mi az ne sum golqm spec ama sym s ME i si imam dos to4no kato pri 98))))
ima edin patch WinMEDos mu se vika , ta toi ti ebava 3 filesa ot koito edinq e command.com , drugiqt e io.sys tretiq ve4e ne go pomnq))) ta sled kat se pa4nat tretiq det go neznam se furlq v system dira , command-a se metka v win dira i v roota i io.sys-a v wina , sled tva ve4e moejesh da si polzvash autoexeca i config-a kakto pri 98cata , v configa oba4e zaduljitelno se zarejda IFSHLP.SYS v menuto za start na wina (ako imash menu de )ako ne se metka na koi si red iskash
btw tam si ima TXT de ama na kratko izglejda taka
1. Copy the patched files to their destination, overwriting the original ones:
"IO.SYS" to "C:\"
"COMMAND.COM" to both "C:\WINDOWS\" and "C:\"
"REGENV32.EXE" to "C:\WINDOWS\SYSTEM"
2. Edit "C:\CONFIG.SYS" and "C:\AUTOEXEC.BAT" changing them as described below:
Add to "CONFIG.SYS" the line: "DEVICE=C:\WINDOWS\IFSHLP.SYS".
mi tva e ot mene . dano sym ti bil polezen ;o))))
