Страница 6 от 12 ПърваПърва ... 45678 ... ПоследноПоследно
Резултати от 76 до 90 от общо 172
Like Tree20Одобрявам
Ariston Kyris Net 35
    Dec 2024
    #76
    Отговор: Ariston Kyris Net 35
    Аз накарах AI да ги сравни в една таблица...
    Parameter Tj / Condition MIDEA Oasis Plus Ariston KYRIS NET R32 35
    Model MOX330-12HFN8-QRE1GW / MSOPBU-12HRFN8-QRE1GW KYRIS NET R32 35
    Refrigerant R32 R32
    Refrigerant charge 1.10 kg 1.10 kg
    Power supply 1×230 V 50 Hz 1×230 V 50 Hz
    Cooling capacity A35/A27 3.50 kW 3.52 kW
    Cooling electrical input A35/A27 0.76 kW 0.75 kW
    EER A35/A27 4.60 4.70
    Heating capacity A7/A20 3.80 kW 3.81 kW
    Heating electrical input A7/A20 0.86 kW 0.77 kW
    COP A7/A20 4.40 4.94
    Cooling Pdesignc 3.50 kW 3.50 kW
    Cooling SEER 9.20 9.20
    Cooling energy class A+++
    Pdc Tj = 35°C 3.50 kW 3.51 kW
    EER Tj = 35°C 4.60 4.61
    Cdc Tj = 35°C 0.250
    Pdc Tj = 30°C 2.35 kW 2.55 kW
    EER Tj = 30°C 7.20 7.10
    Cdc Tj = 30°C 0.250
    Pdc Tj = 25°C 1.59 kW 1.61 kW
    EER Tj = 25°C 11.30 11.32
    Cdc Tj = 25°C 0.250
    Pdc Tj = 20°C 1.56 kW 1.54 kW
    EER Tj = 20°C 15.20 15.20
    Cdc Tj = 20°C 0.250
    Qce Annual 133 kWh 133 kWh
    Pdesignh 2.90 kW 2.90 kW
    SCOP 5.10 5.10
    Heating energy class A+++
    Pdh Tj = −7°C 2.57 kW 2.58 kW
    COP Tj = −7°C 3.58 3.48
    Pdh Tj = +2°C 1.58 kW 1.64 kW
    COP Tj = +2°C 5.02 5.11
    Pdh Tj = +7°C 1.02 kW 1.05 kW
    COP Tj = +7°C 6.60 6.56
    Pdh Tj = +12°C 1.15 kW 1.23 kW
    COP Tj = +12°C 7.50 7.51
    Pdh Tj = Tbiv 2.57 kW 2.58 kW
    COP Tj = Tbiv 3.58 3.48
    Tbiv −7°C −7°C
    Pdh Tj = TOL 2.68 kW 2.69 kW
    COP Tj = TOL 2.90 2.91
    TOL −10°C −15°C
    Qhe Annual 796 kWh 796 kWh
    Indoor sound power 60 dB(A) 59 dB(A)
    Outdoor sound power 63 dB(A) 61 dB(A)
    Standby power Cooling 1 W 1 W
    Off power Cooling 1 W 1 W
    Thermostat-off power Cooling 12 W 11 W
    Crankcase heater Cooling 0 W 0 W
    Standby power Heating 1 W 1 W
    Off power Heating 1 W 1 W
    Thermostat-off power Heating 19 W 10 W
    Crankcase heater Heating 0 W 1 W
    Backup heater 0.16 kW
    Mar 2010
    #77
    Интересно, Мидеята няма нагревателя и са я дали -10, а това явно заради нагревателя -15, но пък Мидеята дава малко по-добри показатели, явно пак заради нагревателя. В интерес на истината, на хартия са им добри показателите, поне за парите си. Не са уау, но за среден клас, според мен биват.
    Dec 2024
    #78
    Те са тествани на различни места, но по един стандард и са почти едно към едно. На едното място просто не дават колко е нагревателят, като може би и Мидеята е измерен на -15гр, но са допуснали грешка на сайта. А част от данните са обявените от производителя/марката.
    Aug 2011
    #79
    Мидея имат и по екстремен климатик от въпросния Оазис на същата цена https://kaisai-bulgaria.com/product/...nrhi-knp12nrho
    Dec 2024
    #80
    Този Kaisai е същото нещо като Аристона, иначе Midea Oasis в БГ е по-слаба версия на Oasis-а от таблицата по-горе.
    Sep 2018
    Хюстън
    #81
    А излишните дефрости на Мидейката под 0-та,колко време продължават и на колко често са?
    Dec 2024
    #82
    Зависи от условията и някъде може би ще се наложи пипане под капака, но пък с този хардуер ще има възможност да се измъква по-бързо от дефростите, като зависи и на каква мощност работи по време на размразяване.
    #83
    Цитат Първоначално публикувано от HiDefinition Виж публикацията
    не по често от на 3-4 пъти по скъпия ME LN
    Dec 2024
    #84
    От което следва че и двете марки са насочени към do-it-yourself потребители, а който не иска да си цапа ръчичките, просто избира Старлайт
    Sep 2018
    Хюстън
    #85
    Въпроса ми беше сериозен не с цел СПАМ Alexi по отговора ти предполагам на 2.5 часа, по 5-7мин?
    Mar 2010
    #86
    Dec 2024
    #87
    HiDefinition, и аз не се шегувах, нали се пише че при TCL не са толкова чести дефростите.
    Разбира се, че ще е двойнороторен, само дето тук са сложили уж по-премиум четирипътен вентил от Мидеята
    Иначе съществуват и двойнороторни компресори само с една входяща тръба.
    Този пост е редактиран от casal; 17-08-26 в 15:59.
  16. Senior Member Аватара на ccankov73
    Apr 2013
    Разград
    #88
    Явно на чайника не му се занимава да мисли софт да топли през намотките на компресора, а му е по-лесно да сложи външен нагревател.
    Mar 2010
    #89
    Той нагревателя е в тавата и ако е както казва Алекси само при дефрост, ще го преживея. 60 дена с Т под 0, по 10 дефр на ден х 160в са 96 КВ/бр, мен лично повече ме притеснява консумацията от 2.6кв при макс мощност, че помещението е голямо и е само с витрини плъзгащи и стационарни, ще видим, ще ви кажа.
    Dec 2024
    #90
    Точно за такова помещение е и едва ли ще се развърта често до максимална мощност.
  1. Проблем с Ariston B450L
    От hristo17 във форум Хладилна техника
    Отговори: 10
    Последно: 11-01-15, 21:12
  2. Проблем с хладилник Ariston
    От Стани във форум Ремонт и сервиз - Бяла техника
    Последно: 31-07-13, 20:12
  3. Амортисьор за Ariston AVLX 88
    От Lucky Luciano във форум Ремонт и сервиз - Бяла техника
    Последно: 30-09-10, 13:29
  4. Ariston Aqualtis
    От sunshine0 във форум Друга битова техника
    Последно: 27-01-10, 22:19
  5. ariston al88x
    От stel69 във форум Бяла техника
    Последно: 26-05-09, 21:44
