Страница 12 от 150 ПърваПърва ... 210111213142262 ... ПоследноПоследно
Резултати от 166 до 180 от общо 2238
Like Tree569Одобрявам
    #166
    Отговор: TCL телевизори
    TCL shows the first ultra-thin QLED LCD TV with Quantum Dot On Glass...
    https://www.hdblog.it/2019/09/07/tcl...-dot-on-glass/
    TV Series X81,55X815 and 65X815
    The QDOGs integrate the Quantum Dots inside a thin glass plate, a rigid material that therefore does not require a support and also acts as an optical guide. On "traditional" Quantum Dot TVs (in jargon they are called QDEF, Quantum Dot Enhancement Film), a separate plastic material is used which also serves as an optical guide. The main advantage is a reduced thickness due to the simplified internal structure
    source:[hdblog.it],
    Quantum Dot architectures: The horizon comes closer...https://www.displaydaily.com/article...n-comes-closer
    Fig. 1. The quantum dot on glass (QDOG) architecture replaces a plastic light guide plate (LGP) and separate quantum dot enhancement film (QDEF) with a high-stability glass on which the quantum dots are applied directly. (Graphics: Nanosys)
    source:[displaydaily.com]
    TCL 55EC780 преглед
    http://www.hdtv.com.pl/forum/tcl/144...t-otwarty.html
    Assembled in Poland by TCL Polska
    TCL 55EC780 test
    https://hdtvpolska.com/telewizor-tcl...zl/?showfull=1
    55EC780:LCD (with PFS LED backlight) typ. VA,Edge LCD,50/60Hz,WCG,HDR10,HLG,Dolby Vision,HDR 10+,Android tv (9.0 Pie),hands-free voice control.
    Model: BeyondTV
    Brand: TCL
    Board:RTD2851 ,SoC Realtek RTD2851
    Device:BeyondTV
    Hardware:rtd285o
    Platform:rtd285o
    Installed RAM:2048 MB
    Available Memory: 607 MB
    Total capacity of internal memory: 10,10GB
    Free internal memory : 9521 MB
    Total External Memory Capacity : 7664 MB
    Free amount of external memory : 7630 MB
    Bluetooth Version : 4+
    4 x ARM Cortex -A55 @ 1100 MHz
    Instruction set :64 bit ARM v8-A(32 bit mode)
    CPU Cores :4
    CPU Clock Range:700-1100 MHz
    Core 1 Clock:900 MHz
    Core 2 Clock:900 MHz
    Core 3 Clock:900 MHz
    Core 4 Clock:900 MHz
    GPU Vendor:ARM
    GPU Renderer: Mali-470 MP
    Open GL ES Version: 2.0
    Android TV Version : 9 (Pie)
    API Level:28
    ...However, I have attention related to sharpness, which does not come directly from the processing systems, but from the matrix control algorithm. The TV uses spatial dithering, which is (probably) to improve viewing angles. This involves generating a single color by two adjacent pixels instead of each pixel separately. For example, to generate yellow, one pixel has only the green subpixel lit and the other pixel has only the red. In a classic matrix both of these subpixels would burn in both pixels. This is illustrated by the photo below under a microscope.
    Matrix with spatial dithering
    Classic matrix
    What are the consequences of this method? First of all, worse readability of image details. The image loses resolution on colored objects. The loss is noticeable primarily from close range. With this type of matrix control one could argue whether the TV can be qualified as full 4K. While according to the ICDM and ISO standards, the criteria will be met (since these standards are based on contrast modulation between pixels), so according to CTA will be a problem because the definition is:
    Physical pixels shall be individually addressable such that the horizontal and vertical resolution above can be demonstrated over the full range of colors provided by the display.
    The underlined part of the quote speaks of individually addressed pixels in the entire color rank. In TCL EC78 and definitely not all colors can be addressed pixels, as evidenced by the photo below:
    TCL EC780
    Other tv no dithering
    However, if we are talking about resolution and seeing details, remember that you have to sit close enough to the screen to appreciate the virtues of the larger number of pixels on the screen.
    One thing caught my attention. I don't know why the manufacturer has implemented a non-switchable dimmer matrix in scenes where there is a lot of black. Of course, such a procedure is to deceive the user's eyesight, but it should be adjustable or blocked completely. In EC78 it is definitely too aggressive. As a result, in the test shot from the movie "Oblivion" the brightness of white dropped to an extremely low brightness of 15 nits! Black was like tar, but the picture was much worse because of its brightness. After lighting a small light in the room, I saw myself more in the reflection of the matrix than the actual image:
    Aggressive darkening of the image means that you can clearly see reflecting objects in the matrix.
    Viewing angles :
    VA matrices used in televisions generally do not provide good viewing angles, especially in the case of televisions with specialized backlighting (which extends the color palette). The TCL EC78 actually uses the spatial dithering technique that improves angles at the expense of resolution and which I described in the paragraphs above. Unfortunately, it does not bring tangible results. Colors warp quickly even from a small angle of view.
    SOC Realtek
    https://www.realtek.com/en/press-roo...ns-at-2019-ces
    Този пост е редактиран от hristoslav2; 23-12-19 в 12:43.
    #167
    И тия почнаха с номерата - ако така ще я карат сите ...ще си гледаме старите тв .
    #168
    произвеждат се в Полша
    TCL Operations Polska sp. Z o. o. zak
    Как се разчита моделният суфикс ?
    Пример - U55EC780B
    U - резолюция
    • U - Ultra HD (3840 x 2160)
    • F - Full HD (1920 x 1080)
    • H - HD Ready (1366 x 768)
    65 - диагонал в инчове
    ЕC78 - серия ()
    • EC78 -
    • EP68 -
    • EP66 -
    • EP64 -
    • ES56 -
    0 - дизайн
    B - цвят на корпуса
    • B - черен
    • W - бял
    • S - сребрист
    • DS - тъмно сив
    https://tweakers.net/i/K6ekDEnRW7a-i...002687656.jpeg
    Таблица модели 2019
    TCL TV 2019 - European models
    OS Android 9.0 (Pie) --
    Class & type Premium LCD Step-up LCD Standard LCD Base LCD
    Series
    __________________
    X10S
    ________________
    X10
    ___________________________
    EC78
    EP68
    ________________
    EP66
    ________________
    EP64
    ________________
    DC60
    ________________
    DP60
    ________________
    ES560
    ________________
    DS5
    ________________
    DTV
    ________________
    Models
    75X10S 65X10
    55X10
    65EC780
    55EC780
    65EP68
    55EP680
    50EP680
    75EP660
    65EP660
    60EP660
    55EP660
    50EP660
    43EP660
    65EP640
    55EP640
    50EP640
    43EP640
    -- 65DP600
    55DP600
    50DP600
    49DP600
    43DP600
    40EP560
    32EP560
    ---- --- Октомври 2019 Ноември 2019 Май 2019 Май 2019 Май 2019 2019 2018 --- -- --
    Display
    Resolution 768 x 4320 3840 x 2160 3840 x 2160 3840 x 2160 3840 x 2160 3840 x 2160 3840 й 2160 3840 x 2160 40" - 1920 x 1080
    32" - 1366 x 768
    Panel -- QLED LCD 10-bit
    100 Hz
    LCD 8-bit + FRC
    Edge LED, 50 Hz
    55" - MVA
    LCD 8-bit + FRC
    50 Hz
    LCD 8-bit + FRC
    50 Hz
    LCD 8-bit + FRC
    50 Hz
    LCD 8-bit LCD 8-bit + FRC
    50 Hz
    65" - MVA
    LCD 8-bit
    50 Hz
    Brightness -- 65" - 1500 nits 65" -
    55" - 400 nits
    65" - 320 nits
    55" - 350 nits
    50" - 380 nits
    75" - 290 nits
    65" - 280 nits
    55" - 260 nits
    50, 43" - 270 nits
    HDR HDR10, HDR10+, Dolby Vision, HLG HDR10, HDR10+, Dolby Vision, HLG HDR10, HDR10+, Dolby Vision, HLG HDR10, HDR10+, Dolby Vision, HLG HDR10, HLG HDR10, HLG -- HDR10, HLG HDR10 -- --
    Wide Color Gammut -- -- No Yes Yes - -- No No -- --
    Dimming -- 65" - 768 zones ? Pro ? Frame Dimming - -- Frame Dimming No -- --
    Processor / Remote control
    SOC
    CPU Cores
    Instruction Set
    GPU
    RAM
    достъпна памет
    4x ARM Cortex A55@11000MHz
    Realtek 2851
    4x ARM Cortex A55@1100MHz
    ARM Mali 470 MP
    16GB / 10GB
    664MB
    Realtek
    Quad Core
    16GB / 10GB
    Realtek
    Quad Core
    16GB / 10GB
    Realtek
    Quad core
    Mstar MSD6586
    2 x Cortex A9
    Mali 400 MP2
    1 GB
    Realtek
    Quad core
    8GB / 4GB
    Remote control --- RC602S6 - Bluetooth
    RC802N6
    RC602S6 - Bluetooth
    RC802N6
    RC802V4
    RC802N4
    RC802N4 RC802N4 -- --- --- -- --
    Audio
    Audio -- Dolby Atmos
    Dolby Surround
    Dolby Atmos
    Dolby AC4
    Dolby Atmos
    Dolby True HD
    Dolby AC4
    Dolby AC4
    Dolby Audio
    Dolby AC4
    Dolby Digital +
    -- Dolby Digital +
    Dolby Audio
    Dolby Digital +
    Dolby Audio
    Sound -- ONKYO 2 x 10W
    2 x 15W
    ONKYO 2 x 15W
    2 x 10 W 2 x 10 W 2 x 8 W -- 2 x 8 W 40" - 2 x 8 W
    32" - 2 x 5 W
    Woofer -- No No No No No -- No No -- --
    Equaliser -- Yes Yes Yes Yes Yes -- Yes No -- --
    Tuner / Broadcasting
    Digital tuner -- T2/C/S2 T2/C/S2 T2/C/S2 T2/C/S2 T2/C/S2 -- T2/C/S2 T2/C/S2 -- --
    Teletext -- Yes Yes Yes Yes Yes -- Yes Yes -- --
    EPG -- up to 8-days up to 8-days up to 8-days up to 8-days up to 8-days -- up to 8-days up to 8-days -- --
    Smart TV
    Web Brouser -- Yes Yes Yes Yes Yes -- Yes Yes -- --
    HBBTV -- 2.0.1 2.0.1 2.0.1 2.0.1 2.0.1 -- 2.0.1 1.5 -- --
    Smart TV -- Android TV Android TV Android TV Android TV Android TV -- Linyx OS 3.0 Android TV -- --
    Applications -- Google Play Store Google Play Store Google Play Store Google Play Store Google Play Store -- Yes Google Play Store -- --
    4K -- -- Netflix, You Tube & more Netflix, You Tube & more Netflix, You Tube & more Netflix, YouTube & more -- Netflix, You Tube ? -- --
    Android OS -- 9.0 Pie 9.0 Pie 9.0 Pie 9.0 Pie 9.0 Pie -- No 9.0 Pie -- --
    Smart Home -- Google Home Google Home Google Home Google Home -- -- No Google Home -- --
    AL Google Assistant -- -- Far Field Ready Far Field Ready Far Field Ready Far Field ready -- No Ready -- --
    Al Amazon Alexa -- -- Works with Alexa Works with Alexa Works with Alexa Works with Alexa -- Works with Alexa No -- --
    Voice Search -- Built in TV and RC Built in RC Built in RC Ready Ready -- No Ready -- --
    Convergence
    Sleep Timer Yes Yes Yes Yes Yes -- -- Yes Yes -- --
    PIP / PAT -- -- - / - Yes / Yes Yes / Yes --/ Yes -- No / - No / - -- --
    Bluetooth -- -- A2DP, HID A2DP, HID A2DP, HID A2DP, HID -- No No -- --
    DLNA 1.5 -- -- Yes Yes Yes Yes -- Yes Yes -- --
    Wi-Fi Direct (Miracast) -- Yes Chromecast & T-cast Chromecast & T-cast Chromecast & T-cast Chromecast & T-cast -- T-cast Chromecast & T-cast -- --
    USB HID support -- -- Yes Yes Yes Yes -- Yes Yes -- --
    User Convenience & Connectivity
    USB Multimedia -- -- Video up to 4K: AVI, WMV, MP4, MPG, TS, MKV, WebM, VP9,
    Audio: WMA, MP3, Pictures: HEIF, JPG, PNG, BMP, Text subtitles
    -- -- Video up to 4K: AVI, MP4, MPG, TS, MKV, WebM, Audio: MP3, Pictures: JPG, PNG, BMP, Text subtitles Video up to 1080P: AVI, WMV, MP4, MPG, TS, MKV, OGM, Audio: WMA, MP3, Pictures: JPG, PNG, BMP, Text subtitles -- --
    Caption (Subtitle) -- Yes Yes Yes Yes -- -- Yes Yes -- --
    Game mode -- -- Yes Yes Yes -- -- Yes Yes -- --
    USB channel list clone -- -- Yes Yes Yes -- -- Yes Yes -- --
    HDMI -- -- 3 x 2.0b 3 x 2.0b 3 x 2.0b 3 x 2.0b -- 3 x 2.0b 2 x 1.4 -- --
    HDCP 2.2 All HDMI All HDMI All HDMI All HDMI All HDMI All HDMI -- All HDMI No -- --
    USB -- -- 2 x 2.0 2 x 2.0 2 x 2.0 2 x 2.0 -- 2 x 2.0 1 x 2.0 -- --
    YUV+Composite -- -- No Yes Yes Yes -- No No -- --
    Ethernet (LAN RJ-45) Yes Yes Yes Yes Yes Yes -- Yes Yes -- --
    Wi-Fi 802.11 ac/b/g/n 802.11 ac/b/g/n 802.11 ac/b/g/n 802.11 b/g/n 802.11 b/g/n 202.11 b/g/n -- 802.11 b/g/n 802.11 b/g/n -- --
    Digital Audio Out -- -- Optical Optical Optical Optical -- Optical -- -- --
    Headphone -- -- Yes Yes Yes Yes -- Yes Yes -- --
    RF in Terestrial / Sat Yes / Yes Yes / Yes Yes / Yes Yes / Yes Yes / yes Yes / Yes -- Yes / yes Yes / Yes -- --
    Sat: Diseq / SCD Yes 2.0 / Yes Yes 2.0 / Yes Yes 2.0 / Yes Yes 2.2 / Yes Yes 2.2 / Yes Yes v.2.2 / Yes -- Yes v. 1.0 / No Yes v. 1.0 / No -- --
    HDMI ARC -- -- via HDMI 1 via HDMI 1 via HDMI 1 via HDMI 1 -- via HDMI 3 via HDMI 1 -- --
    HDMI max resolution -- -- 2160P/60Hz 12bit 2160P/60Hz 12bit 2160P/60Hz 12bit 2160P/60Hz 12bit -- 2160P/60Hz 12bit 1080P/60Hz -- --
    MHL -- -- Yes (3.0) via HDMI 1 Yes (3.0) via HDMI 1 Yes (3.0) via HDMI 1 Yes (3.0) via HDMI1 -- No No -- --
    Series
    S10X
    ________________
    S10X
    ________________
    EC78
    ________________
    EP68
    ________________
    EP66
    ________________
    EP64
    ________________
    DP6C
    ________________
    DP60
    ________________
    ES560
    ________________
    DS5
    ________________
    DTV
    ________________
    * Google Assistant не е наличен на някои езици и в някои страни. Google Assistant изисква връзка с интернет / трансфер на данни.
    * Съвместимостта на Alexa ви позволява да използвате устройства Amazon Alexa, включително Amazon Echo, Echo Dot, Echo Show, Echo Spot и Echo Plus (закупени отделно) за управление на телевизора
    https://forum.xda-developers.com/and...3559227/page16
    Има ли начин да се инсталира читав браузър или друго приложение.
    https://tv.aptoide.com/
    Сваляте файла от линка,качвате го на флашка и я поставяте в телевизора,отваряте Es file explorer или друг файлменаджер който ползвате и чрез него виждате APK файла на флашката,кликвате на него, давате му install и това е всичко...
    Друг начин за инсталиране на приложения е този вид сайтове - Apk downloader. Копира се линка на избрано приложение от Play Store и чрез въпросния сайт се изтегля апк файла на флашка и се инсталира чрез файлменаджер (примерно X-plore) на телевизора.
    http://4pda.ru/forum/index.php?showtopic=767233&st=0
    Този пост е редактиран от hristoslav2; 25-12-19 в 19:30.
    Nov 2017
    #169
    Хора сигурни ли сте че LAN е само 100мбита а не 1000? След като USB е само версия 2.0 то не виждам как ще гледам 4к видео файлове с 400-500мбит ако лана е 100 мегабитов (освен през HDMI с компютър). Днес си поръчах 50EP660 , но се чудя дали да не го откажа с този остарял LAN. Дали няма да стане ако сложа USB лан карта (все пак е андроид), като така ще имам възможно най голяма скорост към моят NAS сървър?
    Този пост е редактиран от stanchobs; 22-12-19 в 20:01.
    #170
    Няма модел телевизор с гигабитов лан порт.
    Nov 2017
    #171
    За мен не е проблем да си пускам през HDMI филми от компютъра и да ги гледам , но телевизора ще го ползват родителите ми и не искам да ги мъча с такива сложни за тях неща. За това търсих нещо по практично , но поръчах преди да проуча тези неща със лан картата. Исках да е просто като си отворят плеъра от андроида и да си пуснат филмчето през мрежата и да си имат звук без да пипат каквито и да е настройки - като за индианци направено, но както и да е вече е поръчано и трябва да търся други лесни начини. Гледах в нета че старите модели на TCL поддържат LAN през USB и защо пък и по новите да не могат. Това ми даде малко надежда че ще стане както съм си го мислил, защото USB 2.0 поддържа до 480mbit което мен донякъде ме устройва. Не искам да купувам външни HDMI андроид тв боксове с гигабитов ЛАН, защото пак става сложно и с тях
    Този пост е редактиран от stanchobs; 22-12-19 в 20:18.
    #172
    ТВ с USB 2.0 нямат никакви проблеми с гледането на УХД филми/файлове от външен ХДД/флашка.
    Nov 2017
    #173
    Те нямат проблеми , но то е смешно в 2020 година да си прехвърлям филм на флашка/HDD от NAS за да го гледам нa TV, защото разбираш ли една гигабитова лан карта струва 10-15 лева и тези производителите им се свидят и слагат по 5 лева остарял чип ...
    #174
    Ми те май всички са с 100мбита , което не пречи на хората да си гледат по ЛАН. Трябва да е някой файл с твърде голям битрейт, за да има проблеми, в такъв случай и от ХДД е много вероятно да има проблеми, плеърите на тв не поддържат кой знае колко голям битрейт.
    Nov 2017
    #175
    Ще пробвам с USB 1000мбитова LAN карта да видя до колко голям битрейт ще ме пусне нормално да гледам филм, но ще мога да тествам чак когато пристигнат нещата другата седмица и ще пиша тук да си знаят хората ако имат сходни проблеми като моите или пък ако някой има такава лан карта да пробва преди мен и да сподели.
    #176
    По-голям проблем са им мижавия хардуер/процесори в Андроид моделите (не че и другите са много по-добре) - тия дето обикновено ги ползват не съм ги виждал и в телефони за 50$
    Nov 2017
    #177
    Ето този филм е най пресен пример The.Witcher.2019.S01E01.WEB-DL.2160p който искам да гледам на телевизора без компютър, а той ако тръгне от USB входа значи съм на прав път да си взимам усб лан картата, защото ме съмнява да тръгне от вградения лан или wifi.
    Този пост е редактиран от stanchobs; 22-12-19 в 21:43.
    #178
    Няма начин да не върви или ако има проблем, то не се дължи на стандарта ЮСБ/носител, а на софтуера в тв - поне в Андроид имаш варианти за други плеъри.
    п.п. на Самсунг-а ми (дето и те са само с USB2.0 от няколко години) всичко си тръгва пускал съм и БД от стрийм папката .
  17. Тук е от
    Nov 2017
    #179
    Сега си направих един малък тест и сложих старият 10/100 мбитов суич за да емулирам такава лан карта и филма тръгна без проблеми. Явно ще се кара така заводско телевизора като дойде, а аз си мислих че нищо няма да върви като хората грешката е била в мен и все пак мисля да си взема и външната лан карта за по голяма скорост, ако вземе някъде да спича телевизора.
    Mar 2008
    #180
    аз пак не разбрах - TCL 50EP660 колко херца е?
    има ли Time Shift
    и има ли по-добра алтернатива на пазара?
    Този пост е редактиран от apmil4ev; 23-12-19 в 11:23.
  1. VOX телевизори
    Последно: 26-06-23, 11:46
  2. Телевизори DSM, NEO?
    Последно: 19-01-16, 23:27
  3. телевизори
    Последно: 31-08-12, 07:46
  4. 3d Телевизори
    Последно: 18-12-11, 16:06
  5. 3д телевизори на LG
    Последно: 10-10-11, 21:39
