Страница 8 от 11 ПърваПърва ... 678910 ... ПоследноПоследно
Резултати от 106 до 120 от общо 152
Miranda или QIP
    May 2004
    #106
    Re: Miranda или QIP
    QIP 7970
    Код:
    Added:
    - optional: NTLM authentication support for proxies based on MS Windows platforms;
    - optional: launch qip on startup;
    - optional: possibility to disable showing of birthday balloons;
    - optional: possibility to disable showing of how long user was idle in Away, NA statuses;
    - close tab after sending message feature (Send button popup menu);
    - future qip clients identification for mobile platforms;
    Fixed/Updated:
    - [upd] drawing images on buttons methods for MS Windows Vista compatibility;
    - [upd] if messaging window is active with user who sent message then sound of incoming message will not be played;
    - [upd] addopt.bmp, added new icons for future qip clients for mobile platforms;
    - [upd] if contact hint is showing then received custom status text will be updated on hint directly;
    - [upd] selection, quoting behavior in messaging window;
    - [upd] tray clicks handling function;
    - [upd] if using /ifa command line parameter then qip sets Invisible For All on server before closing;
    - [upd] protocol and messaging module;
    - [fix] messaging window taskbar button sometimes stays highlighted;
    #107
    Re: Miranda или QIP
    Една чудесна статия, която отива още малко по-далече от обсъжданията в тази тема - тук
    May 2004
    #108
    Re: Miranda или QIP
    QIP 7980
    Код:
    Recommended update.
    Attention! This build is out little bit earlier than planned, because of some ICQ server bug consequences
    which were found by the author of qip. You can read more in our forum.
    Added:
    - optional: possibility to not play sound of incoming message when messaging window and tab is active;
    Fixed/Updated:
    - [upd] showing of user's client and version in popup message window when checking not in list user status;
    - [upd] user details window: added zodiac sign showing in user birth date info (don't forget to add signs.bmp
    	to skins folder in case if you don't use default skin);
    - [upd] grouped statuses in context popup menu;
    - [upd] ntlm authentication functions (you have to use domain name with username in connection settings window);
    - [upd] docking.dll file, updated docking functions (don't forget to replace old file if you update qip using archived file);
    - [upd] removed command line parameter /agree;
    - [upd] password change window: added checkbox to see what typing in fields;
    - [upd] user details window: Attached email showing in Additional/Information tab in case if it is localized account;
    - [fix] low priority errors fixes;
    Nov 2003
    #109
    Re: Miranda или QIP
    Преди време в една друга тема (за Thunderbird) стана въпрос и за сигурността при Миранда. Намирам, че плугина SecureDB+Autobackup върши чудесна работа. В момента съм на WIN'98 (на работа) и не мога да проверя QIP дали може да криптира историята, но с този плугин за Миранда се защитава цялата база на профила и без да знаеш паролата, не може нито да се логнеш, нито да импортираш съобщенията в друг профил, нито да гледаш съобщенията. В QIP ме подразни простото записване в текстов файл на лога на съобщенията. Възможно е да има и там някакво разширение не съм проверил още, за което се извинявам.
    Mar 2006
    #110
    Re: Miranda или QIP
    има ли възможност по qip да се пращат малки файлове?
    Apr 2004
    #111
    Re: Miranda или QIP
    Цитат Първоначално публикувано от brankod
    Да, има възможност от Preferences > General > сложи тикче на Enable File Transfer...
    Mar 2006
    #112
    Re: Miranda или QIP
    Цитат Първоначално публикувано от hypperion
    мерси
    Dec 2003
    #113
    Re: Miranda или QIP
    Отдавна забелязвам едно странно поведение при QIP - след дълго (24+ часа) висене online (или друг свързан статус) в един момент ме disconnect-ва и излиза сервизно съобщение от типа "Error message: Server Pause/Shutdown command received, reconnect please", при което се налага респективно да reconnect-на.
    На някой да му се случва същото нещо? Нямам спомен с Miranda да съм търпял такъв проблем...
    #114
    Re: Miranda или QIP
    Ами не. Да не би да си на PPPoE връзка и динамично IP с доставчика си... и да те disconnect-ва след 24 часа примерно (аз едно време в Младост бях така към HomeLan). Само за това ми иде на ума. Ама пък QIP-а си е достатъчно умен, за да си се reconnect-не сам, така че
    А и нали Miranda-та, казваш, не правела така. Откакто мина от Miranda на QIP да си сменял доставчик?
    Dec 2003
    #115
    Re: Miranda или QIP
    Цитат Първоначално публикувано от Slero
    Тц. Служебно съм си бил на БТК.нет винаги. :\
    Dec 2003
    #116
    Re: Miranda или QIP
    При мен има дни в които това съобщение (Error message: Server Pause/Shutdown command received, reconnect please) ми го дава 4-5 пъти за 1-2 часа. Нещо май не се разбира с някои сървъри както трябва. И това на qip пуснат 2-3 часа по-рано.
  15. Moderator Аватара на glowndark
    Oct 2004
    #117
    Re: Miranda или QIP
    QIP
    Feb 2006
    #118
    Re: Miranda или QIP
    May 2004
    #119
    Re: Miranda или QIP
    QIP 7981
    Код:
    Actually this is QIP 2005 Pre 7990 build, but because of last server updates we have to release
    this build before the day we planned.
    If you experience server connection problem and QIP shows "Unknown server error" then you should
    update your version to this one. Else you should wait for the next QIP build planned on the next week.
    May 2004
    #120
    Re: Miranda или QIP
    QIP 7990
    Код:
    Recommended update.
    Added:
    - preferences window: events volume control;
    - command line parameter /sndold - to use old sound playing engine;
    - messaging window: client version showing instead of '...' in the typing panel;
    Fixed/Updated:
    - [upd] new skin file msgbge.bmp can be added for message typing window;
    - [upd] messaging window: hot keys handling function;
    - [upd] messaging window: if there is an email in email panel then double click will act like mailto link;
    - [upd] protocol module:
    - [fix] user details window: wrong some dates of zodiac signs;
    - [fix] command line parameter /ifa ignored after switching user;
    - [fix] case sensitivity for group when renaming;
    - [fix] a lot of small code updates;
  1. Miranda IM, версия 0.9.8
    От kod във форум Новини от SetCombG.com
    Последно: 19-10-10, 16:13
  2. BG речник и за Miranda
    От universum във форум Общ - софтуер
    Последно: 19-11-06, 19:52
  3. Miranda Problem
    От MiSteR във форум Общ - софтуер
    Последно: 15-02-06, 17:03
  4. Miranda authorization
    От BBB във форум Общ - софтуер
    Последно: 01-04-04, 00:25
