
    1 x Ethernet RJ45
    1 x CI+ 1.3
    in TV
    Lan - Ethernet RJ45
    Wi-Fi
    802.11 a
    802.11 b
    802.11 n
    802.11 n 5GHz
    802.11 ac
    Bluetooth ver. 4.0
    DVB - T/T2/C/S/S2
    with PVR function
    DiSEqC version 1.0
    Analog (PAL,SECAM)
    HEVC
    VP9 profile 2
    The HDR EOTF was extremely good but the colour gamut wasn't tracking Rec.2020 correctly. Vertical Blooming
    KS7000
    KU6600
    (curved)
    65", 55", 49", 43"
    No No 65" -
    55" -
    49" -
    43" -
    Compatible
    65" - SVA, 8-bit, ?Hz, Curvature 4200R
    55" - SVA, 8-bit, 60/50Hz, Curvature 4200R
    49" - SVA, 8-bit, 60/50Hz, Curvature 3000R
    43" - SVA, 8-bit, 60/50Hz, Curvature 3000R
    Picture Quality Index - 1600
    65" - Direct led
    55" - Direct Led
    49" - Direct Led
    43" - Direct Led
    PWM Freq,-120/100Hz
    65"-
    55"-
    49"-
    43"-
    65" -
    55" -
    49" -
    43" -
    65" -
    55" -
    49" -
    43" -
    65" - Game mode
    55" - Game mode
    49" - Game mode
    43" - Game mode
    Quad Core
    1GHz
    16_DTV_JazzL
    Tizen 2,4 OS
    2 x USB 2.0
    1 x USB 3.1
    1 x Ethernet RJ45
    1 x AV Composite In 3.5mm jack
    1 x V Component In 3.5mm jack
    1 x RS 232 C
    1 x CI+ 1.3
    Lan - Ethernet RJ45
    Wi-Fi
    802.11 a
    802.11 b
    802.11 n
    802.11 n 5GHz
    802.11 ac
    Bluetooth ver. 4.0
    Wi-Fi Direct
    DVB -T/ T2/C/S/S2
    with PVR function
    DiSEqC version 1.0
    Analog (PAL,SECAM)
    HEVC
    KU6600
    KU6500
    (curved)
    78", 65", 55", 49", 43"
    No No 78" - max
    65" - max
    55" - max 290cd/m2 / SD- 290cd/m2
    49" - max
    43" - max
    Compatible
    78" - VA, 8-bit, Hz?, Curvature 4200R
    65" - VA, 8-bit, Hz?, Curvature 4200R
    55" - VA, 8-bit, 60/50Hz, Curvature 4200R
    49" - VA, 8-bit, 60/50Hz, Curvature 3000R
    43" - VA, 8-bit, 60/50Hz, Curvature 3000R
    Picture Quality Index 1600
    78" - Direct led
    65" - Direct Led
    55" - Direct Led
    49" - Direct Led
    43" - Direct Led
    PWM Freq,-120/100Hz
    78"-
    65"-
    55"-
    49"-
    43"-
    78" -
    65" -
    55" -
    49" -
    43" -
    78" -
    65" -
    55" -
    49" -
    43" -
    78" - Game mode
    65" -
    55" -
    49" -
    43" -
    Quad Core
    16_DTV_JazzL
    Tizen 2,4 OS
    2 x USB 2.0
    1 x Ethernet RJ45
    4 x HDMI 2.0 (ARC, CEC)
    1 x CI+ 1.3
    Lan - Ethernet RJ45
    Wi-Fi
    802.11 a
    802.11 b
    802.11 n
    802.11 ac
    Bluetooth ver. 4.0
    Wi-Fi Direct
    DVB - T/T2/C/S/S2
    with PVR function
    DiSEqC version 1.0
    Analog (PAL,SECAM)
    HEVC
    KU6500
    KU6400
    65", 55", 49", 43", 40"
    No No 65" -
    55" -
    49" -
    43" -
    40" -
    Compatible
    65" - VA, 8-bit, ?Hz
    40" - VA, 8-bit, 60/50Hz
    Motion Interpolation (30fps)
    Picture Quality Index 1500
    65" - Edge Led
    55" - Edge Led
    49" - Edge Led below
    43" - Edge Led below
    40" - Edge Led below
    NO Local Dimming
    PWM Freq,-120/100Hz
    65"-
    55"-
    49"-
    43"-
    40"-
    65"-
    55"-
    49"-
    43"-
    40"-
    65"-
    55"-
    49"-
    43"-
    40"-
    65" -
    55" -
    49" -
    43" -
    40" -
    16_DTV_JazzL
    Tizen 2,4 OS
    2 x USB 2.0
    1 x Ethernet RJ45
    1 x CI+ 1.3
    Lan
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 ac
    Bluetooth ver. 4.0 HID
    Wi-Fi Direct
    DLNA
    DVB - T/T2/C/S/S2
    with PVR function
    DiSEqC version 1.0
    Analog (PAL,SECAM)
    HEVC
    KU6400
    KU6300
    (curved)
    No No 78" -
    65" -
    55" - max 440cd/m2
    49" -
    43" -
    Compatible
    65" - VA, 8-bit, 60/50Hz, Curvature 4200R
    55" - VA, 8-bit, 6050/Hz, Curvature 4200R
    40" - VA, 8-bit, 60/50Hz, Curvature 3000R
    Picture Quality Index 1400
    65" - Led
    55" - Direct Led ?
    49" -
    43" -
    40" -
    NO Local Dimming
    PWM Freq,-120/100Hz
    65" -
    55" -
    49" -
    43" -
    40" -
    65" -
    55" - 4508:1 /108.2cd/m2 / 0.024cd/m2
    49" -
    43" -
    40" -
    65" -
    55" -
    49" -
    43" -
    40" -
    65" -
    55" - 19.8ms
    49" -
    43" -
    40" -
    16_DTV_JazzL
    Tizen 2,4 OS
    2 x USB 2.0
    1 x Ethernet RJ45
    1 x CI+ 1.3
    Lan
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    802.11 ac
    Wi-Fi Direct
    DLNA
    DVB -T/ T2/C
    Analog (PAL,SECAM)
    HEVC
    KU6300
    KU6100
    (curved)
    No No 65" -
    55" -
    49" -
    43" -
    40" -
    Compatible
    65" - VA, 8-bit, ?Hz, Curvature 4200R
    Picture Quality Index 1300
    65" - Edge Led
    55" -
    49" -
    43" -
    40" -
    NO Local Dimming
    PWM Freq,-120/100Hz
    65" -
    55" -
    49" -
    43" -
    40" -
    65" -
    55" -
    49" -
    43" -
    40" -
    65" -
    55" -
    49" -
    43" -
    40" -
    65" -
    55" -
    49" -
    43" -
    40" -
    16_DTV_JazzL
    Tizen 2,4 OS
    2 x USB 2.0
    1 x Ethernet RJ45
    1 x CI+ 1.3
    Lan
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    Bluetooth
    Wi-Fi Direct
    DLNA
    DVB -T/ T2/C
    Analog (PAL,SECAM)
    HEVC
    KU6100
    KU6000
    70", 65", 60", 55", 50", 49", 43", 40"
    No No Compatible 70" - VA, 8-bit, ?Hz
    60" - VA, 8-bit, ?Hz
    50" - VA, 8-bit, 60/50Hz
    70" - Edge Led
    65" - Edge Led
    60" - Edge Led
    55" - Edge Led
    50" - Edge Led below
    NO Local Dimming
    PWM Freq,-120/100Hz
    70"-
    65"-
    60"-
    55"-
    50"-
    49"-
    43"-
    40"-
    70"-
    65"-
    60"-
    55"-
    50"-
    49"-
    43"-
    40"-
    70"-
    65"-
    60"-
    55"-
    50"-
    49"-
    43"-
    40"-
    70" -
    65" -
    60" -
    55" -
    50" -
    49" -
    43" -
    40" -
    16_DTV_JazzL
    Tizen 2,4 OS
    2 x USB 2.0
    1 x Ethernet RJ45
    1 x CI+ 1.3
    Lan
    a/b/g/n
    Wi-Fi Direct
    DLNA
    DVB - T/T2/C
    with PVR function
    Analog (PAL,SECAM)
    HEVC
    KU6000
    Samsung FHD TV 2016
    Product
    ____________
    Certification
    UHD
    Premium
    _____
    Dolby
    Vision
    _____
    HDR
    _______________
    Videopanel
    (type matrix, bit, curvature)
    Backlight
    ___________________
    Dimming
    Color Space
    Contrast & Black level
    Viewing angle
    ____________
    Input
    Lag
    ________
    SoC
    Platform
    OS
    __________
    Ports
    Networks
    Tuner
    _________________
    Picture Accuracy
    Out-of-the-Box
    (score out of 10)
    ___________
    Product
    K6500
    55", 49", 40"
    No No No 55" - VA, 8-bit, 120/100Hz
    49" - VA, 8-bit, 120/100Hz
    40" - VA, 8-bit, 120/100Hz
    55" - Edge Led
    49" - Edge Led
    40" - Edge Led
    55" -
    49" -
    40" -
    55" -
    49" -
    40" -
    55" -
    49" -
    40" -
    55" -
    49" -
    40" -
    16_DTV_HawkM
    Tizen 2,4 OS
    Вluеtооth Vеr. 4.0 HID Lan
    a/b/g/n
    Wi-Fi Direct
    DLNA
    DVB -T/ T2/C
    with PVR function
    Analog (PAL,SECAM)
    K6500
    K6300
    (curved)
    55", 49", 40"
    No No No 55" - , 8-bit, 60/50Hz
    49" - , 8-bit, 60/50Hz
    Picture Quality Index 800
    55" - Edge Led
    49" - Edge led
    40" - Edge Led
    55" -
    49" -
    40" -
    55" -
    49" -
    40" -
    55" -
    49" -
    40" -
    55" -
    49" -
    40" -
    16_DTV_HawkM
    Tizen 2,4 OS
    a/b/g/n
    Wi-Fi Direct
    DLNA
    Bluetooth
    DVB - T/T2/C
    Analog (PAL,SECAM)
    K6300
    K6000
    70",65", 60",55", 50", 43", 40"
    No No No 70" -
    60" - VA, 8-bit, 60/50Hz
    50" - , 8-bit, 60/50Hz
    43" - , 8-bit, 60/50Hz
    40" - VA, 8-bit, 60/50 Hz
    70" - Edge Led
    60" - Edge Led
    55" - Edge Led
    50" - Edge Led
    43" - Edge Led
    40" - Edge Led
    70" -
    65" -
    60" -
    55" -
    50" -
    43" -
    40" -
    70" -
    65" -
    60" -
    55" -
    50" -
    43" -
    40" -
    70" -
    65" -
    60" -
    55" -
    50" -
    43" -
    40" -
    70" -
    65" -
    60" -
    55" -
    50" -
    43" -
    40" -
    16_DTV_HawkM
    Tizen 2,4 OS
    a/b/g/n
    Wi-Fi Direct
    DLNA
    Bluetooth
    DVB - T/T2/C
    Analog (PAL,SECAM)
    K6000
    K5600
    55", 49", 40", 32"
    No No No 55" - 8-bit, 60/50Hz
    32" - 8-bit, 60/50Hz
    Picture Quality Index 400
    55" - Edge Led
    49" - Edge Led
    40" - Edge Led
    32" - Edge Led
    55" -
    49" -
    40" -
    32" -
    55" -
    49" -
    40" -
    32" -
    55" -
    49" -
    40" -
    32" -
    55" -
    49" -
    40" -
    32" -
    16_DTV_HawkM
    a/b/g/n
    Wi-Fi Direct
    DLNA
    DVB - T/T2/C
    Analog (PAL,SECAM)
    K5600
    K5500
    55", 49", 40", 32"
    32" - , 8-bit, 60/50Hz
    55" - Edge Led
    49" - Edge Led
    40" - Edge Led
    32" - Edge Led
    55" -
    49" -
    40" -
    32" -
    55" -
    49" -
    40" -
    32" -
    55" -
    49" -
    40" -
    32" -
    55" -
    49" -
    40" -
    32" -
    16_DTV_HawkM
    Tizen 2,4 OS
    a/b/g/n
    Wi-Fi Direct
    DLNA
    DVB - T/T2/C
    Analog (PAL,SECAM)
    K5500
    K5100
    40"
    No No No 40" - VA, 8bit, 60/50Hz
    Picture Quality Index 200
    40" - Edge Led 40" - 40" - 40" - Вluеtооth Vеr. 4.0 HID Lan
    a/b/g/n
    Wi-Fi Direct
    DLNA
    DVB - T/T2/C
    Analog (PAL,SECAM)
    K5100
    Този пост е редактиран от hristoslav2; 20-07-16 в 21:53.
  3. Junior Member Аватара на troll4o
    Aug 2013
    #467
    Цитат Първоначално публикувано от Todor Kanev Виж публикацията
    Колеги едно въпросче,възможно ли е да се инсталират неофициални приложения на samsung 49KS7000,вградените са доста калпави не кефят
    Кои не официални приложения те интригуват?
    Sent from my K00Z using Tapatalk
    #468
    Review: Samsung UN65KS9800 Raises The Bar On HDR | HD Guru
    За тези, които са пропуснали дотук ревютата за Samsung модели 2016
    KS9800
    Samsung KS9800 Series HDR LED TV Review - Reviewed.com Televisions
    KS9500/KS9000
    Review: Samsung’s 4K Ultra HD UN65KS9500 Brings HDR Home | HD Guru
    Samsung KS9500 Review (UN55KS9500, UN65KS9500)
    Samsung KS9500 LED TV Calibration Settings
    https://www.avforums.com/review/sams...v-review.12673
    Samsung UE65KS9500 (KS9500/ KS9800) Review
    https://www.homecinemamagazine.nl/20...erie-s-uhd-tv/
    KS9000
    Samsung UE55KS9000 (KS9000) 4K HDR TV Review
    https://www.avforums.com/review/sams...v-review.12481
    https://www.youtube.com/watch?v=Z8EZUF0eNFU
    Samsung KS9000 (UE49KS9000) Test - SUHD, Ultra HD Premium - SAMSUNG - HDTV Centrum Polska
    https://www.avforums.com/review/sams...v-review.12269
    KS8500
    Samsung KS8500 Review - 2016 4K Smart TV - UN55KS8500, UN65KS8500
    Samsung KS8500 Review (UN49KS8500, UN55KS8500, UN65KS8500)
    KS8000
    https://reviews.lcdtvbuyingguide.com...n55ks8000.html
    Samsung KS8000 Review (UN49KS8000, UN55KS8000, UN60KS8000, UN65KS8000)
    Samsung KS8000 LED TV Calibration Settings
    (USA KS9000 EU KS8000 ?) Samsung KS9000 Review (UN55KS9000, UN65KS9000, UN75KS9000)
    Samsung UE49KS8000 - test
    KS7500
    Samsung UE55KS7500 (KS7500) Review
    https://www.avforums.com/review/sams...v-review.12590
    https://www.youtube.com/watch?v=XaPNxfSBOJU
    Test Samsung UE55KS7500 : un TV certifié UHD Premium | HDfever
    KS7000
    Samsung UE55KS7000 : Test complet - Les Numériques
    https://www.avforums.com/review/sams...v-review.12659
    KU7000
    Samsung KU7000 Review (UN40KU7000, UN43KU7000, UN49KU7000, UN55KU7000, UN65KU7000)
    KU6300
    Samsung KU6300 Review (UN40KU6300, UN43KU6300, UN50KU6300, UN55KU6300, UN60KU6300, UN65KU6300, UN70KU6300)
    Jun 2010
    Burgas
    #469
    Днес закупих кс7002 но в смарт магазина има много малко приложения.Как да добавя приложението на булсатком?Няма го в магазина а на други самсунги съм го виждал в магазина им.Нямаше и упътване в кашона което ме кара да се чудя че може да са ми пробутали някоя мостра.
    Aug 2015
    #470
    Хвърлил съм око на 40KU6300. Дали ще ги има скоро по магазините и на каква ли ще е цена. Сравнявах го с 40JU6500 и е малко по-добър за монитор и видео игри.
    #471
    Цитат Първоначално публикувано от sasho1bs Виж публикацията
    Днес закупих кс7002 но в смарт магазина има много малко приложения.Как да добавя приложението на булсатком?Няма го в магазина а на други самсунги съм го виждал в магазина им. Нямаше и упътване в кашона което ме кара да се чудя, че може да са ми пробутали някоя мостра.
    Така е - всички приложения трябва първо да се преработят под Tizen преди да ги качат на платформата.
    https://developer.tizen.org/design/p.../new-tizen-2.4
    Цитат Първоначално публикувано от paradisee Виж публикацията
    Попитай Самсунг България. Какво ще се продава на нашият пазар го решават техните маркетолози в централата.
    Свържете се с нас | Samsung BG
    Има го в Украина, *****, Казахстан и Турция...
    Този пост е редактиран от hristoslav2; 24-07-16 в 12:59.
  9. Member Аватара на Сидеров
    Feb 2016
    #472
    Вкарали са к6300 съмнявам се да вкарат ку6300
  10. Junior Member
    Feb 2015
    #473
    Относно не работещите видео клипове в приложението на Нова Плей, ето какво отговориха от Нова:
    Oт известно време има технически проблем с приложението за Samsung Smart TV.
    Приложението се разработва съвместно с колегите от Samsung и заедно работим по отстраняването на проблема, но за съжаление неможем да дадем срок, в който проблемът ще бъдеотстранен.
    Надяваме се това да стане в близките няколко седмици.
    Екип Nova Play
    dnedkov одобрява това.
    #474
    Този пост е редактиран от hristoslav2; 27-07-16 в 20:50.
    Jun 2010
    Burgas
    #475
    Книжка с упътване само при мен ли няма?
    #476
    Книжката вече е електронна - e-help
    Този пост е редактиран от hristoslav2; 29-07-16 в 22:00.
    sasho1bs одобрява това.
    Jun 2010
    Burgas
    #478
    След като изгледах това видео https://www.youtube.com/watch?v=hrrlQVcW2Zc установих че и моя е леко отворен от дясно Бях потресен и съм много ядосан.Вече съм на 5 ти ден от както го купих и няма връщане назад.Много съм разочарован и дано не попречи на картината или не се отваря повече .
  17. Senior Member Аватара на svetlio1
    #479
    Двойно залепващо тиксо за захващане на капака във висок клас тв - потресен съм - тия вече хептен за канарчета ни вземат ... какво следва - плюнка и дъвка
    Този пост е редактиран от svetlio1; 31-07-16 в 19:34.
  18. Infraction Users
    Sep 2011
    #480
    Естествено, че има връщай го! Това си е за рекламация!
  1. Избор на климатик 2016 г.
    Отговори: 3492
    Последно: 01-01-17, 18:50
  2. Samsung Телевизори 2015
    Отговори: 1121
    Последно: 02-01-16, 09:17
  3. Има ли пасивни 3D телевизори на Samsung?
    Последно: 21-10-14, 23:00
  4. Samsung спира производството на OLED телевизори
    Последно: 07-05-14, 15:20
  5. Отговори: 6
    Последно: 16-08-11, 14:39
