Series | L9 | L7 | L6 | T5 | L5 | L35 | L25 | W25 | L15 | W15 | D15 | Series |
Models | | | | | | 48L3553
40L3533 | 50L2556
50L2546
40L2556
40L2546 | | 48L1533
48L1531
40L1544
40L1534
40L1533
40L1531
32L1544
32L1533 | 32W1534
32W1534 | 24D1533
24D1534 | Models |
Design |
Color | | | | | | Matt black bezel with titanium deco and titanium frame stand | | | | Matt black bezel with black stand | Matt black bezel with black trim and slant mold black stand | Color of TV |
- | | | | | | | | | | | | Color of stand |
Display |
Type screen | | | | | | Flat | Flat | | | Flat | Flat | Type screen |
Size (inches) | | | | | | 40, 48 | 40, 50 | | 32, 40, 48 | 32 | 24 | Size (inches) |
Resolution | | | | | | FullHD | FullHD | FullHD | FullHD | FullHD | HD Ready | Resolution |
Type matrix | | | | | | VA | VA | | VA | | VA | Type matrix |
Local Dimming | | | | | | No | No | | - | - | - | Local Dimming |
Backlight | | | | | | Edge Led | Edge Led | | Direct Led | | Edge Led | Backlight |
Native Contrast | | | | | | 48" - 4000
40" - 3500 | | | 40" - 4000 | | 24" - 3000 | Native Contrast |
Dynamic contrast | | | | | | 48" - 27000
40" - 25000 | | | 40" - 22000 | | 24" - 18000 | Dynamic Contrast |
Panel frequency | | | | | | 50Hz | 50Hz | 50Hz | 50Hz | 50Hz | 50Hz | Panel frequency |
AMR | | | | | | AMR+ 200 | | | AMR+100 | AMR+100 | AMR+100 | AMR |
----- | | | | | | | | | | | | --n |
DCI Color Space | | | | | | - | - | - | - | - | - | DCI Color Space in |
(High Dinamic Range) | | | | | | - | - | - | - | - | No | (High Dinamic Range) |
Certificate | | | | | | - | - | - | - | - | - | Certificate |
Picture Mode: | | | | | | Dynamic
Game
User | | | Dynamic
Game
PC
User | | Dynamic
Game
PC
User | Picture Mode: |
Others | | | | | | Active Backlight Control
Colour Temperature selectable
Manual picture size select | | | Active Backlight Control
Manual picture size select | | DVD Player (built-in)
DVD Region : 2
DVD+/-R/RW / Audio CD / VCD 2.0 / SVCD / MP3 / JPEG (from CD/DVD disc) : Y/Y/N/N/Y/Y | Others |
Audio |
Dolby & DTS | | | | | | | Dolby Digital Plus
DTS 2.0 + Digital out | | Dolby Digital Plus | | Dolby Digital Plus | Dolby & DTS |
Speakers | | | | | | | Bass Boost
40" - Sound Output (RMS) W : 2 x 7W | | Sound Output (RMS) W : 2X8W | | Sound Output (RMS) W : 2x2,5W | Speakers |
Tuners |
DVB | | | | | | DVB-T/C/S/S2 | DVB-T/C/S/S2 | | DVB-T/C/S/S2 | DVB-T/C/S/S2 | DVB-T/C | DVB |
USB Features |
Picture | | | | | | JPEG Base / JPEG Progressive, BMP | | | JPEG Base / JPEG Progressive, BMP | | JPEG Base / JPEG Progressive, BMP | Picture |
Audio | | | | | | MPEG1 layer 2 MP3, MPEG1 layer 3 MP3, AC3, ASF, LPCM*, IMA-ADPCM/MS-ADPCM*, LBR** video files only | | | MPEG1 layer 2 MP3, MPEG1 layer 3 MP3, AC3, ASF, LPCM*, IMA-ADPCM/MS-ADPCM*, LBR** video files only | | MPEG1 layer 2 MP3, MPEG1 layer 3 MP3, AC3, ASF, LPCM*, IMA-ADPCM/MS-ADPCM*, LBR* | Audio |
Video | | | | | | MPEG1 layer 2 MP3, MPEG1 layer 3 MP3, AC3, ASF, LPCM*, IMA-ADPCM/MS-ADPCM*, LBR** video files only | | | MPEG1 layer 2 MP3, MPEG1 layer 3 MP3, AC3, ASF, LPCM*, IMA-ADPCM/MS-ADPCM*, LBR** video files only | | MPEG1 layer 2 MP3, MPEG1 layer 3 MP3, AC3, ASF, LPCM*, IMA-ADPCM/MS-ADPCM*, LBR* | Video |
Smart TV |
Smart | | | | | | PVR Record (to external USB storage device)
PVR Record with Time Shift
Wi-Fi® (Built-in)
DLNA
Smart TV
Open Browser | | | | | No | Smart |
Other Features |
--- | | | | | | Timer
Panel Lock
Auto Format
No Signal Off | Freeze Screen
Timer
Panel Lock
Auto Format
4:3 stretch
No Signal Off | | Timer
Panel Lock
Auto Format
Panel Lock
Auto Format
No Signal Off | --- |
Interface |
HDMI | | | | | | (back) : 3 | (back) : 1
(side) : 1 | | (back) : 2 | | (back) : 1 | HDMI |
USB | | | | | | 2 | 1 | | 1 | | 1 | USB |
Component | | | | | | Yes (3mm jack) | yes | | Yes (via VGA) | | Yes (via VGA) | Component |
Composite | | | | | | Yes (3mm jack) | yes | | Yes (3mm jack) | | Yes (side AV) | Composite video |
3.5mm Composite Adapter | | | | | | | | | | | | 3.5mm Composite Adapter |
Scart | | | | | | | Full RGB | | 1 (FULL RGB) | | 1 (FULL RGB) | Scart |
S-Video | | | | | | Yes via SCART | | | Yes via SCART | | Yes via SCART | S-video |
Digital Audio Out | | | | | | Coaxial | yes | | Coaxial | | Coaxial | Digital Audio Out |
Headphone | | | | | | yes | yes | | yes | | yes | headphone |
PC Input | | | | | | yes | Yes | | yes | | yes | PC Input |
Series | L9 | L7 | L6 | T5 | L5 | L3 | L2 | W2 | L1 | W1 | D1 | Series |
