Вижте резултатите от анкетата: Колко инча е вашият LCD телевизор Panasonic ?
342. Не можете да гласувате в тази анкета
  • 19''
    0 0%
  • 26''
    2 0.58%
  • 32''
    78 22.81%
  • 37''
    35 10.23%
  • 42''
    153 44.74%
  • 47''
    59 17.25%
  • 55''
    15 4.39%
Страница 108 от 113 ПърваПърва ... 5898106107108109110 ... ПоследноПоследно
Резултати от 1,606 до 1,620 от общо 1684
Like Tree88Одобрявам
Panasonic LCD TV / How Tos & FAQ - на първа страница (2014)
    Dec 2014
    #1606
    Re: Panasonic LCD TV / How Tos & FAQ - на първа страница (2014)
    Can someone please answer me what type of panel does Panasonic 48AS640 use? Reading reviews i found out that the subpixel structure looks like this (image taken from HDTVPOLSKA):
    They say it is an Innolux VA panel PSA type.
    If it's any help Panasonic 50AS600 has the same matrix type, but different refresh rate and higher contrast (HDTVPOLSKA).
    On the first page of this thread it is written that the panel of 42AS600 is Innolux Super MVA:
    TX-42AS600E - Innolux (V420HJ2-LE6) - Super MVA / 4000:1 / 60hz / LVDS(2-ch, 8-bit) / R.T.9.5ms GtoG
    I also found this page where the above shown subpixel structure mostly resembles AUO A-MVA3 (Advanced MVA 3.01). Same info can be found here. EDIT: Comparing these two subpixel structures again I noticed that they are not very similar, so my mistake.
    Can some one please clarify?
    Този пост е редактиран от drgst; 19-12-14 в 14:34.
    #1607
    Отговор: Panasonic LCD TV / How Tos & FAQ - на първа страница (2014)
    This is MVA + PSA LCD panel.
    The only thing I know is that Panasonic has a contract with http://en.briview.com/
    Since last year, the major TV manufacturers conclude contracts with Chinese companies that assemble videopanels on request (buy matrices, and the rest produce themselves).
    http://hdtelevizija.com/2014/12/20/p...nalizom-slike/
    Този пост е редактиран от hristoslav2; 20-12-14 в 21:46.
    drgst одобрява това.
    Dec 2013
    #1608
    Цитат Първоначално публикувано от Frogst Виж публикацията
    Едно уточнение за "TV Anywhere" - работи коректно и при включен телевизор, стига да не се използва вградения тунер (т.е. ако ползваме някое от приложенията, или някой от другите входове на телевизора). Така с помощта на външен DVB-C приемник и сплитер (за разделяне на сигнала от кабелната тв - към телевизора и към приемника) ще имаме достъп по всяко време до пакета от телевизионни програми, за който сме абонирани. Неудобство ще е наличието на още едно дистанционно.
    Интересно, ако се ползва CA модул дали се получават нещата с кодираните канали? Би трябвало, но нямам възможност да проверя, а искам да помогна на приятел.
    Dec 2014
    #1609
    Привет! От няколко дни притежавам телевизор Panasonic tx-47as650 и като цяло съм доволен от покупката, но имам един въпрос. От два дни насам когато телевизора е изключен индикатора за вкл./изкл. свети постоянно в оранжево, а преди това си светеше в червено. Когато включа телевизора индикатора си свети нормално постоянно в зелено. На какво може да се дължи това? Прочетох доста и проверих дали няма включен таймер или нещо за запис, но поне аз не открих в настройките да съм задал такива. В други форуми се говори за премигащи индикатори, но моя случай не е такъв. Не намирам сам отговор на моя проблем, за това Ви моля за помощ.
    Благодаря предварително!
    Този пост е редактиран от bozhko; 22-12-14 в 09:56.
    #1610
    При мен светва в оранжево, когато задам напомняне за предаване или за запис на такова.
    Dec 2014
    #1611
    Благодаря ти за бързия отговор. След покупката на телевизора не съм го базикал много. Единственото което направих беше да свържа телевизора с домашната мрежа чрез кабел към рутера. От къде всъщност се задават тези напомняния или запис да не би аз да не съм ги видял в настройките тези неща. Бих искал все пак да проверя. Всъщност и друго искам да попитам. При стартиране на skype не ми излиза формата за канектване/регистация, а си остава на началния екран само с логото на skype. Къде бъркам?
    #1612
    GUIDE -> чрез бутона със стрелките избираш предаване от списъка -> OK -> пак с бутона със стреките (горе-долу) избираш - напомняне, USB HDD запис или Ext. rec.
    За скайпа задължително трябва да имаш свързана камера.
    Dec 2014
    #1613
    Проверих всички настройки и никъде нямам зададено напомняне или запис на програма. Не знам от какво друго може да е. Предавам се. Благодаря ти за помощта.
  11. Banned
    Dec 2011
    #1614
    Това и при мен е така. Нямам идея защо свети оранжево ?! Преди и на мен ми правеше впечатление ,че е червено от повече от седмица насам е оранжево. Но не му обръщам внимание честно казано това в какъв цвят свети този индикатор не смятам ,че е проблем та толкова внимание му отделяме )))
    п.п. Факт е че и двамата нещо сме натиснали или направили та е така........но спокойно няма му нищо на ТВ-то ))
    Dec 2013
    #1615
    Цитат Първоначално публикувано от bozhko Виж публикацията
    Привет! От няколко дни притежавам телевизор Panasonic tx-42as650 и като цяло съм доволен от покупката, но имам един въпрос. От два дни насам когато телевизора е изключен индикатора за вкл./изкл. свети постоянно в оранжево, а преди това си светеше в червено. Когато включа телевизора индикатора си свети нормално постоянно в зелено. На какво може да се дължи това? Прочетох доста и проверих дали няма включен таймер или нещо за запис, но поне аз не открих в настройките да съм задал такива. В други форуми се говори за премигащи индикатори, но моя случай не е такъв. Не намирам сам отговор на моя проблем, за това Ви моля за помощ.
    "Настройки" - "Мрежа" - "Мрежови настройки" - "DLNA сървър" - изключено
    и "Настройки" - "Мрежа" - "Настройки TV Anywhere" - "TV Anywhere" - изключено
    При това положение свети червено. Ако една от двете опции е активирана - свети оранжево.
    P.S. Когато е зададено напомняне, или запис на предаване също свети оранжево
    Този пост е редактиран от Frogst; 22-12-14 в 03:20.
    stanislav77 одобрява това.
    Dec 2014
    #1616
    Благодаря на всички за отговорите ! Колегата Frogst е абсолютно прав. След изключване на DLNA сървъра индикатора вече свети в червено. TV Anywhere си беше изключено. Разбира се колегата PEPY86 и той е прав, че отделяме прекалено много внимание на това, но нали знаете когато имате нещо ново как е . С това мисля, че въпроса е приключен. Благодаря още веднъж на всички. Страхотни сте!
    PEPY86 одобрява това.
    Dec 2014
    #1617
    Re: Отговор: Panasonic LCD TV / How Tos & FAQ - на първа страница (2014)
    Thank you very much for the answer hristoslav2.
    I noticed that you posted an answer in this thread about your Panasonic TV, so if you don't mind I'm very much interested in which Panasonic TV do you own as I see your opinion is highly regarded on this matter. I'm doubtful between Panasonic 47AS650 and Panasonic 48AS640, which have completely different LCD panels and hence different properties. I need good viewing angles, but read a few reviews about IPS panels including the review about 47AS650 from hdtelevizija.com where the reviewer laments the fact that IPS has good viewing angles.
    I would very much like to hear your opinion.
    Thanks in advance.
    Dec 2014
    #1618
    Frogst ме изпревари и аз преди два дни се почесвах умно защо свети оранж,но понеже бях бърникал само DNLA след изключване се оправиДа питам и аз,някъде четох из форума за ефекта театър някои знае ли настройки за премахването му?Един и същ филм на лаптопа е добре,на телевизора е някак изкуствено.
  17. Senior Member Аватара на svetlio1
    #1619
    IFC (Intelligent Frame Creation) настройката я слагаш най-много на минимум за филми .
  18. Novice
    Dec 2014
    #1620
    Здравейте, преди няколко дена си купих модела tx-as750 за 1500лв. Първоначално бях набелязал по-евтиния tx-as650, но на място консултанта почна да ми обяснява , че това е по-нов модел, бил с два тунера, процесорът бил по-бърз, вадел по-хубава картина и аз бързо се навих на по-скъпия с 350лв.телевизор. Като се прибрах в къщи и разгледах по-спокойно техническите данни на двата телевизора установих, че май единствената разлика е втория тунер на по-скъпия модел, който на практика изглежда немога да използвам тъй като телевизията ми е към м-тел(ако мога да го използвам ме поправете). Това, че съм към мтел не ми дава възможност по всяка вероятност да използвам и другата "екстра" -TV Anywhere, която я има и в по-евтиния вариант. Така в мен остана един привкус, че съм се набутал за по-скъпия модел телевизор тъй като реално немога да му ползвам екстрите. Дали е така?
  1. Media Player - Popcorn Hour 2014(всички модели)/FAQ на първа страница
    От jovanoty във форум Мултимедийни плейъри
    Отговори: 841
    Последно: 12-02-24, 10:50
  2. Media Player - Mede8er 2014/(всички модели) FAQ на първа страница
    От pipchi във форум Мултимедийни плейъри
    Отговори: 541
    Последно: 30-10-18, 12:41
  3. Отговори: 2279
    Последно: 04-02-15, 10:01
  4. Philips LCD TV / How Tos & FAQ - на първа страница (2014)
    Отговори: 729
    Последно: 15-01-15, 20:03
  5. Samsung LCD & OLED TV / FAQ - на първа страница (2014)
    Отговори: 1319
    Последно: 02-01-15, 20:26
