718. Не можете да гласувате в тази анкета
  • Качество на картината
    662 92.20%
  • Качество на звука
    216 30.08%
  • Приемлива цена
    337 46.94%
  • Лесен за употреба
    127 17.69%
    56 7.80%
    181 25.21%
    239 33.29%
  • Последна технология
    117 16.30%
    121 16.85%
  • Атрактивен дизайн и стил
    104 14.48%
    282 39.28%
  • Вграден интернет достъп
    187 26.04%
    124 17.27%
  • Безжична интернет връзка
    197 27.44%
  • USB запис
    80 11.14%
  • Ultra HD TV
    226 31.48%
  • 3D съвместимост
    61 8.50%
  • Oled TV
    46 6.41%
    8 1.11%
  • Curved TV (огънат екран)
    14 1.95%
Отговори на анкетата
Страница 16 от 627 ПърваПърва ... 614151617182666 ... ПоследноПоследно
Резултати от 226 до 240 от общо 9395
Like Tree1854Одобрявам
    #226
    New LG RGBW 4K Ultra HD LCD Line Sparks Debate | HD Guru
    A new entry level 4K Ultra HD LCD TV line LG Electronics dropped in the U.S. market two weeks ago has started to create a stir over how to define 4K UHD resolution.
    LG’s new UF6800 LED LCD TV series, which includes 55- and 65-inch screen sizes, features a controversial new LCD panel that uses a white sub-pixel, along with the standard Red, Green and Blue (RGB) sub-pixels that make up each pixel, in order to produce a lower-cost 4K Ultra HD LCD TV.
    Critics, who contacted HD Guru about the new sets, say the additional white sub-pixel reduces the number of RGB sub-pixels in the 3840 pixel count across the screen, and the set therefore fails to comply with the Consumer Electronics Association’s (CEA’s) terminology for 4K Ultra HD minimum performance attributes...
    HDR Still Not Happening At Retail | HD Guru
    TEST : LG UF8507 / UF8527 / UF850V 55" Ultra HD - LG - HDTV Centrum Polska
    55UF8507: panel W-Ledtype S-IPS,( Contrast: 900:1) 50 Ηz
    Sony X90C review - FlatpanelsHD
    KD-65X9005C: S-IPS panel (ANSI contrast: 662: 1, Black level: 0.198 cd/m2), 100Hz with MCFI + flashing backlight.
    TEST : Philips PUS 7600 48" Android TV Ultra HD - PHILIPS - HDTV Centrum Polska
    Philips 48PUS7600/12 chassis QV15.1E LA, panel W-Led type MVA , (Contrast: 4500:1, Black level: 0.03 cd/m2)100Hz with MCFI + flashing backlight.
    http://hdtvpolska.com/MEGATEST/philis7600/56.jpg
    Panasonic TX-65CR852B (CR852/ CR850) Review
    Този пост е редактиран от hristoslav2; 21-08-15 в 19:12.
  3. Member Аватара на novla
    Dec 2014
    #227
    Мани не пускай телевизори Филипс, че като ги гледам ми иде да си продам Сонито и да си взема Филипс. Philips 48PUS7600 ма като гледам, че е скромните 2600 лв. ... :D
    #228
    Малко са хубавите неща в Philips PUS7600...
    Разделителна способност и размер 3840x2160, 55"
    Тип видеопанел a-Si TFT-LCD тип. MVA, с подсветка Edge W-LED,
    Опресняване на матрицата: 100/120Hz
    Нативен контраст (без гаснене и мигане): 4 500:1
    Контраст при филми: средно: 4 600:1, max: 5 200:1, min: 4 000:1
    Максимална яркост след калибриране 350cd/m2
    Отражения от екрана: средни, екран тип сатен
    Грешки в цветовете след калибриране Средна dE: 1,1 , максимална dE: 2,9
    Резолюция в подвижно изображение 1080 хоризонтални ТВ линии с подобрители,
    300 хоризонтални ТВ линии без подобрители
    Input Lag 83ms в режим игра, 103ms в стандартен режим
    Цветна резолюция (PC - 4:4:4) Не
    Правилно боравене с кадрите 24Hz Да, 50Hz Да, 60Hz Да
    Поддръжка на 10 битов цвят Не
    Поддръжка на резолюция от 3840x2160 @ 60Hz 4:2:0 Да
    Поддръжка на резолюция от 3840x2160 @ 24Hz 4:4:4 Не
    Поддръжка на резолюция от 3840x2160 @ 60Hz 4:4:4 Не
    Тест за възпроизвеждане на SAT UHD TV канал Не
    Поддръжка за файлове UHD кодек HEVC Да
    Поддръжка на YouTube 4K Да
    Съвместим с HDCP 2.2 няма данни
    Относно подчертаното в таблицата
    Philips PUK7100 PUS7100 im Test - AUDIO VIDEO FOTO BILD
    НЕVС вeчe e дocтъпeн зa интepнeт cъдъpжaниe и чpeз UЅВ, нo в мoмeнтa нe и зa caтeлитният тyнep.(зa cepии 6400,7100,7600)
    Този пост е редактиран от hristoslav2; 22-08-15 в 00:09.
    Aug 2015
    #229
    Дали има хубави неща в LG 65UG8709 ??????
    #230
    В Германия или в Австрия ще пазаруваш ? Питам понеже у нас се предлага LG 65UG870V
    LG 65UG8709 | LG Deutschland
    http://www.hifi-forum.de/index.php?a...e&forum_id=145
    Разделителна способност и размер 3840x2160, 65"
    Тип видеопанел a-Si TFT-LCD тип. S-IPS, с подсветка Edge W-LED,
    Нативен контраст (без гаснене и мигане): 900:1
    Контраст при филми: средно: 1 300:1, max: 2 500:1, min: 750:1
    Максимална яркост след калибриране 250cd/m2
    Грешки в цветовете след калибриране Средна dE: 1,3 , максимална dE: 2,4
    Резолюция в подвижно изображение 300 хоризонтални ТВ линии без подобрители
    Input Lag 32ms в режим игра, 40ms в стандартен режим
    Цветна резолюция (PC - 4:4:4) Да при връзка с PC
    Поддръжка на 10 битов цвят Да
    Поддръжка на резолюция от 3840x2160 @ 24Hz 4:4:4 Да
    Поддръжка на резолюция от 3840x2160 @ 60Hz 4:4:4 Да
    Тест за възпроизвеждане на SAT UHD TV канал Да
    Съвместим с HDCP 2.2 Да
    To enable chroma 4:4:4, set the icon of the input to PC. For 4k @ 60hz @ 4:4:4, also enable UHD Deep Color.
    Този пост е редактиран от hristoslav2; 24-08-15 в 00:38.
    Aug 2015
    #231
    В Германия, 2010 си купих LG с Опресняване на матрицата: 50Hz в София и реших пак LG, но едва ли сте е този. Трябва ми разумен модел без OLED.......
    #232
    Не робувай на марки. Кое не ти харесва в UG8790 ? Държиш ли на извит телевизор?
    Aug 2015
    #233
    няма логика 2010 да е 50Hz Опресняване на матрицата и 2015 същата ( не мога да разбера дали е 50 или 100), всъщност ми направи отлично впечатление, гледах около 15 минути Аватар 3Д с пасивни очила на него. Малко е скъп 2650 евро, не е задължително да е извит
    #234
    Лесно е
    Kaĸ дa пpoвepя, дaли LG тeлeвизopът ми e 100Нz?
    Aĸo в нacтpoйĸитe нa пapaмeтъpa зa изoбpaжeниe ТruМоtіоn, имa фyнĸция Dе-Вlur, знaчи тeлeвизъpът e 100Нz, aĸo тaзи фyнĸция я нямa, тo тeлeвизopът e 50Нz.
    LG 2015 TVs: Reviews and Prices
    LG - Artykuły - Articles - HDTV Centrum Polska
    Aug 2015
    #235
    Всъщност ми трябва съвет за избор на нов добър телевизор, без да изпадам в купуване на някакви рекламни трикове примерно OLED или 4k, за които няма излъчване на контент по никой канал и не могат да се ползват
    Aug 2011
    #236
    Всъщност от какво разстояние ще го гледаш и дали под ъгъл?
    Този, малък ли е?
    Aug 2015
    #237
    не е под ъгъл, около 3,5 метра
    Aug 2011
    #238
    60H7000 е идеален за целта. Понеже питаш за реалните херци - 200Hz.
  17. Тук е от
    Aug 2015
    #239
    Сравнявайки LG 65UG8709 срещу SAMSUNG UE-60H7000, 200Hz. на SAMSUNG са сериозно предимство, а LG също има някои добри страни примерно новата WebOS 2.0.Опитвам се да направя генерално сравнение на двата за да разбера накъде да тръгна
    #240
    Samsung UE-65JU7000 - Tizen OS
    Panasonic TX-65CX800 - Firefox OS
    От коя верига в Германия ще го купуваш?
    Отговори: 31
    Последно: 18-05-17, 11:02
    Последно: 22-07-13, 20:30
    Последно: 07-04-13, 09:49
    Последно: 30-12-11, 13:49
    Последно: 29-08-11, 12:00
