Страница 53 от 72 ПърваПърва ... 343515253545563 ... ПоследноПоследно
Резултати от 781 до 795 от общо 1080
Like Tree203Одобрявам
Samsung телевизори 2017
    #781
    Отговор: Samsung телевизори 2017
    svetlio1
    Още от вчера нещо бъркаш с цената.
    Samsung Q9 review - FlatpanelsHD
    ...Samsung has this year decided to abandon FALD (full-array local dimming) and implemented edge LED its high-end TVs. This is a change from previous years. Q9 is the flagship model and it is equipped with LEDs placed along the sides of the TV, which is a curious decision considering that both Sony and Panasonic are raising the bar for LCD technology by implementing yet more advanced local dimming systems, and especially considering the history of issues that have been associated with edge LED.
    Samsung has also decided to abandon its ‘SUHD’ moniker in favour of ‘QLED’, which is a marketing term for LCD panels with quantum dot technology. Historically, researchers have used the term ‘QLED’ to refer to an entirely new self-emitting display technology but Samsung decided to go ahead and use it to wrap its LCD in sparkling glitter paper. It is clearly meant to confuse consumers to think that ‘QLED’ and ‘OLED’ are related and it is honestly a bit tiring to once again see Samsung’s marketing engine go into overdrive. It happened with ‘LED’, then ‘SUHD’, and now ‘QLED’, each time trying to sell LCD technology as "the next big thing". Just produce a real QLED TV and call a spade a spade....
    Measurements Out-of-box Calibrated
    Black level 0.05 cd/m2 0.03 cd/m2
    Black level (HDR) 0.17 cd/m2 0.17 cd/m2
    Brightness 250 cd/m2 203 cd/m2
    Max brightness (HDR) 1286 (770) cd/m2 770 cd/m2
    Contrast 7000:1 7400:1
    Contrast (HDR) 4580:1 4580:1
    Input lag 81 ms 21 ms (Game Mode)
    DCI-P3 98% -
    Rec.2020 70% -
    Power consumption Out-of-box Calibration
    SDR 160 W 130 W
    HDR 307 W 307 W
    Standby 1.0 W
    Time measurements Seconds
    Start-up (until responsive) 3s
    Start-up (until picture comes on) 2s
    Netflix app start-up 5s
    Youtube app start-up 3s
    Amazon app start-up 4s
    Google Play app start-up 7s
    Video file / source Specs Status
    Amazon 4K HDR 4K (3840x2160 pixels) – 10 bit colors - Rec.2020 color space – 4:2:0 subsampling – HEVC Works
    Netflix 4K HDR 4K (3840x2160 pixels) – 10 bit colors - Rec.2020 color space – 4:2:0 subsampling – HEVC Works
    YouTube 4K HDR 4K (3840x2160 pixels) – 10 bit colors - Rec.2020 color space – 4:2:0 subsampling – VP9 Profile2 Works
    Dubai 4K 4K (3840x2160 pixels) – 23.976fps – 10 bit colors - BT.709 color space – 4:2:0 subsampling – 51.4 Mbps bitrate – HEVC - .ts file Works
    Costa Rica 4K 4K (3840x2160 pixels) – BT.709 color space – 4:2:0 subsampling – 12.71 Mbps bitrate – VP9 - .mkv file Works
    Terrifying Pyroclast 4K 4K (3840x2160 pixels) – BT.709 color space – 4:2:0 subsampling – variable bitrate – VP9 - .mkv file Works
    Big Buck Bunny HD (.ts version) HD (1920x1080 pixels) – 8 bit colors - YUV color space – 4:2:0 subsampling – 2.5 Mbps bitrate – 60fps - HEVC - .ts file Works
    Big Buck Bunny HD HD (1920x1080 pixels) – 8 bit colors - YUV color space – 4:2:0 subsampling – 60fps - 2.2 Mbps bitrate – HEVC - .mkv file Works
    LG Arctique 4K 4K (3840x2160 pixels) – 8 bit colors – YUV color space – 4:2:0 subsampling – 50.0 Mbps bitrate – 29.970fps - AVC - .mp4 file Works
    Eutelsat 4K demo 4K (3840x2160 pixels) – 10 bit colors – YUV color space – 4:2:0 subsampling – 23.1 Mbps bitrate – 50fps - HEVC - .ts file Works
    TravelXP HLG 4K (3840x2160 pixels) – 50fps frame rate – 10 bit colors – BT.2020 color space – 4:2:0 subsampling – 20.7 Mbps bitrate – HEVC – HLG – .ts file Fails
    Ghost Towns 8K 8K (7680x4320 pixels) – variable frame rate – 8 bit colors - YUV color space – 4:2:0 subsampling – 20.7 Mbps bitrate – AVC - .mp4 file Fails
    HFR (100fps) test file 4K (3840x2160 pixels) – 100fps – 10 bit colors – Rec.2020 color space – 4:2:0 subsampling – 23.7 Mbps bitrate – HEVC - .ts file Fails
    Настройки (напомням, че са за конкретната тествана бройка)
    Group Setting Value
    Profile Movie
    Expert Backlight 12
    Brightness 0
    Contrast 95
    Sharpness 0
    Color 50
    Tone (G/R) R50
    Use picture settings All sources
    Digital clean view Off
    Auto Motion Plus Off / (0/0)
    Local Dimming Low
    HDMI UHD Color On for HDR HDMI sources
    Dynamic Contrast Off
    Color temp Warm2
    Gamma BT.1886 +1
    Color space User
    White balance 2-point
    -Red 7
    -Green 7
    -Blue 7
    +Red 10
    +Green -7
    +Blue 0
    #782
    svetlio1
    Е да де, ама като го писах беше толкова ..., то и сега пак е с 270лв по-ниска от тукашните технота .
    #783
    MU9000 : they replace the KS7500 of 2016 .
    The MU9005 range is close to the features of last year's SUHD models (KS7500). There is a VA 100 Hz panel natively 10 bits and the luminous peak is announced at 1000 cd / m². The series also adopts an Ultra filter and Auto Depth Enhancer technology to improve the contrast ratio. Beware, the 49-inch model uses only a simulated 10-bit panel (8-bit + FRC), but unlike the 49-inch MU7000, it is 100 Hz. For the rest, the features are identical to the MU7045 series.
    The differences of the 7045 range with the 7005 are subtle. Samsung is announcing a Micro Dimming Supreme UHD system (versus a Micro Dimming UHD for the MU7005 models), but both series share an Edge-Led backlight system, like all 2017 Samsung TVs mentioned in this article . The difference must therefore be made in the image processing, probably slightly more powerful. The fluidity index goes from the PQI 2300 (MU7005) to the PQI 2400. Be careful though, the 49-inch model is still limited by its 60 Hz panel.
    Samsung UE65MU7075 - Edge-LED, 8-bit + FRC, VA panel,
    This model is a variant of the MU7045, which is differentiated by its remote control. The MU7075 uses the same aluminum remote control as the QLed models.
    The real changes come with the MU7005 series. If the 49-inch model is to be avoided (the VA 60 Hz panel is identical to that of the MU6405 models), the 55, 65, 75 and 82-inch models feature a VA 100 Hz panel, making it possible to scan the backlight - And we know from experience that the Auto Motion Plus from Samsung is very powerful. This range is announced HDR 1000 compatible, which implies a higher luminous peak (announced at 600 cd / m²). Compared to the MU6000 series, there are many improvements: the audio system switches to 40 W, there are 4 HDMI ports and 1 USB 3.0 port in addition to the 2 USB 2.0 ports, and even a dual DVB-T tuner, cable and satellite. The MU7005 series also uses the Mini One Connect, which allows the connection to be offset. It is a real upscale,
    UHD TV (серии MU6100, MU6200, MU6400, MU6500, MU6600)
    Samsung UE-MU6600(curved) : the declination of the MU6500 with a darker frame.
    The MU6605 series is a variant of the MU6505 series. The three diagonals all have a curved VA slab and share the same characteristics. Samsung announces only a slightly faster PQI 1700 fluidity index, compared to a PQI 1600 for the MU6505 series. The most striking change is the color of the frame, here in imitation titanium with a matching foot.
    The MU6505 series is simply the curved version of the MU6405. There is therefore no change in the characteristics. On the other hand, all these models have a VA panel and there should be no surprise in terms of contrast.
    The MU6405 series shares the same features with a few details. The design is slightly different, since the borders are no longer black, but imitation aluminum. And this model embeds a DVB-S / S2 satellite tuner in addition to the DVB-T and cable tuner. As mentioned above, be careful when buying: the 49 and 55-inch versions are equipped with a PLS panel, the contrast of which is much lower than that of the other models in VA.
    All these models have a VA Ultra HD panel, except for the 55-inch PLS. The native frequency is blocked at 50 Hz, which prevents the use of backlight scanning to improve the sharpness of moving images. These models are HDR-compatible, but again, we can not expect much, because the maximum brightness is limited to around 350 cd / m². Moreover, these panels are not natively in 10 bits, but use the Frame Rate Control Technology (FRC ) method to achieve this. These televisions have two 10W speakers and a fairly comprehensive connectivity (3 x HDMI, YUV / Composite, 2 USB ports, 1 optical output, and Wi-Fi), but they still do not Headphone output. Samsung's Tizen operating system,
    Този пост е редактиран от hristoslav2; 07-08-17 в 17:48.
  5. Super Moderator
    Dec 2000
    Sofia
    #784
    Тея от Самсунг са .... По въпроса с бялото петно което ми се появи до долната рамка ето техният "експертен" отговор. Дал съм им още седмица да си помислят дали са го видяли и препращам писмото до КЗП както и ще пиша до централата им ...за кеф.
    Благодарим Ви, че се свързахте със Самсунг Електроникс България!
    Във връзка с Вашето запитване Ви информираме следното:
    Симптомът, от който се оплаквате не представлява дефект, това е нормална проява на всеки дисплей, който използва активна матрица TFT . Този феномен се забелязва по-добре в случаите, при които дисплеите използват LED посветка в сравнение с дисплеите, които използват подсветка с лампи (CCFL), защото светлинната интензивност, която са в състояние да произведат устройствата с LED подсветка е много по-голяма отколкото на тези, които са с лампи (обикновен LCD).
    Повишената интензивност на светлината предоставя по-добро качество на картината при условия на силно осветление в помещението (стая с естествена дневна светлина), условия, при които един обикновен LCD няма да възпроизведе толкова добра картина.
    За да се възползвате от съответстващо изображение и при условия на по-ниска осветеност на помещението е необходимо да намалите в съответствие интензитета на единицата за led осветеност (Backlight) .
    Използването на необосновано висока интензивност създава феномена, от който се оплаквате.
    В случай че се нуждаете от допълнителна информация, не се колебайте да се свържете с нас на адрес : serom.bg.contactus@samsung.com
    Ето го и дефекта:
    #785
    Направо ги прескачай и се свързвай с централата - то нищо чудно ако и лентата с диодите са лепили с двойно залепващо "тиксо" да се е отлепила и понадигнала в тая област и едав ли ще е сериозно усилие да се фиксира ама тия ботове от съпорта ги пишат едни ...
    Мен преди ония от ЛГ се опитаха да ме убеждават , че не мога да си настроя тв ... , когато те не бяха сложили 100хц панел
    bobkatagaz одобрява това.
    #786
    49MU6500....
    http://www.vybortv.ru/forum-o-televi...&t=1807#p64620
    Цитат Първоначално публикувано от stenly Виж публикацията
    Я пак?? Този симптом го има само при a-si TFT видеопанели използващи Edge-LED подсветка в долната част на рамката! Причината? Разместени лента със светодиоди, дифузьор...
    Тези с CCFL, HCFL подсветка не се прилагат в телевизорите от години, а причината да не се среща при тях е, че лампите се намират директно зад матрицата, а не в долната част на рамката.
    Повърхностно погледнато е така, но само ако се използва Direct-LED подсветка с локално затъмняване и голям брой клъстъри + променен алгоритъм за управление на субпикселите...в противен случай от това страда контраста.
    За да се възползвате от съответстващо изображение и при условия на по-ниска осветеност на помещението е необходимо да намалите в съответствие интензитета на единицата за led осветеност (Backlight).
    Това е най-лесното, като решение...ама нали така "ще пострада качеството на образа"- както се изразяват по горе.
    Това не е феномен, а ефект, причинен от дефект.
    Можеше и по-добра снимка да качиш иначе едва ли ще ти го ремонтират. Опасявам се, че в сервизите нямат право да отварят видеопанелите. Ако има техник във форума нека пише дали съм прав.
    LG, Sony и Sharp увеличават доставките на телевизори за сметка на Samsung и китайски производители
    По данни от отраслови източници, компаниите LG, Sony и Sharp увеличават доставките на телевизори за сметка на Samsung и големи китайски производители, които, напротив, са съкратили доставките.
    Компанията Samsung първоначално е планирала да пусне тази година 48 млн телевизора, което е малко повече от миналогодишният показател от 46 млн броя. Но както се твърди, южнокорейският производител се наложило да коригира плана до 45 или даже до 42 млн броя, доколкото се е снижило търсенето.
    Потвърждение на информацията за сега няма, тя даже е довела до повишаване на цените на LCD панелите за телевизори.
    Очаква се, че планът по доставките няма да бъде изпълнен не само от Samsung, но и пет от шестте големи китайски производители (изключвайки TCL).
    В същото време, на LG приписват увеличение в доставките до 29 млн броя. Миналата година същата компания пусна 28 млн телевизора. Очаква се, че компанията Sony ще увеличи доставките с 12 до 13 млн броя. За нарастването в доставките от тези производители помага интересът на потребителите към моделите с OLED екрани.
    С цел да увеличат доставките, Sony и LG са се обърнали към странични производители: Sony - към TPV Technology и Foxconn Electronics, които заедно ще пуснат тази година 6 млн телевизора под марката Sony; а LG - към TPV Technology, Skyworth и BOE Vision-electronic Technology, които ще пуснат 4 млн телевизора под марката LG.
    Компанията Sharp през тази година ще увеличи доставките на телевизори повече от два пъти - до 9-9,5 млн броя.
    LG, Sony, Sharp ramping TV shipments at expense of Samsung, China players
    SmartTv Service Remote Control
    https://play.google.com/store/apps/d...arov.smarttvrc
    2017: Обзор и тест Samsung 43M5500, 49M5500
    Този пост е редактиран от hristoslav2; 10-08-17 в 18:16.
    botev4o одобрява това.
    #787
    #788
    Samsung QE65Q7F : Test complet - Téléviseur - Les Numériques
    QE65Q7F: true 4K UHD (RGB), MVA panel, Edge LED (bottom-local dimming-vertical stripes) LCD, 100/120Hz with MCFI + flashing backlight, HDR10/HLG/HDR10 + compatible, WCG, Tizen os.
    Подсветка в долната част на рамката (долу в дясно, се вижда топлинната сигнатура на one conect box)
    Белият оптичен кабел с куплунга идващ от One Connect Box - внимавайте да не го прегъвате, в комплекта трябва да има специален защитен пластмасов извит улей, през който се прекарва кабела, когато трябва да направите 90 градусов завой.
    One Connect Box не става за други марки телевизори, защото няма HDMI изход (output).
    Универсалното дистанционно
    Smart Remote - Almighty one remote control | Samsung QLED TV
    Добър звук между 60Hz и 2000Hz за разбираем говор (гледа се зелената зона), но не достатъчно, така че е препоръчително да имате външно озвучаване(не говоря за компютърни колонки..)
    sourse: lesnumeriques.com
    Този пост е редактиран от hristoslav2; 07-08-17 в 22:42.
    #789
    Всички HDMI на всички марки тв обикновено са си "вход" - изход е само аудиото по ARC ..., каква ти е идеята с това дето си написал?
    #790
    svetlio1
    В случай, че искаш да ползваш One Connect Box с телевизор от друга марка. Бокса няма HDMI изход, а само специалният One Conect порт, и съответно такъв кабел.
    TV QLED (серии Q7F, Q7C, Q8, Q9) - HDR 2000 нита и 10-битов панел с Ultra HD Premium сертификат
    TVs – UHD Alliance
    HDR 10+(SMPTE 2094-40),
    Samsung QLED TV 2017 - european models
    Series Q
    Model
    ______________
    Type
    _________________
    bit
    __________
    Resolution
    _________
    Subpixel structure
    _________
    Panel frequency MCFI
    Motion Clarity Frame Interpolation
    BFI
    black frame insertion
    Backlight
    _______________
    HDR
    _________
    Series Q
    Model
    ______________
    QE-88Q9F
    a-si TFT MVA QDCF
    (Samsung)
    10-bit 3840x2160 RGB 120/100Hz Yes Yes Edge LED
    (right-left, local dimming)
    2000cd/m2 QE-88Q9F
    QE-75Q9F
    a-si TFT MVA QDCF
    (Samsung)
    2000cd/m2 QE-75Q9F
    QE-65Q9F
    a-si TFT MVA QDCF
    (Samsung)
    2000cd/m2 QE-65Q9F
    QE-75Q8C
    a-si TFT MVA QDCF
    (bottom)
    1500cd/m2 QE-75Q8C
    QE-65Q8C
    a-si TFT MVA QDCF
    (Samsung)
    10-bit 3840x2160 RGB 120/100Hz Yes Yes Edge-LED
    (bottom)
    1500cd/m2 QE-65Q8C
    QE-55Q8C
    a-si TFT MVA QDCF
    (Samsung)
    (bottom)
    1500cd/m2 QE-55Q8C
    QE-65Q7C
    a-si TFT MVA QDCF
    (Samsung)
    (bottom)
    1500cd/m2 QE-65Q7C
    QE-55Q7C
    a-si TFT MVA QDCF
    (Samsung)
    (bottom)
    1500cd/m2 QE-55Q7C
    QE-49Q7C
    a-si TFT MVA QDCF
    (Samsung)
    (bottom)
    1500cd/m2 QE-49Q7C
    QE-75Q7F
    a-si TFT MVA QDCF
    (Samsung)
    (bottom-12 zones)
    1500cd/m2 QE-75Q7F
    QE-65Q7F
    a-si TFT MVA QDCF
    (65A1MU8XM-Samsung)
    (bottom-12 zones)
    1500cd/m2 QE-65Q7F
    QE-55Q7F
    a-si TFT MVA QDCF
    (Samsung)
    (bottom-12 zones)
    1500cd/m2 QE-55Q7F
    QE-49Q7F a-si TFT MVA QDCF
    (Samsung)
    (bottom-12 zones)
    1500cd/m2 QE-49Q7F
    Series Premium UHD TV Series
    QE-65MU9000C a-si TFT MVA QDEF
    (bottom)
    1000cd/m2 QE-65MU9000C
    QE-55MU9000C a-si TFT MVA QDEF
    (bottom)
    1000cd/m2 QE-55MU9000C
    QE-49MU9000C a-si TFT MVA QDEF
    8-bit + FRC 3840x2160 RGB 120/100Hz Yes Yes Edge-LED
    (bottom)
    1000cd/m2 QE-49MU9000C
    QE-85MU8000 a-si TFT MVA QDEF (Samsung) 8-bit + FRC 3840x2160 RGB 120/100Hz Yes Yes Edge-LED
    (bottom + local dimming)
    1000cd/m2 QE-82MU8000
    QE-75MU8000 a-si TFT MVA QDEF (Samsung) 8-bit + FRC 3840x2160 RGB 120/100Hz Yes Yes Edge-LED
    1000cd/m2 QE-75MU8000
    QE-65MU8000 a-si TFT MVA QDEF
    (bottom)
    1000cd/m2 QE-65MU8000
    QE-55MU8000 a-si TFT MVA QDEF
    1000cd/m2 QE-55MU8000
    QE-49MU8000 a-si TFT MVA QDEF (Samsung) 8-bit + FRC 3840x2160 RGB 60/50Hz Yes Yes Edge-LED
    1000cd/m2 QE-49MU8000
    QE-65MU7000 a-si TFT MVA QDEF
    (bottom)
    1000cd/m2 QE-65MU7000
    QE-55MU7000 a-si TFT MVA QDEF
    (bottom)
    1000cd/m2 QE-55MU7000
    QE-49MU7000 a-si TFT MVA QDEF (49А6U0SM - Samsung) 8-bit + FRC 3840x2160 RGB 60/50Hz Yes Yes Edge-LED
    (bottom)
    1000cd/m2 QE-49MU7000
    QE-40MU7000 a-si TFT MVA QDEF (Samsung) 8-bit + FRC 3840x2160 RGB 60/50Hz Yes Yes Edge-LED
    (bottom)
    1000cd/m2 QE-40MU7000
    Series UHD TV Series
    QE-65MU6600 a-si TFT MVA
    (Samsung)
    8-bit 3840x2160 RGB 60/50Hz - Yes Edge LED
    (bottom)
    320cd/m2 QE-65MU6600
    QE-49MU6600 a-si TFT MVA
    (bottom)
    320cd/m2 QE-49MU6600
    QE-49MU6500 a-si TFT MVA
    (bottom)
    320cd/m2 QE-49MU6500
    QE-65MU6400 a-si TFT MVA
    8-bit + FRC 3840x2160 RGB 60/50Hz - Yes Edge LED
    (bottom)
    320cd/m2 QE-65MU6400
    QE-55MU6400 a-si TFT IPS(PLS)
    (bottom)
    320cd/m2 QE-55MU6400
    QE-49MU6400 a-si TFT IPS(PLS)
    (49B6AUOKK-BOE)
    (bottom)
    320cd/m2 QE-49MU6400
    QE-40MU6400 a-si TFT MVA
    (Samsung)
    (bottom)
    320cd/m2 QE-40MU6400
    QE-65MU6200 a-si TFT MVA
    (Samsung)
    (bottom)
    320cd/m2 QE-65MU6200
    QE-55MU6200 a-si TFT MVA
    (Samsung)
    (bottom)
    320cd/m2 QE-55MU6200
    QE-49MU6200 a-si TFT MVA
    (bottom)
    320cd/m2 QE-49MU6200
    QE-55MU6100 a-si TFT IPS
    (bottom)
    320cd/m2 QE-55MU6100
    QE-50MU6100 a-si TFT MVA
    (bottom)
    320cd/m2 QE-50MU6100
    QE-43MU6100 a-si TFT ?
    (bottom)
    320cd/m2 QE-43MU6100
    QE-40MU6100 a-si TFT MVA
    (Samsung)
    (bottom)
    320cd/m2 QE-40MU6100
    QE-65MU6000 a-si TFT MVA
    (bottom)
    320cd/m2 QE-65MU6000
    QE-55MU6000 a-si TFT IPS
    (bottom)
    320cd/m2 QE-55MU6000
    QE-49MU6000 a-si TFT MVA
    (Samsung)
    (bottom)
    320cd/m2 QE-49MU6000
    QE-40MU6000 a-si TFT MVA
    (Samsung)
    (bottom)
    320cd/m2 QE-40MU6000
    Series Full HD TV Series
    QE-55M6300 a-si TFT ??
    8-bit 1920x1080 RGB 60/50Hz - Yes Edge LED
    (bottom)
    ---cd/m2 QE-55M6300
    QE-49M6300 a-si TFT ??
    (bottom)
    ---cd/m2 QE-49M6300
    QE-55M5500 a-si TFT ??
    (bottom)
    ---cd/m2 QE-55M5500
    QE-49M5500 a-si TFT ??
    (bottom)
    ---cd/m2 QE-49M5500
    QE-43M5500 a-si TFT MVA
    (43L6AF0KK-AUO)
    (bottom)
    ---cd/m2 QE-43M5500
    QE-32M5500 a-si TFT MVA
    (bottom)
    ---cd/m2 QE-32M5500
    Този пост е редактиран от hristoslav2; 10-08-17 в 18:55.
    May 2010
    #791
    Вчера ми изписа, че има нов ъпдейт. Някой инсталирал ли е? Впечатления?
  15. Super Moderator
    Dec 2000
    Sofia
    #792
    120.1 ...инсталирах го, нищо ново/различно не видях. youtube продължава при мен да се дъни.
    May 2010
    #793
    Той и при мен не е спрял. [emoji3]
  17. Senior Member Аватара на svetlio1
    #794
    В какъв смисъл се дъни?
    От два дни пускам клипове на 50MU6102 и не съм имал проблеми ... засега
  18. Super Moderator
    Dec 2000
    Sofia
    #795
    След известно време не мога да скролвам по клипчетата. Просто маркера стои на един клип и само него мога да пускам. Проблема се решава след рестарт на телевизора. След няколко часа, пак същото.
    Отговори: 14
    Последно: 08-06-19, 13:13
  2. Samsung телевизори 2016
    Отговори: 821
    Последно: 01-01-17, 16:42
  3. Samsung Телевизори 2015
    Отговори: 1121
    Последно: 02-01-16, 08:17
  4. Има ли пасивни 3D телевизори на Samsung?
    Последно: 21-10-14, 22:00
  5. Отговори: 6
    Последно: 16-08-11, 13:39
