Вижте резултатите от анкетата: Какъв диагонал e вашият LCD телевизор Finlux ?
125. Не можете да гласувате в тази анкета
  • 55" LCD
    14 11.20%
  • 52" LCD
    0 0%
  • 48" LCD
    4 3.20%
  • 47" LCD
    1 0.80%
  • 46" LCD
    3 2.40%
  • 42" LCD
    16 12.80%
  • 40" LCD
    14 11.20%
  • 39" LCD
    3 2.40%
  • 37" LCD
    2 1.60%
  • 32" LCD
    50 40.00%
  • 26" LCD
    3 2.40%
  • 24" LCD
    9 7.20%
  • 22" LCD
    5 4.00%
  • 19" LCD
    1 0.80%
Страница 23 от 40 ПърваПърва ... 13212223242533 ... ПоследноПоследно
Резултати от 331 до 345 от общо 588
Like Tree44Одобрявам
Finlux телевизори
    Feb 2015
    #331
    Отговор: Finlux LCD TV / FAQ - на първа страница
    Hi Dimitar,
    I've changed one of the files. The change on the remaining ones unnecessary. You'll see 2 different files in this zip. One with Dashboard menu enabled and the other without it. You can install the dashboard menu first and if you don't like that, you can use the other one. Please note that when you install the dashboard menu, the OK button in the middle will have another function. You can use TV button instead.
    (WARNING: this file is only for Dimitar. Don't install someone else's profile to your TV. The versions should matchs exactly. Otherwise you can have problems or kill your tv's motherboard)
    http://www.filedropper.com/mb95changed
    Please keep your original file for future use. You may want to re-install it in case you have to call service.
    The changes I've done listed below;
    1- Enabled Hbbtv feature. If you've any channel supports this feature, you'll see a RED button on the screen (you need internet connection on TV)
    2- Disabled encyrption for PVR saved files. You can play them on your PC (you'll need k-lite full codec)
    3- Enabled Wink animation (it's a surprise )
    4- Fixed DVB subtitles (the main purpose was that. Please let me know about the result)
    5- Enabled source naming (for example you've playstation connected to HDMI1 and a media player on HDMI2. You can go into options and advanced options and sources, you can give name to them anymore. Instead of HDMI1 it can appear as Playstation)
    6- Added quick standby menu option.
    7- Added equalizer to qmenu
    8- Removed the digital manual from the left bottom and opened up some space. I think you won't need to read the instructions from TV.
    9- Enabled HTML channel info (if you're connected to internet by your TV, when you press i (info) button 2 times on any channel, you'll get program detail.
    10- The dashboard menu. It's a cool menu, you may want to use that.
    The installation :
    1- Create a folder named "Profile" in the USB.
    2- Put mb95_swprofile.bin and DownloadProfile.mb95 file into that folder.
    3- Follow the same instructions to go USB Operations. After it done, restart your TV.
    ps: Can you send me a screenshot from your service menu? Your profiles are almost like my device but I've noticed some differences.
    Този пост е редактиран от diabolical; 25-02-15 в 10:22.
    hristoslav2 и svetlio1 харесват това.
  3. Novice
    Dec 2014
    #332
    Огромни благодарности!!! Всичко стана много лесно и както е описано от колегата. Субтитрите вече са ок и съм много доволен и благодарен на колегата.
    П.С. : Here is the screenshots https://www.dropbox.com/s/012tdbyl8h...sktop.rar?dl=0
    П. С. 2: Тази операция може ли да стане на абсолютно същия телевизор закупени в един и същи ден от един магазин? Понеже като закупувах моят, бях с колега и той също реши, че му харесва и закупи и той. Ако може да стане да ползвам тези файлове. Ако не, възможно да помоля колегата от турция да му пратя файловете на моя колега и да ги промени като моите. Благодаря предварително!
    Този пост е редактиран от Димитър Дяков; 26-02-15 в 11:29.
    Feb 2015
    #333
    Check the service menu, as I see from the screenshot your software profile version is 214. Check that information.
    Also please check if the mainboard is the same (MB95M)
    If they're matching there should be no problem.
    translate/превод
    Проверете сервизното менюто, както виждам от скрииншота вашата версия на софтуерният профил е 214. Проверете тази информация.
    Също така проверете дали дънната платка е същата (MB95M)
    Ако съвпадат не трябва да има проблем.
    Този пост е редактиран от hristoslav2; 26-02-15 в 19:48.
  5. Novice
    Dec 2014
    #334
    Благодаря много!!!
  6. kod
    kod е офлайн
    Administrator Аватара на kod
    Jul 2000
    #335
    Без спам в темата моля - лични въпроси - на лични съобщения!
  7. kod
    kod е офлайн
    Jul 2000
    #336
    Цитат Първоначално публикувано от diabolical Виж публикацията
    I've read from google translate and it was really painful to be a member as it asks for some numbers and calculations and google can't translate it good. So, the translation doesn't work properly and I'll write in English. Otherwise I should use google translate to post as I don't know Bulgarian and the translation from google is socks.
    Sorry, we had big problems with bots and ad spammers.
    I know, the registration is very complicated, but it stops 100% of bots... I will probably translate the registration questions in English.
    Apr 2015
    #337
    Здравейте!
    Имам същия проблем със субтитрите , това на снимката е сервизното меню. Помогнете, моля!
    Feb 2015
    #338
    Hi cikus, please create the files that I've mentioned and upload to a site. I'll get and work on them.
    cikus одобрява това.
    Apr 2015
    #339
    Hello again. I'm glad you're willing to help me. Here is the file
    http://www.filedropper.com/tv_1
    Thank you in advance!
    Apr 2015
    #340
    Здравейте Имам Finlux 32FLYR160DOC и се опитвам да го ползвам чрез DLNA от компютъра. Пробвах различни програми - като почнеш от WMplayer, Simple DLNA ,, Plex, Servioo и до този руския Домашний медиа-сервер но за жалост все още немога да намеря лесен за настройване DLNA сървър с който да мога и субтитрите да гледам.
    На много места хвалеха Домашния медиа сървър но той е само на руски, и с доста сложни настройки. Някъде бяха пуснали линк към клипче с настройките на този софтуер но вече за жалост не е активно. Пробвах го но освен че ми затри една папка с филми неможах да се ориентирам и да си го настроя сам. Може ли някой да сподели какъв софтуер е ползвал за DLNA на Windows 7 чрез който ТВто да чете и субтитрите от компютъра? Тоест освен да си виждам в папката самия видео файл да мога да виждам и sub/srt файла му?
    Ако действително домашния медиа сървър е най-доброто може ли да качите някъде няколко скрийншота с настрйките да знам как да си го настроя?
  13. Junior Member
    Sep 2012
    Ямбол
    #341
    След няколко опити, с какви ли не, един приятел ми препоръча PS3, тръгна от първия път, само нещо с прескачането на минути от филм не се получава, но това не е чак такъв проблем!
  15. Member Аватара на popov
    Mar 2011
    Бургас
    #342
    Цитат Първоначално публикувано от nirbod Виж публикацията
    Вчера го изтеглих от линка който си дал.Работи си добре Единствената настройка която направих,е да му задам от кой диск да ''чете''.В моя случай е локален диск D
    Jan 2015
    #343
    Отговор: Finlux телевизори
    Някой пробвал ли е, дали Finlux поддържат USB мишка или клавиатура?
    Моя е Finlux 40F HR274H
  17. Junior Member
    Jul 2012
    #344
    Здpaвeйтe! Имaм тeлeвизop 32flyr160dc fhd гope-дoлy oт гoдинa. Kaтo зa cвoитe 400 и мaлĸo лeвa e нaпpaвo oтличeн. Oбaчe, биx иcĸaл дa paзбepa няĸoи нeщa. 1. Интepecyвa мe, мoгa ли дa видя ĸaĸвa мy e тoчнo мaтpицaтa ĸaтo мapĸa и мoдeл - дocтa ми xapecвa ĸaтo цвeтoвe и ъгъл нa виждaнe! Πpocтo ми e любoпитaнo. 2. Kyчe-мapĸa e, тa зaтoвa пpeдпoлaгaм ĸaĸъв щe e oтгoвopът, aмa имa ли вce пaĸ нaчин зa ъпдeйтвaнe нa fіrmwаrе? Бeлĸим ce пoявят няĸoи нoви фyнĸции в cмapтa или пъĸ cтaнe пo-бъpз... Πoняĸoгa зaбивa cмapт мeнютo и гo вaдя oт ĸoнтaĸтa. 3. He виждaм нищo oт poдa нa АРР ЅТОRЕ. Mнoгo ми ce щe, aмa ĸaтo нищo мoжe дa e oгpaничeнa paбoтa... 4. Имaм ЅОNY, нa ĸoeтo мoжe дa ce глeдa TB oнлaйн... Имa ли cмиcъл дa ce нaдявaм, чe и пpи тoзи FІNLUХ щe тpъгнe? Блaгoдapя пpeдвapитeлнo!
    #345
    1. Най-вероятно е на LG. Може да провериш като свалиш задният капак или в сервизното меню.
    2. Май...не. Официално Вестел не предлагат софтуерна поддръжка - за подробности попитай в Зора
    support at Finlux Direct
    Opdateringer – Finlux
  1. OLED Телевизори - съвети и обсъждане
    От hristoslav2 във форум Телевизори
    Отговори: 1827
    Последно: 16-05-25, 22:15
  2. Hitachi телевизори (инфо на първа страница)
    Отговори: 341
    Последно: 23-07-21, 18:47
  3. Sharp LCD TV / FAQ - на първа страница
    От hristoslav2 във форум Sharp телевизори
    Отговори: 1269
    Последно: 09-03-15, 23:29
  4. Sony LCD TV / FAQ - на първа страница /част 3/
    Отговори: 2014
    Последно: 07-01-15, 19:15
  5. Philips LCD TV / FAQ - на първа страница /част 3/
    Отговори: 1539
    Последно: 26-01-14, 17:56
