Страница 29 от 33 ПърваПърва ... 192728293031 ... ПоследноПоследно
Резултати от 421 до 435 от общо 494
Like Tree50Одобрявам
Samsung телевизори 2019
    Sep 2019
    #421
    Отговор: Samsung телевизори 2019
    Привет! Как се разбира дали телевизорът е 100Hz, моля за извинение ако тук не е темата за това!
    #422
    Само от менюто и спецификациите.
    Най-евтиният е Samsung 55RU8002
    #423
    Text rendering doesn’t look too good on VA-QLED display panels.
    VA-QLED displays make look good with high-resolutions (e.g. 4K).
    However, the pixel density and quantum pixels used in the Samsung's VA-QLED displays creates an obvious “screen door effect” in the larger versions of the panels where you can see individual pixels even at a normal viewing distance. A shout out to the IGN review for noticing this problem.
    You can see the outline of the pixels on a VA-QLED display, even at a normal viewing distance especially on areas of solid color.
    This isn’t super-appealing but you won’t really notice it on the 60-cm model unless you stare at large areas of solid color all day. The real problem with this VA-QLED panel is that regular text looks truly awful. Modern web design trends tend to lean towards slightly grayer text, which the unusual quantum-sub-pixels produces by turning off half of the whole pixel. This leaves visible white lines striking through the text since every other row of quantum pixels are turned halfway off.
    The following contrast-adjusted photo shows the text “VA-QLED” in gray photographed on the said panel. Click-through to the larger version to see it in greater detail. Note how the half-height sup-pixels negatively affect the gray text rending by introducing white dots scattered throughout the text.
    Gray text
    The next photo shows the same as the previous one, but with black text. Here, you can see how the half-height sub-pixels negatively affect the anti-aliased outer-edges of each letter glyph.
    Black text
    You can also see a larger version of the feature photo from the top of the article if you prefer a non-color-adjusted version where you can see even more details.
    You can change the TrueType font smoothing and anti-aliasing settings in Windows all you want. You won’t find a setting that works well with this type of display panel.
    How you perceive this display panel design-decision depends on your eye-sight and how you perceive the world. When I look at a sentence and not individual letters, I see the white quantum sub-pixel as several white lines striking through the text. My significant other has somewhat worse eyesight than me and claims to not notice it as much.
    You can read up on and study a ton of detailed technical reviews of this monitor model and display panel type. It’s been on the market since late 2016. However, you won’t find any acknowledgment of the text rendering issue I’ve mentioned here. It’s present throughout the Windows 10 user-interface with the default settings and even Google Search Result Pages are badly affected by it. You can find some mentions of it in some of the deeper corners of places like Reddit, though.
    https://www.ctrl.blog/entry/va-qled-text-rendering.html
    https://www.ign.com/articles/2018/09...monitor-review
    Dec 2019
    #424
    Здравейте!
    От три дни имам телевизор Samsung QLED 4K TV QE43Q60R 43" 4K Ultra HD.Ползвам телевизия и интернет от А1.Аз нямам големи претенции откъм допълнителни екстри.Ясно ми е,че това е базовата версия.Ползвам го за спорт,филми и YouTube.Няма какво да се лъжем,картината е под всякаква критика, единствено на HD каналите се държи прилично,при клипчета във формат 4К е много добре.Не ми харесва,че подсветката му не е равномерна и в горните краища на тъмно свети.Има ли някакъв начин чрез настройки това да се премахне и още едно питане имам.На търсачката в YouTube може ли да се сменя на български, защото сега има само опция на латиница?
  6. Member Аватара на brabusbg
    Nov 2010
    #425
    Търсачката на YouTube е само на латиница.
    Изпратено от моят SM-G950F с помощта на Tapatalk
    Dec 2019
    #426
    Благодаря!
  9. Senior Member Аватара на sony 1
    Dec 2016
    #427
    Цитат Първоначално публикувано от Росен Виж публикацията
    Здравейте!
    Eдинствената оправия с подсветката е гледане на някакво осветление, друг начин няма.
    Dec 2019
    #428
    Не е чак толкова дразнещо,ако не се загледаш.Аз друго се питам,от Самсунг едва ли не знаят че матриците им светят като улични лампи,защо тогава не ги правят както трябва.Все пак дали моделът е базов,или висока серия не би трябвало да оптрделя колко равномерна ще е подсветката.Все пак не ти го дават даром.
  11. Member Аватара на brabusbg
    Nov 2010
    #429
    Че то проблема не е само при Самсунг, а при всички LCD телевизори.
    Dec 2019
    #430
    Е,този нали уж е QLED,не би ли трябвало тук вече всичко да е изчистено откъм равномерна подсветка.Няма ли някой,който да следи за качеството,което се предлага на пазара,или тази осветеност е в рамките на някакви допустими граници?
    #431
    QLED си е LCD тв , а щом има подсветка може да се очаква да има неравномерно осветяване - въпрос на късмет в конкретна бройка . В доста от случаите се дължи и на неправилно транспортиране и от там размести/изкривени отражатели ...
    Dec 2019
    #432
    Да кажем,че някои при транспортиране получават дефекти,но при самото им производство не се ли тестват преди да се пуснат на пазара?
    Nov 2016
    #433
    Малко тежки думи са това че "картината е под всякаква критика" , q60 е базов модел от QLED серията, а не базов модел като цяло... И все телевизора няма Local dimming.
    Sent from my SM-N975F using Tapatalk
    Dec 2019
    #434
    Не казвам,че вината е в телевизора,а в доставчика,защото,както казах по-горе,на Hd каналите се държи добре.Аз също имах предвид,че е базова серия от QLed моделите.
    Nov 2016
    #435
    Така вече звучи по-добре. Тук всичките доставчици са такива май... Аз гледах NOVA на C9 и Q90R 65 инчови варианти и положението беше трагично. Чак от дистанция около 3 метра не се виждаха проблемите.
    П.П Някой знае ли как може да се гледа HDR10+ филм без блу рей плеър? Изтеглих един на който пише че е HDR10+ ,но телевизора показваше само HDR10?
  1. Избор на климатик '2019
    Отговори: 3063
    Последно: 04-01-20, 10:11
  2. Samsung телевизори 2018
    Отговори: 443
    Последно: 02-01-19, 15:43
  3. Отговори: 1
    Последно: 02-01-19, 09:26
  4. Samsung Телевизори 2015
    Отговори: 1121
    Последно: 02-01-16, 08:17
    Последно: 21-10-14, 22:00
