Страница 46 от 88 ПърваПърва ... 36444546474856 ... ПоследноПоследно
Резултати от 676 до 690 от общо 1320
Like Tree121Одобрявам
Samsung LCD & OLED TV / FAQ - на първа страница (2014)
    Apr 2014
    #676
    Отговор: Samsung LCD & OLED TV / FAQ - на първа страница /част 6/
    I understand, there is no worth to change my F6400 to F6300 (for ex.)...I studied on ebay the mainboard from f6400 and f6500...on some submodel it is really loked the same.
    On german forum writes about f6470 to f6640 ....that's why i think that it could work on my tv also(f6400 to f6600). Anyway i also found this on russian forum that you indicated:
    "Today finally figured out how to UE22F5400AK (well, and other TV series F) to extend the smart application of the older model. Just through the service menu translated his model UF7200: press on the remote INFO-MENU-MUTE-POWER. Next:
    Option-SW MODEL. Choose model arrows left and right. Turn off the TV find UF7200. On again cherished by a combination of three keys.
    If image crumbles and rattles, do the following:
    Option-Option-MRT Lvds Format. And adjusting the keys left and right, until the image is normal. Turn off the TV. Turn in normal mode and go to Smart Hub. Voila! Ship dates of application. After downloading I think to revert to its model. because suspect. that the processor in this model may be weak. Although this is purely amateurish opinion."
    Този пост е редактиран от hristoslav2; 24-05-14 в 00:05.
    #677
    Check if the firmware version is the same for both models. If they are the same, you can change the model in the service menu.
    LVDS -
    this is the interface of videopanel.
    Apr 2014
    #678
    LVDS -
    According to this tabel :
    https://forum.setcombg.com/%D1%82%D0...82-6-a-20.html
    posted by you it's based on a same MStar12 chipset. Major differences is the presence of DVB-s2 tuner, microdiming, cmr. But if i not touch the tuner type , panel type, still remain chance of brick?
    #679
    Този пост е редактиран от hristoslav2; 24-05-14 в 18:52.
    Apr 2014
    #680
    Ok, i change it. Model:uf6600, MOB:6640, as i find on a german forum.
    Samsung UE46F6500 Test/Einstellungen, Samsung - HIFI-FORUM (Seite 15) ... #705
    Now i have a +option in picture menu:Black level optimization (realy do not known if it working or not, i just don't see the difference when changing it). maybe is placebo but maybe image is look somewhat crisper...need to test more.
    Maybe you remind me from Philips forum..i had the chance to change that Philips with this TV set
    Thank you for your help.
    hristoslav2 одобрява това.
    #681
    @hristoslav2-е, ИНАЧЕ яко заклеймяваме, който пише на български с латински букви, ама яко толерираме в български форум да си пише на ***** майчин език ТОЧНО на 24 май без грам уважение и забележка на великите ни администратури-прехласнати в отговори и окумяване по чуждите недъги към НАШИЯТ най-великия български ВСЕЛЕНСКИ език! И точно поради това на тази смешна планета Земя - още милиони години яко ще ни пренебрегват всички доказано посещаващи ни извънземни раси - просто ей така минаващи през нас като разхайтен крайпътен хан с евтини проститутки за зареждане с гориво от долни страсти. Нищо лично!!! Нула уважение в този форум с надсмешка точно на 24 май!
    Не виждам какъв е проблема, всеки, който не е българин по народност да пише на английски език във форума.
    Това е масова практика по повечето чуждестранни форуми и не се смята за нарушение.
    От друга страна, ти с хамалския и просташки език, който демонстрираш точно на 24 май, трябва да се замислиш, кой проявява неуважение.
    Нищо лично.
    mod/edit
    Този пост е редактиран от Momchil; 25-05-14 в 11:52.
  9. Pat
    Pat е офлайн
    Senior Member Аватара на Pat
    Oct 2003
    #682
    И какво общо има писането на английски или български език на която и да е дата. Ти не схващаш ли че човека не е българин и не знае български. На какъв език искаш да пише - на занзибарски? Английският е признат международен език за комуникация. Няма нищо по-нормално във форум в който не знаеш местния език да пишеш на английски. Това няма нищо общо с така наречената шльокавица.
    Dominator одобрява това.
  10. Member Аватара на legaltk
    Sep 2012
    #683
    От друга гледна точка това е признание за авторитета на един БГ-форум.
    Радостно е, че потребители извън БГ се обръщат към форума, за което голяма заслуга имат и модераторите.
    root666, Dominator и Frogst харесват това.
    #684
    Е, щом е така:
    okgrjgji0eug0\wr9JFoijfgjrkogkdogpdti3w-r;f.][aepfg
    В случаят това е единственият начин на комуникация. Лично аз съм писал на англииски в полски форум и не съм имал проблем с модераторите. Проблемът е когато българин пише на латиница - това е неуважение към правилата на форума и писмеността ни. Имаше такъв случай - българин живеещ в Турция, но пишещ тук на латиница. След направена от мен забележка - спря да пише(но не и да чете). Нищо не му пречи да си купи една клавиатура за 20 лева! За твое сведение 35% от посетителите на форума са чужденци. Влез на този сайт http://www.flagcounter.com/ подбери си броят държави...после ще получиш линк на имейла си, който можеш да поставиш в подписа на профила си. Така ще следиш колко чужденци и от кои държави посещават форума.
    След като блокирах достъпа до имейла си, повечето от тях предпочитат да ми пишат на лични.
    mod/edit
    Този пост е редактиран от hristoslav2; 25-05-14 в 12:41.
    #685
    Въпрос към собствениците на С6000
    Цитат Първоначално публикувано от dimon
    Да те попитам нещо тънко, ако случайно си срещал решение..., понеже много четеш.
    Става дума за моделите UEXXC6000. Това са моделите с най-сполучливите матрици според мен. Имам няколко при мен с дефектирали мейн бордове след ползване на CI . След 2-3 дневно ползване на карти от кабелна телевизия мейн борда умира. Прави опити за включване и рестарти. Нищо физически не дефектира, но дотам. Цените на бордовете варират между 250-300 лв , което не е икономически изгодно. Сподели , ако си срещал някъде друго решение като префлашване или н.п. !
    Поздрави !
    Тези които са имали проблем или нямат такъв, нека да напишат към кой кабелен оператор са и какъв Кам модул и карта ползват.
    http://www.flatpanelshd.com/review.p...&id=1401086199
    Nov 2013
    #686
    Здравейте
    появи се някакъв проблем с картината ми изведнъж стана в зелен нюанс
    бях влезнал в сервизното меню да си отравя стартирането на "souarce" исега забелязах че картината ми бие леко в зелено-жълто
    модела ми е 2013 г Ue32F6500
  15. mvb
    mvb е офлайн
    May 2014
    #687
    Привет от мен. Вчера се сдобих с UE32F4500. Порових из форума, но не можах да намеря инфо за оптимални настройки на картината при стандартен режим - контраст и т.н. Виждам, че има детайлни настройки за други модели, но за този няма. Пробвах се и с гугъл, но отново безуспешно. Мога ли да пробвам настройките дадени за по-висок клас модели тук или ако може някой имащ подобен телевизор и повече опит да даде съвет. Ползвам цифрова ТВ на Мегалан и я вързах към скарт буксата на ТВ-то. Благодаря предварително.
    #688
    Цитат Първоначално публикувано от georgimv Виж публикацията
    Здравейте
    Ааа..пипал си нещо което не трябва. Помисли добре и си спомни,какво си правил в сервизното стъпка по-стъпка и после върни първоначалните му настройки каквито са били преди да влезеш. И повече не пипай там...
    Цитат Първоначално публикувано от mvb Виж публикацията
    Потърси настройки за 32F5500 / 32F5000 - сходни са на твоят модел
    Този пост е редактиран от hristoslav2; 27-05-14 в 16:57.
  17. Тук е от
    Nov 2013
    #689
    то е лесно да се каже сети се какво си направил ама аз докато търсех как да сменя souarce влизах почти навсякъде но не си спомням да съм променял нещо....Няма ли начин да се върнат първоначалните настройки от това меню...Благодаря предварително
    #690
    Не. Трябва някой да ти прати снимки от всички страници в сервизното меню, а ти да ги сравниш с тези в твоят телевизор. Другият начин е в сервиза..
    georgimv одобрява това.
  1. OLED Телевизори - съвети и обсъждане
    От hristoslav2 във форум Телевизори
    Отговори: 1827
    Последно: 16-05-25, 22:15
  2. LG LCD & Oled TV / FAQ - на първа страница /част 6/
    Отговори: 1690
    Последно: 06-01-15, 19:11
  3. Отговори: 1599
    Последно: 30-11-13, 22:51
  4. Отговори: 1607
    Последно: 09-05-13, 19:57
  5. Отговори: 1511
    Последно: 20-10-12, 12:45
