Резултати от 16 до 30 от общо 43
Like Tree5Одобрявам
Xiaomi телевизори (инфо на първа страница)
    #16
    Отговор: Xiaomi телевизори (инфо на първа страница)
    Xiaomi Mi LED TV P1 32 (L32M6-6AEU) review
    https://geex.x-kom.pl/recenzje/xiaom...ja-telewizora/
    L32M6-6AEU: VA panel-4 domain,horizontal stripe,RGB,
    Direct LED LCD
    60Hz
    HD 1366 × 768
    android tv 9
    Серии 2021
    Xiaomi Mi TV 6 Extreme Edition (L55M7-Z1 / L65M7-Z1 / L75M7-Z1)
    Xiaomi Mi TV P1 (L32M6-6AEU / L43M6-6AEU / L50M6-6AEU / L55M6-6AEU)
    Xiaomi Mi TV Q1 ()
    Xiaomi Redmi Smart TV ()
    Този пост е редактиран от hristoslav2; 02-08-21 в 21:08.
    #17
    Xiaomi L55M6-6AEU Mi LED TV P1 review
    https://geex.x-kom.pl/recenzje/xiaom...telewizora-4k/
    L55M6-6AEU: VA panel,, Direct LED LCD, 60Hz
    Input lag - 9.8 ms
    CPU: Quad A55, up to 1.5GHz, MediaTek 9611
    GPU: Mali G52 MP2
    RAM: 2GB
    Storage: 16GB
    Operating system: Android TV™ 10
    Bluetooth : BT5.0
    Внимание! Въпреки опцията HDMI 2.1, видима в менюто, Xiaomi L55M6 няма такъв тип конектор (има 3 HDMI 2.0 гнезда с максимална тактова честота 600MHz).
    The black level was well set at the factory (50), while the white level ( contrast option ) is worth lowering from 50 to 49.
    Fortunately, the Xiaomi L55M6 does not use global dimming ( frame dimming ).
    HDR
    Support for HDR content is not the strong point of the Xiaomi L55M6.
    On the board occupying 10% of the screen area, the maximum luminance (three minutes after the start of the measurement) was 336 nits, which is a result slightly below average.
    The Xiaomi L55M6 uses a 60Hz class LCD matrix, therefore the maximum sharpness of moving images (in all modes) is very low: only 150 lines at 1080 maximum.
    Този пост е редактиран от hristoslav2; 02-08-21 в 20:39.
    #18
    Бъдещите продукти на Xiaomi няма да носят префикса MI.
    https://www.xda-developers.com/xiaom...s-mi-branding/
    Xiaomi Mi TV 6 Extreme Edition с модели L55M7-Z1, L65M7-Z1 и L75M7-Z1
    https://www.amd.com/en/products/freesync-tvs
    MODEL FREESYNC MANUFACTURER SIZE LCD TYPE RESOLUTION RANGE INTERFACE LFC HDR
    L75M7-Z1 FreeSync Premium Xiaomi 75.0" VA 3840x2160 48-120 via HDMI HDMI® Yes Yes
    L55M7-Z1 FreeSync Premium Xiaomi 55.0" VA 3840x2160 48-120 via HDMI HDMI® Yes Yes
    L65M7-Z1 FreeSync Premium Xiaomi 65.0" IPS 3840x2160 48-120 via HDMI HDMI® Yes Yes
    Specifications Xiaomi Mi TV P1 32″
    LCD panel with 16: 9 aspect ratio
    32 ″ size with HD resolution 1,366 x 768 dots
    60Hz native refresh
    Color Gamut: 64 % NTSC (typ.), 90 % BT709 (typ.), 72 % DCI-P3 (typ.)
    MSD6683 Processor up to 1.2Ghz with Mali 470 MP3 GPU
    1.5GB RAM with 8GB eMMC storage
    Android TV 9 operating system (with Chromecast built-in)
    10W sound system with Dolby Audio and DTS HD
    WiFi and Bluetooth 5.0 wireless connectivity
    Connections 3 x HDMI (1 x eARC), 2 x USB 2.0, 1 x Ethernet ...
    Dimensions of length 733mm x 180mm x 479mm
    weight of 3.9kg (with base included)
    Specifications Xiaomi Mi TV P1 43″
    Panel with 16: 9 aspect ratio
    43 ″ size with 4K UHD resolution 3,840 x 2,160 dots
    60Hz native refresh
    Color Gamut: 72 % NTSC (typ.), 78 % DCI-P3 (typ.), 95 % BT709 (typ.)
    MEDIATEK MT9611 processor up to 1.5Ghz with Mali G52 MP2 GPU
    2GB RAM with 16GB eMMC storage
    Android TV 10 operating system (with Chromecast built-in)
    20W (2X10W) sound system with Dolby Audio and DTS HD
    Dimensions of length 962mm x 205mm x 625mm
    weight of 7.4Kg (with base included)
    Specifications Xiaomi Mi TV P1 50″
    50 ″ size with 4K UHD resolution 3,840 x 2,160 dots
    60Hz HDR + native refresh
    Color Gamut: 88 % NTSC (typ.), 94 % DCI-P3 (typ.), 99.5 % BT709 (typ.)
    Dimensions of length 1117.2mm x 276.8mm x 710.6mm
    weight of 9.9Kg (with base included)
    Specifications Xiaomi Mi TV P1 55″
    55 ″ size with 4K UHD resolution 3,840 x 2,160 dots
    Dimensions of length 1243.9mm x 285.3mm x 782.2mm
    weight of 11.9Kg (with base included)
    Specifications Xiaomi Mi TV Q1 75″
    4K QLED panel with support for HDR10 + and Dolby Vision and 16: 9 aspect ratio
    75 ″ size with resolution 3,840 x 2,160 dots
    120Hz native refresh 1000 nit brightness with 178º / 178º viewing angle
    192-zone FALD backlighting
    MediaTek MT9611 Quad Core Cortex A-55 Processor with Mali G52 MP2 GPU
    2GB RAM with 32GB eMMC storage
    30W sound system with Dolby Audio and DTS HD 6 speakers
    WiFi 5 and Bluetooth 5.0 wireless connectivity
    Connections 3 x HDMI (1 x eARC and 1 x HDMI 2.1), 2 x USB 2.0, 1 x Ethernet, 1 x optical audio, 1 x digital tuner, 1 x microphone mute, 1 x 3.5mm jack
    Dimensions length 1673.5mm x 368.9mm x 1029.9mm
    weight of 33.3kg (with stand included)
    Пролетта в Китай пуснаха модела Mi TV EA 2022
    Според сертификатите, всеки модел се произвежда от множество компании.
    Mi TV EA 2022 32-inch (L32M7-EA)
    TCL OVERSEAS ELECTRONICS (HUIZHOU) CO., LTD
    Hefei Huikejinyang Technology Co., Ltd
    Mi TV EA 2022 40-inch (L40M7-EA)
    Nanjing Skyworth Flat Display Technology Co.ltd、http://investor.skyworth.com/en/contact.php
    Mi TV EA 2022 43-inch (L43M7-EA)
    Sichuan Changhong Electric Co.,Ltd. http://www.cccme.org.cn/shop/cccme2342/index.aspx
    Hefei BOE Vision-electronic Technology Co., Ltd
    Mi TV EA 2022 50-inch (L50M7-EA)
    HUIZHOU KTC TECHNOLOGY CO.,LTD. https://www.ktc.cn/en/
    Mi TV EA 2022 55-inch (L55M7-EA)
    Suzhou RAKEN Technology Co.,Ltd. http://www.szraken.com/
    Mi TV EA 2022 65-inch (L65M7-EA)
    Този пост е редактиран от hristoslav2; 24-08-21 в 21:39.
  5. Junior Member
    Nov 2012
    #19
    здавейте мога ли да записвам тв предавания на външен хард диск и с коя програма
    #20
    За кой модел телевизор на марката става въпрос ?
    Xiaomi май нямат PVR функция..
    Вариант е ако има някакво приложение за PVR на Android TV
    Този пост е редактиран от hristoslav2; 27-09-21 в 19:23.
  7. Junior Member
    Nov 2012
    #21
    MI 4s 55
    #22
    модела няма PVR
    https://www.lcd-compare.com/televise...i-TV-4S-55.htm
    телевизорът е с Android 9.0 (Pie) така че трябва да имаш достъп до Google Play и от там да си го изтеглиш и инсталираш
    https://technozee.com/android-tv-screen-recorder/
    https://play.google.com/store/search...ps&hl=bg&gl=US
  10. Junior Member
    Nov 2012
    #23
    мерси
    #24
    #25
    Xiaomi току-що представи своето второ поколение QLED телевизори на световния пазар с линията Xiaomi TV Q2.
    Ниската цена се дължи на липсата на повишена честота на кадрите (60Hz)
    Серията включва три модела - с екрани с диагонал 50, 55 и 65 инча. Цената им съответно е 600, 700 и 900 евро.
    Телевизорите са оборудвани с LCD панели с QD, резолюция 4K и кадрова честота 60 Hz. 92% покритие на цветовото пространство DCI-P3(топ моделите от други марки стигат до 99%), както и поддръжка за MEMC и Dolby Vision IQ
    Звуковата подсистема има два 15-ватови високоговорители с Dolby Atmos и DTS-X. В софтуерно отношение е заложено на Google TV и SoC Mediatek, който комбинира четири ARM Cortex-A55 CPU ядра с Mali-G52 MC1 GPU.
    1x 3,5 mm жак за слушалки
    1x оптичен цифров аудио изход
    1x композитен вход (AV)
    1x Ethernet (LAN)
    2x USB 2.0 Type-A
    3 x HDMI (including eARC and HDMI 2.1)
    WiFi 2.4/5Ghz
    Bluetooth 5.0
    DVB-T/T2/C, DVB-S/S2 C1
    Bluetooth v5.0
    https://twitter.com/Xiaomi/status/1577280090282622979
    https://www.mi.com/global/discover/article?id=2788
  13. Novice Аватара на Iliyan Nikolov
    Nov 2012
    Milan,Italy
    #26
    От скоро съм с L55M7-EAEU,ако може някакви оптимални настройки за калибриране?Весела Коледа!
    Изпратено от моят SM-A528B с помощта на Tapatalk
    #27
    Xiaomi Mi LED TV P1 43 "- 4K TV тест
    Характеристики на смарт телевизора Xiaomi L43M6
    Системата Android версия 10, използвана в L43M6, все още работи приемливо: в някои области беше доста ефективна, въпреки че в други (като превключване на канали) беше сравнително бавна. Въпреки това телевизорът никога не ми затваряше.
    Както подобава на Android, изборът от приложения е много голям.
    VoD приложения:
    Apple TV
    CDA
    Disney+
    FilmBox
    HBO Go
    Netflix
    Player
    Polsat Box Go
    Polsat Go
    Prime Video
    Rakuten TV*
    TVP VOD
    YouTube
    Viaplay
    * Испаноезичният Rakuten TV - Peliculas y Series се предлага от фабриката, която стартира в полската версия веднага след инсталирането.
    Приложения за поточно предаване на музика:
    Deezer
    Spotify
    Tidal
    Фабричният медиен плейър се справи с файловете: flv, mkv, mov, mp4, mts, tp, но за съжаление отказа да възпроизвежда avi и wmv файлове. Освен това не успя да обработи файлове, записани с помощта на кодека AV1.
    Телевизорът не поддържа мрежови протоколи (напр. DLNA, SMB и др.).
    За съжаление по време на едноседмичния тест една и съща софтуерна грешка се появяваше всеки ден. Е, след дълъг период на бездействие (напр. след нощ, прекарана с телевизора в режим на готовност), приемникът се включи отново, максимизира подсветката, т.е. свети с най-високата налична яркост, въпреки че опцията "задно осветяване" показва зададена стойност предишния ден. За съжаление, яркостта на подсветката не може да бъде намалена: можете да преместите плъзгача "подсветка" наляво и надясно, но без резултат - телевизорът не намали яркостта.
    Единственият изход, който можах да намеря, беше да използвам опцията "рестартиране" (системни настройки/настройки на устройството/за/рестартиране). Рестартирането (повтарям: рестартиране, а не преинсталиране) реши проблема. За съжаление, както споменах, проблемът се появяваше всеки ден.
    Внимание!
    Въпреки опцията HDMI 2.1, която се вижда в менюто, Xiaomi L43M6 няма този тип конектор. Вместо това има 3 HDMI 2.0 слота с максимална тактова честота от 600 MHz. Всеки сокет може да работи в три "режима" от 1.4, през 2.0, чак до [фиктивния] 2.1. Най-ниският режим "2.1", видим на снимката, всъщност позволява съвместимост с поддръжка на 2.0 + eARC, а не действителна работа в режим 2.1 (за това е необходима комуникация чрез FRL, което чипът, използван в L43M6, не може).
    Резюме
    В техническо отношение Xiaomi L43M6 е различен телевизор от своя предшественик L43M5 (може би защото OEM производството се извършва в друга фабрика). Телевизорът има много предимства, включително добра мултимедия, ясна картина, ярки, но в същото време доста естествени цветове и добро съотношение цена/качество. Условно го препоръчвам за гледане в най-много средно светли помещения или на включена светлина.
    Признавам, че телевизорът беше близо до пълната препоръка, а основната причина за липсата й са няколко грешки в софтуера, които за съжаление идентифицирахме повече, отколкото при 55-инчовия модел. Да се ​​надяваме, че производителят ще ги премахне чрез актуализация на софтуера.
    Тест и ревю на Xiaomi Mi LED TV Q1E 55"
    https://geex.x-kom.pl/recenzje/test-...led-tv-q1e-55/
    гугъл превод
    Характеристики на смарт телевизора Xiaomi L55M6-6ESG
    По време на теста L55M6-6ESG работеше с Android версия 10. Телевизорът работеше доста бързо и не ми затвори нито веднъж. Въпреки това забелязах няколко проблема:
    Когато използвах Blu-ray диск плейър, трябваше да деактивирам HDMI (CEC) управлението, за да изведа менюто на телевизора.
    При намаляване на силата на звука до нула, иконата на високоговорителя остава на екрана през цялото време и не изчезва (същия е случаят в телевизорите ... TCL).
    След като изберете иконата Live TV в главното меню, телевизорът не активира никакви DVB канали, а превключва към един от най-скоро използваните HDMI конектори (тази доста досадна грешка е типична и за телевизори ... TCL).
    Интересен факт: известно е, че Xiaomi няма собствена фабрика за телевизори, а възлага производството и (частично) дизайна на други. Според мен в конкретния случай усещането за прилики с телевизорите TCL не може да е случайно.
    Не можете да се оплачете от избора на приложения.
    VoD приложения:
    Apple TV
    CDA
    Disney+
    FilmBox
    HBO Go
    Netflix
    Player
    Polsat Box Go
    Polsat Go
    Prime Video
    Rakuten TV*
    TVP VOD
    YouTube
    Viaplay
    * Наличен е само азиатският Rakuten на VIKI.
    Deezer
    Spotify
    Приливни
    Медийният плейър, който е предварително инсталираният медиен плейър, се справи с файловете: flv, mkv, mov, mp4, mts, tp, но отказа да възпроизвежда avi и wmv файлове. Освен това не успя да обработи файлове, записани с помощта на кодека AV1.
    Други бележки:
    сортирането на файлове от USB е възможно по име на файл, дата на модификация или тагове, но не е възможно да се промени посоката на сортиране;
    изгледът показва папки/директории в самия край, което може да е неудобно (същото е в TCL телевизорите);
    според мен е по-добре да инсталирате друг файлов плейър, например VLC.
    Внимание! Въпреки опцията HDMI 2.1, която се вижда в менюто на Xiaomi L55M6-6ESG, няма конектори от този клас. Вместо това има три HDMI 2.0 конектора (макс. 600 MHz).
  16. Junior Member
    Nov 2010
    #28
    Здравейте! От скоро се оглеждам за нов телевизор около 40 инча. Попаднах на този: https://www.pazaruvaj.com/lcd-crt-i-...43-p679612254/ огледах се в него понеже ползвам телефони от тази марка и съм изключително доволен. Незнам при телевизорите как се справят и затова се обръщам за съвет.?.?.
    Телевизора ще се ползва предимно за PS, Youtube игри от Google Play и телевизия чрез приложенията на А1 или виваком - (още не съм решил кое точно). Или да ми дадете съвет за нещо подобно но да е задължително с Android и 4К??? Бюджета е около 700 - 800 лв.
    Този пост е редактиран от w902; 20-04-23 в 00:24.
    #29
    Xiaomi Mi LED TV A2 55″ тест и преглед
    https://geex.x-kom.pl/recenzje/test-...-led-tv-a2-55/
    Тестваният Xiaomi Mi LED TV A2 55″ има още две имена :
    технически L55M7-EAEU и
    вътрешен MiTV-MOOQ1, използван по време на инсталацията.
    Последното се отнася за миналогодишния модел от Q-серията, който се идентифицира като MiTV-MOOQ0. Тестваният модел, от друга страна, се идентифицира по време на инсталацията като MiTV-MOOQ1.
    Второто име е най-просто и комуникативно и затова ще го използвам в ревюто, особено след като е на табелата с данни ( интересен факт : горният модел от серията Q1 имаше символа L55M6, което означава, че приликите между серията A2 и миналогодишния Q1 не са случайни) .
    Най-големият недостатък на телевизора може да бъде първата му инсталация, особено за тези потребители, които не са имали телевизор от тази марка преди. След включване към захранването светва за момент белият диод под централно поставеното лого и нищо не се случва - телевизора не реагира на дистанционното. Работата е там, че трябва да включите телевизора с помощта на малък бутон, разположен долу вдясно зад диода. Едва тогава телевизорът ще започне.
    Знаех за това, защото в предишните модели беше добре описано и отбелязано в ръководството. Тази година това беше пропуснато, което може да раздразни новоизпечените собственици на телевизори от тази марка и да причини ненужна работа на отдела за техническа поддръжка.
    В режим HDR на 10% прозорец к максималната осветеност след три минути измерване беше само … 284 cd/m^2 . Това е нисък резултат и именно той е отговорен за грешките при възпроизвеждане на цветовете в режим HDR. С други думи, L55M7 няма да работи с HDR съдържание.
    Седемлентовият еквалайзер е наличен само в персонализиран режим, но е доста маскиран, тъй като достъпът до него се осъществява чрез маркиране на името на режима („персонализиран“) и натискане на бутона за потвърждение в централния селектор на дистанционното управление.
    Xiaomi L55M7 използва процесор m7362, хардуерна платформа "Тарзан" и система Android 10, без Google TV. Телевизорът работеше добре, въпреки че на моменти се забавяше и изискваше малко повече търпение. Когато свързах Bluetooth клавиатура към него, дистанционното ми спря да работи и трябваше да извадя кабела от буксата, да разкача клавиатурата, след което всичко се нормализира.
    Внимателните потребители ще забележат много грешки в полската версия на системата, включително субтитри на ... испански. Въпреки че много неща са подобрени в сравнение с Q1, например автоматично откриване и настройка на телевизора към по-широка цветова палитра), някои недостатъци от миналогодишното Q1 все още са налице. Това са например:
    HDMI контролът (CEC) трябва да бъде изключен, за да се изведе менюто;
    когато изберем иконата "Телевизия на живо", телевизорът ни превключва към последния използван HDMI конектор; само натискането на "вход" на дистанционното управление ни дава достъп до телевизия (интересното е, че същото е и в телевизорите TCL);
    след намаляване на силата на звука до нула, иконата на високоговорителя остава на екрана (интересното е, че е същото в телевизорите TCL).
    https://www.mi.com/global/product/xiaomi-tv-a2-55/specs
    Този пост е редактиран от hristoslav2; 04-05-23 в 22:51.
    Iliyan Nikolov одобрява това.
    #30
    Android 11. Тест и преглед на Xiaomi Mi LED TV A2 32″
    https://geex.x-kom.pl/recenzje/test-...-led-tv-a2-32/
    Това е вторият от телевизорите Xiaomi от серията A2. След 55-инчовия модел скачаме до дъното на тази серия, за да вземем най-малкия, 32-инчов модел в сервиза. Още спецификацията, предоставена от производителя, казва, че не можем да очакваме същите технически параметри като при по-големите модели, т.е. 43, 50 и 55 инча. Въпреки това се оказа, че една характеристика на 32-инчовия Xiaomi превъзхожда 55-инчовия модел. Каква е тази функция и дали си струва да се интересувате от този телевизор, ще разберете от теста. Затова ви каня да прочетете ревюто на Xiaomi Mi TV LED A2 32".
    Телевизорите на тази добре позната китайска марка са ни свикнали да имат три имена, така че това до търговското име Xiaomi Mi TV LED A2 32 "има още две:
    вътрешен MiTV-MOSR1, използван по време на инсталацията и
    L32M7-EAEU.
    Последното е най-просто и логично и затова ще го използвам в това ревю, още повече, че е на табелката.
    Xiaomi Mi TV LED A2 32" (наричан по-нататък L32M7 за простота) е LCD телевизор с разделителна способност на екрана от 1366 на 768 пиксела. Телевизорът работеше под управлението на версията на софтуера RTT8-210119.001.1879 и системата Android 11. Произведен е в Полша, а тестваното копие идва от магазина x-kom.
    цветове
    В режим на затоплен ( т.е. с дефицит на синьо) филм ( 6,089 K ), средната грешка на тестовата проба от няколко десетки цвята беше 5,2 , т.е. над прага на възприемане .
    Черно и контраст
    Съотношението на контраста по ANSI беше 4475:1, което е много добър резултат. Фабрично нивото на бялото (опция "яркост") беше зададено правилно (50), докато нивото на бялото (опция "контраст") беше грешно, тъй като телевизорът изгаряше малко изображението на светлините. Регулирането на нивото на черното (опцията "яркост") от 50 до 48 елиминира този проблем.
    HDR
    Този път в теста няма да намерите снимки от HDR филми, защото Xiaomi L32M7 е телевизор, който не поддържа HDR съдържание.
    Картографиране на движението
    Xiaomi L32M7 е оборудван с LCD дисплей от клас 60 Hz. Максималната острота на движещите се изображения беше 150 линии (TVL) при 1080 максимум, което за съжаление е слаб резултат, характерен за най-бавните 60-херцови панели.
    Що се отнася до другите явления, свързани с трафика:
    ефектът на мръсен екран ( DSE ) е среден;
    по време на футболни игри от време на време имаше тънки вертикални линии, но те не ме притесняваха;
    размазването беше средно силно.
    Xiaomi L32M7 няма функцията за изглаждане на движението, но на екран с толкова малък диагонал според мен не е нито голям проблем, нито недостатък.
    Характеристики на Xiaomi Mi LED TV A2 32″ смарт телевизор
    Xiaomi L32M7 използва процесор mt5867 и, което е интересно, системата Android 11. Както можете да видите, това е по-нова версия на системата от тази в 55-инчовия модел (10). Що се отнася до функционалността на Android, няма големи разлики - все още не е версията за Google TV.
    Промените обаче са в онези области, където производителят има повече свобода. И така, някои опции са по-добре усъвършенствани, отколкото например в 55-инчовия модел от същата серия, който имаше Android 10.
    Забелязах подобни проблеми като в L55M7:
    след намаляване на звука до нула, иконата на високоговорителя остава на екрана (подобно на TCL телевизорите).
    Телевизорът не е демон на скоростта и има само 2GB RAM, така че трябва да внимавате колко приложения отваряте наведнъж, за да не натоварите системата.
    Измерени параметри (фабрични настройки)
    ANSI(x:1) - 4475:1 контраст
    средна грешка dE2000 (BT709) - 5.2
    входно забавяне (ms) - 37.7*
    *Латентността може да бъде намалена до 32,4ms чрез превключване от режим "игра" към режим "монитор".
  1. Hisense телевизори (инфо на първа страница)
    Отговори: 687
    Последно: 17-06-26, 20:43
  2. TCL телевизори (инфо на първа страница)
    Отговори: 2237
    Последно: 12-12-25, 13:25
  3. JVC телевизори (инфо на първа страница)
    Последно: 08-04-24, 11:15
  4. Telefunken телевизори (инфо на първа страница)
    Последно: 20-10-23, 19:46
  5. Sunny телевизори (инфо на първа страница)
    От Eva69 във форум Други телевизори
    Отговори: 17
    Последно: 04-08-20, 21:28
