Страница 15 от 64 ПърваПърва ... 5131415161725 ... ПоследноПоследно
Резултати от 211 до 225 от общо 953
Like Tree58Одобрявам
AV ресивъри Yamaha / FAQ - на първа страница ,обсъждане ,мнения
    Jan 2010
    #211
    Re:AV ресивъри Yamaha / FAQ - на първа страница ,обсъждане ,мнения
    Ето отговор на Ямаха:
    What is the difference between the RX-V line and the HTR line AV receivers ?
    There are many similarities between these two product lines. The RX-V line and the HTR line are produced in the same Yamaha factory using the same high quality parts throughout. The RX-V and equivalent HTR models have the same warranty periods; the same manufacturers suggested retail price, the same features, and the same remote control units. There is a cosmetic difference found on the front panels of these two lines. The RX-V line maintains the traditional white colored lettering normally found on most Yamaha components, while the HTR line provides a slightly different approach. Yamaha has created a new look by using gold colored lettering in selected areas on the HTR receiver series. However, both the RX-V line and the HTR line feature the same high quality black metal front panel construction. The amplifiers in the HTR and RX-V units are identical but rated differently to comply with the accepted measurement standards of their respective channels of distribution. Both ratings are FTC approved and are designed to handle the dynamics of today's audio and video sources. The RX-V line has the power amplifiers rated from 20-20000 Hz. The HTR line has the power amplifiers rated at 1000 Hz. Both lines can reproduce the full frequency response of 20-20000 Hz. The RX-V line is typically sold through Yamaha authorized audio/video specialty retailers, and is not available for mail order sales. The HTR line is sold through mass merchants, catalog retailers, and department stores. You may also purchase the HTR line through the mail. All transactions must be done through the authorized Yamaha dealer network. Any purchase made from an unauthorized dealer/retailer voids the Yamaha manufacturer's warranty.
    С една дума са еднакви като RX са бутикови,a HTR се продават и по пощата
    Но и аз си мисля,че HTR са Китайски,a RX са Малайзийски.
    Ето линк към сайта: http://faq.yamaha.com/us/en/article/..._av_receivers_
  3. Junior Member
    Jun 2010
    #212
    Да, ама не! Мойто RX-V е Китайско
    Jan 2009
    #213
    Някой има ли представа за модела RX-V371, кои други дистанционни стават освен стандартното за него RAV-333. Искам да си намеря такова което да управлява и ТВ и други.
    Засега съм намерил RAV 334, 432, 436 в ebay не са от най-евтините, но не знам в България да се продават.
  5. Moderator
    Aug 2006
    #214
    Купи си едно Logitech Harmony от евтините и ще си управляваш всичко 100 пъти по-удобно и лесно.
    http://technomarket.bg/products/0909...ote-915-000134
    Jan 2009
    #215
    Това ще може ли да управлява и WD TV LIVE HUB и сателитния приемник на Булсатком?
  7. Moderator
    Aug 2006
    #216
    Всичко управлява и не само това, а и можеш да си направиш макроси - да ти пуска всички нужни уреди с една команда на нужните входове.
    Примерно макрос за гледане на филми от WDTV - пуска телевизора на вход HDMI1, пуска ресийвъра на вход DVD, пуска плеъра. Докато си в него си настройваш с Volume да контролира увеличаването на ресийвъра, стрелките, ОК .. да са на плеъра бутоните.... По този начин.
    Jan 2009
    #217
    Ето това вече наистина ми хареса. Нали има описание как се прави това с макросите ?
  10. Moderator
    Aug 2005
    #218
    Но по-добре модел Хармъни с дисплей , когато свършат съвпадащите се бутони да си добавяш тези ,които липсват . Има тема за дистанционните , нека да не се разводнява тази .
    Jan 2010
    #219
    Колега,
    в Lidl имаше за 15лв. универсално-обучаемо с макроси-SilverCrest.Аз си взех от любопитство и за тази цена е просто перфектно.Не е като Лоджитека,но върши работа
    Apr 2009
    #220
    Здравейте!Купих си ресивер RX-V371.При включването му се чуват три превключвания на релета - последователно,а при гасене го правят едновременно.Нормално ли е това и трябва ли да се чуват изобщо?От всичките ми уреди при които се чуват такива превключвания 2 LCD телевизора , уредба и домашно кино е само по едно превключване и то тихичко.Може би защото кутията на ресивера е голяма и метална ...
  13. CP
    CP е офлайн
    Oct 2005
    #221
    Вероятно след ресивъра ти се включва захранването на тонколоните? При мен също е така, чуват се две последователни прещраквания след включване, а при изключване се гасят едновременно.
  15. Moderator
    Aug 2005
    #222
    Нормално е.
  16. Junior Member
    Apr 2006
    #223
    имам RX-V467 към който наскоро закачих плазма Панасоник с ARC / audio return channel / , чрез HDMI 1.4 кабел. След минаване през сетъп и включване на ARC в ресивъра имам звук от телевизора. Проблема е , че когато спра телевизора и го включа отново - нямам звук. Изключвам и включвам отново ARC от ресивъра и звука тръгва. Има ли начин това да става автоматично а не да го правя при всяко включване на телевизора?
  17. CP
    CP е офлайн
    Oct 2005
    #224
    Този проблем и аз го имам, засега не съм намерил решение /не че съм търсил много/. Поради което пускам винаги последно ресивъра. Ако междувременно сменям входовете на телевизора /да превключа от телевизия на HD плеър през HDMI или обратно/ - звукът не се губи, ресивърът се ориентира автоматично. Ако някой подскаже решение и аз ще съм благодарен.
    Apr 2009
    #225
    Аз съм с Samsung le40d6500 , Yamaha RX-V371 ,Philips BDP5200.Свързани са с HDMI 1.4.На всички устройства са пуснати всички опции за HDMI-CEC.Всичко работи нормално ако са включени и трите устройства.Варианта при който първо е пуснат телевизора , после решаваш да пуснеш звука през ресивера и го включваш не става - при включване на ресивера звука от телевизора спира ,но не излиза през външните колони.В момента в който пусна и плеъра автоматично всички изходи и входове се пренасочват и всичко е ОК.Когато плеъра е изключен от мрежата всичко си работи пак нормално и ARC си е ОК.Тогава ресивера се разпознава като RX-V371.Предполагам ,че има някакъв конфликт между устройствата.Когато и плеъра е включен /в мрежата/ в менюто на телевизора плеъра си излиза с точното име BDP5200 ,а ресивера като reciever.Преди малко в менюто на плеъра намерих опция fast wake up.Като я включих вече той се разпознава като blu ray player а ресивера като RX-V371 и всичко работи както трябва.Винаги има вариант да включа оптичен кабел между телевизора и ресивера ,ама защо?Нещо което ми направи впечатление ,че в инструкциите на ямахата за управлението през HDMI пише ,че не става за Viera link ,което май е при панасоник!
  1. Отговори: 154
    Последно: 17-07-26, 16:23
  2. Отговори: 287
    Последно: 16-12-25, 17:50
  3. Отговори: 43
    Последно: 01-02-24, 18:27
  4. Отговори: 93
    Последно: 16-05-22, 21:22
  5. Отговори: 3
    Последно: 04-04-15, 19:22
