Страница 8 от 16 ПърваПърва ... 678910 ... ПоследноПоследно
Резултати от 106 до 120 от общо 233
Like Tree52Одобрявам
Panasonic телевизори 2017
  1. Senior Member Аватара на svetlio1
    #106
    Отговор: Panasonic телевизори 2017
    #107
    https://www.infosat.de/technik/progr...-panasonic-exw
    Programmlisten für Panasonic - EXW-Serie
    http://drivers.control4.com/solr/dri...22&q=&start=38
    Panasonic OLED TV 2017 - european models / Panasonic OLED TV 2017 - european models / Panasonic TV 2017 - european models
    Series Certificates HDR Hardware & Software Calibration Picture Quality Other Series
    Series & Model
    ________________
    UHD Premium
    _____
    ISF ccc
    ________
    ISFccc -
    Certified
    Calibration
    Configuration
    THX
    ________
    Accurate Color
    Reproduction
    Sharper Pictures
    THX Cinema & THX 4K Cinema modes
    Automation System
    IP Home Control
    __________
    HDR 10
    ST2084
    (EOTF PQ),
    ST2086
    (static metadata)
    ST2094
    (dynamic metadata)
    ________
    Hybrid
    Log Gamma
    (HLG)
    _____
    Dolby Vision
    VS10
    ____
    Advanced HDR Technicolor
    _______
    SoC / GPU / RAM
    _____________________________
    Plattform,
    Central Processing Unit,
    System on Chip,
    Instruction set,
    Graphic Processor Unit,
    RAM,
    Total memory
    Software
    ____________
    Operating System,
    Firmware version,
    Apps program languages,
    Videopanel
    Size class,
    Type LCD/Oled matrix,
    Resolution,
    Pixel structure,
    Bits of color,
    Quantum dots,
    Frequency of T-Con board,
    Curvature,
    Screen Uniformity,
    Anti-reflective filter
    Backlight Unit
    ______________
    Type backlight,
    Local Dimming zone,
    Type LED,
    Backlight Scanning,
    Black Frame Insertion,
    Pulsе Wide Modulation
    Frame Interpolation
    ________________
    Technology for generating and inserting intermediate frames to achieve a smooth picture in dynamic scenes.
    Measurement Unit (Index)
    Opportunities for calibration
    ISF ccc,
    3D LUT,
    -Color Menagment System,
    Technicolor Expert Mode,
    White balance,
    Gamma,
    Internal Processing
    Scaling,
    Overscaninng,
    Upscaling,
    Digital Noise reduction,
    Deinterlacing (Video mode, Film mode),
    Colorimetry
    DCI P3 coverage (xy / uv),
    Rec.2020 coverage (xy / uv),
    White balance dE,
    Color Delta E,
    Gamma,
    Color Temperature,
    Colors
    Brightness
    Peak in HDR
    Peak in SDR,
    Average Picture Level,
    Automatic Brightness Limiter,
    Contrast
    ______________
    ANSI Contrast,
    With local dimming,
    Without local dimming,
    Static contrast,
    Dinamic contrast,
    White level,
    Black level
    Viewing angle
    _____________
    Horizontal & Vertical
    (°cone)
    Motion resolution
    ______________
    Horizontal Lines
    Vertical Lines
    Input Lag
    ______________
    in HDR
    in True Cinema
    in Game mode
    by default
    Audio
    Total power,
    speakers,
    Surround,
    Sound mode,
    Built in Media Player
    Supported file systems
    Image file formats
    Audio file formats/codecs
    Video file formats
    Subtitles
    _______________________________________________
    Connectivity
    __________________
    Supported Resolutions
    Resolution / Frame per seconds
    24, 25, 30, 50, 60, 100, 120fps
    Progresive / Interleased
    Chroma subsampling
    4:4:4
    4:2:2
    4:2:0
    Conectors
    Tuners
    Tuners,
    Teletext reception,
    Multi window,
    Timeshift,
    PVR,
    Note
    Pros & Cons
    __________________
    EZ1000 (Oled)
    successor CZ950
    TX-77EZ1000E
    TX-65EZ1000E
    (Continental Europe)
    EZW1004
    (for Germany, Niderland)
    EZC1004
    (for Switzerland)
    EZ1000R
    (for Russia)
    EZ1002B
    (for United Kingdom)
    Yes Yes Yes - ensuring that you experience the filmmaker's vision exactly as it was intended.
    THX Cinema
    THX Bright room
    THX 4K Cinema
    Crestron / Control4 Yes - in TV, Internet video services, HDMI, USB port. Yes - in terrestrial and satellite TV,
    No No Plattform:
    SoC: MediaTek MT5597
    Core Architecture: ARM Cortex A53
    Instruction set:
    Operating at up to:
    CPU bit: 64-bit
    CPU Cores: Quad (4)
    CPU Frequency: 1.1GHz
    GPU: Mali T-860 MP2
    Open GL:
    RAM:
    Total memory:
    Available memory:
    Internal storage total space:
    Internal storage free space:
    Video Decoder: HEVC/VP9 UltraHD 60fps 10-bits
    HDR: Dolby Vision, HDR10, HLG
    Audio Decoder: Dolby, DTS
    E
    OS:“My Home Screen 2.0” - but the core is still Firefox OS 2.5, which is an open source project.
    HTML5 v.2.0 SDK
    76,5" - AM-OLED(Triple Stacked), 3840x2160, WRGB, 10-bit, No, 120/100Hz, Flat
    64.5" - AM-OLED(Triple Stacked), 3840x2160, WRGB,
    Model: LC650LQD (LG Display)
    No vignetting;
    PWM - No
    No backlight,
    No -,
    No -,
    No -,
    No -
    MEMC (IFC)
    BMR -
    (Backlight Motion Rate)
    Motion Processing Settings
    Anti-Blur:
    Anti-Judder:
    Panasonic uses its excellent motion compensation system to display a perfectly sharp moving image. Setting the Intelligent Frame Creation to Minimum offers the best rendering. The picture is sharp, without artifact and the camcorder effect is limited. On this point, Panasonic does better than Sony and hangs up at Philips, which was previously the benchmark in terms of motion compensation on Oled TVs.
    ISF Professional
    (expert mode - Day & Night)
    Compatibility with Portrait Display's CalMAN calibration software.
    Direct Display Control mode to allow to adjust settings directly from the Calman software (professional edition) by connecting screen to a PC via Ethernet.
    3D LUT(look-up tables)- 8000 points
    For instance, the EZ1002 allows professional users to upload their own colour 3D LUTs by SD/USB memory, if required.
    YCbCr full range coverage
    Finner gain controls (0.5increments).
    CMS - RGBCYM
    No
    White balance - 2/20 points
    Gamma
    Gray scale of 10 points
    Rec.2020
    Rec.709
    Very Good for HD,
    77" - DCI/P3 - xy 97% / uv 98%
    77" - BT.2020 - 73% / 76%
    77" -
    77" - dE
    77" - Gamma 2.2
    77" -
    65" - DCI/P3 - xy 97% / uv 98%
    65" - BT.2020 - 73% / 76%
    65" -
    65" - (True cinema) dE 1.2/ max dE 2.0
    65" - Gamma 2.2
    65" - 6840K
    Colors - 1073741824
    30-bits (3 sipbixels x 10-bits)
    By default, the TV is set to a gamma to 2.4 - the standard for Ultra HD. So you have to go through the settings to go back to a gamma of 2.2, ideal for HD content.
    77" - max 800cd/m2 in HDR
    77" - max 430cd/m2 in SDR
    65" - max 792cd/m2 in HDR
    65" - max 430cd/m2 in SDR
    APL -
    ABL - full-field peak white came in at:
    5% - 900cd/m2 (Vivid mode) - in HDR
    10% - 700cd/m2 (Vivid mode) - in HDR
    77" -
    77" - x
    77" - Inf.:1
    77" -
    77" -
    77" -
    77" - 0cd/m2
    65" -
    65" - x
    65" - Inf.:1
    65" -
    65" -
    65" - cd/m2
    65" - 0cd/m2
    77" -
    77" -
    65" - 65° (h)
    65" - ° (v)
    Color shift - 26°
    Brightness - 69°
    Black Level - 75°
    77" - ? (h)
    77" - ? (v)
    65" - ? (h)
    65" - ? (v)
    77" - in HDR
    77" -
    77" - in Game mode
    77" - by default
    65"- HDR - ms
    65" - 107ms
    65"- Game mode -25ms
    65"- by default
    80W (RMS) [2x20W, 2x20W]
    Dynamic Blade Speaker:
    Tweeter x 2, Squaker x 4, Woofer x 8,
    Quad Passive Radiator
    Reference Surround Sound Pro
    VR-Audio True Surround+
    Dolby Digital Plus
    Dolby Puls,
    No - DTS
    Standard/Music/Ambience/User
    FAT16, FAT 32, NTFS and exFAT
    Image file formats
    JPEG 4K, GIF, PNG, MPO, JPG,
    AAC (Advanced Audio Coding)
    FLAC (Free Lossless Audio Codec, .flac)
    MP3 (MPEG-2 Audio Layer II, .mp3)
    WMA Pro (Windows Media Audio, .wma)
    WAV (Waveform Audio File Format, .wav, .wave)
    Apple Lossless
    Video file formats
    AVCHD/Progressive,
    3GPP (3rd Generation Pertnership Project, .3gp)
    AVI (Audio Video Interleaved, .avi)
    DivX (.avi, divx,, .mkv)
    H.263
    H.264 / MPEG-4 Part 10 / AVC Video
    H.265 / MPEG-H Part 2 / HEVC
    MKV (Matroska Multimedia Container, .mkv, .mk3d, .mka, .mks)
    Quik Time (.mov,. qt)
    WMV (Windows Media Video, .wmv)
    MP4 (MPEG-4 Part 14, .mp4, .m4a,. m4p, .m4b, .m4r, .m4v)
    MPEG-4
    TS (MPEG Transport Stream, .ts, .tsv, .tsa)
    FLV
    VRO (DVD-VR, .VRO)
    VOB (Video Object, .vob)
    PS
    VP9, profile ?
    To playback HDR, a HDR source is required (H.264 or H.265(ST2084 or HLG format)
    Subtitles
    Micro DVD, SRT, SUB, SubRip, TMPlayer, TXT
    Obviously not playing DTS-HD tracks or TrueHD or ISO or Blu-ray folders (BDMV) and like all televisions, 24p videos are played in 60 im / s, but converting the framerate is well managed, with smooth playback without jerkiness and a picture of beauty. The reading is also interesting audio files with management Flac, WAV and ALAC, the ability to display album art or tags, but no native playback of files called "HiRes" all files in 88.2, 96, 176.4 or 192 kHz are downmixes in 48 kHz / 24 bits.
    Lan (100BASE-TX/10BASE-T)
    Wi-Fi,
    802.11 a,
    802.11 b,
    802.11 g,
    802.11 n,
    802.11 n 5GHz,
    802.11 ac,
    Wi-Fi Direct,
    DLNA 3.0,(DTCP-IP/DMP/DMR/DMS)
    Bluetooth(NFC) Ver.4.1 HID/HOGP/3DSP/SPP(for keyboard and mouse, no Bluetooth audio)
    Miracast,
    4096x2160 - 60p (displayed as 3840x2160)
    4096x2160 - 50p (displayed as 3840x2160)
    4096x2160 - 30p (displayed as 3840x2160)
    4096x2160 - 25p/4:4:4 (10, 12 bit) (displayed as 3840x2160)
    4096x2160 - 24p/4:4:4 (10, 12 bit) (displayed as 3840x2160)
    3840x2160 - 120- No
    3840x2160 - 60p /4:4:4, 8bit
    3840x2160 - 60p/4:2:2 (8,10,12-bit)
    3840x2160 - 60p/4:2:0 (8,10-bit)
    3840x2160 - 50p
    3840x2160 - 30p
    3840x2160 - 25p /4:4:4 (10, 12 bit)
    3840x2160 - 24p /4:4:4 (10, 12 bit)
    1920 x 1080 / 120Hz - ?
    1920 x 1080 / 60p (HDMI 1/2 / Component)
    1920 x 1080 / 50p (HDMI / Component)
    1920 x 1080 / 30p (Only HDMI 3/4)
    1920 x 1080 / 24p (Only HDMI)
    1920 x 1080 / 60i
    1920 x 1080 / 50i
    1366 x 720 / 24p (Only HDMI)-Up to 18Gbps
    HDR included in HDMI ??
    2 x USB 2.0 (DC 5V MAX 500mA)
    1 x USB 3.0 (DC 5V MAX 900mA)
    1 x Ethernet RJ45
    4 x HDMI 2.0a - (ARC(input 2), CEC, MHL 3.0)
    with HDCP (High-bandtwidth Digital Content protection) 2.2
    1 x AV Composite in 3.5mm jack
    1 x Video Component In 3.5mm jack
    1 x Optical Audio Out (AAC/PCM/AC3)- 18 dBm, 660 nm
    1 x Hedphone output (16-32Ω recommended)
    1 x SD Memory Card Slot (SDXC memory card compatible)
    1 x Antena (RF) (female)
    2 x CI + (ver. 1.3)
    1 x Satelite In (Main; F-type female)
    1 x Satelite In (Sub: F-type female)
    BS·110 degree CS-IF input terminal (75 Ω) and satellite antenna power supply (DC 15 V) output
    Compatible Rec.2020 input
    Analog (NTSC, PAL, SECAM)
    B/G,D/K,I (45,25MHz–863,25MHz)
    2x DVB-T/T2 (H.264) -T2 HD (H.265) (VHF/UHF)
    2x DVB-S/S2 (950-2150MHz) (DiSEqC version 1.0)
    2x DVB-C (VHF/UHF)
    1x TV>IP Server & Client
    Teletext - 2000 Pages (TOP & List)
    2T
    PAP (Picture and picture)
    PIP (Picture in picture)
    PAT (Picture and text)
    Timeshift & PVR
    (USB-HDD Recording)
    MPEG2,
    MPEG4,
    HEVC H.265 (to 3840x2160/60p, 10bit)
    VP9 ProFile.2
    The "real cinema" mode offers the best results by default. Then lower the brightness to 46 to get a white close to 150 cd / m². Then go to the advanced settings to adjust the gamma to 2.2.
    EZ1000 (Oled)
    TX-77EZ1000E
    TX-65EZ1000E
    EZW1004
    (for Germany)
    EZC1004
    (for Switzerland)
    EZC1004
    (for Switzerland)
    EZ1002B
    EZ950(Oled)
    TX-77EZ950E
    TX-65EZX50E
    EZW954
    EZC954
    (for Switzerland)
    EZ952B
    THX Cinema
    THX Bright room
    THX 4K Cinema
    No No Plattform:
    Core Architecture: ARM 4 Cortex A53
    Instruction set:
    Operating at up to:
    CPU: 64-bit
    GPU:
    Open GL
    RAM:
    Total memory:
    Available memory:
    Decoder: HEVC/VP9, UltraHD 60fps 10-bit
    E
    HTML5 v.2.0 SDK
    77" - AMOLED(Triple Stacked), 3840x2160, WRGB, 10-bit, No, 120/100Hz, Flat
    No vignetting;
    PWM - No
    BFI - No
    No backlight
    MEMC (IFC)
    BMR -
    Anti-Blur:
    Anti-Judder:
    ISF Professional
    3D LUT (look-up tables)
    - 8000 points
    YCbCr full range coverage.
    Finner gain controls (0.5 increments)
    CMS - RGBCYM
    No
    Gamma
    Rec.2020
    Rec.709
    Very Good for HD,
    77" -
    77" -
    77" -
    77" -
    77" -
    65" - DCI/P3 - 97% / 98%
    65" -
    65" -
    65" - 2.2
    65" -
    77" - max
    77" - max
    65" - max 800cd/m2 in HDR
    APL -
    77" -
    77" -
    77" - Inf.:1
    77" -
    77" - ? cd/m2
    77" - 0cd/m2
    65" -
    65" - x
    65" - Inf.:1
    65" -
    65" -
    65" - cd/m2
    65" - 0cd/m2
    77" - (h)
    77" - (v)
    65" - 65° (h)
    65" - ° (v)
    Color shift - 26°
    Brightness - 69°
    Black Level - 75°
    77" - (h)
    77" - (v)
    65" - (h)
    65" - (v)
    77" - in HDR mode
    77" - in Game mode
    77" - by default
    65"- in HDR - ms
    65"- in Game mode -
    65"- by default
    80W (RMS)
    Dolby Digital Plus
    Dolby Puls,
    No - DTS
    Image file formats
    Apple Lossless
    Video file formats
    AVCHD/Progressive,
    H.263
    MPEG-4
    FLV
    VRO (DVD-VR, .VRO)
    PS
    VP9, profile ?
    Subtitles
    Wi-Fi,
    802.11 a,
    802.11 b,
    802.11 g,
    802.11 n,
    802.11 n 5GHz,
    802.11 ac,
    Wi-Fi Direct,
    Miracast,
    3840x2160 - 120- No
    3840x2160 - 50p
    3840x2160 - 30p
    1920 x 1080 / 60i
    1920 x 1080 / 50i
    1 x Ethernet RJ45
    2 x CI + (ver. 1.3)
    2x DVB-C (VHF/UHF)
    2T
    Timeshift & PVR
    (USB-HDD Recording)
    MPEG2,
    MPEG4,
    VP9 ProFile.2
    EZ950 (Oled)
    TX-77EZ950E
    TX-65EZX50E
    EZW954
    (for Germany)
    EZC954
    (for Switzerland)
    EZ952B
    ________________
    UHD Premium
    _____
    ISF ccc
    ________
    ISFccc -
    Certified
    Calibration
    Configuration
    THX
    ________
    Accurate Color
    Reproduction
    Sharper Pictures
    Automation System
    IP Home Control
    __________
    HDR 10
    ST2084
    (EOTF PQ),
    ST2086
    (static metadata)
    ST2094
    (dynamic metadata)
    ________
    Hybrid
    Log Gamma
    (HLG)
    _____
    Dolby Vision
    VS10
    ____
    _______
    SoC / GPU / RAM
    Plattform,
    System on Chip,
    Instruction set,
    RAM,
    Total memory
    Software
    ____________
    Operating System,
    Firmware version,
    Videopanel
    Size class,
    Resolution,
    Pixel structure,
    Bits of color,
    Quantum dots,
    Curvature,
    Screen Uniformity,
    Backlight Unit
    ______________
    Type backlight,
    Local Dimming zone,
    Type LED,
    MEMC,
    Backlight Scanning,
    Frame Interpolation
    ________________
    ISF ccc,
    3D LUT,
    White balance,
    Gamma,
    Internal Processing
    IScalling,
    nterpolation,
    Overscaninng,
    Colorimetry
    White balance dE,
    Color Delta E,
    Gamma,
    Color Temperature,
    Brightness
    Peak in HDR
    Peak in SDR,
    Contrast
    ______________
    ANSI Contrast,
    With local dimming,
    Static contrast,
    Dinamic contrast,
    White level,
    Black level
    Viewing angle
    _____________
    (°cone)
    Motion resolution
    ______________
    Input Lag
    ________________
    in HDR
    in Game mode
    by default
    Audio
    Total power,
    speakers,
    Surround,
    Sound mode,
    Image file formats
    Video file formats
    Subtitles
    Connectivity
    __________________
    Chroma subsampling
    4:4:4
    4:2:2
    4:2:0
    Conectors
    Tuners
    Tuners,
    Teletext reception,
    Multi window,
    Timeshift,
    PVR,
    Note
    __________________
    EX780 (LCD)
    TX-75EX780E
    TX-65EX780E
    TX-58EX780E
    TZ-50EX780E
    EXX789
    EXN788
    EXF787
    EXT786
    EXW784
    (Germany, Niderland,
    Switzerland, France)
    EX752B
    No Yes No Crestron / Control4 Yes - in TV, Internet video services, HDMI, USB port. Yes - in terrestrial and satellite TV,
    No No Plattform:
    SoC: MediaTek MT5
    Core Architecture: 4 cores
    Instruction set:
    Operating at up to:
    GPU:
    Open GL
    RAM:
    Total memory:
    Available memory:
    E
    OS: Firefox 2.5
    HTML5 v.2.0 SDK
    74,5" - SMVA(Innolux), 3840x2160, RGB, 10-bit, ?, 120/100Hz with MCFI + blinking backlight
    64,5" - SMVA(Innolux), 3840x2160, RGB, 10-bit, ?, 120/100Hz with MCFI + blinking backlight
    58" - SMVA(Innolux), 3840x2160, RGB, 10-bit, ?, 120/100Hz with MCFI + blinking backlight
    49,5" - SMVA(Innolux), 3840x2160, RGB, 10-bit, ?, 120/100Hz with MCFI + blinking backlight
    Index - 2400 BMR IFC
    Edge Led (Down),
    Local Dimming
    65" - 15 sections(5x3)
    58" - 12 sections(4x3),
    W-Led,
    Yes,
    No
    Yes,
    MEMC (IFC)
    BMR - 2400
    Anti-Blur:
    Anti-Juddering:
    Led Motion:
    ISF Professional
    - allows professional users to upload their own colour 3D LUTs in cube format by SD/USB memory, if required
    - ability to load 1D Lut
    CMS - RGBCYM
    No
    Gamma
    Rec.2020
    Rec.709
    Very Good for HD,
    75" - DCI/P3-
    75" - BT.2020 -
    75" -
    75" - average dE 0.5 / max dE 2.0
    75" -
    75" -
    65" -
    65" -
    65" -
    65" -
    65" -
    58" -
    58" -
    58" -
    58" -
    58" -
    Corors -
    75" - max 540 nits in HDR
    75" - max 380 nits in SDR
    75" -
    75" -
    65" - max 550 nits in HDR
    65" - max nits in SDR
    65" -
    65" -
    58" - max 550 nits in HDR
    58" - max nits in SDR
    58" -
    58" -
    50" - max 550 nits in HDR
    50" - max
    50" -
    50" -
    75" - 4100:1
    75" -
    75" -
    75" -
    75" -
    75" -
    75" -
    65" -
    65" -
    65" -
    65" -
    65" -
    58" -
    58" -
    58" -
    58" -
    58" -
    50" -
    50" -
    50" -
    50" -
    50" -
    75" - (h)
    75" - (v)
    65" - (h)
    65" - (v)
    58" - (h)
    58" - (v)
    50" - (h)
    50" - (v)
    75" - (h)
    75" - (v)
    65" - (h)
    65" - (v)
    58" - (h)
    58" - (v)
    50" - (h)
    50" - (v)
    77" - 22ms
    77" - 22ms
    77" -
    65" - 22ms
    65" -
    65" -
    58" -
    58" -
    58" -
    50" -
    50" -
    50" -
    Image file formats
    Apple Lossless
    Video file formats
    AVCHD/Progressive,
    H.263
    MPEG-4
    FLV
    VRO (DVD-VR, .VRO)
    PS
    VP9, profile ?
    Subtitles
    Wi-Fi,
    802.11 a,
    802.11 b,
    802.11 g,
    802.11 n,
    802.11 n 5GHz,
    802.11 ac,
    Wi-Fi Direct,
    Miracast,
    3840x2160 - 60p, 50p, 30p, 25p, 24p,
    4096x2160 - 60p, 50p, 30p, 25p, 24p,
    2160p 60fps mode "4K Pure Direct" - 4:4:4
    1 x Ethernet RJ45
    2 x CI + (ver. 1.3)
    2x DVB-C (VHF/UHF)
    Teletext - 1500 Pages (TOP & List)
    2T
    Timeshift & PVR
    (USB-HDD Recording)
    Programs recorded on a USB hard disk on a TV can only be played on the recorded TV. Please do not use USB hard disk formatted on TV with other equipment. When used with other equipment, reformatting becomes necessary, and all the recorded programs and saved data are deleted.
    MPEG2,
    MPEG4,
    VP9 ProFile.2
    The suggested choice is, of course, "True Cinema" if you do not intend to make any adjustments. It is this mode is set in accordance with the correct reproduction of the image (as seen director). If you want to adjust the picture after his, it is best to use this mode to "Custom Settings". In each mode should make sure that the feature is not enabled overscan, trimming edges of the picture: Image -> Settings screen -> 16: 9 Overscan -> Off
    65EX780 - Stand (Rotation)
    58EX780 - Stand (rotation and heel height)
    50EX780 - Stand (rotation and height adjustment)
    EX780 (LCD)
    TX-75EX780E
    TX-65EX780E
    TX-58EX780E
    TZ-50EX750E
    EXW784
    (for Germany & Switxerland)
    EX782B
    EXR700
    (for Russia)
    EX730 (LCD)
    TX-65EX730E
    TX-58EX730E
    TX-50EX730E
    TX-40EX730E
    EXW735
    EXW734
    (for Germany,
    Switzerland,
    Niderland)
    EX732B
    No No Plattform:
    Instruction set:
    Operating at up to:
    GPU:
    Open GL
    RAM:
    Total memory:
    Available memory:
    E
    OS: Firefox 2.5
    HTML5 v.2.0 SDK
    65" - S-MVA(Innolux), 3840x2160, RGB, 8-bit + FRC, 60/50Hz, Flat
    58" - SMVA(Innolux), 3840x2160, RGB, 8-bit + FRC, 60/50Hz, Flat
    50" - SMVA(Innolux), 3840x2160, RGB, 8-bit + FRC, 60/50Hz, Flat
    40" - SMVA(Innolux), 3840x2160, RGB, 8-bit + FRC, 60/50Hz, Flat
    Edge Led (Down),
    Local Dimming,
    W-Led,
    Yes - IFC,
    MEMC (IFC)
    BMR - 1600
    (Backlight Motin Rate)
    Very Good for HD,
    65" - max 350cd/m2 in HDR
    65" - max 350cd/m2 in SDR
    APL -
    ABL -
    65" -
    65" -
    65" -
    65" -
    65" -
    65" - cd/m2
    65" - cd/m2
    65" - °(h)/ °(v)
    Color shift - °
    Brightness - °
    Black Level - °
    65" - horizontal lines
    65"- HDR - ms
    65"- Game mode -
    65"- by default
    2 x 10W (RMS) FAT16, FAT 32, NTFS and exFAT
    Image file formats
    Apple Lossless
    Video file formats
    AVCHD/Progressive,
    H.263
    MPEG-4
    FLV
    VRO (DVD-VR, .VRO)
    PS
    VP9, profile ?
    Subtitles
    UltraHD for HDMi 1 & 2
    Regime1: 4:4:4, 4:2:2(30p, 25p, 24p), 4:2:0(60p, 50p)
    Regime2: 4:4:4, 4:2:2(30p, 25p, 24p), 4:4:4, 4:2:2, 4:2:0(60p, 50p)
    1 x Ethernet RJ45
    2 x CI + (ver. 1.3)
    2x DVB-C (VHF/UHF)
    2T
    Timeshift & PVR
    (USB-HDD Recording)
    MPEG2,
    MPEG4,
    VP9 ProFile.2
    EX730 (LCD)
    TX-65EX730E
    TX-58EX730E
    TX-50EX730E
    TX-40EX730E
    EXW734
    (for Germany & Switzerland)
    EX732B
    EX700 (LCD)
    TX-65EX700E
    TX-58EX700E
    TX-50EX700E
    TX-40EX700E
    703/700-> difference in built-in tuners
    EXW704
    EX700B
    EXR700
    (for Russia)
    No No Plattform:
    Instruction set:
    Operating at up to:
    CPU:
    GPU:
    Open GL
    RAM:
    Total memory:
    Available memory:
    E
    OS: Firefox 2.5
    HTML5 v.2.0 SDK
    65" - SMVA(Innolux), 3840x2160, RGB, 8-bit + FRC, 60/50Hz, Flat
    Index 1600 BMR IFC
    Edge Led,
    Local Dimming ?,
    W-Led,
    Very Good for HD,
    65" - DCI/P3 - % / %
    65" - BT.2020 - % / %
    65" -
    65" -
    65" -
    65" -
    65" - max cd/m2 in HDR
    65" - max cd/m2 in SDR
    APL -
    ABL -
    65" -
    65" -
    65" -
    65" -
    65" -
    65" - cd/m2
    65" - cd/m2
    65" - 65°(h)/(v)
    Color shift -
    Brightness -
    Black Level -
    65"- HDR - ms
    65"- Game mode -
    65"- by default
    2 x 10W (RMS)
    Dolby Digital Plus ?
    Dolby Puls,
    No - DTS
    Image file formats
    Apple Lossless
    Video file formats
    AVCHD/Progressive,
    H.263
    MPEG-4
    FLV
    VRO (DVD-VR, .VRO)
    PS
    VP9, profile ?
    Subtitles
    Wi-Fi,
    802.11 a,
    802.11 b,
    802.11 g,
    802.11 n,
    802.11 n 5GHz,
    802.11 ac,
    Wi-Fi Direct,
    No - Bluetooth
    Miracast,
    HbbTV
    UltraHD for HDMI 1 & 2
    1 x Ethernet RJ45
    3 x HDMI 2.0a - (ARC(input 2), CEC, MHL 3.0)
    1 x CI + (ver. 1.3)
    1 x Satelite In (Main; F-type female) only in EX703
    No Bluetooth
    EX700 - DVB-T/T2/C
    EX703 - DVB-T/T2/C/S2
    EX700B - DVB-T/T2/S2
    DVB-C (VHF/UHF)
    TV>IP Client
    Teletext - 1000 Pages (TOP & List)
    2T
    Timeshift & PVR
    (USB-HDD Recording) with Rewind Live TV
    MPEG2,
    MPEG4,
    VP9 ProFile.2
    EX703 (LCD)
    TX-65EX700E (703)
    TX-58EX700E (703)
    TX-50EX700E (703)
    TX-40EX700E (703)
    EXW704
    EX702B
    EX600 (LCD)
    TX-65EX600E
    TX-55EX600E
    TX-49EX600E
    TX-43EX600E
    TX-40EX600E
    603/600->difference in built-in tuners
    EXW604
    EXW604S
    EX602B
    The TV also offers a HDR Bright Enhancer mode in order to boost the luminance in theory, in practice its activation does not bring any benefit. On the other hand, we appreciate the possibility of activating the HDR in any Image mode, even in Game mode.
    No No Plattform:
    SoC: MediaTek MT55
    Instruction set:
    Operating at up to:
    CPU:
    GPU:
    Open GL
    RAM:
    Total memory:
    Available memory:
    E
    OS: Firefox 2.5
    HTML5 v.2.0 SDK
    55" - IPS(LG Display), 3840x2160, RGB, 8-bit + FRC
    49" - IPS(LG Display), 3840x2160, RGB, 8-bit + FRC
    43" - IPS(LG Display), 3840x2160, RGB, 8-bit
    40" - S-MVA(Innolux), 3840x2160, RGB, 8-bit
    Edge Led
    The EX600 does not offer any dimming room but a simple Adaptive Backlight Dimming to modulate the backlight. In addition to being inefficient, the mechanism causes a loss of legibility in dark scenes, whichever mode is selected, it is better to quickly disable it.
    BMR - 1300
    Intelligent Frame Creation (IFC) motion compensation is particularly effective set to Minimum, on the other hand Blu-ray , Blu-ray 4K UHD and other content encoded in 24p Custom mode remains more advisable in order to manually adjust the Fluidity and Clarity settings. There is also a Clear Motion option that inserts a black image between each frame (BFI), but its use generates a noticeable blinking effect.
    CMS-RGBCYM
    As with the higher-end models, the manufacturer offers a complete set of tools to fine-tune the TV to a 10-point gray scale, a CMS adjustable to the 6 primary and secondary colors RGBCYM, and Predefined gamma values ​​that can also be adjusted manually.
    Very Good for HD,
    65" -
    65" -
    65" -
    65" - <2.0
    65" -
    65" -
    55" -
    55" -
    55" - BT.2020 - 51%
    55" - <2.0
    55" - (True Cinema) 2.3
    55" - 6642K
    Just be sure to adjust the Gamma setting to 2.5 so as to get an average of 2.4, in daytime you can switch to 2.3 to get a real gamma of 2.2. The colorimetry is also a pleasant surprise, the saturations are well adjusted with an excellent average DeltaE of 1.46.
    49" -
    49" -
    49" -
    49" -
    49" -
    49" -
    40" -
    40" -
    40" -
    40" -
    40" -
    40" -
    65" - max
    65" - max
    55" - max 318cd/m2 in HDR (10% test pattern)
    55" - max
    49" - max
    49" - max
    40" - max
    40" - max
    65" -
    65" -
    65" -
    65" -
    65" -
    65" -
    65" -
    55" - 760:1
    55" -
    55" -
    55" -
    55" -
    55" -
    55" - 0.17cd/m2
    49" -
    49" -
    49" -
    49" -
    49" -
    49" -
    49" -
    40" -
    40" -
    40" -
    40" -
    40" -
    40" -
    40" -
    65" -
    65" -
    65" -
    55" -
    55" - 20.9ms (True Cinema)
    55" -
    49" -
    49" -
    49" -
    40" -
    40" -
    40" -
    2 x 10W (RMS)
    VR Audio True Surround
    Image file formats
    Apple Lossless
    Video file formats
    AVCHD/Progressive,
    H.263
    MPEG-4
    FLV
    VRO (DVD-VR, .VRO)
    PS
    VP9, profile ?
    Subtitles
    Multiple audio tracks and subtitles are handled well, with the ability to adjust their size / position / color, not to mention Dolby Digital (but not DTS) compatibility.
    Unfortunately, 10-bit HEVC videos whose bitrate exceeds 100 Mbps are still not played back.
    Wi-Fi,
    802.11 a,
    802.11 b,
    802.11 g,
    802.11 n,
    802.11 n 5GHz,
    802.11 ac,
    Wi-Fi Direct,
    No - Bluetooth
    Miracast,
    HbbTV
    1 x Ethernet RJ45
    1 x CI + (ver. 1.3)
    1 x Satelite In (Main; F-type female) only in EX603
    No Bluetooth
    EX600 - DVB-T/T2/C
    EX603 - DVB-T/T2/C/S2
    DVB-C (VHF/UHF)
    IP>TV Client
    2T
    Timeshift & PVR
    (USB-HDD Recording)
    MPEG2,
    MPEG4,
    VP9 ProFile.2
    + Nice picture quality UHD 4K
    + 4K Upscaling Effective on HD Sources
    + Very good settings in carton out
    + Good viewing angles
    + Excellent input lag
    + Fluidity and clarity of the Smart TV + + + Firefox interface
    + Connectivity (three HDMI 2.0a inputs)
    - Low contrast and black depth
    - Limited coverage of the Rec 2020 and
    - HDR rendering little impact
    - A Dummy Adaptive Backlight Dimming
    - Perfectible manufacturing quality
    EX600 (LCD)
    TX-65EX600E (603)
    TX-55EX600E (603)
    TZ-49EX600E (603)
    TX-40EX600E (603)
    EXW604
    EX602B
    Този пост е редактиран от hristoslav2; 21-05-17 в 23:54.
    #108
    Да го беше превел
    Panasonic EZ има по-добра картина (out of the box) сред OLED. Повече възможности за калибрация. Отлично мащабиране както и в Sony A1. Компенсацията на движения е по-добра в Sony. Panasonic EZ има BFI (но забележимо мигане както и в Sony). Panasonic EZ е по-ярък от A1, с по-добра детайлизация в сенките и цветовете. Panasonic EZ има по-добра картина с UHD Blu-ray Master for 4000 nits, Sony A1 дава по-добра картина при UHD Blu-ray диск за 1000 nits.
    От минусите: проблеми с цветовата градация както при LG C7, но е възможно uhd дискът да е проблемен, скриншота от който те привеждат във всички обзори или Sony да е по-добър в градациите? Няма поддръжка на Dynamic HDR/Dolby Vision.
    https://www.homecinemamagazine.nl/20...w1004-oled-tv/
    Panasonic EZ1002/ EZ1000 OLED TV Unboxing + Picture Settings
    We unbox the Panasonic EZ1002 4K OLED TV, which is also marketed as the EZ1000 series outside the UK. After initial set-up, we explain the various picture settings available in the user menu.
    http://www.hdfever.fr/forum/viewtopi...rt=320#p317881
    Таблицата може да бъде допълнена. Ако имате предложения или информация - пишете.
    Multimedia player in Panasonic TV 2017
    Specifications
    Multimedia
    Series
    EX600/620/630
    Series
    EX700/720/730
    Series
    EX750/780
    EZ900/1000
    Media Gateway / Sources Ethernet (wired) • Wi-Fi (wireless) • USB Port Ethernet (wired) • Wi-Fi (wireless) • USB Port Ethernet (wired) • Wi-Fi (wireless) • USB Port
    video
    • File Extensions: 3G2 • 3GP • ASF • AVI • F4V • FLV • M2TS • M4V • MKV • MOD • MP4 • MPEG • MPG • MTS • TP • TRP • TS • TTS • VOB • VRO • WEBM • WMV 3G2 • 3GP • ASF • AVI • F4V • FLV • M2TS • M4V • MKV • MOD • MP4 • MPEG • MPG • MTS • TP • TRP • TS • TTS • VOB • VRO • WEBM • WMV
    • Formats / Containers: 3GPP • ASF • AVI • FLV • MKV • MP4 • PS • TS • WEBM 3GPP • ASF • AVI • FLV • MKV • MP4 • PS • TS • WEBM
    Codecs : H.264 • H.265 / HEVC • MPEG1 • MPEG2 • MPEG4 • VC-1 • VP9 • WMV9 H.264 • H.265 / HEVC • MPEG1 • MPEG2 • MPEG4 • VC-1 • VP9 • WMV9
    audio
    Codecs : AAC • ADPCM • DOLBY DIGITAL • DOLBY DIGITAL PLUS • HE-AAC • LPCM • MP3 • MPEG AUDIO • VORBIS • WMA • WMA PRO AAC • ADPCM • DOLBY DIGITAL • DOLBY DIGITAL PLUS • HE-AAC • LPCM • MP3 • MPEG AUDIO • VORBIS • WMA • WMA PRO
    • File Extensions: FLAC • M4A • MP3 • WAV • WMA FLAC • M4A • MP3 • WAV • WMA
    • Formats / Containers: AAC • APPLE LOSSLESS • FLAC • LPCM • MP3 • WMA • WMA PRO AAC • APPLE LOSSLESS • FLAC • LPCM • MP3 • WMA • WMA PRO
    • Codecs : AC • APPLE LOSSLESS • FLAC • LPCM • MP3 • WMA • WMA PRO AAC • APPLE LOSSLESS • FLAC • LPCM • MP3 • WMA • WMA PRO
    Images / Photos
    • File Extensions: JPEG • JPG JPEG • JPG
    • Formats: JPEG JPEG
    Subtitles
    • Files: SRT • SUB • TXT SRT • SUB • TXT
    • External Formats: MicroDVD • SubRip • TMPlayer MicroDVD • SubRip • TMPlayer
    Този пост е редактиран от hristoslav2; 21-05-17 в 19:20.
    #109
    Да го беше превел
    Който може - да превежда от немски ... , не че и ти ги превеждаше до сега де
    Panasonic EZ1002 4K OLED TV Review
    #110
    Panasonic EXW784 Review - Life on big foot
    Google translate Ni to Bg
    source photo:[tweakers.net]
    Panasonic TX-55EX600 : Test complet - Téléviseur - Les Numériques
    TX-55EX600:IPS panel true UHD (RGB),Full LED-global dimming,50/60Hz
    S-IPS panel
    подсветка в долната част на рамката
    We explain different HDR tone-mapping algorithms using the Sony A1, LG C7 & Panasonic EZ1002 OLED TVs that so happen to arrive in our test room during the same week.
    Винсънт Teo от HDTVtest обяснява "от негова гледна точка" Плюсовете и минусите на три различни подхода в "HDR Tone Mapping", които са адаптирани за А1, C7 и EZ1000 ... ясно е, в рамките на "присъщите" ABL ограничения на OLED технологията (при преминаване в режим HDR).
    Той обръща внимание, че вижда различни "равноотдалечени" технически резултати в измерването на пиковата яркост при HDR в 65 "EZ1000 ...
    "LesNumeriques" - 792 нита
    "digitalfersehenden" - 850 нита,
    "AVForums" - 640 нита ...
    65 "EZ950 и 65" EZ1000 в техните режими THX , Real Cinema, Professional 1 и 2 дават около 800 нита не повече ... а режим Vivid трябва да бъде около 900 нита;
    55 "EZ950 в точните режими трябва да бъде около 700 нита, а неговата максимална яркост около 800 нита ....
    https://www.avforums.com/threads/son...#post-25051494
    The EZW 1004, the brand new OLED TV from Panasonic has arrived at the editorial office. We did not wait long and unpacked it. As you know it from us, we explain this time, of course, all the important details that this stylish TV has to offer.
    source video:[youtube.com - video TechNite]
    Panasonic's new EZ1002B 4K OLED TV promises supreme colour accuracy and an uncompromising approach to picture quality combined with semi-professional image processing.
    Този пост е редактиран от hristoslav2; 27-05-17 в 18:31.
    #111
    Как да разчетем моделният префикс на телевизор Panasonic?
    пример- TX-50EXW734E
    T - телевизор
    X - континентално предназначение
    • X - Europe
    • H - Asia, Africa, Middle East, Oceania (Australia & New Zeeland)
    • C - Nord & South America
    50 - диагонален размер на екрана в инчове /1инч - 2,5 см/
    • 65" - 162,5 см
    • 60" - 150,0 см
    • 58" - 145,0 см
    • 55" - 137,5 см
    • 50" - 125,0 см
    • 49" - 122,5 см
    • 43" - 107.5 см
    • 42" - 105,0 см
    • 40" - 100,0 см
    • 39" - 97,5 см
    • 32" - 80,0 см
    E - година на модела
    • A - 2014
    • C - 2015
    • D - 2016
    • Е - 2017
    X - Резолюция (липсата на тази буква показва, че модела е HDReady - пример 32E300E)
    • X - ULTHRA HD (3840x2160)
    • S - FullHD (1920x1080)
    W - модели с разлика в комплектацията, предназначени за различни вериги ритейлъри- модели с това обозначение като правило не се продават у нас
    • C - Швейцария
    • W - Германия
    • E - Белгия
    • N - Нидерландия
    • R - ***** и Украина (само 2 езика в менюто, няма PVR + измама с модела - техният DX800 това е нашият DX700 и т.н. по веригата)
    • F - Франция и Нидерландия
    • T - Австрия
    • M - Нидерландия
    • X - Нидерландия
    7 - Серия
    • 9 - флагман
    • 8 - висок клас
    • 7 - среден клас
    • 6 - среден клас
    • 5 - бюджетна серия
    • 4 - основна серия
    • 3 - базова серия
    7 - Под-серия, показваща хардуерни различия
    • 8 -
    • 7 -
    • 6 -
    • 5 -
    • 5 -
    • 4 -
    • 3 -
    • 2 -
    • 1 -
    • 0 -
    4 - това са модели по поръчка на търговски вериги /разликите в комплектацията
    Някои от вас са забелязали, че моделите в някои европейски страни като Германия, Холандия и Англия завършват на цифра 4(например DXW904, DX804)....Тези модели се различават софтуерно спрямо моделите продавани у нас (завършват на 0).Има хардуерна разлика при моделите за Германия и Швейцария(за отделни търговски вериги) - вграден допълнително сателитен тунер в моделите от средният и ниският клас или променен цвят на корпуса.
    За Англия моделният код завършва с цифра 2 и буква B в края(пример DX902B) - това е заради различната система на EPG прилагана при тях - MHEG. Затова и ъпдейтите за тях са отделно.
    • 9 -
    • 8 - Double tuner - DVB-T/T2/C/S/S2 (HEVC)
    • 7 -
    • 6 -
    • 5 - DVB-T/T2/C (HEVC for UltraHD models)
    • 4 - 2 x DVB-T2 (H.264) für Österreich, DVB-T2 HD (H.265) für Deutschland / DVB-S2 / DVB-C / TV>IP
    • 3 - DVB-T/T2/C/S2 (HEVC for UltraHD models)
    • 2 -
    • 1 -
    • 0 - DVB-T/T2/C
    Е - регионално предназначение /и цвят на корпуса/:
    • E - Europa,
    • ES - Europe, Silver color
    • F - Europe-France....?
    • S - Silver color,
    • B - Britain & Ireland (заредени със софтуер за MHEG[еквивалент на EPG])
    • W - white color
    Други кодове за регионално предназначение
    Asia
    • C - China
    • D - India, Nepal
    • H - Hong Kong
    • R - Iran
    • S - Singapure, Indonesia and Philipinnes
    • T - Thailand
    • K - Malaysia
    • W - Taiwan
    Oceania
    • A - Australia
    • Z - New Zeeland
    • U - Australia, New Zeeland
    Midlle East & Africa
    • M - Kuwait, UAE, Egypt, Lebanon, Syria, Saudi Arabia
    • Q - Africa
    Nord America
    • U - United States & Canada
    • X - Mexico
    South America
    • A - Argentina
    • B - Brasil
    • H -
    • L - Peru, Bolivia, Paraguay
    • X -
    Регистриране за 5 години гаранция
    https://panasonic5y.com/bg-BG/Promo-models.aspx
    Panasonic модели телевизори 2017
    Panasonic Home Entertainment Spring 2017 [.pdf]
    http://www.panasonic.com/content/dam...2017%20(1).pdf
    http://www.panasonic.com/content/dam...017_spring.pdf
    LED LCD телевизори VIERA - Panasonic
    Telewizory Panasonic 2017 – TV TEST
    Няма да има нова 9-та серия. Продължава продажбата на миналогодишната серия DX900.
    Няма нито един модел с извит дисплей - всички са плоски. Пикът на предлагането на телевизори с извит екран в Европа, беше през 2015 година, но през 2017 година те вече са рядкост. Свърши мейнстрийма в западните страни, докато в Азия, извитите телевизори се считат за премиални модели.
    https://fotos.subefotos.com/4160c00c...ebb95d648o.jpg
    65DX900 - (2016 модел, продължава през 2017 г.)
    58DX900 - (2016 модел, продължава през 2017 г.)
    58DX800 - (2016 модел, продължава през 2017 г.) до изчерпване на бройките
    50DX800 - (2016 модел, продължава през 2017 г.) до изчерпване на бройките
    High-End
    Двете нови Oled серии, идват като заместници на серия CZ950.
    77EZ1000 - UltraHD/HDR, OLED, THX, Quattro тунер с 2 CI слота(2 x DVB-T2/C/S2/IP)
    65EZ1000 - UltraHD HDR, OLED, THX, Quattro тунер с 2 CI слота(2 x DVB-T2/C/S2/IP)
    Добавен е антиотражателен филтър.
    Комбинирано дистанционно - алуминии отгоре с подсветка, отдолу пластмаса
    source photo: [nl.hardware.info]
    Портовете са поставени отзад на устройството. Откриваме два HDMI порта насочени встрани и два назад, два USB насочени назад и един отстрани, четец на SD карта, три антенни конектора, жак за слушалки и компонент/композит видео вход. Оптичен цифров изход, Lan порт, вграден Wi-Fi и също Bluetooth, последният е само за клавиатура и мишка, а не за аудио устройства.
    Всички връзки могат да бъдат скрити зад панела, но това очевидно е възможно, ако използвате само страничните портове. За тези връзки Panasonic включва и подреждане на кабелите, но най-вероятно не могат да бъдат скрити повече от два HDMI кабела .
    sorce photo: [homecinemamagazine.nl]
    Насочените назад портове ще бъдат проблем, ако искате да закачите телевизора по-плътно до стената.
    http://img1.lesnumeriques.com/test/1...sans-cache.jpg
    http://img1.lesnumeriques.com/test/1...-son-cable.jpg
    http://img1.lesnumeriques.com/test/1...-cache-son.jpg
    65EZ950 - UltraHD HDR, OLED, THX, Quattro тунер с 2 CI слота(2 x DVB-T2/C/S2/IP)
    55EZ950 - UltraHD HDR, OLED, THX, Quattro тунер с 2 CI слота(2 x DVB-T2/C/S2/IP)
    Единствената разлика в панелите е присъствието на антиотражателен филтър в серия EZ1000 и липсата му в EZ950.
    Input Lag в HDR режим - 30ms
    Двете Oled серии използват едни и същи Oled панели на LGDisplay и процесори(вероятно на MediaTek). Разликата е, че EZ950 няма филтър и саунд бар, като в EZ1000
    Телевизорите използват новият OLED панел на LG 2017. Инженерите заявиха, че това е специален панел, произведен за нуждите на Panasonic...Ха това може да се провери само със снимки на структурата на пиксела.
    Неговото поколение се дефинира като G3.5 (броят генерации Ultra HD Oled панели - 2014, 2015, 2016, 2017), докато предшественикът му CZ950, използва панел от 2-ро поколение, а до миналата година (2016 г.), LG има 3 поколения панели(генерации). Новият панел е по-лек от предишния почти двойно (имам предвид CZ950) и осигурява много по-добро покритие на цветовото пространство(99% DCI).
    Друга техническа разработка, е прилагането на анти-отражателен филтър - Absolute Black Filter, чието преимущество e абсорбирането на светлината от околната атмосфера и елиминира отраженията. Нещо повече, той напълно елиминира лилавият оттенък на OLED панели в присъствието на силна външна светлина.
    Да припомня, че се използва подобрена версия на софтуера от миналогодишният Oled CZ950, за показване на големи подробности в най-тъмните сцени на изображението. В допълнение, инженерите от Panasonic казаха, че за да се постигне това ниво на детайлност в тъмни области на изображението (като например нощна сцена с движение), се налага пълен контрол на повторното запалване на пиксела след неговото изгасване. Запалването отново на напълно потушен пиксел за показване лека текстура (с много ниско ниво на яркост), пак според тези инженери е истинско техническо предизвикателство. Предизвикателство, което Panasonic са решили, благодарение на дългогодишния си опит и експертиза в плазмената технология.
    Двете серии разполагат с по две дистанционни. Едно стандартно алуминиево с подсветка и второ смарт тъчпад, с който да местите курсора по екрана.
    Middle Range
    75, 65, 58, 50, EX780E(in Europe) -> EX750B(in UK) - 120/100Нz, UltrаНD, НDR, Edge Led Lосаl Dіmmіng, 3D, Quаttrо тyнep c 2 СІ cлoтa(2 х DVВ-Т2/С/Ѕ2/ІР), 3D Active, Edge Led(Down) Local Dimming, яркост от 800nit.
    У нас ще се предлага само серия EX780 с кръстата стойка.
    В някои страни от западна Европа, се предлагат модели с правоъгълна стойка.
    Единствената серия, която тази година поддържа 3D. Очилата се синхронизират по Bluethoot, така че може да ползвате очила и от други марки телевизори- например Samsung SSG-5100.
    Звукът на EX780 се осигурява от два пълни високоговорителя, които седят в долната част на корпуса, а звукът е насочен надолу. Това е най-често срещаната настройка за високоговорителите в телевизор, но за съжаление не най-добрата. Поради това, че звукът няма ясен фокус върху ушите ви, ще чуете само косвен звук, който е отразен един или повече пъти, както и има неблагоприятен ефект върху стерео образа и яснотата на гласовете.
    Като цяло, звукът не е лош, но не е особено добър.
    Switch Design (Многофункционален дизайн). На гърба има и система за прикриване на всички кабели от погледа (преминават в централния пиедестал на стойката).
    Серията EX780 изглежда много впечатляващо. Това в немалка степен се дължи на огромната X-образна основа. С тегло от 4,5 кг отнема много място, но това е солидна основа, но и нещо друго. Това е така, защото функцията на въртяща се основа, е нещо което оценявам. Много съвременни устройства използват крака в краищата на телевизора. Които са по-малки и по своята същност стабилни, но очевидно не позволяват да завъртите телевизора.
    65" - Cтoйĸa(въpтeнe)
    58" - Cтoйĸa(въpтeнe и регулиране на виcoчинaта)
    50" - Cтoйĸa(въpтeнe и peгyлиpане на виcoчинaта)
    Stand: 50" & 58"" - up/down + swivel, 65" swivel, 75" - fixed
    Звукът на изхода за слушалки може да се регулира отделно.
    Друг важен момент и уникална характеристика на серията Panasonic EX е функцията за гласови указания. Това е функция за четене, особено важна за хора или с влошено зрение или дислексия. Четецът на съобщения ви чете при поискване цялото текстово съдържание на екрана, като менюта, уеб страници или EPGs. Засега няма информация на колко езика чете.
    Серията е с Edge Led подсветка в долната част, с "локално затъмняване"...(Digitally Enhanced Local Dimming).
    source photo: dday.it
    На термоснимката, ясно се виждат 3 сектора в долната част на рамката, и 3-те осветени от тях секции, от общо 12 (4 x 3).
    Серия ЕХ730 (65, 58, 50, 40) - UltrаНD, НDR, Edge Led Lосаl Dіmmіng, Quаtrо тyнep c 2 СІ cлoтa(2 х DVВ-Т2/С/Ѕ2/ІР),
    EXW735 -
    EX730 -
    Edge Led Local Dimming (от двете страни на дисплея), яркост от 350 nit, 90% покритие на цветовото пространство DCI/P3
    Крачетата от стойката може да се местят в близост до центъра или по краищата - в 2 позиции.
    65, 58, 50, 40, ЕХ700 - UltrаНD, НDR, Lосаl Dіmmіng, Quаtrо тyнep (2 х DVВ-Т2/С/Ѕ2/ІР), Backlight Motion Rate IFC 1600, Телетекст 1000р, Дистанционно комбинирано, алуминии с пластмаса
    Edge Led, с яркост от 350 nit
    Крачетата от стойката може да се обръщат, и местят в близост до центъра или по краищата - в 4 позиции.
    Entry Level
    Серия EX60 (55, 49, 40)
    EX633E - UltrаНD, 60/50Hz, HDR, Quаtrо тyнep(DVВ-Т2/С/Ѕ2/ІР), Backlight Motion Rate IFC 1500, Телетекст 1000р,
    EX630E - UltrаНD, 60/50Hz, HDR, Quаtrо тyнep(DVВ-Т2/С/Ѕ2/ІР), Backlight Motion Rate IFC 1500, Телетекст 1000р,
    EX620E - UltrаНD, 60/50Hz, HDR, Quаtrо тyнep(DVВ-Т2/С/Ѕ2/ІР), Backlight Motion Rate IFC 1500, Дистанционно N2QAYB001111
    EX613E - UltrаНD, 60/50Hz, HDR, Quаtrо тyнep(DVВ-Т2/С/Ѕ2/ІР),
    EX610E - UltrаНD, 60/50Hz, HDR, Backlight Motion Rate IFC 1500, Цвят-сребрист, Дистанционно N2QAYB001115
    EXW604 -
    EX600E - UltrаНD, 60/50Hz, HDR, Quаtrо тyнep(DVВ-Т2/С/Ѕ2/ІР), Backlight Motion Rate IFC 1300, Цвят-черен, Дистанционно N2QAYB001111
    EX600S - Silver (сребрист цвят на корпуса)
    Крачетата от стойката може да се местят.
    https://www.homecinesolutions.fr/a/i...vsveOt8xbA.jpg
    https://www.homecinesolutions.fr/a/i...XaPX48dI9g.jpg
    FullHD
    49ES600 - FullHD, 120/100Hz ??
    40ES600 - FullHD,
    32ES600 - FullHD,
    Edge Led
    Вероятно тази серия ще се продава само в определени страни.
    49ES500 - FullHD, 60/50Hz,
    43ES500 - FullHD, 60/50Hz,
    40ES500 - FullHD, 60/50Hz,
    32ES500 - HDReady, 60/50Hz,
    24ЕЅ500 - HDReady, 60/50Hz,
    Edge Led
    ES513 - DVB-T/T2/C/S2
    ES503 - DVB-T/T2/C
    ES500 - DVB-T/T2/C
    Предлага се с два цвята на рамката:
    Чepeн: 24 ", 32", 40 ", 43", 49 "
    Cpeбpиcт: 32", 43 ", 49" - завършват на буква S
    49ES400 - Full HD, 60/50Hz
    40ES400 - Full HD, 60/50Hz
    32ES400 - HD-Ready, 60/50Hz
    Panasonic OS
    Firefox OS, вече е My Home Screen 2.0 и според слухове ще бъде преименуван...
    Лично за мен, това е втората най-добра OS за телевизори след webOS- като дизайн, работа....
    Panasonic, ползваха последните години Firefox OS, като смарт TV платформа в своите по-скъпи модели. Миналата година обаче, Mozila спряха поддръжката на операционната система Firefox(наречена My Home Screen 2.0) с отворен код и отказаха да продължат развитието на този софтуер. Panasonic продължава обаче да използва системата и твърди, че са поели развитието и.
    За потребителя, това няма значение; тя изглежда и работи по същия начин. Трябва да се отбележи, че интерфейсът е все още задочно 1080p. Можете да го очакваме че през 2017 година ще премине в 2160p.
    Кратка демонстрация показа обаче, че "новата" система всъщност е останала същата като миналата година, най-важното допълнение е появата на папки, съдържащи няколко връзки или приложения с пин на началния екран.
    Има абсолютно същия вид [Firefox OS] дава същите чувства и това, което са направили, е да добавят някои (малки) подобрения. Панасоник не са закупили софтуера, защото Firefox е бил свободен. Започнали са с Firefox и са добавили някои функции.
    На началния екран все още сме свидетели на големи "икони".
    Там са показани до пет наведнъж, които трябва да превъртате хоризонтално.
    Ако сложите много приложения на началния си екран, това може да бъде объркващо и затова сега има възможност за създаване на папки. Това работи добре, макар че не е възможно да се променят имената на папките; всички са наречени "Моята папка".
    https://www.youtube.com/watch?v=of6n9hBOKBY
    От лявата страна началния екран в Smart TV 2015 г., с Firefox OS. Вдясно на Smart TV от 2017 с "Panasonic OS".
    Вляво менюто с приложения на Firefox OS. Вдясно от "Panasonic OS".
    https://firefoxosdevices.org/en/#typ...ng-devices:yes
    https://developer.mozilla.org/en-US/...efox_OS_for_TV
    https://developer.mozilla.org/ja/doc...efox_OS_for_TV
    My Home Screen 2.0 стартира само с натискането на един бутон на дистанционното управление. По същия начин, потребителския интерфейс вече предлага възможността за създаване и преименуване на потребителски дискретни папки, които могат да бъдат приложения "редове" или дори източници (HDMI 3 ...).
    Бутонът на дистанционното My App, може да бъде персонализиран за бърз достъп до любимо съдържание.
    Software
    Unipf technical information.
    Firmware
    TV | Digital AV | Support | Panasonic Global
    SoC
    Panasonic имат 3 завода за чипове в Япония. Преди няколко години продадоха дял на израелската TowerJazz. Последните 5 години нерядко използват процесори на китайската MediaTek
    Imaging―Display | Application | Socionext Inc.
    http://www.socionext.com/en/products...msoc/spec.html
    Гласов асистент и Гласови напътствия
    Телевизорът прочита с глас изписаното на екрана по време на настройка или информация за програмата.
    Remote Control
    Разлики в дистанционните по модели
    EZW1004, EZ1000, EZW954, EZ950,
    EXX789, EXW787, EXW784 EX780, EXW735, EXW734, EX730, EX703, EX700 EX633, EX620, EX613, EX610, EXW604, EX603, EX600
    N2QAYB001115 N2QAYB001111
    Няма второ Няма второ Няма второ
    Серии EZW1000/950 са снабдени с две дистанционни управления. Първото е голям, по-луксозен метален вариант на класическо Panasonic дистанционното. Бутоните са по-малки, но подреждането е класическо, отлично оформление. Чрез докосване е малко по-трудно да си намерят бутоните, но за сметка на това дистанционното има функция за подметка на бутоните (бутонът за осветление се намира горе в дясно). Това дистанционно е допълнено с бутона "My App". По този начин можете да стартирате приложение, което сте избрали за този бутон.
    По-малкото дистанционно управление е тъчпад дистанционно. Разполага с минимален брой клавиши за избор и голям тъчпад. Бързо стигате до някои функции - прекарвате пръст и после правите до едно-две кликвания. Значително подобрение в това отношение няма. Но клавишите със стрелки, които първоначално изглеждат ненужни, са алтернатива.
    Panasonic поддържа гласови команди, като например да регулирате силата на звука, стартиране на приложения или при търсенията. тази функция обаче изисква да използвате тъчпад дистанционното или да инсталирате приложението Panasonic TV Remote 2 на вашия смартфон или Ipad.
    В серията EX780 се използва стандартно инфрачервено дистанционно управление, което все още не е претърпяло някаква значителна промяна, а това според мен трябваше да стане още миналата година. Дизайнът му леко се различава от стандартите на XXI век. Предният му панел е изработен от пластмаса, имитираща полиран метал като рамката на телевизора, докато панела на гърба е направен от черна пластмаса(отново като телевизора отзад). Бутонното оформление не се е променило, с изключение на една подробност - в долния ляв ъгъл е добавен бутон "моят ап", с който можете да стартирате избрано то вас приложение. Това е много добро решение, което позволява на потребителя да спести време, ако често използвате някои услуги (напр. плеър).
    Дистанционното е дълго 21cm дълго и заедно с две батерии АА тежи около 145 грама. Батериите са поставени зад друга, при което центърът на тежестта се намира в центъра. Това дистанционно приляга удобно в ръката ви. Двете вдлъбнатини на гърба, дават допълнително сцепление. Освен това, е направен каналза показалеца на гърба, което кара палеца естествено да застава над G-бутона. Гумираните бутони имат ясно осезаем "щрак" и отчетлив печат.
    Enjoy your VIERA with TV Remote 2 | TV | Digital AV | Consumer Products | Support | Panasonic Global
    Bluetooth
    Само за работа с съвместими с HID (Human Interface Device Profile) клавиатури.
    Audio
    Стойка
    EZ1000
    Аудио секцията на Panasonic TX-EZ1000 е поверена на Technics, фирма специализирана в аудиото - собственост на Panasonic. Те са разработили стабилен саунд бар, който също така служи като стойка.
    Вградена аудио система от 14 високоговорителя с мощност от 80 вата(8 ниско-честотни, 4 средно-честотни, 2 високочестотни и пасивен излъчвател за усилване на басите), срещу 12 говорителя и 40 вата мощност при миналогодишният DX800 и още четири пасивни радиатори, които трябва да му даде възможност да осигури звук дори по-добър от DX800. Системата Dynamic Blade Speaker, е настроена и оптимизирана от инженерите на Technics.
    EX780 се отличава с особенна кръстовидна основа. Забележителното е, че може да се регулира на три различни височини, и също така е възможно да се върти екрана. Последната функция, до преди няколко години беше често срещана, а последните две години изчезна.
    Ѕwіtсh Dеѕіgn (Mнoгoфyнĸциoнaлeн дизaйн). Bcичĸи ĸaбeли мoжe дa ce cĸpивaт в цeнтpaлнaтa чacт нa cтoйĸaтa.
    Серия Тип стойка Възможности за монтаж на крачетата
    EZ1000 Саундбар служещ като стойка Фиксиран, но може да се махне при монтаж на стена.
    EZ950 Фиксирана стойка с две крачета Може да се махне при монтаж на стена.
    DX900 Две фиксирани крачета. Може да се махат при монтаж на стена..
    EX780 75" - фиксирана
    65" - само завъртане
    50", 58" - 3 степени нагоре/надолу + завъртане
    EX730 Две крачета. Крачетата от стойката може да се местят в близост до центъра или по краищата, освен това може да избирате начина на монтаж - с правата или извитата част напред.
    EX700 Две крачета. Крачетата от стойката може да се местят в близост до центъра или по краищата, освен това може да избирате начина на монтаж - с правата или извитата част напред.
    EX600 Две крачета Крачетата от стойката може да се местят в близост до центъра или по краищата.
    ES600 Фиксирана. Може да се премахне.
    ES500 Две фиксирани крачета. -
    ES400 Две фиксирани крачета. -
    Тунери
    Двойни тунери имат само серии - DX900, DX800, DX780, DX750, DX730. С тях можете да гледате и записвате две програми едновременно, да гледате програма докато записвате друга и т.н..
    DVB по IP
    Моделите поддържащи DVB via IP могат да служат като сървър, за да осигурят предаване към друг телевизор, поддържащ функцията DVB via IP клиент или SAT IP съвместими устройства.
    https://www.panasonic.com/de/consume...it-sat-ip.html
    Resources | SAT IP
    DVB viewer - your software for TV and Radio - Home
    https://www.youtube.com/watch?v=y3iY_0qKjiE
    EZ1000 - (Server/Client)
    EZ950 - (Server/Client)
    EX780 - (Server/Client)
    EX730 - (Server/Client)
    EX703 - (Client)
    EX700 - (Client)
    EX603 - (Client)
    ES513 - (Client)
    ES500 - (Client)
    3D
    От модели 2017, единствено EX780 има 3D функция. Очилата не влизат в комплекта.
    https://ic.tweakimg.net/ext/i/2001510167.jpeg
    https://ic.tweakimg.net/ext/i/2001510169.jpeg
    Изискваните активни очила се синхронизират чрез Bluetooth и струват около 40 евро. Те трябва да бъдат свързани при първото стартиране на телевизора. Можете да направите това, като ги държите близо до телевизора и задържите бутона натиснат. Внимавайте особенно когато гледате в осветено помещение, в което е налице ярка околна светлина- можете да видите дразнещо примигване в очилата, но проблема ще изчезне ако затъмните стаята.
    В таблицата са дадени поддържаните от серия EX780 модели 3D очила
    Country/ Area LCD TV Model Number
    Europe
    (except UK / Ireland)
    EX780, EXW784, EXT786, EXF787, EXN788, EXX789 TY-ER3D4ME
    TY-ER3D4SE
    TY-ER3D5ME
    TY-ER3D6ME
    http://av.jpn.support.panasonic.com/...yewear/eu.html
    Kaĸ ce разчита модела на 3D очила Panasonic ?
    Пример - ТY-ЕR3D4МE
    TY - телевизионен аксесоар
    Е - Eyewear - очила
    R - тип връзка с телевизора
    • R - RF (wirеless) Вluеtooth система
    • W - (wi-fi) безжични
    • P - поляризирани (за пасивно 3D)
    3D - 3D
    4 - година на модела
    • 6 - 2016 година
    • 5 - 2015 година
    • 4 - 2012 година
    • 3 - 2011 година
    • 2 - 2010 година
    M - Размер на очилата
    • L - Lаrgе
    • М - Меdіum
    • Ѕ - Ѕmаll
    E - Регион
    • E - Европа
    • U - Северна Америка
    • P - пакет от 2 броя
    THX
    Само телевизори преминали успешно над 400 THX лабораторни тестове в 30 тестови категории, получават сертификация на екрана THX 4K Display.
    Panasonic Oled TV и серия EX780 имат UHD Premium и THX-сертификати. По този начин, Panasonic се придържа към лицензирането на THX при топ моделите.
    Компанията предлага и приложение за настройки.
    https://itunes.apple.com/gb/app/thx-tune-up/id592624594
    https://play.google.com/store/apps/d...hx.tuneup.free
    HDR
    Panasonic заяви, че всички нейни 2017 UltraHD LCD телевизори ще получат поддръжка за двата формата HDR10 и HLG (чрез актуализация на фърмуера). За сега, компанията е избрала да не обръща внимание на по-премиалният формат Dolby Vision - тоест да изчака развитието в сектора. От модели телевизори 2016 знаем, че много от средният клас LCD телевизори на хартия поддържат HDR, но всъщност не са способни да го направят. Също така, оказва се, че нито един от LCD 2017 телевизорите не е "UHD Premium" сертифициран.
    LCD моделите предлагат максимална яркост, варираща между 350 и 550 CD/m², което означава, че тези телевизори, не отговарят на изискванията за UltraHD Premium сертифициране - 1000 cd/m2, необходими за LCD телевизори. OLED моделите постигат нива на яркост от 950 cd/m² за 55-инчовите модели и дори 1000 cd/m² за 65-инчовият модел, което е впечатляващо за Oled.
    Всички Ultra HD модели имат вградени клиенти за Youtube и Netflix с възможност да възпроизвеждат директно HDR материал от тези стрийминг услуги.
    65EZ1000 може да произведе максимална яркост от 1000cd/m2
    55EZ1000 може да произведе максимална яркост от 950cd/m2
    EX780 може да произведе максимална яркост от 550 cd/m².(Edge Led - Local Dimming + >90% DCI/P3)
    EX730 може да произведе максимална яркост от 350 cd/m².(Edge Led - Local Dimming + >90% DCI/P3)
    EX700 може да произведе максимална яркост от 350 cd/m².(Edge Led - Local Dimming + >90% DCI/P3)
    EX600 може да произведе максимална яркост от 350 cd/m².(Direct Led - Global Dimming)
    За настоящите стандарти това не е нещо особено, и затова ефекта на HDR е много ограничен.
    Възможности за калибрация
    Високият клас дисплеи на Panasonic винаги са перфектно адаптирани към калибриране на картината.
    В случаят със серии EZ1000, EZ950, EX780, производителят обаче е отишъл още една крачка напред и предоставил достъп до вътрешните 3D LUT таблици в телевизора. Това означава, че можете да програмирате цветовото пространство, което ще ви даде неконвенционално възпроизвеждане на цветовете. Достъпът до 3D LUT масивите обаче е желателен, ако дисплеят ще се използва за филмов монитор или като монитор в студио за пост-продукция. Най-полезни са реализациите на различни цветови пространства. Директно от камерата Rec 709, или Rec.2020. Сега, това ще бъде възможно да се приложи в потребителски дисплей, което вероятно ще го направи добър, колкото професионален дисплей!
    source photo: www.phileweb.com/
    3D LUT (справочни таблици), подобни на тези, използвани от професионалните кино и телевизионни монитори на Panasonic. LUT - това е процес на цифрова обработка при който се създава нужното изображение използвайки карти (банки) експозиции и DK (Digital Knee).
    Освен това, професионалните потребители могат дори да качват свои собствени 3D LUTs от SD карта / USB стик.
    - възможност да заредите потребителска 3D LUT в .cube формат
    - възможност да заредите потребителска 1D LUT
    - YCbCr пълно покритие на обхвата
    - фин контрол на нарастването (стъпка от 0,5) [gain controls]
    - ISF калибрационен контрол
    3D LUT Creator - официальный сайт
    ето как да направите това(пример от форума на италианските ни колеги)
    3D LUT
    Argyll Color Management System Home Page
    Panasonic има традиция от 2013 година в поддръжката на софтуера за калибриране CalMAN (които се използва в ревютата от калибратори).
    Portrait Displays | Software for Displays – Customized for OEM Brands SpectraCal - Display Color Calibration
    ISF Certified Calibration Configuration (3C) | ISF Forum
    За да се случи автоматично калибриране, трябва да има пряк интерфейс между телевизионния екран и лаптопа, известен като Direct Control Display (DDC), която връзка обикновено се провежда през IP или безжично. След като се установи DDC, настройките на картината могат да бъдат направени от лаптопа, без да се налага да отваряте менюто за картината на екрана. Това е изключително полезно, особено за HDR калибриране, тъй като измерванията на по-ярки нива на яркост, няма да се разреждат с наличието менюта или плъзгачи на екрана, което допринася за по-точен резултат. CalMAN не само ще прави автоматично регулиране на цветовите настройки на новите телевизори, но ще добави измервания на цветовият обем към инструментариума.
    Панели
    EX600 се предлага в 40, 43, 49, 55 и 65 инча. Прави впечатление, че Panasonic в тази серия слага различен тип матрици: 40 и 65 инчови модели разполагат с панел VA, а 43, 49 и 55-инчови варианти имат панел IPS.
    55EX600E: IPS panel, 50/60Hz
    ES513(49,40,32") - IPS panel, 50/60Hz
    Media Player
    Вграденият мултимедиен плейър е за снимки, музика и видеоклипове от свързано USB устройство или от мрежата. Повечето телевизори поддържат само DLNA да възпроизвеждане на файлове чрез мрежата, но Panasonic също поддържа и за SMB , така че можете да възпроизвеждате файлове от компютъра си без да се налага да инсталирате DLNA сървър. Много удобно, но за съжаление Panasonic телевизори не поддържат DTS аудио. За DTS лиценз трябва да се плати. В резултат на това много филми се възпроизвеждат без звук, който значително ограничава полезността на мултимедийния плейър.
    За съжаление се натъкнахме на други проблеми при възпроизвеждане на HDR тестов материал. Когато пуснете да възпроизвежда HEVC 4k-филм с малко по-висок битрейт от 100 Mbit/сек, мултимедийния плеър започва да накъсва и забива. Повечето други тазгодишни UHD телевизори възпроизвеждат този тест материал безпроблемно. Също така 4K филми с AVC и около 100 Mbit/сек не вървят гладко. Всички материали с висока разделителна способност вървят добре. Субтитрите се извеждат чисто, като може да се настройва размера и позицията им на екрана.
    Specifications
    Multimedia
    Series
    EX600/620/630
    Series
    EX700/720/730
    Series
    EX750/780
    EZ900/1000
    video
    audio
    Images / Photos
    Subtitles
    Control4 Driver Search
    Тестове
    https://www.avforums.com/review/pana...v-review.13312
    Panasonic TX-65EZ1000 : Test complet - Téléviseur - Les Numériques
    https://tweakers.net/reviews/5409/pa...rote-voet.html
    https://www.homecinemamagazine.nl/20...84-tx-65ex780/
    https://hdtvpolska.com/panasonic-ex7...ltra-hd-z-hdr/
    Panasonic EX700 review - FlatpanelsHD
    Panasonic TX-55EX610E – test telewizora 4K na 2017 rok | rtvManiaK.pl
    Test Panasonic EX600 (TX-55EX600E) : une TV UHD 4K HDR au bon rapport qualité/prix ?
    Този пост е редактиран от hristoslav2; 28-05-17 в 16:57.
    svetlio1 одобрява това.
    #112
    Series & Model
    ________________
    UHD Premium
    _____
    ISF ccc
    ________
    ISFccc -
    Certified
    Calibration
    Configuration
    THX
    ________
    Accurate Color
    Reproduction
    Sharper Pictures
    Automation System
    IP Home Control
    __________
    HDR 10
    ST2084
    (EOTF PQ),
    ST2086
    (static metadata)
    ST2094
    (dynamic metadata)
    ________
    Hybrid
    Log Gamma
    (HLG)
    _____
    Dolby Vision
    VS10
    ____
    _______
    SoC / GPU / RAM
    Plattform,
    System on Chip,
    Instruction set,
    RAM,
    Total memory
    Software
    ____________
    Operating System,
    Firmware version,
    Videopanel
    Size class,
    Resolution,
    Pixel structure,
    Bits of color,
    Quantum dots,
    Curvature,
    Screen Uniformity,
    Backlight Unit
    ______________
    Type backlight,
    Local Dimming zone,
    Type LED,
    Backlight Scanning,
    Frame Interpolation
    ________________
    ISF ccc,
    3D LUT,
    White balance,
    Gamma,
    Internal Processing
    Scaling,
    Overscaninng,
    Upscaling,
    Colorimetry
    White balance dE,
    Color Delta E,
    Gamma,
    Color Temperature,
    Colors
    Brightness
    Peak in HDR
    Peak in SDR,
    Contrast
    ______________
    ANSI Contrast,
    With local dimming,
    Static contrast,
    Dinamic contrast,
    White level,
    Black level
    Viewing angle
    _____________
    (°cone)
    Motion resolution
    ______________
    Horizontal Lines
    Vertical Lines
    Input Lag
    ______________
    in HDR
    in True Cinema
    in Game mode
    by default
    Audio
    Total power,
    speakers,
    Surround,
    Sound mode,
    Image file formats
    Video file formats
    Subtitles
    Connectivity
    __________________
    Chroma subsampling
    4:4:4
    4:2:2
    4:2:0
    Conectors
    Tuners
    Tuners,
    Teletext reception,
    Multi window,
    Timeshift,
    PVR,
    Note
    Pros & Cons
    __________________
    EZ1000 (Oled)
    successor CZ950
    TX-77EZ1000E
    TX-65EZ1000E
    EZW1004
    EZC1004
    (for Switzerland)
    EZR1000
    (for Russia)
    EZ1002B
    THX Cinema
    THX Bright room
    THX 4K Cinema
    No No Plattform:
    Instruction set:
    Operating at up to:
    CPU bit: 64-bit
    CPU Cores: Quad (4)
    GPU: Mali T-860 MP2
    Open GL:
    RAM:
    Total memory:
    Available memory:
    E
    HTML5 v.2.0 SDK
    No vignetting;
    PWM - No
    No backlight,
    No -,
    No -,
    No -,
    No -
    MEMC (IFC)
    BMR -
    Anti-Blur:
    Anti-Judder:
    ISF Professional (expert mode - Day & Night)
    CMS - RGBCYM
    Gamma
    Rec.2020
    Rec.709
    THX Cinema and THX Bright Room are the ideal choice for those who want absolutely no enhancement.
    The True Cinema is almost identical to the THX Cinema preset. She uses a gamma of 2.4 and is therefore slightly darker, and better suited for a dark room.
    The illuminance at 30 you have quite some obscure, choose 60 for a better experience with ambient light.
    The light sensor can possibly activate, turn the backlight certainly 70.
    Noise Reduction and MPEG remaster activate your best if you start from a bad source (old DVDs or low quality YouTube).
    Intelligent Frame Creation: Out for purists, but the middle class gave some additional detail and smooth images without obvious artifacts.
    We still recommend that certain activated to the minimum.
    Power, Contrast Control you can put car for a slight boost in contrast.
    Search in Picture, Picture settings, 16: 9 image scanning and turn this 'off'.
    Thus you avoid the device still hides a part of the image edge.
    For a slightly more processed image, but still very faithfully, select the Cinema setting.
    Turn it 'Heat Color' on Warm2, and take into account the above recommendations.
    Very Good for HD,
    77" -
    77" - dE
    77" - Gamma 2.2
    77" -
    65" -
    65" - Gamma 2.2
    65" - 6840K
    Colors - 1073741824
    APL -
    77" -
    77" - x
    77" - Inf.:1
    77" -
    77" -
    77" -
    77" - 0cd/m2
    65" -
    65" - x
    65" - Inf.:1
    65" -
    65" -
    65" - cd/m2
    65" - 0cd/m2
    77" -
    77" -
    65" - 65° (h)
    65" - ° (v)
    Color shift - 26°
    Brightness - 69°
    Black Level - 75°
    77" - ? (h)
    77" - ? (v)
    65" - ? (h)
    65" - ? (v)
    77" - in HDR
    77" -
    77" - in Game mode
    77" - by default
    65"- HDR - ms
    65" - 107ms
    65"- by default
    Dolby Digital Plus
    Dolby Puls,
    No - DTS
    Image file formats
    Apple Lossless
    Video file formats
    AVCHD/Progressive,
    H.263
    MPEG-4
    FLV
    VRO (DVD-VR, .VRO)
    PS
    VP9, profile ?
    Subtitles
    Wi-Fi,
    802.11 a,
    802.11 b,
    802.11 g,
    802.11 n,
    802.11 n 5GHz,
    802.11 ac,
    Wi-Fi Direct,
    Miracast,
    3840x2160 - 120- No
    3840x2160 - 50p
    3840x2160 - 30p
    1920 x 1080 / 60i
    1920 x 1080 / 50i
    1 x Ethernet RJ45
    2 x CI + (ver. 1.3)
    2x DVB-C (VHF/UHF)
    2T
    Timeshift & PVR
    (USB-HDD Recording)
    MPEG2,
    MPEG4,
    VP9 ProFile.2
    EZ1000 (Oled)
    TX-77EZ1000E
    TX-65EZ1000E
    EZW1004
    (for Germany)
    EZC1004
    (for Switzerland)
    EZC1004
    (for Switzerland)
    EZ1002B
    EZ950(Oled)
    TX-77EZ950E
    TX-65EZX50E
    EZW954
    EZC954
    (for Switzerland)
    EZR950
    (for Russia)
    EZ952B
    THX Cinema
    THX Bright room
    THX 4K Cinema
    No No Plattform:
    Instruction set:
    Operating at up to:
    CPU: 64-bit
    GPU:
    Open GL
    RAM:
    Total memory:
    Available memory:
    E
    HTML5 v.2.0 SDK
    No vignetting;
    Anti-reflective filter
    PWM - No
    BFI - No
    No backlight
    MEMC (IFC)
    BMR -
    Anti-Blur:
    Anti-Judder:
    ISF Professional
    - 8000 points
    CMS - RGBCYM
    No
    Gamma
    Rec.2020
    Rec.709
    Very Good for HD,
    77" -
    77" -
    77" -
    77" -
    77" -
    65" -
    65" -
    65" - 2.2
    65" -
    77" - max
    77" - max
    APL -
    77" -
    77" -
    77" - Inf.:1
    77" -
    77" - ? cd/m2
    77" - 0cd/m2
    65" -
    65" - x
    65" - Inf.:1
    65" -
    65" -
    65" - cd/m2
    65" - 0cd/m2
    77" - (h)
    77" - (v)
    65" - 65° (h)
    65" - ° (v)
    Color shift - 26°
    Brightness - 69°
    Black Level - 75°
    77" - (h)
    77" - (v)
    65" - (h)
    65" - (v)
    77" - in HDR mode
    77" - in Game mode
    77" - by default
    65"- in HDR - ms
    65"- in Game mode -
    65"- by default
    80W (RMS)
    Dolby Digital Plus
    Dolby Puls,
    No - DTS
    Image file formats
    Apple Lossless
    Video file formats
    AVCHD/Progressive,
    H.263
    MPEG-4
    FLV
    VRO (DVD-VR, .VRO)
    PS
    VP9, profile ?
    Subtitles
    Wi-Fi,
    802.11 a,
    802.11 b,
    802.11 g,
    802.11 n,
    802.11 n 5GHz,
    802.11 ac,
    Wi-Fi Direct,
    Miracast,
    3840x2160 - 120- No
    3840x2160 - 50p
    3840x2160 - 30p
    1920 x 1080 / 60i
    1920 x 1080 / 50i
    1 x Ethernet RJ45
    2 x CI + (ver. 1.3)
    2x DVB-C (VHF/UHF)
    2T
    Timeshift & PVR
    (USB-HDD Recording)
    MPEG2,
    MPEG4,
    VP9 ProFile.2
    EZ950 (Oled)
    TX-77EZ950E
    TX-65EZX50E
    EZW954
    (for Germany)
    EZC954
    (for Switzerland)
    EZ952B
    ________________
    UHD Premium
    _____
    ISF ccc
    ________
    ISFccc -
    Certified
    Calibration
    Configuration
    THX
    ________
    Accurate Color
    Reproduction
    Sharper Pictures
    THX Cinema & THX 4K Cinema modes
    Automation System
    IP Home Control
    __________
    HDR 10
    ST2084
    (EOTF PQ),
    ST2086
    (static metadata)
    ST2094
    (dynamic metadata)
    ________
    Hybrid
    Log Gamma
    (HLG)
    _____
    Dolby Vision
    VS10
    ____
    Advanced HDR Technicolor
    _______
    SoC / GPU / RAM
    _____________________________
    Plattform,
    Central Processing Unit,
    System on Chip,
    Instruction set,
    Graphic Processor Unit,
    RAM,
    Total memory
    Software
    ____________
    Operating System,
    Firmware version,
    Apps program languages,
    Videopanel
    Size class,
    Type LCD/Oled matrix,
    Resolution,
    Pixel structure,
    Bits of color,
    Quantum dots,
    Frequency of T-Con board,
    Curvature,
    Screen Uniformity,
    Backlight Unit
    ______________
    Type backlight,
    Local Dimming zone,
    Type LED,
    MEMC,
    Backlight Scanning,
    Black Frame Insertion,
    Pulsе Wide Modulation
    Frame Interpolation
    ________________
    Technology for generating and inserting intermediate frames to achieve a smooth picture in dynamic scenes.
    Measurement Unit (Index)
    Opportunities for calibration
    ISF ccc,
    3D LUT,
    -Color Menagment System,
    Technicolor Expert Mode,
    White balance,
    Gamma,
    Internal Processing
    IScalling,
    nterpolation,
    Overscaninng,
    Digital Noise reduction,
    Deinterlacing (Video mode, Film mode),
    Colorimetry
    DCI P3 coverage (xy / uv),
    Rec.2020 coverage (xy / uv),
    White balance dE,
    Color Delta E,
    Gamma,
    Color Temperature,
    Brightness
    Peak in HDR
    Peak in SDR,
    Average Picture Level,
    Automatic Brightness Limiter,
    Contrast
    ______________
    ANSI Contrast,
    With local dimming,
    Without local dimming,
    Static contrast,
    Dinamic contrast,
    White level,
    Black level
    Viewing angle
    _____________
    Horizontal & Vertical
    (°cone)
    Motion resolution
    ______________
    Input Lag
    ________________
    in HDR
    in Game mode
    by default
    Audio
    Total power,
    speakers,
    Surround,
    Sound mode,
    Built in Media Player
    Supported file systems
    Image file formats
    Audio file formats/codecs
    Video file formats
    Subtitles
    _______________________________________________
    Connectivity
    __________________
    Supported Resolutions
    Resolution / Frame per seconds
    24, 25, 30, 50, 60, 100, 120fps
    Progresive / Interleased
    Chroma subsampling
    4:4:4
    4:2:2
    4:2:0
    Conectors
    Tuners
    Tuners,
    Teletext reception,
    Multi window,
    Timeshift,
    PVR,
    Note
    __________________
    EX780 (LCD)
    TX-75EX780E
    TX-65EX780E
    TX-58EX780E
    TZ-50EX780E
    (Continental Europe)
    EXX789
    EXN788
    EXF787
    EXT786
    EXW784
    75EXR780
    (For Russia)
    EX752B
    (for United Kingdom)
    No No Plattform:
    SoC: MediaTek MT5
    Instruction set:
    Operating at up to:
    GPU:
    Open GL
    RAM:
    Total memory:
    Available memory:
    Internal storage total space:
    Internal storage free space:
    E
    OS: Firefox 2.5
    HTML5 v.2.0 SDK
    Edge Led (Down), Local Dimming
    PFS LED - Potassium fluorosilicate (PFS)-based phosphors for LED-based backlighting in displays.
    W-Led,
    Yes,
    No
    Yes,
    MEMC (IFC)
    BMR - 2400
    (Backlight Motion Rate)
    Motion Processing Settings
    Anti-Blur:
    Anti-Juddering:
    Led Motion:
    ISF Professional
    Compatibility with Portrait Display's CalMAN calibration software.
    Direct Display Control mode to allow to adjust settings directly from the Calman software (professional edition) by connecting screen to a PC via Ethernet.
    3D LUT(look-up tables)- 8000 points
    Finner gain controls (0.5increments).
    CMS - RGBCYM
    No
    White balance - 2/20 points
    Gamma
    Gray scale of 10 points
    Rec.2020
    Rec.709
    Very Good for HD,
    75" - DCI/P3-
    75" - BT.2020 -
    75" -
    75" -
    75" -
    65" -
    65" -
    65" -
    65" -
    65" -
    58" -
    58" -
    58" -
    58" -
    58" -
    Corors -
    75" -
    75" -
    65" -
    65" -
    58" -
    58" -
    50" - max
    50" -
    50" -
    75" - 4100:1
    75" -
    75" -
    75" -
    75" -
    75" -
    75" -
    65" -
    65" -
    65" -
    65" -
    65" -
    58" -
    58" -
    58" -
    58" -
    58" -
    50" -
    50" -
    50" -
    50" -
    50" -
    75" - (h)
    75" - (v)
    65" - (h)
    65" - (v)
    58" - (h)
    58" - (v)
    50" - (h)
    50" - (v)
    75" - (h)
    75" - (v)
    65" - (h)
    65" - (v)
    58" - (h)
    58" - (v)
    50" - (h)
    50" - (v)
    77" - 22ms
    77" - 22ms
    77" -
    65" - 22ms
    65" -
    65" -
    58" -
    58" -
    58" -
    50" -
    50" -
    50" -
    Image file formats
    JPEG 4K, GIF, PNG, MPO, JPG,
    AAC (Advanced Audio Coding)
    FLAC (Free Lossless Audio Codec, .flac)
    MP3 (MPEG-2 Audio Layer II, .mp3)
    WMA Pro (Windows Media Audio, .wma)
    WAV (Waveform Audio File Format, .wav, .wave)
    Apple Lossless
    Video file formats
    AVCHD/Progressive,
    3GPP (3rd Generation Pertnership Project, .3gp)
    AVI (Audio Video Interleaved, .avi)
    DivX (.avi, divx,, .mkv)
    H.263
    H.264 / MPEG-4 Part 10 / AVC Video
    H.265 / MPEG-H Part 2 / HEVC
    MKV (Matroska Multimedia Container, .mkv, .mk3d, .mka, .mks)
    Quik Time (.mov,. qt)
    WMV (Windows Media Video, .wmv)
    MP4 (MPEG-4 Part 14, .mp4, .m4a,. m4p, .m4b, .m4r, .m4v)
    MPEG-4
    TS (MPEG Transport Stream, .ts, .tsv, .tsa)
    FLV
    VRO (DVD-VR, .VRO)
    VOB (Video Object, .vob)
    PS
    VP9, profile ?
    To playback HDR, a HDR source is required (H.264 or H.265(ST2084 or HLG format)
    Subtitles
    Micro DVD, SRT, SUB, SubRip, TMPlayer, TXT
    Obviously not playing DTS-HD tracks or TrueHD or ISO or Blu-ray folders (BDMV) and like all televisions, 24p videos are played in 60 im / s, but converting the framerate is well managed, with smooth playback without jerkiness and a picture of beauty. The reading is also interesting audio files with management Flac, WAV and ALAC, the ability to display album art or tags, but no native playback of files called "HiRes" all files in 88.2, 96, 176.4 or 192 kHz are downmixes in 48 kHz / 24 bits.
    Lan (100BASE-TX/10BASE-T)
    Wi-Fi,
    802.11 a,
    802.11 b,
    802.11 g,
    802.11 n,
    802.11 n 5GHz,
    802.11 ac,
    Wi-Fi Direct,
    DLNA 3.0,(DTCP-IP/DMP/DMR/DMS)
    Bluetooth(NFC) Ver.4.1 HID/HOGP/3DSP/SPP(for keyboard and mouse, no Bluetooth audio)
    Miracast,
    1 x Ethernet RJ45
    2 x CI + (ver. 1.3)
    2x DVB-C (VHF/UHF)
    2T
    Timeshift & PVR
    (USB-HDD Recording)
    MPEG2,
    MPEG4,
    VP9 ProFile.2
    EX780 (LCD)
    TX-75EX780E
    TX-65EX780E
    TX-58EX780E
    TZ-50EX750E
    EXW784
    EX782B
    EXR700
    (for Russia)
    EX730 (LCD)
    TX-65EX730E
    TX-58EX730E
    TX-50EX730E
    TX-40EX730E
    EXW735
    EXW734
    (for Germany,
    Switzerland,
    Niderland)
    EX732B
    No No Plattform:
    SoC: MediaTek MT5597
    Instruction set:
    Operating at up to:
    GPU:
    Open GL
    RAM:
    Total memory:
    Available memory:
    E
    OS: Firefox 2.5
    HTML5 v.2.0 SDK
    Edge Led (Down), Local Dimming,
    W-Led,
    Yes - IFC,
    MEMC (IFC)
    BMR - 1600
    Very Good for HD,
    APL -
    ABL -
    65" -
    65" -
    65" -
    65" -
    65" -
    65" - cd/m2
    65" - cd/m2
    65" - °(h)/ °(v)
    Color shift - °
    Brightness - °
    Black Level - °
    65"- HDR - ms
    65"- Game mode -
    65"- by default
    Image file formats
    Apple Lossless
    Video file formats
    AVCHD/Progressive,
    H.263
    MPEG-4
    FLV
    VRO (DVD-VR, .VRO)
    PS
    VP9, profile ?
    Subtitles
    2 x USB 2.0 (DC 5V MAX 500mA)
    1 x USB 3.0 (DC 5V MAX 900mA)
    1 x Ethernet RJ45
    4 x HDMI 2.0a - (ARC(input 2), CEC, MHL 3.0)
    with HDCP (High-bandtwidth Digital Content protection) 2.2
    1 x AV Composite in 3.5mm jack
    1 x Video Component In 3.5mm jack
    1 x Optical Audio Out (AAC/PCM/AC3)- 18 dBm, 660 nm
    1 x Hedphone output (16-32Ω recommended)
    1 x SD Memory Card Slot (SDXC memory card compatible)
    1 x Antena (RF) (female)
    2 x CI + (ver. 1.3)
    1 x Satelite In (Sub: F-type female)
    BS·110 degree CS-IF input terminal (75 Ω) and satellite antenna power supply (DC 15 V) output
    Compatible Rec.2020 input
    Analog (NTSC, PAL, SECAM)
    B/G,D/K,I (45,25MHz–863,25MHz)
    2x DVB-T/T2 (H.264) -T2 HD (H.265) (VHF/UHF)
    2x DVB-S/S2 (950-2150MHz) (DiSEqC version 1.0)
    2x DVB-C (VHF/UHF)
    1x TV>IP Server & Client
    2T
    PAP (Picture and picture)
    PIP (Picture in picture)
    PAT (Picture and text)
    Timeshift & PVR
    (USB-HDD Recording)
    MPEG2,
    MPEG4,
    HEVC H.265 (to 3840x2160/60p, 10bit)
    VP9 ProFile.2
    EX730 (LCD)
    TX-65EX730E
    TX-58EX730E
    TX-50EX730E
    TX-40EX730E
    EXW734
    EX732B
    EX700 (LCD)
    TX-65EX700E
    TX-58EX700E
    TX-50EX700E
    TX-40EX700E
    EXW704
    EX700B
    EXR700
    (for Russia)
    No No Plattform:
    Instruction set:
    Operating at up to:
    CPU:
    GPU:
    Open GL
    RAM:
    Total memory:
    Available memory:
    E
    OS: Firefox 2.5
    HTML5 v.2.0 SDK
    Index 1600 BMR IFC
    Edge Led, Local Dimming ?,
    W-Led,
    Very Good for HD,
    65" -
    65" -
    65" -
    65" -
    APL -
    ABL -
    65" -
    65" -
    65" -
    65" -
    65" -
    65" - cd/m2
    65" - cd/m2
    65" - 65°(h)/(v)
    Color shift -
    Brightness -
    Black Level -
    65"- HDR - ms
    65"- Game mode -
    65"- by default
    2 x 10W (RMS)
    VR-Audio True Surround
    Dolby Puls,
    No - DTS
    Standard/Music/Ambience/User
    Image file formats
    Apple Lossless
    Video file formats
    AVCHD/Progressive,
    H.263
    MPEG-4
    FLV
    VRO (DVD-VR, .VRO)
    PS
    VP9, profile ?
    Subtitles
    Wi-Fi,
    802.11 a,
    802.11 b,
    802.11 g,
    802.11 n,
    802.11 n 5GHz,
    802.11 ac,
    Wi-Fi Direct,
    No - Bluetooth
    Miracast,
    HbbTV
    1 x Ethernet RJ45
    1 x CI + (ver. 1.3)
    No Bluetooth
    EX700 - DVB-T/T2/C
    DVB-C (VHF/UHF)
    TV>IP Client
    2T
    Timeshift & PVR
    MPEG2,
    MPEG4,
    VP9 ProFile.2
    EX703 (LCD)
    TX-65EX700E (703)
    TX-58EX700E (703)
    TX-50EX700E (703)
    TX-40EX700E (703)
    EXW704
    EX702B
    EX600 (LCD)
    TX-65EX600E
    TX-55EX600E
    TX-49EX600E
    TX-43EX600E
    TX-40EX600E
    EXW604
    EXW604S
    EX602B
    No No Plattform:
    SoC: MediaTek MT55
    Instruction set:
    Operating at up to:
    CPU:
    GPU:
    Open GL
    RAM:
    Total memory:
    Available memory:
    E
    OS: Firefox 2.5
    HTML5 v.2.0 SDK
    Edge Led
    BMR - 1300
    CMS-RGBCYM
    Very Good for HD,
    65" -
    65" -
    65" -
    65" - <2.0
    65" -
    65" -
    55" -
    55" -
    55" - BT.2020 - 51%
    55" - <2.0
    55" - 6642K
    49" -
    49" -
    49" -
    49" -
    49" -
    49" -
    40" -
    40" -
    40" -
    40" -
    40" -
    40" -
    65" - max
    65" - max
    55" - max
    49" - max
    49" - max
    40" - max
    40" - max
    65" -
    65" -
    65" -
    65" -
    65" -
    65" -
    65" -
    55" - 760:1
    55" -
    55" -
    55" -
    55" -
    55" -
    55" - 0.17cd/m2
    49" -
    49" -
    49" -
    49" -
    49" -
    49" -
    49" -
    40" -
    40" -
    40" -
    40" -
    40" -
    40" -
    40" -
    65" -
    65" -
    65" -
    55" -
    55" -
    49" -
    49" -
    49" -
    40" -
    40" -
    40" -
    2 x 10W (RMS)
    Image file formats
    Apple Lossless
    Video file formats
    AVCHD/Progressive,
    H.263
    MPEG-4
    FLV
    VRO (DVD-VR, .VRO)
    PS
    VP9, profile ?
    Subtitles
    Wi-Fi,
    802.11 a,
    802.11 b,
    802.11 g,
    802.11 n,
    802.11 n 5GHz,
    802.11 ac,
    Wi-Fi Direct,
    No - Bluetooth
    Miracast,
    HbbTV
    1 x Ethernet RJ45
    1 x CI + (ver. 1.3)
    No Bluetooth
    EX600 - DVB-T/T2/C
    DVB-C (VHF/UHF)
    IP>TV Client
    2T
    Timeshift & PVR
    (USB-HDD Recording)
    MPEG2,
    MPEG4,
    VP9 ProFile.2
    EX600 (LCD)
    TX-65EX600E (603)
    TX-55EX600E (603)
    TZ-49EX600E (603)
    TX-40EX600E (603)
    EXW604
    EX602B
    Този пост е редактиран от hristoslav2; 30-05-17 в 22:33.
    #113
    Отговор: Panasonic телевизори 2017
    Често задавани въпроси
    Online Answers - Panasonic Corporation
    От къде да си сваля инструкции?
    По-голямата част от ръководства са на разположение в рамките на раздела за поддръжка на сайта.
    Най-лесният начин за намиране на потребителя е да се търси за номера на вашия модел, например TX-65DX900E.
    При преглеждане на резултатите не забравяйте да кликнете върху точният модел, който имате.
    Свали
    Кога мога да регистрирам удължена гаранция на уреда, който закупих?
    Удължената гаранция е само за определени уреди и трябва да се извърши в определен период от време, след покупката, особено ако е в промоционален период. Не може да бъде извършена извън този период от време. Можете да попитате търговския представител, от където закупувате уред или директно центъра за обслужване на клиенти на Panasonic.
    Въпрос: Как да проверя ТВ при покупка? На какво да обърна внимание?
    1. Проверете за изгорели пиксели с помоща на картинки 1920*1080 в различни цветове.
    https://yadi.sk/d/V27J1ewp3JXPa2
    Огледайте внимателно екрана за пиксели с цвят различен от този на заливката.
    За справка: Panasonic Electronics Pixel Policy и ISO 13406-2.
    2. У дома го проверете за неравномерна подсветка - засветки на черен екран при изгасено осветление и затъмнени прозорци (засветките по ъглите в една или друга степен зависят от конкретният екземпляр ТВ).
    http://uk.rtings.com/tv/learn/tv-warranties-care
    Как да проверим за блокирали пиксели?
    Натискаме -/V на телевизора и без да го пускаме натискаме три пъти определен бутон на ДУ :
    -/V + Option - Появява се заливка на екрана в различни цветове , градиентна заливка, цветни полоси и т.н. - много полезно за търсене на изгорели пиксели. Изход - изключете телевизора с бутона на отстрани на корпуса.
    При гледане на филми с тъмни сцени телевизора автоматично си променя яркостта!
    -Проблема го има на единия от четирите HDMI входа този с ARC.
    Пуснете за тоя HDMI вход режима на картината "Реалистично кино настр." и изключете всички ЕКО истории и динамични контрасти.
    Как да видим заработените часове?
    Количеството заработени часове може да се види в потребителското меню:
    Menu -> Help -> System Information - на ред Status4
    (Menu -> Help -> Version -> Status4.).
    Числото след буквата представлява заработените часове. Като увеличава стойността си с единица, на всеки 60 минути "заработено" време.
    [Статус 4 започва с А до 100 часа, след това B за 100-199 часа, след това C.....]
    Къде мога да намеря фирмуер за моят телевизор?
    Download Information of VIERA | Download | TV | Digital AV | Consumer Products | Support | Panasonic Global
    Как да проверя версията на фърмуера в моя телевизор в потребителското меню?
    Включете телевизора
    Меню -> Настройка -> Системно Меню -> Системна Информация
    Пример
    Софтуерна версия 2515-10300
    Статус1 0071-0502 4000-0006
    Статус2 0038-115 010001
    Статус3 00700-3201 0000-0000
    На първият ред е изписана версията на фърмуера /2515/ която е на телевизора ви.
    Валидна ли е гаранцията на моят телевизор ако се преместя в друга страна?
    Ако се преместите в друга страна в Европа, гаранцията е валидна.
    Ако се преместите извън Европа, за съжаление гаранцията няма да е валидна.
    Как мога да разбера данни и контакти за връзка с Панасоник, когато съм извън страната, от която съм закупил моя продукт?
    Моля изберете вашата локация на следната страница:
    Get support in your country - Support - Panasonic
    След избиране на страната, ще бъдете пренасочени към друг сайт за поддръжка на клиентите, на официалния език на страната, която сте избрали и ще можете лесно да намерите контакти за връзка с нас.
    Мога ли да ползвам моят Panasonic телевизор закупен от България в друга държава?
    Ако ползвате телевизор от България, в друга страна моля имайте в предвид следното:
    Може да се наложи да закупите адаптер за щепсела и трансформатор за правилният волтаж. Телевизора е възможно да не е съвместим със локално излъчваният сигнал.
    Стандартите в България са
    DVB за телевизия
    https://www.dvb.org/news/worldwide
    220V/50Hz - за напрежение
    https://www.110220volts.com/media/wy...world-wide.jpg
    Стандарт за щепсели
    https://www.110220volts.com/media/wy..._the_world.jpg
    Свържете се със операторите преди да предприемете подобно действие.
    За функцията TV Anywhere е е нужно да изтеглите апликацията Panasonic Media Center, съвместима за Android и iOS.
    Как мога да настроя субтитрите на моя телевизор?
    Когато гледате телевизионни програми чрез вградения тунер на телевизора (DVB-T/C/S), можете да пускате/скривате субтитрите(ако са налични на програмата), с бутона [STTL], от дистанционното. Ако са налични субтитри, тогава можете също да променяте настройките, докато гледате сигнала със субтитри, натискайки „Option” бутона на дистанционното управление. Ако сигнала, който се гледа дава възможност за няколко езика, то тогава можете да изберете някой от тези, чрез „Subtitle language option”.
    * Бутона [STTL] не е активен, когато гледате свален от интернет филм със вградени субтитри.
    Има и допълнителни настройки за всичко важно - големина , цвят, кодировка, местоположение и закъснение/избързване.
    При свързване на флашка/HDD излиза надпис за включено външно у-во , натискате HOME->устройства и съответното HDD/флашка , после "видео" (има "снимки" и "музика") и навигирате по папките.
    След пускане на филм, натискате OPTION->настройки видео-> там вече са мулти аудио, за избиране на аудио пътека, двоен моно звук - ляв или десен канал, повторение и настройки на субтитрите.
    Там също са настройки за вкл./изкл. , кодировка (кирилица), размер - 5 степени, цвят - бяло, червено, синьо, жълто и зелено.
    Следва позиция - 5 степени и настройка за закъснение/избързване .
    Защо не мога да видя субтитри, когато гледам филми на моя телевизор чрез DLNA?
    За гледане на филми със субтитри, през DLNA, препоръчваме субтитрите да са вградени. Това означава, че има само един файл (видео), който съдържа в него си и субтитрите.
    Нямам субтитри на програмите излъчващи такива.
    Изключили сте ги. Натиснете бутона STTL - намира се под зеленият бутон за телетекста.
    Мога ли да използвам USB клавиатура или мишка на моя телевизор?
    Ако използвате USB „Plug-and-play” клавиатура или мишка.което не изисква софтуер (или някакви драйвери, за да работи), би трябвало да работи без проблемно с телевизора. Моля свържете се със производителя на устройството(клавиатура/мишка) за потвърждение.
    Може ли браузърът автоматично да обнови страницата?
    Ако страницата има скриптове/плъгини които позволяват това, самата страница ще се обнови автоматично.
    Не мога да видя моите снимки или видео файлове, от моята SD карта. Използвам Windows 10.
    Под Windows 10, някои разширения на файловете (.png , .jpg , .mov), които са широко разпространени и използвани от основни програми, инсталирани на вашия компютър, могат да бъдат скрити. Това може да доведе до проблеми при гледане на записаните/снимани файлове с вашия фотоапарат/видео камера.
    Моля отворете File Explorer (This PC) → Натиснете на „View option”, в горното меню → Проверете полето/отметката точно срещу „File name extensions option” (опции на разширенията на файлове)
    За да видите скрити файлове и папки → Проверете полето/отметката до „Hidden item option”.
    Какъв вид HDMI кабел е добре да използвам, за да свържа моят UltraHD Blu-ray плейър към UltraHD телевизор?
    Когато искате да изкарате UltraHD сигнал, моля използвайте кабел с дължина максимум 5.0 метра. Уверете се, че кабелът е версия 2.0 или по-висока - високоскоростен HDMI-съвместим кабел,който поддържа 18 Gbps трансфер.
    HDMI :: Resources :: FAQ
    Мога ли да използвам HDMI кабел по-дълъг от 10 метра?
    Да, но ще има много смущения, които ще се отразят на качеството на сигнала.
    Има много компании, които работят по HDMI решения, които разширяват ефективния обхват на кабела от типичният 10м обхват, до много по-големи дължини. Тези компании произвеждат различни решения, които включват активни кабели (с вградена активна електроника, която усилва и разширява сигнал по кабела), усилватели, както CAT5/6 кабели и увеличен брой влакна.
    Едно от решенията е технологията HDBaseT, която се прилага от много IT фирми.
    HDBaseT™ – A Standard of the Future, Today
    Кой модел телевизор има връзка DisplayPort 1.2?
    За съжаление само един модел от 2014 година има подобна връзка - AX900.
    Как мога да настроя моят 4K телевизор да види 4К съдържанието от външен източник?
    Моля, помислете за следното, когато настройвате 4K система:
    Най-HDMI преднина трябва да е съвместим 4K
    В зависимост от модела на вашия телевизор, може да се наложи да използвате HDMI вход 2 или 4 - вижте вашия продукт наръчник за по-нататъшни указания.
    В настройките на HDCP изберете "AUTO". Ако източникът не се признава, опитайте 2.2.
    В HDMI Авто настройки използват или Режим 1 или лежим 2.
    Как да си настроя часа.
    Меню -> Таймер -> Часова зона -> GMT+2.
    Забележка! При всяка смяна от лятно на зимно и обратното - трябва да променяте позицията.
    Зимно - GMT+2
    Лятно - GMT+3
    Мога ли да добавям „Любими” (Favourites) към моя начален екран(Home screen) със Firefox OS?
    В началото имате 3 избора за бърз достъп от вашият начален екран: Към Live TV, Apps и Свързани у-ва. Но със Firefox OS можете също, много лесно да добавяте апликации или съдържание, каквото желаете, на вашия начален екран (Home screen).
    Има ли вариант да си сейфна каналите по някакъв начин да ги експортна и после да си ги подредя и върна(за старите модели)?
    Вариант има чрез програмата chansort.На празна USB флашка форматирана на FAT32 се създава нов текстов документ, който се преименува на hotel.pwd.Поставя се в телевизора и се показва едно меню да се въведе четири цифрен код, който е 4850. Така на флашката вече има добавена папка с име hotel_setup.
    На компютър се пуска chansort->File->Open tv data file и се посочва svl.db от папка hotel_setup.Отворения списък се редактира след което се избира save as и презаписва същият този svl.db.
    Поставя се в телевизора и отново се появява менюто за въвеждане на парола този път е 4851.Изчаква се да приключи и се изгася телевизора от бутона на него.След пускането всички канали са в желаната последователност.
    https://sourceforge.net/projects/chansort/
    По време на инсталация на DVB-S уникабел (Unicable system), не мога да въведа моя 4 цифров PIN код.
    Телевизорите на Панасоник в такива случаи имат възможността да приемат само 3 цифри. За това, ако имате възможност, променете или създайте на ново този код, да го направите да е 3 цифрен.
    Телевизорът ми има двойни тунери и два слота за карти - какви са опциите?
    В някои модели (CR850, CX800, AX900, X940,CX750, DX900, DX800, DX780, EZ1000, EZ950, EX780), ще намерите двоен тунер, който предвижда възможността за записване на една програма, докато гледате друга. По този начин Вие може да спрете излъчването на живо(стартирайки запис и превключвайки на друга програма) и да изгледате после записа, или да планирате бъдещи записи, дори когато телевизорът е изключен.
    При поставен само 1 модул и 1 карта:
    - може да гледате един кодиран канал и да записвате втори, който е некодиран
    - може да гледате един некодиран и да записвате втори, който е кодиран
    - може да гледате един кодиран, но не може да записвате втори, който е кодиран
    При поставени 2 модула с 2 карти:
    - може да гледате един кодиран и да записвате втори, който е кодиран
    При поставени два модула и две карти на два различни оператора:
    - може да гледате кодирана програма от пакета на единият оператор и да записвате кодирана програма от пакета на другият оператор
    Как да свържа телевизора си към интернет?
    Молим Ви да следвате следните стъпки:
    1. Натиснете бутона [Menu]
    2. Изберете [Network] „Мрежа”
    3. [Network Connection]
    4. [Quick setup]> С тази функция, телевизора ще опита да засече дали е свързан LAN кабел и ще се опита да осъществи връзка с интернет. Ако не се засече LAN кабел, тогава ще се появи менюто за настройки на безжичен интернет [Wireless]
    5. Изберете желаната мрежа за достъп, към която желаете да се свържете
    6. Въведете кода за сигурност(парола). Молим да се уверите, че потвърждавате паролата с бутона „Back/return”.
    7. Автоматичните настройки са направени и екран с [Network Status] ще се появи.
    Ако сте напреднал потребител и желаете да видите всички детайли за мрежата, молим Ви да направите следните стъпки:
    1. Натиснете [Menu]
    4. [Manual]> изберете даден вид мрежа и следвайте инструкциите.
    Каква е препоръчителното разстояние между безжичен рутер и телевизор?
    Panasonic препоръчва максимум 5 метра разстояние между интернет-рутера и телевизора за добра и стабилна връзка. Силата на връзката и качеството могат да зависят много от локацията и мощността на излъчване на рутера.
    Как мога да потвърдя паролата, която съм написал за Wi-Fi връзката на моя телевизор?
    На по-новите модели, начина за потвърждение е чрез натискане на „BACK/RETURN” бутона, който се намира точно до OK бутона.
    Защо имам звук само от телевизора, вместо от аудио системата, когато съм ги свързал с HDMI ARC?
    Първо, проверете дали HDMI кабела, е свързан във HDMI ARC входа на двете устройства. Ако желаете звука да излиза само през тон-колоните, а не през телевизора, трябва да натиснете [Apps] на дистанционното и да изберете [Viera Link]. След това променете на „Home Cinema”.
    Защо се появява съобщението „Not available” на моя телевизор „Viera” , когато променям избора на говорители на моята Аудио система?
    Молим Ви да се уверите, че вашата звукова система е свързана към телевизора чрез HDMI ARC. Ако сте го направили, то можете да пробвате следните стъпки, за да накарате телевизора да разпознае говорителя.
    1. Когато и двата уреда са включени, премахнете HDMI кабела и от двата уреда.
    2. Изключете телевизора и после аудио системата.
    3. Свържете HDMI кабела
    4. Включете Аудио системата и тогава телевизора (по обратния ред на изключването)
    5. На телевизора, отидете на [Apps] и изберете „Viera Link”.
    Екрана на телевизора ми, започва да става по-тъмен по краищата/ъглите.
    Възможно е това да се случва, ако „Adaptive Backlight control” е активиран. Моля проверете дали вашият телевизор има следните опции и ги премахнете:
    Menu – Picture – Adaptive Backlight Control – OFF
    Как мога да променя името на входовете (Inputs) на моя телевизор?
    Някои телевизори предлагат опцията да се преименува името на входовете (Inputs). Например, бихте могли да промените „HDMI 1” на „ТВ програми” или HDMI2 на „Компютър/ТВ Игра”. Това може да бъде настроено от:
    [Menu]-[Display settings]-[Input labels]
    След редактиране на името, трябва да потвърдите с натискане на „back/return” бутона.
    Какво е „Viera Link”?
    Viera Link (HDAVI Control) е CEC протокол - удобна функция, предлагаща съвместни операции/управление между уреди поддържащи протокола. Можете да използвате функцията, когато свържете съвместими оборудвания чрез HDMI кабел.
    Не мога да видя всички мой входни гнезда след като натисна AV бутона на моя TV, защо?
    Това показва, че другите входове са скрити, следвайте следващите стъпки.:
    1. Натиснете бутона MENU на дистанционното управление;
    2. Изберете SETUP;
    3. Изберете настройките на дисплея;
    4. Изберете INPUT LABELS;
    5. Изберете подходящия етикет и да го превключите напред към друга опция.
    Как мога да използвам miracast/mirroring с моя телевизор?
    Следните инструкции са валидни за 2013, 2014, 2015 серии CS, 2016 серии DS, 2017 серии EX. Моля натиснете [Apps] и изберете апликацията/бутон [Mirroring]. За 2014 серии CX и 2016 серии DX, „Mirroring” опцията може да бъде достъпна чрез натискане на [HOME] бутона на дистанционното, после отивате на [Devices] и избирате [Mirroring].
    Какво е „Intelligent Frame Creation”?
    Понякога може да забележите един проблем, когато гледате спорт или други неща със бързо движещи се обекти, това се нарича "размазване при движение" или "Judder". Това е, когато картината се появява рязко, особено, когато камерата панорамира и може да окаже голямо влияние, при гледане на сцени с бързо движение, като футбол например. За да се предпазите от това и да сте сигурни, че получавате най-гладката и качествена картина, трябва да проверите настройките на вашия телевизор, да видите, ако има "Intelligent Frame Creation" функция (Интелигентно Добавяне на Кадри). При включване на тази функция (On), вашият телевизор ще добавя, "Интелигентно", допълнителни кадри към излъчвания канал/предаване - ефективното създаване на хибрид между предния кадър и следващия кадър - помага за намалянето на "замазването/размазването при движение".
    Има налични две версии:
    IFC (Intelligent Frame Creation) - в нашия стандартен клас и
    IFC Pro - в по-високият клас
    Кои модели телевизори от 2016г. Поддържат „Control 4” през IP?
    „Control 4” използва вградената SDDP технология, за поддръжка на „Smart Home Решения” за телевизорите Panasonic от 4К Ultra HD сериите.
    Следните модели поддържат „Control 4”: DX900 и DX800, EZ1000, EZ950, EX780, EX730, EX700, EX600.
    Как мога да направя цял екран на TV да се появи директно (с телевизор, който използва начални екрани), когато включа телевизора?
    1. Натиснете бутона HOME, за да стигнете до страницата ИЗБОР НА НАЧАЛЕН ЕКРАН;
    2. Натиснете бутона ЛЯВА СТРЕЛКА докато не видите началния екран, наречен FULL SCREEN TV;
    3. Когато изберете FULL SCREEN екрана, натиснете бутона OK;
    4. Натиснете бутона BLUE, за да получите достъп до настройките за този начален екран;
    5. Превъртете надолу, до POWER ON опция и натиснете OK;
    6. Изберете ВИНАГИ ТОЗИ НАЧАЛЕН ЕКРАН и натиснете OK.
    Не мога да открия "Panasonic 4K Channel" въпреки, че е показан на следната страница: Panasonic България
    Приложението Panasonic 4K Channel е достъпно само до избрани 4К телевизори и по-точно модели които поддържат HEVC: WT600, AX800, AX900, X940e, CX, DX900, DX800, DX780
    Може ли Дигиталния Оптичен кабел да пренася 5.1 аудио сигнал от телевизор към аудио система?
    Телевизорът има възможността да изпраща 5.1 аудио сигнал чрез оптичния кабел. Това е възможно само, ако самия звук е с 5.1 съдържание. Моля отидете в менюто на вашия Панасоник телевизор:
    Menu > Sound > SPDIF Selection > Select Auto
    Имайте в предвид, че не гарантираме, че аудио сигнала ще бъде продължен от телевизора, ако свържете външно устройство към телевизора. За това съветваме клиентите да свързват външен източник на аудио директно към аудио системата, ако желаете аудио сигнала да излиза от там. Аудио устройството/система трябва да има поне 5.1 говорители. Ако са по-малко, така или иначе ще бъдат използвани всички налични говорители, но няма да е същия ефект, както при 5.1 говорители/тонколони.
    На моята Firefox операционна система, Media Player изглежда, че е изчезнал от листа с апликации. Как мога да имам достъп до моите видео/снимки/музика от свързаната към телевизора флашка?
    На операционната система Firefox, достъпа до външно у-во(флашка с памет) може да стане от „Devices Deck” (Мениджър/плот на устройствата) и след това избирате желаното устройство. Можете да стигнете до това меню чрез „HOME” бутона на вашето дистанционно.
    Как да рестартирам/върна началните настройки на телевизора си?
    Меню-Настройка-Системно меню-Начални настройки
    За връщане на началните настройки на телевизора си моля отидете на [Shipping conditions] (Начални настройки):
    1. Отидете на [Menu]
    2. После [Setup]
    3. [System menu] – (това може да се намира на втората страница на менюто с настройки за някои модели)
    4. [Shipping conditions] (Начални настройки)
    5. И следвайте инструкциите на екрана
    * В зависимост от годината на вашия телевизор, името и разположението на тази функция може да варира.
    Защо функцията „Картина в картината” (PiP) не работи с моите телевизор и Blu-ray плейър?
    Следният проблем може да се появи, когато комбинираме Ultra HD Blu-Ray диск и ТВ програма. Функцията „Картина в картината”(PiP), на телевизора, е възможна само със HD съдържание. Когато гледате устройство, което е Ultra HD, не можете да ползвате функцията „Картина в картината”. Също така мащабирането/промяната от Full HD на Ultra HD, се води, че не е FHD съдържание. Молим Ви да промените настроената резолюция на плейъра, ако използвате Ultra HD диск, когато желаете да използвате функцията „Картина в картината”:
    Menu-setup-player settings-hdmi-video format- select 1080i or 1080p
    Имайте в предвид, че тези настройки могат да бъдат малко по-различни в зависимост от вашия плейър.
    Гледане на защитено с авторски права HDCP 2.2 съдържание
    За да гледате защитено с авторски права HDCP 2.2 съдържание, например 4K съдържание, свържете плейъра и телевизора чрез съвместим с HDCP 2.2 жак. Можете да гледате защитено с авторски права 4K съдържание само чрез връзка със съвместим с HDCP 2.2 HDMI жак. За подробности относно това дали телевизорът и 4K устройствата са оборудвани със съвместим с HDCP 2.2 HDMI жак, вижте инструкциите за експлоатация, предоставени с телевизора и устройствата.
    Как да задам „Timer recording” (записване във времето)?
    За да зададете записване във времето (Timer recording), е възможно само, когато гледате DVB сигнал. Няма как с аналогов сигнал или такъв от декодер. Уверете се, че има достатъчно място на външния хард диск преди да зададете записване.
    1. Свържете външния хард диск (със собствено захранване) към USB-то на телевизора.
    2. Изберете [Menu]-[Setup]-[USB HDD setup]
    3. Изберете хард диска за записване и натиснете ОК. Следвайте стъпките.
    4. Червено кръгче и зелена стрелкичка ще се появят до името на Хард диска.
    5. [Menu]-[Timer]-[Timer programming]
    6. Задайте детайли за записването (можете да променяте датата със стрелките горе/долу). Натиснете ОК за запаметяване.
    Мога ли да ползвам Direct TV Record когато възпроизвеждам 3D изображения?
    Direct TV Record не може да се възпроизвежда по време на изобразяване на 3D файлове.
    Мога ли да настроя външният таймер за записване по време на възпроизвеждане на 3Д изображения/филми?
    Функцията външен таймер не може да се използва по време на възпроизвеждане на 3Д изобажение
    Защо функцията “USB Recording/Pause Live TV (Timeshift)” (Запис на телевизия върху външен хард/памет) не работи на новото ми, току-що закупено, дистанционно управление?
    В случай, че сега сте закупили дистанционното N2QAYB000753 и иползвате един от моделите телевизори, споменати по-долу, то тогава трябва да направите допълнителни действия, за да активирате тази функция.
    Важи за модели и серии:
    2010: D25-, D28-, V20-, GT20-, GW20-, GF22-, GN23-, GT24-, GS21-series
    2011: EW30-, EX34-, EN33-, EF32-, ES31-, DT30-, DT35-, GT30-, GTX34-, GTN33-, GTF32-, GTS31-, VT30-series
    2012: EW5, E5 series
    За да използвате това дистанционно с телевизора ВИ, то трябва да въведете код "73".
    - Натиснете и задръжте ON/OFF бутона, който се намира под "Volume" бутона.
    - Натиснете 7 и след това 3.
    - Натиснете бутона [STOP] (в горния - ляв ъгъл)
    - Пуснете бутона ON/OFF
    Сега функцията USB-Recording/ Pause Live TV (Timeshift) или "Записване на телевизия върху външен хард/памет", трябва да бъде управляема от вашето дистанционно.
    Къде мога да намеря лист със продукти, които няма да поддържат приложението на YouTube?
    Подобен лист можете да намерите на следният адрес:
    EU & CIS | Notice of termination of YouTube app on some old models | support | Panasonic
    Наличен ли е все още Skype на телевизорите Панасоник?
    От Microsoft съобщиха, че Скайп за телевизори повече няма да има. Въпреки това, можете да ползвате за сега Skype на някои телевизори с по-стари версии на фърмуер, както и на Blu-ray рекордери/плейъри/домашно кино.
    От Юли, Microsoft съобщават за Skype, че:
    - Skype няма да приема нови абонати/потребители;
    - Промяна на имената на дадените телевизори или устройства, няма да бъде налично повече;
    - При продукти, които все още имат скайп, качеството му може да е влошено и ползването на скайп да създава проблеми със уреда.
    Относно ползване на Skype за в бъдеще на нашите уреди/телевизори, за сега единствения вариант остава, ако свържете вашия компютър/лаптоп към телевизор и го ползвате като дисплей, а програмата да си е от компютъра. За повече информациа относно Skype, можете да посетите:
    https://support.skype.com/en/faq/FA3...-for-tv&s=ecym
    Защо не мога повече да използвам Facebook на моя телевизор?
    От Фейсбук(Facebook) са решили да станат API v.2.0. С тази нова версия, Фейсбук също промениха някои правила,заради това информацията на потребители и техни приятели, не може да бъде споделяно чрез тяхната база данни. С тези нови правила и ограничения, апликацията не може да бъде поддържана, поради загубата на най-завладяващи функции.
    Възможно ли е да се гледа 4K HDR съдържание на Телевизор, който не поддържа HDR(High Dynamic Range)?
    Отговорът е - не.
    Ако използвате блу-рей плейър, който е свързан към ТВ който не поддържа HDR, този плейър предава стандартен SDR сигнал, вместо HDR.
    От къде мога да изтегля Panasonic Streaming приложението на моя iPad? Търсех го в App Store магазина, но не можах да го намеря.
    За да намерите и изтеглите това приложение, ще трябва да промените настройката за филтриране в приложениет. На горната страна от ляво, имате 2 възможности: iPad само или само iPhone. Моля, изберете "само iPhone".
    Music Streaming (for Android) | Application | Audio | Digital AV | Consumer Support | Support | Panasonic Global
    Защо моя компютър със операционна система Windows XP, ме пита да ре-форматирам моята SDXC карта-памет?
    Карти памет и други видове памети, които са SDXC(най-новият вид система за памети), са форматирани със exFAT файлова система. Тази система се поддържа единствено от Windows 8, Windows 7, Windows Vista SP1(или по-нови) и Windows XP SP2/SP3 с Hotflix KB955704. Без Hotflix KB955704, Windows XP, в повечето случаи ще има проблеми с четенето или форматирането на карти памет и други, които са вече форматирани под exFAT файлова система. Ако желаете да си инсталирате Hotflix, кликнете на следния линк и изберете „download”:
    https://www.microsoft.com/en-us/down....aspx?id=25026
    - Натиснете „Run” за стартиране на инсталацията
    - Или натиснете „Save” за запазване на вашия компютър и инсталиране по-късно.
    След инсталация, Ви молим да рестартирате компютъра и да пробвате да прочетете отново SDXC картата.
    Мойте 3Д очила презареждащи ли са?
    Ние имаме 3 вида 3Д очила:
    Пасивни, Активни презареждащи и Активни които са без възможност за презареждане.
    Пасивните няма батерия и няма нужда да се зареждат, Активните 3Д очила които имат USB кабел в комплекта могат да се презареждат, ако Вие нямате този кабел, то това означава, че Вашите очила не могат да бъдат презаредени.
    Мога ли да променя записващият режим на моят уред, след като съм задал да записва от моят Guide?
    За съжаление може да промените записващият режим само ако изберете AV1, AV2, AV3 или AV4 от "Канал" при запис.
    Имате ли проблеми със звука на вашият чисто нов телевизор?
    Ако устройството Ви е свързано чрез HDMI, моля опитайте следните настройки: За 2015 и 2016г. Модели, моля извършете следните настройки: [Menu]-[Setup]-[HDMI Auto settings]. Изберете HDMI порта, който използвате за използване на канали и променете стандартно избрания режим. За 2014/2015 и 2016 година [Menu]-[Setup]-[Hdmi HDCP settings] и изберете опцията 1.4
    Еквилайзера в менюто липсва или не ми е активен.
    Еквилайзера е активен когато е избран "Режим на звука" - "Потребителски".
    При избор от VIERA Link менюто на външна аудио система - изборът на аудио настройки е орязан.
    Телевизора не възпроизвежда HDR от моят Ultra HD BD плейър.
    Ако видите съобщение относно HDR проблем със съвместимостта, докато се възпроизвежда Ultra HD Blu-ray диск, моля проверете настройките на вашият ТВ, както следва:
    Примерно съобщение: „Този плейър не е свързан към HDR съвместим телевизор”.
    Моля проверете HDMI input-а, където е свързан вашият плейър (HDMI1, HDMI2,…)и:
    1) Ако използвате Панасоник телевизор съвместим със 4К и HDR, моля проверете следните настройки на вашият ТВ: - „Меню”, „Настройки”, „HDMI HDR Настройки” , изберете HDMI input, в който вашият плейър е включен и изберете „On/включено”
    2) Ако ползвате телевизор, който не е Панасоник, но пак е съвместим с 4К и HDR , моля следвайте инструкциите за употреба на вашияте телевизор.
    3) Когато от плейъра използвате диск със HDR съдържание, но телевизорът ви не е съвместим със HDR, то изображението ще се възпроизвежда автоматично в SDR, дори и съобщението(за което споменахме по-горе) да се появи.
    Защо цветовете на екрана са лоши/странни, като използвам плейър, рекордер?
    За някои по-стари рекордери, когато има връзка чрез SCART кабел, се появява подобен проблем с картината(черно-бяла или розова).
    В такъв случай, нещата, които може да направите са:
    - От дистанционното на рекордера натиснете бутона за функциите и изберете [Others] → [Setup] → [Connection] → AV1 Output
    Тук ще намерите следните опции: Video / S Video / RGB1 / RGB2
    Променете вида, в зависимост от възможността на телевизора Ви.
    Ако проблемът не се реши, Ви молим да пробвате друг SCART кабел.
    Кои модели телевизори от 2015 ще поддържат HDR след ъпдейт?
    За моделите CX800/CR850* ще е възможно да се излъчват съдържания с HDR, доставени през HDMI кабел, но има 3 стъпки, които трябва да бъдат направени.
    *Не е възможно за 40”-инчови модели
    1. Ъпгрейднете вашият телевизор с най-новия фърмуеър. Ако вашият телевизор е свързан с интернет, е възможно автоматично, той сам, да си свали тези ъпдейти.
    2. Ъпгрейднете „Video/imaging” фърмуеър на вашия телевизор, посредством USB стик.
    3. Променете „HDMI HDR” настройките.
    За да свалите фърмуеър-а, моля кликнете на следния линк:
    http://tda.panasonic-europe-service....ang=en&fmt=zip
    Името на файла за сваляне е U15_CX800_HDR_Contents.zip . Който е съвместим със CX800 и CR 850 сериите. Можете да отворите файла със следните програми:
    WinZip, WinRAR или IzArc. В папката може да намерите още 2 файла 153_3228_N025.zip and GC15_E030002.zip
    Моля проверете текущата версия на софтуера на вашия телевизор:
    Menu – Help – System Information
    Ако първите 4 цифри на версията на софтуера са по-високи от 3228, моля продължете със стъпка 2.
    1. Ъпдейта на фърмуер-а може да бъде направен чрез конвенционалната процедура. Това ще бъде изискано автоматично от вашия телевизор, ако е свързан към интернет.
    Ако вашия модел не е свързан към интернет, моля следвайте следните стъпки:
    1.2 Двойно кликване на сваления файл P153_3228_N025.zip
    1.3 Преместете или копирайте файла: SDDL.SEC, който е във .zip , някъде във вашият компютър.
    1.4 Свържете флашка във някой от вашите USB слотове на вашия компютър.
    1.5 Копирайте файла (не папката) в първата или най-горната папка в йерархията. Не поставяйте в отделна папка файла SDD.SEC .
    1.6 Включете телевизора
    1.7 Вкарайте флашката, която подготвихте в стъпка 1.4, във вашия телевизор. След което следвайте инструкциите на вашия телевизор.
    1.8 Натиснете "ОК" бутона да започнете свалянето на файла
    1.9 Потвърдете, че искате да започнете свалянето
    2. Вторият ъпдейт може да се направи само ръчно със флашка. Това означава, че вашия телевизор не може да извърши този ъпдейт автоматично, дори и да е свързан към интернет. Нужният ъпдейт е: GC15_E030002.zip, който вече сте свалили. Следните инструкции са нужни, за да упгрейднете вашият Video/imaging фърмуеър.
    2.2 Двойно кликване на сваления файл P153_3228_N025.zip
    2.3 Преместете или копирайте файла: SDDL.SEC, който е във .zip , някъде във вашият компютър.
    2.4 Свържете флашка във някой от вашите USB слотове на вашия компютър.
    2.5 Копирайте файла (не папката) в първата или най-горната папка в йерархията. Не поставяйте в отделна папка файла SDD.SEC .
    2.6 Включете телевизора
    2.7 Вкарайте флашката, която подготвихте в стъпка 1.4, във вашия телевизор. След което следвайте инструкциите на вашия телевизор.
    2.8 Натиснете "ОК" бутона да започнете свалянето на файла
    2.9 Потвърдете, че искате да започнете свалянето. Моля изчакайте докате свалянето завърши.
    Когато ъпдейта е готов, ще видите следното съобщение:
    (1) Remove the USB flash memory from TV. (извадете флашката от телевизора)
    (2) Turn the TV off at the main power switch.(изключете телевизора от основния бутон за изключване. *не от дистанционното )
    (3) Turn TV back on at the main power switch.( Включете отново телевизора от основния бутон за включване)
    3. Промяна на HDMI HDR настройките
    3.1 натиснете AV за избор на HDMI вход
    3.2 Натиснете [Menu] бутона, за влизане в главното меню.
    3.3 Изберете "Setup" в главното меню
    3.4 Изберете "HDMI HDR Setting" и натиснете ОК.
    3.5 Изберете HDMI input, който е свързан към HDR у-вото и натиснете ОК.
    3.6 Изберете "On" и натиснете ОК
    3.7 Натиснете [EXIT] за връщане към картината
    Какво е „Miracast” и какво е „Mirroring”(Огледален образ)?
    Miracast е името на технологията, но някои производители дават различно име на тази функция. Приложението е налично на Panasonic Viera телевизорите и Blu-ray плейърите от 2013 г. И е още познато като „Mirroring”. Компютри с Windows 8.1 и телефони с Windows Phone 8.1, могат да подават сигнал на Miracast устройства. Телефони и таблети с Android 4.2 нагоре, могат също да се визуализират/подават сигнал на Miracast устройства. Amazon`s Fire OS е вградена в Android , затова тя също поддържа Miracast.
    Miracast представлява безжична технология, която компютърът може да използва за прожектиране на изображението от екрана на компютъра към телевизори, проектори и мултимедийни плейъри за поточно предаване, които също поддържат Miracast.
    Стандартът на Wi-Fi Direct позволява на две устройства да формират директна Wi-Fi връзка помежду си. Тази връзка им позволява да се свързват помежду си, без необходимостта от безжичен рутер като посредник. На практика, това означава, че Miracast не разчита на вашата домашна мрежа, не се нуждае от достъп до Wi-Fi. Miracast устройствата създават своя собствена "мрежа" и свободно преминаване на данните през нея. Самата връзка е създадена чрез WPS и е обезпечена с WPA2.
    Miracast използва H.264 за видео предаване, което означава ефективна компресия и прилично Full HD качество на картината. Освен това, Miracast поддържа Digital Rights Management (DRM), което означава, че услуги като iPlayer и YouTube могат да бъдат предавани към телевизора. Недостатъкът на Miracast е, че дисплеят на таблета или смартфонът ви ще трябва да работи през цялото време, което не е добре за батерията.
    Ако искате да проверите дали вашето устройство е Miracast съвместимо, можете да проверите уебсайта на Wi-Fi Alliance.
    Product Finder | Wi-Fi Alliance
    Какво е MHL?
    MHL® – Expand Your World
    MHL е нещо като HDMI – нов стандарт, който прави възможна връзката между телевизора и мобилния ни телефон. Връзката между телевизора и телефона става чрез специален MHL кабел. Този кабел доставя видео резолюция от 1080р, както и възможност да управляваме телефона си чрез дистанционното на телевизора. Дори телевизорът ни да няма MHL вход, обаче, само срещу $15 можем да се сдобием с адаптер, който осъществява връзка между HDMI входа и MHL кабела.
    Вероятно най-очевидната употреба на MHL кабел би била това да гледате видеоклипове от смартфона си на по-голям екран.
    Това значи че може да гледате всичко което сте заснели или да използвате приложения като Netflix, което реално превръща смартфона ви в домашна система за забавление. Тъй като MHL просто копира дисплея на вашия смартфон, абсолютно всички приложения са съвместими.
    Има обаче още доста начини да използвате MHL. Например, в комбинация с подходящ джойстик, можете да играете игрите от смартфона си на телевизор или проектор, което реално превръща MHL устройството ви в игрална конзола. Понеже връзката не е безжична, лаг не съществува.
    Можете да разглеждате снимки, или дори да свържете Bluetooth мишка и клавиатура и да превърнете смартфона си в настолен компютър.
    Качествата на MHL се изявяват още повече ако пътувате често. Просто вземете вашия MHL кабел и няколко допълнителни аксесоара, като джойстик например, и превърнете хотелската си стая в гейминг зала или киносалон.
    И това са само няколко примера. Ако имате инсталирана система в колата, можете да пуснете приложението за навигация директно на дисплея на таблото.
    Технологията се развива постоянно. Версиите 1 и 2 поддържат 1080p некомпресирано HD видео и 8 канален звук. MHL 3.0 поддържа 4K видео, 7.1 канален съраунд звук с Dolby TrueHD, DTS-HD Master Audio, подръжка на повече от 1 дисплей, както и съвместимост с MHL 1 и 2. Поддържа се и RCP (Remote Control Protocol), който позволява на TV дистанционно да управлява смартфон чрез стандартни бутони като Stop, Play, Rewind, Pause и Enter.
    Как да заставя телевизора с включването да преминава не в ТВ режим а в AV режим? Как да изменя източника на сигнал при включване. Например сигнал по HDMI вместо TV-ефир ?
    За това в телевизора съществува настройка в така нареченият режим "Хотел", който не е описан в инструкцията на ползвателя. С негова помощ може да се застави нужният ви вход първи след включване. От там можете да настроите кой вход да се пуска по подразбиране, с колко усилване и така нататък. Това не е Сервизно меню, просто скрито такова.
    Натискаме бутона за превключване на каналите "-/V" на ПРЕДНИЯ ПАНЕЛ и без да го пускаме, три пъти натискаме "AV" на ДУ, и попадаме в меню Hotel Mode, където можем да изберем нужният видео вход, който да бъде избран от телевизора автоматически, при всяко следващо включване.
    Ценното е, че позволява при включване на телевизора, да задейства нужният ви видео вход. Работата е в това, че в дадената серия телевизори, ако сте гледали програма от който и да е видео вход, при изключване-включване на ТВ, тази настройка не се запомня. И той включва с първият ефирен канал. Полезно за тези, които ще използват ТВ основно като монитор.
    Влизане в хотелското меню: (within 2 second).
    [TV] : + [REMOTE] : TV/AV (3 times)
    Натискате и задържате бутона v/- /Vol. “Down”/на телевизора и натиснете три пъти бутона "TV\AV" (DVD) на дистанционното.
    Hotel Mode : ON
    Initial INPUT: HDMI1 или там на който искате да включва при старта.
    Как да настроя телевизора така ,че когато включа сателита/DVD,Blu-ray/, да се пуска автоматично и телевизора ?
    Трябва да влезете в HOTEL MODE. Натиснeте "-/V" на телевизора и без да го пускате натиснете три пъти AV на дистанционното, след като влезете, си изберете на кой вход да ви тръгва телевизора.
    Eкрана станa черен и не иска да изкара повече картина! Включва се, но стои на Stand By и като се включи от дистанционното датчика отчита, но няма картина.
    Просто сте включили на АV режим. Натиснете бутон TV на дистанционното.
    При изключване на телевизора след някакво време се чува прещракване/звук на реле/. Когато се включи телевизора сутринта отново - липсват част от каналите.
    Включена е функцията за автоматично опресняване на списъка с програми(в менюто може да зададете час, кога да става това).
    Меню->Настройки->системно меню->Системна актуализация->Автоматично търсене в режим готовност - го давате на "изключено"...и това е.
    Изображението подавано от компютър, ми излиза извън границите на екрана ?
    Трябва да изключите режим 16:9 сканиране /OverScan -Off/
    Отивате в Настройки -> Други настройки -> 16:9 сканиране -> Изкл. (Setup->Other Settings-> 16:9 Overscan -> OFF)
    Свързал съм моят Ultra HD телевизор ,като монитор към моето PC, но не мога да настроя разделителната способност (резолюцията) на Ultra HD.
    Когато свързвате Ultra HD телевизор към компютър, чрез HDMI кабел, тогава максималната резолюция, на която телевизора може да работи е 3840х2160. Но имайте в предвид, че това зависи също така от сигнала,който се подава (видео картата). Ако видео картата не поддържа сигнал с такава голяма резолюция, то няма как да подаде такава, а телевизора в случая зависи от това какъв сигнал ще му се подаде като входящ.
    Какво е 1080 pure direct ?
    "Включва поддръжка на цифров сигнал във формат 4:4:4. Използва се само с източник на сигнал 4:4:4 - тоест засега само сигнал от PC.
    Забележка: тази функция е възможна само за HDMI вход 1080р. Не работи, когато отсътства сигнал, при входен сигнал YCbCr 4:2:2 и в режим 3D."
    The 1,080p Pure Direct function transmits and outputs high-quality YUV 4:4:4 30-bit video signals directly to the TV. This reproduces colors that are highly faithful to the original.
    Изводът се набива сам - в сегашните условия - безполезна, при отсъстствие на такова съдържание. При Блу-Рей и всичкото останало видео - просто не работи - все едно, че е изключена.
    Този пост е редактиран от hristoslav2; 29-05-17 в 19:51.
    svetlio1 и Frogst харесват това.
    #114
    Малко по-успешни снимки на панела на моя 49CX740
    hristoslav2 одобрява това.
    #115
    Как да разчетем моделният префикс на телевизор Panasonic?
    пример- TX-50EXW734E
    T - телевизор
    X - континентално предназначение
    • X - Europe
    • H - Asia, Africa, Middle East, Oceania (Australia & New Zeeland)
    • C - Nord & South America
    50 - диагонален размер на екрана в инчове /1инч - 2,5 см/
    • 65" - 162,5 см
    • 60" - 150,0 см
    • 58" - 145,0 см
    • 55" - 137,5 см
    • 50" - 125,0 см
    • 49" - 122,5 см
    • 43" - 107.5 см
    • 42" - 105,0 см
    • 40" - 100,0 см
    • 39" - 97,5 см
    • 32" - 80,0 см
    E - година на модела
    • A - 2014
    • C - 2015
    • D - 2016
    • Е - 2017
    X - Резолюция (липсата на тази буква показва, че модела е HDReady - пример 32E300E)
    • X - ULTHRA HD (3840x2160)
    • S - FullHD (1920x1080)
    W - модели с разлика в комплектацията, предназначени за различни вериги ритейлъри- модели с това обозначение като правило не се продават у нас
    • C - Швейцария
    • W - Германия
    • E - Белгия
    • N - Нидерландия
    • R - ***** и Украина (само 2 езика в менюто, няма PVR + измама с модела - техният DX800 това е нашият DX700 и т.н. по веригата)
    • F - Франция и Нидерландия
    • T - Австрия
    • M - Нидерландия
    • X - Нидерландия
    7 - Серия
    • 9 - флагман
    • 8 - висок клас
    • 7 - среден клас
    • 6 - среден клас
    • 5 - бюджетна серия
    • 4 - основна серия
    • 3 - базова серия
    7 - Под-серия, показваща хардуерни различия
    • 8 -
    • 7 -
    • 6 -
    • 5 -
    • 5 -
    • 4 -
    • 3 -
    • 2 -
    • 1 -
    • 0 -
    4 - това са модели по поръчка на търговски вериги /разликите в комплектацията
    Някои от вас са забелязали, че моделите в някои европейски страни като Германия, Холандия и Англия завършват на цифра 4(например DXW904, DX804)....Тези модели се различават софтуерно спрямо моделите продавани у нас (завършват на 0).Има хардуерна разлика при моделите за Германия и Швейцария(за отделни търговски вериги) - вграден допълнително сателитен тунер в моделите от средният и ниският клас или променен цвят на корпуса.
    За Англия моделният код завършва с цифра 2 и буква B в края(пример DX902B) - това е заради различната система на EPG прилагана при тях - MHEG. Затова и ъпдейтите за тях са отделно.
    • 9 -
    • 8 - Double tuner - DVB-T/T2/C/S/S2 (HEVC)
    • 7 -
    • 6 -
    • 5 - DVB-T/T2/C (HEVC for UltraHD models)
    • 4 - 2 x DVB-T2 (H.264) für Österreich, DVB-T2 HD (H.265) für Deutschland / DVB-S2 / DVB-C / TV>IP
    • 3 - DVB-T/T2/C/S2 (HEVC for UltraHD models)
    • 2 -
    • 1 -
    • 0 - DVB-T/T2/C
    Е - регионално предназначение /и цвят на корпуса/:
    • E - Europa,
    • ES - Europe, Silver color
    • F - Europe-France....?
    • S - Silver color,
    • B - Britain & Ireland (заредени със софтуер за MHEG[еквивалент на EPG])
    • W - white color
    Други кодове за регионално предназначение
    Asia
    • C - China
    • D - India, Nepal
    • H - Hong Kong
    • R - Iran
    • S - Singapure, Indonesia and Philipinnes
    • T - Thailand
    • K - Malaysia
    • W - Taiwan
    Oceania
    • A - Australia
    • Z - New Zeeland
    • U - Australia, New Zeeland
    Midlle East & Africa
    • M - Kuwait, UAE, Egypt, Lebanon, Syria, Saudi Arabia
    • Q - Africa
    Nord America
    • U - United States & Canada
    • X - Mexico
    South America
    • A - Argentina
    • B - Brasil
    • H -
    • L - Peru, Bolivia, Paraguay
    • X -
    Регистриране за 5 години гаранция
    https://panasonic5y.com/bg-BG/Promo-models.aspx
    Този пост е редактиран от hristoslav2; 04-06-17 в 12:41.
    svetlio1 и mitaknika харесват това.
    #116
    Panasonic Home Entertainment Spring 2017 [.pdf]
    http://www.panasonic.com/content/dam...2017%20(1).pdf
    http://www.panasonic.com/content/dam...017_spring.pdf
    LED LCD телевизори VIERA - Panasonic
    Telewizory Panasonic 2017 – TV TEST
    Няма да има нова 9-та серия. Продължава продажбата на миналогодишната серия DX900.
    Няма нито един модел с извит дисплей - всички са плоски. Пикът на предлагането на телевизори с извит екран в Европа, беше през 2015 година, но през 2017 година те вече са рядкост. Свърши мейнстрийма в западните страни, докато в Азия, извитите телевизори се считат за премиални модели.
    https://fotos.subefotos.com/4160c00c...ebb95d648o.jpg
    65DX900 - (2016 модел, продължава през 2017 г.)
    58DX900 - (2016 модел, продължава през 2017 г.)
    58DX800 - (2016 модел, продължава през 2017 г.) до изчерпване на бройките
    50DX800 - (2016 модел, продължава през 2017 г.) до изчерпване на бройките
    High-End
    Двете нови Oled серии, идват като заместници на серия CZ950.
    77EZ1000 - UltraHD/HDR, OLED, THX, Quattro тунер с 2 CI слота(2 x DVB-T2/C/S2/IP)
    65EZ1000 - UltraHD HDR, OLED, THX, Quattro тунер с 2 CI слота(2 x DVB-T2/C/S2/IP)
    Добавен е антиотражателен филтър.
    65EZ950 - UltraHD HDR, OLED, THX, Quattro тунер с 2 CI слота(2 x DVB-T2/C/S2/IP)
    55EZ950 - UltraHD HDR, OLED, THX, Quattro тунер с 2 CI слота(2 x DVB-T2/C/S2/IP)
    Единствената разлика в панелите е присъствието на антиотражателен филтър в серия EZ1000 и липсата му в EZ950.
    Двете Oled серии използват едни и същи Oled панели на LGDisplay и процесори(вероятно на MediaTek). Разликата е, че EZ950 няма филтър и саунд бар, като в EZ1000
    Телевизорите използват новият OLED панел на LG 2017. Инженерите заявиха, че това е специален панел, произведен за нуждите на Panasonic...
    Неговото поколение се дефинира като G3.5 (броят генерации Ultra HD Oled панели - 2014, 2015, 2016, 2017), докато предшественикът му CZ950, използва панел от 2-ро поколение, а до миналата година (2016 г.), LG има 3 поколения панели(генерации). Новият панел е по-лек от предишния почти двойно (имам предвид CZ950) и осигурява много по-добро покритие на цветовото пространство(99% DCI).
    Друга техническа разработка, е прилагането на анти-отражателен филтър - Absolute Black Filter, чието преимущество e абсорбирането на светлината от околната атмосфера и елиминира отраженията. Нещо повече, той напълно елиминира лилавият оттенък на OLED панели в присъствието на силна външна светлина.
    Да припомня, че се използва подобрена версия на софтуера от миналогодишният Oled CZ950, за показване на големи подробности в най-тъмните сцени на изображението. В допълнение, инженерите от Panasonic казаха, че за да се постигне това ниво на детайлност в тъмни области на изображението (като например нощна сцена с движение), се налага пълен контрол на повторното запалване на пиксела след неговото изгасване. Запалването отново на напълно потушен пиксел за показване лека текстура (с много ниско ниво на яркост), пак според тези инженери е истинско техническо предизвикателство. Предизвикателство, което Panasonic са решили, благодарение на дългогодишния си опит и експертиза в плазмената технология.
    Стойка
    Аудио секцията на Panasonic TX-EZ1000 е поверена на Technics, фирма специализирана в аудиото - собственост на Panasonic. Те са разработили стабилен саунд бар, който също така служи като стойка.
    Вградена аудио система от 14 високоговорителя с мощност от 80 вата(8 ниско-честотни, 4 средно-честотни, 2 високочестотни и пасивен излъчвател за усилване на басите), срещу 12 говорителя и 40 вата мощност при миналогодишният DX800 и още четири пасивни радиатора, които трябва да му дадат възможност да осигури звук по-добър дори от DX800. Системата Dynamic Blade Speaker, е настроена и оптимизирана от инженерите на Technics.
    Свързаност
    Портовете са поставени отзад на устройството. Откриваме два HDMI порта насочени встрани и два назад, два USB насочени назад и един отстрани, четец на SD карта, три антенни конектора, жак за слушалки и компонент/композит видео вход. Оптичен цифров изход, Lan порт, вграден Wi-Fi и също Bluetooth, последният е само за клавиатура и мишка, а не за аудио устройства.
    source photo: [homecinemamagazine.nl]
    Всички връзки могат да бъдат скрити зад панела, но това очевидно е възможно, ако използвате само страничните портове. За тези връзки Panasonic включва и подреждане на кабелите, но най-вероятно не могат да бъдат скрити повече от два HDMI кабела .
    sorce photo: [homecinemamagazine.nl]
    Насочените назад портове ще бъдат проблем, ако искате да закачите телевизора по-плътно до стената.
    http://img1.lesnumeriques.com/test/1...sans-cache.jpg
    http://img1.lesnumeriques.com/test/1...-son-cable.jpg
    http://img1.lesnumeriques.com/test/1...-cache-son.jpg
    Input Lag в HDR режим - 30ms
    Двете серии разполагат с по две дистанционни. Едно стандартно алуминиево с подсветка и второ смарт тъчпад, с който да местите курсора по екрана.
    Middle Range
    75, 65, 58, 50, EX780E(in Europe) -> EX750B(in UK) - 120/100Нz, UltrаНD, НDR, Edge Led Lосаl Dіmmіng, 3D, Quаttrо тyнep c 2 СІ cлoтa(2 х DVВ-Т2/С/Ѕ2/ІР), 3D Active, Edge Led(Down) Local Dimming, яркост от 800nit.
    Stand
    Концепцията "Switch дизайн" модулни стъпки също е разширена, и за разлика от своя предшественик с четири крачета(DX780), сега Panasonic са приели друг подход тук. Сега при EX780 имаме централна стойка с кръстата основа, а модулността идва от стойката " променлива концепцията ", която позволява регулиране на височината на екрана в 3 позиции.
    Телевизорът може също да бъде поставен директно върху земята на висока основа(платформа), но също така и върху мебели в ниска или средна позиция, като по този начин се позволява например да инсталирате централен говорител под екрана или по-голям саундбар. Последно най-накрая, основата може да се завърта на 30 ° - значителна подробност. Последната функция, до преди няколко години беше често срещана, а последните две години изчезна.
    Ѕwіtсh Dеѕіgn (Mнoгoфyнĸциoнaлeн дизaйн). Bcичĸи ĸaбeли мoжe дa ce cĸpивaт в цeнтpaлнaтa чacт нa cтoйĸaтa.
    Качеството на изработка е много добро, основата показва много добра устойчивост на усукване в съответствие с това, независимо от избраната позиция.
    65" - Cтoйĸa(само въpтeнe)
    58" - Cтoйĸa(въpтeнe и регулиране на виcoчинaта)
    50" - Cтoйĸa(въpтeнe и peгyлиpане на виcoчинaта)
    Stand: 50" & 58"" - up/down + swivel, 65" swivel, 75" - fixed
    source photo:[audiovideohd.fr]
    У нас ще се предлага само серия EX780 с кръстата стойка.
    source photo:[hifi-regler.de]
    Switch Design (Многофункционален дизайн). На гърба има и система за прикриване на всички кабели от погледа (преминават в централния пиедестал на стойката).
    source photo:[tweakers.net]
    В някои страни от западна Европа, се предлагат модели с правоъгълна стойка.
    Единствената серия, която тази година поддържа 3D. Очилата се синхронизират по Bluethoot, така че може да ползвате очила и от други марки телевизори- например Samsung SSG-5100.
    Conectivity
    Всички конектори се намират от лявата страна, и се покриват от два пластмасови капака за да стане всичко по-дискретно. Изборът на конектори наистина не се променя, но за сега EX780 предлага четири HDMI 2.0a входове с HDCP 2.2, 4K / 60p, HDR, Deep Color и т.н. за свързване на Блу-рей плейъри UHD 4K, 4K медия плейър и други източници 4K HDR. Внимание, само 1 и 2 HDMI входа предлагат възпроизвеждане с пълен обхват 4:4:4.
    Audio
    Звукът на EX780 се осигурява от два пълни високоговорителя, които седят в долната част на корпуса, а звукът е насочен надолу. Това е най-често срещаната настройка за високоговорителите в телевизор, но за съжаление не най-добрата. Поради това, че звукът няма ясен фокус върху ушите ви, ще чуете само косвен звук, който е отразен един или повече пъти, както и има неблагоприятен ефект върху стерео образа и яснотата на гласовете.
    Като цяло, звукът не е лош, но не е особено добър.
    Звукът на изхода за слушалки може да се регулира отделно.
    Друг важен момент и уникална характеристика на серията Panasonic EX е функцията за гласови указания. Това е функция за четене, особено важна за хора или с влошено зрение или дислексия. Четецът на съобщения ви чете при поискване цялото текстово съдържание на екрана, като менюта, уеб страници или EPGs. Засега няма информация на колко езика чете.
    Серията е с Edge Led подсветка в долната част, с "локално затъмняване"...(Digitally Enhanced Local Dimming).
    source photo: dday.it
    На термоснимката, ясно се виждат 3 сектора в долната част на рамката, и 3-те осветени от тях секции.
    Серия ЕХ730 (65, 58, 50, 40) - UltrаНD, НDR, Edge Led Lосаl Dіmmіng, Quаtrо тyнep c 2 СІ cлoтa(2 х DVВ-Т2/С/Ѕ2/ІР),
    EXW735 -
    EX730 -
    Edge Led Local Dimming (от двете страни на дисплея), яркост от 350 nit, 90% покритие на цветовото пространство DCI/P3
    Крачетата от стойката може да се местят в близост до центъра или по краищата - в 2 позиции, плюс това могат да се обръщат - така получаваме общо 4 варианта.
    65, 58, 50, 40, ЕХ700 - UltrаНD, НDR, Lосаl Dіmmіng, Quаtrо тyнep (2 х DVВ-Т2/С/Ѕ2/ІР), Backlight Motion Rate IFC 1600, Телетекст 1000р, Дистанционно комбинирано, алуминии с пластмаса
    Edge Led, с яркост от 350 nit
    Стойка
    Крачетата от стойката може да се обръщат, и местят в близост до центъра или по краищата - в 4 позиции.
    Entry Level
    Серия EX60 (55, 49, 40)
    EX633E - UltrаНD, 60/50Hz, HDR, Quаtrо тyнep(DVВ-Т2/С/Ѕ2/ІР), Backlight Motion Rate IFC 1500, Телетекст 1000р,
    EX630E - UltrаНD, 60/50Hz, HDR, Quаtrо тyнep(DVВ-Т2/С/Ѕ2/ІР), Backlight Motion Rate IFC 1500, Телетекст 1000р,
    EX620E - UltrаНD, 60/50Hz, HDR, Quаtrо тyнep(DVВ-Т2/С/Ѕ2/ІР), Backlight Motion Rate IFC 1500, Дистанционно N2QAYB001111
    EX613E - UltrаНD, 60/50Hz, HDR, Quаtrо тyнep(DVВ-Т2/С/Ѕ2/ІР),
    EX610E - UltrаНD, 60/50Hz, HDR, Backlight Motion Rate IFC 1500, Цвят-сребрист, Дистанционно N2QAYB001115
    EXW604 -
    EX600E - UltrаНD, 60/50Hz, HDR, Quаtrо тyнep(DVВ-Т2/С/Ѕ2/ІР), Backlight Motion Rate IFC 1300, Цвят-черен, Дистанционно N2QAYB001111
    (55EX600e - IPS, Full Led)
    EX600S - Silver (сребрист цвят на корпуса)
    Крачетата от стойката може да се местят.
    https://www.homecinesolutions.fr/a/i...vsveOt8xbA.jpg
    https://www.homecinesolutions.fr/a/i...XaPX48dI9g.jpg
    FullHD
    49ES600 - FullHD, Hz ??
    40ES600 - FullHD, 50/60Hz
    32ES600 - FullHD, 50/60hz
    Edge Led
    Вероятно тази серия ще се продава само в определени страни.
    49ES500 - FullHD, 60/50Hz,
    43ES500 - FullHD, 60/50Hz,
    40ES500 - FullHD, 60/50Hz, Edge Led
    32ES500 - HDReady, 60/50Hz, Edge Led
    24ЕЅ500 - HDReady, 60/50Hz, Edge Led
    ES513 - DVB-T/T2/C/S2
    ES503 - DVB-T/T2/C
    ES500 - DVB-T/T2/C
    Предлага се с два цвята на рамката:
    Чepeн: 24 ", 32", 40 ", 43", 49 "
    Cpeбpиcт: 32", 43 ", 49" - завършват на буква S
    49ES400 - Full HD, 60/50Hz, Edge Led, audio 2x10W
    40ES400 - Full HD, 60/50Hz, edge Led, audio 2x10W
    32ES400 - HD-Ready, 60/50Hz, Edge Led, audio 2x10W
    Hardware
    SoC
    Panasonic имат 3 завода за чипове в Япония. Преди няколко години продадоха дял на израелската TowerJazz.
    Imaging―Display | Application | Socionext Inc.
    Platform SoCs (General-Purpose Processors) | Socionext Inc.
    Последните 5 години, често използват процесори на китайската MediaTek.
    Традиционно използват видеопанели на Innolux
    Innolux Corporation
    и от 4 години на LG Display
    LG Display
    Внимание: при LCD панелите, понятието генерация обозначава произведеният размер на стъкленият субстрат от който се режат дисплеите.
    P8.5 (2200 X 2500mm glass substrate) is optimized for the production of 6 x 55" panels
    P7.5 (1950 X 2250mm glass substrate) is optimized for the production of 6 x 47" panels
    P7 (1950 X 2250mm glass substrate) is optimized for the production of 42" and 47" LCD TV panels
    P6 (1500 X 1850mm glass substrate) is optimized for the production of 6 x 37" panels
    P5.5 (1300 X 1500mm glass substrate) is optimized for the production of 6 x 32" panels
    P5 (1100 X 1300mm glass substrate) is optimized for the production of 6 x 27" panels
    P4 (650 X 850mm glass substrate) is optimized for the production of 6 x 15" panels
    P3.5 (620 X 750mm glass substrate) is optimized for the production of 6 x 14.1" panels
    Series
    ________
    Videopanel
    _________________
    SoC, CPU, GPU
    _____________________________________
    Main board
    T-con board,
    Power board
    __________________
    Oled
    • EZ1000: 77": LC770AQP-AKA3 90 EA
    (LG Display)
    65": LC650AQP-AKA3 90 EA
    (LG Display)
    Plattform:
    SoC: MediaTek
    Core Architecture:
    Instruction set:
    Operating at up to:
    CPU bit: 64-bit
    CPU Cores: Quad (4)
    CPU Frequency:
    GPU:
    Open GL:
    RAM:
    Total memory:
    Available memory:
    Internal storage total space:
    Internal storage free space:
    Video Decoder: HEVC/VP9 UltraHD 60fps 10-bits
    HDR: HDR10, HLG
    Audio Decoder: Dolby,
    - TNP
    • EZ950: 77": LC770AQP-AKA3 90 EA
    (LG Display)
    (LG Display)
    Plattform:
    SoC: MediaTek
    Core Architecture:
    Instruction set:
    Operating at up to:
    CPU bit: 64-bit
    CPU Cores: Quad (4)
    CPU Frequency:
    GPU: Mali
    Open GL:
    RAM:
    Total memory:
    Available memory:
    HDR: HDR10, HLG
    LCD - UltraHD
    • EX780: S-MVA(Innolux) RGB, 10-bits panel, 100/120Hz, with MCFI + blinking backlight
    Edge Led (Down), Local Dimming
    PFS LED - Potassium fluorosilicate (PFS)-based phosphors for LED-based backlighting in displays.
    65" - 15 sections(5x3)
    58" - 12 sections(4x3),
    Plattform:
    SoC: MediaTek
    Core Architecture:
    Instruction set:
    Operating at up to:
    CPU bit: 64-bit
    CPU Cores: Quad (4)
    CPU Frequency:
    GPU: Mali
    Open GL:
    RAM:
    Total memory:
    Available memory:
    HDR: HDR10, HLG
    • EX730: S-MVA(Innolux) RGB panel, 50/60Hz, with MCFI,
    Edge led(below), Local Dimming
    Plattform:
    SoC: MediaTek MT5597
    Core Architecture: ARM Cortex A53
    Instruction set:
    Operating at up to:
    CPU bit: 64-bit
    CPU Cores: Quad (4)
    CPU Frequency: 1.1GHz
    GPU: Mali T-860 MP2
    Open GL:
    RAM:
    Total memory:
    Available memory:
    HDR: HDR10, HLG
    • EX700: 65": S-MVA(Innolux) RGB, 8bits + FRC panel, 50/60Hz, with MCFI, Edge Led
    58": S-MVA(Innolux), RGB, 8bits + FRC panel, 50/60Hz, with MCFI, Edge Led
    40": S-MVA(Innolux), RGB, 8bits + FRC panel, 50/60Hz, with MCFI, Edge Led
    Plattform:
    Instruction set:
    Operating at up to:
    CPU bit: 64-bit
    CPU Cores: Quad (4)
    GPU: Mali T-860 MP2
    Open GL:
    RAM:
    Total memory:
    Available memory:
    HDR: HDR10, HLG
    • EX600: 65": S-MVA(Innolux), RGB, 8-bits +FRC panel, 50/60Hz, Direct led
    55": IPS (LG Display), RGB, 8-bits + FRC panel, 50/60Hz, Direct Led
    49": IPS (LG Display), RGB, 8-bits + FRC panel, 50/60Hz, Direct Led
    43": IPS (LG Display), RGB, 8-bits + FRC panel, 50/60Hz, Direct Led
    40": S-MVA(Innolux) RGB, 8-bits + FRC panel, 50/60Hz, Direct Led
    Plattform:
    Instruction set:
    Operating at up to:
    CPU bit: 64-bit
    CPU Cores: Quad (4)
    GPU: Mali T-860 MP2
    Open GL:
    RAM:
    Total memory:
    Available memory:
    HDR: Dolby Vision, HDR10, HLG
    LCD - FullHD
    • ES600:
    • ES500: 49": IPS 8-bits panel, 50/60Hz
    40": IPS 8-bits panel, 50/60Hz
    32": IPS 8-bits panel, 50/60Hz
    24": IPS panel, 50/60Hz
    • ES400: 49": IPS 8-bits panel, 50/60Hz
    Remote Control
    Разлики в дистанционните по модели
    EZW1004, EZ1000, EZW954, EZ950,
    EXX789, EXW787, EXW784 EX780, EXW735, EXW734, EX730, EX703, EX700 EX633, EX620, EX613, EX610, EXW604, EX603, EX600
    N2QAYB001115 N2QAYB001111
    Няма второ Няма второ Няма второ
    Серии EZW1000/950 са снабдени с две дистанционни управления. Първото е голям, по-луксозен метален вариант на класическо Panasonic дистанционното. Бутоните са по-малки, но подреждането е класическо, отлично оформление. Чрез докосване е малко по-трудно да си намерят бутоните, но за сметка на това дистанционното има функция за подметка на бутоните (бутонът за осветление се намира горе в дясно). Това дистанционно е допълнено с бутона "My App". По този начин можете да стартирате приложение, което сте избрали за този бутон.
    По-малкото дистанционно управление е тъчпад дистанционно. Разполага с минимален брой клавиши за избор и голям тъчпад. Бързо стигате до някои функции - прекарвате пръст и после правите до едно-две кликвания. Значително подобрение в това отношение няма. Но клавишите със стрелки, които първоначално изглеждат ненужни, са алтернатива.
    Panasonic поддържа гласови команди, като например да регулирате силата на звука, стартиране на приложения или при търсенията. тази функция обаче изисква да използвате тъчпад дистанционното или да инсталирате приложението Panasonic TV Remote 2 на вашия смартфон или Ipad.
    В серията EX780 се използва стандартно инфрачервено дистанционно управление, което все още не е претърпяло някаква значителна промяна, а това според мен трябваше да стане още миналата година. Дизайнът му леко се различава от стандартите на XXI век. Предният му панел е изработен от пластмаса, имитираща полиран метал като рамката на телевизора, докато панела на гърба е направен от черна пластмаса(отново като телевизора отзад). Бутонното оформление не се е променило, с изключение на една подробност - в долния ляв ъгъл е добавен бутон "моят ап", с който можете да стартирате избрано то вас приложение. Това е много добро решение, което позволява на потребителя да спести време, ако често използвате някои услуги (напр. плеър).
    Дистанционното е дълго 21cm дълго и заедно с две батерии АА тежи около 145 грама. Батериите са поставени зад друга, при което центърът на тежестта се намира в центъра. Това дистанционно приляга удобно в ръката ви. Двете вдлъбнатини на гърба, дават допълнително сцепление. Освен това, е направен каналза показалеца на гърба, което кара палеца естествено да застава над G-бутона. Гумираните бутони имат ясно осезаем "щрак" и отчетлив печат.
    Gamepad
    Списък на тестваните до 2015 година.
    Maker
    Model Number
    Logitech Gamepad F310, F510, F710
    Guillemot F1 Wireless Gamepad Ferrari F60 Limited edition
    T-Wireless 3 in 1 Rumble Force
    Стойки
    Серия Тип стойка Възможности за монтаж на крачетата
    EZ1000 Саундбар служещ като стойка Фиксиран, но може да се махне при монтаж на стена.
    EZ950 Фиксирана стойка с две крачета Може да се махне при монтаж на стена.
    DX900 Две фиксирани крачета. Може да се махат при монтаж на стена..
    EX780 75" - фиксирана
    65" - само завъртане
    50", 58" - 3 степени нагоре/надолу + завъртане
    EX730 Две подвижни крачета. Крачетата от стойката може да се местят в близост до центъра или по краищата, освен това може да избирате начина на монтаж - с правата или извитата част напред.
    EX700 Две подвижни крачета. Крачетата от стойката може да се местят в близост до центъра или по краищата, освен това може да избирате начина на монтаж - с правата или извитата част напред.
    EX600 Две подвижни крачета Крачетата от стойката може да се местят в близост до центъра или по краищата.
    ES600 Две подвижни крачета. Може да се преместят в средата или в краищата.
    ES500 Две фиксирани крачета. -
    ES400 Две фиксирани крачета. -
    Panasonic OS
    Firefox OS, вече е My Home Screen 2.0 и според слухове ще бъде преименуван...
    Лично за мен, това е втората най-добра OS за телевизори след webOS- като дизайн, работа....
    Panasonic, ползваха последните години Firefox OS, като смарт TV платформа в своите по-скъпи модели. Миналата година обаче, Mozila спряха поддръжката на операционната система Firefox(наречена My Home Screen 2.0) с отворен код и отказаха да продължат развитието на този софтуер. Panasonic продължава обаче да използва системата и твърди, че са поели развитието и.
    За потребителя, това няма значение; тя изглежда и работи по същия начин. Трябва да се отбележи, че интерфейсът е все още задочно 1080p. Можете да го очакваме че през 2017 година ще премине в 2160p.
    Кратка демонстрация показа обаче, че "новата" система всъщност е останала същата като миналата година, най-важното допълнение е появата на папки, съдържащи няколко връзки или приложения с пин на началния екран.
    Има абсолютно същия вид [Firefox OS] дава същите чувства и това, което са направили, е да добавят някои (малки) подобрения. Панасоник не са закупили софтуера, защото Firefox е бил свободен. Започнали са с Firefox и са добавили някои функции.
    На началния екран все още сме свидетели на големи "икони".
    Там са показани до пет наведнъж, които трябва да превъртате хоризонтално.
    Ако сложите много приложения на началния си екран, това може да бъде объркващо и затова сега има възможност за създаване на папки. Това работи добре, макар че не е възможно да се променят имената на папките; всички са наречени "Моята папка".
    https://www.youtube.com/watch?v=of6n9hBOKBY
    От лявата страна началния екран в Smart TV 2015 г., с Firefox OS. Вдясно на Smart TV от 2017 с "Panasonic OS".
    Вляво менюто с приложения на Firefox OS. Вдясно от "Panasonic OS".
    https://firefoxosdevices.org/en/#typ...ng-devices:yes
    https://developer.mozilla.org/en-US/...efox_OS_for_TV
    https://developer.mozilla.org/ja/doc...efox_OS_for_TV
    My Home Screen 2.0 стартира само с натискането на един бутон на дистанционното управление. По същия начин, потребителския интерфейс вече предлага възможността за създаване и преименуване на потребителски дискретни папки, които могат да бъдат приложения "редове" или дори източници (HDMI 3 ...).
    Бутонът на дистанционното My App, може да бъде персонализиран за бърз достъп до любимо съдържание.
    Тунери
    Двойни тунери имат само серии - DX900, DX800, DX780, DX750, DX730. С тях можете да гледате и записвате две програми едновременно, да гледате програма докато записвате друга и т.н..
    DVB по IP
    Моделите поддържащи DVB via IP могат да служат като сървър, за да осигурят предаване към друг телевизор, поддържащ функцията DVB via IP клиент или SAT IP съвместими устройства.
    https://www.panasonic.com/de/consume...it-sat-ip.html
    Resources | SAT IP
    DVB viewer - your software for TV and Radio - Home
    https://www.youtube.com/watch?v=y3iY_0qKjiE
    EZ1000 - (Server/Client)
    EZ950 - (Server/Client)
    EX780 - (Server/Client)
    EX730 - (Server/Client)
    EX703 - (Client)
    EX700 - (Client)
    EX603 - (Client)
    ES513 - (Client)
    ES500 - (Client)
    https://www.infosat.de/technik/progr...-panasonic-exw
    Programmlisten für Panasonic - EXW-Serie
    3D
    3D FAQs | Digital AV | Consumer Products | Support | Panasonic Global
    От модели 2017, единствено EX780 има 3D функция. Очилата не влизат в комплекта.
    https://ic.tweakimg.net/ext/i/2001510167.jpeg
    https://ic.tweakimg.net/ext/i/2001510169.jpeg
    Изискваните активни очила се синхронизират чрез Bluetooth и струват около 40 евро. Те трябва да бъдат свързани при първото стартиране на телевизора. Можете да направите това, като ги държите близо до телевизора и задържите бутона натиснат. Внимавайте особенно когато гледате в осветено помещение, в което е налице ярка околна светлина- можете да видите дразнещо примигване в очилата, но проблема ще изчезне ако затъмните стаята.
    В таблицата са дадени поддържаните от серия EX780 модели 3D очила
    Country/ Area LCD TV Model Number
    Europe
    (except UK / Ireland)
    EX780, EXW784, EXT786, EXF787, EXN788, EXX789 TY-ER3D4ME
    TY-ER3D4SE
    TY-ER3D5ME
    TY-ER3D6ME
    3D Eyewear Information of VIERA for Europe(except UK / Ireland) | TV | Digital AV | Consumer Products | Support | Panasonic Global
    Kaĸ ce разчита модела на 3D очила Panasonic ?
    Пример - ТY-ЕR3D4МE
    TY - телевизионен аксесоар
    Е - Eyewear - очила
    R - тип връзка с телевизора
    • R - RF (wirеless) Вluеtooth система
    • W - (wi-fi) безжични
    • P - поляризирани (за пасивно 3D)
    3D - 3D
    4 - година на модела
    • 6 - 2016 година
    • 5 - 2015 година
    • 4 - 2012 година
    • 3 - 2011 година
    • 2 - 2010 година
    M - Размер на очилата
    • L - Lаrgе
    • М - Меdіum
    • Ѕ - Ѕmаll
    E - Регион
    • E - Европа
    • U - Северна Америка
    • P - пакет от 2 броя
    Software
    Unipf technical information.
    Firmware
    TV | Digital AV | Support | Panasonic Global
    Playback function
    File Sharing & DLNA
    Enjoy your VIERA with Home Networking | TV | Digital AV | Consumer Products | Support | Panasonic Global
    Web Browser App
    Web Browser App | TV | Digital AV | Consumer Products | Support | Panasonic Global
    Гласов асистент и Гласови напътствия
    Телевизорът прочита с глас изписаното на екрана по време на настройка или информация за програмата.
    Enjoy your VIERA with TV Remote 2 | TV | Digital AV | Consumer Products | Support | Panasonic Global
    Bluetooth
    Само за работа с съвместими с HID (Human Interface Device Profile) клавиатури.
    http://www.usb.org/developers/hidpage/
    USB-HDD-Recording
    Операциите не са гарантирани при всички случаи.
    Операциите не са гарантирани с всички хардуерни и софтуерни промени.
    Аналоговите телевизионни програми не могат да бъдат записани на USB HDD.
    Не всички програми могат да бъдат записвани в зависимост от доставчика на услуги и доставчика на програма.
    Когато телевизорът е ремонтиран, поради повреда, може да се наложи да форматирате USB HDD отново с телевизора, за да го използвате. (Всички данни ще бъдат изтрити при форматиране.)
    За да използвате USB HDD с вашия компютър след записа от вашият телевизор, форматирайте го отново на вашия компютър.
    Данните, записани на USB HDD от даден телевизор могат да се възпроизвеждат само на същият телевизор. Вие не може да възпроизвежда данните на други телевизори (включително телевизори от един и същ модела) или всякакви компютри.
    Капацитетът на USB HDD, които са били тествани за изпълнение: От 160GB до 3 TB. (Трябва да използвате AC адаптер.)
    THX & UHD Premium
    Само телевизори преминали успешно над 400 THX лабораторни тестове в 30 тестови категории, получават сертификация на екрана THX 4K Display.
    Panasonic Oled TV(EZ1000, EZ950) и серия EX780 имат UHD Premium и THX-сертификати. По този начин, Panasonic се придържа към лицензирането на THX при топ моделите.
    Компанията предлага и приложение за настройки.
    https://itunes.apple.com/gb/app/thx-tune-up/id592624594
    https://play.google.com/store/apps/d...hx.tuneup.free
    http://www.uhdalliance.org/faq/
    HDR
    Panasonic заяви, че всички нейни 2017 UltraHD LCD телевизори ще получат поддръжка за двата формата HDR10 и HLG (чрез актуализация на фърмуера). За сега, компанията е избрала да не обръща внимание на по-премиалният формат Dolby Vision - тоест да изчака развитието в сектора. От модели телевизори 2016 знаем, че много от средният клас LCD телевизори на хартия поддържат HDR, но всъщност не са способни да го направят. Също така, оказва се, че нито един от LCD 2017 телевизорите не е "UHD Premium" сертифициран.
    LCD моделите предлагат максимална яркост, варираща между 350 и 550 CD/m², което означава, че тези телевизори, не отговарят на изискванията за UltraHD Premium сертифициране - 1000 cd/m2, необходими за LCD телевизори. OLED моделите постигат нива на яркост от 950 cd/m² за 55-инчовите модели и дори 1000 cd/m² за 65-инчовият модел, което е впечатляващо за Oled.
    Всички Ultra HD модели имат вградени клиенти за Youtube и Netflix с възможност да възпроизвеждат директно HDR материал от тези стрийминг услуги.
    65EZ1000 може да произведе максимална яркост от 1000cd/m2
    55EZ1000 може да произведе максимална яркост от 950cd/m2
    EX780 може да произведе максимална яркост от 550 cd/m².(Edge Led - Local Dimming + >90% DCI/P3)
    EX730 може да произведе максимална яркост от 350 cd/m².(Edge Led - Local Dimming + >90% DCI/P3)
    EX700 може да произведе максимална яркост от 350 cd/m².(Edge Led - Local Dimming + >90% DCI/P3)
    EX600 може да произведе максимална яркост от 350 cd/m².(Direct Led - Global Dimming)
    За настоящите стандарти това не е нещо особено, и затова ефекта на HDR е много ограничен.
    Media Player
    Вграденият мултимедиен плейър е за снимки, музика и видеоклипове от свързано USB устройство или от мрежата. Повечето телевизори поддържат само DLNA да възпроизвеждане на файлове чрез мрежата, но Panasonic също поддържа и за SMB , така че можете да възпроизвеждате файлове от компютъра си без да се налага да инсталирате DLNA сървър. Много удобно, но за съжаление Panasonic телевизори не поддържат DTS аудио. За DTS лиценз трябва да се плати. В резултат на това много филми се възпроизвеждат без звук, който значително ограничава полезността на мултимедийния плейър.
    За съжаление се натъкнахме на други проблеми при възпроизвеждане на HDR тестов материал. Когато пуснете да възпроизвежда HEVC 4k-филм с малко по-висок битрейт от 100 Mbit/сек, мултимедийния плеър започва да накъсва и забива. Повечето други тазгодишни UHD телевизори възпроизвеждат този тест материал безпроблемно. Също така 4K филми с AVC и около 100 Mbit/сек не вървят гладко. Всички материали с висока разделителна способност вървят добре. Субтитрите се извеждат чисто, като може да се настройва размера и позицията им на екрана.
    Multimedia player in Panasonic TV 2017
    Specifications
    Multimedia
    Series
    EX600/620/630
    Series
    EX700/720/730
    Series
    EX750/780
    EZ900/1000
    Media Gateway / Sources Ethernet (wired) • Wi-Fi (wireless) • USB Port Ethernet (wired) • Wi-Fi (wireless) • USB Port Ethernet (wired) • Wi-Fi (wireless) • USB Port
    video
    • File Extensions: 3G2 • 3GP • ASF • AVI • F4V • FLV • M2TS • M4V • MKV • MOD • MP4 • MPEG • MPG • MTS • TP • TRP • TS • TTS • VOB • VRO • WEBM • WMV 3G2 • 3GP • ASF • AVI • F4V • FLV • M2TS • M4V • MKV • MOD • MP4 • MPEG • MPG • MTS • TP • TRP • TS • TTS • VOB • VRO • WEBM • WMV
    • Formats / Containers: 3GPP • ASF • AVI • FLV • MKV • MP4 • PS • TS • WEBM 3GPP • ASF • AVI • FLV • MKV • MP4 • PS • TS • WEBM
    Codecs : H.264 • H.265 / HEVC • MPEG1 • MPEG2 • MPEG4 • VC-1 • VP9 • WMV9 H.264 • H.265 / HEVC • MPEG1 • MPEG2 • MPEG4 • VC-1 • VP9 • WMV9
    audio
    Codecs : AAC • ADPCM • DOLBY DIGITAL • DOLBY DIGITAL PLUS • HE-AAC • LPCM • MP3 • MPEG AUDIO • VORBIS • WMA • WMA PRO AAC • ADPCM • DOLBY DIGITAL • DOLBY DIGITAL PLUS • HE-AAC • LPCM • MP3 • MPEG AUDIO • VORBIS • WMA • WMA PRO
    • File Extensions: FLAC • M4A • MP3 • WAV • WMA FLAC • M4A • MP3 • WAV • WMA
    • Formats / Containers: AAC • APPLE LOSSLESS • FLAC • LPCM • MP3 • WMA • WMA PRO AAC • APPLE LOSSLESS • FLAC • LPCM • MP3 • WMA • WMA PRO
    • Codecs : AC • APPLE LOSSLESS • FLAC • LPCM • MP3 • WMA • WMA PRO AAC • APPLE LOSSLESS • FLAC • LPCM • MP3 • WMA • WMA PRO
    Images / Photos
    • File Extensions: JPEG • JPG JPEG • JPG
    • Formats: JPEG JPEG
    Subtitles
    • Files: SRT • SUB • TXT SRT • SUB • TXT
    • External Formats: MicroDVD • SubRip • TMPlayer MicroDVD • SubRip • TMPlayer
    Възможности за калибрация
    Високият клас дисплеи на Panasonic винаги са перфектно адаптирани към калибриране на картината.
    В случаят със серии EZ1000, EZ950, EX780, производителят обаче е отишъл още една крачка напред и предоставил достъп до вътрешните 3D LUT таблици в телевизора. Това означава, че можете да програмирате цветовото пространство, което ще ви даде неконвенционално възпроизвеждане на цветовете. Достъпът до 3D LUT масивите обаче е желателен, ако дисплеят ще се използва за филмов монитор или като монитор в студио за пост-продукция. Най-полезни са реализациите на различни цветови пространства. Директно от камерата Rec 709, или Rec.2020. Сега, това ще бъде възможно да се приложи в потребителски дисплей, което вероятно ще го направи добър, колкото професионален дисплей!
    source photo: www.phileweb.com/
    3D LUT (справочни таблици), подобни на тези, използвани от професионалните кино и телевизионни монитори на Panasonic. LUT - това е процес на цифрова обработка при който се създава нужното изображение използвайки карти (банки) експозиции и DK (Digital Knee).
    Освен това, професионалните потребители могат дори да качват свои собствени 3D LUTs от SD карта / USB стик.
    - възможност да заредите потребителска 3D LUT в .cube формат
    - възможност да заредите потребителска 1D LUT
    - YCbCr пълно покритие на обхвата
    - фин контрол на нарастването (стъпка от 0,5) [gain controls]
    - ISF калибрационен контрол
    3D LUT Creator - официальный сайт
    ето как да направите това(пример от форума на италианските ни колеги)
    3D LUT
    Argyll Color Management System Home Page
    Panasonic има традиция от 2013 година в поддръжката на софтуера за калибриране CalMAN (които се използва в ревютата от калибратори).
    Portrait Displays | Software for Displays – Customized for OEM Brands SpectraCal - Display Color Calibration
    ISF Certified Calibration Configuration (3C) | ISF Forum
    За да се случи автоматично калибриране, трябва да има пряк интерфейс между телевизионния екран и лаптопа, известен като Direct Control Display (DDC), която връзка обикновено се провежда през IP или безжично. След като се установи DDC, настройките на картината могат да бъдат направени от лаптопа, без да се налага да отваряте менюто за картината на екрана. Това е изключително полезно, особено за HDR калибриране, тъй като измерванията на по-ярки нива на яркост, няма да се разреждат с наличието менюта или плъзгачи на екрана, което допринася за по-точен резултат. CalMAN не само ще прави автоматично регулиране на цветовите настройки на новите телевизори, но ще добави измервания на цветовият обем към инструментариума.
    Control4 Driver Search
    Тестове
    https://www.avforums.com/review/pana...v-review.13312
    Panasonic TX-65EZ1000 : Test complet - Téléviseur - Les Numériques
    https://www.homecinemamagazine.nl/20...w1004-oled-tv/
    https://tweakers.net/reviews/5409/pa...rote-voet.html
    https://www.homecinemamagazine.nl/20...84-tx-65ex780/
    https://hdtvpolska.com/panasonic-ex7...ltra-hd-z-hdr/
    Panasonic EX700 review - FlatpanelsHD
    Panasonic TX-55EX610E – test telewizora 4K na 2017 rok | rtvManiaK.pl
    Panasonic TX-55EX600 : Test complet - Téléviseur - Les Numériques
    Test Panasonic EX600 (TX-55EX600E) : une TV UHD 4K HDR au bon rapport qualité/prix ?
    Test Panasonic EX780 (TX-58EX780E) : un TV LED 4K HDR pour cinéphiles
    Google превод Fr to Bg
    Този пост е редактиран от hristoslav2; 05-06-17 в 20:38.
    #117
    Отговор: Panasonic телевизори 2017
    Посещение с цел проверка на производствената централа в Япония за производството на Viera 2017.
    パナソニック有機ELテレビは“匠”が作る。ジャパンプレミアムは宇都宮から - AV Watch
    Панасоник представи в Индия прототип на прозрачен телевизор на бъдещето.
    Този пост е редактиран от hristoslav2; 07-06-17 в 23:04.
    #118
    We do a professional, scientific review of the Panasonic EZ1002 (also sold as the EZ1000 series outside the UK in Europe), which is the company's flagship OLED TV for 2017.
    The specific model we tested was the 65-inch Panasonic TX-65EZ1002B.
    - "премиален" дизайн: със странна стойка с нелеп саундбар-прахоуловител и също такъв нелеп "кожен" заден панел.
    - от 4 х HDMI порта 4K@60@10 бит поддържат само първите два. При това отчитайки, че HDMI ARC има на вторият порт, остава само първият. Т.е. свързвате игровата конзола, AV ресивъра и това е всичко, няма къде да свържете плейъра.
    - няма HDR Dolby Vision
    - дълго хвали подобрената обработка "около-черното". Завършва, впрочем, със думите, че Sony с опцията Smooth Gradation прави това по-добре. Интересно какво би казал за madVR с неговите люти алгоритми
    - после казва, че бандинг има при всички и това е нормално и почти незабележимо
    От положителното:
    - точно цветопредаване от кашона, но при това отбелязва, че на техните пресети за HDR10 все пак се е наложило да се калиброва
    - правилен алгоритъм за тонална компресия за HDR10
    - има вкарване на черен кадър, който сваля яркостта до 63 нита на пълен бяло поле и повече или по-малко приемливо мига само в 60Hz. Но все пак отбелязва, че това е най-добрият резултат днес
    - инпут-лаг 25 мс, а ако закопаете пълна хроматчност или BFI - 35 мс
    Този пост е редактиран от hristoslav2; 11-06-17 в 19:10.
    #119
    Panasonic TX-65EX780E: velký 4K LED televizor s krásnými barvami [test]
    positives
    Extremely well-adjusted color image
    + Excellent set color gamut according Rec.709 and Rec2020 / P3
    + Decent spaciousness scenes
    + Decent movement with individual correction (two sliders)
    + Streaming function (TV Anywhere)
    + Quiet, swift, transparent environment
    + Extensive menu
    + Continuous browsing menu
    + Programmable button on the remote control
    + EQ
    + Options subtitles
    + Separate volume control headphone output settings
    + Twin tuners with two CI slots +
    + 3D (for someone)
    + Design
    cons
    - Occasionally plus image noise
    - HDR Edge
    - User nepřívětivost satellite part
    - does not support DTS
    - Average support for multimedia formats (SD / HD) playback via USB
    - Occasional "doubling / blurring" the edges of objects in motion scenes
    - Can not highlight the desired program
    - sound unemotional
    Panasonic EZ1002/ EZ1000 (TX-65EZ1002B) Review
    Conclusion
    The Panasonic TX-65EZ1002B is an excellent OLED television whose key strengths include unrivalled colour accuracy, highly configurable motion sharpening, and the most balanced HDR10 tone-mapping we’ve witnessed on a consumer OLED to date.
    For a number of prospective buyers, one deterrent will be lack of Dolby Vision (DV) support. At this time of publication (June 2017), we haven’t had the opportunity to pit disc-based Dolby Vision content on a DV-capable set against HDR10 on a comparable television, and so don’t know how much of the proprietary technology’s theoretical dynamic metadata advantage will translate into real-world benefits. But the marketing reality is that many consumers who are spending a few grand on a high-end television in 2017 will likely be looking to futureproof their set regardless of whether Dolby Vision takes off or not… sadly it’s become a tickbox exercise. Time will tell.
    In Panasonic’s defence, the EZ1000/ EZ1002 boasts some of the best tone-mapping from HDR10 4K Blu-rays we’ve seen on a consumer TV, striking an impressive balance between retention of bright highlight detail and APL (Average Picture Level) especially for 4000-nit-graded material. And halfway into 2017, HDR10 Ultra HD Blu-rays still far outnumber Dolby Vision ones whose confirmed titles to be released this year can be counted on one hand, including must-have blockbusters such as Despicable Me I and II, The Fate of The Furious, Power Rangers and Resident Evil: Vendetta. Even then, these Dolby Vision 4K Blu-ray discs will still contain a HDR10 base layer, so it’s not as if they cannot be enjoyed in their high dynamic range glory on the Panasonic OLED.
    Another factor that may put many off the TX65EZ1002B is its high price – the 65-incher is at least £2000 more expensive than its closest competitor, the Sony Bravia A1/ A1E. Whether the EZ1002B is worth the price difference depends on how much you value class-leading colour fidelity. You can add a £300 eeColor external 3D LUT box (plus calibration fee) to get the Sony’s colour accuracy to match the Panasonic’s, but the unit only colour-corrects for 1080p SDR, not UHD HDR. To do the latter, you’ll need the Lumagen Radiance 4K Pro series of video processor which retails upwards of £4000, and even then you’ll always be swimming upstream to fight the TV’s internal tone-curve and gamut mapping unless you can disable it completely (which as far as we’re aware the Sony A1 OLED doesn’t allow you to do).
    In other words, the Panasonic EZ1000/ EZ1002 is actually a bargain in relative terms. As long as you get a panel with decent near-black and white uniformity, after calibration the TV could pass for a client reference monitor in a film grading studio. There’s also apparently a user-uploadable 3D LUT (look-up table) function, though unfortunately we didn’t have time during our review period to test it.
    In summary, the 65EZ1002B is a stunning prosumer display with a price to match, a PR-OLEDβ„’. If price is a sticking point, you can wait for Panasonic’s step-down OLED model, the EZ952/ EZ950 series, which hopefully will come close to the performance of the flagship EZ1002/ EZ1000.
    Този пост е редактиран от hristoslav2; 13-06-17 в 22:34.
    Aug 2007
    #120
    Хростослав, Благодаря за клипчето, не разбрах само работи ли с кодирани канали, например ако имам Близу дали ще мога да предам кодираният канал на клиента( другоя тв) ? Имаш ли някаква идея? Иначе взех два ЕХ780 , единият работи, другият дефектира 15 минути след включването, червена лампа мига 10 пъти на определен период от време тия дни ще го нося в сервиза да го видят.
Страница 8 от 16 ПърваПърва ... 678910 ... ПоследноПоследно
  1. Panasonic Plasma телевизори - част 4
    От hristoslav2 във форум Panasonic телевизори
    Отговори: 1733
    Последно: 23-07-25, 14:28
  2. Panasonic 2017 за японския пазар
    Отговори: 14
    Последно: 08-06-19, 14:13
  3. Panasonic телевизори 2016
    От kod във форум Panasonic телевизори
    Отговори: 345
    Последно: 01-01-17, 18:27
  4. Panasonic се отказва от LCD панелите за телевизори
    От bbozhanov във форум Panasonic телевизори
    Последно: 01-06-16, 20:27
  5. Panasonic телевизори 2015
    Отговори: 677
    Последно: 02-01-16, 08:49
