Страница 2 от 2 ПърваПърва 12
Резултати от 16 до 20 от общо 20
Бавене на Windows при отваряне на приложение
  1. Moderator
    Mar 2005
    #16
    Re: Бавене на Windows при отваряне на приложение
    А можеш ли да погледнеш датата и размера на файла rundll32.exe ?
    При мен
    rundll32.exe е с размер 33К (33 280)
    и с някаква стара дата 04.08.2004
    А като цъкна Properties/Version, виждам
    File Version: 5.1.2600.2180
    Oct 2003
    #17
    Julian, я виж при теб как са.
    Код:
    Windows Registry Editor Version 5.00
    [HKEY_CLASSES_ROOT\*]
    "QuickTip"="prop:Type;Size;Write"
    "InfoTip"="prop:Type;DocAuthor;DocTitle;DocSubject;DocComments;Write;Size"
    "AlwaysShowExt"=""
    "TileInfo"="prop:Type;Size"
    [HKEY_CLASSES_ROOT\*\OpenWithList]
    [HKEY_CLASSES_ROOT\*\OpenWithList\Excel.exe]
    [HKEY_CLASSES_ROOT\*\OpenWithList\IExplore.exe]
    [HKEY_CLASSES_ROOT\*\OpenWithList\MSPaint.exe]
    [HKEY_CLASSES_ROOT\*\OpenWithList\Notepad.exe]
    [HKEY_CLASSES_ROOT\*\OpenWithList\Winword.exe]
    [HKEY_CLASSES_ROOT\*\OpenWithList\WordPad.exe]
    [HKEY_CLASSES_ROOT\*\shellex]
    [HKEY_CLASSES_ROOT\*\shellex\ContextMenuHandlers]
    [HKEY_CLASSES_ROOT\*\shellex\ContextMenuHandlers\Offline Files]
    @="{750fdf0e-2a26-11d1-a3ea-080036587f03}"
    [HKEY_CLASSES_ROOT\*\shellex\ContextMenuHandlers\Open With]
    @="{09799AFB-AD67-11d1-ABCD-00C04FC30936}"
    [HKEY_CLASSES_ROOT\*\shellex\ContextMenuHandlers\Open With EncryptionMenu]
    @="{A470F8CF-A1E8-4f65-8335-227475AA5C46}"
    [HKEY_CLASSES_ROOT\*\shellex\ContextMenuHandlers\WinRAR]
    @="{B41DB860-8EE4-11D2-9906-E49FADC173CA}"
    [HKEY_CLASSES_ROOT\*\shellex\ContextMenuHandlers\{a2a9545d-a0c2-42b4-9708-a0b2badd77c8}]
    @="Start Menu Pin"
    [HKEY_CLASSES_ROOT\*\shellex\PropertySheetHandlers]
    [HKEY_CLASSES_ROOT\*\shellex\PropertySheetHandlers\CryptoSignMenu]
    @="{7444C719-39BF-11D1-8CD9-00C04FC29D45}"
    [HKEY_CLASSES_ROOT\*\shellex\PropertySheetHandlers\{1F2E5C40-9550-11CE-99D2-00AA006E086C}]
    [HKEY_CLASSES_ROOT\*\shellex\PropertySheetHandlers\{3EA48300-8CF6-101B-84FB-666CCB9BCD32}]
    [HKEY_CLASSES_ROOT\*\shellex\PropertySheetHandlers\{883373C3-BF89-11D1-BE35-080036B11A03}]
    @="Summary Properties Page"
    Apr 2002
    #18
    Има един сигурен начин да изловиш какво се случва:
    Sysinternals =>Filemonitor, Process Monitor, Reg Monitor както и TCP view
    Пробвай с всяка една поотделно и виж какво причинява забявянето
    Sep 2003
    #19
    Цитат Първоначално публикувано от Riki888
    5. Не се занимавай със глупости ами си запази информацията от компютъра и го клонирай отново
    Това и направих в крайна сметка, след като така и не успях да намеря причината за забавянето, а и нямах наистина много време да губя.
    Благодаря на всички, взели отношение по темата.
    Apr 2006
    #20
    защо не видиш макрос настройките - намират се в туулс -> секюрити
    смъкни на лоу и кажи как е
    от личен опит!
  1. Приложение bulgarian keyboard
    От pilot във форум Мобилни устройства
    Последно: 24-04-13, 22:17
  2. Бавене при нов лаптоп !!
    От cveteca във форум Общ - софтуер
    Отговори: 23
    Последно: 02-05-12, 00:39
  3. Отговори: 2
    Последно: 21-12-08, 19:23
  4. Има ли simbian приложение антирадар??????
    От SX1 във форум Смартфони, телефони
    Отговори: 21
    Последно: 04-11-04, 18:39
  5. UPS за нестандартно приложение
    От pland във форум Дъра-Бъра
    Последно: 26-09-04, 19:06
