Страница 7 от 75 ПърваПърва ... 567891757 ... ПоследноПоследно
Резултати от 91 до 105 от общо 1119
Like Tree172Одобрявам
SONY телевизори 2019
    #91
    Отговор: SONY телевизори 2019
    Sony Bravia OLED & LCD TV 2019 Line-up
    Class MASTER Series Mainstream MASTER Series 8K Mainstream Entry
    Type OLED - UltraHD LCD - UltraHD LCD - FullHD
    Series
    ___________________
    AG9
    __________________
    AG8
    __________________
    ZG9
    __________________
    XG95
    availability in March
    __________________
    XG90
    __________________
    XG85
    __________________
    XG83
    __________________
    XG80
    availability in April
    ___________________
    WG66
    __________________
    Models
    KD-77AG9
    KD-65AG9
    KD-55AG9
    KD-65AG8
    KD-55AG8
    KD-98ZG9
    KD-85ZG9
    KD-85XG9505
    KD-75XG9505
    KD-65XG9505
    KD-55XG9505
    KD-49XG9005
    XG8599
    XG8596
    XG8588
    XG8577
    XG8505
    KD-49XG8305
    KD-43XG8305
    KD-75XG8005
    KD-65XG8005
    KD-55XG8005
    KD-49XG8005
    KD-43XG8005
    50WG665
    50WG660
    43WG665
    43WG660
    Formats 55", 65", 77" 65", 75" 85", 98" 55", 65", 75", 85" 49" 55", 65", 75", 85" 43", 49" 43"", 49",55",65",75" 43", 50"
    Processor
    CPU & GPU X1 Ultimate
    Mediatek 5893(5598)
    4xARM Cortex
    X1 Extreme
    Mediatek 5892(5597)
    4xARM Cortex-A73 @ 1500MHz
    64-bit ARMv8-A (32-bit mode)
    GPU - ARM Mali-G71 Vulkan
    X1 Ultimate
    Mediatek 5893(5598)
    4xARM Cortex
    X1 Ultimate
    Mediatek 5893(5598)
    4xARM Cortex
    X1 Extreme
    MediaTek 5597
    X1
    Mediatek 5596
    4xARM Cortex-A53 @ 1100MHz
    GPU - ARM Mali-T860 MP2
    X1
    MediaTek 5596
    X1
    MediaTek
    MediaTek
    RAM 4GB - -
    Flash 16 GB internal memory (approximately 8GB available) + expandable via USB Dongle -
    Operation System Android 8.0 OREO (update to Android 9.0 Pie) Linux kernel ?
    Display
    Manifacturer:
    Model:
    Type:
    Resolution:
    Display aspect ratio:
    Pixel Format:
    Display Colors::
    Luminance(cd/m²):
    Viewing Angle:
    Color Gamut:
    Contrast Ratio:
    Response speed(ms)
    Frame Rate:
    Life Time:
    LG Display
    LE650AQD / LE550AQD
    AM-OLED, Oxide-WOLED-Color Filter
    3840(RG/BW)x 2160, UHD
    16:9 (H:V)
    RGBW Vertical Stripe
    1.07B (8-bit + Dithering)
    500 (Typical) 900 max
    60/60/60/60 (Typ.) (Left, Right, Up, Down)
    97% DCI-P3
    150000:1 (Typ.) (Transmissive)
    1 (Typ.)(G to G); 8 (Typ.)(MPRT)
    120Hz
    30K (Typ.) (Hours). After that time, the brightness may drop about 50%.
    98"(Samsung, LG)
    85"(AUO, Innolux)
    LCD
    7680(RGB)×4320
    16:9(H:V)
    RGB Vertical Stripe
    1.07B (8-bit + FRC)
    -- (Typical) -- max
    60/60/60/60 (Typ.)
    97% DCI-P3
    6000:1 (Typ.)
    14 (Typ.)(G to G)
    100/120Hz
    30K (Typ.) (Hours).
    LCD, Super-MVA
    Innolux
    LCD
    3840(RGB)×2160
    16:9(H:V)
    RGB Vertical Stripe
    1.07B (8-bit + FRC)
    500 (Typical) -- max
    60/60/60/60 (Typ.)
    97% DCI-P3
    6000:1 (Typ.)
    14 (Typ.)(G to G);
    100/120Hz
    30K (Typ.) (Hours).
    MVA
    LCD
    3840(RGB)×2160,
    16:9(H:V)
    RGB Vertical Stripe
    1.07B (8-bit + FRC)
    -- (Typical) -- max
    60/60/60/60 (Typ.)
    97% DCI-P3
    1200:1 (Typ.)
    14 (Typ.)(G to G)
    100/120Hz
    30K (Typ.) (Hours).
    AMVA3
    Acer Unipac Optronics
    LCD
    3840(RGB)×2160
    16:9 (H:V)
    RGB Vertical Stripe
    1.7B (8-bit + FRC)
    IPS ?
    LCD
    3840(RGB)×2160
    16:9 (H:V)
    RGB Vertical Stripe
    1.07B (8-bit + FRC)
    -- (Typical)
    60/60/60/60
    97% DCI-P3
    1200:1 (Typ.)
    14 (Typ.)(G to G)
    100/120Hz
    30K (Typ.) (Hours).
    LCD
    3840(RGB)x2160
    16:9 (H:V)
    RGB Vertical Stripe
    LCD
    1920(RGB)×1080
    16:9 (H:V)
    RGB Vertical Stripe
    1.07B (8-bit + FRC)
    -- (Typical)
    60/60/60/60 (Typ.)
    97% DCI-P3
    ?:1 (Typ.)
    14 (Typ.)(G to G)
    50/60Hz
    30K (Typ.) (Hours).
    Backlight Type OLED is a self-emitting pixels display technology meaning that it controls luminance on the pixel level FALD
    Backlight Master Drive
    FALD
    85" - ? zones
    75" - ? zones
    65" - ? zones
    55" - ? zones
    FALD
    49" - ? zones
    Edge LED
    Local Dimming
    Edge LED
    Local Dimming
    55, 65, 75" - Direct Led
    Global Dimming
    43",49" - Edge Led
    Local Dimming
    Edge LED
    No Local Dimming
    Native Refresh Rate 48/50/60/100/120Hz (100Hz - PAL / 120Hz - NTSC) 48/50/60 Hz
    Viewing Angle - - X-Wide Angle Filter X-Wide Angle Filter
    (only in 75" & 85")
    Triluminos Display No Yes
    (Blue Leds - PFS (potassium-fluorosilicate) phosphor featuring an extremely narrow red peak - "TRILUMINOS")
    No
    MEMC MotionFlow XR - -
    Motion Enhancer X-Motion Clarity ? X-Reality Pro -
    CalMan Calibration Function Yes No Yes
    No
    Object-based Super Resolution Yes - - - -
    Video Features
    CineMotion/Film
    Mode/Cinema Drive
    -- -- Yes -- -- -- -- -- --
    24p True Cinema -- -- -- Yes -- -- -- -- --
    4:3 Default -- -- -- Yes -- -- -- -- --
    Auto Wide -- -- -- Yes -- -- -- -- --
    Blinking Type -- -- -- Line Blinking -- -- -- -- --
    Dual database
    processing
    Dynamic Contrast
    Enhancer
    Face Area Detection -- -- -- Yes -- -- -- -- --
    HDR (High Dynamic
    Range) compatiblity
    HDR10, Hybrid Log-Gamma, Dolby Vision HDR10, HLG HLG
    Live Color™
    Technology
    Object-based HDR
    remaster
    Picture Modes Vivid, Standard, Cinema, Game, Graphics, Photo, Custom, Dolby Vision Bright, Dolby Vision Dark, Netfix calibrated -- -- -- --
    Precision Color
    Mapping
    Super Bit Mapping™
    4K HDR
    Yes -- -- -- --
    Video Processing 4K X-Reality PRO -- -- -- --
    Wide Mode Wide Zoom / Normal /
    Full / Zoom
    Normal / Full1 / Full2
    for PC
    Audio
    Audio Power Output: -- -- -- 10W + 10W -- -- -- -- --
    Bass/Treble/Balance: -- -- -- Balance -- -- -- -- --
    Speaker Confguration: -- -- -- 2ch/Full Range (Bass
    Refex)(25x90mm)x2,
    Tweeterx2
    Speaker Position: -- -- -- Side Back + Down Firing -- -- -- -- --
    AUDIO Acoustic Surface Audio+
    Support for Dolby Atmos will be provided through a future software update
    Acoustic Surface Audio Acoustic Multi Audio
    TV Centre speaker Mode
    2+2 speakers
    2 speakers
    2 + 2 speakers
    2 speakers
    Audio Features
    Advanced Auto Volume: Yes -- -- -- -- --
    Alternate Audio (Digital): Yes -- -- -- -- --
    ARC Output Format : -- -- -- Two channel linear PCM:
    48 kHz 16 bits,Dolby
    Digital,Dolby Digital
    Plus,DTS
    Auto Surround: Yes -- -- -- -- --
    Clear Phase: Yes -- -- -- -- --
    Digital audio out
    (Optical) format:
    Digital,DTS
    Dolby audio format
    support:
    -- -- -- Dolby Audio (Dolby
    Digital, Dolby Digital Plus,
    Dolby AC-4)
    DTS audio format
    support:
    DTS Digital Surround -- -- -- -- --
    HDMI Audio Return
    Channel(ARC):
    Yes (eARC)return audio to an audio device via HDMI in high resolution
    (support Lip Sync Correction, Uncompressed 7.1 & 5.1, Dolby TrueHD, Dolby Atmos, DTS: X)
    HDMI input Audio
    format:
    5.1 channel linear PCM:
    32 / 44.1/ 48/ 88.2/96/ 176.4/ 192kHz 16/20/24bits, Dolby Digital, Dolby Digital Plus, DTS
    Simulated Surround
    Sound:
    -- -- -- S-Force Front Surround -- -- -- -- --
    S-Master: S-Master Digital Amplifer -- -- -- --
    Sound Modes: -- -- -- Standard, Dialog,
    Cinema, Music ,Sports,
    Dolby Audio
    Convenience Features
    Application Store: Yes (Google Play Store) --
    Auto Picture Mode: Yes -- -- --
    Auto Shut-of: Yes -- -- --
    Channel Block (with
    password):
    Analog & Digital -- -- -- --
    Chromecast built-in: Yes -- -- -- --
    HDMI-CEC: Yes -- -- -- --
    i-Manual: Yes -- -- --
    On/Of Timer: Yes -- -- -- --
    On-Screen Clock: Yes -- -- -- --
    Parental Control: Yes -- -- -- --
    Show/Hide Channels: Yes (Digital & Analog) -- -- -- --
    Sleep Timer : Yes -- -- -- --
    Text Input Language: -- -- --
    USB drive format
    support:
    Yes (Supported File
    System: FAT16/FAT32/
    exFAT/NTFS)
    USB playback codecs: MPEG1: MPEG1/
    MPEG2PS: MPEG2/
    MPEG2TS (HDV,AVCHD): MPEG2,AVC /
    MP4 (XAVC S): AVC ,MPEG4,HEVC /
    AVI: Xvid, MotinJpeg/
    ASF(WMV): VC1/
    MOV:AVC, MPEG4, MotionJpeg/
    MKV: Xvid, AVC,MPEG4, VP8.HEVC /
    WEBM: VP8/
    3GPP: MPEG4, AVC /MP3 /ASF (WMA) /WAV/ MP4AAC / FLAC /
    JPEG WEBM: VP9/ AC4/ogg/AAC/ ARW(Screen nail only)
    Voice Search: Yes*
    *Hands Free feature(Builtin Mic) availability depends on language and may need sofware update.
    Please check Sony support page for further information;
    https://www.sony.net/tv-hf-ww/
    Inputs and Outputs
    4K 60P High-Quality
    formats
    - - HDMI IN1, IN2, IN3, IN4
    ports for 4K(up to 6Gbps)
    signal
    Analog Audio Input(s)
    (Total)
    - - 1 (1Side Analog
    Conversion)
    Bluetooth profle
    support
    Version 4.2 - compatible HID/HOGP/SPP/A2DP/AVRCP profiles
    HIDP (Human Interface Device Profile) - Mouse / Keyboard Connectivity
    HOGP (Low Energy Consumption)
    SPP (Serial Port Profile)
    A2DP (Advanced Audio Distribution Profile) - stereo audio
    AVRCP (A/V Remote Control Profile) - AV remote control
    Composite Video
    Input(s)
    - 1 (Side) - -
    Digital Audio Output(s) 1 (Bottom) - - - -
    Ethernet Connection(s) 1(Bottom)
    10BASE-T / 100BASE-TX Connector (The connection speed of the network may vary depending on the operating environment.)
    10BASE-T / 100BASE-TX communication speed and quality are not guaranteed for this TV. )
    HDCP HDCP2.3(for
    HDMI1/2/3/4)
    HDMI inputs total 4 x v.2.0b (1Side,3Bottom)- no VRR, QMR - 4 x v.2.0b (1Side,3Bottom)- no VRR, QMR - - - -
    HDMI Signal 4096x2160p (24,60Hz),
    3840x2160p (24,30,60Hz),
    1080p (30,60,120Hz),
    1080/24p, 1080i (60Hz),
    720p (30,60Hz), 720/24p,
    480p
    HDMI™ PC Input 640 x 480 (31.5kHz,60Hz),
    800 x 600 (37.9kHz,60Hz),
    1024x768 (48.4kHz,60Hz),
    1280x1024 (64.0kHz,60Hz),
    1152x864 (67.5kHz,75Hz),
    1600x900 (55.9kHz,60Hz),
    1680x1050 (65.3kHz,60Hz),
    1920x1080 (67.5kHz,60Hz)
    Headphone Output(s) 1 (Side) - -
    RF Connection Input(s) 1 (Bottom) -
    RS-232C Input(s) 1 - - - -
    USB Port(s) - - 2 (Side) / 1 (Bottom)
    USB 2.0 (Type A)(x2) [speed up to 480Mbps]
    USB 3.1 Gen 1 (Type A) [speed up to 5Gbps]
    Network Features
    Codec for Home
    Network
    MPEG1: MPEG1/
    MPEG2PS :MPEG2 /
    MPEG2, AVC/ MP4(XAVC
    S): AVC, MPEG4, HEVC/
    ASF (WMV): VC1/
    MOV: AVC, MPEG4,
    MotionJpeg/ MKV: Xvid,
    AVC, MPEG4, VP8.HEVC/
    WEBM: VP8/ 3GPP:
    MPEG4, AVC /MP3/ ASF
    (WMA) /LPCM /WAV /
    MP4AAC /FLAC/ JPEG
    DLNA HOME NETWORK CLIENT, HOME NETWORK RENDERER (Digital Media Player / Digital Media Renderer)
    (Digital Living Network Alliance) Founded in 2003 as the Digital Home Working Group, the DLNA (www.dlna.org) sets guidelines for using the Universal Plug and Play (UPnP) protocol to transfer and stream media between computers, mobile devices and home theater equipment.
    Internet Browser: Vewd (Not Pre-Installed) Opera TV is now Vewd. -
    Screen
    mirroring(Miracast™)
    YES (only for B2B purpose) MHL 3.0 -
    Wi-Fi Wi-Fi network 802.11 compatible a / b / g / n / ac , Wi-Fi Frequency 2.4GHz / 5GHz
    Compatible network: Wi-Fi Direct ™ (without router)
    Auto Low Latency Mode (ALLM) 15 ms
    Extremely Low Input Lag
    20 ms
    Low Input Lag
    HDMI-VRR
    variable refresh rate
    YES - -
    Smartfone Connectivity:
    Chromecast built-in
    Video & TV SideView (iOS/Android)
    Remote control(s): new remote - new remote - - - - -
    Design:
    Frame color:
    Color / Base Type:
    Този пост е редактиран от hristoslav2; 30-01-19 в 22:17.
    emil22, svetlio1, daniel72 и 1 други харесват това.
    Sep 2018
    #92
    XG85 са с X1 а не с X1 extreme.
    hristoslav2 одобрява това.
  4. Junior Member Аватара на Milen Berberov
    Sep 2012
    #93
    Здравейте ,да попитам знае ли някой 55XF9005 поддържа H265 ,пробвах модула на А1 и само звук имам на каналите ?
  5. Senior Member Аватара на iveto
    Jan 2013
    Свети Влас
    #94
    Да,поддържа H265...но това няма нищо общо с CA модула,който предполагам са ти дали от А1 за да гледаш телевизия...
    Milen Berberov одобрява това.
  6. Junior Member Аватара на Milen Berberov
    Sep 2012
    #95
    Голяма мъка са тия модули на А1 ,тогава какво може да се направи че не ми се взима техен приемник ?
  7. Senior Member Аватара на iveto
    Jan 2013
    Свети Влас
    #96
    Мъка е защото са тояги,имам 4 телевизора с CA модули в къщи,като само единия е от А1,и само с него имам проблеми,другите съм си ги купувал от магазина по 60-70лв. бяха преди години,сега незнам колко са...с тях нямам никакви грижи...така че,проблема,не е във Вашия телевизор
  9. Senior Member Аватара на sony 1
    Dec 2016
    #97
    Milen Berberov
    Викни ги техниците да си го настроят модула.
  10. Junior Member Аватара на Milen Berberov
    Sep 2012
    #98
    Аз гледам с модула от лятото ама сега искам да гледам от 39 гр щот скоро ше спират от стария спътник ,на 16 гр няма проблем ,но там не са с новия кодек явно там е проблема
  11. Junior Member
    Feb 2008
    #99
    Тне Voice не е кодирана в пакета на А1 . Би трябвало да работи на Hellas Sat 3 ако телевизора ти поддържа HEVC .
    Този пост е редактиран от emil22; 28-01-19 в 21:16.
  12. Junior Member Аватара на Milen Berberov
    Sep 2012
    #100
    Цитат Първоначално публикувано от emil22 Виж публикацията
    Аз първо него пробвах и той има само звук
  13. Junior Member
    Feb 2008
    #101
    Значи проблема е в телевизора или от A1 нещо са омазали нещата с излъчването .
    За съжаление нямам насочена антена към 39 Е, за да пробвам сателитния тунер на Philips 8303 как ще се справи .
  15. Junior Member Аватара на Milen Berberov
    Sep 2012
    #102
    Днес се отваря един боксов канал ,явно проблема не е в Тв. а си е на Ментела
  16. Junior Member
    Feb 2008
    #104
    Цитат Първоначално публикувано от Milen Berberov Виж публикацията
    Има нещо сбъркано в цялата работа.
    Моя Philips 55PUS8303 отваря без проблем UHD и HD каналите, които са свободни на Astra и се излъчват в hevc h.265 .
    А при свободните SD канали в hevc h.265 - черен екран и звук ?!?
  17. Senior Member Аватара на sony 1
    Dec 2016
    #105
    Да ни е честит Android 8 Oreo
    Най накрая излезе
    https://www.sony.bg/electronics/supp...loads/00015793
  1. Избор на климатик '2019
    Отговори: 3063
    Последно: 04-01-20, 11:11
  2. SONY телевизори 2018
    Отговори: 911
    Последно: 02-01-19, 14:40
  3. SONY телевизори 2017
    Отговори: 1108
    Последно: 01-01-18, 07:21
  4. SONY телевизори 2016
    Отговори: 1640
    Последно: 01-01-17, 18:45
  5. SONY телевизори 2015
    Отговори: 866
    Последно: 02-01-16, 08:36
