-   Philips LCD TV / FAQ - на първа страница, обсъждане, мнения /част 2/  Всичко за Philips телевизори. Новите модели през 2011 година.
 Мнения и Избор на 3D телевизор
 Линкове към старите теми:
 Philips телевизори - част 1
 Модели 2011
 Standard
  Код:
 model     resolution  din.contrast      IFC  res.time           backlight     ambilight   3D  Smart TV  PVR   Wi-Fi HDMI USB   тунери    Цвят      звук
 58PFL9956 21:9 2560 x 1080 500,000:1  450cd/m²  600Hz 2.0ms Pixel Precise HD   Edge-Lit LED    Spectra 3   active   Y    Y
 50PFL7956 21:9 2560 x 1080 500,000:1  450cd/m²  400Hz 2.0ms Pixel Precise HD   Edge-Lit LED    Spectra 3   active   Y    Y
 46PFL9706   1920x1080  100,000,000:1 450cd/m²  400Hz 0.5ms Perfect Pixel HD    LED Pro      Spectra XL  active   Y    Y   built  4  2  DVB-T/C/S2   титан      2x20W  moth eye filter
 52PFL9606   1920x1080  5,000,000:1  500cd/m²  400Hz 0.5ms Perfect Pixel HD    LED Pro      Spectra XL  active   Y    Y   built  4  2  DVB-T/C/S2   алуминиев    2x20W
 46PFL9606   1920x1080  5,000,000:1  450cd/m²  400Hz 0.5ms Perfect Pixel HD    LED Pro      Spectra XL  active   Y    Y   built  4  2  DVB-T/C/S2   алуминиев    2x20W
 40PFL9606   1920x1080  5,000,000:1  450cd/m²  400Hz 0.5ms Perfect Pixel HD    LED Pro      Spectra XL  active   Y    Y   built  4  2  DVB-T/C/S2   алуминиев    2x20W
 37PFL9606   1920x1080   500,000:1  450cd/m²  400Hz 1.0ms Perfect Pixel HD   Edge-Lit LED    Spectra 3   active   Y    Y   built  4  2  DVB-T/C/S2   алуминиев    2x25W
 32PFL9606   1920x1080   500,000:1  450cd/m²  200Hz 1.0ms Perfect Pixel HD   Edge-Lit LED    Spectra 3   active   Y    Y   built  4  2  DVB-T/C/S2   алуминиев    2x20W
 52PFL8606   1920x1080   500,000:1  450cd/m²  200Hz  1ms Perfect Pixel HD    Edge LED     Spectra 2   active   Y    Y   built  4  2  DVB-T/Т2/C/S2 титан      2x20W
 46PFL8686   1920x1080   500,000:1  450cd/m²  200Hz  1ms Perfect Pixel HD    Edge LED     Spectra 2   active   Y    Y   built  4  2  DVB-T/Т2/C/S2 титан      2x16W
 46PFL8606   1920x1080   500,000:1  450cd/m²  200Hz  1ms Perfect Pixel HD    Edge LED     Spectra 2   active   Y    Y   built  4  2  DVB-T/
 40PFL8606   1920x1080   500,000:1  450cd/m²  200Hz  1ms Perfect Pixel HD    Edge LED     Spectra 2   active   Y    Y   built  4  2  DVB-T/
 37PFL8606   1920x1080   500,000:1  450cd/m²  200Hz  1ms Perfect Pixel HD    Edge LED     Spectra 2   active   Y    Y   PTA01  4  2  DVB-T/
 32PFL8606   1920x1080   500,000:1  450cd/m²  200Hz  1ms Perfect Pixel HD    Edge LED     Spectra 2   active   Y    Y   built  4  2  DVB-T/
 55PFL7606   1920x1080   500,000:1  450cd/m²  200Hz  2ms Pixel Precise HD    Edge LED     Spectra 2  passive   Y    Y   PTA01  4  2  DVB-T/C     графит     2x14W
 47PFL7696   1920x1080   500,000:1  450cd/m²  600Hz  2ms Pixel Precise HD    Edge LED     Spectra 2  passive   Y    Y   built  4  2  DVB-T/C     графит     2x14W
 47PFL7606   1920x1080   500,000:1  450cd/m²  200Hz  2ms Pixel Precise HD    Edge LED     Spectra 2  passive   Y    Y   PTA01  4  2  DVB-T/C     графит     2x10W
 42PFL7696   1920x1080   500,000:1  450cd/m²  600Hz  2ms Pixel Precise HD    Edge LED     Spectra 2  passive   Y    Y   built  4  2  DVB-T/C     графит     2x14W
 42PFL7676   1920x1080   500,000:1  450cd/m²  200Hz  2ms Pixel Precise HD    Edge LED     Spectra 2  passive   Y    Y   PTA01  4  2  DVB-T/C     графит     2x14W
 42PFL7666   1920x1080   500,000:1  450cd/m²  200Hz  2ms Pixel Precise HD    Edge LED     Spectra 2  passive   Y    Y   built  4  2  DVB-T/C     графит     2x14W
 42PFL7606   1920x1080   500,000:1  450cd/m²  200Hz  2ms Pixel Precise HD    Edge LED     Spectra 2  passive   Y    Y   PTA01  4  2  DVB-T/C     графит     2x12W
 42PFL7486   1920x1080   500,000:1  450cd/m²  200Hz  2ms Pixel Precise HD    Edge LED     Spectra 2    N    Y    Y   built  4  2  DVB-T/C     графит     2x14W
 42PFL7466   1920x1080   500,000:1  450cd/m²  200Hz  2ms Pixel Precise HD    Edge LED     Spectra 2    N    Y    Y   built  4  2  DVB-T/C     графит     2x14W
 42PFL7456   1920x1080   500,000:1  450cd/m²  200Hz  2ms Pixel Precise HD    Edge LED     Spectra 2    N    Y    Y   PTA01  4  2  DVB-T/C     графит     2x14W
 42PFL7406   1920x1080   500,000:1  450cd/m²  200Hz  2ms Pixel Precise HD    Edge LED     Spectra 2    N    Y    Y   PTA01  4  2  DVB-T/C     графит     2x12W
 37PFL7606   1920x1080   500,000:1  450cd/m²  200Hz  2ms Pixel Precise HD    Edge LED     Spectra 2  passive   Y    Y   PTA01  4  2  DVB-T/C     графит     2x
 32PFL7606   1920x1080   500,000:1  450cd/m²  200Hz  2ms Pixel Precise HD    Edge LED     Spectra 2  passive   Y    Y   PTA01  4  2  DVB-T/C     графит     2x
 32PFL7486   1920x1080   500,000:1  450cd/m²  200Hz  2ms Pixel Precise HD    Edge LED     Spectra 2    N    Y    Y   PTA01  4  2  DVB-T/C     графит     2x14W
 32PFL7476   1920x1080   500,000:1  450cd/m²  200Hz  2ms Pixel Precise HD    Edge LED     Spectra 2    N    Y    Y   PTA01  4  2  DVB-T/C     графит     2x14W
 46PFL6806   1920x1080   500,000:1  400cd/m²  200Hz  2ms Pixel Plus HD     Edge LED     Spectra 2    N    Y    Y   PTA01  3  1  DVB-T/C     бял      2x14W
 40PFL6806   1920x1080   500,000:1  400cd/m²  200Hz  2ms Pixel Plus HD     Edge LED     Spectra 2    N    Y    Y   PTA01  3  1  DVB-T/C     бял      2x14W
 55PFL6606   1920x1080   500,000:1  400cd/m²  100Hz  2ms Pixel Plus HD     Edge LED       N      N    Y    Y   PTA01  3  1  DVB-T/C     графит     2x10W
 46PFL6606   1920x1080   500,000:1  400cd/m²  100Hz  2ms Pixel Plus HD     Edge LED       N      N    Y    Y   PTA01  3  1  DVB-T/C     графит
 40PFL6636   1920x1080   500,000:1  400cd/m²  100Hz  2ms Pixel Plus HD     Edge LED       N      N    Y    Y   PTA01  3  1  DVB-T/C     сребрист
 40PFL6626   1920x1080   500,000:1  400cd/m²  100Hz  2ms Pixel Plus HD     Edge LED       N      N    Y    Y   PTA01  3  1  DVB-T/C     черен      2x14W
 40PFL6636   1920x1080   500,000:1  400cd/m²  100Hz  2ms Pixel Plus HD     Edge LED       N      N    Y    Y   PTA01  3  1  DVB-T/C     сребрист    2x14W
 40PFL6606   1920x1080   500,000:1  400cd/m²  100Hz  2ms Pixel Plus HD     Edge LED       N      N    Y    Y   PTA01  3  1  DVB-T/C     графит     2x10W
 37PFL6606   1920x1080   500,000:1  400cd/m²  100Hz  2ms Pixel Plus HD     Edge LED       N      N    Y    Y   PTA01  3  1  DVB-T/C     графит     2x10W
 32PFL6636   1920x1080   500,000:1  400cd/m²  100Hz  2ms Pixel Plus HD     Edge LED       N      N    Y    Y   PTA01  3  1  DVB-T/C     сребрист    2x14W
 32PFL6626   1920x1080   500,000:1  400cd/m²  100Hz  2ms Pixel Plus HD     Edge LED       N      N    Y    Y   PTA01  3  1  DVB-T/C     черен      2x14W
 52PFL5606   1920x1080   500,000:1  400cd/m²  100Hz  2ms Pixel Plus HD     Edge LED       N      N    Y    N    N    3  1  DVB-T/C     черен      2x10W
 46PFL5606   1920x1080   500,000:1  400cd/m²  100Hz  2ms Pixel Plus HD     Edge LED       N      N    Y    N    N    3  1  DVB-T/C     черен      2x10W
 40PFL5606   1920x1080   500,000:1  400cd/m²  100Hz  2ms Pixel Plus HD     Edge LED       N      N    Y    N    N    3  1  DVB-T/C     черен      2x10W
 37PFL5606   1920x1080   500,000:1  400cd/m²  100Hz  2ms Pixel Plus HD     Edge LED       N      N    Y    N    N    3  1  DVB-T/C     черен      2x10W
 32PFL5606   1920x1080   500,000:1  400cd/m²  100Hz  2ms Pixel Plus HD     Edge LED       N      N    Y    N    N    3  1  DVB-T/C     Черен гланцов  2x10W
 32PFL5206   1366x768   100,000:1  400cd/m²  100Hz  2ms Pixel Plus HD     Edge LED       N      N    Y    N    N    3  1  DVB-T/C     Черен гланцов  2x5W
 46PFL4606   1920x1080   100 000:1  400cd/m²  100Hz  2ms Pixel Plus HD      CCFL        N      N    N    N    N    3  1  DVB-T/C     Черен алуминий  2x10W
 42PFL4606   1920x1080   100 000:1  400cd/m²  100Hz  2ms Pixel Plus HD      CCFL        N      N    N    N    N    3  1  DVB-T/C     черен      2x10W
 32PFL4606   1920x1080   100 000:1  400cd/m²  100Hz  2ms Pixel Plus HD      CCFL        N      N    N    N    N    3  1  DVB-T/C     Черен гланцов  2x10W
 42PFL3606   1920x1080   100 000:1  400cd/m²  50Hz  5ms Pixel Plus HD      CCFL        N      N    N    N    N    2  1  DVB-T/C     Черен алуминий 2x10W
 32PFL3606   1920x1080   100 000:1  400cd/m²  50Hz  5ms Pixel Plus HD      CCFL        N      N    N    N    N    2  1  DVB-T/C     черен      2x10W
 26PFL3606
 22PFL3606
 19PFL3606
 32PFL3406     1366x758 100 000:1  400cd/m²  50Hz  5ms Pixel Plus HD      CCFL        N      N    N    N    N    2  1  DVB-T/C    черен      2x10W
 модели 8606 - 2x14 W - Incredible Surround
 модели 86x6 - 2x16 W - Incredible Surround
 модели 7х06 - 2x12 W - Incredible Surround
 модели 7хx6 - 2x14 W - Incredible Surround
 модели 7956 - 2x17 W - Incredible Surround
 LED Pro
 40PFL9606: 168 лед блока
 46PFL9606: 112 лед блока
 46PFL9706: 224 лед блока + moth eye filter
 52PFL9606: 288 лед блока
 Цветове на корпусите при отделните модели
 9606 - металик,
 8686 – черен,
 8606 – черен,
 7696 – металик/графит,
 7486 – металик/графит,
 7476 - металик/графит,
 7456 - металик/графит,
 7606 – графит,
 6806 - металик/графит,
 6636 - металик/графит (светъл),
 6626 - металик/графит,
 6606 - металик/графит,
 5606 – черен
 DesignLine Edge (в бяло с Ambilight 2)
  Код:
 model     resolution  din.contrast      IFC  res.time           backlight     ambilight   3D  Smart TV  PVR   Wi-Fi HDMI USB   тунери    Цвят  озвучаване
 42PDL7406   1920x1080   500,000:1  450cd/m²  400Hz  2ms Pixel Precise HD    Edge LED     Spectra 2    N    Y    Y   PTA01  4  2  DVB-T/C      бял      2x12W
 32РDL7906   1920x1080   500,000:1  450cd/m²  400Hz  2ms Pixel Precise HD    Edge LED     Spectra 2    N    Y    Y   PTA01  4  2  DVB-T/C      бял      2x12W
 DesignLine Tilt (в черно без Ambilight)
  Код:
 model     resolution
 26РDL4906H  1366х768 50 Hz, LED and USB playback.
 22РDL4906H  1366х768 50 Hz, LED and USB playback.
 Подобрен антиотражателен филтър.[/b] само в модел 46PFL9706 - moth eye filter.
 http://gagadget.com/files/u2/2011/03...sTV2011_27.jpg
 9-та серия е с Moth Eye-Filter  http://www.fullhd.gr/images/stories/...heyefolter.jpg
 Philips антиотражателен филтър - сравнен с модели от други марки
 https://www.youtube.com/watch?v=jANSbe0shMo#ws
 Вграденият браузър в новите модели[/b]
 My Opera is now closed - Opera Software
 HTTP-USER-AGENT:  Opera / 9.70 (Linux mips; U; CE-HTML/1.0 (); en) Presto/2.2.1
 Въпрос към знаещите:
 - известно е, че операторите на цифрова телевизия (кабелна, сателитна или наземна/terrestrial) излъчват програмите с различно качество на кодиране
- до голяма степен, качеството на кодиране (и на предаването) се определя от стойността на т.н. параметър Bit Data Rate или Max Video Bit Rate
- стойността на този праметър в случай на HDTV програма може да варира между 8 и 17 Mbps (кодиране MPEG-4 AVC)
- и въпросът: може ли през сервизното меню да са наблюдава стойността на Bit Data Rate или Max Video Bit Rate за текущата програма?
 Ако стойностите са известни, може обективно да се съди за качеството на програмата...
-   Re:Philips LCD TV / FAQ - на първа страница, обсъждане, мнения /част 2/  Може ли някой да помогне с разчитането на кода на матрицата?????
 Интересува ме код 265????
-   Re:Philips LCD TV / FAQ - на първа страница, обсъждане, мнения /част 2/  Моля, помогнете!Купих си телевизор Philips 40PFL5605H.Не мога да хвана нито един цифров канал само аналогови и то с ужасно качество.Сигнала ми е от кабелна телевизия.Моделът има вграден цифров тунер и би трябвало да хване нещо ефирно, но не се получава.Дайте съвет и напътствия.
-   Re:Philips LCD TV / FAQ - на първа страница, обсъждане, мнения /част 2/  Избери за страна Финландия или Германия. При избор България ,няма цифров тунер в настройките.
-   Re:Philips LCD TV / FAQ - на първа страница, обсъждане, мнения /част 2/   Цитат:
				Първоначално публикувано от nautica_   Може ли някой да помогне с разчитането на кода на матрицата?????
-   Re:Philips LCD TV / FAQ - на първа страница, обсъждане, мнения /част 2/  Може ли да се направи обективно сравнение между 42PFL7404H(1208 лева) vs 42PFL5405H/12(1199 лева) .
 Това са два модела с еднакви цени, но 7 цата е миналогодишен, а 5 цата е от тази година(с по-голям контраст и по-бърза по ТТД).
 Дайте да видим матриците и процесорите, за да не стане грешка при избора.Някой гледал ли ги е един до друг?
 Въпросът е кой от двата да се избере????
				Първоначално публикувано от Staykov   Може ли да се направи обективно сравнение между 42PFL7404H(1208 лева) vs 42PFL5405H/12(1199 лева) .
 Philips 42PFL7404H/12 - процесор NXP/Trident PNX8543  http://www.tridentmicro.com/productt...tv543-pnx8543/
 - корпус Roadrunner
 - LGD CCFL display S-IPS (код 183)
 - шаси Q548.1E LA създадено на платформа TV543/82  http://www.nxp.com/#/aip/aip=[aip=456]|pp=[t=aip,i=456]
 Набор основни чипове на шасси Q552.1
 • PNX8543 Video and аudio processor,Digital Colour Decoder
 • HD1816AF Hybrid Tuner
 • DRX3926K Demodulator
 • TDA9996 HDMI Switch
 • TPA3123D2PWP Class D Power Amplifier
 • PNX5100 Video Back-End Processor.
 Philips 42PFL5405H/12 - процесор NXP/Trident PNX8550х  http://www.tridentmicro.com/productt...v550-pnx8550x/
 - корпус Rembrand
 - LGD CCFL display S-IPS (код 276)
 - шаси Q552.1E LA
 (The Q552.1E LA is a new chassis launched in Europe in 2010.The whole range is covered by PNX8550x main IC so-called NXP TV550 platform.)
 • PNX85500 System-On-Chip (SOC) TV Processor
 • TX31XX Hybrid Tuner (DVB-T/C, analogue)
 • STV6110AT DVB-S Satellite Tuner /само в модели завършващи на К/
 • SII9x87 HDMI Switch
 • TPA312xD2PWP Class D Power Amplifier
 • LAN8710 Dual Port Gigabit Ethernet media access controller.
 Основни разлики в 5-та серия от 6-а и 7-а /2010г/ опростно акустическо оформление,един събуфер и два туитера,орязано количество SDRAM от 512MB до 256MB,отсъстствие на един скарт,HDMI и SD картов четец.
-   1 Прикачен файл(ове) Re:Philips LCD TV / FAQ - на първа страница, обсъждане, мнения /част 2/  550 / 543
 Видеопроцесорът PNX5120 е интегриран, в новия чип PNX85500
-   2 Прикачен файл(ове) Re:Philips LCD TV / FAQ - на първа страница, обсъждане, мнения /част 2/  малко картинки :2009 / 2010
-   Re:Philips LCD TV / FAQ - на първа страница, обсъждане, мнения /част 2/  От седмица съм собственик на Philips 40PFL7605. Има 2 неща, които ме дразнят:
 1. Филмите изглеждат като театър, уж екшън, а все едно гледам сапунка
 2. Нещо не са съвсем наред цветовете, най-вече червеното, което бие на цикламено.
 Ако някой може да даде насоки за корекция, но като за средностатистически потребител, тоест на малко по-обикновен език :smiley:
				Първоначално публикувано от DukeFan   От седмица съм собственик на Philips 40PFL7605. Има 2 неща, които ме дразнят:
 1. Изключи от менюто функцията HD Natural Motion !
 2. Настрой си в менюто режим на картината - топъл /Warm/
-   Re:Philips LCD TV / FAQ - на първа страница, обсъждане, мнения /част 2/  Благодаря за съветите, по точка 1 има значително подобрение :smiley:, но по точка 2 все още има какво да се желае. Изчетох една тема за калибрация в avguide и мисля, че схванах за какво става въпрос. Сега въпросът ми е, понеже в темата се пипат едни адвансед настройки на отделните цветове, а в менютата на Филипса не откривам такива, възможно ли е по някакъв начин да се достигне до тях?
-   Re:Philips LCD TV / FAQ - на първа страница, обсъждане, мнения /част 2/  То хубаво си прочел темата за калибрация ,но имаш ли колориметър и софтуер? А опит в калибрирането ?? :)
 Достъпът до тези настройки става с влизане в сервизното меню.Не знам точно в коя опция се намират-трябва да потърсиш. Всичко е на твой риск!!! :police:
-   Re:Philips LCD TV / FAQ - на първа страница, обсъждане, мнения /част 2/  Аз още не съм решил да правя такова нещо, само събирам информация. Не съм готов да поема риска от отпадане на гаранцията още на втората седмица :smiley:
-   Re:Philips LCD TV / FAQ - на първа страница, обсъждане, мнения /част 2/  Philips представиха новите 4-та, 5-та и 6-та серии /4706, 5706, 6706/ за американският пазар
 http://www.flatpanelshd.com/news.php...&id=1294234461
 http://www.engadget.com/2011/01/05/p...ries-lcds-blu/
 Eто ви клип ,в който показват как стойката в 8-ма и 9-та серия се трансформира в такава за стена/от средата на клипа/
 http://live.philips.com/index.php/en...o/601358650001
