Страница 1 от 5 123 ... ПоследноПоследно
Резултати от 1 до 15 от общо 67
Съвет за цифров фотоапарат
    May 2004
    Здравейте,искам да помоля за съвет за цифров фотоапарат.Спрял съм се на два модела-Cannon A520 и Cannon A95,бих се радвал и на всякакви други предложения.
    Благодаря предварително* :coolsmiley:
  3. Senior Member Аватара на Lupus
    Aug 2003
    Re: Съвет за цифров фотоапарат
    @G_R_U,
    Пусни едно търсене във форума. Минаха няколко такива теми и има много полезна информация.
    Dec 2004
    Човека го мързи в тая жега бе Lupus.Ето му нещо "здъвкано":
    Canon PowerShot A95
    The main changes are the sensor resolution (5MP) and a larger (1.8 inch) and considerably higher resolution (118,000 pixel) swing out LCD screen. Other improvements include an enhanced movie mode and a wider assortment of subject-based shooting modes. Let's have a quick look at the main selling points:
    * 5.0 million effective pixels
    * 3x (38-114mm equiv.) F2.8-4.9 zoom lens
    * 1.8 inch 'vari angle' (swing and tilt) LCD
    * DIGIC processor
    * 9 point AiAF plus flexizone focus
    * 14 exposure modes
    * Print/Share button & direct print
    * Autofocus illuminator
    * Part metal body
    Canon PowerShot A520
    Announced just before PMA in February 2005, the PowerShot A520 is the replacement for the PowerShot A85, and continues the line of best-selling budget models that goes right back to early 2001 with the A10 and A20. The changes are evolutionary rather than revolutionary; a reduction in size and weight (it's 13% smaller and 20% lighter), the inclusion of a new four times optical zoom lens (the A85 had a three times), zoom-linked flash, a shift from CompactFlash to SD card for storage and a drop to two AA batteries from four.
    * 4.0 megapixel CCD
    * 4x (35-140mm equiv.) zoom lens
    * Manual, semi automatic and fully automatic exposure
    * 20 exposure modes
    * New 'hold' function
    * Zoom flash
    * 9-point AiAF focus
    * Optional underwater housing, external flashgun and add-on lenses
    * AA battery power
    G_R_U, ама да не кажеш сега да ти го превеждам :knuppel2:
  5. Moderator
    Nov 2001
    За предложения Панасоник LZ2 със 6x zoom и оптичен стабилизатор.
    Apr 2003
    За тези пари - добър избор ! но може да погледне и Сумсунг V700, както и другите им нови модели които са съшо добри !
    Mar 2003
    А А95 е една адски добра сапунерка ! Размазва 3-те други изброени апарати
    Я кажи една цена граница И какви предпочитания имаш за апарата ?
    Jun 2002
    mxkolev, аве човеко на САМСУНГ нищо не става, аз така съм се убедил, готин дизай, ама орязани функции или пък нещо все не им е наред!!! Така, че моля недай дава на хората глупави съвети, Той пита за КАНОН не за боклуци!!!
    G_R_U, аз лично бих си взел А520 зариди малко по-големият zoom и заради пълните ръчни настройки!!! Но дори да си вземеш и А95 няма да сбъркаш. На прав път си с марката* .
    Mar 2003
    LUDIA, кви ги дрънкаш ?
    Да не би А95 да няма ръчните настройки ? А 1/1.8" матрицата ? Въртящ дисплей ... като цяло много по-пъргав като операции...
    Samsung - скъпите добри модели със Schneider ги хвалят разбиращи хора V5 ли беше V50 ли ... не съм навътре с тях Но имат яки !
    Jun 2002
    CrossBlade, за CANON-а незнам, 95 не ми е попадал между ръцете. НО едно знам КОЙТО ми ХВАЛИ САМСУНГ нищо не разбира от техника. Ако ще и оптика на ОЛИМПУС или КАРЛ ЦАЙС да им сложат все ще са същите боклуци. САМСУНГ имат политика да правят хубави на външен вид работи, не много скъпи за да се копуват доста и с готини оферти и т.н. НО все нещо не им е като трябва или все някакъв такъв дефект ще му искочи дето никъде другаде не можеш да го видиш, само при САМСУНГ!!! Не съм продавал САМСУНГ фотота, само са идвали при мен клиенти да им продавам карти. Ами поне от това което видях за 2-3 минутки не съм впечатлен. НО си вадя заключения от тяхната друга техника GSM-и, ТВ и ДВД(големи боклуци - лично мое мнение). Аде, че ще стане спор, кой какво харесва. Малко се отклонихме от темата, ама какво да се прави стават и такива работи .
    Aug 2005
    Хей LUDIA , моля те дай малко повече информация защо не харесваш Samsung!Моторчето ли не работи, оптиката ми е лоша, картите ли са бавни, батериите ли (9 на брой) са слаби, форматите на файловете ли са лоши? Не разбрах как си преценил качествата им само за 2-3 минутки. Кой модел имаш предвид?
    Предварително ти благораря!
    Aug 2005
    Ето тук G_R_U можеш да видиш какво мислят за апаратите, които си харесал тези, които разбират от апарати: http://www.dpreview.com/ или направо http://www.dpreview.com/reviews/compare_post.asp?method=sidebyside&cameras=canon_a520%2Ccanon_a95&show=all
    Mar 2003
    Шшшт. Самсунг са буклуци на купчини направо Ама апаратите и телефоните им (мобилните) са добре. Другото не отричам - не става.
    П.П. Не харесвам нито апаратите им, нито телефоните - но стават, не са лоши. Не бих си ги купил. Но са добре, за разлика от другата им техника (,която също не бих си купил)
  16. Moderator
    Nov 2001
    Абе стига сте се хващали за тези ръчни настройки. Повечето незнаят как да ги позлват а само се кефят че фотоапарат им имал пълнио ръчни настройки. А дори и да си наясно какво можеш да направиш с тези ръчно настройки докато си го настроиш фотоапарата отиде да дойде. Това не вие фотоапарат с гривана на обектива за бленда и врътка отгоре за скорост. Такъв е само един модел на панасоник който е много скъп. По дорбе обръщайте венимание на силата на светкавицата и кой фотоапарат е по бърз(бърз автофокус и малко времем между две снимики).Конкретно какнон не да от най бързите фотоапарати. Иначе а95 прави добри снимки но да бяха го направили малко по бърз. Панасоник има по добри обективи от какнони вече всички сапунери са с оптичемн стабилизатор, които е доста важен да любителски снимки.
    Mar 2003
    Все едно защо се хващате за мощните конфигурации, повечето хора само чатят с mIRC клиент и отварят Internet Explorer. Важен е "цветен екран"
    Ако човек не му трябват и апарата го купува само да си снима кучето - ок. НО за скъп апарат без ръчни настройки - то нека поне да е миниатюрен - като Nikon S1 примерно.
    Aug 2005
    Същият въпрос и към CrossBlade. Моля те дефинирай какво значи, че фотоапаратите на Самсунг "са боклуци". Не разбирам как можеш да кажеш само "не бих си го купил" и това, или онова става. Я по-добре обяснете имате ли опит във фотографията, с какво снимате. Не разбрах дали някой от двамата изобщо е "тествал" апаратите, за които толкова "компетентно" се изказва.
    И съвет към тези, които избират фотоапарати/обективи: тука няма това е по-хубаво, онова е по-лошо. Едно нещо е за сметка да друго. Така, че преценявайте за собствените си нужди и не се водете по акъла на разни "разбирачи".
  1. Съвет за избор на цифров фотоапарат.
    От Стоян във форум Фото и видеокамери
    Последно: 15-08-11, 18:06
  2. Съвет за цифров фотоапарат - Polaroid или Kodak
    От Dorothea във форум Фото и видеокамери
    Отговори: 31
    Последно: 25-01-07, 21:29
  3. Цифров фотоапарат
    От bx във форум Общ - хардуер
    Последно: 28-05-06, 20:02
  4. Съвет за избор на цифров фотоапарат
    От Audioslave във форум Фото и видеокамери
    Отговори: 13
    Последно: 15-03-06, 13:51
  5. Цифров Фотоапарат съвет
    От shulio във форум Фото и видеокамери
    Отговори: 33
    Последно: 26-07-04, 09:25
