Вижте резултатите от анкетата: Как оценявате картината на вашият LCD телевизор LG ?
154. Не можете да гласувате в тази анкета
  • Отлична
    54 35.06%
  • Много добра
    65 42.21%
  • Добра
    22 14.29%
  • Средна
    8 5.19%
  • Задоволителна
    4 2.60%
  • Слаба
    3 1.95%
Отговори на анкетата
Страница 14 от 96 ПърваПърва ... 412131415162464 ... ПоследноПоследно
Резултати от 196 до 210 от общо 1435
Like Tree292Одобрявам
LG LCD & Oled TV / FAQ - на първа страница, обсъждане, мнения /част 5/
    Dec 2002
    #196
    Отговор: LG LCD & Oled TV / FAQ - на първа страница, обсъждане, мнения /част 5/
    LG Service Menu Explorer
    Описание
    NOTE: Don't ask for support on how to modify the parameters and functionality. If you have problems in connection put out power plug for 10s and retry, you don't have to be inside any menu, your TV must be conneted to a ethernet switch/router or WiFi access point, no ad-hoc support. The
    "Authorization Code" is generated and displayed by TV on TV Screen if TV and Phone are configured correctly at the pearing time, is not a code sent with the application.
    Why have I to buy a new remote controller (like Logitech Harmony Remote) when I have an Android phone? It does much more at a smaller price and you can take it with you anywhere!
    This application(the 1st and only that work through network connection) is very simple, use it to enable the two secret service menu of LG TVs, so you can have extra functionality like DIVX and DVR and much more! Now you don't need extra infrared remote controllers! The TV must be connected on a local network with Ethernet or WiFi. The application is tested with 42LW650G but is supposed to work with LEX8, LZ9800, LZ970, LZ9700, LZ9600, LW9600, LW950, LW9500, LW770, LW7700, LW7500, LW650, LW6500, LW570, LW5700, LW5600, LW550, LW5500, LV570, LV5700, LV550W, LV550T, LV5500, LV5400, LV375, LV373S, LV372S, LV3700, LK550, LK530, PZ950, PZ570, PZ950, PZ950, PZ750, PZ550, PZ540, PZ950, PZ570, PZ950, PZ750, 32LV3730, and all models produced in 2011. All 2012 and newer models like LM are not yet supported.
    Jul 2012
    #197
    Здравейте, моля някой ако знае да даде мнение. Гледам кабелна ТВ с два телевизора. При LG M2631 показва сила и качество на сигнала около 85-90%, а при LG 32M660 показва 45-50%. Сменям ги на една и съща букса - все това. На какво може да се дължи......
    #198
    Цитат Първоначално публикувано от mil_21 Виж публикацията
    Различни тунери...софтуер.
    Този пост е редактиран от hristoslav2; 07-06-13 в 20:17.
    jonov одобрява това.
    Jul 2012
    #199
    Благодаря hristoslav 2, ама ме дразни. На аналоговите канали картината при малкия е много по добре, на цифровите не се забелязва. Слагах и усилвател и все тая.
  6. Pat
    Pat е офлайн
    Senior Member Аватара на Pat
    Oct 2003
    #200
    Това е съвсем нормално - колкото екрана е по-малък толкова по-трудно се забелязват шумовете в картината (за аналогов сигнал), поради по-малкото разстояние м/у точките/пикселите на екрана. От тук и картината изглежда по-добра.
    Разпъни един аналогов сигнал на 50' екран и ще ти се прииска да изхвърлиш телевизора.
    При цифровия сигнал няма шумове и разликата в качеството идва от резолюцията и количеството информация в секунда (bit rate) с който се запълва тази резолюция.
    Този пост е редактиран от Pat; 08-06-13 в 10:48.
    zabadara одобрява това.
    Jul 2012
    #201
    OK!
  9. Junior Member
    Apr 2013
    #202
    Хайде да ми е честит 42LA690...
    zabadara, Dominator и Милен Младенов харесват това.
  10. Banned
    Dec 2010
    #203
    Re: LG LCD & Oled TV / FAQ - на първа страница, обсъждане, мнения /част 5/
    Здравейте някой знае ли на LG 32LA620S да ли браузъра му поддържа флаш?Благодаря.
  11. Junior Member
    Jan 2012
    #204
    Отговор: Re: LG LCD & Oled TV / FAQ - на първа страница, обсъждане, мнения /част 5/
    Цитат Първоначално публикувано от patzi Виж публикацията
    Имам желание да му закача някакво иптв на мойто лг лм 649.Някой пускал ли си е някаква листа с канали на някое приложение.Рових из нета но не се оправих, даже се обърках.nStreamVOD-LG това го търсих като приложение и го няма.SSIPTV и него не мога.... Приемам помощ и то май от нулата..
    Аз ползвам това Smart IPTV on LG Smart TV - YouTube Ако имаш въпроси по него питай.
  12. Infraction Users
    Sep 2011
    #205
    Цитат Първоначално публикувано от biglubo Виж публикацията
    И колко канала са достъпни?
  13. Banned
    Dec 2010
    #206
    Очилата от телевизорите от 2011г,стават ли на тазгодишните телевизори 2013г за 3д,може ли да се гледа с тях?
    #207
    Да , ако имаш предвид за пасивно 3Д , а не тия от плазмените им тв (активно 3Д) .
  16. Banned
    Dec 2010
    #208
    Да, става дума очила от LG LW5590 да ли стават на LG LA620S пасивни са!Смятам да си взема един 32инча за спалнята,ама ги продават без очила та да ползвам очилата от стария LG LW5590.
    Mar 2013
    #209
    Стават . Очилата за пасивното 3D и без това са достатъчно евтини . Може да си купиш очила за телевизора в спалнята и да не разнасяш тези от хола всяка вечер .
    Nov 2006
    #210
    Цитат Първоначално публикувано от juspar Виж публикацията
    Поддържа.
  1. Отговори: 1599
    Последно: 30-11-13, 22:51
  2. Отговори: 1607
    Последно: 09-05-13, 19:57
  3. Отговори: 1511
    Последно: 20-10-12, 12:45
  4. Отговори: 1429
    Последно: 11-06-12, 16:00
  5. Отговори: 1375
    Последно: 30-09-11, 17:31
