По въпроса със затъмняването - Ambient light detection и Contrast enhancer изключени ли са
При закачени външни източници, настройките трябва да се правят докато източника е активен и всеки източник е с независими настройки.
Няма да е зле да се създаде нова тема в раздела Samsung относно тази дискусия, понеже доволно разводнихме темата за избор.
Резултаt върнат от AI, за излючваен на local diming:
Всеки HDMI вход на ТВ, или тунер, трябва да е с персонализирани/отделни настройки на звука и картината.Код:1. Disable Power Saving & Eco Settings (Immediate Action)
Samsung enabled these by default. Turning them off is the first step to a stable image.
- Go to Menu > Settings > All Settings > General & Privacy > Power and Energy Saving.
- Turn off "Brightness Optimization".
- Turn off "Energy Saving Solution".
- Turn off "Motion Lighting".
2. Disable Aggressive Contrast Processing
- Go to Picture > Expert Settings.
- Set Contrast Enhancer to Off (or Low if it's too dim, but Off is best for consistent brightness).
3. Adjust SDR Picture Mode
- Use Filmmaker Mode or Movie Mode for the most accurate and consistent SDR brightness. These modes generally apply less aggressive dimming algorithms compared to "Standard" or "Eco".
- Set Peak Brightness to High in Expert Settings to ensure the panel can still reach high highlights in SDR.
4. Service Menu (Advanced - Risks Warranty)
If the above settings do not fix the issue, the TV is likely engaging ASBL/TPC (Target Panel Conditioning).
- Note: Accessing the service menu can void your warranty.
- Users often use a service remote to access the SVC Menu > Expert > OLED and set ANAPEAK 2 or disable TPC Enable to stop the TV from dimming during dark scenes with static logos.
5. Other Potential Causes
- Gaming Settings: If you are in Game Mode, ensure "Game HDR" is not interfering, or try toggling the HDMI 10-bit settings to fix potential handshake issues causing brightness fluctuations.
- Overheating: If the room is very hot or the TV is in a confined space, the S90F may throttle brightness to cool down, regardless of settings.
By turning off Energy Saving, Brightness Optimization, and turning off Contrast Enhancer, you should see a significant improvement in SDR brightness stability.
То и аз го написах взето от Ai отговор в Гугъл.
И какъв е смисълът да си купувате ТВ с local dimming, след като искате да го изключвате?
Според мен просто са се объркали! И това не е за OLED а за miniLED.
Иначе, оправих всичко :) Вече няма затъмняване при SDR. ABL-ът е много слабо забележим , трябва да е супер ярка сцена на цял екран, за да се усети лек спад в яркостта. Няма нищо общо с агресивния ABL при WOLED телевизорите.
Накратко, това е моят телевизор. След като си нагласих картината както ми харесва и оправих проблемите, реших да го задържа. Махнах и транспортното фолио и, както се очакваше, картината стана дори една идея по-добра.
Ако някой се колебае за S90F 65" – да взима смело. Телевизорът е страхотен, особено ако се намери на цена около 2200 лв, както беше при мен.
Да, има един период на „свикване“ с настройките и интерфейса, и не всеки ще се оправи веднага. Но за това са форумите, да си помагаме и да споделяме опит.
За останалите размери обаче бих се насочил по-скоро към LG C5.
:offtopic: Пичове, според мен доста българи имат S90F и една тема за модела в раздела на Samsung ще бъде доста по-полезна, отколкото рандъм приказки в темата за избор. Със сигурност има адски много хора, които нямат регистрация и само четат.
Според мен това е най-голямата и най-четената тема във форума, дори и от хора без регистрация. Повечето просто нямат нещо конкретно набелязано и търсят обща информация, затова и реших да започна да пиша тук (може и да греша, разбира се).
И честно казано, не видях отделна тема за модела , поне не в първите 2–3 страници в Samsung раздела, което си е малко срамота, ако питаш мен :D
В този ред на мисли , 65" S90F ще е последния достъпен QD-OLED , защото S90H ще е САМО WOLED .
Samsung Downgraded My Editor's Choice TVs! I Get Why
QD-OLED-а вече ще е само за високия им клас телевизори S95
Като гледах няколко видеа в които сравняват двата типа олед монитори, изтъкват повече недостатъци на QD-OLED панела.
Да, единия недостатък е с текста. Другото е че не се препоръчват за по-осветени стаи и ако попада много светлина върху панела, то черното вече не е черно както се очаква от тази технология. Сега при телевизорите дали е същото положение не знам.
Погледнах и малко измервания конкретно на S90F при осветяване с околна светлина. На практика черното става по-сиво и от начален клас Mini-LED при попадане на светлина върху QD-OLED. А като засивее черното това значи че пада контраста и цялата идея на тази технология малко се обезсмисля според мен. Така освен другите грижи, трябва да се гледа и в по-тъмни стаи, ако много се държи на контраста и черното.
В реални условия аз не забелязвам такъв проблем. Да, стаята ми не е много светла (нормална стая), но повярвай ми, контрастът е повече от перфектен. АКО имаше нещо подобно, щях да го споделя.
Тези неща бяха по-характерни за първите генерации на QD-OLED, но S90F е трето поколение и доста от недостатъците вече са изчистени.
Ако трябва да издребнявам и да търся някакъв „недостатък“, когато имах възможност да тествам C1 около месец (преди да го подаря), ми направи впечатление, че картината там изглеждаше някак по-„обемна“. Обектите имаха едно почти 3D усещане, все едно са пред теб и можеш да ги докоснеш.
Много хора, на които го показах на живо, също го потвърдиха. Доста странно усещане е, но сякаш е специфично за WOLED телевизорите на LG. Може би е свързано с обработката на цветовете или нещо друго.
При S90F това май го няма, или не е толкова изразено. Трудно е да се обясни, трябва просто да се види на живо.
