Резултати от 16 до 30 от общо 38
Celeron @ 800
    Aug 2002
    #16
    Celeron @ 800
    HGD - не видях да пише ядрото на Celeron II ( mendochino , или Coopermine )
    a дали съм подгортвен - да ти кажа май много-по добре от теб
    а и тия процесори са на 1,75 , а не на 1,5 V
    na 1,5 - 1,45 sa FCPGA2
    ади провери пак и ела
    Sep 2002
    #17
    Celeron @ 800
    ае вярно ли е че тоз преходник струва към 20 евро ?
  4. HGD
    HGD е офлайн
    Member
    Jul 2003
    #18
    Celeron @ 800
    <blockquote id="quote"><font size="1" id="quote"><b id="quote">цитат:</b id="quote"></font id="quote"><table border="0" id="quote"><tr id="quote"><td class="quote" id="quote"><font size="1" id="quote">HGD - не видях да пише ядрото на Celeron II ( mendochino , или Coopermine )
    <div align="right">оргинално мнение на Mr.TECHNO</div id="right">
    1,75 е при overclocking с повишаване на напежението. Стандартно е 1.5!!!
    Celeron II Coppermine
    Performance Rating 533 – 1300+ MHz
    Generation Sixth: 80686 IA-32
    Operational Rates Level 1 Cache Speed 1.0#215; Core Rate
    Level 2 Cache Speed 1.0#215; Core Rate
    Front-side Bus Speed 66 – 100 MHz
    Multiplier Ratio 5.0#215; – 13.0+x
    Physical Design Interface Packing 370-Pin FCPGA Socket
    Core Die Size .18 micron
    Core Size by Stepping A2 = 106 mm2
    B0 = 104 mm2
    CO = 90 mm2
    D0 = 95 mm2
    Transistor Count 28.1 Million Total
    #189; Cache Disabled
    Voltage Interface Split Core and I/O
    Core Voltage 1.5 volts
    I/O Voltage 3.3 volts
    Level 2 Cache Voltage 3.3 volts
    Power Consumption 9 – 22 watts
    Maximum Power 14 – 33 watts
    Architectural Design Core Technology OOO and Speculative
    Execution RISC
    Register Support Integer = 32 bit
    FPU = 80 bit
    MMX = 64 bit
    SSE = 128 bit
    Execution Units 2 #215; ALU/MMX/SSE
    1 #215; Pipelined FPU
    Maximum Execution Rate 5 Micro-Ops per Cycle
    Data Bus Width 64 bit
    Maximum Memory Support Physical = 64 Gigabyte
    Virtual = 64 Terabyte
    Multi-Processor Support 2-way SMP via APIC
    Level 1 Code Cache 16 KB 4-way
    Level 1 Data Cache 16 KB 4-way
    Level 2 Cache 128 KB Unified
    Read Buffer 4 #215; 32 Byte
    Write Buffer 32 Byte
    Pre-fetch Queue 32 Byte
    Static Branch Prediction Supported
    Dynamic Branch Prediction 512 Entry 4-way
    RSB Branch Prediction 4 Entry
    Floating-Point Processor Integrated
    Multimedia Extensions MMX, SSE
    Celeron Tualatin
    Performance Rating 1130 – 1260+ MHz
    Front-side Bus Speed 100 – 133 MHz
    Multiplier Ratio 8.5#215; – 13+x
    Physical Design Interface Packing 370-Pin FCPGA2 Socket
    Core Die Size .13 micron
    Core Size by Stepping 80 mm2
    Transistor Count 256 KB = 28.1 Million
    512 KB = 44 Million
    Core Voltage 1.45 – 1.475 volts
    Power Consumption 15 – 21 watts
    Maximum Power 12.8 – 31.2 watts
    Architectural
    OOO and Speculative Execution
    RISC
    FPU = 80 bit
    MMX = 64 bit
    SSE = 128 bit
    Maximum Memory
    Level 2 Cache 256 – 512 KB Unified
    Dynamic Branch
  5. HGD
    HGD е офлайн
    Member
    Jul 2003
    #19
    Celeron @ 800
    <blockquote id="quote"><font size="1" id="quote"><b id="quote">цитат:</b id="quote"></font id="quote"><table border="0" id="quote"><tr id="quote"><td class="quote" id="quote"><font size="1" id="quote">ае вярно ли е че тоз преходник струва към 20 евро ?
    <div align="right">оргинално мнение на MAKAPOB</div id="right">
    20 лева (ако е нов) е по-вероятна сума за MSI. А втора употреба - 10-тина.
    Jun 2003
    #20
    Celeron @ 800
    значи,
    дънцето ми е iBX440/Slot 1 , използвам Slot1/s370 "Slocket" NO NAME !,
    без никакви преработки подкарвам:
    Celeron 366A/s370/Mendocino
    Celeron 466/s370/Mendocino
    Celeron 766/s370/Coppermine
    пък вие си умувайте !
    извода е:
    зависи от дъното - ако поддържа 1.5V - тръгват всякакви P II/III CPU-та
    Sep 2002
    #21
    Celeron @ 800
    ами в момента е 2V и то само си задава волтажа на процесора
    Dec 2003
    #22
    Celeron @ 800
    as imam edin vapros:
    kak moje da trqgne procesor na duno prez S370 ako dunoto e s vgraden slot 1 ili socket A?
  10. Senior Member Аватара на breiii
    Oct 2003
    #23
    Celeron @ 800
    smokeless има преходник от Slot1 към FCPGA или FCPGA2. Няма такъв от socket A.
    П.П. Въпросвай на кирилица[]
    Jan 2002
    #24
    Celeron @ 800
    МАКАРОВ
    Онези за 20 евро май стават и за Туалатини - поразпитай.
  12. Senior Member Аватара на breiii
    Oct 2003
    #25
    Celeron @ 800
    <blockquote id="quote"><font size="1" id="quote"><b id="quote">цитат:</b id="quote"></font id="quote"><table border="0" id="quote"><tr id="quote"><td class="quote" id="quote"><font size="1" id="quote">МАКАРОВ
    <div align="right">оргинално мнение на srg_o</div id="right">
    FCPGA2=Tualatin
    Jan 2002
    #26
    Celeron @ 800
    Да бе, това имах предвид, само че говорих с човека и май не е така... май са обикновени fcpga-slot1, само че са суперскъпи.. .след Нова Година все пак ще отида да видя...
  15. Senior Member Аватара на breiii
    Oct 2003
    #27
    Celeron @ 800
    Имам познат на познат (на баба му хвърчилото) който отиде да си купи преди време 1 преходник от Slot1 към FCPGA и 1 FCPGA към FCPGA2. Нямам връзка с него и нямам представа дали се е получило нещо с тази комбинация.
    Ако искаш и мислиш че си заслужава...
    Jan 2001
    #28
    Celeron @ 800
    Има FC-PGA Celeron на различни волтажи. Това за Mr. Techno и HGO. И двамата са прави, тъй като Intel им задават /"поставят"/ напрежението според честотата и партидата. В общи линий съм виждал всякакви варианти между 1.5V и 1.75V.
    Aug 2002
    #29
    Celeron @ 800
    <blockquote id="quote"><font size="1" id="quote"><b id="quote">quote:</b id="quote"></font id="quote"><table border="0" id="quote"><tr id="quote"><td class="quote" id="quote"><font size="1" id="quote"><blockquote id="quote"><font size="1" id="quote"><b id="quote">цитат:</b id="quote"></font id="quote"><table border="0" id="quote"><tr id="quote"><td class="quote" id="quote"><font size="1" id="quote">HGD - не видях да пише ядрото на Celeron II ( mendochino , или Coopermine )
    <div align="right">Originally posted by HGD*-*23/12/2003*:* 21:58:57</div id="right">
    [/quote]
    HGD тук оак су сгрешил - ади покажи ми процесор FC-PGA на който да има написано на самия чип че е 1,5 V
    досега които съм асемблирал и продавал са с 1, 7 / 1,75 V и то си го пише на самия процесор - тук имам три пред мен , и на трите пише 1,7 V ( това може би означава че са овърклокнати ? )
    това че четеш е много хубаво - поздравления , но може за малко разнообразие и да потвърдиш литературата с практика ( а за мен обратното [] )
    ПП
    досега не съм срещнал процесор FCPGA с 1,5V ( FC-PGA2 - да те са от 1,55 - 1,45V )
    ако някой има - да ми се обади ( BTW - не съм привърженик на снимките - мога да направя да пише каквото си искам аз - с малко Photoshop , и др. там известни или неизвестни програмки
    Jan 2001
    #30
    Celeron @ 800
    Значи не си асемблирал системи със Celeron FC-PGA 533/566. Те са на 1.5V.
  1. Celeron-D 341
    От bx във форум Процесори и Дънни платки
    Последно: 23-02-06, 14:17
  2. Celeron 566
    От ODB във форум Овърклок
    Отговори: 17
    Последно: 22-05-03, 13:40
  3. @ na Celeron na 700
    От Atholon във форум Овърклок
    Последно: 30-10-02, 13:16
  4. Celeron 1.3A
    От XM6002B във форум Процесори и Дънни платки
    Отговори: 13
    Последно: 19-05-02, 16:13
  5. celeron 800 ?????????????
    От mitak във форум Овърклок
    Отговори: 40
    Последно: 12-12-01, 22:55
