Страница 31 от 76 ПърваПърва ... 21293031323341 ... ПоследноПоследно
Резултати от 451 до 465 от общо 1140
Like Tree162Одобрявам
Philips телевизори (инфо на първа страница)
  1. Member Аватара на JOKVN
    Feb 2012
    #451
    Отговор: Philips телевизори (инфо на първа страница)
    Здравейте,днес се сдобих с един 43PUS8545 ,но не мога никъде да намеря инфо за калибрация на картината.Някой ако може да помогне с инфо,ще съм благодарен.
    #452
    JOKVN
    https://prohardver.hu/teszt/philips_...allitasok.html
    това са настройки за определен източник на сигнал.
    Този пост е редактиран от hristoslav2; 21-11-20 в 00:08.
    JOKVN одобрява това.
    #453
    Philips 55OLED+935 review,calibration
    https://www.avforums.com/reviews/phi...v-review.18144
    Verdict
    With the OLED+935, Philips has set out to create a luxury all-in-one solution and with the results we have seen within our review, they have achieved that goal. The design is stunning with excellent use of materials and it looks good enough to be the centrepiece of any living room.
    The speaker bar looks gorgeous and it sounds superb with music and movies. The new tweeter on top design and drivers all come together to offer a speaker bar that will put most separate soundbars to shame. The Bowers & Wilkins sound DNA is present and correct with stunning music playback with impressive and weighty movies soundtracks. All that is missing is a little more low end for some action movies, but it is easy to add a subwoofer using the RCA pre-out if desired.
    The picture quality is excellent with SDR film and TV content with superb greyscale and colour accuracy out of the box in Movie mode as well as reference calibration results. Films look cinematic and image quality challenges that seen on other brands at this price point. Skintones look lifelike and there is excellent dynamic range and depth to SDR images, with deep blacks and plenty of shadow detail visible.
    HDR content is also excellent with stunning dynamic range, colour accuracy and specular highlight details on display. The tone mapping ensures there is not only visible detail within the specular highlights but just above black shadow details are also present and correct. Motion is also very good with 24fps movie material with no signs of induced judder.
    Images in SDR and HDR are accurate and cinematic in the best settings and of course, if you are not all about the creator’s intent, you can go mad with the picture manipulation controls thanks to the P5 processor. If Vivid mode is your thing, then Philips does it better than any other manufacturer out there.
    Added to the excellent picture and sound performance from the OLED+935 is four-sided Ambilight which we think makes a superb static white bias light that helps to combat eye fatigue in dim room viewing. Plus, just like accurate vs. vivid mode in picture terms, you can also have Ambilight follow the video or audio and create colour changes across the walls behind the set, turning your living room into a nightclub. Ambilight may also help create immersion for gaming on the TV with the lights following the action, but with an input lag of 37ms and no HDMI 2.1, the OLED+935 is perhaps not the strongest choice for gamers.
    The OS and smart TV system is Android TV (9.0) and we found it to be fast and stable throughout our testing period. There is a good choice of apps and terrestrial catch-up services to keep most users happy and the interface is slick and intuitive. Being Dutch, there are also more adult choices available in the app store should you be interested, sir.
    We really think Philips is on a roll at the moment with its TVs and there is no doubt that the OLED+935 easily competes with the LG, Sony and Panasonic models in terms of picture quality and sound system designs. It’s a luxury TV that makes good on its promise of accurate pictures and excellent sound quality and it comes highly recommended!
    Този пост е редактиран от hristoslav2; 04-11-20 в 09:30.
  5. Novice
    Nov 2020
    Плевен
    #454
    Отговор: Philips телевизори 2019
    Здравейте. Купих си телевизор philips 24PFS5535. След сканиране за цифрови и аналогови канали (на кабелна телевизия), цифровите канали ги номерира примерно от 1 до 340, а аналоговите са с някакви четирицифрени номера, например 1378 и т.н.. На телевизор самсунг номерирането на аналоговите канали пак започва от 1 и е много лесно да се прехвърлиш от цифрова на аналогова телевизия. От цифровите бутони на дистанционното избираш същия номер, на който си в момента и вече си в аналоговите. При самсунг лесно избираш аналогов канал директно от цифровите бутони на дистанционното, защото едноцифрени и двуцифрени номера се помнят лесно. Това, което се ориентирах да направя на филипса с аналоговите канали, които ме интересуват е, че ги именувах и в списъка ми излизат с имена, но неудобството си остава, трябва да отварям списъка, не мога директно с цифровите бутони на дистанционното. Та питането ми е има ли начин да се промени номерацията на аналоговите канали и как се преминава от цифрови на аналогови канали на телевизор филипс сравнено със самсунг ?
    Има и друго питане. При самсунговете първоначално цифровите канали ми ги подреждаше по азбучен ред, после кабелната направи така, че да излизат по начин, по който те са ги подредили (тематично). При този филипс нито са по азбучен ред нито тематично. Има ли начин да задам подредбата да е такава както е задала кабелната ?
    Nov 2008
    #455
    Не знам за този модел, но по принцип с Фаворити (Любими) става номера, на майка ми на тв-то (32PFS5803) ги направих тези, които ги гледа в списък и си ги избира с номер. Ама и на нея аналогови не съм ѝ оставил, няма нужда (планът ми е на макс. канали с ка-модул на А1/Близу).
    Не помня за А1 за цифровите и аналоговите, почват от 1 цифровите, аналоговите от 500 или 1000, но аз сканирам само цифрови. Преди държах и аналоговите, че при тях по-бързо се превключва от канал на канал, но бях с HD резолюция, сега аналоговия 480i скалиран до 4К e неприятна гледка.
    Да, и фаворитите може да се пренареждат и преименуват лесно, има дори софтуери, ама няма смисъл играене с флашка и т.н... А1 си ги именува добре.
    Този пост е редактиран от enkov; 05-11-20 в 11:10.
  7. Novice
    Nov 2020
    Плевен
    #456
    Благодаря, получи се. В списъка с предпочитани номерацията започна от 1 и се избират с лекота с цифровите бутони на дистанционното.
    А в какъв ред са цифровите програми при А1, подредбата на А1 или в друг някакъв ред ?
    Този пост е редактиран от daniel16; 05-11-20 в 00:12.
    Feb 2011
    #457
    При сканиране не избирай налични оператори , а други .
    #458
    daniel16
    Защо са ти аналоговите при условие, че имаш цифрови ?
    Върни фабричните и пресканирай на ново само цифровите, като избереш оператор - други.
  11. Novice
    Nov 2020
    Плевен
    #459
    На този кухненски телевизор могат да се гледат основно аналогови и ми трябва да може да се избират лесно
    Благодаря за напътствията, ще направя и пресканирането, за да видя как ще се подредят цифровите. Не съм имал телевизор филипс и ми е интересно да го разуча
    Nov 2008
    #460
    Ясно ни е вече, на кухненския няма CI модул или декодер. Нямаш избор, те отключените цифрови колко са? 2-3 само май. С Фаворити (Любими) и това е.
    И моят 32" е в кухнята, ама му взех модул и си плащам картата на месец, защото иначе си губи идеята от FullHD. И сега се гледат само FHD канали в кухнята.
    Иначе, за подредбата от А1 е, все едно е хвърлял някой зарове. Пълна лотария, губих много време да ги нареждам във Фаворити.
    #461
    Philips 55PUS9435/12
    https://geex.x-kom.pl/recenzje/znami...ips-55pus9435/
    55PUS9435: VA panel
    Direct LED LCD
    Wide Color Gamut
    50/60Hz
    equipped with a soundbar developed in cooperation with Bowers & Wilkins 2.1.2 ,50W
    Dolby Atmos,DTS-HD
    HDR10,HLG,HDR10+,Dolby Vision
    HDMI 2.0b x4
    android tv 9.0
    Ambilight 3+Hue
    Assembled in Poland, by TP Vision
    HDR
    When enjoying HDR content, it is imperative to switch from the default HDR Natural mode , which is too cool, to a better HDR movie . In this mode, on the 10% board, the maximum luminance after three minutes of the measurement was 420 cd / m ^ 2 and it was stable throughout the entire measurement period.
    Summary
    It cannot be denied that Philips has created a unique TV with a combination of features that cannot be found in the competition. High contrast, good color reproduction in the factory settings, good multimedia, Ambilight and unique, definitely above-average sound are features that cannot be ignored.
    Philips 55PUS9435 gave me a lot of fun, because overall it offers more than the sum of its advantages. In my opinion, the combination of a stylish soundbar branded by Bowers & Wilkins, an illuminated remote control with a modern shape, a tasteful box for accessories and the Ambilight system indicates a product with almost luxurious aspirations. Of course, I recommend Philips 55PUS9435, because it is a universal TV, practical and very pleasant in everyday use.
    https://www.youtube.com/watch?v=7VtQ...ture=emb_title
    #462
    Philips: Изявление за текущи проблеми с поточно предаване (резолюция) на телевизори 2017/18
    https://toengel.net/philipsblog/2020...2017-18er-tvs/
    Philips 50pus7805 vs Philips50pus8545.
    Този пост е редактиран от hristoslav2; 15-11-20 в 23:33.
    Oct 2018
    #463
    Тези настройки от prohardver.hu са просто абсурдни, за да са "коректните". Направо съм шокиран, че този, който е писал статията може да го каже. Sharpness на максимум WTF, Color correction на максимум, че то на минимум скапва цветовете, Contrast mode също. Споделям моите настройки на 50" версия на PUS8505, които съм си правил на база вече 2 месеца с телевизора, без техника, но калибирация спрямо телефона ми с OLED (с един от най-високите резултати за точност на картината при телефоните).
    Режим
    ISF Night -
    за максимална точност на цветовете
    Game -
    ако се връзва към компа за игри, както е при мен
    Color - 50, но ако искате малко повече да изпъкват 55 е добър компромис
    Backlight contrast - 95, след това почва малко да изкривява черно/сиво
    Sharpness - от 0 до 2 не повече, аз съм на 2
    Color enchantments - off, всичко друго чупи цветовете
    Color gamut - Normal, защото Wide причинява "червени лица" в повечето случаи
    Color temp - warm
    Whitepoint 2 points - Red 127, Green 117, Blue 117, Red bl -2, Green bl-2, Blue bl +2 получава се приятна палитра, в която бялото е доста добре балансирано, не бие на червено, синьо и т.н. Не мисля, че са перфектно калибирани, но са доста, доста ОК
    Contrast mode - off, иначе чупи жълтото и бие към зелено
    HDR upscaling - ON, мааалко скапва цветовете, но е добър компромис
    Dynamic contrast - off, иначе чупи цветовете
    Video contrast - 85
    Light sensor - off
    Gamma - 0, телевизора има добра Gamma и тази настройка, можете да си а направите спрямо лични предпочитания
    Ultra resolution - on
    Noise red - min, но не повече
    Mpeg artf reduc - min но не повече
    Motion - аз го държа на OFF, или Personal / minimum, по форумите казват, че Pure cinema също е ОК, но като го вържа към компа и мръдна мишката и видя как маже ми става лошо
    Този пост е редактиран от Kratos87; 21-11-20 в 08:03.
    enkov, n1s0 и JOKVN харесват това.
  17. Member Аватара на JOKVN
    Feb 2012
    #464
    Браво колега чудесни настройки,сега ги пробвах и видях много по добра картина сравнение настройките на prohardver.hu.При техните настройки лицата на хората бяха направо морковено червени и едни нереални цветове,бях се притеснил че съм се набутал с модела.
  18. Junior Member
    Feb 2007
    #465
    Здравей те,не мога да изкарам многоканален звук през оптиката на MX Player на58PUS8545/12
  1. Избор на климатик '2019
    Отговори: 3063
    Последно: 04-01-20, 11:11
  2. Philips телевизори 2018
    Отговори: 254
    Последно: 02-01-19, 14:11
  3. Philips телевизори 2017
    Отговори: 279
    Последно: 01-01-18, 07:35
  4. Philips телевизори 2016
    Отговори: 453
    Последно: 01-01-17, 19:22
  5. Philips телевизори 2015
    Отговори: 426
    Последно: 02-01-16, 08:21
