Страница 182 от 707 ПърваПърва ... 132172180181182183184192232 ... ПоследноПоследно
Резултати от 2,716 до 2,730 от общо 10591
Like Tree5865Одобрявам
    #2716
    тестват никотинови лепенки върху пациенти с коронавирус
    https://spisanie8.bg/%D0%B7%D0%B4%D1...KlTJbo_Q2CAGv0
    https://www.theguardian.com/world/20...9IQcOqWLqG5Aeo
    За Gena_bs и JackKrauser...
    https://pik.bg/%D0%B1%D0%BE%D0%BB%D0...ews381055.html
    https://navylive.dodlive.mil/2020/03...id-19-updates/
    Latest
    Daily Update: April 22, 2020
    Key Developments
    As of today, 99% of USS Theodore Roosevelt (CVN 71) crewmembers have been tested for COVID-19, with 777 total positive and 3,919 negative results. Of the total positive cases, 63 Sailors have recovered. 4,196 Sailors have moved ashore.
    Six Sailors assigned to USS Theodore Roosevelt are in U.S. Naval Hospital Guam being treated for COVID-19 symptoms. None of the Sailors hospitalized for COVID-19 are in the Intensive Care Unit (ICU).
    On April 19, 2020, a Department of the Navy civilian employee assigned to Personnel Support Detachment Oceana, died at the Naval Medical Center Portsmouth. The apparent cause of death was from complications associated with the Coronavirus Disease 2019 (COVID-19).
    On April 21, 2020, a Department of the Navy civilian employee assigned to Washington Navy Yard died at George Washington University Hospital. The apparent cause of death was from complications associated with the Coronavirus Disease 2019 (COVID-19).
    Този пост е редактиран от hristoslav2; 23-04-20 в 15:07.
    DOLBY VISION 4K одобрява това.
  3. Moderator
    Mar 2005
    #2717
    Изтриване на 81 база-двойки в SARS-CoV-2 ORF7a, идентифицирано от наблюдение в Аризона (януари-март 2020 г.)
    https://www.medrxiv.org/content/10.1....17.20069641v1
    Авторите наблюдават "изтриване" на част от един от гените на SARS-CoV-2. Загубата на 81 нуклеотида (As, Cs, Gs и Us) на ген е сравнително "голяма" мутация и това може да означава, че генът вече не е функционален. В SARS-CoV е показано, че генът, при който е извършена тази делеция (наречена ORF7a), помага да се защити вирусът от протеин, който не позволява на вируса да се отдели от клетката гостоприемник. Следователно вирус с тази мутация може да загуби тази защита и следователно може да се репликира по-малко. Авторите обаче не са потвърдили това експериментално.
    Защо това е интересно?
    Това е само 1 изтриване, което е наблюдавано. Вероятно има много изтривания при други заразени хора, които на практика не могат да се проследят.
    Предполага се, че така вирусът отслабва и става достатъчно слаб, за да бъде ендемичен (като сезонната настинка). Израелски учени също са заявили, че вирусът има 70-дневен циркулационен цикъл в популация, преди да изчезне или да отслабне значително.
    Това е интересно да се наблюдава при голямо население като Индия и Китай. Тях вируса трябваше да ги е заличил досега, но не е така. Може би поради голямата им популация вирусът в крайна сметка "изгаря" и се предава поради собственото си изтриване. Китай сега казват, че получават само случаи на внос, същото е и за Индия, които са блокирали прибирането на индийци извън страната.
    Нещо сходно каза и български епидемиолог, но "по-фолк" вариант - когато вируса зарази здрав човек, самия вирус "отслабвал" от добрата имунна система на този човек и след това заразявайки следващия, то вируса вече е по-малко опасен. И ако има верига на заразявания от например 20 човека, като по-голямата част от хората във веригата са достатъчно здрави, то при 21-вия вируса бил съвсем отслабен (каквото и да значи това слаб или силен за вирус, вероятно е аналог на неопасен/опасен)
    stainway одобрява това.
  4. Senior Member Аватара на Tommorow
    Пловдив, България
    #2718
    Още по поп-фолк казано: ако ядеш една седмица банани, на осмия ден изобщо няма да ти е до банани....
    Този пост е редактиран от Tommorow; 23-04-20 в 15:20.
  5. Moderator
    Mar 2005
    #2719
    А ако ядеш една седмица само гнили и горчиви банани, то на осмия ден пак ще ти се иска да хапнеш истински банан сладък и сочен
    #2720
    Не ви е нужен превод - само изгледайте диаграмите..
    https://medium.com/@tomaspueyo/coron...e-f4d3d9cd99ca
    https://clubz.bg/96932-prof_montgomy...ojde_vaksinata
    Този пост е редактиран от hristoslav2; 23-04-20 в 23:18.
    #2721
    Изпълняват се заповеди отвън и се имитира дейност по "борба" с неизвестно какво.
    Днес на КПП-то искаха на декларацията да пиша марка, регистрационен номер на автомобила и точен час за излизане. Не ми е известно да са сменили бланката. Поправете ме, ако съм го пропуснал. Писна ми вече от идиотии!
    Щели по този начин да следят с камерите на АПИ "лъжещите" къде точно отиват. Разбирам защо хората се опитват да се измъкват през черните пътища.
    А защо не следят колко пъти сме ползвали годишните винетки и да ни приспаднат месеците в ограничения?
    Сега ще пуснат "съгражданите" ни с повече от 1 гражданство за Рамазан Байрам (24.05) и ще "докажат" правилността на мерките, графиките и прогнозите си. И лекичко ще увеличат срока на ИП до края на юни поне.
    Горките абитуренти! Дано поне успеят да завършат и си вземат дипломите!
  9. Moderator
    Mar 2005
    #2722
    Още по вчерашната минидискусия. Мислех да не пиша повече по нея, но днешните новини са ... изненадващи :
    "Новите заразени с Covid-19 сред медицинския персонал са 12. Повечето от случаите не са в отделенията, където се лекуват заразно болни, а в други отделения. Това показва, че колегите подценяват опасността, каза главният здравен инспектор Ангел Кунчев."
    "Четирима обитатели на дома за възрастни хора във видинското село Гара Орешец са заразени с Covid-19. Епидемиологичното проучване е показало, че един от възрастните, които живеят в дома, е бил настанен в неврологичното отделение на видинската болница, която е огнище на зараза заради вътреболнична инфекция. Домът е поставен под карантина."
    "Районната прокуратура във Видин е повдигнала обвинения на председателя на гражданското сдружение БОЕЦ Георги Георгиев заради всяване на паника по темата коронавирус. Самият той обаче твърди, че обвинение и досега не му е връчвано, въпреки че държавното обвинение съобщи за него още преди три дни. В последните два дни Георгиев твърди, че ходи в прокуратурата и настоява да му връчат официално документите, но това не се случва. В четвъртък разказа, че дори писмено е поискал да бъде официално обвинен.
    Обвиненията срещу Георгиев са заради негови твърдения, че медицинските лица във видинската болница "Св. Петка“ не се тестват за коронавирус, въпреки че са били контактни със заразени пациенти. Това се правело по разпореждане на здравната каса, като заповедта била да се тестват само хора със симптоми."
    Nov 2019
    #2723
    Този пост е редактиран от hristoslav2; 23-04-20 в 19:51.
    Gena_bs одобрява това.
    #2724
    В щатите са "открили", че първите заразени на тяхна територия са от много по-рано. Доста преди първия пациент долетял от Ухан и починал на 26.02.
    И сега ще "преразгледат" бройката на смъртоносно засегнатите и заразени американци.
    Явно и на тях не им излиза зададената бройка и се стремят да я увеличат до "референтните" стойности.
    Иначе ще им орежат премиалните.
    Plovdiv
    #2725
    Off:
    "Борисов и Мутафчийски пътували заедно в хеликоптер. По време на полета Мутафчийски се обърнал към Бойко и му казал:
    - Ако хвърля 1 пакет с маски за лице, ще направя 1 човек по-щастлив!
    Бойко да не остане по назад отвърнал:
    - Аз пък ще хвърля 50 маски за лице и ще направя 50 човека по-щастливи!
    В това време главният пилот дочул разговора между тях и се обърнал с лека усмивка към тях:
    - Сигурен съм, че ако Ви изхвърля ей сега и двамата, ще направя поне 7 милиона души изключително щастливи!"
    Изпратено от моят Mi Note 10 с помощта на Tapatalk
    Gena_bs и ccankov73 харесват това.
    #2726
    От 00:00 часа тази вечер се въвежда временна забрана за влизането в България на лица и превозни средства, идващи от Република Турция
    https://www.mh.government.bg/bg/novi...vremenna-zabr/
    Затварят джамиите. Мюсюлманите ще се окажат много по-дисциплинирани. Нито мрънкат, че джамиите са затворени, нито че няма да могат да се съберат по празниците със семействата си, които са в Турция. Даже са оптимисти и казват, че всяко зло е за добро.
    https://www.mediapool.bg/infektsiyat...ews306522.html
    Чак сега ще започнат да мислят, как да защитятя старците.....Персонала като му свърши смяната, се прибира у дома...и така старците в дома имат контакт с външният свят. Решението съм го предложил още преди месец, после пак го повторих...
    Ето защо исках да се изолират старческите домове(да се спази плана на НОЩ-персонала трябва да живее там)
    https://fakti.bg/world/465830-v-belg...rcheski-domove
    Излиза някой и казва, че трябва да пазим тези в старческите домове и рисковите групи. Ама няма предвид той лично да ги пази, а пожелателно тази работа да я свършат някакви други хора, които дори не знаят какво да правят. Ясно е, че това с пазенето няма да стане.
    При пандемия някои хора трябва задължително да останат да живеят на работното си място - никакво връщане удома
    - медицинският персонал в болниците с ковид отделение
    - някои полицаи..
    - персонала в затворите
    - персонала в старческите домове
    - някои митничари
    - летищният персонал, който има контакт с пътниците
    Докато премине пандемията...
    ccancov73
    COVID-19 Treatment Guidelines
    https://covid19treatmentguidelines.n.../introduction/
    https://covid19treatmentguidelines.n...investigation/
    https://gmcc.alibabadoctor.com/prevention-manual
    https://wellcomeopenresearch.org/articles/5-75
    Този пост е редактиран от hristoslav2; 23-04-20 в 22:44.
    Apr 2013
    Разград
    #2727
    Вече са 5 групи - от асимптоматичен, до критичен.Препоръчват вазодилататор инхалаторно(разширява съдовете) при критичните.Максимално “задържане” на интубацията(закачане към машина) т.е. подаване на О2 по други начини.Екстракорпоралната оксигенация още не е проучена добре.Другите неща са стандартни при лечение на тежки пациенти включая емпирично антибиотици, обръщане по корем, циркулационен съпорт и т.н.
    И все още нищо доказано действащо :
    As noted in that section, no drug has been proven to be safe and effective for the treatment of COVID-19.
    #2728
    Израелски професор: С или без изолация, епидемията се развива по един и същ начин
    https://www.lexmedicanews.com/index....-sysht-nachin/
    pap1918 и DOLBY VISION 4K харесват това.
    Dec 2017
    #2729
    Цитат Първоначално публикувано от MitkoS Виж публикацията
    Ами пак излъгаха брутално в ефир , че добрата имунна система щвла да навреди при заразяване (това за което писах преди два дни) ... първият им път беше , че маските били вредни (а всъщност било защото били дефицит) сам си го призна впоследствие. После хората не се вслушвали ...
    Apr 2013
    Разград
    #2730
    Ето го и оригинала : https://drive.google.com/file/d/1rkM...9HH3xtysAkDAOY
    Всъщност Професора препоръчва да се отвори бизнеса на 50%(който към момента на написването 08.04 в Израел е отворен на 15%) и според резултатите след още десет дена евентуално да се отвори на 100%.Но при запазване на соц. изолация, носене на маски, хигиена и т.н.за които признава че имат ефект.
    Също така и предупреждава, че това може да доведе до покачване на смъртността Не от Covid 19 и до недостиг на дихателни апарати.
    Накратко иска отваряне на бизнеса, но с предупреждение.Местата с висока концентрация на случаи се изключват от препоръките.
    Отговори: 1139
    Последно: 08-09-26, 01:24
  2. SONY телевизори 2019
    Отговори: 1118
    Последно: 17-03-20, 09:52
  3. LG телевизори 2019
    Отговори: 500
    Последно: 09-03-20, 12:33
  4. Samsung телевизори 2019
    Отговори: 493
    Последно: 29-01-20, 08:06
  5. Избор на климатик '2019
    Отговори: 3063
    Последно: 04-01-20, 11:11
